System (versatilely) bricked - after recovery of failed system update
Hey there. Once again I bricked my system and could need some help. I feel I stacked up some failures so I thought to acquire some help before extending this combo. May you be able to deliver the combo breaker!
So my initial problem occurred when I tried to do a normal system update via pamac update.
Since I had these conflicts between openJDK and openJRE I tried to resolve these and continue with the update. I don’t exactly remember what I did to resolve the conflict. Stuff I found in this forum. I don’t think this is of interest for now but I’m sure if it is you will let me know. However, somehow I managed that the update would proceed. But the next time I took a look at my computer it was off and restarting showed the typical ‘/boot/vmlinuz-X’ not found message so I started into my manjaro live distro and proceeded with these instructions. I run the following commands
[ -f /var/lib/pacman/db.lck ] && rm -f /var/lib/pacman/db.lck
pacman-mirrors -f && pacman -Syyu
update-grub
exit
and except that update-grub command couldn’t be found everything seemed fine. I restarted into my system but the kernel still wasnt able to load. I was able to select another kernel tho and start into the system. I run an pacman -Syu and restarted. This time i wasn’t able to start into any of the kernels anymore but therefore received this little present:
Inode 18482639, i_blocks is 32, should be 24.
•FIXED.
Inode 22548299, i blocks is 16, should be 8.
FIXED.
/dev/numeOn1p2: Inode 22550306, i blocks is 8, should be 0.
FIXED.
/deurnumeOn1p2: Inode 22551616, i blocks is 1416, should be 0. FIXED.
/dev/numeOn1p2: Inode 22553506, i_blocks is 4200, should be 2112. FIXED /dev/numeOn1p2: Inode 2255?061, i_ blocks is 18472, should be 9640.
FIXED.
/dev/numeOn1p2: Inode 22557124, i blocks is 9928, should be 5224.
FIXED.
Inode 22589874, i blocks is 16, should be 8.
FIXED.
/dev/numeOn1p2: Inode 22590035, i_blocks is 31776, should be 18384. FIXED.
/dev/nune0n1p2: Inode 22591496, i_blocks is 64, should be 8. FIXED /dev/numeOn1p2: Inode 22592158, i_blocks is 416, should be 208. FIXED.
/dev/numeOn1p2: Inode 22601055, i_blocks is 5256, should be 0. FIXED.
Inode 22647895, i_blocks is 8, should be 0. FIXED.
Inode 22902291 extent tree (at level 1) could be shorter.
IGNORED.
Inode 25167896 extent tree (at level 1) could be shorter.
IGNORED.
Inode 25823238 extent tree (at level 2) could be narrower.
IGNORED.
/dev/numeOn1p2: Inode 25827225 extent tree (at level 1) could be narrouer.
IGNORED
Inode 26478756 extent tree (at level 1) could be shorter.
IGNORED.
/deu/nuneOn1p2: Inode 26739006 extent tree (at level 1) could be shorter. IGNORED.
/dev/nuneOnip2: Inode 26739219, I_blocks is 8, should be 0. FIXED.
/dev numeOnIp2: Inode 26739646 extent tree (at leuel 1) could be shorter. IGNORED.
/deu/nuneOn1p2: Inode 26740111, i_blocks is 141, should be 72.
FIXED.
/dev/numeOn1p2: Inode 26740178 extent tree (at level 1) could be shorter. IGNORED.
/dev nuncOn1p2: Inode 26741194 extent tree (at level 1) could be shorter.
IGNORED
/dev/numeOn1p2: Inode 26741698 extent tree (at level 1) could be shorter.
IGNORED
/dev numeOn1p2: Inode 26742288 extent tree (at level 1) could be shorter.
IGNORED.
/deurnumeOn1p2: Inode 26742489 extent tree (at level 1) could be shorter.
IGNORED.
/dev/nune0n1p2: Inode 26742652 extent tree (at level 1) could be shorter. IGNORED.
/dev/numeOn1p2: Inode 26743100 extent tree (at level 1) could be shorter.
IGNORED.
/dev/nune0n1p2: Inode 26747191 extent tree (at level 1) could be shorter. IGNORED. /dev/numeOn1p2: Inode 26748702 extent tree (at level 1) could be shorter. IGNORED.
Inode 26869910, i_blocks is 176, should be 88.
FIXED.
/dev/numeOn1p2: Inode 26869911, 1_blocks is 46384, should be 23192. FIXED.
/dev/numeOn1p2: Inode 26870048, i_blocks is 16, should be B.
FIXED.
/deu/nuneOn1p2: Inode 26870224, i_blocks is 592, should be 296. FIXED.
dev numeOn1p2: Inode 26870238, i_blocks is 240, should be 120.
FIXED.
/deu/numen1p2: Inode 26870291, i blocks is 81312, should be 40656. FIXED.
/dev/numeOn1p2: Inode 26873667, i_blocks is 1104, should be 552.
FIXED.
/dev numeOn1p2: Inode 26873673, _blocks is 19504, should be 13848.
FIXED.
/dev/nune0n1p2: Inode 26873676, i_blocks is 16, should be 8.
FIXED.
/dev/numeOn1p2: Inode 26874854, L_blocks is 26512, should be 23200.
FIXED.
/deu/numeôn1p2: Inode 26874855, i_ blocks is 256, should be 128.
FIXED
dev nume@nin2: inode 26874866, i_blocks is 21432, should be 8192. FIXED.
/dev/nune0n1p2: Inode 26874917, i_blocks is 13512, should be 8760.
FIXED.
/dev/numeOn1p2: Inode 26874918, 1_blocks is 16664, should be 8336.
FIXED.
Duplicate or bad block in use!
/deu/numen1p2: Multiply-claimed block(s) in inode 26739692: 16742400--16744447
dev/nune@nip?: Multiply-claimed block(s) in inode 26756038: 16742400--16744447 /dev/numeOnip2: (There are 2 inodes containing multiply-claimed blacks.)
/dev/numeOn1p2: File /var/tmp/pamac/packages-meta-ext-ul.json.gz(inode#26739692,modtimeTueDec2609:14:292023)
has 2048 multiply-claimed block(s), shared with 1 files):
/deurnumeOn102:
/var/11b/mlocate/mlocate.b (inode #26756038, mod time Fri Dec 29 14:33:13 2023)
/deu/nune0n1p2:
/dev/nuneOn1p2: UNEXPECTED INCONSISTENCY: RUN isck MANUALLY.
(i.e.. without -a or -p options)
ERROR: Bailing out, Run fSck UUID=(2190208-74e5-4e29-9eed-dob36863г0a7* manually
********* FILESYSTEM CHECK FAILED ******
Please run fsck manually.
After leaving this maintenance shell, the system will reboot automatically.
