@anon89812132 & @Mirdarthos : thank you for caring.
In fact installing haveged to speed up slow start was an Ubuntu habit.
I checked with haveged : entropy_avail is at 3008
I removed it and restarted : entropy_vail is at 3810 !
This clears the matter !
Remaining matter, my start is still verrry long:
[sum@ordi1 ~]$ sudo dmesg
[sudo] Mot de passe de sum :
[ 0.000000] microcode: microcode updated early to revision 0x2f, date = 2019-02-17
[ 0.000000] Linux version 5.10.13-2-MANJARO (builduser@development) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36) #1 SMP PREEMPT Sat Feb 6 10:28:21 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=d770c061-597b-4849-868d-6cb431db7ceb ro quiet apparmor=1 security=apparmor udev.log_priority=3 ipv6.disable=1
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000020200000-0x000000003fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000401fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040200000-0x00000000a2c0bfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a2c0c000-0x00000000a2c0cfff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000a2c0d000-0x00000000a2d1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000a2d20000-0x00000000a2d47fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000a2d48000-0x00000000a2d77fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000a2d78000-0x00000000a2d8dfff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000a2d8e000-0x00000000a2d93fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a2d94000-0x00000000a2d95fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000a2d96000-0x00000000a2d96fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a2d97000-0x00000000a2db7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000a2db8000-0x00000000a2dc5fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a2dc6000-0x00000000a2de7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000a2de8000-0x00000000a2e22fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a2e23000-0x00000000a2fe7fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000a2fe8000-0x00000000a2ffcfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a2ffd000-0x00000000a2ffffff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000a3000000-0x00000000afffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000e3ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed13fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed18000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff980000-0x00000000ffbfffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffd80000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000034f7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.00 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0xa2ffff98 SMBIOS=0xa2db6218
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: ASUSTeK Computer Inc. K53SD/K53SD, BIOS K53SD.208 08/10/2012
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2294.963 MHz processor
[ 0.000986] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000997] last_pfn = 0x34f800 max_arch_pfn = 0x400000000
[ 0.001002] MTRR default type: uncachable
[ 0.001003] MTRR fixed ranges enabled:
[ 0.001004] 00000-9FFFF write-back
[ 0.001005] A0000-BFFFF uncachable
[ 0.001006] C0000-CFFFF write-protect
[ 0.001007] D0000-DFFFF uncachable
[ 0.001008] E0000-E7FFF write-through
[ 0.001010] E8000-FFFFF write-protect
[ 0.001010] MTRR variable ranges enabled:
[ 0.001012] 0 base 000000000 mask F80000000 write-back
[ 0.001014] 1 base 080000000 mask FE0000000 write-back
[ 0.001015] 2 base 0A0000000 mask FFC000000 write-back
[ 0.001016] 3 base 0A3000000 mask FFF000000 uncachable
[ 0.001017] 4 base 100000000 mask F00000000 write-back
[ 0.001018] 5 base 200000000 mask F00000000 write-back
[ 0.001019] 6 base 300000000 mask FC0000000 write-back
[ 0.001020] 7 base 340000000 mask FF0000000 write-back
[ 0.001022] 8 base 34F800000 mask FFF800000 uncachable
[ 0.001022] 9 disabled
[ 0.001943] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002285] total RAM covered: 12072M
[ 0.002611] Found optimal setting for mtrr clean up
[ 0.002612] gran_size: 64K chunk_size: 16M num_reg: 9 lose cover RAM: 0G
[ 0.003381] e820: update [mem 0xa3000000-0xffffffff] usable ==> reserved
[ 0.003389] last_pfn = 0xa2ffd max_arch_pfn = 0x400000000
[ 0.014773] found SMP MP-table at [mem 0x000fcc70-0x000fcc7f]
[ 0.014816] check: Scanning 1 areas for low memory corruption
[ 0.014820] reserving inaccessible SNB gfx pages
[ 0.016400] Secure boot could not be determined
[ 0.016402] RAMDISK: [mem 0x36b2d000-0x3758dfff]
[ 0.016410] ACPI: Early table checksum verification disabled
[ 0.016414] ACPI: RSDP 0x00000000A2FFFF98 000024 (v02 _ASUS_)
[ 0.016419] ACPI: XSDT 0x00000000A2FFEE18 000074 (v01 _ASUS_ Notebook 06222004 MSFT 00010013)
[ 0.016426] ACPI: FACP 0x00000000A2F9AD98 0000F4 (v04 _ASUS_ Notebook 06222004 MSFT 00010013)
[ 0.016433] ACPI: DSDT 0x00000000A2F86018 013B0A (v01 _ASUS_ Notebook 00000000 INTL 20091112)
[ 0.016438] ACPI: FACS 0x00000000A2FE4E40 000040
[ 0.016441] ACPI: FACS 0x00000000A2FE4D40 000040
[ 0.016445] ACPI: APIC 0x00000000A2FFDF18 0000CC (v02 _ASUS_ Notebook 06222004 MSFT 00010013)
[ 0.016449] ACPI: DBGP 0x00000000A2FFFF18 000034 (v01 _ASUS_ Notebook 06222004 MSFT 00010013)
[ 0.016453] ACPI: ECDT 0x00000000A2FE4B18 0000C1 (v01 _ASUS_ Notebook 06222004 AMI. 00000003)
[ 0.016457] ACPI: SLIC 0x00000000A2F9BE18 000176 (v01 _ASUS_ Notebook 06222004 ASUS 00000001)
[ 0.016461] ACPI: HPET 0x00000000A2FE5D18 000038 (v01 _ASUS_ Notebook 06222004 AMI. 00000003)
[ 0.016465] ACPI: MCFG 0x00000000A2FE5C98 00003C (v01 _ASUS_ Notebook 06222004 MSFT 00000097)
[ 0.016469] ACPI: SSDT 0x00000000A2F85818 000787 (v01 PmRef Cpu0Ist 00003000 INTL 20091112)
[ 0.016473] ACPI: SSDT 0x00000000A2F84018 000996 (v01 PmRef CpuPm 00003000 INTL 20091112)
[ 0.016477] ACPI: ASF! 0x00000000A2FE4A18 0000A0 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 0.016488] ACPI: Local APIC address 0xfee00000
[ 0.016532] No NUMA configuration found
[ 0.016534] Faking a node at [mem 0x0000000000000000-0x000000034f7fffff]
[ 0.016538] NODE_DATA(0) allocated [mem 0x34f7f4000-0x34f7f7fff]
[ 0.041074] Zone ranges:
[ 0.041077] DMA [mem 0x0000000000000000-0x0000000000ffffff]
[ 0.041079] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.041081] Normal [mem 0x0000000100000000-0x000000034f7fffff]
[ 0.041083] Device empty
[ 0.041084] Movable zone start for each node
[ 0.041085] Early memory node ranges
[ 0.041087] node 0: [mem 0x0000000000000000-0x000000000009ffff]
[ 0.041088] node 0: [mem 0x0000000000100000-0x000000001fffffff]
[ 0.041089] node 0: [mem 0x0000000020200000-0x000000003fffffff]
[ 0.041090] node 0: [mem 0x0000000040200000-0x00000000a2c0bfff]
[ 0.041091] node 0: [mem 0x00000000a2d8e000-0x00000000a2d93fff]
[ 0.041092] node 0: [mem 0x00000000a2d96000-0x00000000a2d96fff]
[ 0.041093] node 0: [mem 0x00000000a2db8000-0x00000000a2dc5fff]
[ 0.041094] node 0: [mem 0x00000000a2de8000-0x00000000a2e22fff]
[ 0.041095] node 0: [mem 0x00000000a2fe8000-0x00000000a2ffcfff]
[ 0.041096] node 0: [mem 0x0000000100000000-0x000000034f7fffff]
[ 0.041379] Zeroed struct page in unavailable ranges: 24559 pages
[ 0.041381] Initmem setup node 0 [mem 0x0000000000000000-0x000000034f7fffff]
[ 0.041383] On node 0 totalpages: 3088401
[ 0.041385] DMA zone: 64 pages used for memmap
[ 0.041386] DMA zone: 160 pages reserved
[ 0.041387] DMA zone: 4000 pages, LIFO batch:0
[ 0.041421] DMA32 zone: 10338 pages used for memmap
[ 0.041422] DMA32 zone: 661617 pages, LIFO batch:63
[ 0.046592] Normal zone: 37856 pages used for memmap
[ 0.046596] Normal zone: 2422784 pages, LIFO batch:63
[ 0.065655] Reserving Intel graphics memory at [mem 0xa4000000-0xafffffff]
[ 0.065785] ACPI: PM-Timer IO Port: 0x408
[ 0.065787] ACPI: Local APIC address 0xfee00000
[ 0.065806] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.065809] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.065810] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.065812] ACPI: IRQ0 used by override.
