Since the last stable update of June 19th my system has some quirks. It will not shutdown entirely anymore or if I leave it idle for some time it completely freezes the UI or the whole system. Another varition that I have is that I left it idle, touch a key to bring it back to live and the login screen shows up but nothing responds to either keyboard or mouse. Sometimes when it is frozen the mouse will still move, other times nothing responds. From all the topics I have read it seems to have to do with my display drivers but perhaps it might also be the mkinitcpio.conf that changed due to a new pacnew file.
The new pacnew lists the hooks as follows:
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap consolefont block filesystems fsck)
My old hooks were set as:
HOOKS=(base udev autodetect modconf kms block keyboard keymap filesystems)
However changing the hooks back to the old configuration makes no difference.
The other thing I tried is switching from X11 to Wayland, this also makes no difference and the same behavior happens.
After a reboot I run optimus-manager and then see the following:
ERROR: a GPU setup was initiated but Xorg post-start hook did not run.
Log at /var/log/optimus-manager/switch/switch-20250528T150304.log
If your login manager is GDM, make sure to follow those instructions:
https://github.com/Askannz/optimus-manager#important--gnome-and-gdm-users
If your display manager is neither GDM, SDDM nor LightDM, or if you don't use one, read the wiki:
https://github.com/Askannz/optimus-manager/wiki/FAQ,-common-issues,-troubleshooting
Cannot execute command because of previous errors.
Running prime-offload takes care of that but I think it is because the shutdown hangs.
Another thing I tried is to set the Saved Session to none, reboot and then enable Saved Sessions again, reboot but every reboot it still hangs as shown in the attached image.
Not sure where to go from here. Below are the outputs that I collected.
Thanks for any pointers.
journalctl -b-1 -p4 --no-pager --boot=-1
mei 28 13:21:40 roland-xps kernel: x86/cpu: SGX disabled or unsupported by BIOS.
mei 28 13:21:40 roland-xps kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
mei 28 13:21:40 roland-xps kernel: hpet_acpi_add: no address or irqs in _CRS
mei 28 13:21:40 roland-xps kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
mei 28 13:21:40 roland-xps kernel: wmi_bus wmi_bus-PNP0C14:03: [Firmware Bug]: WQBC data block query control method not found
mei 28 13:21:40 roland-xps kernel: i8042: Warning: Keylock active
mei 28 13:21:40 roland-xps systemd-modules-load[390]: Failed to find module 'vboxdrv'
mei 28 13:21:40 roland-xps systemd-modules-load[390]: Failed to find module 'vboxnetadp'
mei 28 13:21:40 roland-xps systemd-modules-load[390]: Failed to find module 'vboxnetflt'
mei 28 13:21:40 roland-xps systemd-modules-load[390]: Failed to find module 'nvidia'
mei 28 13:21:40 roland-xps systemd-modules-load[390]: Failed to find module 'nvidia-drm'
mei 28 13:21:40 roland-xps systemd-modules-load[390]: Failed to find module 'nvidia-uvm'
mei 28 13:21:41 roland-xps kernel: spi-nor spi0.0: supply vcc not found, using dummy regulator
mei 28 13:21:41 roland-xps kernel: Bluetooth: Received HCI_IBS_WAKE_ACK in tx state 0
mei 28 13:21:41 roland-xps (uetoothd)[844]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
mei 28 13:21:41 roland-xps kernel: sof_sdw sof_sdw: ASoC: Parent card not yet available, widget card binding deferred
mei 28 13:21:42 roland-xps nmbd[995]: [2025/05/28 13:21:42.128651, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
mei 28 13:21:42 roland-xps nmbd[995]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
mei 28 13:21:42 roland-xps ModemManager[899]: <wrn> [plugin-manager] task 0: port context already scheduled
mei 28 13:21:42 roland-xps bluetoothd[844]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
mei 28 13:21:43 roland-xps dbus-broker-launch[841]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mei 28 13:21:44 roland-xps dbus-broker-launch[1263]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mei 28 13:21:44 roland-xps dbus-broker-launch[1263]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mei 28 13:21:44 roland-xps dbus-broker-launch[1263]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mei 28 13:21:47 roland-xps systemd[1]: logid.service: Failed with result 'exit-code'.
mei 28 13:21:48 roland-xps dbus-broker-launch[841]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mei 28 13:21:55 roland-xps sddm-greeter-qt6[1259]: file:///usr/share/sddm/themes/breeze/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
mei 28 13:21:55 roland-xps ModemManager[899]: <wrn> [plugin-manager] task 1: port context already scheduled
mei 28 13:21:56 roland-xps sddm[1038]: Authentication information: SDDM::Auth::INFO_UNKNOWN "Place your finger on the fingerprint reader"
mei 28 13:21:59 roland-xps (systemd)[3645]: pam_env(systemd-user:session): pam_putenv: delete non-existent entry; SSH_AGENT_PID
mei 28 13:21:59 roland-xps systemd-xdg-autostart-generator[3652]: Configuration file /home/rolandd/.config/autostart/jetbrains-toolbox.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mei 28 13:21:59 roland-xps dbus-broker-launch[3656]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mei 28 13:21:59 roland-xps dbus-broker-launch[3656]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mei 28 13:21:59 roland-xps dbus-broker-launch[3656]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mei 28 13:21:59 roland-xps sddm-helper[3488]: pam_env(sddm:session): pam_putenv: delete non-existent entry; SSH_AGENT_PID
mei 28 13:21:59 roland-xps systemd-xdg-autostart-generator[3709]: Configuration file /home/rolandd/.config/autostart/jetbrains-toolbox.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mei 28 13:21:59 roland-xps kernel: nvme nvme0: using unchecked data buffer
mei 28 13:21:59 roland-xps kernel: block nvme0n1: No UUID available providing old NGUID
mei 28 13:22:00 roland-xps baloo_file[3733]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.104'
mei 28 13:22:00 roland-xps baloo_file[3733]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.106'
mei 28 13:22:00 roland-xps org_kde_powerdevil[3851]: Failed to create wl_display (No such file or directory)
mei 28 13:22:01 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
mei 28 13:22:01 roland-xps plasmashell[3822]: Toolbox not loading, toolbox package is either invalid or disabled.