************* *К*************************
sh: can't access tty: job control turned off
Because it seems I make everything worse I assumed it would be smart to ask people who actually know what they are doing. I do have timeshift backups. I’m not sure what would make more sense at this point. Trying to fix the system or restore a timeshift backup. Also i’d like to understand what actually happened here. O community - have patience with me.
I hope, you have a recent, good backup :man_shrugging:
do this by booting a live system - chroot is not necessary at this stage
The file system is inconsistent/corrupted and could not be fixed automatically.
The process could be a little more complicated, but try this first.
Your output looks strange - did you copy/paste it or did you type it?
For example:
The device name should be the same - but it isn’t.
… there is an “O” in the place where there should be a “0” (zero) …
/dev/nune0n1p2
vs.
/dev/numeOn1p2
I’m hoping you typed it out yourself and made these errors in naming - else this is a real mess …
Same here. :see_no_evil:
  • deu/numen1p2
  • dev/nune@nip?
I am out :footprints:
Oh sorry for that. I should have added that I copied this from a screenshot via automatic text recognition. It’s not that messed up :smiley:
Well, then do try to run the fsck manually after you booted a live system.
… there you have the option to tell the program what to do (fix it or not)
But when the automatic procedure fails, it is unlikely that the manual procedure will end up without data loss.
Using a backup of your personal data - or even getting it off the disk right now - and then re-installing is the better option at this stage.
In my opinion.
You can likely still mount the filesystem in read only mode and get a copy of your valuable data.
Three years ago I lost a lot of stuff - the disk the backup was on failed - and I did not have another recent copy but only a new installation with some of it present.
… just a story …
Alright, thank you. I’ll see that i backup some data first then. Considering your proposal I assume that the timeshift backup isn’t of any help at this point ?
If you have one from prior to the current issue - it will be of help.
… providing it also contains the $HOME directory
which it usually doesn’t - unless you configured it this way
The system is easy to reinstall - or to restore from a timeshift backup.
What you care about is personal data - usually not included in a timeshift restore point.
But the file system errors need to be corrected first before you can deploy any backup.
You have two files claiming the same block, both generated, better to lose those than data you might need.
Also you did not mention how this happened exactly, so hardware failure is on the table.
repair your file system, but dont do it from chroot… boot into manjaro live usb, and post output from:
lsblk -fs
I just checked. Unfortunately a new timeshift backup was created after I could boot into the system via the other kernel last time - after the failed update where the system was somehow corrupted already. Because I backup /home with timeshift I always only keep the newest backup. So there is an entry for today in the timeshift directory but unfortunately timeshift does not list it. Maybe the backup did not finish or something. I will backup data I need manually now as soon as i have an external drive at hand since its still possible to mount the partitions. After ill try fsck or whatever else will be proposed to me here.
@brahma the output of lsblk -fs:
NAME FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0
     squash 4.0                                                    0   100% /run/miso/sfs/livefs
loop1
     squash 4.0                                                    0   100% /run/miso/sfs/mhwdfs
loop2
     squash 4.0                                                    0   100% /run/miso/sfs/desktopfs
loop3
     squash 4.0                                                    0   100% /run/miso/sfs/rootfs
sda1 iso966 Jolie MANJARO_XFCE_220
                        2022-12-24-05-17-08-00
└─sda
                        2022-12-24-05-17-08-00                     0   100% /run/miso/bootmnt
sda2 vfat   FAT12 MISO_EFI
                        4A53-5D40
└─sda
sdb
nvme0n1p1
     vfat   FAT32 NO_LABEL
                        72EE-6D1A                             299.1M     0% /mnt/boot/efi
└─nvme0n1
nvme0n1p2
     ext4   1.0         c2f90208-74e5-4e29-9eed-d0b3b863f0d7   11.2G    92% /mnt
└─nvme0n1
nvme0n1p3
     swap   1     swap  e3774d6e-9d82-40a5-a14f-595af7bc4462
└─nvme0n1
Well it is but I think this is very unlikely this would be a huge coincident. Unfortunately I do not remember all the steps I took exactly because I was following standard instructions from this forum and I don’t understand everything of it to the fullest. I described my procedure to the best of my knowledge…
Saying that… something comes to my mind. When I was able to boot into the system the last time (after the failed recovery from live-usb) the system continued from where it crashed - meaning the update continued. Thinking of it this probably means it went into hibernation during the update right ? So i guess the charger wasnt applied properly. Anyways, maybe the continuation of this update process resulted in conflicts with the updates from the live distro recovery attempt ? Does that sound like a possible scenario ?
so run the fsck manually:
sudo fsck /dev/nvme0n1p2
if it run succesfully, chroot:
manjaro-chroot -a
rerun update:
pacman-mirrors -f 5 && pacman -Syyu
if you up to date, post output from:
ldconfig
mhwd-kernel -li
Then it is likely just filesystem corruption.
Going by the logs, you can just fsck the partition, then remove the two broken files; as they will be automatically generated again, you have no real loss.
If you have something on the partition you should really be paranoid about losing, then back it up before you fsck it, but I do not expect further data loss.
Some suggestions for the future
  • Use Btrfs as file system. It is rock solid. (Nearly unbreakable in the event of power outages or system crashes)
  • Use Snapper to create snapshots
    It is more configurable than Timeshift. You can create multiple profiles for different subvolumes (/ /home /var/log …). So you can adjust it to your needs.
    You can rollback each profile individually. Together with Btrfs I have over 100 snapshots of my system and no space problems.
