Systemd automount not unmounted when idle
systemd has stopped unmounting drives when they are idle. This is for quite some time through several updates, not new with the latest update. I have not found anything in forums for Manjaro or Arch mentioning this.
The mounting works perfectly when I access something below the mountpoint, e.g listing a directory with ls. But no matter how long I keep away from the drive, it stays mounted. I cannot find anything that might keep access open to the drive with lsof +D /data/hd1Tb/ .
How can I check what is keeping the drive mounted without activating the mounting?
The systemd unit files seem to be OK and should unmount the drive after 5 minutes idle.
Example:
$ cat /etc/systemd/system/data-hd1Tb.automount
[Unit]
Description=On demand mount hd1Tb on /data/hd1Tb
[Automount]
Where=/data/hd1Tb
TimeoutIdleSec=300
[Install]
WantedBy=multi-user.target
$ cat /etc/systemd/system/data-hd1Tb.mount
[Unit]
Description=mount hd1Tb on /data/hd1Tb
[Mount]
What=/dev/disk/by-label/hd1Tb
Where=/data/hd1Tb
Type=ext4
Options=defaults,noatime,discard
TimeoutSec=10
[Install]
after 30 minutes of not running ANYTHING on the system
tir 11 aug 12:38:58 CEST 2026
systemctl list-automounts --all
WHAT        WHERE                    MOUNTED IDLE TIMEOUT UNIT
/dev/sdb1   /data/hd1Tb              yes     5min         data-hd1Tb.automount
/dev/sdc1   /data/ssd200             yes     5min         data-ssd200.automount
/dev/sda1   /data/swdisk             yes     5min         data-swdisk.automount
binfmt_misc /proc/sys/fs/binfmt_misc yes     -            proc-sys-fs-binfmt_misc.automount
4 automounts listed.
systemctl status data-hd1Tb.automount
● data-hd1Tb.automount - On demand mount hd1Tb on /data/hd1Tb
     Loaded: loaded (/etc/systemd/system/data-hd1Tb.automount; enabled; preset: disabled)
     Active: active (running) since Tue 2026-08-11 09:20:34 CEST; 3h 18min ago
 Invocation: 0975fe55afdc4046b9b13bebae4352fa
   Triggers: ● data-hd1Tb.mount
      Where: /data/hd1Tb
aug 11 09:20:34 statPC systemd[1]: Set up automount On demand mount hd1Tb on /data/hd1Tb.
aug 11 09:22:22 statPC systemd[1]: data-hd1Tb.automount: Got automount request for /data/hd1Tb, triggered by 1759 (ls)
systemctl status data-hd1Tb.mount
● data-hd1Tb.mount - mount hd1Tb on /data/hd1Tb
     Loaded: loaded (/etc/systemd/system/data-hd1Tb.mount; disabled; preset: disabled)
     Active: active (mounted) since Tue 2026-08-11 09:22:23 CEST; 3h 16min ago
 Invocation: a74c3b11a1e8444cae28458fd628a9d3
TriggeredBy: ● data-hd1Tb.automount
      Where: /data/hd1Tb
       What: /dev/sdb1
      Tasks: 0 (limit: 18954)
     Memory: 660K (peak: 2.5M)
        CPU: 10ms
     CGroup: /system.slice/data-hd1Tb.mount
aug 11 09:22:22 statPC systemd[1]: Mounting mount hd1Tb on /data/hd1Tb...
aug 11 09:22:23 statPC systemd[1]: Mounted mount hd1Tb on /data/hd1Tb.
systemctl status data-ssd200.automount
● data-ssd200.automount - On demand mount ssd200 on /data/ssd200
     Loaded: loaded (/etc/systemd/system/data-ssd200.automount; enabled; preset: disabled)
 Invocation: cb3c044f1c9f498fabfecea517ca5f93
   Triggers: ● data-ssd200.mount
      Where: /data/ssd200
aug 11 09:20:34 statPC systemd[1]: Set up automount On demand mount ssd200 on /data/ssd200.
aug 11 09:22:23 statPC systemd[1]: data-ssd200.automount: Got automount request for /data/ssd200, triggered by 1759 (ls)
systemctl status data-ssd200.mount
● data-ssd200.mount - mount ssd200 on /data/ssd200
     Loaded: loaded (/etc/systemd/system/data-ssd200.mount; disabled; preset: disabled)
 Invocation: c3bbd0ef663d482f91203f6a1b38702d
TriggeredBy: ● data-ssd200.automount
      Where: /data/ssd200
       What: /dev/sdc1
     Memory: 2.2M (peak: 2.7M)
        CPU: 9ms
     CGroup: /system.slice/data-ssd200.mount
aug 11 09:22:23 statPC systemd[1]: Mounting mount ssd200 on /data/ssd200...
aug 11 09:22:23 statPC systemd[1]: Mounted mount ssd200 on /data/ssd200.
systemctl status data-swdisk.automount
● data-swdisk.automount - On demand mount swdisk on /data/swdisk
     Loaded: loaded (/etc/systemd/system/data-swdisk.automount; enabled; preset: disabled)
 Invocation: 7a8ca2a3eb5a4655912b583b3d15f5eb
   Triggers: ● data-swdisk.mount
      Where: /data/swdisk
aug 11 09:20:34 statPC systemd[1]: Set up automount On demand mount swdisk on /data/swdisk.
