Hello team -
I’m running Plasma 5.26.5 on Kernel 5.15.102-1, on a System76 Galago Pro
I was recently prompted to update the system76-driver but am getting the error shown below. Any advice troubleshooting would be great. To me it looks like a build issue but my view is not too informed… If there are steps I can take I’m happy to do so.
Reid
==> Starting pkgver()...
==> Starting build()...
* Getting build dependencies for wheel...
/usr/lib/python3.10/site-packages/setuptools/dist.py:547: UserWarning: Normalizing '20.04.78' to '20.4.78'
warnings.warn(tmpl.format(**locals()))
File "/usr/lib/python3.10/site-packages/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/usr/lib/python3.10/site-packages/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/usr/lib/python3.10/site-packages/pyproject_hooks/_in_process/_in_process.py", line 118, in get_requires_for_build_wheel
return hook(config_settings)
File "/usr/lib/python3.10/site-packages/setuptools/build_meta.py", line 338, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=['wheel'])
File "/usr/lib/python3.10/site-packages/setuptools/build_meta.py", line 320, in _get_build_requires
self.run_setup()
File "/usr/lib/python3.10/site-packages/setuptools/build_meta.py", line 484, in run_setup
super(_BuildMetaLegacyBackend,
File "/usr/lib/python3.10/site-packages/setuptools/build_meta.py", line 335, in run_setup
exec(code, locals())
File "<string>", line 83, in <module>
File "/usr/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/usr/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/usr/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.10/site-packages/setuptools/dist.py", line 1221, in run_command
super().run_command(command)
File "/usr/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 987, in run_command
cmd_obj.ensure_finalized()
File "/usr/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 111, in ensure_finalized
self.finalize_options()
File "/usr/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 253, in finalize_options
if pd is not None and pd.key == self.egg_name.lower():
AttributeError: 'PathDistribution' object has no attribute 'key'
ERROR Backend subprocess exited when trying to invoke get_requires_for_build_wheel
==> ERROR: A failure occurred in build().
Aborting...
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Service runtime: 2.452s
CPU time consumed: 2.285s