  • You even can combine Snapshots with extern backups (backsnap)
You find good Information about Btrfs in the wiki
and in
I Followed your instructions including deleting the conflicting files as proposed by @wntr
output of ldconfig was empty so here is ldconfig -v:
ldconfig: Path `/usr/lib64' given more than once
(from <builtin>:0 and <builtin>:0)
ldconfig: Can't stat /usr/libx32: No such file or directory
/usr/lib/R/lib: (from /etc/ld.so.conf.d/R.conf:1)
	libR.so -> libR.so
/usr/lib/libfakeroot: (from /etc/ld.so.conf.d/fakeroot.conf:1)
	libfakeroot-0.so -> libfakeroot.so
/usr/lib32: (from /etc/ld.so.conf.d/lib32-glibc.conf:1)
	libnss_myhostname.so.2 -> libnss_myhostname.so.2
	libnss_dns.so.2 -> libnss_dns.so.2
	libpciaccess.so.0 -> libpciaccess.so.0.11.1
	libwayland-server.so.0 -> libwayland-server.so.0.22.0
	libnsssysinit.so -> libnsssysinit.so
	libXext.so.6 -> libXext.so.6.4.0
	libvdpau.so.1 -> libvdpau.so.1.0.0
	libfribidi.so.0 -> libfribidi.so.0.4.0
	libnss_db.so.2 -> libnss_db.so.2
	libxshmfence.so.1 -> libxshmfence.so.1.0.0
	libnspr4.so -> libnspr4.so
	libm.so.6 -> libm.so.6
	libxkbregistry.so.0 -> libxkbregistry.so.0.0.0
	libnss_hesiod.so.2 -> libnss_hesiod.so.2
	libsmime3.so -> libsmime3.so
	libunwind.so.8 -> libunwind.so.8.0.1
	libcanberra.so.0 -> libcanberra.so.0.2.5
	libpsl.so.5 -> libpsl.so.5.3.4
	libpthread.so.0 -> libpthread.so.0
	libXft.so.2 -> libXft.so.2.3.8
	libnss_compat.so.2 -> libnss_compat.so.2
	liblzma.so.5 -> liblzma.so.5.4.5
	libpcprofile.so -> libpcprofile.so
	libva-drm.so.2 -> libva-drm.so.2.2000.0
	libvulkan_intel_hasvk.so -> libvulkan_intel_hasvk.so
	libwayland-client.so.0 -> libwayland-client.so.0.22.0
	libxcb-dri3.so.0 -> libxcb-dri3.so.0.1.0
	libxcb-shm.so.0 -> libxcb-shm.so.0.0.0
	libobjc.so.4 -> libobjc.so.4.0.0
	libxcb-xinput.so.0 -> libxcb-xinput.so.0.1.0
	libblkid.so.1 -> libblkid.so.1.1.0
	libcups.so.2 -> libcups.so.2
	libkadm5srv_mit.so.12 -> libkadm5srv_mit.so.12.0
	libxkbcommon.so.0 -> libxkbcommon.so.0.0.0
	libz.so.1 -> libz.so.1.3
	libEGL.so.1 -> libEGL.so.1.1.0
	libcap.so.2 -> libcap.so.2.69
	libxcb-render.so.0 -> libxcb-render.so.0.0.0
	libbz2.so.1.0 -> libbz2.so.1.0.8
	libsqlite3.so.0 -> libsqlite3.so.0.8.6
	libcolord.so.2 -> libcolord.so.2.0.5
	libEGL_mesa.so.0 -> libEGL_mesa.so.0.0.0
	libpcre2-8.so.0 -> libpcre2-8.so.0.11.2
	libxcb-damage.so.0 -> libxcb-damage.so.0.0.0
	libatspi.so.0 -> libatspi.so.0.0.1
	libpam_misc.so.0 -> libpam_misc.so.0.82.1
	libXxf86vm.so.1 -> libXxf86vm.so.1.0.0
	libdrm_radeon.so.1 -> libdrm_radeon.so.1.0.1
	libgdk_pixbuf-2.0.so.0 -> libgdk_pixbuf-2.0.so.0.4200.10
	libnss3.so -> libnss3.so
	libxcb-dpms.so.0 -> libxcb-dpms.so.0.0.0
	libgpg-error.so.0 -> libgpg-error.so.0.34.0
	libssh2.so.1 -> libssh2.so.1.0.1
	libpanelw.so.6 -> libpanelw.so.6.4
	libFLAC.so.12 -> libFLAC.so.12.1.0
	libgssapi_krb5.so.2 -> libgssapi_krb5.so.2.2
	libvorbisfile.so.3 -> libvorbisfile.so.3.3.8
	libthread_db.so.1 -> libthread_db.so.1
	libunwind-setjmp.so.0 -> libunwind-setjmp.so.0.0.0
	libcupsimage.so.2 -> libcupsimage.so.2
	libva.so.2 -> libva.so.2.2000.0
	libSM.so.6 -> libSM.so.6.0.1
	libutil.so.1 -> libutil.so.1
	libnss_systemd.so.2 -> libnss_systemd.so.2
	libxcb-xkb.so.1 -> libxcb-xkb.so.1.0.0
	libe2p.so.2 -> libe2p.so.2.3
	libGLdispatch.so.0 -> libGLdispatch.so.0.0.0
	libgio-2.0.so.0 -> libgio-2.0.so.0.7800.3
	libXrandr.so.2 -> libXrandr.so.2.2.0
	libXss.so.1 -> libXss.so.1.0.0
	libanl.so.1 -> libanl.so.1
	libgo.so.22 -> libgo.so.22.0.0
	libdrm_amdgpu.so.1 -> libdrm_amdgpu.so.1.0.0
	libGLESv2.so.2 -> libGLESv2.so.2.1.0
	libva-glx.so.2 -> libva-glx.so.2.2000.0
	libnss_resolve.so.2 -> libnss_resolve.so.2
	libdrm_intel.so.1 -> libdrm_intel.so.1.0.0
	liblcms2.so.2 -> liblcms2.so.2.0.16
	libtiff.so.6 -> libtiff.so.6.0.2
	libldap.so.2 -> libldap.so.2.0.200
	libltdl.so.7 -> libltdl.so.7.3.2
	libLTO.so.16 -> libLTO.so.16
	libdebuginfod.so.1 -> libdebuginfod-0.190.so
	libvulkan_intel.so -> libvulkan_intel.so
	libRemarks.so.16 -> libRemarks.so.16
	libssl3.so -> libssl3.so
	libsystemd.so.0 -> libsystemd.so.0.37.0
	libxatracker.so.2 -> libxatracker.so.2.5.0
	libcurl.so.4 -> libcurl.so.4.8.0
	libgnutls.so.30 -> libgnutls.so.30.37.0
	libICE.so.6 -> libICE.so.6.3.0
	libcom_err.so.2 -> libcom_err.so.2.1
