I had an issue where when i plug in an etherner cabel my system died and had to hard reboot.
This was the previous error:
Feb 11 16:17:56 HunorT480 wpa_supplicant[706]: rfkill: WLAN hard blocked
Feb 11 16:17:56 HunorT480 kernel: iwlwifi 0000:03:00.0: RF_KILL bit toggled to disable radio.
Feb 11 16:17:56 HunorT480 kernel: iwlwifi 0000:03:00.0: reporting RF_KILL (radio disabled)
Feb 11 16:17:56 HunorT480 (udev-worker)[15896]: rfkill2: /etc/udev/rules.d/10-trackpoint.rules:4 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.6/0000:03:00.0/ieee80211/phy0/rfkill2/device/sensitivity}, ignoring: No such file or directory
Feb 11 16:17:56 HunorT480 (udev-worker)[15896]: rfkill2: /etc/udev/rules.d/10-trackpoint.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.6/0000:03:00.0/ieee80211/phy0/rfkill2/device/speed}, ignoring: No such file or directory
Feb 11 16:17:56 HunorT480 (udev-worker)[15896]: rfkill2: /etc/udev/rules.d/10-trackpoint.rules:6 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.6/0000:03:00.0/ieee80211/phy0/rfkill2/device/inertia}, ignoring: No such file or directory
Feb 11 16:17:56 HunorT480 (udev-worker)[15896]: rfkill2: /etc/udev/rules.d/10-trackpoint.rules:7 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.6/0000:03:00.0/ieee80211/phy0/rfkill2/device/press_to_select}, ignoring: No such file or directory
Feb 11 16:17:56 HunorT480 NetworkManager[557]: <info> [1707664676.9211] manager: rfkill: Wi-Fi now disabled by radio killswitch
Feb 11 16:17:56 HunorT480 NetworkManager[557]: <info> [1707664676.9213] device (wlp3s0): state change: disconnected -> unavailable (reason 'none', sys-iface-state: 'managed')
Feb 11 16:17:56 HunorT480 kernel: e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 100 Mbps Half Duplex, Flow Control: None
Feb 11 16:17:56 HunorT480 kernel: e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
F
Now I have this issue that when i close the lid the system wont go into suspend mode.
I have the logind.service configured right.
Any idea what could have happened?
Informations
Journalctl
journalctl -b -n 50
Feb 12 22:53:37 HunorT480 kernel: </TASK>
Feb 12 22:53:37 HunorT480 kernel: OOM killer enabled.
Feb 12 22:53:37 HunorT480 rtkit-daemon[2554]: The canary thread is apparently starving. Taking action.
Feb 12 22:53:37 HunorT480 rtkit-daemon[2554]: Demoting known real-time threads.
Feb 12 22:53:37 HunorT480 rtkit-daemon[2554]: Demoted 0 threads.
Feb 12 22:53:37 HunorT480 kernel: Restarting tasks ... done.
Feb 12 22:53:37 HunorT480 kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Feb 12 22:53:37 HunorT480 (udev-worker)[955303]: thermal_zone3: /etc/udev/rules.d/10-trackpoint.rules:4 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone3/device/sensitivity},>
Feb 12 22:53:37 HunorT480 (udev-worker)[955303]: thermal_zone3: /etc/udev/rules.d/10-trackpoint.rules:5 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone3/device/speed}, ignor>
Feb 12 22:53:37 HunorT480 (udev-worker)[955303]: thermal_zone3: /etc/udev/rules.d/10-trackpoint.rules:6 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone3/device/inertia}, ign>
Feb 12 22:53:37 HunorT480 (udev-worker)[955303]: thermal_zone3: /etc/udev/rules.d/10-trackpoint.rules:7 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone3/device/press_to_sele>
Feb 12 22:53:37 HunorT480 (udev-worker)[955304]: thermal_zone4: /etc/udev/rules.d/10-trackpoint.rules:4 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone4/device/sensitivity},>
Feb 12 22:53:37 HunorT480 (udev-worker)[955304]: thermal_zone4: /etc/udev/rules.d/10-trackpoint.rules:5 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone4/device/speed}, ignor>
Feb 12 22:53:37 HunorT480 (udev-worker)[955304]: thermal_zone4: /etc/udev/rules.d/10-trackpoint.rules:6 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone4/device/inertia}, ign>
Feb 12 22:53:37 HunorT480 (udev-worker)[955304]: thermal_zone4: /etc/udev/rules.d/10-trackpoint.rules:7 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone4/device/press_to_sele>
Feb 12 22:53:37 HunorT480 (udev-worker)[955305]: thermal_zone6: /etc/udev/rules.d/10-trackpoint.rules:4 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone6/device/sensitivity},>
Feb 12 22:53:37 HunorT480 (udev-worker)[955305]: thermal_zone6: /etc/udev/rules.d/10-trackpoint.rules:5 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone6/device/speed}, ignor>
Feb 12 22:53:37 HunorT480 (udev-worker)[955305]: thermal_zone6: /etc/udev/rules.d/10-trackpoint.rules:6 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone6/device/inertia}, ign>
Feb 12 22:53:37 HunorT480 (udev-worker)[955305]: thermal_zone6: /etc/udev/rules.d/10-trackpoint.rules:7 Failed to write ATTR{/sys/devices/virtual/thermal/thermal_zone6/device/press_to_sele>
Feb 12 22:53:37 HunorT480 systemd-sleep[955138]: Failed to put system to sleep. System resumed again: Device or resource busy
Feb 12 22:53:37 HunorT480 kernel: PM: suspend exit
Feb 12 22:53:38 HunorT480 systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
Feb 12 22:53:38 HunorT480 systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
Feb 12 22:53:38 HunorT480 systemd[1]: Failed to start System Suspend.
