This is what that command currently returns. I cut out some duplicate lines.
Oct 02 15:18:47 cucumber-pc kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 02 15:18:47 cucumber-pc kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Oct 02 15:18:47 cucumber-pc kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 02 15:18:47 cucumber-pc kernel: ata5.00: supports DRM functions and may not be fully accessible
Oct 02 15:18:48 cucumber-pc kernel: i2c i2c-0: Systems with more than 4 memory slots not supported yet, not instantiating SPD
Oct 02 15:18:48 cucumber-pc (udev-worker)[338]: event15: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Oct 02 15:18:48 cucumber-pc kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Oct 02 15:18:48 cucumber-pc kernel: EDAC sbridge: Couldn't find mci handler
Oct 02 15:18:48 cucumber-pc kernel: EDAC sbridge: Failed to register device with error -19.
Oct 02 15:18:48 cucumber-pc systemd-journald[328]: File /var/log/journal/f9abbd310eee437d99a871cdfe930f0e/system.journal corrupted or uncleanly shut down, renaming and replacing.
Oct 02 15:18:48 cucumber-pc kernel: nvidia: loading out-of-tree module taints kernel.
Oct 02 15:18:48 cucumber-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 02 15:18:48 cucumber-pc kernel: Disabling lock debugging due to kernel taint
Oct 02 15:18:48 cucumber-pc kernel: nvidia: module license taints kernel.
Oct 02 15:18:49 cucumber-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.104.05 Sat Aug 19 01:15:15 UTC 2023
Oct 02 15:18:49 cucumber-pc kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Oct 02 15:18:51 cucumber-pc kernel: Xorg[676]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Oct 02 15:18:53 cucumber-pc sddm-greeter[700]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fff1db56360), parent's thread is QThread(0x556e8b6adba0), current thread is QThread(0x556e8b7ff9d0)
Oct 02 15:18:53 cucumber-pc sddm-greeter[700]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Oct 02 15:18:54 cucumber-pc sddm-greeter[700]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Oct 02 15:18:54 cucumber-pc sddm-greeter[700]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Oct 02 15:18:54 cucumber-pc sddm-greeter[700]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Oct 02 15:18:54 cucumber-pc sddm-greeter[700]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Oct 02 15:18:54 cucumber-pc sddm-greeter[700]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 02 15:18:54 cucumber-pc sddm-greeter[700]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.18'
Oct 02 15:18:54 cucumber-pc sddm-greeter[700]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.19'
Oct 02 15:18:56 cucumber-pc kernel: usb 3-10: Failed to suspend device, error -110
Oct 02 15:20:04 cucumber-pc systemd-journald[328]: File /var/log/journal/f9abbd310eee437d99a871cdfe930f0e/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Oct 02 15:20:04 cucumber-pc ksplashqml[791]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Oct 02 15:20:04 cucumber-pc ksplashqml[791]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Oct 02 15:20:05 cucumber-pc ksmserver[844]: Qt: Session management error: networkIdsList argument is NULL
Oct 02 15:20:05 cucumber-pc ksmserver[844]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.16'
Oct 02 15:20:05 cucumber-pc kwin_x11[847]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Oct 02 15:20:05 cucumber-pc kwin_x11[847]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Oct 02 15:20:05 cucumber-pc kded5[846]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Oct 02 15:20:05 cucumber-pc plasmashell[884]: Checking screens: available: (QScreen(0x5622d834e150, name="DP-2"), QScreen(0x5622d834e240, name="DP-4")) redundant: QHash() fake: QSet() all: (QScreen(0x5622d834e150, name="DP-2"), QScreen(0x5622d834e240, name="DP-4"))
Oct 02 15:20:06 cucumber-pc plasmashell[884]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 02 15:20:06 cucumber-pc plasmashell[884]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 02 15:20:06 cucumber-pc kded5[846]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Oct 02 15:20:06 cucumber-pc backlighthelper[962]: org.kde.powerdevil: no kernel backlight interface found
Oct 02 15:20:06 cucumber-pc org_kde_powerdevil[912]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 02 15:20:06 cucumber-pc org_kde_powerdevil[912]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Oct 02 15:20:06 cucumber-pc org_kde_powerdevil[912]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 02 15:20:06 cucumber-pc org_kde_powerdevil[912]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Oct 02 15:20:07 cucumber-pc plasmashell[884]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 02 15:20:07 cucumber-pc plasmashell[884]: Checking screens: available: (QScreen(0x5622d834e240, name="DP-4"), QScreen(0x5622d834e150, name="DP-2")) redundant: QHash() fake: QSet() all: (QScreen(0x5622d834e240, name="DP-4"), QScreen(0x5622d834e150, name="DP-2"))