	libunistring.so.5 -> libunistring.so.5.0.0
	libcairo-gobject.so.2 -> libcairo-gobject.so.2.11800.0
	libunwind-ptrace.so.0 -> libunwind-ptrace.so.0.0.0
	libnssutil3.so -> libnssutil3.so
	libtirpc.so.3 -> libtirpc.so.3.0.0
	libtiffxx.so.6 -> libtiffxx.so.6.0.2
	libhogweed.so.6 -> libhogweed.so.6.8
	libpulse.so.0 -> libpulse.so.0.24.2
	libquadmath.so.0 -> libquadmath.so.0.0.0
	libpulse-mainloop-glib.so.0 -> libpulse-mainloop-glib.so.0.0.6
	libdl.so.2 -> libdl.so.2
	libthai.so.0 -> libthai.so.0.3.1
	libbrotlienc.so.1 -> libbrotlienc.so.1.1.0
	libdrm_nouveau.so.2 -> libdrm_nouveau.so.2.0.0
	libxcb-present.so.0 -> libxcb-present.so.0.0.0
	libgphobos.so.4 -> libgphobos.so.4.0.0
	libxcb-xv.so.0 -> libxcb-xv.so.0.0.0
	libxcb-screensaver.so.0 -> libxcb-screensaver.so.0.0.0
	libxcb-shape.so.0 -> libxcb-shape.so.0.0.0
	libunwind-coredump.so.0 -> libunwind-coredump.so.0.0.0
	libX11-xcb.so.1 -> libX11-xcb.so.1.0.0
	libasan.so.8 -> libasan.so.8.0.0
	libtdb.so.1 -> libtdb.so.1.4.9
	libcanberra-gtk.so.0 -> libcanberra-gtk.so.0.1.9
	libformw.so.6 -> libformw.so.6.4
	libwayland-cursor.so.0 -> libwayland-cursor.so.0.22.0
	libffi.so.8 -> libffi.so.8.1.2
	libdecor-0.so.0 -> libdecor-0.so.0.200.1
	libturbojpeg.so.0 -> libturbojpeg.so.0.3.0
	libkrb5.so.3 -> libkrb5.so.3.3
	libkeyutils.so.1 -> libkeyutils.so.1.10
	libOSMesa.so.8 -> libOSMesa.so.8.0.0
	libvorbis.so.0 -> libvorbis.so.0.4.9
	libxcb-xinerama.so.0 -> libxcb-xinerama.so.0.0.0
	libudev.so.1 -> libudev.so.1.7.7
	libmount.so.1 -> libmount.so.1.1.0
	libcrypt.so.2 -> libcrypt.so.2.0.0
	libmemusage.so -> libmemusage.so
	libatk-bridge-2.0.so.0 -> libatk-bridge-2.0.so.0.0.0
	libsoftokn3.so -> libsoftokn3.so
	libnss_mymachines.so.2 -> libnss_mymachines.so.2
	ld-linux.so.2 -> ld-linux.so.2
	libsensors.so.5 -> libsensors.so.5.0.0
	libicudata.so.74 -> libicudata.so.74.2
	libopus.so.0 -> libopus.so.0.9.0
	libnss_files.so.2 -> libnss_files.so.2
	libwayland-egl.so.1 -> libwayland-egl.so.1.22.0
	libXfixes.so.3 -> libXfixes.so.3.1.0
	libgthread-2.0.so.0 -> libgthread-2.0.so.0.7800.3
	librt.so.1 -> librt.so.1
	libxkbcommon-x11.so.0 -> libxkbcommon-x11.so.0.0.0
	libXcomposite.so.1 -> libXcomposite.so.1.0.0
	libexpat.so.1 -> libexpat.so.1.8.10
	libvulkan.so.1 -> libvulkan.so.1.3.274
	libGLEW.so.2.2 -> libGLEW.so.2.2.0
	libXmu.so.6 -> libXmu.so.6.2.0
	libxcb-composite.so.0 -> libxcb-composite.so.0.0.0
	libnettle.so.8 -> libnettle.so.8.8
	libxcb-xfixes.so.0 -> libxcb-xfixes.so.0.0.0
	libxml2.so.2 -> libxml2.so.2.12.3
	libpulse-simple.so.0 -> libpulse-simple.so.0.1.1
	libgdruntime.so.4 -> libgdruntime.so.4.0.0
	libGLX.so.0 -> libGLX.so.0.0.0
	libXmuu.so.1 -> libXmuu.so.1.0.0
	libXinerama.so.1 -> libXinerama.so.1.0.0
	libuuid.so.1 -> libuuid.so.1.3.0
	libasyncns.so.0 -> libasyncns.so.0.3.1
	libglapi.so.0 -> libglapi.so.0.0.0
	libX11.so.6 -> libX11.so.6.4.0
	libkdb_ldap.so.1 -> libkdb_ldap.so.1.0
	libgnutlsxx.so.30 -> libgnutlsxx.so.30.0.0
	libkrb5support.so.0 -> libkrb5support.so.0.1
	libxcb-dri2.so.0 -> libxcb-dri2.so.0.0.0
	libXi.so.6 -> libXi.so.6.1.0
	libepoxy.so.0 -> libepoxy.so.0.0.0
	libvorbisenc.so.2 -> libvorbisenc.so.2.0.12
	libatopology.so.2 -> libatopology.so.2.0.0
	libgbm.so.1 -> libgbm.so.1.0.0
	libpixman-1.so.0 -> libpixman-1.so.0.42.2
	libgcc_s.so.1 -> libgcc_s.so.1
	libXdamage.so.1 -> libXdamage.so.1.1.0
	libicutest.so.74 -> libicutest.so.74.2
	libss.so.2 -> libss.so.2.0
	libatk-1.0.so.0 -> libatk-1.0.so.0.25009.1
	libfreeblpriv3.so -> libfreeblpriv3.so
	libext2fs.so.2 -> libext2fs.so.2.4
	libasound.so.2 -> libasound.so.2.0.0
	libdw.so.1 -> libdw-0.190.so
	libgfortran.so.5 -> libgfortran.so.5.0.0
	libXtst.so.6 -> libXtst.so.6.1.0
	libfreebl3.so -> libfreebl3.so
	libgmodule-2.0.so.0 -> libgmodule-2.0.so.0.7800.3
	libxcb-record.so.0 -> libxcb-record.so.0.0.0
	libpcre2-posix.so.3 -> libpcre2-posix.so.3.0.4
	libssl.so.3 -> libssl.so.3
	libglut.so.3 -> libglut.so.3.12.0
	libitm.so.1 -> libitm.so.1.0.0
	libva-wayland.so.2 -> libva-wayland.so.2.2000.0
	libc_malloc_debug.so.0 -> libc_malloc_debug.so.0
	libdatrie.so.1 -> libdatrie.so.1.4.0
	libglib-2.0.so.0 -> libglib-2.0.so.0.7800.3
	libdrm.so.2 -> libdrm.so.2.4.0
	libgmpxx.so.4 -> libgmpxx.so.4.7.0
	libgomp.so.1 -> libgomp.so.1.0.0
	libcolordcompat.so -> libcolordcompat.so