Feb 12 22:53:38 HunorT480 systemd[1]: Dependency failed for Suspend.
Feb 12 22:53:38 HunorT480 systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
Feb 12 22:53:38 HunorT480 systemd[1]: systemd-suspend.service: Consumed 2.072s CPU time.
Feb 12 22:53:38 HunorT480 systemd-logind[714]: Operation 'sleep' finished.
Feb 12 22:53:38 HunorT480 ModemManager[751]: <msg> [sleep-monitor-systemd] system is resuming
Feb 12 22:53:38 HunorT480 systemd[1]: Stopped target Sleep.
Feb 12 22:53:38 HunorT480 NetworkManager[706]: <info> [1707774818.2366] manager: sleep: wake requested (sleeping: yes enabled: yes)
Feb 12 22:53:38 HunorT480 NetworkManager[706]: <info> [1707774818.2367] device (enp0s31f6): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Feb 12 22:53:38 HunorT480 ModemManager[751]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:16.3': Device support check task already available for >
Feb 12 22:53:38 HunorT480 ModemManager[751]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.6/0000:03:00.0': Device support check task already a>
Feb 12 22:53:38 HunorT480 ModemManager[751]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': Device support check task already available for >
Feb 12 22:53:38 HunorT480 NetworkManager[706]: <info> [1707774818.3291] device (enp0s31f6): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Feb 12 22:53:38 HunorT480 kernel: e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
Feb 12 22:53:38 HunorT480 i3lock[954829]: pam_unix(i3lock:auth): authentication failure; logname= uid=1002 euid=1002 tty=:0 ruser= rhost= user=i3hunor
Feb 12 22:53:38 HunorT480 NetworkManager[706]: <info> [1707774818.5448] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Feb 12 22:53:38 HunorT480 dunst[2796]: WARNING: No icon found in path: 'nm-no-connection'
Feb 12 22:53:38 HunorT480 dunst[2796]: CRITICAL: Source ID 468 was not found when attempting to remove it
Feb 12 22:53:38 HunorT480 NetworkManager[706]: <info> [1707774818.5458] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Feb 12 22:53:38 HunorT480 NetworkManager[706]: <info> [1707774818.5463] manager: NetworkManager state is now DISCONNECTED
Feb 12 22:53:40 HunorT480 betterlockscreen[954806]: [*] Running postlock...
Feb 12 22:53:40 HunorT480 systemd[1]: betterlockscreen@i3hunor.service: Deactivated successfully.
lines 10-50/50 (END)
Sys Info
inxi -v7azy
Kernel: 5.15.146-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=cc7be21e-d9d4-4881-841a-b047d2a1253a rw quiet
udev.log_priority=3 intel_pstate=disable acpi_backlight=intel
Desktop: i3 v: 4.23 info: polybar vt: 7 dm: 1: LightDM v: 1.32.0 2: SDDM
note: stopped Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N24ET72W (1.47 )
date: 01/03/2023
ID-1: BAT0 charge: 15.1 Wh (82.5%) condition: 18.3/23.9 Wh (76.5%)
volts: 11.4 min: 11.4 model: LGC 01AV489 type: Li-poly serial: <filter>
status: not charging cycles: 453
ID-2: BAT1 charge: 44.9 Wh (63.2%) condition: 71.0/71.3 Wh (99.6%)
power: 8.3 W volts: 11.6 min: 10.8 model: SANYO 01AV427 type: Li-ion
serial: <filter> status: discharging cycles: 76
System RAM: total: 8 GiB note: est. available: 7.51 GiB
used: 3.57 GiB (47.5%)
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1203 high: 1532 min/max: 400/1901 boost: enabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 1371 2: 879 3: 1023 4: 1532
5: 900 6: 1245 7: 1426 8: 1249 bogomips: 30409
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 compositor: Picom v: git-b700a
driver: X: loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x0521 built: 2016
res: 1920x1080 hz: 60 dpi: 157 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k5.15.146-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module
tools: pacat,pactl,pamixer,pavucontrol
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Local Storage: total: 238.47 GiB used: 66.5 GiB (27.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: L15P temp: 31.9 C scheme: GPT
ID-1: / raw-size: 118.93 GiB size: 116.5 GiB (97.96%) used: 66.47 GiB (57.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: cc7be21e-d9d4-4881-841a-b047d2a1253a
used: 25.4 MiB (26.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 2EAD-1B08
ID-3: /home/<filter>/Google_drive raw-size: N/A size: 15 GiB
used: 4.25 GiB (28.3%) fs: fuse.rclone remote: googledrive:
ID-1: swap-1 type: file size: 8 GiB used: 669.5 MiB (8.2%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 118.93 GiB fs: ntfs label: N/A
uuid: 3648B0CC48B08C5D
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 1804C52004C5022C
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:3 info: Chicony Integrated Camera (1280x720@30) type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 44.0 C pch: 41.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Processes: 248 Uptime: 1d 3h 56m wakeups: 4 Init: systemd v: 255
Packages: pm: pacman pkgs: 1570 libs: 420 tools: pamac,yay Shell: Bash
v: 5.2.21 running-in: kitty inxi: 3.3.31
EDIT: Not even calling suspend works. The screen locks and become unresponsive but no sleep.