[ 0.065813] ACPI: IRQ9 used by override.
[ 0.065816] Using ACPI (MADT) for SMP configuration information
[ 0.065818] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.065823] TSC deadline timer available
[ 0.065824] smpboot: Allowing 16 CPUs, 12 hotplug CPUs
[ 0.065864] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.065866] PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
[ 0.065868] PM: hibernation: Registered nosave memory: [mem 0x40000000-0x401fffff]
[ 0.065871] PM: hibernation: Registered nosave memory: [mem 0xa2c0c000-0xa2c0cfff]
[ 0.065872] PM: hibernation: Registered nosave memory: [mem 0xa2c0d000-0xa2d1ffff]
[ 0.065873] PM: hibernation: Registered nosave memory: [mem 0xa2d20000-0xa2d47fff]
[ 0.065874] PM: hibernation: Registered nosave memory: [mem 0xa2d48000-0xa2d77fff]
[ 0.065874] PM: hibernation: Registered nosave memory: [mem 0xa2d78000-0xa2d8dfff]
[ 0.065877] PM: hibernation: Registered nosave memory: [mem 0xa2d94000-0xa2d95fff]
[ 0.065879] PM: hibernation: Registered nosave memory: [mem 0xa2d97000-0xa2db7fff]
[ 0.065881] PM: hibernation: Registered nosave memory: [mem 0xa2dc6000-0xa2de7fff]
[ 0.065884] PM: hibernation: Registered nosave memory: [mem 0xa2e23000-0xa2fe7fff]
[ 0.065886] PM: hibernation: Registered nosave memory: [mem 0xa2ffd000-0xa2ffffff]
[ 0.065887] PM: hibernation: Registered nosave memory: [mem 0xa3000000-0xafffffff]
[ 0.065888] PM: hibernation: Registered nosave memory: [mem 0xb0000000-0xdfffffff]
[ 0.065889] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xe3ffffff]
[ 0.065890] PM: hibernation: Registered nosave memory: [mem 0xe4000000-0xfebfffff]
[ 0.065891] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.065891] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
[ 0.065892] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed13fff]
[ 0.065893] PM: hibernation: Registered nosave memory: [mem 0xfed14000-0xfed17fff]
[ 0.065894] PM: hibernation: Registered nosave memory: [mem 0xfed18000-0xfed19fff]
[ 0.065895] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
[ 0.065896] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.065897] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.065898] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.065898] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff97ffff]
[ 0.065899] PM: hibernation: Registered nosave memory: [mem 0xff980000-0xffbfffff]
[ 0.065900] PM: hibernation: Registered nosave memory: [mem 0xffc00000-0xffd7ffff]
[ 0.065901] PM: hibernation: Registered nosave memory: [mem 0xffd80000-0xffffffff]
[ 0.065903] [mem 0xb0000000-0xdfffffff] available for PCI devices
[ 0.065906] Booting paravirtualized kernel on bare hardware
[ 0.065909] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.072502] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[ 0.073059] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.073072] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.073073] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.073113] Built 1 zonelists, mobility grouping on. Total pages: 3039983
[ 0.073115] Policy zone: Normal
[ 0.073116] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=d770c061-597b-4849-868d-6cb431db7ceb ro quiet apparmor=1 security=apparmor udev.log_priority=3 ipv6.disable=1
[ 0.074232] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.074730] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.074921] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.114549] Memory: 11990912K/12353604K available (14344K kernel code, 2059K rwdata, 4804K rodata, 1708K init, 4272K bss, 362432K reserved, 0K cma-reserved)
[ 0.114558] random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
[ 0.114712] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.114726] Kernel/User page tables isolation: enabled
[ 0.114748] ftrace: allocating 41806 entries in 164 pages
[ 0.131941] ftrace: allocated 164 pages with 3 groups
[ 0.132094] rcu: Preemptible hierarchical RCU implementation.
[ 0.132096] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.132097] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.132098] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.132099] Trampoline variant of Tasks RCU enabled.
[ 0.132100] Rude variant of Tasks RCU enabled.
[ 0.132101] Tracing variant of Tasks RCU enabled.
[ 0.132102] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.132103] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.137043] NR_IRQS: 20736, nr_irqs: 552, preallocated irqs: 16
[ 0.137323] Console: colour dummy device 80x25
[ 0.137342] printk: console [tty0] enabled
[ 0.137367] ACPI: Core revision 20200925
[ 0.137518] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.137534] APIC: Switch to symmetric I/O mode setup
[ 0.137605] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.137636] Switched APIC routing to physical flat.
[ 0.138020] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.154201] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x21149edbfad, max_idle_ns: 440795290016 ns
[ 0.154206] Calibrating delay loop (skipped), value calculated using timer frequency.. 4591.17 BogoMIPS (lpj=7649876)
[ 0.154209] pid_max: default: 32768 minimum: 301
[ 0.157570] LSM: Security Framework initializing
[ 0.157577] Yama: becoming mindful.
[ 0.157603] AppArmor: AppArmor initialized
[ 0.157649] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.157680] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.157995] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.158006] process: using mwait in idle threads
[ 0.158009] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.158010] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.158013] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.158015] Spectre V2 : Mitigation: Full generic retpoline
[ 0.158016] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.158017] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.158019] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.158020] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.158022] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.158024] MDS: Mitigation: Clear CPU buffers
[ 0.158232] Freeing SMP alternatives memory: 36K
[ 0.160972] smpboot: CPU0: Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz (family: 0x6, model: 0x2a, stepping: 0x7)
[ 0.161153] Performance Events: PEBS fmt1+, SandyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.161163] ... version: 3
[ 0.161164] ... bit width: 48
[ 0.161164] ... generic registers: 4
[ 0.161166] ... value mask: 0000ffffffffffff
[ 0.161167] ... max period: 00007fffffffffff
[ 0.161167] ... fixed-purpose events: 3
[ 0.161168] ... event mask: 000000070000000f
[ 0.161330] rcu: Hierarchical SRCU implementation.
[ 0.162730] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.162925] smp: Bringing up secondary CPUs ...