	libncursesw.so.6 -> libtinfo.so.6
	libplds4.so -> libplds4.so
	libpng16.so.16 -> libpng16.so.16.40.0
	libverto.so.0 -> libverto.so.0.0
	libicuuc.so.74 -> libicuuc.so.74.2
	libstdc++.so.6 -> libstdc++.so.6.0.32
	libpcre2-32.so.0 -> libpcre2-32.so.0.11.2
	libcanberra-gtk3.so.0 -> libcanberra-gtk3.so.0.1.9
	libicuio.so.74 -> libicuio.so.74.2
	libgmp.so.10 -> libgmp.so.10.5.0
	libBrokenLocale.so.1 -> libBrokenLocale.so.1
	libicui18n.so.74 -> libicui18n.so.74.2
	libfdisk.so.1 -> libfdisk.so.1.1.0
	libXt.so.6 -> libXt.so.6.0.0
	libxcb-glx.so.0 -> libxcb-glx.so.0.0.0
	liblber.so.2 -> liblber.so.2.0.200
	librsvg-2.so.2 -> librsvg-2.so.2.48.0
	libcrypto.so.3 -> libcrypto.so.3
	libxcb.so.1 -> libxcb.so.1.1.0
	libjpeg.so.8 -> libjpeg.so.8.3.2
	libfontconfig.so.1 -> libfontconfig.so.1.13.0
	libvulkan_radeon.so -> libvulkan_radeon.so
	libpamc.so.0 -> libpamc.so.0.82.1
	libxcb-sync.so.1 -> libxcb-sync.so.1.0.0
	libGLU.so.1 -> libGLU.so.1.3.1
	libasm.so.1 -> libasm-0.190.so
	libgobject-2.0.so.0 -> libgobject-2.0.so.0.7800.3
	libncurses++w.so.6 -> libncurses++w.so.6.4
	libXau.so.6 -> libXau.so.6.0.0
	libdbus-1.so.3 -> libdbus-1.so.3.32.4
	libcairo-script-interpreter.so.2 -> libcairo-script-interpreter.so.2.11800.0
	libxcb-xtest.so.0 -> libxcb-xtest.so.0.0.0
	libbrotlicommon.so.1 -> libbrotlicommon.so.1.1.0
	libtasn1.so.6 -> libtasn1.so.6.6.3
	libgtk-3.so.0 -> libgtk-3.so.0.2407.32
	libnsl.so.1 -> libnsl.so.1
	libGLX_mesa.so.0 -> libGLX_mesa.so.0.0.0
	libFLAC++.so.10 -> libFLAC++.so.10.0.1
	libLLVM-16.so -> libLLVM.so
	libresolv.so.2 -> libresolv.so.2
	libogg.so.0 -> libogg.so.0.8.5
	libxcb-dbe.so.0 -> libxcb-dbe.so.0.0.0
	libpcre2-16.so.0 -> libpcre2-16.so.0.11.2
	libc.so.6 -> libc.so.6
	libXrender.so.1 -> libXrender.so.1.3.0
	libpangoft2-1.0.so.0 -> libpangoft2-1.0.so.0.5100.0
	libgdk-3.so.0 -> libgdk-3.so.0.2407.32
	libxcb-xf86dri.so.0 -> libxcb-xf86dri.so.0.0.0
	libk5crypto.so.3 -> libk5crypto.so.3.1
	libcrypt.so.1 -> libcrypt.so.1.1.0
	libkadm5clnt_mit.so.12 -> libkadm5clnt_mit.so.12.0
	libkdb5.so.10 -> libkdb5.so.10.0
	libmenuw.so.6 -> libmenuw.so.6.4
	libgailutil-3.so.0 -> libgailutil-3.so.0.0.0
	libfreetype.so.6 -> libfreetype.so.6.20.1
	libpangoxft-1.0.so.0 -> libpangoxft-1.0.so.0.5100.0
	libsndfile.so.1 -> libsndfile.so.1.0.37
	libxcb-res.so.0 -> libxcb-res.so.0.0.0
	libidn2.so.0 -> libidn2.so.0.3.8
	libplc4.so -> libplc4.so
	libGL.so.1 -> libGL.so.1.7.0
	libicutu.so.74 -> libicutu.so.74.2
	libgcrypt.so.20 -> libgcrypt.so.20.4.3
	libelf.so.1 -> libelf-0.190.so
	libsmartcols.so.1 -> libsmartcols.so.1.1.0
	libxcb-randr.so.0 -> libxcb-randr.so.0.1.0
	libgssrpc.so.4 -> libgssrpc.so.4.2
	libva-x11.so.2 -> libva-x11.so.2.2000.0
	libpam.so.0 -> libpam.so.0.85.1
	libharfbuzz-subset.so.0 -> libharfbuzz-subset.so.0.60830.0
	libzstd.so.1 -> libzstd.so.1.5.5
	libharfbuzz-gobject.so.0 -> libharfbuzz-gobject.so.0.60830.0
	libXdmcp.so.6 -> libXdmcp.so.6.0.0
	libbrotlidec.so.1 -> libbrotlidec.so.1.1.0
	libunwind-x86.so.8 -> libunwind-x86.so.8.0.1
	libXcursor.so.1 -> libXcursor.so.1.0.2
	libatomic.so.1 -> libatomic.so.1.2.0
	libpangocairo-1.0.so.0 -> libpangocairo-1.0.so.0.5100.0
	libcairo.so.2 -> libcairo.so.2.11800.0
	libubsan.so.1 -> libubsan.so.1.0.0
	libOpenGL.so.0 -> libOpenGL.so.0.0.0
	libkrad.so.0 -> libkrad.so.0.0
	libpsx.so.2 -> libpsx.so.2.69
	libharfbuzz.so.0 -> libharfbuzz.so.0.60830.0
	libpango-1.0.so.0 -> libpango-1.0.so.0.5100.0
	libxcb-xvmc.so.0 -> libxcb-xvmc.so.0.0.0
	libp11-kit.so.0 -> libp11-kit.so.0.3.1
/usr/lib: (from <builtin>:0)
	liburing.so.2 -> liburing.so.2.5
	libabsl_symbolize.so.2308.0.0 -> libabsl_symbolize.so.2308.0.0
	libboost_atomic.so.1.83.0 -> libboost_atomic.so.1.83.0
	libabsl_raw_logging_internal.so.2308.0.0 -> libabsl_raw_logging_internal.so.2308.0.0
	libabsl_strings_internal.so.2308.0.0 -> libabsl_strings_internal.so.2308.0.0
	libboost_date_time.so.1.83.0 -> libboost_date_time.so.1.83.0
	libboost_mpi.so.1.83.0 -> libboost_mpi.so.1.83.0
	libtalloc.so.1 -> libtalloc-compat1-2.4.1.so
	libruby.so.3.0 -> libruby.so.3.0.6
	libQt6Multimedia.so.6 -> libQt6Multimedia.so.6.6.1
	libmd4c.so.0 -> libmd4c.so.0.4.8
	libabsl_flags_program_name.so.2308.0.0 -> libabsl_flags_program_name.so.2308.0.0
	libwoff2enc.so.1.0.2 -> libwoff2enc.so.1.0.2