aug 11 09:22:23 statPC systemd[1]: data-swdisk.automount: Got automount request for /data/swdisk, triggered by 1759 (ls)
systemctl status data-swdisk.mount
● data-swdisk.mount - mount swdisk on /data/swdisk
     Loaded: loaded (/etc/systemd/system/data-swdisk.mount; disabled; preset: disabled)
     Active: active (mounted) since Tue 2026-08-11 09:22:24 CEST; 3h 16min ago
 Invocation: fa546d80e6fc44da85eb06bcb1828835
TriggeredBy: ● data-swdisk.automount
      Where: /data/swdisk
       What: /dev/sda1
     Memory: 524K (peak: 2.2M)
        CPU: 9ms
     CGroup: /system.slice/data-swdisk.mount
aug 11 09:22:23 statPC systemd[1]: Mounting mount swdisk on /data/swdisk...
aug 11 09:22:24 statPC systemd[1]: Mounted mount swdisk on /data/swdisk.
inxi -zv8
  Kernel: 6.18.42-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=f3904944-7f28-4603-975d-69a3043ccbfa rw hibernate=no nowatchdog
    mitigations=off security=none "dyndbg=func fw_log_firmware_info +p"
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.28.0
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
    Firmware: BIOS vendor: American Megatrends v: 4631 date: 01/14/2025
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 16 GiB available: 15.52 GiB used: 2.63 GiB (16.9%)
  Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3000 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-3000C16-16GISB serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: no module installed
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 1724 min/max: 558/4208 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1724 2: 1724 3: 1724
    4: 1724 5: 1724 6: 1724 7: 1724 8: 1724 9: 1724 10: 1724 11: 1724 12: 1724
    bogomips: 86404
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: retbleed status: Vulnerable
  Type: spec_rstack_overflow status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Type: vmscape status: Vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Gigabyte driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
    empty: DP-1,DP-2,DVI-D-1 bus-ID: 08:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 53.0 C
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4480x2640
    display-ID: 0
  Monitor-1: DP-3 pos: bottom-r model: Denon DENON-AVR serial: <filter>
    built: 2014 res: mode: 640x480 hz: 60 scale: 100% (1) dpi: 61 gamma: 1.2
    chroma: red: x: 0.627 y: 0.341 green: x: 0.278 y: 0.596 blue: x: 0.153
    y: 0.071 white: x: 0.282 y: 0.298 size: 800x450mm (27.87x15.67")
    diag: 918mm (36.1") ratio: 16:9 modes: 1920x1080, 2880x576, 2880x480,
    1280x720, 1440x576, 1440x480, 720x576, 720x480, 640x480
  Monitor-2: HDMI-A-1 pos: primary,top-left model: Philips FTV
    serial: <filter> built: 2017 res: mode: 3840x2160 hz: 60 scale: 200% (2)
    to: 1920x1080 dpi: 34 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green:
    x: 0.325 y: 0.588 blue: x: 0.145 y: 0.051 white: x: 0.278 y: 0.290
    size: 1440x810mm (56.69x31.89") diag: 1652mm (65") ratio: 16:9
    modes: 1920x1080, 3840x2160, 1600x1200, 1680x1050, 1400x1050, 1280x1024,
    1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.6-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 590 Series (radeonsi polaris10
    ACO DRM 3.64 6.18.42-1-MANJARO) device-ID: 1002:67df memory: 7.81 GiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX 590 Series (RADV POLARIS10) driver: mesa radv v: 26.1.6-arch1.1
    device-ID: 1002:67df surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.18.42-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Local Storage: total: 2.52 TiB used: 1.18 TiB (47.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-00L5B1
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: N/A serial: <filter> fw-rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EADS-00L5B1 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
    scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Micron model: MTFDDAK256MAY-1AH12ABHA
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: M5T4 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU800NS38
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 8B scheme: MBR
  ID-1: / raw-size: 476.94 GiB size: 468.38 GiB (98.21%)
    used: 20.01 GiB (4.3%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: statroot
    uuid: f3904944-7f28-4603-975d-69a3043ccbfa
  ID-2: /data/hd1Tb raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 760.37 GiB (83.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: hd1Tb
    uuid: a0f67169-c4c3-48e9-bafe-a73dc0983560
  ID-3: /data/ssd200 raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
    used: 5.5 MiB (0.0%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: ssd200
    uuid: 90a6ed92-904a-458e-90e7-427c598d9337
  ID-4: /data/swdisk raw-size: 923.5 GiB size: 907.93 GiB (98.31%)
    used: 431.82 GiB (47.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: swdisk
    uuid: ed96f3d3-edea-43bc-8418-2223e4ec312d
  ID-5: /home/<filter>/cryptomount.fredox.vol raw-size: 650 MiB
