Hello Manjaro team -
I’m trying to update the system76-driver and receiver this error:
==> ERROR: One or more PGP signatures could not be verified!
Looking for similar forum posts I found a likely candidate saying it’s best to clear the pamac-build folder, and followed that instruction, shown below, together with the follow-on pamac install attempt.
I also looked at the AUR entry. If there were special install notes I couldn’t follow it. Sorry if I missed it.
thx
galago% sudo rm -rf /var/tmp/pamac-build-rsv2/system76-driver/
galago%
galago%
galago% pamac install system76-driver
Warning: system76-driver is only available from AUR
Preparing…
Checking system76-driver dependencies…
Resolving dependencies…
Checking inter-conflicts…
To build (1):
system76-driver 20.04.47-1 (20.04.46-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Sorry I skipped the formatting requirement. Will try harder to comply. It’s simple.
As for importing the key, the instruction from the wiki says this:
gpg --import public.key
As I interpreted the command (which I obviously did not do correctly) it seems like I need to point the gpg statement at a server, right ), it generated this:
galago% gpg --import 87F211AF2BE4C2FE
gpg: WARNING: unsafe permissions on homedir '/home/rsv2/.gnupg'
gpg: can't open '87F211AF2BE4C2FE': No such file or directory
gpg: Total number processed: 0
galago%
Thinking I had a permissions issue I also added the ‘sudo’:
galago% sudo gpg --import 87F211AF2BE4C2FE
[sudo] password for rsv2:
galago%
So… I’m missing a step, or a command parameter
thx
galago% sudo gpg --recv-keys 87F211AF2BE4C2FE
Sorry, try again.
gpg: key 87F211AF2BE4C2FE: public key "Jeremy Soller (https://soller.dev) <jackpot51@gmail.com>" imported
gpg: Total number processed: 1
gpg: imported: 1
Can’t get a port on AUR but that’s next:
Failed to query https://aur.archlinux.org/rpc/?v=5&type=info&arg[]=system76-driver from AUR: Socket I/O timed out
Error: target not found: system76-driver
galago%
