Recently updated firmware on T14 ThinkPad Gen 6 (Intel / Lunar Lake) and am periodically experiencing huge spikes in RAM/CPU due to journald-systemd. Monitoring journalctl -f during the spasm seems to reveal a bunch of errors related to wifi and bluetooth. e.g.
kernel: iwlwifi 0000:00:14.3: Error sending SYSTEM_STATISTICS_CMD: time out after 2000ms.
kernel: iwlwifi 0000:00:14.3: Current CMD queue read_ptr 65 write_ptr 66
kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 101.6ef20b19.0 bz-b0-fm-c0-101.ucode
kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 21s! [Socket Thread:1795]
kernel: CPU#0 Utilization every 4000ms during lockup:
kernel: Bluetooth: hci0: Timeout (500 ms) on tx completion
kernel: Bluetooth: hci0: Failed to send frame (-62)
kernel: Bluetooth: hci0: sending frame failed (-62)
Around the same time (~1 week ago) I also installed sof-firmware and switched from pulseaudio to pipewire.
Currently on kernel 6.18 where my bluetooth and audio works as opposed to 6.12 where it doesn’t. I’m guessing it is simply that the kernel hasn’t caught up to the firmware yet. Until that time, would there be any workaround to stop this behavior ?
Kernel: 6.18.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=67e4e047-f3e8-4b4f-bae3-e4eba6537a99 rw apparmor=1
security=apparmor udev.log_priority=3 snd_intel_dspcfg.dsp_driver=1
resume=UUID=6fc4dcf7-27d8-4b3d-9773-b7dc4be8f087
Desktop: i3 v: 4.25.1 with: polybar tools: avail: i3lock,
xfce4-screensaver, xss-lock vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 21QGCTO1WW v: ThinkPad T14 Gen 6
Mobo: LENOVO model: 21QGCTO1WW v: SDK0T76574 WIN
serial: <superuser required> part-nu: LENOVO_MT_21QG_BU_Think_FM_ThinkPad
T14 Gen 6 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
v: N4HET23W (1.11 ) date: 01/07/2026
Mod edit: Corrected code formatting.
BG405
6 March 2026 15:36
2
Hi @_dunce , could you provide the full output of inxi -zv8 rather than that truncated part? This might provide some useful information. No audio expert myself, but it often reveals something.
Sure, below:
base: Arch Linux
ID-1: BAT0 charge: 45.5 Wh (81.4%) condition: 55.9/57 Wh (98.1%)
power: 42.9 W volts: 17.81 min: 15.6 model: Sunwoda 5B11M90127 type: Li-poly
serial: <filter> charging: status: charging control: start: 0% end: 100%
cycles: 230
System RAM: total: 32 GiB available: 30.87 GiB used: 7.9 GiB (25.6%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 4 GiB speed: 8533 MT/s volts: curr: 0.5 width (bits): data: 16
total: 16 manufacturer: Micron Technology part-no: N/A serial: <filter>
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: Intel Core Ultra 7 258V bits: 64 type: MCP arch: Lunar Lake
level: v3 note: check built: 2024+ process: TSMC n3b (3nm) family: 6
model-id: 0xBD (189) stepping: 1 microcode: 0x125
Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 smt: <unsupported> cache:
L1: 832 KiB desc: d-4x32 KiB, 4x48 KiB; i-8x64 KiB L2: 14 MiB
desc: 4x2.5 MiB, 1x4 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4574 min/max: 400/4700:4800:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 4574 2: 4574 3: 4574
4: 4574 5: 4574 6: 4574 7: 4574 8: 4574 bogomips: 52838
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lam lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg
wbnoinvd x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Lunar Lake [Intel Arc Graphics 130V / 140V] vendor: Lenovo
driver: xe v: kernel arch: Xe2 process: TSMC n3 (3nm) built: 2024+ ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:64a0
class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 5986:11af
Display: x11 server: X.org v: 1.21.1.21 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: iris gpu: xe display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x0c3f built: 2023 res:
mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 161 gamma: 1.2 chroma: red:
x: 0.600 y: 0.369 green: x: 0.353 y: 0.561 blue: x: 0.149 y: 0.149 white:
x: 0.322 y: 0.349 size: 302x188mm (11.89x7.4") diag: 356mm (14")
ratio: 16:10 modes: 1920x1200
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (LNL)
device-ID: 8086:64a0 memory: 30.14 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel Lunar Lake-M HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_lnl bus-ID: 00:1f.3
chip-ID: 8086:a828 class-ID: 0403
API: ALSA v: k6.18.12-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel BE201 320MHz driver: iwlwifi v: kernel port: N/A
bus-ID: 00:14.3 chip-ID: 8086:a840 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:550f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-1: Intel driver: btintel_pcie v: 0.1 bus-ID: 00:14.7
chip-ID: 8086:a876 class-ID: 0d11
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 476.94 GiB used: 248.06 GiB (52.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPETJ512MMW1MDQ size: 476.94 GiB block-size: physical: 512 B
fw-rev: 1.0Q06B0 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 439.47 GiB size: 431.5 GiB (98.19%)
used: 246.29 GiB (57.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 67e4e047-f3e8-4b4f-bae3-e4eba6537a99
used: 404 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: EA3A-8457
ID-1: swap-1 type: partition size: 37.18 GiB used: 1.77 GiB (4.8%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 6fc4dcf7-27d8-4b3d-9773-b7dc4be8f087
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 1024 KiB fs: ext4 label: N/A
uuid: b968f6f2-ecc5-4a5f-8adf-ff10e83f3aa2
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 8 rev: 2.0
Device-1: 3-4:2 info: Bison Integrated Camera type: video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:11af class-ID: fe01 serial: <filter>
Hub-4: 3-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Packages: pm: pacman pkgs: 1527 libs: 402 tools: pamac
1: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
2: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
3: https://mirror.23m.com/manjaro/stable/$repo/$arch
4: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
7: https://manjaro.kurdy.org/stable/$repo/$arch
8: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
9: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 400
1: cpu: 7.4% command: firefox pid: 76101 mem: 675.0 MiB (2.1%)
2: cpu: 7.1% command: firefox pid: 1778 mem: 786.0 MiB (2.4%)
3: cpu: 3.3% command: firefox pid: 74318 mem: 440.2 MiB (1.3%)
4: cpu: 1.2% command: wireplumber pid: 1217 mem: 34.4 MiB (0.1%)
5: cpu: 1.0% command: firefox pid: 2167 mem: 905.7 MiB (2.8%)
Memory top: 5 of 400
1: mem: 905.7 MiB (2.8%) command: firefox pid: 2167 cpu: 1.0%
2: mem: 834.0 MiB (2.6%) command: firefox pid: 2078 cpu: 0.3%
3: mem: 786.0 MiB (2.4%) command: firefox pid: 1778 cpu: 7.1%
4: mem: 756.0 MiB (2.3%) command: firefox pid: 2378 cpu: 0.7%
5: mem: 675.0 MiB (2.1%) command: firefox pid: 76101 cpu: 7.4%
Processes: 400 Power: uptime: 1d 5h 42m states: freeze,mem,disk
suspend: s2idle wakeups: 6 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.33 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 259
Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.9
running-in: alacritty inxi: 3.3.40
jofi
6 March 2026 17:36
4
I think older kernel versions would receive only bug fixes. Since Lunar Lake is still relatively new i would rather try the latest kernel release which would be 6.19.*.
Seems to be related to your Intel BE201 wifi card. There are a few other similar reports floating around. Being a relatively new card (First supported kernel is 6.18 - https://www.intel.com/content/www/us/en/download/824804/intel-wireless-wi-fi-drivers-for-linux.html ) there may be some bugs?! I’d be inclined to report it to Intel.
