Hello!
I’ve been using manjaro for some time now, and recently the whole system
would permanently freeze on seemingly random intervals, unfortunately one such freeze happened few weeks back while updating the system so I had to rescue it with a live-iso. Because it left nvidia installation in a weird state I’ve ultimately decided to do a full system reinstallation.
Unfortunately the issue persists even on newly installed system.
It happens at random whenever a program is run with prime-run, so I strongly suspect that it has something to do with nvidia drivers.
Here are results from inxi -Fazy -c0
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=b1f5dd4b-59b0-4ca7-a3cd-e76d4b19d6ad rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 82WQ v: Legion Pro 7 16IRX8H
serial: <superuser required> Chassis: type: 10 v: Legion Pro 7 16IRX8H
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> part-nu: LENOVO_MT_82WQ_BU_idea_FM_Legion Pro 7
16IRX8H uuid: <superuser required> UEFI: LENOVO v: KWCN31WW
date: 02/09/2023
ID-1: BAT0 charge: 103.9 Wh (100.0%) condition: 103.9/99.9 Wh (104.0%)
volts: 16.9 min: 15.5 model: SMP L22M4PC1 type: Li-poly serial: <filter>
status: full cycles: 3
Info: model: 13th Gen Intel Core i9-13900HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x123
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 836 high: 1144 min/max: 800/5200:5400:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 923 2: 800 3: 872 4: 800
5: 910 6: 800 7: 798 8: 800 9: 1083 10: 800 11: 800 12: 800 13: 1047
14: 800 15: 800 16: 800 17: 800 18: 1144 19: 800 20: 800 21: 800 22: 800
23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
32: 800 bogomips: 154880
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD104M [GeForce RTX 4080 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:27e0
class-ID: 0300
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5 chip-ID: 04f2:b7b6
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 4480x1600 s-dpi: 96 s-size: 1184x423mm (46.61x16.65")
s-diag: 1257mm (49.5")
Monitor-1: HDMI-1-0 pos: primary,bottom-l res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: eDP-1 pos: top-right res: 2560x1600 hz: 240 dpi: 188
size: 345x215mm (13.58x8.46") diag: 407mm (16") modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.8-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a788 memory: 61.08 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4080 Laptop GPU driver: nvidia v: 550.78 device-ID: 10de:27e0
surfaces: xcb,xlib
Device-1: Intel Raptor Lake High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bc
class-ID: 0403
Device-3: GN Netcom Jabra Evolve2 30 SE driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:6
chip-ID: 0b0e:0e37 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 4000 bus-ID: 76:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp118s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager,wpa_supplicant
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 2.75 TiB used: 126.5 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CL1QGXA7 temp: 52.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 126.49 GiB (13.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:3
used: 8.3 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 64 GiB note: est. available: 62.54 GiB used: 4.92 GiB (7.9%)
Processes: 449 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1285 pm: pacman pkgs: 1278 libs: 350 tools: pamac pm: flatpak
pkgs: 7 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
And here are the results from journalctl --priority=err --no-pager
cze 04 13:50:40 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 13:50:41 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 13:50:42 kayak-82wq kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 83.e8f84e98.0 so-a0-gf-a0-83.ucode
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00A002F0 | trm_hw_status0
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x004DB338 | branchlink2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x004D119A | interruptlink1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x004D119A | interruptlink2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x0001551C | data1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000010 | data2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x003D29A4 | beacon time
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00040DE4 | tsf low
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00055C16 | time gp2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000053 | uCode version major
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0xE8F84E98 | uCode version minor
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000430 | hw version
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00C80002 | board version
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x0000001C | hcmd
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00020000 | isr0
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x48F00002 | isr2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00C3000C | isr3
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x001C0103 | last cmd Id
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x0001551C | wait_event
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00002048 | flow_handler
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x2010190E | ADVANCED_SYSASSERT
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x80471ABC | umac branchlink2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0xC0081500 | umac interruptlink1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x0102171C | umac data1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data2
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000053 | umac major
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0xE8F84E98 | umac minor
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00055C11 | frame pointer
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0xC0886BE0 | stack pointer
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x0024010D | last host cmd
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00008599 | IML/ROM data1
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: Fseq Registers:
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x003D0003 | FSEQ_TOP_INIT_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00190003 | FSEQ_CNVIO_INIT_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x0000A652 | FSEQ_OTP_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00080401 | FSEQ_CNVI_ID
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00400410 | FSEQ_CNVR_ID
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00080401 | CNVI_AUX_MISC_CHIP
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00400410 | CNVR_AUX_MISC_CHIP