[ 0.163085] x86: Booting SMP configuration:
[ 0.163086] .... node #0, CPUs: #1 #2
[ 0.167660] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.167748] #3
[ 0.170069] smp: Brought up 1 node, 4 CPUs
[ 0.170069] smpboot: Max logical packages: 4
[ 0.170069] smpboot: Total of 4 processors activated (18367.69 BogoMIPS)
[ 0.171277] devtmpfs: initialized
[ 0.171277] x86/mm: Memory block size: 128MB
[ 0.171896] PM: Registering ACPI NVS region [mem 0xa2e23000-0xa2fe7fff] (1855488 bytes)
[ 0.171896] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.171896] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.171896] pinctrl core: initialized pinctrl subsystem
[ 0.171896] PM: RTC time: 09:42:07, date: 2021-02-10
[ 0.171896] NET: Registered protocol family 16
[ 0.171896] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.171949] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.172164] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.172182] audit: initializing netlink subsys (disabled)
[ 0.172206] audit: type=2000 audit(1612950127.033:1): state=initialized audit_enabled=0 res=1
[ 0.172206] thermal_sys: Registered thermal governor 'fair_share'
[ 0.172206] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.172206] thermal_sys: Registered thermal governor 'step_wise'
[ 0.172206] thermal_sys: Registered thermal governor 'user_space'
[ 0.172206] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.172206] cpuidle: using governor ladder
[ 0.172206] cpuidle: using governor menu
[ 0.172206] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.172206] ACPI: bus type PCI registered
[ 0.172206] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.174243] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ 0.174247] PCI: MMCONFIG at [mem 0xe0000000-0xe3ffffff] reserved in E820
[ 0.174259] PCI: Using configuration type 1 for base access
[ 0.174318] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.174576] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.175492] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.175492] ACPI: Added _OSI(Module Device)
[ 0.175492] ACPI: Added _OSI(Processor Device)
[ 0.175492] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.175492] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.175492] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.175492] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.175492] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.193861] ACPI: 3 ACPI AML tables successfully acquired and loaded
[ 0.194841] ACPI: EC: EC started
[ 0.194842] ACPI: EC: interrupt blocked
[ 0.196190] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.196191] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.197144] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.308799] ACPI: Dynamic OEM Table Load:
[ 0.308807] ACPI: SSDT 0xFFFF991000AFD800 00073F (v01 PmRef Cpu0Cst 00003001 INTL 20091112)
[ 0.310241] ACPI: Dynamic OEM Table Load:
[ 0.310247] ACPI: SSDT 0xFFFF991000B10000 000303 (v01 PmRef ApIst 00003000 INTL 20091112)
[ 0.311411] ACPI: Dynamic OEM Table Load:
[ 0.311416] ACPI: SSDT 0xFFFF991000D40E00 000119 (v01 PmRef ApCst 00003000 INTL 20091112)
[ 0.313328] ACPI: Interpreter enabled
[ 0.313361] ACPI: (supports S0 S3 S4 S5)
[ 0.313362] ACPI: Using IOAPIC for interrupt routing
[ 0.313400] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.313738] ACPI: Enabled 13 GPEs in block 00 to 3F
[ 0.381233] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.381241] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.382069] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.382071] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.382858] PCI host bridge to bus 0000:00
[ 0.382861] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.382862] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.382864] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.382865] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.382867] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.382868] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.382869] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.382871] pci_bus 0000:00: root bus resource [mem 0xb0000000-0xfeafffff window]
[ 0.382872] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
[ 0.382874] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.382888] pci 0000:00:00.0: [8086:0104] type 00 class 0x060000
[ 0.383021] pci 0000:00:01.0: [8086:0101] type 01 class 0x060400
[ 0.383063] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.383201] pci 0000:00:02.0: [8086:0116] type 00 class 0x030000
[ 0.383210] pci 0000:00:02.0: reg 0x10: [mem 0xdc400000-0xdc7fffff 64bit]
[ 0.383216] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[ 0.383220] pci 0000:00:02.0: reg 0x20: [io 0xe000-0xe03f]
[ 0.383233] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.383467] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[ 0.383489] pci 0000:00:16.0: reg 0x10: [mem 0xdf00b000-0xdf00b00f 64bit]
[ 0.383569] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.383699] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[ 0.383716] pci 0000:00:1a.0: reg 0x10: [mem 0xdf008000-0xdf0083ff]
[ 0.383803] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.383942] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[ 0.383960] pci 0000:00:1b.0: reg 0x10: [mem 0xdf000000-0xdf003fff 64bit]
[ 0.384043] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.384192] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[ 0.384289] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.384443] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[ 0.384538] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.384688] pci 0000:00:1c.3: [8086:1c16] type 01 class 0x060400
[ 0.384785] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.384934] pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400
[ 0.385030] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.385182] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[ 0.385199] pci 0000:00:1d.0: reg 0x10: [mem 0xdf007000-0xdf0073ff]
[ 0.385286] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.385426] pci 0000:00:1f.0: [8086:1c49] type 00 class 0x060100
[ 0.385660] pci 0000:00:1f.2: [8086:1c03] type 00 class 0x010601
[ 0.385674] pci 0000:00:1f.2: reg 0x10: [io 0xe0b0-0xe0b7]
[ 0.385682] pci 0000:00:1f.2: reg 0x14: [io 0xe0a0-0xe0a3]
[ 0.385690] pci 0000:00:1f.2: reg 0x18: [io 0xe090-0xe097]
[ 0.385698] pci 0000:00:1f.2: reg 0x1c: [io 0xe080-0xe083]
[ 0.385706] pci 0000:00:1f.2: reg 0x20: [io 0xe060-0xe07f]
[ 0.385715] pci 0000:00:1f.2: reg 0x24: [mem 0xdf006000-0xdf0067ff]
[ 0.385760] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.385887] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[ 0.385906] pci 0000:00:1f.3: reg 0x10: [mem 0xdf005000-0xdf0050ff 64bit]
[ 0.385927] pci 0000:00:1f.3: reg 0x20: [io 0xe040-0xe05f]
[ 0.386120] pci 0000:01:00.0: [10de:1058] type 00 class 0x030000
[ 0.386135] pci 0000:01:00.0: reg 0x10: [mem 0xdb000000-0xdbffffff]
[ 0.386147] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xc7ffffff 64bit pref]
[ 0.386159] pci 0000:01:00.0: reg 0x1c: [mem 0xc8000000-0xc9ffffff 64bit pref]
[ 0.386167] pci 0000:01:00.0: reg 0x24: [io 0xd000-0xd07f]
[ 0.386174] pci 0000:01:00.0: reg 0x30: [mem 0xdc000000-0xdc07ffff pref]
[ 0.386182] pci 0000:01:00.0: enabling Extended Tags
[ 0.386199] pci 0000:01:00.0: Enabling HDA controller
[ 0.386451] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.386453] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.386456] pci 0000:00:01.0: bridge window [mem 0xdb000000-0xdc0fffff]
[ 0.386459] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xc9ffffff 64bit pref]
[ 0.386504] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.386508] pci 0000:00:1c.0: bridge window [io 0xc000-0xcfff]
[ 0.386512] pci 0000:00:1c.0: bridge window [mem 0xde600000-0xdeffffff]
[ 0.386518] pci 0000:00:1c.0: bridge window [mem 0xcc200000-0xccbfffff 64bit pref]
[ 0.386632] pci 0000:03:00.0: [8086:08ae] type 00 class 0x028000
[ 0.386686] pci 0000:03:00.0: reg 0x10: [mem 0xddc00000-0xddc01fff 64bit]
[ 0.386938] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.387116] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.387120] pci 0000:00:1c.1: bridge window [io 0xb000-0xbfff]
[ 0.387125] pci 0000:00:1c.1: bridge window [mem 0xddc00000-0xde5fffff]
[ 0.387131] pci 0000:00:1c.1: bridge window [mem 0xcb700000-0xcc0fffff 64bit pref]
[ 0.387235] pci 0000:04:00.0: [1b21:1042] type 00 class 0x0c0330
[ 0.387279] pci 0000:04:00.0: reg 0x10: [mem 0xdd200000-0xdd207fff 64bit]
[ 0.387498] pci 0000:04:00.0: PME# supported from D3hot D3cold
[ 0.387649] pci 0000:00:1c.3: PCI bridge to [bus 04]
[ 0.387654] pci 0000:00:1c.3: bridge window [io 0xa000-0xafff]
[ 0.387658] pci 0000:00:1c.3: bridge window [mem 0xdd200000-0xddbfffff]
[ 0.387664] pci 0000:00:1c.3: bridge window [mem 0xcac00000-0xcb5fffff 64bit pref]
[ 0.387759] pci 0000:05:00.0: [1969:1083] type 00 class 0x020000
[ 0.387793] pci 0000:05:00.0: reg 0x10: [mem 0xdc800000-0xdc83ffff 64bit]
[ 0.387808] pci 0000:05:00.0: reg 0x18: [io 0x9000-0x907f]
[ 0.387956] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.388103] pci 0000:00:1c.5: PCI bridge to [bus 05]
[ 0.388107] pci 0000:00:1c.5: bridge window [io 0x9000-0x9fff]
[ 0.388111] pci 0000:00:1c.5: bridge window [mem 0xdc800000-0xdd1fffff]
[ 0.388117] pci 0000:00:1c.5: bridge window [mem 0xca100000-0xcaafffff 64bit pref]
[ 0.445110] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12)
[ 0.445206] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 12)
[ 0.445298] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 10 12)
[ 0.445389] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *10 12)
[ 0.445480] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.445572] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.445665] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 10 12)
[ 0.445756] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 10 12)
[ 0.446042] ACPI: EC: interrupt unblocked
[ 0.446044] ACPI: EC: event unblocked
[ 0.446051] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.446052] ACPI: EC: GPE=0x1b
[ 0.446054] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot ECDT EC initialization complete
[ 0.446055] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.446128] iommu: Default domain type: Translated
[ 0.446144] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.446144] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.446144] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.446144] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.446144] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.446144] vgaarb: loaded
[ 0.446144] SCSI subsystem initialized
[ 0.446144] libata version 3.00 loaded.