    size: 622.5 MiB (95.77%) used: 542.2 MiB (87.1%) fs: ext4 dev: /dev/dm-1
    maj-min: 253:1 mapped: loop0 label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-0 maj-min: 253:0 mapped: swap label: swap
    uuid: 56ec0d6b-fab8-424c-8caa-953e93af7b17
  ID-1: /dev/sda2 maj-min: 8:2 size: 8.01 GiB fs: ext2 label: cryptswap
    uuid: 01319864-7821-48aa-a580-240abe298ed6
  Device-1: 1-7:2 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 1-9:3 info: NZXT Smart Device V2 type: HID
    driver: nzxt-smart2,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2006 class-ID: 0300
    serial: <filter>
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-1:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0617
  System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 772
  Packages: pm: pacman pkgs: 1218 libs: 295 tools: pamac
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    6: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    8: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    9: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    10: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 374
  1: cpu: 4.2% command: firefox pid: 45407 mem: 710.1 MiB (4.4%)
  2: cpu: 2.9% command: firefox pid: 44343 mem: 692.0 MiB (4.3%)
  3: cpu: 2.4% command: firefox pid: 45929 mem: 340.4 MiB (2.1%)
  4: cpu: 1.2% command: kwin_wayland pid: 923 mem: 345.0 MiB (2.1%)
  5: cpu: 0.7% command: konsole pid: 46369 mem: 119.1 MiB (0.7%)
  Memory top: 5 of 374
  1: mem: 710.1 MiB (4.4%) command: firefox pid: 45407 cpu: 4.2%
  2: mem: 692.0 MiB (4.3%) command: firefox pid: 44343 cpu: 2.9%
  3: mem: 364.9 MiB (2.2%) command: plasmashell pid: 1103 cpu: 0.1%
  4: mem: 345.0 MiB (2.1%) command: kwin_wayland pid: 923 cpu: 1.2%
  5: mem: 344.5 MiB (2.1%) command: krunner pid: 3507 cpu: 0.0%
  Processes: 374 Power: uptime: 3h 55m states: freeze,mem suspend: deep
    avail: s2idle wakeups: 0 hibernate: disabled image: 6.17 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 261 default: graphical tool: systemctl
  Compilers: gcc: 16.1.1 Shell: Bash v: 5.3.15 running-in: konsole
    inxi: 3.3.41
Hmm - as I remember this - the TimoutIdleSec would do that.
I haven’t given much thought to it… I will keep an eye out when I get some more time.
On my system
aug 11 06:21:53 tiger systemd[1]: a-backup01.automount: Got automount request for /a/backup01, triggered by 4385 ((sleep))
triggered by 4385 ((sleep)) - that one is a bit strange - need investigation
aug 11 06:11:26 tiger systemd[1]: a-projects.automount: Got automount request for /a/projects, triggered by 1686 (syncthing)
But this one will keep my device awake for ever…
Something in Plasma keeps the drive mounted.
I booted to runlevel 3 and logged in to the tty and ran lsof +D /data/hd1Tb/ to trigger the automount. Then I waited 10 minutes and then checked with systemctl list-automounts --all , and then the drive was dismounted.
from journalctl
aug 11 14:38:32 statPC sudo[867]:   freddy : TTY=tty1 ; PWD=/home/freddy ; USER=root ; COMMAND=/usr/bin/lsof +D /data/hd1Tb/
aug 11 14:38:32 statPC sudo[867]: pam_unix(sudo:session): session opened for user root(uid=0) by freddy(uid=1000)
aug 11 14:38:32 statPC systemd[1]: data-hd1Tb.automount: Got automount request for /data/hd1Tb, triggered by 871 (lsof)
aug 11 14:38:32 statPC systemd[1]: Mounting mount hd1Tb on /data/hd1Tb...
aug 11 14:38:33 statPC kernel: EXT4-fs (sdb1): mounting with "discard" option, but the device does not support discard
aug 11 14:38:33 statPC kernel: EXT4-fs (sdb1): mounted filesystem a0f67169-c4c3-48e9-bafe-a73dc0983560 r/w with ordered data mode. Quota mode: none.
aug 11 14:38:33 statPC systemd[1]: Mounted mount hd1Tb on /data/hd1Tb.
aug 11 14:38:47 statPC sudo[867]: pam_unix(sudo:session): session closed for user root
aug 11 14:45:14 statPC systemd[1]: Unmounting mount hd1Tb on /data/hd1Tb...
aug 11 14:45:14 statPC kernel: EXT4-fs (sdb1): unmounting filesystem a0f67169-c4c3-48e9-bafe-a73dc0983560.
aug 11 14:45:14 statPC systemd[1]: data-hd1Tb.mount: Deactivated successfully.
aug 11 14:45:14 statPC systemd[1]: Unmounted mount hd1Tb on /data/hd1Tb.
aug 11 14:52:06 statPC systemd[1]: Starting Cleanup of Temporary Directories...
aug 11 14:52:06 statPC systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
aug 11 14:52:06 statPC systemd[1]: Finished Cleanup of Temporary Directories.
aug 11 14:52:48 statPC sudo[988]:   freddy : TTY=tty1 ; PWD=/home/freddy ; USER=root ; COMMAND=/usr/bin/journalctl -b0
aug 11 14:52:48 statPC sudo[988]: pam_unix(sudo:session): session opened for user root(uid=0) by freddy(uid=1000)
Then I booted normally and logged in to Plasma and opened Konsole and ran ls /data/hd1Tb to trigger the automount. Then I waited 10 minutes and then checked with systemctl list-automounts --all , and the drive was still mounted.
from journalctl
aug 11 15:16:01 statPC systemd[1]: data-hd1Tb.automount: Got automount request for /data/hd1Tb, triggered by 1582 (ls)
aug 11 15:16:01 statPC systemd[1]: Mounting mount hd1Tb on /data/hd1Tb...