mei 28 13:22:01 roland-xps org_kde_powerdevil[3851]: org.kde.powerdevil: [DDCutilDetector]: Failed to initialize callback
mei 28 13:22:02 roland-xps wireplumber[3662]: spa.alsa: Path rt715 Capture is not a volume or mute control
mei 28 13:22:02 roland-xps org_kde_powerdevil[3851]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore4\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore5\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore6\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore7\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore8\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"restore9\" - conversion of \"5886,0,1282,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore9\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore10\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"restore11\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore11\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"restore12\" - conversion of \"3968,0,1280,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore12\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"restore13\" - conversion of \"3328,0,2560,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore13\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps kwin_x11[3793]: kf.config.core: "\"fsrestore14\" - conversion of \"0,0,0,0\" to QRect failed"
mei 28 13:22:02 roland-xps systemd[3645]: app-\x2fhome\x2frolandd\x2f.SynologyDrive\x2fSynologyDrive.app\x2fbin\x2fcloud\x2ddrive\x2dui@876620dbf1464cfca35ee6b19a8a1c3e.service: Failed with result 'exit-code'.
mei 28 13:22:02 roland-xps kded6[3792]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
mei 28 13:22:02 roland-xps kded6[3792]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
mei 28 13:22:02 roland-xps kded6[3792]: QDBusObjectPath: invalid path "/modules/wpad-detector"
mei 28 13:22:02 roland-xps kded6[3792]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
mei 28 13:22:02 roland-xps kded6[3792]: QDBusObjectPath: invalid path "/modules/oom-notifier"
mei 28 13:22:02 roland-xps kded6[3792]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
mei 28 13:22:02 roland-xps systemd[3645]: app-java@817ca8095c8049c887f3b04ec91ac52d.service: Failed with result 'exit-code'.
mei 28 13:22:02 roland-xps kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mei 28 13:22:03 roland-xps konsole[4108]: QLayout: Cannot add a null widget to QHBoxLayout/
mei 28 13:22:03 roland-xps systemd-xdg-autostart-generator[4319]: Configuration file /home/rolandd/.config/autostart/jetbrains-toolbox.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mei 28 13:22:03 roland-xps konsole[4088]: QLayout: Cannot add a null widget to QHBoxLayout/
mei 28 13:22:03 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
mei 28 13:22:03 roland-xps systemd[3645]: We couldn't coldplug app-jetbrains\x2dphpstorm\x2d2@2a9e49078ef04c8eb0c20351a4310fac.service, proceeding anyway: No such device or address
mei 28 13:22:03 roland-xps systemd[3645]: We couldn't coldplug app-io.dbeaver.DBeaver@b0bf10f2da164768b249b64e707829f6.service, proceeding anyway: No such device or address
mei 28 13:22:03 roland-xps systemd[3645]: We couldn't coldplug app-chromium@c3989b29ddcc46caab91667d6c7877ef.service, proceeding anyway: No such device or address
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Save All" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&Yes" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Yes to All" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&No" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "No to All" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Abort" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Retry" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps keepassxc[4100]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Ignore" msgid_plural: "" msgctxt: "@action:button"
mei 28 13:22:03 roland-xps kconf_update[4424]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
mei 28 13:22:03 roland-xps kconf_update[4424]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
mei 28 13:22:03 roland-xps kconf_update[4424]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
mei 28 13:22:03 roland-xps kconf_update[4424]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
mei 28 13:22:03 roland-xps kded6[3792]: kf.bluezqt: PendingCall Error: "The name is not activatable"
mei 28 13:22:03 roland-xps marknote[4089]: qrc:/qt/qml/org/kde/marknote/qml/NotesPage.qml:16:1: QML NotesPage: Created graphical object was not placed in the graphics scene.
mei 28 13:22:04 roland-xps marknote[4089]: qrc:/qt/qml/org/kde/marknote/qml/EditPage.qml:15:1: QML EditPage: Created graphical object was not placed in the graphics scene.
mei 28 13:22:04 roland-xps marknote[4089]: qt.qml.list.incompatible: Cannot append QQuickRepeater(0x5e77507cecf0) to a QML list of QQuickAbstractButton*
mei 28 13:22:04 roland-xps marknote[4089]: qt.qml.list.incompatible: Cannot append QQuickRepeater(0x5e77506aa800) to a QML list of QQuickAbstractButton*
mei 28 13:22:04 roland-xps marknote[4089]: qt.qml.list.incompatible: Cannot append QQuickRepeater(0x5e77506a5f80) to a QML list of QQuickAbstractButton*
mei 28 13:22:04 roland-xps kwin_x11[3793]: kwin_scene_opengl: Could not delete framebuffer because no context is current
mei 28 13:22:06 roland-xps systemd[3645]: dbus-:1.1-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
mei 28 13:22:07 roland-xps systemd[3645]: dbus-:1.1-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
mei 28 13:22:07 roland-xps systemd[3645]: dbus-:1.1-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/335e65c7/UpdatesWidget.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps systemd[3645]: dbus-:1.1-org.kde.kwalletd6@3.service: Failed with result 'exit-code'.
