Hello everyone…
although I’ve installed new kernels (Linux 5.9.3-11 and 5.9.1_rt19-1) my system won’t use either after reboot and keeps using LTS Linux 5.4.80-2
I have no problem at all with my system using the LTS …but i would like to learn why …
Sorry for the newbie question and thank you in advance to anyone who can enlighten me…
Chris
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_MONETARY = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_TIME = "el_GR.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=6602f6da-ccbf-456c-97f5-15d10da3de47 rw quiet udev.log_priority=3
resume=/dev/sda2
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: FUJITSU product: LIFEBOOK A530 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: FUJITSU model: FJNBB06 serial: <filter> BIOS: FUJITSU // Phoenix
v: Version 1.16 date: 08/19/2010
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Dual Core model: Intel Core i3 M 380 bits: 64 type: MT MCP
arch: Nehalem family: 6 model-id: 25 (37) stepping: 5 microcode: 7
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20221
Speed: 1072 MHz min/max: 933/2533 MHz Core speeds (MHz): 1: 958 2: 962
3: 950 4: 965
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: Fujitsu Limited.
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0046
Device-2: Silicon Motion - Taiwan (formerly Feiya ) USB 2.0 PC Cam
type: USB driver: uvcvideo bus ID: 1-1.1:3 chip ID: 090c:37b6
serial: <filter>
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 20.2.3
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Fujitsu Limited. driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:3b56
Sound Server: ALSA v: k5.4.80-2-MANJARO
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Fujitsu Limited. driver: ath9k v: kernel port: 1840 bus ID: 03:00.0
chip ID: 168c:002b
vendor: Fujitsu Limited. driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 5000 bus ID: 07:00.0 chip ID: 10ec:8168
IF: enp7s0 state: down mac: <filter>
Local Storage: total: 298.09 GiB used: 20.78 GiB (7.0%)
ID-1: /dev/sda vendor: Hitachi model: HTS545032B9A300 size: 298.09 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: C61J scheme: MBR
ID-1: / raw size: 290.05 GiB size: 284.49 GiB (98.09%)
used: 20.78 GiB (7.3%) fs: ext4 dev: /dev/sda1
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.04 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 167 Uptime: 8m Memory: 3.65 GiB used: 915.2 MiB (24.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
pacman: 1401 lib: 347 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08```
