I’m not sure this is an XFCE specific problem, but I do have Manjaro XFCE.
Currently my power settings are set to Never on System and Display, for suspend and hibernate.
However, when I leave the computer at night, I lock it using Ctrl+Alt+Del. If I then come back without an hour or so, it wakes up immediately.
If I leave it overnight, the only way to wake the computer up is a hard reset with the power button.
I have the output of journalctl -p3 -b-1
after such an event
-- Journal begins at Mon 2021-10-04 20:39:14 CDT, ends at Wed 2021-10-06 17:54:>
Oct 05 08:27:18 ThreatLevelMidnight kernel: x86/cpu: SGX disabled by BIOS.
Oct 05 08:27:19 ThreatLevelMidnight kernel: usb 1-10: device descriptor read/64>
Oct 05 08:27:50 ThreatLevelMidnight lightdm[947]: gkr-pam: unable to locate dae>
Oct 05 08:28:16 ThreatLevelMidnight pulseaudio[1129]: GetManagedObjects() faile>
Oct 05 08:30:53 ThreatLevelMidnight lightdm[1930]: gkr-pam: unable to locate da>
Oct 05 21:51:36 ThreatLevelMidnight lightdm[18137]: gkr-pam: unable to locate d>
Oct 06 00:29:50 ThreatLevelMidnight systemd-coredump[23200]: [🡕] Process 2403 (>
Stack trace of thr>
#0 0x00007fedc8ff>
Oct 06 17:50:46 ThreatLevelMidnight systemd-coredump[30921]: Failed to connect >
lines 1-13/13 (END)...skipping...
-- Journal begins at Mon 2021-10-04 20:39:14 CDT, ends at Wed 2021-10-06 17:54:46 CDT. --
Oct 05 08:27:19 ThreatLevelMidnight kernel: usb 1-10: device descriptor read/64, error -71
Oct 05 08:27:50 ThreatLevelMidnight lightdm[947]: gkr-pam: unable to locate daemon control file
Oct 05 08:28:16 ThreatLevelMidnight pulseaudio[1129]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security>
Oct 05 08:30:53 ThreatLevelMidnight lightdm[1930]: gkr-pam: unable to locate daemon control file
Oct 05 21:51:36 ThreatLevelMidnight lightdm[18137]: gkr-pam: unable to locate daemon control file
Oct 06 00:29:50 ThreatLevelMidnight systemd-coredump[23200]: [🡕] Process 2403 (Web Content) of user 1000 dumped core.
Stack trace of thread 2403:
#0 0x00007fedc8ffc2de n/a (n/a + 0x0)
Oct 06 17:50:46 ThreatLevelMidnight systemd-coredump[30921]: Failed to connect to coredump service: Connection refused
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=02fcd93b-a896-4b13-a4e7-72405c374848 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO v: Rev 1.xx
serial: <filter> UEFI-[Legacy]: American Megatrends v: 2202 date: 09/19/2016
RAM: total: 31.28 GiB used: 2.72 GiB (8.7%)
Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
L2: 8 MiB bogomips: 64026
Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 1207
3: 3164 4: 2108 5: 953 6: 800 7: 800 8: 975
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 02:00.1 chip-ID: 10de:10f0
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: f000 bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 13.21 TiB used: 12.15 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 34.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD1001FALS-42J7B0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 1.5 Gb/s type: N/A serial: <filter> rev: 0K05
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DX001-1CM164
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD4003FZEX-00Z4SA0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD3001FFSX-68JNUN0 size: 2.73 TiB block-size: physical: 4096 B
rev: 0A81 scheme: GPT
ID-7: /dev/sdf maj-min: 8:80 vendor: Western Digital
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 12.15 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 02fcd93b-a896-4b13-a4e7-72405c374848
ID-1: /dev/sda1 maj-min: 8:1 size: 953.87 GiB fs: ext4 label: 850Pro
uuid: 5dff6f31-d3d8-4cc6-bae5-21949956a29f
ID-2: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: WDBlack_1TB
uuid: 07554E672A198B3F
ID-3: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ntfs label: SSHD
uuid: CCF673BDF673A67C
ID-4: /dev/sdd1 maj-min: 8:49 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdd2 maj-min: 8:50 size: 3.64 TiB fs: ntfs label: LargeStorage
uuid: E68874158873E28B
ID-6: /dev/sde1 maj-min: 8:65 size: 2.73 TiB fs: ext4 label: Red1
uuid: be38f164-e944-4f8c-9509-36b37af4c57c
ID-7: /dev/sdf1 maj-min: 8:81 size: 2.73 TiB fs: ext4 label: Red0
uuid: 76a80a3c-7332-4e0f-a8a8-9452ba054458
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: Corsair Vengeance K70R keyboard type: Keyboard,HID
driver: corsair,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1b1c:1b09 class-ID: 0300
Device-2: 1-7:3
info: Razer USA RC30-0305 Gaming Mouse Dongle [Viper Ultimate (Wireless)]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:007b class-ID: 0300
Device-3: 1-8:4 info: Razer USA Razer BlackWidow V3 Pro type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1532:025c class-ID: 0300 serial: <filter>
Hub-2: 1-9:5 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 12 Mb/s
Device-1: 1-9.2:7 info: Razer USA RC30-030502 Mouse Dock
speed: 12 Mb/s power: 500mA chip-ID: 1532:007e class-ID: 0300
Device-2: 1-10:6 info: Razer USA Viper (wired) type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1532:0078 class-ID: 0301
Device-3: 1-11:8 info: Corsair H110iGTX Cooler type: <vendor specific>
driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 1b1c:0c07 class-ID: 0000 serial: <filter>
Device-4: 1-14:9 info: Microchip MCP2200 USB Serial Port Emulator
type: Abstract (modem),CDC-Data,HID driver: cdc_acm,hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 04d8:00df
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 49 C
Processes: 223 Uptime: 11m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1065 lib: 306 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: terminator inxi: 3.3.06
Is there anywhere other than the Power Manager that I could check for settings?