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/abe7ae8a/FeedWidget.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/f5cc0f6c/js/CraftAssetImages.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/f5cc0f6c/js/PluginBase.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/f5cc0f6c/js/CraftAssetFiles.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/f5cc0f6c/js/RedactorOverrides.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/f5cc0f6c/js/CraftAssetImageEditor.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/f5cc0f6c/js/CraftElementLinks.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/f5cc0f6c/js/RedactorInput.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:07 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/de.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/hu.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/tr.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/it.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/fa.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/fr.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/en.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/sl.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/ru.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/ro.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/sv.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/hr.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps xdg-desktop-por[3740]: Backend call failed: The name is not activatable
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/he.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/no.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/zh_tw.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/cs.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/fi.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/es.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/ko.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/zh_cn.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/pl.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/sk.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/da.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/ja.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/ar.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/pt_br.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:08 roland-xps baloo_file_extractor[6418]: kf.baloo: "/home/rolandd/dev/sites/backbase.com/server/public_html/cpresources/60c024f5/_langs/nl.min.js" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mei 28 13:22:16 roland-xps java[4608]: Negative content width -12 (allocation 1, extents 6x7) while allocating gadget (node separator, owner GtkSeparatorToolItem)
mei 28 13:22:20 roland-xps kdeconnectd[4000]: 2025-05-28T13:22:20 default: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mei 28 13:22:21 roland-xps kdeconnectd[4000]: 2025-05-28T13:22:21 kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/rolandd/.local/share/kpeoplevcard/kdeconnect-ec61c07c_086c_49a8_a4c5_209deae59efe/1383e7-https---nas..rolandd..com-8443-addressbooks-users-RolandD-addressbook-0e5e457f-50ff-4618-bb52-850048184594..vcf.1383e7-https---nas..rolandd..com-8443-addressbooks-users-RolandD-addressbook-af228737-9bc4-4407-bafe-409c498a0c4e..vcf.1383e7-https---nas..rolandd..com-8443-addressbooks-users-RolandD-addressbook-c484a6bd-8824-4795-99e0-14b20a1f909d..vcf.3789r425-2E2A4C46403A443230324C46463A3C.vcf"
mei 28 13:22:21 roland-xps kdeconnectd[4000]: 2025-05-28T13:22:21 kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/rolandd/.local/share/kpeoplevcard/kdeconnect-ec61c07c_086c_49a8_a4c5_209deae59efe/1383e7-https---nas..rolandd..com-8443-addressbooks-users-RolandD-addressbook-05bd3573-49fb-4162-a345-552aa5926291..vcf.1383e7-https---nas..rolandd..com-8443-addressbooks-users-RolandD-addressbook-adc7d840-1d27-4469-a3d1-82cb1135a6c8..vcf.3789r540-54324C2A3638325C5C3A.vcf"
mei 28 13:22:22 roland-xps java[4608]: Negative content width -8 (allocation 5, extents 6x7) while allocating gadget (node separator, owner GtkSeparatorToolItem)
mei 28 13:22:23 roland-xps java[4608]: Negative content width -8 (allocation 5, extents 6x7) while allocating gadget (node separator, owner GtkSeparatorToolItem)
mei 28 13:22:24 roland-xps java[4608]: Negative content width -8 (allocation 5, extents 6x7) while allocating gadget (node separator, owner GtkSeparatorToolItem)
mei 28 13:24:09 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:24:10 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:24:11 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:24:17 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:24:46 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:26:07 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:26:49 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:29:28 roland-xps baloorunner[11795]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
mei 28 13:29:28 roland-xps baloorunner[11795]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
mei 28 13:29:29 roland-xps kwin_x11[3793]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
mei 28 13:29:29 roland-xps kwin_x11[3793]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
mei 28 13:29:30 roland-xps systemsettings[11810]: qrc:/qt/qml/org/kde/kcmutils/PluginSelector.qml:52:5: QML OverlaySheet: Binding loop detected for property "implicitHeight":
file:///usr/lib/qt6/qml/org/kde/kirigami/templates/OverlaySheet.qml:132:5
mei 28 13:29:30 roland-xps systemsettings[11810]: qrc:/qt/qml/org/kde/kcmutils/PluginSelector.qml:52:5: QML OverlaySheet: Binding loop detected for property "y":
file:///usr/lib/qt6/qml/org/kde/kirigami/templates/OverlaySheet.qml:110:5
mei 28 13:29:30 roland-xps systemsettings[11810]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mei 28 13:29:31 roland-xps systemsettings[11810]: qrc:/qt/qml/org/kde/kcmutils/PluginSelector.qml:52:5: QML OverlaySheet: Binding loop detected for property "implicitHeight":
mei 28 13:29:33 roland-xps systemsettings[11810]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mei 28 13:29:39 roland-xps systemsettings[11810]: qrc:/kcm/kcm_kwinrules/RulesEditor.qml:171:5: QML OverlaySheet: Binding loop detected for property "implicitHeight":
mei 28 13:30:06 roland-xps kwin_x11[3793]: kwin_scene_opengl: Could not delete framebuffer because no context is current
mei 28 13:30:40 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:33:29 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:33:30 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:33:32 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:33:33 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:34:23 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:34:24 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:34:47 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:34:48 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:35:44 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:35:45 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:35:47 roland-xps kwin_x11[3793]: kwin_core: XCB error: 152 (BadDamage), sequence: 52479, resource id: 18934088, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mei 28 13:36:03 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:36:04 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:38:05 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:38:07 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:39:32 roland-xps krunner[11740]: qt.svg: Skipping a nested svg element, because SVG Document must not contain nested svg elements in Svg Tiny 1.2
mei 28 13:39:34 roland-xps krunner[11740]: qt.svg: Skipping a nested svg element, because SVG Document must not contain nested svg elements in Svg Tiny 1.2
mei 28 13:39:46 roland-xps plasmashell[3822]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1509 which doesn't exist, creating a new one. This is an application bug!