aug 11 15:16:01 statPC kernel: EXT4-fs (sdb1): mounting with "discard" option, but the device does not support discard
aug 11 15:16:01 statPC kernel: EXT4-fs (sdb1): mounted filesystem a0f67169-c4c3-48e9-bafe-a73dc0983560 r/w with ordered data mode. Quota mode: none.
aug 11 15:16:01 statPC systemd[1]: Mounted mount hd1Tb on /data/hd1Tb.
aug 11 15:16:26 statPC systemd[1]: dbus-:1.2-org.kde.kameleon.qmk.helper@0.service: Deactivated successfully.
aug 11 15:28:36 statPC sudo[1647]:   freddy : TTY=pts/1 ; PWD=/home/freddy ; USER=root ; COMMAND=/usr/bin/journalctl -b0
aug 11 15:28:36 statPC sudo[1647]: pam_unix(sudo:session): session opened for user root(uid=0) by freddy(uid=1000)
ps -fe
UID          PID    PPID  C STIME TTY          TIME CMD
root           1       0  0 15:14 ?        00:00:00 /usr/lib/systemd/systemd --switched-root --system --deserialize=56
root           2       0  0 15:14 ?        00:00:00 [kthreadd]
root           3       2  0 15:14 ?        00:00:00 [pool_workqueue_release]
root           4       2  0 15:14 ?        00:00:00 [kworker/R-rcu_gp]
root           5       2  0 15:14 ?        00:00:00 [kworker/R-sync_wq]
root           6       2  0 15:14 ?        00:00:00 [kworker/R-kvfree_rcu_reclaim]
root           7       2  0 15:14 ?        00:00:00 [kworker/R-slub_flushwq]
root           8       2  0 15:14 ?        00:00:00 [kworker/R-netns]
root          10       2  0 15:14 ?        00:00:00 [kworker/0:1-events]
root          11       2  0 15:14 ?        00:00:00 [kworker/0:0H-events_highpri]
root          12       2  0 15:14 ?        00:00:00 [kworker/u48:0-gfx]
root          14       2  0 15:14 ?        00:00:00 [kworker/R-mm_percpu_wq]
root          15       2  0 15:14 ?        00:00:00 [ksoftirqd/0]
root          16       2  0 15:14 ?        00:00:00 [rcu_preempt]
root          17       2  0 15:14 ?        00:00:00 [rcub/0]
root          18       2  0 15:14 ?        00:00:00 [rcu_exp_par_gp_kthread_worker/0]
root          19       2  0 15:14 ?        00:00:00 [rcu_exp_gp_kthread_worker]
root          20       2  0 15:14 ?        00:00:00 [migration/0]
root          21       2  0 15:14 ?        00:00:00 [idle_inject/0]
root          22       2  0 15:14 ?        00:00:00 [cpuhp/0]
root          23       2  0 15:14 ?        00:00:00 [cpuhp/1]
root          24       2  0 15:14 ?        00:00:00 [idle_inject/1]
root          25       2  0 15:14 ?        00:00:00 [migration/1]
root          26       2  0 15:14 ?        00:00:00 [ksoftirqd/1]
root          28       2  0 15:14 ?        00:00:00 [kworker/1:0H-events_highpri]
root          29       2  0 15:14 ?        00:00:00 [cpuhp/2]
root          30       2  0 15:14 ?        00:00:00 [idle_inject/2]
root          31       2  0 15:14 ?        00:00:00 [migration/2]
root          32       2  0 15:14 ?        00:00:00 [ksoftirqd/2]
root          34       2  0 15:14 ?        00:00:00 [kworker/2:0H-events_highpri]
root          35       2  0 15:14 ?        00:00:00 [cpuhp/3]
root          36       2  0 15:14 ?        00:00:00 [idle_inject/3]
root          37       2  0 15:14 ?        00:00:00 [migration/3]
root          38       2  0 15:14 ?        00:00:00 [ksoftirqd/3]
root          40       2  0 15:14 ?        00:00:00 [kworker/3:0H-events_highpri]
root          41       2  0 15:14 ?        00:00:00 [cpuhp/4]
root          42       2  0 15:14 ?        00:00:00 [idle_inject/4]
root          43       2  0 15:14 ?        00:00:00 [migration/4]
root          44       2  0 15:14 ?        00:00:00 [ksoftirqd/4]
root          45       2  0 15:14 ?        00:00:00 [kworker/4:0-events]
root          46       2  0 15:14 ?        00:00:00 [kworker/4:0H-events_highpri]
root          47       2  0 15:14 ?        00:00:00 [cpuhp/5]
root          48       2  0 15:14 ?        00:00:00 [idle_inject/5]
root          49       2  0 15:14 ?        00:00:00 [migration/5]
root          50       2  0 15:14 ?        00:00:00 [ksoftirqd/5]
root          52       2  0 15:14 ?        00:00:00 [kworker/5:0H-events_highpri]
root          53       2  0 15:14 ?        00:00:00 [cpuhp/6]
root          54       2  0 15:14 ?        00:00:00 [idle_inject/6]
root          55       2  0 15:14 ?        00:00:00 [migration/6]
root          56       2  0 15:14 ?        00:00:00 [ksoftirqd/6]
root          58       2  0 15:14 ?        00:00:00 [kworker/6:0H-events_highpri]
root          59       2  0 15:14 ?        00:00:00 [cpuhp/7]
root          60       2  0 15:14 ?        00:00:00 [idle_inject/7]
root          61       2  0 15:14 ?        00:00:00 [migration/7]
root          62       2  0 15:14 ?        00:00:00 [ksoftirqd/7]
root          64       2  0 15:14 ?        00:00:00 [kworker/7:0H-events_highpri]
root          65       2  0 15:14 ?        00:00:00 [cpuhp/8]
root          66       2  0 15:14 ?        00:00:00 [idle_inject/8]