[ 0.446144] ACPI: bus type USB registered
[ 0.446144] usbcore: registered new interface driver usbfs
[ 0.446144] usbcore: registered new interface driver hub
[ 0.446144] usbcore: registered new device driver usb
[ 0.446144] pps_core: LinuxPPS API ver. 1 registered
[ 0.446144] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.446144] PTP clock support registered
[ 0.446144] EDAC MC: Ver: 3.0.0
[ 0.446144] Registered efivars operations
[ 0.446144] NetLabel: Initializing
[ 0.446144] NetLabel: domain hash size = 128
[ 0.446144] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.446144] NetLabel: unlabeled traffic allowed by default
[ 0.446144] PCI: Using ACPI for IRQ routing
[ 0.446144] PCI: pci_cache_line_size set to 64 bytes
[ 0.446144] e820: reserve RAM buffer [mem 0xa2c0c000-0xa3ffffff]
[ 0.446144] e820: reserve RAM buffer [mem 0xa2d94000-0xa3ffffff]
[ 0.446144] e820: reserve RAM buffer [mem 0xa2d97000-0xa3ffffff]
[ 0.446144] e820: reserve RAM buffer [mem 0xa2dc6000-0xa3ffffff]
[ 0.446144] e820: reserve RAM buffer [mem 0xa2e23000-0xa3ffffff]
[ 0.446144] e820: reserve RAM buffer [mem 0xa2ffd000-0xa3ffffff]
[ 0.446144] e820: reserve RAM buffer [mem 0x34f800000-0x34fffffff]
[ 0.448501] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.448510] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.450938] clocksource: Switched to clocksource tsc-early
[ 0.464662] VFS: Disk quotas dquot_6.6.0
[ 0.464689] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.464811] AppArmor: AppArmor Filesystem Enabled
[ 0.464843] pnp: PnP ACPI init
[ 0.521150] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.521152] system 00:00: [io 0x1000-0x100f] has been reserved
[ 0.521154] system 00:00: [io 0xffff] has been reserved
[ 0.521156] system 00:00: [io 0xffff] has been reserved
[ 0.521158] system 00:00: [io 0x0400-0x0453] has been reserved
[ 0.521159] system 00:00: [io 0x0458-0x047f] has been reserved
[ 0.521161] system 00:00: [io 0x0500-0x057f] has been reserved
[ 0.521162] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.521170] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.521200] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.521254] system 00:02: [io 0x0454-0x0457] has been reserved
[ 0.521259] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.521303] system 00:03: [io 0x0240-0x0259] has been reserved
[ 0.521307] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.521378] pnp 00:04: Plug and Play ACPI device, IDs SYN0a17 SYN0a00 SYN0002 PNP0f03 PNP0f13 PNP0f12 (active)
[ 0.521422] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.521748] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.521751] system 00:06: [mem 0xfed10000-0xfed17fff] could not be reserved
[ 0.521752] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.521754] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.521756] system 00:06: [mem 0xe0000000-0xe3ffffff] has been reserved
[ 0.521757] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.521759] system 00:06: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.521761] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.521762] system 00:06: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.521764] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.521769] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.521881] system 00:07: [mem 0xccc00000-0xccc00fff] has been reserved
[ 0.521886] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.522080] system 00:08: [mem 0x20000000-0x201fffff] has been reserved
[ 0.522082] system 00:08: [mem 0x40000000-0x401fffff] has been reserved
[ 0.522087] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.522114] pnp: PnP ACPI: found 9 devices
[ 0.528252] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.528324] NET: Registered protocol family 2
[ 0.528518] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.528641] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.528938] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.529051] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.529174] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.529271] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.529334] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.529496] NET: Registered protocol family 1
[ 0.529502] NET: Registered protocol family 44
[ 0.529517] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.529521] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.529525] pci 0000:00:01.0: bridge window [mem 0xdb000000-0xdc0fffff]
[ 0.529527] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xc9ffffff 64bit pref]
[ 0.529530] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.529533] pci 0000:00:1c.0: bridge window [io 0xc000-0xcfff]
[ 0.529539] pci 0000:00:1c.0: bridge window [mem 0xde600000-0xdeffffff]
[ 0.529542] pci 0000:00:1c.0: bridge window [mem 0xcc200000-0xccbfffff 64bit pref]
[ 0.529549] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.529552] pci 0000:00:1c.1: bridge window [io 0xb000-0xbfff]
[ 0.529557] pci 0000:00:1c.1: bridge window [mem 0xddc00000-0xde5fffff]
[ 0.529561] pci 0000:00:1c.1: bridge window [mem 0xcb700000-0xcc0fffff 64bit pref]
[ 0.529567] pci 0000:00:1c.3: PCI bridge to [bus 04]
[ 0.529570] pci 0000:00:1c.3: bridge window [io 0xa000-0xafff]
[ 0.529575] pci 0000:00:1c.3: bridge window [mem 0xdd200000-0xddbfffff]
[ 0.529579] pci 0000:00:1c.3: bridge window [mem 0xcac00000-0xcb5fffff 64bit pref]
[ 0.529585] pci 0000:00:1c.5: PCI bridge to [bus 05]
[ 0.529588] pci 0000:00:1c.5: bridge window [io 0x9000-0x9fff]
[ 0.529593] pci 0000:00:1c.5: bridge window [mem 0xdc800000-0xdd1fffff]
[ 0.529597] pci 0000:00:1c.5: bridge window [mem 0xca100000-0xcaafffff 64bit pref]
[ 0.529605] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.529606] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.529608] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.529609] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.529611] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.529612] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.529614] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.529615] pci_bus 0000:00: resource 11 [mem 0xb0000000-0xfeafffff window]
[ 0.529617] pci_bus 0000:00: resource 12 [mem 0xfed40000-0xfed44fff window]
[ 0.529618] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.529620] pci_bus 0000:01: resource 1 [mem 0xdb000000-0xdc0fffff]
[ 0.529621] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xc9ffffff 64bit pref]
[ 0.529622] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff]
[ 0.529624] pci_bus 0000:02: resource 1 [mem 0xde600000-0xdeffffff]
[ 0.529625] pci_bus 0000:02: resource 2 [mem 0xcc200000-0xccbfffff 64bit pref]
[ 0.529627] pci_bus 0000:03: resource 0 [io 0xb000-0xbfff]
[ 0.529628] pci_bus 0000:03: resource 1 [mem 0xddc00000-0xde5fffff]
[ 0.529629] pci_bus 0000:03: resource 2 [mem 0xcb700000-0xcc0fffff 64bit pref]
[ 0.529631] pci_bus 0000:04: resource 0 [io 0xa000-0xafff]
[ 0.529632] pci_bus 0000:04: resource 1 [mem 0xdd200000-0xddbfffff]
[ 0.529633] pci_bus 0000:04: resource 2 [mem 0xcac00000-0xcb5fffff 64bit pref]
[ 0.529635] pci_bus 0000:05: resource 0 [io 0x9000-0x9fff]
[ 0.529636] pci_bus 0000:05: resource 1 [mem 0xdc800000-0xdd1fffff]
[ 0.529638] pci_bus 0000:05: resource 2 [mem 0xca100000-0xcaafffff 64bit pref]
[ 0.529782] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.530522] pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
[ 0.530527] PCI: CLS 64 bytes, default 64
[ 0.530584] Trying to unpack rootfs image as initramfs...