mei 28 13:39:46 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:40:34 roland-xps plasmashell[3822]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1510 which doesn't exist, creating a new one. This is an application bug!
mei 28 13:40:34 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:41:46 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:41:50 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:42:17 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:42:18 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:42:26 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:42:35 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:42:36 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:42:41 roland-xps plasmashell[3822]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1511 which doesn't exist, creating a new one. This is an application bug!
mei 28 13:42:49 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:42:50 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:43:46 roland-xps plasmashell[3822]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1512 which doesn't exist, creating a new one. This is an application bug!
mei 28 13:43:46 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:46:22 roland-xps plasmashell[3822]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1513 which doesn't exist, creating a new one. This is an application bug!
mei 28 13:46:23 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 13:48:51 roland-xps kwin_x11[3793]: kwin_core: XCB error: 152 (BadDamage), sequence: 43727, resource id: 19016752, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mei 28 13:49:18 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:49:19 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:49:21 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:49:35 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:49:36 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:49:37 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:49:38 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 13:57:04 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 7193, resource id: 130052698, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 13:57:04 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 7194, resource id: 130052698, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 13:57:04 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 7206, resource id: 130052698, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 13:57:04 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 7207, resource id: 130052698, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 13:58:59 roland-xps krunner[11740]: qt.svg: Skipping a nested svg element, because SVG Document must not contain nested svg elements in Svg Tiny 1.2
mei 28 14:01:46 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 14:03:36 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 14:06:28 roland-xps plasmashell[3822]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mei 28 14:06:29 roland-xps plasmashell[3822]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mei 28 14:07:06 roland-xps plasmashell[3822]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mei 28 14:07:07 roland-xps plasmashell[3822]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mei 28 14:07:08 roland-xps plasmashell[3822]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mei 28 14:07:09 roland-xps plasmashell[3822]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mei 28 14:07:10 roland-xps plasmashell[3822]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mei 28 14:07:13 roland-xps krunner[11740]: qt.svg: Skipping a nested svg element, because SVG Document must not contain nested svg elements in Svg Tiny 1.2
mei 28 14:07:14 roland-xps baloorunner[11795]: QFSFileEngine::open: No file name specified
mei 28 14:07:16 roland-xps baloorunner[11795]: kf.notifications: Playing audio notification failed: Destroyed
mei 28 14:07:17 roland-xps baloorunner[20373]: QFSFileEngine::open: No file name specified
mei 28 14:07:19 roland-xps baloorunner[20373]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
mei 28 14:07:19 roland-xps baloorunner[20373]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
mei 28 14:08:16 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:08:18 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:08:45 roland-xps kate[20382]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///home/rolandd/Downloads/.forumpost.md.kate-swp")
mei 28 14:10:23 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 1880, resource id: 130064671, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:10:23 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 1881, resource id: 130064671, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:10:23 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 1893, resource id: 130064671, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:10:23 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 1894, resource id: 130064671, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:20:47 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 14:23:41 roland-xps kate[20382]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///home/rolandd/dev/sites/backbase.com/client/public/.sitemap-0.xml.kate-swp")
mei 28 14:42:14 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:42:16 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:42:21 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:43:54 roland-xps kwin_x11[3793]: kwin_core: XCB error: 152 (BadDamage), sequence: 9860, resource id: 19409483, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mei 28 14:45:44 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 25075, resource id: 130092961, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:45:44 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 25076, resource id: 130092961, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:45:44 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 25088, resource id: 130092961, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:45:44 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 25089, resource id: 130092961, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 14:47:03 roland-xps systemd[3645]: dbus-:1.1-org.kde.kwalletd6@4.service: Failed with result 'exit-code'.
mei 28 14:47:03 roland-xps systemd[3645]: dbus-:1.1-org.kde.kwalletd6@5.service: Failed with result 'exit-code'.
mei 28 14:47:21 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 14:48:14 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 14:54:20 roland-xps plasmashell[3822]: org.kde.plasma.notificationmanager: Trying to replace notification with id 1514 which doesn't exist, creating a new one. This is an application bug!
