I may have run updates last weekend. I usually do each weekend. It has no new updates this morning sudo pacman -Syu
sudo systemctl start lightdm
runs but does the same thing, black screen with a cursor.
All errors and up, from the current boot.
[will@silverbox ~]$ journalctl -p3 -b0
Sep 29 08:35:45 silverbox kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT2._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
Sep 29 08:35:45 silverbox kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT2._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Sep 29 08:35:45 silverbox kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
Sep 29 08:35:45 silverbox kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Sep 29 08:35:47 silverbox kernel: usb 4-5: 3:1: cannot get freq at ep 0x86
Sep 29 08:35:47 silverbox kernel: usb 4-5: 3:2: cannot get freq at ep 0x86
Sep 29 08:35:47 silverbox kernel: usb 4-5: 3:3: cannot get freq at ep 0x86
Sep 29 08:35:51 silverbox systemd-coredump[1653]: [🡕] Process 1606 (cups-proxyd) of user 0 dumped core.
Stack trace of thread 1606:
#0 0x000055a9d96f1d75 n/a (/snap/cups/1058/sbin/cups-proxyd + 0x9d75)
Sep 29 08:36:08 silverbox systemd[1]: Failed to start Light Display Manager.
Sep 29 09:32:03 silverbox systemd[1]: Failed to start Light Display Manager.
All logs, info and up, from LightDM, from the previous boot
[will@silverbox ~]$ journalctl -u lightdm -b -1
Sep 29 08:30:53 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:30:53 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:30:55 silverbox lightdm[1694]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:30:55 silverbox lightdm[1694]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1694) opened.
Sep 29 08:30:56 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:30:56 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:30:56 silverbox systemd[1]: lightdm.service: Consumed 605ms CPU time, 86.2M memory peak.
Sep 29 08:30:57 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
Sep 29 08:30:57 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:30:57 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:30:58 silverbox lightdm[1743]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:30:58 silverbox lightdm[1743]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1743) opened.
Sep 29 08:30:58 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:30:58 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:30:59 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
Sep 29 08:30:59 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:30:59 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:00 silverbox lightdm[1763]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:00 silverbox lightdm[1763]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1763) opened.
Sep 29 08:31:00 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:00 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:01 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
Sep 29 08:31:01 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:31:01 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:02 silverbox lightdm[1783]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:02 silverbox lightdm[1783]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1783) opened.
Sep 29 08:31:02 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:02 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:03 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
Sep 29 08:31:03 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:31:03 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:04 silverbox lightdm[1804]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:04 silverbox lightdm[1804]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1804) opened.
Sep 29 08:31:04 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:04 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:05 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
Sep 29 08:31:05 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:31:05 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:06 silverbox lightdm[1824]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:06 silverbox lightdm[1824]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1824) opened.
Sep 29 08:31:06 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:06 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:07 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 6.
Sep 29 08:31:07 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:31:07 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:08 silverbox lightdm[1844]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:08 silverbox lightdm[1844]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1844) opened.
Sep 29 08:31:08 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:08 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:09 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 7.
Sep 29 08:31:09 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:31:09 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:10 silverbox lightdm[1864]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:10 silverbox lightdm[1864]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1864) opened.
Sep 29 08:31:10 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:10 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:11 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 8.
Sep 29 08:31:11 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:31:11 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:12 silverbox lightdm[1884]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:12 silverbox lightdm[1884]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1884) opened.
Sep 29 08:31:12 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:12 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:13 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 9.
Sep 29 08:31:13 silverbox systemd[1]: Starting Light Display Manager...
Sep 29 08:31:13 silverbox systemd[1]: Started Light Display Manager.
Sep 29 08:31:14 silverbox lightdm[1904]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 29 08:31:14 silverbox lightdm[1904]: pam_systemd(lightdm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1904) opened.
Sep 29 08:31:14 silverbox systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 08:31:14 silverbox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Sep 29 08:31:14 silverbox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 10.
Sep 29 08:31:14 silverbox systemd[1]: lightdm.service: Start request repeated too quickly.
Sep 29 08:31:14 silverbox systemd[1]: Failed to start Light Display Manager.