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x00190003 | FSEQ_PREV_CNVIO_INIT_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x003D0003 | FSEQ_WIFI_FSEQ_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x003D0003 | FSEQ_BT_FSEQ_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: 0x000000C8 | FSEQ_CLASS_TP_VERSION
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x80493890
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
cze 04 13:50:42 kayak-82wq bluetoothd[781]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
cze 04 13:50:42 kayak-82wq bluetoothd[781]: Failed to clear UUIDs: Failed (0x03)
cze 04 13:50:42 kayak-82wq bluetoothd[781]: Failed to add UUID: Failed (0x03)
cze 04 13:50:42 kayak-82wq bluetoothd[781]: Failed to set mode: Failed (0x03)
cze 04 13:50:42 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 13:50:47 kayak-82wq systemd-backlight[909]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 13:50:47 kayak-82wq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
cze 04 13:50:47 kayak-82wq systemd-backlight[911]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 13:50:47 kayak-82wq systemd-backlight[913]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 13:50:47 kayak-82wq systemd-backlight[915]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 13:50:47 kayak-82wq systemd-backlight[918]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:02:43 kayak-82wq (sd-worker)[6619]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6621]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6622]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6623]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6624]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6626]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6625]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6627]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6628]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6629]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6630]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6631]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6632]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6633]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6634]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6635]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6636]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6637]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6638]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6639]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6640]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6641]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6642]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6643]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6644]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6645]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6646]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6647]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6648]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6649]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6650]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6651]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6652]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6653]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6654]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6655]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6656]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6658]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6657]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6659]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6660]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6661]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6662]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6663]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6664]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6665]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6666]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6667]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6668]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6669]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6670]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6671]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6672]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6673]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6674]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6675]: Failed start worker process: No such file or directory
cze 04 14:02:43 kayak-82wq (sd-worker)[6676]: Failed start worker process: No such file or directory
cze 04 14:02:51 kayak-82wq plasmashell[1077]: "applications.menu" not found in ("/etc/xdg/menus")
cze 04 14:03:00 kayak-82wq systemd-backlight[7998]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:03:00 kayak-82wq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
cze 04 14:03:00 kayak-82wq systemd-backlight[8076]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:03:00 kayak-82wq systemd-backlight[8089]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:03:00 kayak-82wq systemd-backlight[8092]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:03:00 kayak-82wq systemd-backlight[8094]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:03:03 kayak-82wq kded5[1034]: "applications.menu" not found in ("/etc/xdg/menus")
cze 04 14:03:30 kayak-82wq kded5[1034]: "applications.menu" not found in ("/etc/xdg/menus")
cze 04 14:03:41 kayak-82wq systemd-coredump[23521]: [🡕] Process 1035 (kwin_x11) of user 1000 dumped core.
Stack trace of thread 1035:
#0 0x00007fd6c25bd32c n/a (/usr/lib/libc.so.6 (deleted) + 0x9132c)
cze 04 14:03:49 kayak-82wq dbus-broker-launch[777]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot 5ac5d586793c4def8939fdf55671e3ad --
cze 04 14:04:21 kayak-82wq kernel:
cze 04 14:04:22 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 14:04:23 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 14:04:23 kayak-82wq kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
cze 04 14:04:28 kayak-82wq systemd-backlight[985]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:04:28 kayak-82wq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
cze 04 14:04:28 kayak-82wq systemd-backlight[987]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:04:28 kayak-82wq systemd-backlight[989]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:04:28 kayak-82wq systemd-backlight[991]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:04:28 kayak-82wq systemd-backlight[993]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:35:41 kayak-82wq ark[24407]: kf.xmlgui: Shortcut for action "close" "" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
cze 04 14:48:29 kayak-82wq systemd-backlight[26970]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:48:29 kayak-82wq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