mei 28 14:54:20 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
mei 28 14:54:20 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:54:24 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:54:48 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:55:01 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:55:05 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:55:07 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:55:20 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 14:55:21 roland-xps kglobalacceld[3728]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mei 28 15:00:06 roland-xps krunner[11740]: qrc:/krunner/RunCommand.qml:314: TypeError: Cannot read property 'pinned' of null
mei 28 15:00:06 roland-xps krunner[11740]: qrc:/krunner/RunCommand.qml:300: TypeError: Cannot read property 'helpEnabled' of null
mei 28 15:00:06 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
mei 28 15:00:06 roland-xps plasma-systemmonitor[4143]: QProcess: Destroyed while process ("/usr/lib/ksysguard/ksgrd_network_helper") is still running.
mei 28 15:00:06 roland-xps plasma-systemmonitor[4143]: org.kde.ksysguard.plugin.network: Helper process terminated abnormally: ""
mei 28 15:00:06 roland-xps plasmashell[3822]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
mei 28 15:00:07 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 55857, resource id: 6291536, major code: 129 (SHAPE), minor code: 5 (Extents)
mei 28 15:00:07 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 55861, resource id: 6291536, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 15:00:07 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 55862, resource id: 6291536, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 15:00:07 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 55877, resource id: 6291536, major code: 129 (SHAPE), minor code: 5 (Extents)
mei 28 15:00:07 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 55881, resource id: 6291536, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 15:00:07 roland-xps kwin_x11[3793]: kwin_core: XCB error: 3 (BadWindow), sequence: 55882, resource id: 6291536, major code: 129 (SHAPE), minor code: 3 (Combine)
mei 28 15:00:11 roland-xps sddm-helper[3488]: Signal received: SIGTERM
mei 28 15:00:11 roland-xps sddm[1038]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
mei 28 15:00:11 roland-xps sddm[1038]: Auth: sddm-helper (--socket /tmp/sddm-auth-697765cf-d651-4b8c-aca9-3955c3d4cff4 --id 1 --start /usr/bin/startplasma-x11 --user rolandd) crashed (exit code 1)
mei 28 15:00:11 roland-xps sddm[1038]: Auth: sddm-helper exited with 1
mei 28 15:00:11 roland-xps sddm[1038]: Signal received: SIGTERM
mei 28 15:00:11 roland-xps kwin_x11[3793]: The X11 connection broke: I/O error (code 1)
mei 28 15:00:11 roland-xps kactivitymanagerd[3847]: The X11 connection broke (error 1). Did the X11 server die?
mei 28 15:00:11 roland-xps kded6[3792]: The X11 connection broke: I/O error (code 1)
mei 28 15:00:11 roland-xps systemd[3645]: dbus-:1.68-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
mei 28 15:00:11 roland-xps kernel: BUG: unable to handle page fault for address: ffff8f1149d5c018
mei 28 15:00:11 roland-xps kernel: #PF: supervisor write access in kernel mode
mei 28 15:00:11 roland-xps kernel: #PF: error_code(0x0002) - not-present page
mei 28 15:00:11 roland-xps kernel: Oops: Oops: 0002 [#1] SMP NOPTI
mei 28 15:00:11 roland-xps kernel: CPU: 8 UID: 0 PID: 20853 Comm: kworker/8:0 Tainted: G U 6.15.0-rc6-1-MANJARO #1 PREEMPT(full) 511456f7723a3dc18518c68eb3af702006efd5b0
mei 28 15:00:11 roland-xps kernel: Tainted: [U]=USER
mei 28 15:00:11 roland-xps kernel: Hardware name: Dell Inc. XPS 17 9700/03CPGC, BIOS 1.35.0 03/28/2025
mei 28 15:00:11 roland-xps kernel: Workqueue: events hidinput_led_worker
mei 28 15:00:11 roland-xps kernel: RIP: 0010:__srcu_read_unlock+0x1a/0x30
mei 28 15:00:11 roland-xps kernel: Code: 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 0f 1f 44 00 00 f0 83 44 24 fc 00 48 63 f6 48 c1 e6 04 48 03 77 08 <65> 48 ff 46 08 c3 cc cc cc cc 66 66 2e 0f 1f 84 00 00 00 00 00 90
mei 28 15:00:11 roland-xps kernel: RSP: 0018:ffffd50fc4ccfd78 EFLAGS: 00010202
mei 28 15:00:11 roland-xps kernel: RAX: 0000000000000000 RBX: ffff8f018555be08 RCX: 0000000000000000
mei 28 15:00:11 roland-xps kernel: RDX: 0000000000000002 RSI: 0000000000000010 RDI: ffff8f018555be38
mei 28 15:00:11 roland-xps kernel: RBP: ffffd50fc4ccfdf0 R08: 0000000000000000 R09: 00000000fffffffd
mei 28 15:00:11 roland-xps kernel: R10: ffff8f01e51e6710 R11: ffff8f0238d4b000 R12: 0000000000000000
mei 28 15:00:11 roland-xps kernel: R13: ffff8f018555be38 R14: 0000000000000001 R15: ffff8f018555b898
mei 28 15:00:11 roland-xps kernel: FS: 0000000000000000(0000) GS:ffff8f1149d5c000(0000) knlGS:0000000000000000
mei 28 15:00:11 roland-xps kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
mei 28 15:00:11 roland-xps kernel: CR2: ffff8f1149d5c018 CR3: 00000001079cf003 CR4: 00000000007706f0
mei 28 15:00:11 roland-xps kernel: PKRU: 55555554
mei 28 15:00:11 roland-xps kernel: Call Trace:
