Hi All -
I’m having ongoing headaches working with systemd. I had my setup working flawlessly and something happened (no idea what).
My basic setup:
Unraid server with an array and a couple of external hard drives
Local laptops running Manjaro
Brief Description of Problem: I have my server array mounting fine locally with systemd but the externals are not. Interestingly enough, if I navigate to “Network” in Dolphin, I can see all the shares fine.
Array SystemD .automount file
GNU nano 8.3 mnt-Tower-Media.automount
[Unit]
Description=Automount Media mount from unRaid tower
ConditionPathExists=/mnt/Tower/Media
[Automount]
Where=/mnt/Tower/Media
TimeoutIdleSec=20
[Install]
WantedBy=multi-user.target
.mount file:
GNU nano 8.3 mnt-Tower-Media.mount
[Unit]
Description=Media folder mounted via NFS from Tower unRaid.
After=network.target
[Mount]
What=192.168.0.245:/mnt/user/Media
Type=nfs
Options=_netdev,auto
Again - this works perfect.
Then my expansion external:
GNU nano 8.3 mnt-Tower-Expansion1.automount
[Unit]
ConditionPathExists=/mnt/Tower/Expansion1
[Automount]
Where=/mnt/Tower/Expansion1
TimeoutIdleSec=20
[Install]
[Unit]
[Mount]
What=192.168.0.245:/mnt/disks/Expansion1
Type=nfs
I’ve confirmed that the share is enabled on the Expansion1 external drive from within Unraid. And, this appears to be confirmed as I can navigate fine via Dolphin → Network.
Help appreciated as this is creating downstream effects on my home setup…
