Systemd: Freezing execution
At first there seemed to be no problem but since yesterday I have systemd freezing. No clue how or where to debug this. Any help will be appreciated.
This is the message I get:
Broadcast message from systemd-journald@roland-xps (Sun 2021-07-25 22:32:01 CEST):
systemd[1]: Caught <ABRT>, dumped core as pid 35770.
systemd[1]: Freezing execution.
This is the journal log of the coredump
           PID: 35770 (systemd)
           UID: 0 (root)
           GID: 0 (root)
        Signal: 6 (ABRT)
     Timestamp: Sun 2021-07-25 22:32:01 CEST (5min ago)
  Command Line: /sbin/init
    Executable: /usr/lib/systemd/systemd
 Control Group: /init.scope
          Unit: init.scope
         Slice: -.slice
       Boot ID: d597d4d4236347f58dba94b7378ae371
    Machine ID: a7b3bc1365d44bf8a29140db98c319c9
      Hostname: roland-xps
       Storage: /var/lib/systemd/coredump/core.systemd.0.d597d4d4236347f58dba94b7378ae371.35770.1627245121000000.zst (present)
     Disk Size: 446.3K
       Message: Process 35770 (systemd) of user 0 dumped core.
                Stack trace of thread 35770:
                #0  0x00007f6b9d7e601b kill (libc.so.6 + 0x3d01b)
                #1  0x00005569c0df2e97 n/a (systemd + 0x3ce97)
                #2  0x00007f6b9d988870 __restore_rt (libpthread.so.0 + 0x13870)
                #3  0x00007f6b9d7e5d22 raise (libc.so.6 + 0x3cd22)
                #4  0x00007f6b9d7cf862 abort (libc.so.6 + 0x26862)
                #5  0x00007f6b9db2b972 n/a (libsystemd-shared-248.so + 0x62972)
                #6  0x00007f6b9dcca980 n/a (libsystemd-shared-248.so + 0x201980)
                #7  0x00007f6b9dcd303e n/a (libsystemd-shared-248.so + 0x20a03e)
                #8  0x00007f6b9dcd3a8e sd_event_prepare (libsystemd-shared-248.so + 0x20aa8e)
                #9  0x00007f6b9dcd6bb3 sd_event_run (libsystemd-shared-248.so + 0x20dbb3)
                #10 0x00005569c0e375e8 n/a (systemd + 0x815e8)
                #11 0x00005569c0defe2d n/a (systemd + 0x39e2d)
                #12 0x00007f6b9d7d0b25 __libc_start_main (libc.so.6 + 0x27b25)
                #13 0x00005569c0df2a0e n/a (systemd + 0x3ca0e)
The coredump file it produces is 20MB and not usable for displaying here.
This is the neofetch output:
██████████████████  ████████   rolandd@roland-xps
██████████████████  ████████   OS: Manjaro Linux x86_64
██████████████████  ████████   Host: XPS 17 9700
████████            ████████   Kernel: 5.13.4-1-MANJARO
████████  ████████  ████████   Uptime: 1 hour, 7 mins
████████  ████████  ████████   Packages: 1488 (pacman)
████████  ████████  ████████   Shell: zsh 5.8
████████  ████████  ████████   Resolution: 2560x1440
████████  ████████  ████████   DE: Plasma 5.22.3
████████  ████████  ████████   WM: KWin
████████  ████████  ████████   Theme: Breeze Dark [Plasma], Default [GTK2/3]
████████  ████████  ████████   Icons: [Plasma], breeze-dark [GTK2/3]
████████  ████████  ████████   Terminal: konsole
                               Terminal Font: Noto Mono 10
                               CPU: Intel i9-10885H (16) @ 5.300GHz
                               GPU: Intel CometLake-H GT2 [UHD Graphics]
                               GPU: NVIDIA GeForce RTX 2060 Max-Q
                               Memory: 11325MiB / 64060MiB
Inxi output:
  Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=61563fba-524b-4fad-8d9e-d8b4c4bfde08 ro quiet apparmor=1
  Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Dell product: XPS 17 9700 v: N/A
  Mobo: Dell model: 03CPGC v: A00 serial: <superuser required> UEFI: Dell
  v: 1.8.2 date: 05/21/2021
  ID-1: BAT0 charge: 34.5 Wh (43.8%) condition: 78.7/95.1 Wh (82.8%)
  volts: 11.1 min: 11.4 model: BYD DELL F8CPG0B type: Li-poly serial: 221
  status: Discharging
  RAM: total: 62.56 GiB used: 11.82 GiB (18.9%)
  Info: 8-Core model: Intel Core i9-10885H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