System Info
[will@silverbox ~]$ sudo inxi --verbosity=8 --filter --width
[sudo] password for will:
Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3510e7bf-8999-4434-b116-7dd601ae8f04 rw quiet apparmor=1
Console: pty pts/1 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: System76 product: Wild Dog Performance v: wilp10
serial: N/A Chassis: type: 3 v: Desktop serial: <filter>
Mobo: ASUSTeK model: H87-PLUS v: Rev X.0x serial: <filter> part-nu: All
uuid: 204a8ec0-d7da-11dd-ad6b-e03f4944d631 UEFI: American Megatrends v: 0705
date: 12/05/2013
System RAM: total: 16 GiB available: 15.56 GiB used: 609.1 MiB (3.8%)
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Crucial part-no: BLS8G3D1609DS1S00. serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM1 type: no module installed
Slot: 1 type: PCIe status: in use length: long volts: 3.3 bus-ID: 01:00.0
Slot: 2 type: PCIe status: available length: short volts: 3.3
bus-ID: 02:00.0
Slot: 3 type: PCIe status: available length: short volts: 3.3
bus-ID: ff:00.0
Slot: 4 type: PCIe status: available length: long volts: 3.3
bus-ID: ff:00.0
Slot: 5 type: PCI status: available length: short volts: 3.3
bus-ID: 05:1c.7
Slot: 6 type: PCI status: available length: short volts: 3.3
bus-ID: 05:1d.0
Slot: 7 type: PCI status: available length: short volts: 3.3
bus-ID: 05:1d.1
Info: model: Intel Core i7-4770 socket: BGA1155 (1150) note: check bits: 64
type: MT MCP arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/3900 base/boost: 3400/3900 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
bogomips: 54296
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 550.xx+ status: current (as of 2024-09;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300 temp: 39.0 C
Device-2: Sunplus Innovation UHD Capture driver: snd-usb-audio,uvcvideo
type: USB rev: 3.1 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-5:2
chip-ID: 1bcf:2c99 class-ID: 0102
Display: unspecified server: X.org v: 1.21.1.13 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
tty: 190x42
Monitor-1: HDMI-A-1 model: Dell P2217 serial: <filter> built: 2016
res: 1680x1050 dpi: 90 gamma: 1.2 chroma: red: x: 0.635 y: 0.357 green:
x: 0.310 y: 0.643 blue: x: 0.153 y: 0.071 white: x: 0.314 y: 0.329
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10
modes: 1680x1050, 1920x1080, 1920x1080i, 1280x1024, 1152x864, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
API: OpenGL Message: GL data unavailable in console, glxinfo missing.
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: Sunplus Innovation UHD Capture driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl,pavucontrol
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Info: services: NetworkManager,sshd
Local Storage: total: 3.87 TiB used: 221.73 GiB (5.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 5B0Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: GPT
Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-212V rev: 1.01
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 221.73 GiB (95.0%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 3510e7bf-8999-4434-b116-7dd601ae8f04
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: 712B-FF26
ID-1: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ext4 label: N/A
uuid: 34fe4fda-de97-4e97-af31-5e9085ca4263
ID-2: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ext4 label: N/A
uuid: a5355482-baf3-40be-95ab-391bf5f336a4
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-2:2 info: YICHIP Wireless Device type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
serial: <filter>
Device-2: 3-11:3 info: Alcor Micro AU6477 Card Reader Controller
type: mass storage,HID driver: hid-generic,usb-storage,usbhid interfaces: 2
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 250mA
chip-ID: 058f:6364 class-ID: 0300 serial: <filter>
Device-3: 3-12:4 info: Shenzhen Riitek Wireless Receiver
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 50mA
chip-ID: 1997:2466 class-ID: 0301
Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
Device-1: 4-5:2 info: Sunplus Innovation UHD Capture type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 512mA
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nouveau temp: 39.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 0
Packages: 1545 pm: pacman pkgs: 1496 libs: 469 tools: pamac pm: flatpak
pkgs: 32 pm: snap pkgs: 17
1: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
9: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
10: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
17: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://muug.ca/mirror/manjaro/stable/$repo/$arch
19: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
20: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
22: http://mirror.fcix.net/manjaro/stable/$repo/$arch
23: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
24: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 188
1: cpu: 0.1% command: snapd pid: 792 mem: 46.8 MiB (0.2%)
2: cpu: 0.0% command: init pid: 1 mem: 13.5 MiB (0.0%)
3: cpu: 0.0% command: [kthreadd] pid: 2 mem: 0.00 MiB (0.0%)
4: cpu: 0.0% command: [pool_workqueue_release] pid: 3 mem: 0.00 MiB (0.0%)
5: cpu: 0.0% command: [kworker/R-rcu_g] pid: 4 mem: 0.00 MiB (0.0%)
Memory top: 5 of 188
1: mem: 46.8 MiB (0.2%) command: snapd pid: 792 cpu: 0.1%
2: mem: 23.7 MiB (0.1%) command: systemd-journald pid: 432 cpu: 0.0%
3: mem: 23.1 MiB (0.1%) command: NetworkManager pid: 788 cpu: 0.0%
4: mem: 13.5 MiB (0.0%) command: init pid: 1 cpu: 0.0%
5: mem: 13.0 MiB (0.0%) command: ModemManager pid: 934 cpu: 0.0%
Processes: 188 Power: uptime: 1h 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB Init: systemd v: 256
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.32 running-in: pty pts/1 (SSH) inxi: 3.3.36
[will@silverbox ~]$