Oct 02 15:20:07 cucumber-pc plasmashell[884]: Checking screens: available: (QScreen(0x5622d834e240, name="DP-4")) redundant: QHash((QScreen(0x5622d834e150, name="DP-2"), QScreen(0x5622d834e240, name="DP-4"))) fake: QSet() all: (QScreen(0x5622d834e240, name="DP-4"), QScreen(0x5622d834e150, name="DP-2"))
Oct 02 15:20:07 cucumber-pc pulseaudio[1072]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 02 15:20:08 cucumber-pc plasmashell[884]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:20: TypeError: Cannot read property 'pluginName' of null
Oct 02 15:20:08 cucumber-pc plasmashell[884]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75: TypeError: Cannot read property 'configuration' of null
Oct 02 15:20:08 cucumber-pc plasmashell[884]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Oct 02 15:20:09 cucumber-pc kioslave5[1223]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Oct 02 15:20:09 cucumber-pc plasmashell[884]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 02 15:20:09 cucumber-pc plasmashell[884]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Oct 02 15:20:09 cucumber-pc plasmashell[884]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Oct 02 15:20:09 cucumber-pc plasmashell[884]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 02 15:20:09 cucumber-pc plasmashell[884]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5622da972460) QQmlContext(0x5622d9d83c90) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 02 15:20:09 cucumber-pc plasmashell[884]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:61:17: Unable to assign [undefined] to int
Oct 02 15:20:09 cucumber-pc plasmashell[884]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
Oct 02 15:20:10 cucumber-pc plasmashell[884]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
Oct 02 15:20:21 cucumber-pc plasmashell[884]: trying to show an empty dialog
Oct 02 15:20:21 cucumber-pc plasmashell[884]: libpng warning: iCCP: known incorrect sRGB profile
Oct 02 15:20:21 cucumber-pc plasmashell[884]: libpng warning: known incorrect sRGB profile
Oct 02 15:20:21 cucumber-pc plasmashell[884]: libpng warning: profile matches sRGB but writing iCCP instead
Oct 02 15:20:31 cucumber-pc pulseaudio[1072]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Oct 02 15:20:31 cucumber-pc kded5[846]: kf.bluezqt: PendingCall Error: "Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)"
Oct 02 15:25:42 cucumber-pc systemsettings[1888]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Oct 02 15:25:42 cucumber-pc systemsettings[1888]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 02 15:26:54 cucumber-pc org_kde_powerdevil[912]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Oct 02 15:26:54 cucumber-pc org_kde_powerdevil[912]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 02 15:27:05 cucumber-pc systemsettings[1888]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 02 15:27:05 cucumber-pc systemsettings[1888]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
Oct 02 15:27:05 cucumber-pc systemsettings[1888]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo"
Oct 02 15:27:06 cucumber-pc systemsettings[1888]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Dialog.qml:335:9: QML ScrollView: Binding loop detected for property "calculatedImplicitWidth"
Oct 02 15:27:06 cucumber-pc systemsettings[1888]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 02 15:27:06 cucumber-pc systemsettings[1888]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
Oct 02 15:27:06 cucumber-pc systemsettings[1888]: file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:88:5: QML GridLayout: Binding loop detected for property "knownItemsImplicitWidth"
Oct 02 15:28:24 cucumber-pc plasmashell[884]: trying to show an empty dialog
Oct 02 15:28:24 cucumber-pc plasmashell[884]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 02 15:30:51 cucumber-pc plasmashell[884]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
Oct 02 15:30:56 cucumber-pc kscreenlocker_greet[2825]: Qt: Session management error: networkIdsList argument is NULL
Oct 02 15:30:57 cucumber-pc kscreenlocker_greet[2825]: kf.kirigami: Failed to find a Kirigami platform plugin
Oct 02 15:30:57 cucumber-pc kscreenlocker_greet[2825]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
