Systemctl suspend permission error
Hi guys!
Yesterday, after the update, I noticed something strange: I can no longer suspend my computer, no matter which kernel I try to use. (From the two I’ve tried, one of which I know worked fine before the update because I used it daily.)
When I run it from my custom shortcut on the keyboard nothing happens, and it no longer appears in the launcher, making me think it’s some kind of permission problem.
And indeed, running:
$ systemctl suspend
…from the terminal, yields:
$ systemctl suspend
Call to Suspend failed: Access denied
I tried looking at some logs, but couldn’t see anything:
$ journalctl -u polkit.service -x -b
Dec 12 09:16:49 Mirdarthos-PC systemd[1]: Starting Authorization Manager...
░░ Subject: A start job for unit polkit.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit polkit.service has begun execution.
░░ The job identifier is 108.
Dec 12 09:16:50 Mirdarthos-PC polkitd[639]: Started polkitd version 123
Dec 12 09:16:50 Mirdarthos-PC polkitd[639]: Loading rules from directory /etc/polkit-1/rules.d
Dec 12 09:16:50 Mirdarthos-PC polkitd[639]: Loading rules from directory /usr/share/polkit-1/rules.d
Dec 12 09:16:50 Mirdarthos-PC polkitd[639]: Finished loading, compiling and executing 5 rules
Dec 12 09:16:50 Mirdarthos-PC polkitd[639]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Dec 12 09:16:50 Mirdarthos-PC systemd[1]: Started Authorization Manager.
░░ Subject: A start job for unit polkit.service has finished successfully
░░ A start job for unit polkit.service has finished successfully.
Dec 12 09:17:17 Mirdarthos-PC polkitd[639]: Registered Authentication Agent for unix-session:2 (system bus name :1.54 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF-8)
Dec 12 09:17:46 Mirdarthos-PC polkitd[639]: Registered Authentication Agent for unix-process:1756:6371 (system bus name :1.71 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF->
Dec 12 09:17:46 Mirdarthos-PC polkitd[639]: Unregistered Authentication Agent for unix-process:1756:6371 (system bus name :1.71, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF-8) (disconnected from bus)
Dec 12 09:22:20 Mirdarthos-PC polkitd[639]: Registered Authentication Agent for unix-process:3151:33758 (system bus name :1.90 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF>
Dec 12 09:22:20 Mirdarthos-PC polkitd[639]: Unregistered Authentication Agent for unix-process:3151:33758 (system bus name :1.90, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF-8) (disconnected from bus)
$ journalctl -u suspend.target
-- Boot 28976468bc9d44b9859557e6da6f419c --
Dec 06 12:13:07 Mirdarthos-PC systemd[1]: Reached target Suspend.
Dec 06 12:13:07 Mirdarthos-PC systemd[1]: Stopped target Suspend.
Dec 07 08:11:08 Mirdarthos-PC systemd[1]: Reached target Suspend.
Dec 07 08:11:08 Mirdarthos-PC systemd[1]: Stopped target Suspend.
Dec 07 12:39:55 Mirdarthos-PC systemd[1]: Reached target Suspend.
Dec 07 12:39:55 Mirdarthos-PC systemd[1]: Stopped target Suspend.
Dec 08 08:07:22 Mirdarthos-PC systemd[1]: Reached target Suspend.
Dec 08 08:07:22 Mirdarthos-PC systemd[1]: Stopped target Suspend.
Dec 08 12:14:46 Mirdarthos-PC systemd[1]: Reached target Suspend.
Dec 08 12:14:46 Mirdarthos-PC systemd[1]: Stopped target Suspend.
Dec 09 08:13:36 Mirdarthos-PC systemd[1]: Reached target Suspend.
Dec 09 08:13:37 Mirdarthos-PC systemd[1]: Stopped target Suspend.
-- Boot 5ecb0e6ff83f413a8f8b0522cc9e19a1 --
$ journalctl -u polkit.service -e -b -1
Dec 12 09:07:07 Mirdarthos-PC systemd[1]: Starting Authorization Manager...
Dec 12 09:07:08 Mirdarthos-PC polkitd[564]: Started polkitd version 123
Dec 12 09:07:08 Mirdarthos-PC polkitd[564]: Loading rules from directory /etc/polkit-1/rules.d
Dec 12 09:07:08 Mirdarthos-PC polkitd[564]: Loading rules from directory /usr/share/polkit-1/rules.d
Dec 12 09:07:08 Mirdarthos-PC polkitd[564]: Finished loading, compiling and executing 5 rules
Dec 12 09:07:08 Mirdarthos-PC polkitd[564]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Dec 12 09:07:08 Mirdarthos-PC systemd[1]: Started Authorization Manager.