  cache: L2: 16 MiB bogomips: 76816
  Speed: 2505 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 2505 2: 2588
  3: 2579 4: 2527 5: 2502 6: 2557 7: 2489 8: 2493 9: 2532 10: 2511 11: 2523
  12: 2538 13: 2521 14: 2379 15: 2521 16: 2533
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
  smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Max-Q] vendor: Dell driver: nvidia
  v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f12 class-ID: 0300
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 0bda:5510 class-ID: fe01 serial: 200901010001
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
  s-diag: 777mm (30.6")
  Monitor-1: eDP-1 res: 2560x1440 hz: 60 dpi: 178 size: 366x229mm (14.4x9.0")
  diag: 432mm (17")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.5
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell
  driver: sof-audio-pci-intel-cnl
  alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  chip-ID: 8086:06c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: yes
  Device-1: Qualcomm QCA6390 Wireless Network Adapter [AX500-DBS ]
  vendor: Rivet Networks driver: ath11k_pci v: kernel port: 3000
  bus-ID: 04:00.0 chip-ID: 17cb:1101 class-ID: 0280
  IF: wlp4s0 state: up mac: 9c:b6:d0:3e:f1:67
  IP v4: 192.168.0.218/24 type: dynamic noprefixroute scope: global
  broadcast: 192.168.0.255
  IP v6: fd00:f0f2:49db:1a72:538d:8f40:c34b:108f/64
  IP v6: fe80::a013:d910:223d:468a/64 type: noprefixroute scope: link
  IF-ID-1: br-18e56cd16eda state: down mac: 02:42:10:e8:43:90
  IP v4: 172.23.0.1/16 scope: global broadcast: 172.23.255.255
  IF-ID-2: br-5faaf5c30322 state: up speed: 10000 Mbps duplex: unknown
  mac: 02:42:ef:53:f6:1c
  IP v4: 172.21.0.1/16 scope: global broadcast: 172.21.255.255
  IP v6: fe80::42:efff:fe53:f61c/64 scope: link
  IF-ID-3: docker0 state: down mac: 02:42:0b:aa:c4:25
  IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
  IP v6: fe80::42:bff:feaa:c425/64 scope: link
  IF-ID-4: veth52aa549 state: up speed: 10000 Mbps duplex: full
  mac: 52:38:78:e0:d5:c9
  IF-ID-5: veth961b03c state: up speed: 10000 Mbps duplex: full
  mac: 7a:a6:19:4d:45:1b
  IF-ID-6: vethb1c3015 state: up speed: 10000 Mbps duplex: full
  mac: 3a:31:32:6e:78:68
  WAN IP: 89.99.94.174
  Local Storage: total: 1.86 TiB used: 289.74 GiB (15.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA
  model: KXG60PNV2T04 NVMe 2048GB size: 1.86 TiB block-size: physical: 512 B
  logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: 11JF30WWF9E3
  rev: 10704104 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 1.43 TiB size: 1.41 TiB (98.36%) used: 289.65 GiB (20.1%)
  fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
  uuid: 61563fba-524b-4fad-8d9e-d8b4c4bfde08
  ID-2: /boot/efi raw-size: 150 MiB size: 146 MiB (97.33%)
  used: 92.9 MiB (63.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: ESP uuid: 8EC7-22E3
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 423.79 GiB fs: bitlocker
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: WINRETOOLS
  uuid: 5AE0CE44E0CE265B
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 16.45 GiB fs: ntfs label: Image
  uuid: 36FACEA4FACE5FAB
  ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.4 GiB fs: ntfs
  label: DELLSUPPORT uuid: 7CC47B47C47B02A6
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 27c6:533c class-ID: ff00
  Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
  driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-5: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-6: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 1707 fan-2: 1702
  Processes: 429 Uptime: 1h 9m wakeups: 7238 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1488 lib: 435
  flatpak: 0 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
When I reboot all is fine again until system.d freezes again. Never had this issue in the last 4 months running Manjaro.
