While trying to fix a known problem with my motherboard (Intel Ethernet Controller I225-V stops working), I updated the BIOS and ever since I can’t use suspend. The system begins shutting down as expected, then starts up again immediately, whatever options is chosen — Cinnamon menu: Suspend (suspend-to-ram?), Sleep (suspend-to-idle?), Hibernate; systemctl suspend, systemctl hibernate, systemctl sleep.
I reset BIOS options to “optimized defaults” after updating and I have the same settings as before — nothing exotic, no overclocking. There seem to be very few power-related settings available anyway: you can toggle ErP (EU power reduction when shut down), you can toggle USB power (when shut down), LED states (I don’t use any LEDs) in different power states. There may be some AMD settings related to power, but I’ve never changed them. [ASUS ROG STRIX X670E-F GAMING WIFI (manual)]
This looks right:
$ cat /sys/power/mem_sleep
s2idle [deep]
In Cinnamon power settings, power button is set to suspend; Hybrid Sleep and Hibernate after suspend are off.
I’ve double-checked that the resume parameter in GRUB points to the swap partition.
When using suspend I see this in dmesg:
[ 5874.024279] NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
[ 5874.024282] nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
[ 5874.024408] nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
[ 5874.024412] nvidia 0000:01:00.0: PM: failed to suspend async: error -5
[ 5874.321862] PM: Some devices failed to suspend, or early wake event detected
[ 5874.322476] [drm] PCIE GART of 1024M enabled (table at 0x000000F41FC00000).
[ 5874.322493] amdgpu 0000:12:00.0: amdgpu: PSP is resuming...
This is not something I’ve knowingly ever set up, but I see somewhere else that you can find details in Chapter 21 of the driver readme.
The systemd services mentioned (nvidia-suspend, nvidia-hibernate, nividia-resume) are all present & enabled; the scripts are in the right places.
hibernate shows a different error in dmesg:
[ 6045.462516] xhci_hcd 0000:10:00.0: PM: pci_pm_freeze(): hcd_pci_suspend returns -16
[ 6045.462524] xhci_hcd 0000:10:00.0: PM: dpm_run_callback(): pci_pm_freeze returns -16
[ 6045.462528] xhci_hcd 0000:10:00.0: PM: failed to freeze async: error -16
Maybe I need to check the XHCI Handoff setting in BIOS as well? Any other suggestions on how to diagnose this?
inxi -zv8
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=67b88b14-c229-4711-aafa-0fb8e882fccd rw quiet apparmor=1
security=apparmor udev.log_priority=3 atkbd.reset
resume=UUID=dc86e40b-8923-49c0-8c24-f2a39e4c7dc8
Desktop: Cinnamon v: 6.4.6 tk: GTK v: 3.24.43 wm: Muffin v: 6.4.1
with: albert,plank tools: avail: cinnamon-screensaver vt: 7 dm: LightDM
v: 1.32.0 Distro: Manjaro base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX X670E-F GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 2704 date: 01/17/2025
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 64 GiB available: 61.96 GiB used: 14.97 GiB (24.2%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 32 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK64GX5M2B6400C32 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 7900X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 545 min/max: 545/5660 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 545 2: 545 3: 545
4: 545 5: 545 6: 545 7: 545 8: 545 9: 545 10: 545 11: 545 12: 545 13: 545
14: 545 15: 545 16: 545 17: 545 18: 545 19: 545 20: 545 21: 545 22: 545
23: 545 24: 545 bogomips: 210864
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2783 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,Writeback-1 bus-ID: 12:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 49.0 C
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.3.2:7
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4 driver: X:
loaded: N/A failed: nvidia gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-0 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi gbm: drv: radeonsi surfaceless:
drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 550.144.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070
SUPER/PCIe/SSE2 memory: 11.71 GiB
API: Vulkan v: 1.4.303 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 SUPER driver: N/A device-ID: 10de:2783 surfaces: xcb,xlib
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:1640
class-ID: 0403
Device-3: C-Media Antlion USB adapter
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0d8c:002b class-ID: 0300
serial: <filter>
Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
Device-5: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3
chip-ID: 0b05:1a52 class-ID: 0300
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
chip-ID: 8086:15f3 class-ID: 0200
IP v6: <filter> virtual: proto kernel_ll scope: link
Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 0489:e0e2
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 10.01 TiB used: 6.82 TiB (68.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T700SSD3
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PACR5103 temp: 49.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000DM004-2U9188
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 3B6Q scheme: MBR
SMART Message: A mandatory SMART command failed. Various possible causes.
Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-209M rev: 1.30
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 250 GiB size: 245.77 GiB (98.31%) used: 180.33 GiB (73.4%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6 label: Mangie
uuid: 67b88b14-c229-4711-aafa-0fb8e882fccd
used: 467.8 MiB (91.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: ESP uuid: 9A12-FA87
ID-3: /home raw-size: 250 GiB size: 245.89 GiB (98.36%)
used: 152.88 GiB (62.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: Latty uuid: 105a7867-e1bc-4889-baf2-c98e4e296414
ID-4: /home/<filter>/Cluichí/Minecraft/Bedrock Server raw-size: N/A
size: 108.98 GiB used: 27.13 GiB (24.9%) fs: nfs4
remote: cluifi:/home/sean/minecraft-server
[many mounts snipped]
ID-30: /run/media/sean/FEAAD5D2AAD58813 raw-size: 149 GiB
size: 149 GiB (100.00%) used: 37.53 GiB (25.2%) fs: ntfs block-size: 4096 B
dev: /dev/sdd1 maj-min: 8:49 label: N/A uuid: FEAAD5D2AAD58813
ID-1: swap-1 type: partition size: 65 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb1 maj-min: 8:17 label: swap
uuid: dc86e40b-8923-49c0-8c24-f2a39e4c7dc8
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 249.93 GiB fs: ntfs label: N/A
uuid: B80E820D0E81C53A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 578 MiB fs: ntfs label: N/A
uuid: 1A808F34808F1603
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 450 MiB fs: ntfs label: N/A
uuid: 2E2C84552C841A4B
ID-5: /dev/nvme0n1p9 maj-min: 259:9 size: 44.74 GiB fs: ext4
label: AntelopePlay uuid: b31d8bee-4f0f-45d6-8d4b-c887a1178222
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: C-Media Antlion USB adapter type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
chip-ID: 0d8c:002b class-ID: 0300 serial: <filter>
Device-2: 1-6:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-3: 1-7:4 info: Microsoft Wireless Receiver 1461C
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 045e:07a5 class-ID: 0300
Device-4: 1-9:5 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Device-1: 2-2:2 info: Norelsys NS1068/NS1068X SATA Bridge Controller
type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 2537:1068 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-4:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
Hub-5: 3-4.3:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-4.3.1:6 info: Keyboardio Model 100
type: abstract (modem),CDC-data,keyboard,HID
driver: cdc_acm,hid-generic,usbhid interfaces: 5 rev: 2.0
chip-ID: 3496:0006 class-ID: 0300 serial: <filter>
Device-2: 3-4.3.2:7 info: Logitech C920 HD Pro Webcam type: video,audio
Hub-6: 3-4.3.4:8 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-4.3.4.2:12 info: ROCCAT Kone Pure Military Mouse
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 1e7d:2dbf class-ID: 0301
Device-2: 3-4.4:5 info: LG USA 27UP850 - WK.AEUDCSN External Monitor 4K
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 043e:9a39
Device-3: 3-6:3 info: ASUSTek USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
Device-4: 3-7:9 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-7: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-8: 4-4:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0451:8140
Hub-9: 4-4.3:3 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-10: 4-4.3.4:4 info: Genesys Logic Hub ports: 4 rev: 3.2
Hub-11: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-12: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-13: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-14: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-15: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-16: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 57.0 C mobo: 54.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 44 C fan: 32% device: amdgpu
temp: 50.0 C
Packages: 3680 pm: pacman pkgs: 3560 libs: 655 tools: pamac,yay,yup
pm: flatpak pkgs: 90 pm: snap pkgs: 30
Active pacman repo servers in: /etc/pacman.conf
1: https://download.sublimetext.com/arch/stable/x86_64
1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 557
1: cpu: 41.6% command: nemo pid: 8967 mem: 1393.5 MiB (2.1%)
2: cpu: 8.4% command: firefox pid: 4989 mem: 1115.7 MiB (1.7%)
3: cpu: 4.1% command: thunderbird pid: 4915 mem: 1036.2 MiB (1.6%)
4: cpu: 3.8% command: cinnamon pid: 3620 mem: 513.0 MiB (0.8%)
5: cpu: 2.6% command: caribou pid: 3728 mem: 107.5 MiB (0.1%)
Memory top: 5 of 557
1: mem: 2449.7 MiB (3.8%) command: pamac-manager pid: 29099 cpu: 0.3%
2: mem: 1393.5 MiB (2.1%) command: nemo pid: 8967 cpu: 41.6%
3: mem: 1252.4 MiB (1.9%) command: sublime_text pid: 59371 cpu: 0.2%
4: mem: 1115.7 MiB (1.7%) command: firefox pid: 4989 cpu: 8.4%
5: mem: 1036.2 MiB (1.6%) command: thunderbird pid: 4915 cpu: 4.1%
Processes: 557 Power: uptime: 3h 3m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 fails: 6 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 24.75 GiB services: csd-power,upowerd
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 8/9/13 Shell: Bash v: 5.2.37
running-in: gnome-terminal inxi: 3.3.37