root          67       2  0 15:14 ?        00:00:00 [migration/8]
root          68       2  0 15:14 ?        00:00:00 [ksoftirqd/8]
root          69       2  0 15:14 ?        00:00:00 [kworker/8:0-mm_percpu_wq]
root          70       2  0 15:14 ?        00:00:00 [kworker/8:0H-events_highpri]
root          71       2  0 15:14 ?        00:00:00 [cpuhp/9]
root          72       2  0 15:14 ?        00:00:00 [idle_inject/9]
root          73       2  0 15:14 ?        00:00:00 [migration/9]
root          74       2  0 15:14 ?        00:00:00 [ksoftirqd/9]
root          76       2  0 15:14 ?        00:00:00 [kworker/9:0H-events_highpri]
root          77       2  0 15:14 ?        00:00:00 [cpuhp/10]
root          78       2  0 15:14 ?        00:00:00 [idle_inject/10]
root          79       2  0 15:14 ?        00:00:00 [migration/10]
root          80       2  0 15:14 ?        00:00:00 [ksoftirqd/10]
root          82       2  0 15:14 ?        00:00:00 [kworker/10:0H-events_highpri]
root          83       2  0 15:14 ?        00:00:00 [cpuhp/11]
root          84       2  0 15:14 ?        00:00:00 [idle_inject/11]
root          85       2  0 15:14 ?        00:00:00 [migration/11]
root          86       2  0 15:14 ?        00:00:00 [ksoftirqd/11]
root          87       2  0 15:14 ?        00:00:00 [kworker/11:0-cgroup_release]
root          88       2  0 15:14 ?        00:00:00 [kworker/11:0H-events_highpri]
root          91       2  0 15:14 ?        00:00:00 [kdevtmpfs]
root          92       2  0 15:14 ?        00:00:00 [kworker/R-inet_frag_wq]
root          93       2  0 15:14 ?        00:00:00 [rcu_tasks_kthread]
root          94       2  0 15:14 ?        00:00:00 [rcu_tasks_rude_kthread]
root          95       2  0 15:14 ?        00:00:00 [rcu_tasks_trace_kthread]
root          96       2  0 15:14 ?        00:00:00 [kauditd]
root          97       2  0 15:14 ?        00:00:00 [khungtaskd]
root          99       2  0 15:14 ?        00:00:00 [oom_reaper]
root         101       2  0 15:14 ?        00:00:00 [kworker/R-writeback]
root         102       2  0 15:14 ?        00:00:00 [kcompactd0]
root         103       2  0 15:14 ?        00:00:00 [ksmd]
root         104       2  0 15:14 ?        00:00:00 [khugepaged]
root         105       2  0 15:14 ?        00:00:00 [kworker/R-kblockd]
root         106       2  0 15:14 ?        00:00:00 [kworker/R-blkcg_punt_bio]
root         107       2  0 15:14 ?        00:00:00 [kworker/R-kintegrityd]
root         108       2  0 15:14 ?        00:00:00 [irq/9-acpi]
root         109       2  0 15:14 ?        00:00:00 [kworker/1:1-events]
root         110       2  0 15:14 ?        00:00:00 [kworker/6:1-events]
root         111       2  0 15:14 ?        00:00:00 [kworker/R-tpm_dev_wq]
root         112       2  0 15:14 ?        00:00:00 [kworker/R-ata_sff]
root         113       2  0 15:14 ?        00:00:00 [kworker/R-edac-poller]
root         114       2  0 15:14 ?        00:00:00 [kworker/R-devfreq_wq]
root         115       2  0 15:14 ?        00:00:00 [watchdogd]
root         116       2  0 15:14 ?        00:00:00 [kworker/R-quota_events_unbound]
root         117       2  0 15:14 ?        00:00:00 [kworker/1:1H-kblockd]
root         118       2  0 15:14 ?        00:00:00 [irq/25-AMD-Vi]
root         119       2  0 15:14 ?        00:00:00 [kswapd0]
root         120       2  0 15:14 ?        00:00:00 [kworker/R-kthrotld]
root         121       2  0 15:14 ?        00:00:00 [kworker/u51:0]
root         122       2  0 15:14 ?        00:00:00 [irq/30-aerdrv]
root         123       2  0 15:14 ?        00:00:00 [irq/31-aerdrv]
root         124       2  0 15:14 ?        00:00:00 [irq/32-aerdrv]
root         125       2  0 15:14 ?        00:00:00 [kworker/R-acpi_thermal_pm]
root         126       2  0 15:14 ?        00:00:00 [scsi_eh_0]
root         127       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_0]
root         128       2  0 15:14 ?        00:00:00 [scsi_eh_1]
root         129       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_1]
root         130       2  0 15:14 ?        00:00:00 [scsi_eh_2]
root         131       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_2]
root         132       2  0 15:14 ?        00:00:00 [scsi_eh_3]
root         133       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_3]
root         134       2  0 15:14 ?        00:00:00 [scsi_eh_4]
root         135       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_4]
root         136       2  0 15:14 ?        00:00:00 [scsi_eh_5]
root         137       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_5]
root         138       2  0 15:14 ?        00:00:00 [scsi_eh_6]
root         139       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_6]
root         140       2  0 15:14 ?        00:00:00 [scsi_eh_7]