cze 04 14:48:29 kayak-82wq systemd-backlight[27066]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:48:29 kayak-82wq systemd-backlight[27091]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:48:29 kayak-82wq systemd-backlight[27095]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:48:29 kayak-82wq systemd-backlight[27105]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
-- Boot 05b46f9f8c254eb3be7e0fa7fa7137a8 --
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53609431
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=982, block=214433808) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 3555033
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=7896, block=14155793) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53609207
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=758, block=214433808) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 3555031
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=7894, block=14155793) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53669856
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=4063, block=214433815) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 3034466
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=3425, block=12058642) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53672170
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=6377, block=214433815) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53608664
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=215, block=214433808) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53656313
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=6904, block=214433813) = 0
cze 04 14:57:00 kayak-82wq kernel: EXT4-fs error (device nvme1n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53609278
cze 04 14:57:00 kayak-82wq kernel: ext4_test_bit(bit=829, block=214433808) = 0
cze 04 14:57:01 kayak-82wq kernel:
cze 04 14:57:01 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 14:57:02 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 14:57:03 kayak-82wq kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
cze 04 14:57:03 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 14:57:07 kayak-82wq systemd-backlight[1067]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:57:07 kayak-82wq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
cze 04 14:57:07 kayak-82wq systemd-backlight[1070]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:57:07 kayak-82wq systemd-backlight[1072]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:57:07 kayak-82wq systemd-backlight[1074]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 14:57:07 kayak-82wq systemd-backlight[1076]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 16:16:29 kayak-82wq bluetoothd[942]: Failed to remove UUID: Failed (0x03)
cze 04 16:16:29 kayak-82wq kernel: Bluetooth: hci0: Opcode 0x0c24 failed: -112
cze 04 16:29:24 kayak-82wq kernel: Bluetooth: hci0: unexpected event for opcode 0x0c24
cze 04 16:29:24 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 16:29:24 kayak-82wq kernel: BUG: kernel NULL pointer dereference, address: 0000000000000022
cze 04 16:29:24 kayak-82wq kernel: #PF: supervisor read access in kernel mode
cze 04 16:29:24 kayak-82wq kernel: #PF: error_code(0x0000) - not-present page
cze 04 17:19:17 kayak-82wq kernel: ==================================================================
cze 04 17:19:17 kayak-82wq kernel: BUG: KFENCE: memory corruption in acpi_os_release_object+0xe/0x20
cze 04 17:19:17 kayak-82wq kernel: Corrupted memory at 0x0000000028d6ed4e [ ! ! ! ! ! ! ! ! . . . . . . . . ] (in kfence-#4):
cze 04 17:19:17 kayak-82wq kernel: CPU: 0 PID: 17980 Comm: kworker/0:1 Tainted: P D OE 6.6.32-1-MANJARO #1 6999a884a429ad5a3f5887eda4aeb7a5975a620e
cze 04 17:19:17 kayak-82wq kernel: Hardware name: LENOVO 82WQ/LNVNB161216, BIOS KWCN31WW 02/09/2023
cze 04 17:19:17 kayak-82wq kernel: Workqueue: kacpi_notify acpi_os_execute_deferred
-- Boot edda2ffc3e914c0b93014df87d25cb69 --
cze 04 17:48:12 kayak-82wq kernel:
cze 04 17:48:13 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 17:48:14 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 17:48:14 kayak-82wq kernel: Bluetooth: hci0: Failed to send firmware data (-38)
cze 04 17:48:14 kayak-82wq kernel: Bluetooth: hci0: sending frame failed (-19)
cze 04 17:48:14 kayak-82wq kernel: Bluetooth: hci0: Reading supported features failed (-19)
cze 04 17:48:14 kayak-82wq kernel: Bluetooth: hci0: Failed to read MSFT supported features (-19)
cze 04 17:48:15 kayak-82wq kernel: usb 1-14: device descriptor read/64, error -71
cze 04 17:48:16 kayak-82wq kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
cze 04 17:48:19 kayak-82wq systemd-backlight[1050]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:48:19 kayak-82wq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
cze 04 17:48:19 kayak-82wq systemd-backlight[1052]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:48:19 kayak-82wq systemd-backlight[1054]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:48:19 kayak-82wq systemd-backlight[1056]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:48:19 kayak-82wq systemd-backlight[1058]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
-- Boot 1e25466167d34aab93cec36874bddcfd --
cze 04 17:56:58 kayak-82wq kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 54403299
cze 04 17:56:58 kayak-82wq kernel: ext4_test_bit(bit=226, block=217579537) = 0
cze 04 17:56:58 kayak-82wq kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 53608875
cze 04 17:56:58 kayak-82wq kernel: ext4_test_bit(bit=426, block=214433808) = 0
cze 04 17:56:59 kayak-82wq kernel:
cze 04 17:56:59 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 17:57:00 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 17:57:01 kayak-82wq kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
cze 04 17:57:01 kayak-82wq kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
cze 04 17:57:05 kayak-82wq systemd-backlight[1053]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:57:05 kayak-82wq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
cze 04 17:57:05 kayak-82wq systemd-backlight[1055]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:57:05 kayak-82wq systemd-backlight[1057]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:57:05 kayak-82wq systemd-backlight[1059]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
cze 04 17:57:05 kayak-82wq systemd-backlight[1061]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
EDIT:
I’ve just noticed that every other time the laptop screen is not quite frozen,
and after using xrandr(kde is unresponsive) to change something that refreshes the screen, like --right-of the system unfreezes. I am not sure when there is a total freeze and when there is a partial one though.