Dec 12 09:07:33 Mirdarthos-PC polkitd[564]: Registered Authentication Agent for unix-session:2 (system bus name :1.55 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF-8)
Dec 12 09:08:37 Mirdarthos-PC polkitd[564]: Registered Authentication Agent for unix-process:1757:9767 (system bus name :1.71 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF->
Dec 12 09:08:37 Mirdarthos-PC polkitd[564]: Unregistered Authentication Agent for unix-process:1757:9767 (system bus name :1.71, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF-8) (disconnected from bus)
Dec 12 09:09:32 Mirdarthos-PC polkitd[564]: Registered Authentication Agent for unix-process:1805:15219 (system bus name :1.73 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF>
Dec 12 09:09:32 Mirdarthos-PC polkitd[564]: Unregistered Authentication Agent for unix-process:1805:15219 (system bus name :1.73, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF-8) (disconnected from bus)
Dec 12 09:16:22 Mirdarthos-PC polkitd[564]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.55, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_ZA.UTF-8)
Dec 12 09:16:27 Mirdarthos-PC systemd[1]: Stopping Authorization Manager...
Dec 12 09:16:27 Mirdarthos-PC systemd[1]: polkit.service: Deactivated successfully.
Dec 12 09:16:27 Mirdarthos-PC systemd[1]: Stopped Authorization Manager.
Dec 12 09:16:27 Mirdarthos-PC systemd[1]: polkit.service: Consumed 1.728s CPU time.
$ systemctl status polkit.service
● polkit.service - Authorization Manager
Loaded: loaded (/usr/lib/systemd/system/polkit.service; static)
Active: active (running) since Tue 2023-12-12 09:16:50 SAST; 22min ago
Docs: man:polkit(8)
Main PID: 639 (polkitd)
Tasks: 4 (limit: 19080)
Memory: 8.0M
CPU: 1.388s
CGroup: /system.slice/polkit.service
└─639 /usr/lib/polkit-1/polkitd --no-debug
Also, it looks like all the config files, that I haven’t touched BTW, is present and accounted for:
$ sudo ls /etc/polkit-1/rules.d
99-manjaro.rules
$ sudo cat /etc/polkit-1/rules.d/99-manjaro.rules
polkit.addRule(function(action, subject) {
if (action.id.indexOf("org.freedesktop.udisks2.") == 0 && subject.isInGroup("wheel")) {
return polkit.Result.YES;
if (action.id == "org.freedesktop.login1.power-off" ||
action.id == "org.freedesktop.login1.reboot" ||
action.id == "org.freedesktop.login1.hibernate" ||
action.id == "org.freedesktop.login1.suspend") {
if (action.id == "org.freedesktop.upower.hibernate" ||
action.id == "org.freedesktop.upower.suspend") {
/* Allow users of network group to use blueman feature requiring root without authentication */
if ((action.id == "org.blueman.network.setup" ||
action.id == "org.blueman.dhcp.client" ||
action.id == "org.blueman.rfkill.setstate" ||
action.id == "org.blueman.pppd.pppconnect") &&
subject.isInGroup("network")) {
$ journalctl -p 3 -e -b -1
Dec 12 09:07:04 Mirdarthos-PC kernel: x86/cpu: SGX disabled by BIOS.
Dec 12 09:07:04 Mirdarthos-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT1._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
Dec 12 09:07:04 Mirdarthos-PC kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Dec 12 09:07:04 Mirdarthos-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT0._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
Dec 12 09:07:04 Mirdarthos-PC kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Dec 12 09:07:06 Mirdarthos-PC kernel:
Dec 12 09:07:06 Mirdarthos-PC kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  545.29.06  Thu Nov 16 01:59:08 UTC 2023
Dec 12 09:07:08 Mirdarthos-PC smartd[565]: Device: /dev/sda [SAT], 40 Currently unreadable (pending) sectors
Dec 12 09:07:08 Mirdarthos-PC smartd[565]: Device: /dev/sda [SAT], 40 Offline uncorrectable sectors
Dec 12 09:07:08 Mirdarthos-PC smartd[565]: Device: /dev/sda [SAT], Failed SMART usage Attribute: 184 End-to-End_Error.
Dec 12 09:07:29 Mirdarthos-PC pulseaudio[798]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Dec 12 09:07:31 Mirdarthos-PC systemd[748]: Failed to start xapp-sn-watcher.
Dec 12 09:07:32 Mirdarthos-PC libddcutil[948]: i2c_check_businfo_connector() failed for bus 1
Dec 12 09:07:32 Mirdarthos-PC libddcutil[948]: i2c_check_businfo_connector() failed for bus 3
I checked, and my groups look fine:
$ groups
sys ftp log http games dbus network power sambashare lxd storage optical disk audio wheel mirdarthos roccat android-sdk
So I’m at a total loss, as those are all familiar errors. I don’t know why this is happening, or what to do about it, so I’m hoping someone here does.
Well, does anyone know what to do, or at least why this r happening?
Do you have an nvidia GPU? Are you using X11 or wayland?