	libboost_math_c99l.so.1.83.0 -> libboost_math_c99l.so.1.83.0
	libabsl_random_seed_gen_exception.so.2308.0.0 -> libabsl_random_seed_gen_exception.so.2308.0.0
	libabsl_time_zone.so.2308.0.0 -> libabsl_time_zone.so.2308.0.0
	libabsl_log_internal_check_op.so.2308.0.0 -> libabsl_log_internal_check_op.so.2308.0.0
	libKF5KIOFileWidgets.so.5 -> libKF5KIOFileWidgets.so.5.113.0
	libabsl_raw_hash_set.so.2308.0.0 -> libabsl_raw_hash_set.so.2308.0.0
	libgstcheck-1.0.so.0 -> libgstcheck-1.0.so.0.2208.0
	libaa.so.1 -> libaa.so.1.0.4
	libhidapi-hidraw.so.0 -> libhidapi-hidraw.so.0.14.0
	libboost_context.so.1.83.0 -> libboost_context.so.1.83.0
	libboost_wserialization.so.1.83.0 -> libboost_wserialization.so.1.83.0
	libbtparse.so -> libbtparse.so
	libswscale.so.5 -> libswscale.so.5.9.100
	libboost_prg_exec_monitor.so.1.83.0 -> libboost_prg_exec_monitor.so.1.83.0
	libtcl8.6.so -> libtcl8.6.so
	libjbig.so.2.1 -> libjbig.so.2.1
	libboost_thread.so.1.83.0 -> libboost_thread.so.1.83.0
	libSPIRV-Tools-opt.so -> libSPIRV-Tools-opt.so
	libudf.so.0 -> libudf.so.0.0.0
	libKF5KIOGui.so.5 -> libKF5KIOGui.so.5.113.0
	libxkbfile.so.1 -> libxkbfile.so.1.0.2
	libabsl_log_entry.so.2308.0.0 -> libabsl_log_entry.so.2308.0.0
	liblirc.so.0 -> liblirc.so.0.0.0
	libMonoPosixHelper.so -> libMonoPosixHelper.so
	libboost_serialization.so.1.83.0 -> libboost_serialization.so.1.83.0
	librtmp.so.1 -> librtmp.so.1
	libWildMidi.so.2 -> libWildMidi.so.2.1.0
	libexslt.so.0 -> libexslt.so.0.8.21
	libappindicator3.so.1 -> libappindicator3.so.1.0.0
	libabsl_die_if_null.so.2308.0.0 -> libabsl_die_if_null.so.2308.0.0
	libQt6Core.so.6 -> libQt6Core.so.6.6.1
	libgegl-npd-0.4.so -> libgegl-npd-0.4.so
	libboost_locale.so.1.83.0 -> libboost_locale.so.1.83.0
	libkate.so.1 -> libkate.so.1.3.0
	libboost_fiber.so.1.83.0 -> libboost_fiber.so.1.83.0
	libboost_stacktrace_noop.so.1.83.0 -> libboost_stacktrace_noop.so.1.83.0
	libQt6Gui.so.6 -> libQt6Gui.so.6.6.1
	libgtk-4.so.1 -> libgtk-4.so.1.1200.4
	libbotan-3.so.2 -> libbotan-3.so.2.2.0
	libboost_graph_parallel.so.1.83.0 -> libboost_graph_parallel.so.1.83.0
	lib2geom.so.1.3.0 -> lib2geom.so.1.3.0
	libopcodes-2.41.0.so -> libopcodes-2.41.0.so
	libSvtHevcEnc.so.1 -> libSvtHevcEnc.so.1
	libQt6EglFsKmsGbmSupport.so.6 -> libQt6EglFsKmsGbmSupport.so.6.6.1
	libQt6QuickWidgets.so.6 -> libQt6QuickWidgets.so.6.6.1
	libssh.so.4 -> libssh.so.4.9.6
	libabsl_log_sink.so.2308.0.0 -> libabsl_log_sink.so.2308.0.0
	libabsl_str_format_internal.so.2308.0.0 -> libabsl_str_format_internal.so.2308.0.0
	libvidstab.so.1.2 -> libvidstab.so.1.2
	libboost_unit_test_framework.so.1.83.0 -> libboost_unit_test_framework.so.1.83.0
	libxcb-icccm.so.4 -> libxcb-icccm.so.4.0.0
	librubberband-jni.so -> librubberband-jni.so
	libndr-nbt.so.0 -> libndr-nbt.so.0.0.1
	libSPIRV-Tools-link.so -> libSPIRV-Tools-link.so
	libnss_mdns4.so.2 -> libnss_mdns4.so.2
	libplist-2.0.so.4 -> libplist-2.0.so.4.3.0
	libasprintf.so.0 -> libasprintf.so.0.0.0
	libraw1394.so.11 -> libraw1394.so.11.1.0
	libgsttranscoder-1.0.so.0 -> libgsttranscoder-1.0.so.0
	libSvtAv1Enc.so.1 -> libSvtAv1Enc.so.1.8.0
	libabsl_examine_stack.so.2308.0.0 -> libabsl_examine_stack.so.2308.0.0
	libde265.so.0 -> libde265.so.0.1.8
	libdevmapper.so.1.02 -> libdevmapper.so.1.02
	libinih.so.0 -> libinih.so.0
	libtss2-fapi.so.1 -> libtss2-fapi.so.1.0.0
	libboost_math_c99f.so.1.83.0 -> libboost_math_c99f.so.1.83.0
	libSPIRV-Tools-diff.so -> libSPIRV-Tools-diff.so
	libxklavier.so.16 -> libxklavier.so.16.4.0
	libsasl2.so.3 -> libsasl2.so.3.0.0
	libavahi-client.so.3 -> libavahi-client.so.3.2.9
	libabsl_log_initialize.so.2308.0.0 -> libabsl_log_initialize.so.2308.0.0
	libconfuse.so.2 -> libconfuse.so.2.1.0
	libgvpr.so.2 -> libgvpr.so.2.0.0
	libabsl_random_internal_randen_hwaes.so.2308.0.0 -> libabsl_random_internal_randen_hwaes.so.2308.0.0
	libmjpegutils-2.2.so.0 -> libmjpegutils.so
	libapparmor.so.1 -> libapparmor.so.1.12.3
	libwoff2common.so.1.0.2 -> libwoff2common.so.1.0.2
	liblensfun.so.1 -> liblensfun.so.0.3.4
	libabsl_cordz_info.so.2308.0.0 -> libabsl_cordz_info.so.2308.0.0
	libKF5Bookmarks.so.5 -> libKF5Bookmarks.so.5.113.0
	libiniparser.so.1 -> libiniparser.so.1
	libpostproc.so.57 -> libpostproc.so.57.3.100
	libbd_btrfs.so.3 -> libbd_btrfs.so.3.0.0