Thank you for any insights.
Do you see the same problem when using another kernel (latest LTS 5.10 for example)?
The freeze just happened again after working without problems for the past 4 hours. I did not have the 5.10 kernel installed but did install it prior to the freeze. So I have now rebooted and using the 5.10 kernel and will continue working. Now just have to wait and see if the freeze happens. There is no way that I have found to reproduce the freeze at will.
Will keep you updated.
I’m having this exact same problem. I just upgraded earlier today.
Now whenever I use systemctl, systemd crashes.
The issue started happening after the update.
Broadcast message from systemd-journald@b0x (Mon 2021-07-26 20:15:59 +08):
systemd[1]: Caught <ABRT>, dumped core as pid 13243.
My Linux kernel is 5.4.134-1-MANJARO.
Not sure if this is related, but I’m also seeing systemd PID 1 dying in the last few days.
Looks like the same issue as reported and fixed here in Fedora: 1984651 – systemd[1]: Assertion 'a <= b' failed at src/libsystemd/sd-event/sd-event.c:2903, function sleep_between(). Aborting.
What I see in terms of logs:
Jul 26 22:31:19 x systemd[1]: Assertion 'a <= b' failed at src/libsystemd/sd-event/sd-event.c:2903, function sleep_between(). Aborting.
Jul 26 22:31:19 x audit[869041]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=869041 comm="systemd" exe="/usr/lib/systemd/systemd" sig=6 res=1
Jul 26 22:31:19 x kernel: kauditd_printk_skb: 73 callbacks suppressed
Jul 26 22:31:19 x kernel: audit: type=1701 audit(1627335079.741:995): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=869041 comm="systemd" exe="/usr/lib/systemd/systemd" sig=6 res=1
Jul 26 22:31:19 x systemd-coredump[869043]: Due to PID 1 having crashed coredump collection will now be turned off.
Jul 26 22:31:19 x systemd-coredump[869043]: [🡕] Process 869041 (systemd) of user 0 dumped core.
                                              Stack trace of thread 869041:
                                              #0  0x00007fc8fa55b01b kill (libc.so.6 + 0x3d01b)
                                              #1  0x000055fb302d4e97 n/a (systemd + 0x3ce97)
                                              #2  0x00007fc8fa6fd870 __restore_rt (libpthread.so.0 + 0x13870)
                                              #3  0x00007fc8fa55ad22 raise (libc.so.6 + 0x3cd22)
                                              #4  0x00007fc8fa544862 abort (libc.so.6 + 0x26862)
                                              #5  0x00007fc8fa8a2972 n/a (libsystemd-shared-248.so + 0x62972)
                                              #6  0x00007fc8faa41980 n/a (libsystemd-shared-248.so + 0x201980)
                                              #7  0x00007fc8faa4a03e n/a (libsystemd-shared-248.so + 0x20a03e)
                                              #8  0x00007fc8faa4aa8e sd_event_prepare (libsystemd-shared-248.so + 0x20aa8e)
                                              #9  0x00007fc8faa4dbb3 sd_event_run (libsystemd-shared-248.so + 0x20dbb3)
                                              #10 0x000055fb303195e8 n/a (systemd + 0x815e8)
                                              #11 0x000055fb302d1e2d n/a (systemd + 0x39e2d)
                                              #12 0x00007fc8fa545b25 __libc_start_main (libc.so.6 + 0x27b25)
                                              #13 0x000055fb302d4a0e n/a (systemd + 0x3ca0e)
Jul 26 22:31:19 x systemd[1]: Caught <ABRT>, dumped core as pid 869041.
Jul 26 22:31:19 x audit: BPF prog-id=26 op=UNLOAD
Jul 26 22:31:19 x systemd[1]: Freezing execution.
Jul 26 22:31:19 x kernel: audit: type=1334audit(1627335079.791:996): prog-id=26 op=UNLOAD
Related issue: Assertion 'a <= b' failed at src/libsystemd/sd-event/sd-event.c:2903, function sleep_between() · Issue #20285 · systemd/systemd · GitHub
Should have been fixed in upstream version 248.6.
yep, that’s the one. I’ll probably move over to the testing branch until this gets resolved in stable as my system is unusable for more than a few hours at a time.