[ 0.652454] Freeing initrd memory: 10628K
[ 0.652467] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.652469] software IO TLB: mapped [mem 0x000000009e533000-0x00000000a2533000] (64MB)
[ 0.652950] check: Scanning for low memory corruption every 60 seconds
[ 0.653371] Initialise system trusted keyrings
[ 0.653382] Key type blacklist registered
[ 0.653436] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.654713] zbud: loaded
[ 0.667433] Key type asymmetric registered
[ 0.667435] Asymmetric key parser 'x509' registered
[ 0.667442] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.667481] io scheduler mq-deadline registered
[ 0.667482] io scheduler kyber registered
[ 0.667508] io scheduler bfq registered
[ 0.667588] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ 0.667903] pcieport 0000:00:01.0: PME: Signaling with IRQ 24
[ 0.668121] pcieport 0000:00:1c.0: PME: Signaling with IRQ 25
[ 0.668348] pcieport 0000:00:1c.1: PME: Signaling with IRQ 26
[ 0.668463] pcieport 0000:00:1c.3: PME: Signaling with IRQ 27
[ 0.668679] pcieport 0000:00:1c.5: PME: Signaling with IRQ 28
[ 0.668775] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.668806] efifb: probing for efifb
[ 0.668824] efifb: No BGRT, not showing boot graphics
[ 0.668825] efifb: framebuffer at 0xb0000000, using 1920k, total 1920k
[ 0.668827] efifb: mode is 800x600x32, linelength=3200, pages=1
[ 0.668827] efifb: scrolling: redraw
[ 0.668829] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.668875] fbcon: Deferring console take-over
[ 0.668877] fb0: EFI VGA frame buffer device
[ 0.668885] intel_idle: MWAIT substates: 0x21120
[ 0.668887] intel_idle: v0.5.1 model 0x2A
[ 0.669079] intel_idle: Local APIC timer is reliable in all C-states
[ 0.669237] ACPI: AC Adapter [AC0] (on-line)
[ 0.669303] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.669323] ACPI: Lid Switch [LID]
[ 0.669357] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.670928] ACPI: Sleep Button [SLPB]
[ 0.670979] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.674250] ACPI: Power Button [PWRF]
[ 0.675752] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.675755] ACPI: Thermal Zone [THRM] (71 C)
[ 0.676014] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.678047] Non-volatile memory driver v1.3
[ 0.678049] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.678050] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.678748] ahci 0000:00:1f.2: version 3.0
[ 0.678972] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
[ 0.678975] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[ 0.691455] scsi host0: ahci
[ 0.691808] scsi host1: ahci
[ 0.692023] scsi host2: ahci
[ 0.692140] scsi host3: ahci
[ 0.692245] scsi host4: ahci
[ 0.692353] scsi host5: ahci
[ 0.692396] ata1: SATA max UDMA/133 abar m2048@0xdf006000 port 0xdf006100 irq 29
[ 0.692398] ata2: DUMMY
[ 0.692400] ata3: SATA max UDMA/133 abar m2048@0xdf006000 port 0xdf006200 irq 29
[ 0.692401] ata4: DUMMY
[ 0.692402] ata5: DUMMY
[ 0.692402] ata6: DUMMY
[ 0.692447] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.692454] ehci-pci: EHCI PCI platform driver
[ 0.692650] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.692658] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.692672] ehci-pci 0000:00:1a.0: debug port 2
[ 0.696566] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.696579] ehci-pci 0000:00:1a.0: irq 16, io mem 0xdf008000
[ 0.697546] random: fast init done
[ 0.707581] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.708050] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.708119] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.708121] usb usb1: Product: EHCI Host Controller
[ 0.708122] usb usb1: Manufacturer: Linux 5.10.13-2-MANJARO ehci_hcd
[ 0.708196] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.708323] hub 1-0:1.0: USB hub found
[ 0.708330] hub 1-0:1.0: 2 ports detected
[ 0.708590] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.708595] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.708607] ehci-pci 0000:00:1d.0: debug port 2
[ 0.712525] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.712536] ehci-pci 0000:00:1d.0: irq 23, io mem 0xdf007000
[ 0.716777] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 0.724226] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.724285] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.724287] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.724289] usb usb2: Product: EHCI Host Controller
[ 0.724290] usb usb2: Manufacturer: Linux 5.10.13-2-MANJARO ehci_hcd
[ 0.724291] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.724412] hub 2-0:1.0: USB hub found
[ 0.724419] hub 2-0:1.0: 2 ports detected
[ 0.724540] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.724544] ohci-pci: OHCI PCI platform driver
[ 0.724553] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.724592] usbcore: registered new interface driver usbserial_generic
[ 0.724597] usbserial: USB Serial support registered for generic
[ 0.724632] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.726113] i8042: Detected active multiplexing controller, rev 1.1
[ 0.726898] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.726929] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.726948] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.726968] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.726993] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.727145] rtc_cmos 00:01: RTC can wake from S4
[ 0.727359] rtc_cmos 00:01: registered as rtc0
[ 0.727394] rtc_cmos 00:01: setting system clock to 2021-02-10T09:42:08 UTC (1612950128)
[ 0.727412] rtc_cmos 00:01: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[ 0.727447] intel_pstate: Intel P-state driver initializing
[ 0.727751] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.763667] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.786516] pstore: Registered efi as persistent store backend
[ 0.786532] hid: raw HID events driver (C) Jiri Kosina
[ 0.786610] ashmem: initialized
[ 0.786713] drop_monitor: Initializing network drop monitor service
[ 0.786787] Initializing XFRM netlink socket
[ 0.786790] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 0.786792] NET: Registered protocol family 17
[ 0.787095] microcode: sig=0x206a7, pf=0x10, revision=0x2f
[ 0.787109] microcode: Microcode Update Driver: v2.2.
[ 0.787114] IPI shorthand broadcast: enabled
[ 0.787122] sched_clock: Marking stable (786723635, 276377)->(1088867848, -301867836)
[ 0.787205] registered taskstats version 1
[ 0.787215] Loading compiled-in X.509 certificates
[ 0.791457] Loaded X.509 cert 'Build time autogenerated kernel key: af0853476189aa7e04019ea3754d5a648f6b10c2'
[ 0.792352] zswap: loaded using pool zstd/z3fold
[ 0.792558] Key type ._fscrypt registered
[ 0.792560] Key type .fscrypt registered
[ 0.792561] Key type fscrypt-provisioning registered
[ 0.792778] pstore: Using crash dump compression: zstd
[ 0.792798] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.793315] PM: Magic number: 9:363:727
[ 0.793547] RAS: Correctable Errors collector initialized.
[ 0.799120] random: crng init done
[ 1.007564] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.007594] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.013786] ata1.00: LPM support broken, forcing max_power
[ 1.014424] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1.014498] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 1.014501] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.018340] ata3.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 1.018344] ata3.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.019413] ata3.00: ATAPI: MATSHITABD-CMB UJ141AF, 1.00, max UDMA/100
[ 1.021008] ata1.00: ATA-8: ST1000LM024 HN-M101MBB, 2AR10001, max UDMA/133
[ 1.021010] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32)
[ 1.022054] ata3.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 1.022057] ata3.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.023197] ata3.00: configured for UDMA/100
[ 1.027269] ata1.00: LPM support broken, forcing max_power
[ 1.027864] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1.027939] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[ 1.027943] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.034175] ata1.00: configured for UDMA/133
[ 1.037557] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.047712] scsi 0:0:0:0: Direct-Access ATA ST1000LM024 HN-M 0001 PQ: 0 ANSI: 5
[ 1.047924] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.047928] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.047943] sd 0:0:0:0: [sda] Write Protect is off
[ 1.047946] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.047971] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.049101] scsi 2:0:0:0: CD-ROM MATSHITA BD-CMB UJ141AF 1.00 PQ: 0 ANSI: 5
[ 1.054222] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.068877] sda: sda1 sda2 sda3
[ 1.069308] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.077402] Freeing unused decrypted memory: 2036K
[ 1.077891] Freeing unused kernel image (initmem) memory: 1708K
[ 1.077978] Write protecting the kernel read-only data: 22528k
[ 1.078846] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.079346] Freeing unused kernel image (rodata/data gap) memory: 1340K
[ 1.179905] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.179913] rodata_test: all tests were successful
[ 1.179915] x86/mm: Checking user space page tables
[ 1.184306] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.184309] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.184474] hub 1-1:1.0: USB hub found
[ 1.184496] hub 1-1:1.0: 6 ports detected
[ 1.188487] irq 16: nobody cared (try booting with the "irqpoll" option)
[ 1.188490] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.13-2-MANJARO #1