root         141       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_7]
root         147       2  0 15:14 ?        00:00:00 [kworker/u49:8-events_unbound]
root         148       2  0 15:14 ?        00:00:00 [kworker/u49:9-events_unbound]
root         149       2  0 15:14 ?        00:00:00 [scsi_eh_8]
root         150       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_8]
root         151       2  0 15:14 ?        00:00:00 [scsi_eh_9]
root         152       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_9]
root         153       2  0 15:14 ?        00:00:00 [scsi_eh_10]
root         154       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_10]
root         155       2  0 15:14 ?        00:00:00 [scsi_eh_11]
root         156       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_11]
root         157       2  0 15:14 ?        00:00:00 [scsi_eh_12]
root         158       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_12]
root         159       2  0 15:14 ?        00:00:00 [scsi_eh_13]
root         160       2  0 15:14 ?        00:00:00 [kworker/R-scsi_tmf_13]
root         161       2  0 15:14 ?        00:00:00 [kworker/u49:10-events_power_efficient]
root         169       2  0 15:14 ?        00:00:00 [kworker/1:2-pm]
root         172       2  0 15:14 ?        00:00:00 [kworker/R-mld]
root         173       2  0 15:14 ?        00:00:00 [kworker/R-ipv6_addrconf]
root         174       2  0 15:14 ?        00:00:00 [kworker/R-kstrp]
root         175       2  0 15:14 ?        00:00:00 [kworker/7:1H-kblockd]
root         176       2  0 15:14 ?        00:00:00 [kworker/2:1-events]
root         177       2  0 15:14 ?        00:00:00 [kworker/8:1-events]
root         183       2  0 15:14 ?        00:00:00 [kworker/R-zswap-shrink]
root         184       2  0 15:14 ?        00:00:00 [kworker/u52:0-ttm]
root         186       2  0 15:14 ?        00:00:00 [irq/26-ACPI:Event]
root         187       2  0 15:14 ?        00:00:00 [kworker/0:1H-kblockd]
root         189       2  0 15:14 ?        00:00:00 [kworker/7:3-events]
root         192       2  0 15:15 ?        00:00:00 [kworker/5:1-events]
root         193       2  0 15:15 ?        00:00:00 [kworker/3:1H-kblockd]
root         197       2  0 15:15 ?        00:00:00 [kworker/10:1-events]
root         207       2  0 15:15 ?        00:00:00 [kworker/4:1H-kblockd]
root         211       2  0 15:15 ?        00:00:00 [kworker/2:1H-kblockd]
root         214       2  0 15:15 ?        00:00:00 [kworker/11:1H-kblockd]
root         216       2  0 15:15 ?        00:00:00 [kworker/8:1H-kblockd]
root         217       2  0 15:15 ?        00:00:00 [kworker/10:1H-kblockd]
root         218       2  0 15:15 ?        00:00:00 [kworker/9:1H-kblockd]
root         221       2  0 15:15 ?        00:00:00 [kworker/5:1H-kblockd]
root         227       2  0 15:15 ?        00:00:00 [kworker/2:2-mm_percpu_wq]
root         229       2  0 15:15 ?        00:00:00 [kworker/3:2-events]
root         271       2  0 15:15 ?        00:00:00 [kworker/6:1H-kblockd]
root         287       2  0 15:15 ?        00:00:00 [kworker/11:2-mm_percpu_wq]
root         289       2  0 15:15 ?        00:00:00 [jbd2/sdd1-8]
root         290       2  0 15:15 ?        00:00:00 [kworker/R-ext4-rsv-conversion]
root         299       2  0 15:15 ?        00:00:00 [kworker/R-amdgpu-reset-dev]
root         300       2  0 15:15 ?        00:00:00 [kworker/R-ttm]
root         301       2  0 15:15 ?        00:00:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         302       2  0 15:15 ?        00:00:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         303       2  0 15:15 ?        00:00:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         304       2  0 15:15 ?        00:00:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         305       2  0 15:15 ?        00:00:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         306       2  0 15:15 ?        00:00:00 [kworker/R-dm_vblank_control_workqueue]
root         307       2  0 15:15 ?        00:00:00 [card1-crtc0]
root         308       2  0 15:15 ?        00:00:00 [card1-crtc1]
root         309       2  0 15:15 ?        00:00:00 [card1-crtc2]
root         310       2  0 15:15 ?        00:00:00 [card1-crtc3]
root         311       2  0 15:15 ?        00:00:00 [card1-crtc4]
root         312       2  0 15:15 ?        00:00:00 [card1-crtc5]
root         313       2  0 15:15 ?        00:00:00 [kworker/R-gfx]
root         314       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.0.0]
root         315       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.1.0]
root         316       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.2.0]
root         317       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.3.0]
root         318       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.0.1]