mei 28 15:00:11 roland-xps kernel: <TASK>
mei 28 15:00:11 roland-xps kernel: dispatch_hid_bpf_output_report+0xbb/0xf0
mei 28 15:00:11 roland-xps kernel: ? psi_task_switch+0xfb/0x200
mei 28 15:00:11 roland-xps kernel: ? hid_output_report+0xd6/0x150
mei 28 15:00:11 roland-xps kernel: hid_hw_output_report+0x4f/0xa0
mei 28 15:00:11 roland-xps kernel: hidinput_led_worker+0xbe/0x100
mei 28 15:00:11 roland-xps kernel: process_one_work+0x190/0x350
mei 28 15:00:11 roland-xps kernel: worker_thread+0x2d7/0x410
mei 28 15:00:11 roland-xps kernel: ? __pfx_worker_thread+0x10/0x10
mei 28 15:00:11 roland-xps kernel: kthread+0xf9/0x240
mei 28 15:00:11 roland-xps kernel: ? __pfx_kthread+0x10/0x10
mei 28 15:00:11 roland-xps kernel: ret_from_fork+0x31/0x50
mei 28 15:00:11 roland-xps kernel: ret_from_fork_asm+0x1a/0x30
mei 28 15:00:11 roland-xps kernel: </TASK>
mei 28 15:00:11 roland-xps kernel: Modules linked in: udp_diag tcp_diag inet_diag rfcomm snd_seq_dummy snd_hrtimer snd_seq ccm michael_mic hid_magicmouse apple_mfi_fastcharge r8153_ecm cdc_ether usbnet r8152 mii libphy snd_usb_audio snd_usbmidi_lib snd_ump snd_rawmidi snd_seq_device usbhid iptable_raw nf_conntrack_netlink veth bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set xfrm_user xfrm_algo uhid cmac algif_hash algif_skcipher af_alg overlay squashfs qrtr_mhi xt_conntrack iptable_filter xt_nat xt_tcpudp xt_MASQUERADE snd_ctl_led xt_addrtype bnep snd_soc_sof_sdw snd_soc_intel_hda_dsp_common iptable_nat snd_soc_sdw_utils snd_sof_probes nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 snd_soc_rt711 snd_soc_rt1308_sdw snd_soc_rt715 regmap_sdw hid_sensor_als snd_soc_dmic hid_sensor_trigger industrialio_triggered_buffer kfifo_buf snd_sof_pci_intel_cnl hid_sensor_iio_common vfat industrialio hid_sensor_custom snd_sof_intel_hda_generic fat soundwire_intel snd_sof_intel_hda_sdw_bpt hid_sensor_hub snd_sof_intel_hda_common
mei 28 15:00:11 roland-xps kernel: intel_ishtp_hid snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda snd_hda_codec_hdmi soundwire_cadence snd_sof_pci intel_uncore_frequency snd_sof_xtensa_dsp intel_uncore_frequency_common snd_sof snd_sof_utils snd_soc_acpi_intel_match snd_soc_acpi_intel_sdca_quirks soundwire_generic_allocation snd_soc_acpi intel_tcc_cooling soundwire_bus x86_pkg_temp_thermal intel_powerclamp snd_soc_sdca coretemp crc8 snd_soc_avs kvm_intel qrtr snd_soc_hda_codec snd_hda_ext_core ath11k_pci kvm snd_soc_core ath11k snd_compress irqbypass ac97_bus polyval_clmulni snd_pcm_dmaengine qmi_helpers joydev dell_pc polyval_generic mousedev platform_profile snd_hda_intel ghash_clmulni_intel uvcvideo sha512_ssse3 snd_intel_dspcfg sha256_ssse3 snd_intel_sdw_acpi videobuf2_vmalloc mac80211 sha1_ssse3 uvc snd_hda_codec processor_thermal_device_pci_legacy hci_uart aesni_intel videobuf2_memops hid_multitouch processor_thermal_device crypto_simd videobuf2_v4l2 btqca snd_hda_core iTCO_wdt processor_thermal_wt_hint hid_generic
mei 28 15:00:11 roland-xps kernel: dell_laptop intel_pmc_bxt cryptd pwrseq_core videobuf2_common 8250_dw ee1004 processor_thermal_rfim snd_hwdep iTCO_vendor_support btrtl dell_wmi rapl mei_wdt mei_hdcp videodev snd_pcm mei_pxp btintel dell_smbios intel_cstate ucsi_acpi libarc4 processor_thermal_rapl i2c_i801 intel_rapl_msr dcdbas intel_uncore snd_timer mc cfg80211 dell_wmi_sysman psmouse intel_rapl_common btbcm pcspkr spi_nor dell_wmi_ddv dell_smm_hwmon thunderbolt firmware_attributes_class dell_wmi_descriptor intel_wmi_thunderbolt wmi_bmof snd processor_thermal_wt_req i2c_smbus mei_me typec_ucsi mtd bluetooth mhi intel_lpss_pci soundcore processor_thermal_power_floor i2c_mux intel_ish_ipc typec i2c_nvidia_gpu i2c_hid_acpi processor_thermal_mbox intel_lpss mei intel_ishtp idma64 intel_pch_thermal roles intel_soc_dts_iosf rfkill i2c_hid intel_pmc_core int3403_thermal int340x_thermal_zone pmt_telemetry pmt_class pinctrl_cannonlake int3400_thermal intel_hid intel_vsec sparse_keymap acpi_thermal_rel acpi_pad acpi_tad mac_hid uinput i2c_dev sg
mei 28 15:00:11 roland-xps kernel: crypto_user loop dm_mod nfnetlink ip_tables x_tables rtsx_pci_sdmmc mmc_core nvme serio_raw nvme_core atkbd libps2 nvme_keyring spi_intel_pci spi_intel rtsx_pci vivaldi_fmap nvme_auth i8042 serio i915 i2c_algo_bit drm_buddy video wmi ttm intel_gtt drm_display_helper cec
mei 28 15:00:11 roland-xps kernel: ---[ end trace 0000000000000000 ]---
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 12 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 11 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 10 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 9 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 8 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 7 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 2 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 1 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps kwin_x11[3793]: QThreadStorage: entry 0 destroyed before end of thread 0x6489c6b4ae70
mei 28 15:00:11 roland-xps systemd[3645]: plasma-kded6.service: Failed with result 'exit-code'.