	libSPIRV-Tools.so -> libSPIRV-Tools.so
	libhwloc.so.15 -> libhwloc.so.15.6.2
	libminilzo.so.0 -> libminilzo.so.0
	libdb_cxx-5.3.so -> libdb_cxx-5.3.so
	libtracefs.so.1 -> libtracefs.so.1.7.0
	libabsl_scoped_set_env.so.2308.0.0 -> libabsl_scoped_set_env.so.2308.0.0
	libpolkit-qt5-core-1.so.1 -> libpolkit-qt5-core-1.so.1.175.0
	libhdr10plus.so -> libhdr10plus.so
	libI810XvMC.so.1 -> libI810XvMC.so.1.0.0
	libabsl_random_internal_seed_material.so.2308.0.0 -> libabsl_random_internal_seed_material.so.2308.0.0
	libmpi_cxx.so.40 -> libmpi_cxx.so.40.30.1
	libboost_math_c99.so.1.83.0 -> libboost_math_c99.so.1.83.0
	libedit.so.0 -> libedit.so.0.0.72
	libwsutil.so.15 -> libwsutil.so.15.0.0
	libabsl_flags_usage.so.2308.0.0 -> libabsl_flags_usage.so.2308.0.0
	libabsl_log_internal_message.so.2308.0.0 -> libabsl_log_internal_message.so.2308.0.0
	libnsl.so.3 -> libnsl.so.3.0.0
	libpopt.so.0 -> libpopt.so.0.0.2
	libgpgme.so.11 -> libgpgme.so.11.32.1
	libtss2-tcti-mssim.so.0 -> libtss2-tcti-mssim.so.0.0.0
	libboost_container.so.1.83.0 -> libboost_container.so.1.83.0
	libfftw3f.so.3 -> libfftw3f.so.3.6.10
	libgarcon-1.so.0 -> libgarcon-1.so.0.0.0
	libZXing.so.3 -> libZXing.so.2.2.1
	libgstwayland-1.0.so.0 -> libgstwayland-1.0.so.0.2208.0
	libgstrtsp-1.0.so.0 -> libgstrtsp-1.0.so.0.2208.0
	libfftw3f_omp.so.3 -> libfftw3f_omp.so.3.6.10
	libikvm-native.so -> libikvm-native.so
	libtcmalloc_minimal.so.4 -> libtcmalloc_minimal.so.4.5.14
	libnl-3.so.200 -> libnl-3.so.200.26.0
	libupower-glib.so.3 -> libupower-glib.so.3.1.0
	libldacBT_abr.so.2 -> libldacBT_abr.so.2.0.2.3
	libKF5ItemModels.so.5 -> libKF5ItemModels.so.5.113.0
	liblouis.so.20 -> liblouis.so.20.0.16
	libSPIRV-Tools-lint.so -> libSPIRV-Tools-lint.so
	liboggkate.so.1 -> liboggkate.so.1.2.2
	libjxl_threads.so.0.8 -> libjxl_threads.so.0.8.2
	libmanette-0.2.so.0 -> libmanette-0.2.so.0
	libbd_loop.so.3 -> libbd_loop.so.3.0.0
	libabsl_crc_cpu_detect.so.2308.0.0 -> libabsl_crc_cpu_detect.so.2308.0.0
	libmodplug.so.1 -> libmodplug.so.1.0.0
	libiso9660.so.11 -> libiso9660.so.11.0.0
	libass.so.9 -> libass.so.9.2.1
	libdeflate.so.0 -> libdeflate.so.0
	libidn.so.12 -> libidn.so.12.6.4
	libtss2-tcti-pcap.so.0 -> libtss2-tcti-pcap.so.0.0.0
	libffcall.so.0 -> libffcall.so.0.1.0
	libwoff2dec.so.1.0.2 -> libwoff2dec.so.1.0.2
	libgif.so.7 -> libgif.so.7.2.0
	libfdk-aac.so.2 -> libfdk-aac.so.2.0.2
	liburcu-bp.so.8 -> liburcu-bp.so.8.1.0
	libabsl_hash.so.2308.0.0 -> libabsl_hash.so.2308.0.0
	libboost_program_options.so.1.83.0 -> libboost_program_options.so.1.83.0
	libQt5EglFsKmsSupport.so.5 -> libQt5EglFsKmsSupport.so.5.15.11
	libdvdcss.so.2 -> libdvdcss.so.2.2.0
	libobs-scripting.so.1 -> libobs-scripting.so.30
	libKF5Wallet.so.5 -> libKF5Wallet.so.5.113.0
	libproc2.so.0 -> libproc2.so.0.0.2
	libaudit.so.1 -> libaudit.so.1.0.0
	libpcre16.so.0 -> libpcre16.so.0.2.13
	libpci.so.3 -> libpci.so.3.10.0
	libldb.so.2 -> libldb.so.2.8.0
	libavutil.so.58 -> libavutil.so.58.29.100
	libusbmuxd-2.0.so.6 -> libusbmuxd-2.0.so.6.0.0
	libcord.so.1 -> libcord.so.1.5.0
	libxfce4util.so.7 -> libxfce4util.so.7.0.0
	libabsl_flags_internal.so.2308.0.0 -> libabsl_flags_internal.so.2308.0.0
	libdcerpc-samr.so.0 -> libdcerpc-samr.so.0.0.1
	libnetsnmpmibs.so.40 -> libnetsnmpmibs.so.40.1.0
	libxmlb.so.2 -> libxmlb.so.2.0.0
	libvpx.so.8 -> libvpx.so.8.0.1
	libabsl_flags_commandlineflag_internal.so.2308.0.0 -> libabsl_flags_commandlineflag_internal.so.2308.0.0
	libgdkmm-3.0.so.1 -> libgdkmm-3.0.so.1.1.0
	librubberband.so.2 -> librubberband.so.2.3.0
	libtexlua53.so.5 -> libtexlua53.so.5.3.6
	libnfnetlink.so.0 -> libnfnetlink.so.0.2.0
	libcryptsetup.so.12 -> libcryptsetup.so.12.9.0
	libduktape.so.207 -> libduktape.so.207.20700
	libpaper.so.2 -> libpaper.so.2.1.2
	libgupnp-1.6.so.0 -> libgupnp-1.6.so.0.106.6
	libcairomm-1.0.so.1 -> libcairomm-1.0.so.1.4.0
	libsuitesparse_gpuruntime.so.3 -> libsuitesparse_gpuruntime.so.3.2.1
	libaccounts-glib.so.0 -> libaccounts-glib.so.1.25
	libKF5Purpose.so.5 -> libKF5Purpose.so.5.113.0
	libqca-qt5.so.2 -> libqca-qt5.so.2.3.7
	libcxsparse.so.4 -> libcxsparse.so.4.2.1
	libswresample.so.3 -> libswresample.so.3.9.100
	libgts-0.7.so.5 -> libgts.so
	libnghttp2.so.14 -> libnghttp2.so.14.25.1
	libsigc-2.0.so.0 -> libsigc-2.0.so.0.0.0