I do, but didn’t think it’d affect this. However, I realize I might be wrong, so here’s my details:
$ inxi --admin --verbosity=7 --filter --no-host --width        [sudo] password for mirdarthos:
Kernel: 6.1.66-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet
udev.log_priority=3 modprobe.blacklist=iTCO_wdt
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 info: cairo-dock
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A serial: N/A
Mobo: Gigabyte model: Z370 HD3-CF serial: N/A UEFI: American Megatrends
v: F14 date: 11/13/2021
System RAM: total: 16 GiB available: 15.55 GiB used: 4.25 GiB (27.3%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3000C16-8GSXKB serial: N/A
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
Info: model: Intel Core i7-8700 socket: LGA1151 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4600 base/boost: 4300/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 bogomips: 76831
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-11; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1401 class-ID: 0300
Display: server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1080 s-dpi: 97 s-size: 1341x283mm (52.80x11.14")
s-diag: 1371mm (53.96")
Monitor-1: DVI-I-1 pos: right res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.18") diag: 730mm (28.76") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1080 hz: 60 dpi: 97
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 960/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 960 driver: nvidia v: 545.29.06 device-ID: 10de:1401
surfaces: xcb,xlib
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
API: ALSA v: k6.1.66-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process) with:
tools: pacat,pactl
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Local Storage: total: 8.41 TiB used: 3.02 TiB (35.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 31.9 C
scheme: GPT
SMART: yes health: PASSED on: 190d 14h cycles: 3,135
read-units: 53,754,571 [27.5 TB] written-units: 41,551,393 [21.2 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM000-1F2168
family: Desktop HDD.15 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5900
serial: <filter> fw-rev: CC54 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 133d 10h cycles: 3445
read: 123.09 TiB written: 62.59 TiB Old-Age: UDMA CRC errors: 13567
alert: Bad cable/connection? Pre-Fail: end-to-end: 99 threshold: 99
alert: FAILING_NOW attribute: Spin_Retry_Count value: 100 worst: 100
threshold: 97
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST5000VX0011-1T317X
family: Surveillance size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: VN02 temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 223d 5h cycles: 2512
read: 77.84 TiB written: 16.99 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 224.58 GiB size: 220 GiB (97.96%) used: 83.02 GiB (37.7%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: D563-DAB7
ID-3: /mnt/5TB raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
used: 2.94 TiB (65.1%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: 5TB uuid: 953836d8-e355-4c6d-ac1a-0914b8414f50
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
zswap: yes compressor: zstd max-pool: 20%
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1b3f894f-5481-4241-ace5-c129a0cdb412
ID-1: /dev/sda1 maj-min: 8:1 size: 3.64 TiB fs: ext4 label: 4TB
uuid: c47c5a52-db30-4aef-bcbc-af35b7b021fd
Device-1: 1-4:2 info: ROCCAT Kone EMP type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2e24 class-ID: 0300
Device-2: 1-8:3 info: Corsair K68 RGB Mechanical Gaming Keyboard
type: keyboard,HID driver: usbfs interfaces: 2 rev: 2.0
chip-ID: 1b1c:1b4f class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 73%
Processes: 297 Uptime: 59m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1979 libs: 465 tools: pamac pm: appimage pkgs: 0 Shell: Sudo (sudo)
v: 1.9.15p2 default: Zsh v: 5.9 running-in: yakuake inxi: 3.3.31
And it works if you use ‘sudo’?
I have no issue with systemctl suspend.
Only a small difference between yours and mine is:
I do not have this rule file 99-manjaro.rules Where does it come from?
Check the output of sudo pacman -Qo /etc/polkit-1/rules.d/99-manjaro.rules
It comes from manjaro-hotfixes.
That came with Manjaro IIRC…
$ sudo pacman -Qo /etc/polkit-1/rules.d/99-manjaro.rules
/etc/polkit-1/rules.d/99-manjaro.rules is owned by manjaro-hotfixes 2018.08-6
Just tested this, and strangely:
$ sudo systemctl suspend
No…
what says dbus?
One Terminal: journalctl -b0 -u dbus -f
Second Terminal: systemctl suspend
OR: systemctl suspend --check-inhibitors=no
Try to uninstall manjaro-hotfixes then reboot if it works?
If you have an Nvidia GPU, that must be suspended as well. I guess that for some reason it’s not suspending. I’m not sure how this works in the arch world, as I never had this issue. However, I had this problem in Fedora, this is why I’m suggesting it…
What is its content?
Not one single line.
$ systemctl suspend --check-inhibitors=no        1 ↵
I know, and I had it running and working perfectly before the update yesterday.
Some hints:
systemctl status nvidia-suspend.service
Also you could try to force it (if it really doesn’t suspend)
systemctl start nvidia-suspend.service
systemctl suspend
Check if this is run on systemctl suspend via Wants or Requires (it should)
Nope. Made no difference. After reboot:
$ systemctl suspend
$ sudo systemctl suspend        1 ↵
Check which current packages that have been updated are causing the problem.
Use paclog with date for example:
$ paclog --after=2023-12-10
This did exactly what I expected it to do: suspend the Nvidia card, without suspending the PC, so I had a running PC with no graphics out and couldn’t do anything…luckily there was nothing unsaved…
Output here: https://0x0.st/H36L.txt
Just run journalctl -f in one terminal and then try to suspend. Any output?
My Nvidia suspend worked perfectly after following this:
And withy this error:
…it doesn’t seem to be related to Nvidia… (I say seem, because every- and anything is possible.)
