This is a translation of https://forum.manjaro.org/t/manjaro-kde/110567
Night mode on Manjaro KDE doesn’t seem to work depending on geographic location
I installed gpsd
(which in the past is by default in minimum ISO) but it still not working
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:42: TypeError: Cannot call method 'destroy' of undefined
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:227: TypeError: Cannot read property 'latitude' of undefined
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:345: TypeError: Cannot read property 'longitude' of undefined
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:344: TypeError: Cannot read property 'latitude' of undefined
file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
qml: The item SubCategoryPage_QMLTYPE_78(0x55efdcfd7920) is already in the PageRow
org.kde.plasma.dataengine.geolocation: gpsd not found
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:223:13: QML Label: Binding loop detected for property "verticalAlignment"
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:87:9: QML FormLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:344: TypeError: Cannot read property 'latitude' of null
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:345: TypeError: Cannot read property 'longitude' of null
file:///usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml:227: TypeError: Cannot read property 'latitude' of null