[ 1.188492] Hardware name: ASUSTeK Computer Inc. K53SD/K53SD, BIOS K53SD.208 08/10/2012
[ 1.188493] Call Trace:
[ 1.188496] <IRQ>
[ 1.188503] dump_stack+0x6b/0x83
[ 1.188507] __report_bad_irq+0x35/0xaa
[ 1.188509] note_interrupt.cold+0xb/0x64
[ 1.188514] handle_irq_event+0xa9/0xb0
[ 1.188516] handle_fasteoi_irq+0x8a/0x1f0
[ 1.188520] asm_call_irq_on_stack+0x12/0x20
[ 1.188521] </IRQ>
[ 1.188525] common_interrupt+0xb3/0x130
[ 1.188527] asm_common_interrupt+0x1e/0x40
[ 1.188531] RIP: 0010:note_page+0x0/0x660
[ 1.188533] Code: 77 01 48 89 d1 80 cd 10 48 c1 e8 2b a8 01 48 0f 45 d1 45 31 c0 31 c9 e9 ee fe ff ff 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 <66> 66 66 66 90 41 57 41 56 41 55 49 89 f5 41 54 49 89 cc 55 53 48
[ 1.188535] RSP: 0000:ffffb0a38003bd08 EFLAGS: 00000286
[ 1.188537] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 1.188538] RDX: 0000000000000004 RSI: ffffff1a14e1e000 RDI: ffffb0a38003beb0
[ 1.188539] RBP: ffffb0a38003beb0 R08: ffffffffa587e3d0 R09: 0000000000000000
[ 1.188541] R10: ffff99106bdd8000 R11: ffffffffa6ecb228 R12: ffffff1a14e1e000
[ 1.188542] R13: ffffff1a14e1f000 R14: ffffff1a14e1e000 R15: ffffb0a38003be10
[ 1.188544] ? ptdump_walk_pgd_level_debugfs+0x40/0x40
[ 1.188547] ? ptdump_walk_pgd_level_debugfs+0x40/0x40
[ 1.188550] ptdump_pte_entry+0x57/0x60
[ 1.188554] __walk_page_range+0xb36/0xc40
[ 1.188558] walk_page_range_novma+0x6a/0xa0
[ 1.188560] ptdump_walk_pgd+0x4e/0x80
[ 1.188563] ptdump_walk_pgd_level_core+0xb3/0xe0
[ 1.188565] ? ptdump_walk_pgd_level_debugfs+0x40/0x40
[ 1.188567] ? hugetlb_get_unmapped_area+0x330/0x330
[ 1.188570] ? rest_init+0xbe/0xbe
[ 1.188572] kernel_init+0x49/0x112
[ 1.188575] ret_from_fork+0x22/0x30
[ 1.188577] handlers:
[ 1.188581] [<000000003ee640c6>] usb_hcd_irq
[ 1.188582] Disabling IRQ #16
[ 1.188593] fbcon: Taking over console
[ 1.188719] Console: switching to colour frame buffer device 100x37
[ 1.201240] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.201243] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.201523] hub 2-1:1.0: USB hub found
[ 1.201611] hub 2-1:1.0: 6 ports detected
[ 1.247606] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.247611] Run /init as init process
[ 1.247613] with arguments:
[ 1.247614] /init
[ 1.247615] with environment:
[ 1.247615] HOME=/
[ 1.247616] TERM=linux
[ 1.247617] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[ 1.682569] tsc: Refined TSC clocksource calibration: 2294.787 MHz
[ 1.682579] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2113f8b171d, max_idle_ns: 440795241185 ns
[ 1.682597] clocksource: Switched to clocksource tsc
[ 1.896315] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 1.896327] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
[ 1.907001] xhci_hcd 0000:04:00.0: hcc params 0x0200f180 hci version 0x96 quirks 0x0000000000080000
[ 1.907322] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.907325] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.907326] usb usb3: Product: xHCI Host Controller
[ 1.907328] usb usb3: Manufacturer: Linux 5.10.13-2-MANJARO xhci-hcd
[ 1.907329] usb usb3: SerialNumber: 0000:04:00.0
[ 1.907719] hub 3-0:1.0: USB hub found
[ 1.907730] hub 3-0:1.0: 2 ports detected
[ 1.907890] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 1.907895] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
[ 1.907899] xhci_hcd 0000:04:00.0: Host supports USB 3.0 SuperSpeed
[ 1.907939] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.907964] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.907966] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.907967] usb usb4: Product: xHCI Host Controller
[ 1.907968] usb usb4: Manufacturer: Linux 5.10.13-2-MANJARO xhci-hcd
[ 1.907969] usb usb4: SerialNumber: 0000:04:00.0
[ 1.908107] hub 4-0:1.0: USB hub found
[ 1.908124] hub 4-0:1.0: 2 ports detected
[ 1.940755] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.940760] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.031608] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 2.237582] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[ 2.384196] usb 3-1: New USB device found, idVendor=046d, idProduct=c525, bcdDevice= 2.00
[ 2.384205] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.384226] usb 3-1: Product: USB Receiver
[ 2.384230] usb 3-1: Manufacturer: Logitech
[ 2.403260] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1/3-1:1.0/0003:046D:C525.0001/input/input8
[ 2.403461] hid-generic 0003:046D:C525.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:04:00.0-1/input0
[ 2.405777] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1/3-1:1.1/0003:046D:C525.0002/input/input9
[ 2.461329] hid-generic 0003:046D:C525.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.0-1/input1
[ 2.461475] usbcore: registered new interface driver usbhid
[ 2.461477] usbhid: USB HID core driver
[ 2.627618] usb 1-1.2: new high-speed USB device number 3 using ehci-pci
[ 3.095983] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.707800] usb 1-1.2: New USB device found, idVendor=058f, idProduct=a014, bcdDevice= 0.03
[ 3.707809] usb 1-1.2: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 3.707813] usb 1-1.2: Product: ASUS USB2.0 WebCam
[ 3.707817] usb 1-1.2: Manufacturer: 04G6200086K1AN23J001XSH
[ 6.153509] systemd[1]: systemd 247.3-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 6.167972] systemd[1]: Detected architecture x86-64.
[ 6.218996] systemd[1]: Set hostname to <ordi1>.
[ 13.522309] systemd[1]: Queued start job for default target Graphical Interface.
[ 13.552423] systemd[1]: Created slice system-getty.slice.
[ 13.553597] systemd[1]: Created slice system-modprobe.slice.
[ 13.554658] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 13.555698] systemd[1]: Created slice User and Session Slice.
[ 13.555933] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 13.556122] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.556639] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.556782] systemd[1]: Reached target Local Encrypted Volumes.
[ 13.556833] systemd[1]: Reached target Login Prompts.
[ 13.556941] systemd[1]: Reached target Remote File Systems.
[ 13.556979] systemd[1]: Reached target Slices.
[ 13.557039] systemd[1]: Reached target Swap.
[ 13.557323] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 13.557663] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 13.569998] systemd[1]: Listening on LVM2 poll daemon socket.
[ 13.582972] systemd[1]: Listening on Process Core Dump Socket.
[ 13.583542] systemd[1]: Listening on Journal Audit Socket.
[ 13.583888] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.584312] systemd[1]: Listening on Journal Socket.
[ 13.585018] systemd[1]: Listening on udev Control Socket.
[ 13.585325] systemd[1]: Listening on udev Kernel Socket.
[ 13.588007] systemd[1]: Mounting Huge Pages File System...
[ 13.589978] systemd[1]: Mounting POSIX Message Queue File System...
[ 13.592301] systemd[1]: Mounting Kernel Debug File System...
[ 13.594243] systemd[1]: Mounting Kernel Trace File System...
[ 13.596333] systemd[1]: Starting Load AppArmor profiles...
[ 13.598707] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 13.599966] systemd[1]: Starting Load Kernel Module configfs...
[ 13.601970] systemd[1]: Starting Load Kernel Module drm...
[ 13.603609] systemd[1]: Starting Load Kernel Module fuse...
[ 13.725343] systemd[1]: Starting Set Up Additional Binary Formats...
[ 13.727127] systemd[1]: Starting File System Check on Root Device...
[ 13.730406] systemd[1]: Starting Journal Service...
[ 13.937332] systemd[1]: Starting Load Kernel Modules...
[ 13.937465] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 13.939519] systemd[1]: Starting Coldplug All udev Devices...
[ 13.945026] systemd[1]: Mounted Huge Pages File System.
[ 13.945368] systemd[1]: Mounted POSIX Message Queue File System.
[ 13.945639] systemd[1]: Mounted Kernel Debug File System.
[ 13.945925] systemd[1]: Mounted Kernel Trace File System.
[ 13.947344] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 13.947845] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 195 (systemd-binfmt)
[ 13.950551] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 13.964073] systemd[1]: modprobe@configfs.service: Succeeded.
[ 13.965644] systemd[1]: Finished Load Kernel Module configfs.
[ 13.966252] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 13.969248] systemd[1]: Mounting Kernel Configuration File System...
[ 13.984860] systemd[1]: Mounted Kernel Configuration File System.
[ 14.221294] systemd[1]: Started Journal Service.
[ 14.221408] audit: type=1130 audit(1612950141.991:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.249699] Linux agpgart interface v0.103
[ 14.399197] audit: type=1130 audit(1612950142.168:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.488736] audit: type=1130 audit(1612950142.258:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.488783] audit: type=1131 audit(1612950142.258:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.626958] fuse: init (API version 7.32)
[ 14.630792] audit: type=1130 audit(1612950142.398:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.630807] audit: type=1131 audit(1612950142.398:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.758283] audit: type=1130 audit(1612950142.528:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.846085] audit: type=1130 audit(1612950142.615:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.337860] audit: type=1130 audit(1612950143.108:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.887810] audit: type=1130 audit(1612950143.658:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.010650] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 16.228644] systemd-journald[197]: Received client request to flush runtime journal.