mei 28 15:00:11 roland-xps systemd[3645]: ssh-agent.service: Failed with result 'exit-code'.
mei 28 15:00:11 roland-xps systemd[3645]: plasma-kwin_x11.service: Failed with result 'exit-code'.
mei 28 15:00:11 roland-xps dbus-broker-launch[3656]: Activation request for 'org.freedesktop.portal.Documents' failed.
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a1124056d0 id:8
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a112393080 id:9
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a11229a4c0 id:10
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a1122816f0 id:11
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a11222c130 id:12
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a112220db0 id:13
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a1121c87b0 id:14
mei 28 15:00:11 roland-xps wireplumber[3662]: pw.core: 0x58a112281570: leaked proxy 0x58a112334660 id:15
mei 28 15:00:16 roland-xps systemd[3645]: app-syncthing\x2dstart@autostart.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:00:16 roland-xps systemd[3645]: app-ferdium@autostart.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:00:16 roland-xps systemd[3645]: app-jetbrains\x2dtoolbox@autostart.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:00:16 roland-xps systemd[3645]: app-syncthing\x2dstart@autostart.service: Main process exited, code=killed, status=9/KILL
mei 28 15:00:21 roland-xps dbus-broker-launch[841]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
mei 28 15:00:21 roland-xps systemd[3645]: app-syncthing\x2dstart@autostart.service: Processes still around after SIGKILL. Ignoring.
mei 28 15:00:21 roland-xps systemd[3645]: app-jetbrains\x2dtoolbox@autostart.service: Processes still around after SIGKILL. Ignoring.
mei 28 15:00:21 roland-xps systemd[3645]: app-ferdium@autostart.service: Processes still around after SIGKILL. Ignoring.
mei 28 15:00:26 roland-xps systemd[3645]: app-syncthing\x2dstart@autostart.service: Processes still around after final SIGKILL. Entering failed mode.
mei 28 15:00:26 roland-xps systemd[3645]: app-syncthing\x2dstart@autostart.service: Failed with result 'timeout'.
mei 28 15:00:26 roland-xps systemd[3645]: app-ferdium@autostart.service: State 'final-sigterm' timed out. Killing.
mei 28 15:00:26 roland-xps systemd[3645]: app-jetbrains\x2dtoolbox@autostart.service: Processes still around after final SIGKILL. Entering failed mode.
mei 28 15:00:26 roland-xps systemd[3645]: app-jetbrains\x2dtoolbox@autostart.service: Failed with result 'timeout'.
mei 28 15:00:32 roland-xps systemd[3645]: app-ferdium@autostart.service: Processes still around after final SIGKILL. Entering failed mode.
mei 28 15:00:32 roland-xps systemd[3645]: app-ferdium@autostart.service: Failed with result 'timeout'.
mei 28 15:01:03 roland-xps dbus-broker-launch[841]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
mei 28 15:01:41 roland-xps systemd[3645]: appimagelauncherd.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:41 roland-xps systemd[1]: bluetooth.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:41 roland-xps systemd[3645]: wireplumber.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:41 roland-xps systemd[1]: polkit.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:41 roland-xps systemd[3645]: app-org.chromium.Chromium-4256.scope: Still around after SIGKILL. Ignoring.
mei 28 15:01:41 roland-xps systemd[3645]: app-org.chromium.Chromium-4256.scope: Failed with result 'timeout'.
mei 28 15:01:41 roland-xps systemd[3645]: app-io.dbeaver.DBeaver@b0bf10f2da164768b249b64e707829f6.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:41 roland-xps systemd[3645]: app-jetbrains\x2dphpstorm\x2dd5b73404\x2d6eea\x2d439c\x2db11e\x2d7d5dc896d918@b480c5e46f8943f7b919d0347ec0ba05.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:41 roland-xps systemd[3645]: app-jetbrains\x2dphpstorm\x2d2@2a9e49078ef04c8eb0c20351a4310fac.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:41 roland-xps systemd[3645]: app-chromium@c3989b29ddcc46caab91667d6c7877ef.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:48 roland-xps systemd[1]: containerd.service: State 'stop-sigterm' timed out. Killing.