root         319       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.1.1]
root         320       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.2.1]
root         321       2  0 15:15 ?        00:00:00 [kworker/R-comp_1.3.1]
root         322       2  0 15:15 ?        00:00:00 [kworker/R-sdma0]
root         323       2  0 15:15 ?        00:00:00 [kworker/R-sdma1]
root         324       2  0 15:15 ?        00:00:00 [kworker/R-uvd]
root         325       2  0 15:15 ?        00:00:00 [kworker/R-uvd_enc0]
root         326       2  0 15:15 ?        00:00:00 [kworker/R-uvd_enc1]
root         327       2  0 15:15 ?        00:00:00 [kworker/R-vce0]
root         328       2  0 15:15 ?        00:00:00 [kworker/R-vce1]
root         329       2  0 15:15 ?        00:00:00 [kworker/R-vce2]
root         331       2  0 15:15 ?        00:00:00 [kworker/10:3-cgroup_free]
root         345       2  0 15:15 ?        00:00:00 [kworker/9:8-cgroup_free]
root         346       2  0 15:15 ?        00:00:00 [kworker/9:9-mm_percpu_wq]
root         386       1  0 15:15 ?        00:00:00 /usr/lib/systemd/systemd-journald
root         392       2  0 15:15 ?        00:00:00 [kworker/5:2-cgroup_release]
root         411       2  0 15:15 ?        00:00:00 [kworker/6:2-events]
root         413       1  0 15:15 ?        00:00:00 /usr/lib/systemd/systemd-userdbd
root         416       2  0 15:15 ?        00:00:00 [kworker/4:2-inode_switch_wbs]
root         419       2  0 15:15 ?        00:00:00 [psimon]
systemd+     422       1  0 15:15 ?        00:00:00 /usr/lib/systemd/systemd-timesyncd
root         424       2  0 15:15 ?        00:00:00 [kworker/u50:3-events_power_efficient]
root         429       1  0 15:15 ?        00:00:00 /usr/lib/systemd/systemd-udevd
root         432       2  0 15:15 ?        00:00:00 [kworker/3:3-events]
root         433       2  0 15:15 ?        00:00:00 [kworker/R-iprt-VBoxWQueue]
root         437       2  0 15:15 ?        00:00:00 [psimon]
root         481       2  0 15:15 ?        00:00:00 [iprt-VBoxTscThread]
root         526       2  0 15:15 ?        00:00:00 [kworker/R-led_workqueue]
root         597       2  0 15:15 ?        00:00:00 [kworker/R-kdmflush/253:0]
root         598       2  0 15:15 ?        00:00:00 [kworker/R-kcryptd_io-253:0-1]
root         599       2  0 15:15 ?        00:00:00 [kworker/R-kcryptd-253:0-1]
root         600       2  0 15:15 ?        00:00:00 [dmcrypt_write/253:0]
root         603       2  0 15:15 ?        00:00:00 [kworker/u50:4-kvfree_rcu_reclaim]
root         604       2  0 15:15 ?        00:00:00 [kworker/u50:5-events_unbound]
dbus         626       1  0 15:15 ?        00:00:00 /usr/bin/dbus-broker-launch --scope system --audit
dbus         627     626  0 15:15 ?        00:00:00 dbus-broker --log 10 --controller 9 --machine-id 6431310bd847498bbea78ba06da64b3d --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
root         628       1  0 15:15 ?        00:00:00 /usr/bin/NetworkManager --no-daemon
avahi        630       1  0 15:15 ?        00:00:00 avahi-daemon: running [statPC.local]
polkitd      631       1  0 15:15 ?        00:00:00 /usr/lib/polkit-1/polkitd --no-debug --log-level=notice
root         632       1  0 15:15 ?        00:00:00 /usr/lib/systemd/systemd-logind
avahi        664     630  0 15:15 ?        00:00:00 avahi-daemon: chroot helper
root         681       1  0 15:15 ?        00:00:00 /usr/bin/ModemManager
root         693       1  0 15:15 ?        00:00:00 sshd: /usr/bin/sshd -D [listener] 0 of 10-100 startups
root         696       1  0 15:15 ?        00:00:00 /usr/sbin/crond -n
root         697       1  0 15:15 ?        00:00:00 /usr/bin/sddm
root         699     697  0 15:15 tty2     00:00:00 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_URuqAV -noreset -displayfd 16
root         720       2  0 15:15 ?        00:00:00 [psimon]
root         748       1  0 15:15 ?        00:00:00 /usr/lib/upowerd
root         790       2  0 15:15 ?        00:00:00 [kworker/u52:1]
root         793     697  0 15:15 ?        00:00:00 /usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth-411ff00c-6703-4016-a013-a7ac52fe7e88 --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user freddy
freddy       799       1  0 15:15 ?        00:00:00 /usr/lib/systemd/systemd --user
freddy       801     799  0 15:15 ?        00:00:00 (sd-pam)
root         817       2  0 15:15 ?        00:00:00 [kworker/u53:14-ttm]
root         818       2  0 15:15 ?        00:00:00 [kworker/u53:15-ttm]
freddy       853     793  0 15:15 tty1     00:00:00 /usr/bin/startplasma-wayland
freddy       910     799  0 15:15 ?        00:00:00 /usr/bin/dbus-broker-launch --scope user
freddy       911     910  0 15:15 ?        00:00:00 dbus-broker --log 11 --controller 10 --machine-id 6431310bd847498bbea78ba06da64b3d --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