[ 19.617799] kauditd_printk_skb: 19 callbacks suppressed
[ 19.617804] audit: type=1325 audit(1612950147.201:31): table=filter family=2 entries=122 op=xt_replace pid=263 subj==unconfined comm="iptables-restor"
[ 19.644463] audit: type=1325 audit(1612950147.391:32): table=filter family=2 entries=132 op=xt_replace pid=269 subj==unconfined comm="iptables-restor"
[ 19.871984] audit: type=1130 audit(1612950147.641:33): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.657573] audit: type=1130 audit(1612950149.425:34): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.556774] audit: type=1130 audit(1612950151.325:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.604387] audit: type=1334 audit(1612950151.375:36): prog-id=5 op=LOAD
[ 23.604464] audit: type=1334 audit(1612950151.375:37): prog-id=6 op=LOAD
[ 31.194993] audit: type=1130 audit(1612950158.965:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.053645] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000044F (\GPIS) (20200925/utaddress-204)
[ 32.053653] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
[ 32.053658] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 32.053661] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\GPIO) (20200925/utaddress-204)
[ 32.053665] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GP01) (20200925/utaddress-204)
[ 32.053668] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 32.053669] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\GPIO) (20200925/utaddress-204)
[ 32.053673] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GP01) (20200925/utaddress-204)
[ 32.053676] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 32.053677] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\GPIO) (20200925/utaddress-204)
[ 32.053680] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GP01) (20200925/utaddress-204)
[ 32.053684] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 32.053685] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 32.418002] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 32.418273] i2c i2c-0: 2/4 memory slots populated (from DMI)
[ 32.418620] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 32.419137] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 32.547669] input: PC Speaker as /devices/platform/pcspkr/input/input12
[ 32.990703] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 33.000159] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 33.169808] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 33.169810] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 33.169811] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 33.169812] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[ 33.188623] asus_wmi: ASUS WMI generic driver loaded
[ 33.347193] asus_wmi: Initialization: 0x1
[ 33.347277] asus_wmi: BIOS WMI version: 7.6
[ 33.347431] asus_wmi: SFUN value: 0xa0877
[ 33.347441] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 33.347447] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 33.352162] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input17
[ 33.412806] iTCO_vendor_support: vendor-support=0
[ 33.586751] at24 0-0050: supply vcc not found, using dummy regulator
[ 33.587413] at24 0-0050: 256 byte spd EEPROM, read-only
[ 33.587461] at24 0-0052: supply vcc not found, using dummy regulator
[ 33.588140] at24 0-0052: 256 byte spd EEPROM, read-only
[ 33.624549] psmouse serio4: synaptics: queried max coordinates: x [..5762], y [..4902]
[ 33.674172] psmouse serio4: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xd00073/0x240000/0xa0400/0x0, board id: 1704, fw id: 705499
[ 33.700662] cryptd: max_cpu_qlen set to 1000
[ 33.706127] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input16
[ 33.923974] mousedev: PS/2 mouse device common for all mice
[ 34.069305] audit: type=1130 audit(1612950161.838:39): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.159994] Intel(R) Wireless WiFi driver for Linux
[ 34.160160] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 34.198534] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 34.198620] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[ 34.198866] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 34.431365] atl1c 0000:05:00.0 enp5s0: renamed from eth0
[ 34.722023] iwlwifi 0000:03:00.0: loaded firmware version 39.31.5.1 build 32895 100-5.ucode op_mode iwldvm
[ 34.982666] checking generic (b0000000 1e0000) vs hw (dc400000 400000)
[ 34.982670] checking generic (b0000000 1e0000) vs hw (b0000000 10000000)
[ 34.982672] fb0: switching to inteldrmfb from EFI VGA
[ 34.982789] Console: switching to colour dummy device 80x25
[ 34.982842] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 34.985335] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 35.005126] MXM: GUID detected in BIOS
[ 35.005191] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000003) is beyond end of object (length 0x0) (20200925/exoparg2-393)
[ 35.005202] ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20200925/psparse-529)
[ 35.005214] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x300b)
[ 35.005219] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 35.005483] i915 0000:00:02.0: optimus capabilities: enabled, status dynamic power,
[ 35.005531] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000003) is beyond end of object (length 0x0) (20200925/exoparg2-393)
[ 35.005539] ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20200925/psparse-529)
[ 35.005547] ACPI Error: Aborting method \_SB.PCI0.PEG0.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20200925/psparse-529)
[ 35.005555] ACPI: \_SB_.PCI0.PEG0.GFX0: failed to evaluate _DSM (0x300b)
[ 35.005559] ACPI Warning: \_SB.PCI0.PEG0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 35.005835] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power,
[ 35.005839] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.GFX0 handle
[ 35.005866] nouveau 0000:01:00.0: enabling device (0000 -> 0003)
[ 35.006054] nouveau 0000:01:00.0: NVIDIA GF119 (0d9180a1)
[ 35.014714] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
[ 35.021463] ACPI: Video Device [GFX0] (multi-head: yes rom: yes post: no)
[ 35.025165] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input18
[ 35.037442] nouveau 0000:01:00.0: bios: version 75.19.4d.00.03
[ 35.038964] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 35.046836] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input19
[ 35.164133] fbcon: i915drmfb (fb0) is primary device
[ 35.193305] nouveau 0000:01:00.0: fb: 2048 MiB DDR3
[ 35.265017] vga_switcheroo: enabled
[ 35.265110] [TTM] Zone kernel: Available graphics memory: 6018286 KiB
[ 35.265111] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 35.265112] [TTM] Initializing pool allocator
[ 35.265116] [TTM] Initializing DMA pool allocator
[ 35.265131] nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
[ 35.265132] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 35.265135] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 35.265137] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 35.265139] nouveau 0000:01:00.0: DRM: DCB outp 00: 02010300 00000000
[ 35.265141] nouveau 0000:01:00.0: DRM: DCB conn 00: 00000000
[ 35.265993] nouveau 0000:01:00.0: DRM: MM: using COPY0 for buffer copies
[ 35.305296] Console: switching to colour frame buffer device 170x48
[ 35.324381] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 35.325210] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 35.348745] intel_rapl_common: Found RAPL domain package
[ 35.348749] intel_rapl_common: Found RAPL domain core
[ 35.348751] intel_rapl_common: Found RAPL domain uncore
[ 35.366622] nouveau 0000:01:00.0: DRM: allocated 1024x768 fb: 0x60000, bo 000000009c5316c5
[ 35.366710] nouveau 0000:01:00.0: [drm] fb1: nouveaudrmfb frame buffer device
[ 35.366962] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[ 35.417721] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUG enabled
[ 35.417725] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 35.417727] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 35.417730] iwlwifi 0000:03:00.0: Detected Intel(R) Centrino(R) Wireless-N 100 BGN, REV=0x6C
[ 35.457199] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 35.469528] audit: type=1130 audit(1612950163.238:40): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.564872] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 35.794495] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VB: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 35.794501] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 35.794503] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 35.794505] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 35.794506] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 35.794509] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x19
[ 35.794511] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 35.854146] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
[ 35.854435] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
[ 35.854520] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
[ 36.829477] audit: type=1130 audit(1612950164.598:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-C577\x2dF478 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 37.415628] audit: type=1130 audit(1612950165.185:42): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.418084] audit: type=1130 audit(1612950166.188:43): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-3dc71c14\x2dbd34\x2d452b\x2db101\x2d0c4a4c6f745b comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.691934] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 39.831286] mc: Linux media interface: v0.10