mei 28 15:01:59 roland-xps dbus-broker-launch[841]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
mei 28 15:02:11 roland-xps systemd[1]: user@1000.service: State 'stop-sigterm' timed out. Killing.
sudo inxi -Fazy
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=61563fba-524b-4fad-8d9e-d8b4c4bfde08 rw quiet apparmor=1
security=apparmor udev.log_priority=3 nvidia_drm.modeset=0
i915.enable_guc=2
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: Dell product: XPS 17 9700 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 03CPGC v: A00 serial: <filter> part-nu: 098F
uuid: 4c4c4544-0042-5710-8058-b9c04f593933 UEFI: Dell v: 1.35.0
date: 03/28/2025
ID-1: BAT0 charge: 82.9 Wh (92.7%) condition: 89.4/95.1 Wh (94.0%)
volts: 12.8 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly serial: <filter>
status: charging
Device-1: hid-CC2718400M9GTFQAU-battery model: Apple Inc. Magic Trackpad 2
serial: N/A charge: N/A status: discharging
Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0x100
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3704 min/max: 800/5300 base/boost: 2673/2400 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 3704 2: 3704 3: 3704 4: 3704 5: 3704 6: 3704 7: 3704 8: 3704
9: 3704 10: 3704 11: 3704 12: 3704 13: 3704 14: 3704 15: 3704 16: 3704
bogomips: 76816
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-6,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Max-Q] vendor: Dell
driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f12 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:5510
Device-4: Chicony USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1.4:8 chip-ID: 04f2:b612
Display: unspecified server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 7168x1440 s-dpi: 96 s-size: 1896x381mm (74.65x15.00")
s-diag: 1934mm (76.14")
Monitor-1: DP-6 mapped: DP-2-3 pos: primary,right model: Philips PHL 499P9
serial: <filter> built: 2020 res: N/A dpi: 82 gamma: 1.2
size: 1190x340mm (46.85x13.39") diag: 1239mm (48.8") modes: max: 3840x1080
min: 720x400
Monitor-2: eDP-1 pos: left model: Sharp 0x14d6 built: 2020 res:
mode: 2048x1152 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
size: 366x229mm (14.41x9.02") diag: 432mm (17") ratio: 16:10
modes: 3840x2400
drv: nvidia device: 1 drv: iris device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 30.54 GiB unified: yes
API: Vulkan v: 1.4.313 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2060 with Max-Q Design driver: nvidia v: 570.144
device-ID: 10de:1f12 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1.3:5 chip-ID: 0bda:48a5
class-ID: 0102 serial: <filter>
Device-3: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3.4:9 chip-ID: 0bda:402e
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.2 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Qualcomm QCA6390 Wireless Network Adapter vendor: Rivet Networks
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 04:00.0 chip-ID: 17cb:1101 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1.1.2:13
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: eth0 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.4:4
IF: enp168s0u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-2f060f5dee69 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-6e2fd4565d9b state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-a8c497a8bfde state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-b4afaac49989 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-b763061753ff state: down mac: <filter>
IF-ID-6: br-c4d2a30d5970 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-7: br-e053a10c4585 state: down mac: <filter>
IF-ID-8: br-ec969a4fbcaa state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-9: docker0 state: down mac: <filter>
IF-ID-10: veth055c9cf state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth103d6d1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth30c38ba state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: veth3433b80 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: veth5fa461d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: veth6b7ed90 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: veth89eb6c7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: veth941f995 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: veth9d1e4cf state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: vetha0c3fb1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-20: vethd5a7f69 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-21: vethe3a7861 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-22: vetheced56f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-23: vethee2bb24 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-24: vethfc7ce16 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: apache2, NetworkManager, smbd, systemd-timesyncd,
wpa_supplicant
Local Storage: total: 1.86 TiB used: 1.18 TiB (63.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KXG60PNV2T04 NVMe
2048GB size: 1.86 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 10704104
temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 255d 5h cycles: 3,793
read-units: 233,167,814 [119 TB] written-units: 456,074,911 [233 TB]
ID-1: / raw-size: 1.43 TiB size: 1.41 TiB (98.36%) used: 1.18 TiB (83.5%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 150 MiB size: 146 MiB (97.33%)
used: 97 MiB (66.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
System Temperatures: cpu: 63.0 C pch: 62.0 C mobo: 49.0 C sodimm: 48.0 C
Fan Speeds (rpm): cpu: 2179 fan-1: 2180 fan-2: 2171
Memory: total: 64 GiB available: 62.55 GiB used: 16.86 GiB (27.0%)
igpu: 64 MiB
Processes: 492 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 24.99 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1797 libs: 483 tools: pamac pm: appimage pkgs: 0
pm: flatpak pkgs: 0 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Sudo (sudo)
v: 1.9.16p2 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
mwhd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2025.01.13 false PCI
glxinfo | grep 'renderer string'
OpenGL renderer string: Mesa Intel(R) UHD Graphics (CML GT2)
prime-run glxinfo | grep 'renderer string'
OpenGL renderer string: NVIDIA GeForce RTX 2060 with Max-Q Design/PCIe/SSE2
The image of when the system hangs.