freddy       918     799  0 15:15 ?        00:00:00 /usr/bin/kwin_wayland_wrapper --xwayland
freddy       924     918  0 15:15 ?        00:00:01 /usr/bin/kwin_wayland --wayland-fd 7 --socket wayland-0 --xwayland-fd 8 --xwayland-fd 9 --xwayland-display :1 --xwayland-xauthority /run/user/1000/xauth_zQnntq --xwayland
freddy       974     799  0 15:15 ?        00:00:03 /usr/bin/pipewire
freddy       975     799  0 15:15 ?        00:00:00 /usr/bin/wireplumber
rtkit        987       1  0 15:15 ?        00:00:00 /usr/lib/rtkit-daemon
freddy      1010     924  0 15:15 ?        00:00:00 /usr/bin/Xwayland :1 -auth /run/user/1000/xauth_zQnntq -listenfd 8 -listenfd 9 -displayfd 64 -wm 72 -rootless
freddy      1039     799  0 15:15 ?        00:00:00 /usr/lib/at-spi-bus-launcher
root        1044       2  0 15:15 ?        00:00:00 [kworker/0:2-cgroup_free]
freddy      1052    1039  0 15:15 ?        00:00:00 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope user
freddy      1056    1052  0 15:15 ?        00:00:00 dbus-broker --log 10 --controller 9 --machine-id 6431310bd847498bbea78ba06da64b3d --max-bytes 100000000000000 --max-fds 6400000 --max-matches 5000000000
freddy      1057     799  0 15:15 ?        00:00:00 /usr/lib/at-spi2-registryd --use-gnome-session
freddy      1066     799  0 15:15 ?        00:00:00 /usr/bin/ksmserver
freddy      1068     799  0 15:15 ?        00:00:00 /usr/bin/kded6
root        1105       2  0 15:15 ?        00:00:00 [kworker/u48:3-gfx]
freddy      1106     799  0 15:15 ?        00:00:02 /usr/bin/plasmashell --no-respawn
freddy      1110     799  0 15:15 ?        00:00:00 /usr/bin/pipewire-pulse
freddy      1122     799  0 15:15 ?        00:00:00 /usr/lib/kactivitymanagerd
freddy      1125     799  0 15:15 ?        00:00:00 /usr/bin/gmenudbusmenuproxy
freddy      1127     799  0 15:15 ?        00:00:00 /usr/bin/kaccess
freddy      1128     799  0 15:15 ?        00:00:00 /usr/lib/polkit-kde-authentication-agent-1
freddy      1129     799  0 15:15 ?        00:00:00 /usr/lib/org_kde_powerdevil
freddy      1130     799  0 15:15 ?        00:00:00 /usr/bin/xembedsniproxy
freddy      1184     799  0 15:15 ?        00:00:00 /usr/lib/dconf-service
root        1194       1  0 15:15 ?        00:00:00 /usr/lib/udisks2/udisksd
freddy      1237     799  0 15:15 ?        00:00:00 /usr/bin/xsettingsd
root        1335       1  0 15:15 ?        00:00:00 /usr/lib/power-profiles-daemon
freddy      1342     799  0 15:15 ?        00:00:00 /usr/bin/msm_kde_notifier
freddy      1343     799  0 15:15 ?        00:00:00 /usr/bin/konsole
freddy      1347     799  0 15:15 ?        00:00:00 /usr/lib/xdg-desktop-portal
freddy      1395     799  0 15:15 ?        00:00:00 /usr/lib/xdg-permission-store
freddy      1416     799  0 15:15 ?        00:00:00 /usr/lib/xdg-document-portal
root        1427    1416  0 15:15 ?        00:00:00 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
freddy      1433     799  0 15:15 ?        00:00:00 /usr/lib/xdg-desktop-portal-gtk
freddy      1457    1343  0 15:15 pts/1    00:00:00 /usr/bin/bash
freddy      1496     799  0 15:15 ?        00:00:00 /usr/lib/xdg-desktop-portal-kde
root        1584       2  0 15:16 ?        00:00:00 [jbd2/sdb1-8]
root        1585       2  0 15:16 ?        00:00:00 [kworker/R-ext4-rsv-conversion]
root        1615       2  0 15:20 ?        00:00:00 [kworker/7:1-events]
root        1621     413  0 15:25 ?        00:00:00 systemd-userwork: waiting...
root        1622     413  0 15:25 ?        00:00:00 systemd-userwork: waiting...
root        1623     413  0 15:25 ?        00:00:00 systemd-userwork: waiting...
root        1642       2  0 15:27 ?        00:00:00 [kworker/7:0-mm_percpu_wq]
root        1646       2  0 15:28 ?        00:00:00 [kworker/u48:1-dm_vblank_control_workqueue]
root        1653       2  0 15:28 ?        00:00:00 [kworker/u50:0-events_power_efficient]
freddy      1662    1457  0 15:29 pts/1    00:00:00 ps -fe
A shot in the dark: thumbnailer, search indexer? But it had to be visible with lsof…
When I installed the system I disabled baloo with
kwriteconfig6 --file krunnerrc  --group Plugins --key baloosearchEnabled false
kwriteconfig6 --file baloofilerc --group Basic Settings --key Indexing-Enabled false
and those values are still in the respective files in ~/.config
There is something which keeps the mount from closing.
In my case it is two user services
  • syncthing - which uses my /a/projects mount point
  • backup - which uses my /a/backuo01 mount point
It may not be obvious - I had to think deep on the sleep activation - it turns out it is a timer that keep my backup device mounted.
Although the timer goes to sleep - it does not release the mount - possibly an error on my configuration of the timer/service combination.
