I was watching a video of things to do on manjaro after a install and I saw this command to search for errors, “sudo systemctl --failed” I ran it on my pinephone and got this output:
[sudo] password di manjaro:
UNIT LOAD ACTIVE SUB DESCRIPTION
● umtp-responder.service not-found failed failed umtp-responder.service
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
What should I do to fix it?