[ 39.939602] videodev: Linux video capture interface: v2.00
[ 40.156937] audit: type=1130 audit(1612950167.925:44): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.272498] audit: type=1127 audit(1612950168.041:45): pid=550 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 40.409921] audit: type=1130 audit(1612950168.178:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.479118] audit: type=1131 audit(1612950168.248:47): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.658059] audit: type=1130 audit(1612950168.428:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.757562] audit: type=1130 audit(1612950168.525:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.093874] audit: type=1130 audit(1612950168.861:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.744590] uvcvideo: Found UVC 1.00 device ASUS USB2.0 WebCam (058f:a014)
[ 43.192098] input: ASUS USB2.0 WebCam: ASUS USB2.0 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input23
[ 43.192407] usbcore: registered new interface driver uvcvideo
[ 43.192410] USB Video Class driver (1.1.1)
[ 44.035691] kauditd_printk_skb: 7 callbacks suppressed
[ 44.035698] audit: type=1130 audit(1612950171.805:58): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.038315] audit: type=1130 audit(1612950171.808:59): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.040684] audit: type=1130 audit(1612950171.808:60): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.047877] audit: type=1130 audit(1612950171.818:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=jackett comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.049845] audit: type=1130 audit(1612950171.818:62): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=nextdns comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.099971] audit: type=1130 audit(1612950171.868:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.778855] audit: type=1334 audit(1612950172.548:64): prog-id=9 op=LOAD
[ 44.778913] audit: type=1334 audit(1612950172.548:65): prog-id=10 op=LOAD
[ 44.996993] audit: type=1130 audit(1612950172.765:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.179219] audit: type=1130 audit(1612950175.948:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.867655] iwlwifi 0000:03:00.0: Radio type=0x0-0x0-0x3
[ 48.930797] iwlwifi 0000:03:00.0: Radio type=0x0-0x0-0x3
[ 48.991614] iwlwifi 0000:03:00.0: Radio type=0x0-0x0-0x3
[ 49.064436] iwlwifi 0000:03:00.0: Radio type=0x0-0x0-0x3
[ 50.318209] audit: type=1130 audit(1612950178.088:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 50.484194] audit: type=1130 audit(1612950178.251:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 51.950571] audit: type=1111 audit(1612950179.718:70): pid=556 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=reload arg="0" pid=632 uid=0 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 53.586758] audit: type=1130 audit(1612950181.355:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.592194] audit: type=1130 audit(1612950181.361:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.729576] audit: type=1130 audit(1612950181.498:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.769108] audit: type=1130 audit(1612950187.538:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.448564] audit: type=1131 audit(1612950188.218:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.457701] nouveau 0000:01:00.0: Enabling HDA controller
[ 60.812512] audit: type=1334 audit(1612950188.581:76): prog-id=8 op=UNLOAD
[ 60.812521] audit: type=1334 audit(1612950188.581:77): prog-id=7 op=UNLOAD
[ 60.813845] audit: type=1334 audit(1612950188.581:78): prog-id=10 op=UNLOAD
[ 60.813859] audit: type=1334 audit(1612950188.581:79): prog-id=9 op=UNLOAD
[ 60.815056] audit: type=1334 audit(1612950188.585:80): prog-id=6 op=UNLOAD
[ 60.815063] audit: type=1334 audit(1612950188.585:81): prog-id=5 op=UNLOAD
[ 60.817763] audit: type=1334 audit(1612950188.588:82): prog-id=4 op=UNLOAD
[ 60.817845] audit: type=1334 audit(1612950188.588:83): prog-id=3 op=UNLOAD
[ 61.297592] Adding 262140k swap on /var/lib/systemd-swap/swapfc/1. Priority:50 extents:8 across:75988992k FS
[ 73.923055] kauditd_printk_skb: 10 callbacks suppressed
[ 73.923058] audit: type=1100 audit(1612950201.691:94): pid=899 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="sum" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 73.971511] audit: type=1101 audit(1612950201.741:95): pid=899 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sum" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 74.006068] audit: type=1103 audit(1612950201.775:96): pid=899 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="sum" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 74.006207] audit: type=1006 audit(1612950201.775:97): pid=899 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 74.179231] audit: type=1130 audit(1612950201.948:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 74.181956] iwlwifi 0000:03:00.0: Radio type=0x0-0x0-0x3
[ 74.206184] audit: type=1101 audit(1612950201.975:99): pid=904 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sum" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 74.206253] audit: type=1103 audit(1612950201.975:100): pid=904 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sum" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 74.206390] audit: type=1006 audit(1612950201.975:101): pid=904 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 74.244132] iwlwifi 0000:03:00.0: Radio type=0x0-0x0-0x3
[ 74.249966] audit: type=1105 audit(1612950202.018:102): pid=904 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sum" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 74.275970] audit: type=1334 audit(1612950202.045:103): prog-id=19 op=LOAD
[ 74.773753] wlp3s0: authenticate with 90:4d:4a:c2:5f:b6
[ 74.778089] wlp3s0: send auth to 90:4d:4a:c2:5f:b6 (try 1/3)
[ 74.780916] wlp3s0: authenticated
[ 74.784294] wlp3s0: associate with 90:4d:4a:c2:5f:b6 (try 1/3)
[ 74.788477] wlp3s0: RX AssocResp from 90:4d:4a:c2:5f:b6 (capab=0x1411 status=0 aid=3)
[ 74.791314] wlp3s0: associated
[ 94.017628] kauditd_printk_skb: 8 callbacks suppressed
[ 94.017633] audit: type=1131 audit(1612950221.357:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 95.306532] audit: type=1130 audit(1612950222.647:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 95.757731] nouveau 0000:01:00.0: Enabling HDA controller
[ 101.091400] audit: type=1130 audit(1612950228.433:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pcscd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 102.130772] audit: type=1334 audit(1612950229.470:115): prog-id=20 op=LOAD
[ 102.131045] audit: type=1334 audit(1612950229.473:116): prog-id=21 op=LOAD
[ 105.253215] audit: type=1130 audit(1612950232.593:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 109.303824] audit: type=1105 audit(1612950236.643:118): pid=1238 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 114.406018] [UFW BLOCK] IN=wlp3s0 OUT= MAC=78:92:9c:95:7a:b2:90:4d:4a:c2:5f:b3:08:00 SRC=108.174.11.69 DST=192.168.1.38 LEN=100 TOS=0x18 PREC=0x20 TTL=54 ID=3008 DF PROTO=TCP SPT=443 DPT=55586 WINDOW=14 RES=0x00 ACK URGP=0
[ 117.610257] audit: type=1130 audit(1612950244.950:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 135.685074] audit: type=1130 audit(1612950263.027:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
even if systemd tells a shorter story:
[sum@ordi1 ~]$ systemd-analyze blame
21.314s systemd-journal-flush.service
20.114s systemd-swap.service
18.727s dev-sda2.device
15.665s lightdm.service
11.785s systemd-tmpfiles-clean.service
9.683s cups.service
7.589s systemd-udevd.service
7.552s accounts-daemon.service
6.381s polkit.service
5.552s systemd-sysusers.service
4.589s apparmor.service
4.398s ufw.service
4.055s udisks2.service
3.121s user@1000.service
3.118s upower.service
2.868s avahi-daemon.service
2.862s NetworkManager.service
2.851s systemd-logind.service
2.392s ldconfig.service
2.160s systemd-fsck-root.service
1.896s systemd-tmpfiles-setup-dev.service
1.518s tlp.service
1.486s colord.service
1.453s systemd-tmpfiles-setup.service
1.186s wpa_supplicant.service
1.176s systemd-fsck@dev-disk-by\x2duuid-3dc71c14\x2dbd34\x2d452b\x2db101\x2d0c4a4c6f745b.service
1.036s systemd-fsck@dev-disk-by\x2duuid-C577\x2dF478.service
1.025s modprobe@fuse.service
926ms systemd-random-seed.service
908ms systemd-modules-load.service
885ms modprobe@drm.service
818ms systemd-udev-trigger.service
744ms boot-efi.mount
673ms systemd-binfmt.service
547ms systemd-rfkill.service
517ms systemd-timesyncd.service
497ms systemd-journal-catalog-update.service
490ms systemd-journald.service
488ms systemd-sysctl.service
364ms modprobe@configfs.service
357ms dev-hugepages.mount
355ms dev-mqueue.mount
353ms sys-kernel-debug.mount
351ms sys-kernel-tracing.mount
348ms kmod-static-nodes.service
240ms home.mount
208ms var-lib-systemd\x2dswap-swapfc-1.swap
168ms systemd-update-utmp.service
124ms systemd-remount-fs.service
88ms systemd-backlight@backlight:intel_backlight.service
86ms systemd-localed.service
57ms linux-module-cleanup.service
47ms systemd-user-sessions.service
42ms rtkit-daemon.service
34ms user-runtime-dir@1000.service
21ms systemd-update-done.service
19ms tmp.mount
15ms proc-sys-fs-binfmt_misc.mount
15ms sys-kernel-config.mount
4ms sys-fs-fuse-connections.mount
