I updated today my system and I experienced a few hours later the first coredump.
Then I get logged out. Afterwards I can login normal but I can trigger a core dump with logout with opening the gnome terminal as first application or opening and closing gedit.
I dont know what to do. All Gnome extensions are disabled.
I am not sure which logs are necessary, I can provide other if necessary.
inxi -Fza
System: Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=e92ea224-e857-4963-b1ff-0c3098d7b8d2 rw quiet apparmor=1 security=apparmor resume=UUID=67153e10-2f09-4492-915b-2b3cd215f345 udev.log_priority=3 Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux Machine: Type: Laptop System: Hewlett-Packard product: HP 350 G2 v: 098F200000000010000600087 serial: <filter> Chassis: type: 10 serial: <filter> Mobo: Hewlett-Packard model: 803B v: KBC Version 46.11 serial: <filter> UEFI: Insyde v: F.12 date: 03/23/2015 CPU: Info: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F L2 cache: 4096 KiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19161 Speed: 953 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798 Vulnerabilities: Type: itlb_multihit status: KVM: Split huge pages Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds mitigation: Clear CPU buffers; SMT vulnerable Type: meltdown mitigation: PTI Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling Type: srbds mitigation: Microcode Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1616 Device-2: Advanced Micro Devices [AMD/ATI] Jet XT [Radeon R5 M240] vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu bus ID: 09:00.0 chip ID: 1002:6664 Display: x11 server: X.Org 1.20.9 compositor: gnome-shell driver: ati,modesetting,radeon alternate: fbdev,intel,vesa display ID: :0 screens: 1 Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x286mm (26.7x11.3") s-diag: 735mm (28.9") Monitor-1: HDMI-1 res: 2560x1080 hz: 60 dpi: 95 size: 681x287mm (26.8x11.3") diag: 739mm (29.1") OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.2.3 direct render: Yes Audio: Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0 Sound Server: ALSA v: k5.4.80-2-MANJARO Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 5000 bus ID: 01:00.0 chip ID: 10ec:8168 IF: enp1s0 state: down mac: <filter> Device-2: Broadcom and subsidiaries BCM43228 802.11a/b/g/n driver: wl v: kernel modules: bcma port: 5000 bus ID: 02:00.0 chip ID: 14e4:4359 IF: wlp2s0 state: up mac: <filter> Drives: Local Storage: total: 991.14 GiB used: 44.27 GiB (4.5%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/sda vendor: A-Data model: SP900 size: 59.63 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> scheme: GPT ID-2: /dev/sdb vendor: HGST (Hitachi) model: HTS541010A9E680 size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: A710 scheme: GPT Partition: ID-1: / raw size: 53.39 GiB size: 52.31 GiB (97.96%) used: 44.27 GiB (84.6%) fs: ext4 dev: /dev/sda2 Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default) ID-1: swap-1 type: partition size: 5.93 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 Sensors: System Temperatures: cpu: 50.0 C mobo: 49.0 C gpu: radeon temp: 45.0 C Fan Speeds (RPM): N/A Info: Processes: 204 Uptime: 4h 33m Memory: 7.68 GiB used: 2.17 GiB (28.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1412 apt: 0 pacman: 1395 lib: 386 flatpak: 17 Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.08
sudo journalctl -S -15m
Code at Pastebin com sudo journalctl -S -7m
latest two coredumpctl info systemd
PID: 9383 (systemd)
UID: 1000 (stoefelz)
GID: 1000 (stoefelz)
Signal: 11 (SEGV)
Timestamp: Sat 2020-11-28 21:26:30 CET (22min ago)
Command Line: /usr/lib/systemd/systemd --user
Executable: /usr/lib/systemd/systemd
Control Group: /user.slice/user-1000.slice/user@1000.service/init.scope
Unit: user@1000.service
User Unit: init.scope
Slice: user-1000.slice
Owner UID: 1000 (stoefelz)
Boot ID: 41e02e6c192744068107a09ac47c704b
Machine ID: e6b0dd2c566a4e93a8f889dd11126009
Hostname: stoefelz-notebook
Storage: /var/lib/systemd/coredump/core.systemd.1000.41e02e6c192744068107a09ac47c704b.9383.1606595190000000.zst
Message: Process 9383 (systemd) of user 1000 dumped core.Stack trace of thread 9383: #0 0x00007f29e7beeff0 main_arena (libc.so.6 + 0x1c2ff0) #1 0x3132f8fa9d38e959 n/a (n/a + 0x0) PID: 10712 (systemd) UID: 1000 (stoefelz) GID: 1000 (stoefelz) Signal: 11 (SEGV) Timestamp: Sat 2020-11-28 21:26:42 CET (21min ago)
Storage: /var/lib/systemd/coredump/core.systemd.1000.41e02e6c192744068107a09ac47c704b.10712.1606595202000000.zst
Message: Process 10712 (systemd) of user 1000 dumped core.Stack trace of thread 10712: #0 0x00007f62bebf6f80 main_arena (libc.so.6 + 0x1c2f80) #1 0x02db82713d5e2cf0 n/a (n/a + 0x0)