	liburcu-common.so.8 -> liburcu-common.so.8.1.0
	libmpi.so.40 -> libmpi.so.40.30.5
	libbd_crypto.so.3 -> libbd_crypto.so.3.0.0
	libgutenprintui2.so.2 -> libgutenprintui2.so.2.5.0
	libv4l2rds.so.0 -> libv4l2rds.so.0.0.0
	libpython3.11.so.1.0 -> libpython3.11.so.1.0
	libshiboken6.abi3.so.6.6 -> libshiboken6.abi3.so.6.6.1
	libabsl_low_level_hash.so.2308.0.0 -> libabsl_low_level_hash.so.2308.0.0
	libtalloc.so.2 -> libtalloc.so.2.4.1
	libjasper.so.7 -> libjasper.so.7.0.0
	libboost_stacktrace_addr2line.so.1.83.0 -> libboost_stacktrace_addr2line.so.1.83.0
	libboost_system.so.1.83.0 -> libboost_system.so.1.83.0
	libQt6Core5Compat.so.6 -> libQt6Core5Compat.so.6.6.1
	libabsl_bad_variant_access.so.2308.0.0 -> libabsl_bad_variant_access.so.2308.0.0
	libSPVRemapper.so.13 -> libSPVRemapper.so.13.1.1
	libburn.so.4 -> libburn.so.4.109.0
	libwebkit2gtk-4.0.so.37 -> libwebkit2gtk-4.0.so.37.67.7
	libKF5ThreadWeaver.so.5 -> libKF5ThreadWeaver.so.5.113.0
	libhwy_test.so.1 -> libhwy_test.so.1.0.7
	libgnome-bg-4.so.2 -> libgnome-bg-4.so.2.1.0
	libPyImath_Python3_11-3_1.so.29 -> libPyImath_Python3_11-3_1.so.29.8.0
	libQt6LabsWavefrontMesh.so.6 -> libQt6LabsWavefrontMesh.so.6.6.1
	libdouble-conversion.so.3 -> libdouble-conversion.so.3.3.0
	libSoundTouch.so.2 -> libSoundTouch.so.2.3.2
	libntfs-3g.so.89 -> libntfs-3g.so.89.0.0
	libQt6LabsSettings.so.6 -> libQt6LabsSettings.so.6.6.1
	libpath_utils.so.1 -> libpath_utils.so.1.0.1
	libndr.so.3 -> libndr.so.3.0.1
	libabsl_stacktrace.so.2308.0.0 -> libabsl_stacktrace.so.2308.0.0
	libmousepad.so.0 -> libmousepad.so.0.0.0
	libtss2-tcti-libtpms.so.0 -> libtss2-tcti-libtpms.so.0.0.0
	libbfd-2.41.0.so -> libbfd-2.41.0.so
	libnl-genl-3.so.200 -> libnl-genl-3.so.200.26.0
	liburcu-cds.so.8 -> liburcu-cds.so.8.1.0
	libdvdnav.so.4 -> libdvdnav.so.4.3.0
	libabsl_cord_internal.so.2308.0.0 -> libabsl_cord_internal.so.2308.0.0
	libgeoclue-2.so.0 -> libgeoclue-2.so.0.0.0
	libslang.so.2 -> libslang.so.2.3.3
	libgnomekbdui.so.8 -> libgnomekbdui.so.8.0.0
	libaudqt.so.2 -> libaudqt.so.2.4.0
	libcdda_interface.so.0 -> libcdda_interface.so.0.10.2
	libabsl_exponential_biased.so.2308.0.0 -> libabsl_exponential_biased.so.2308.0.0
	libvpl.so.2 -> libvpl.so.2.10
	libtss2-tcti-spi-helper.so.0 -> libtss2-tcti-spi-helper.so.0.0.0
	libgtkmm-3.0.so.1 -> libgtkmm-3.0.so.1.1.0
	libgvc.so.6 -> libgvc.so.6.0.0
	libamd.so.3 -> libamd.so.3.2.1
	libicalss_cxx.so.3 -> libicalss_cxx.so.3.0.17
	libabsl_flags_usage_internal.so.2308.0.0 -> libabsl_flags_usage_internal.so.2308.0.0
	libbd_nvme.so.3 -> libbd_nvme.so.3.0.0
	libgimpbase-2.0.so.0 -> libgimpbase-2.0.so.0.1000.36
	libgettextlib-0.22.4.so -> libgettextlib.so
	libpamac.so.11 -> libpamac.so.11.6
	libsidplay.so.1 -> libsidplay.so.1.0.3
	libnftables.so.1 -> libnftables.so.1.1.0
	libKF5Solid.so.5 -> libKF5Solid.so.5.113.0
	libgstpbutils-1.0.so.0 -> libgstpbutils-1.0.so.0.2208.0
	libdbusmenu-qt5.so.2 -> libdbusmenu-qt5.so.2.6.0
	libpamac-flatpak.so.11 -> libpamac-flatpak.so.11.6
	libnma.so.0 -> libnma.so.0.0.0
	libpamac-gtk.so -> libpamac-gtk.so
	libcares.so.2 -> libcares.so.2.9.0
	libQt5Positioning.so.5 -> libQt5Positioning.so.5.15.11
	libexif.so.12 -> libexif.so.12.3.4
	libjackserver.so.0 -> libjackserver.so.0.1.0
	libgs.so.10 -> libgs.so.10.02
	libx264.so.164 -> libx264.so.164
	libgprofng.so.0 -> libgprofng.so.0.0.0
	libgraphblas.so.8 -> libgraphblas.so.8.2.1
	libKF5Auth.so.5 -> libKF5Auth.so.5.113.0
	libopenrawgnome.so.9 -> libopenrawgnome.so.9.0.7
	libGraphicsMagick.so.3 -> libGraphicsMagick.so.3.24.4
	libabsl_bad_optional_access.so.2308.0.0 -> libabsl_bad_optional_access.so.2308.0.0
	liblqr-1.so.0 -> liblqr-1.so.0.3.2
	libabsl_cordz_handle.so.2308.0.0 -> libabsl_cordz_handle.so.2308.0.0
	libmpeg2convert.so.0 -> libmpeg2convert.so.0.0.0
	libcaca++.so.0 -> libcaca++.so.0.99.20
	libopenconnect.so.5 -> libopenconnect.so.5.9.0
	libdns_sd.so.1 -> libdns_sd.so.1.0.0
	libprotobuf.so.25 -> libprotobuf.so.25.1.0
	libtsan.so.2 -> libtsan.so.2.0.0
	libcdio++.so.1 -> libcdio++.so.1.0.0
	libsrt.so.1.5 -> libsrt.so.1.5.3
	libgcr-ui-3.so.1 -> libgcr-ui-3.so.1.0.0
	libjsoncpp.so.25 -> libjsoncpp.so.25
	libnewt.so.0.52 -> libnewt.so.0.52.23
	libdb_cxx-6.2.so -> libdb_cxx.so
	librevenge-0.0.so.0 -> librevenge-0.0.so.0.0.5
	libKF5I18n.so.5 -> libKF5I18n.so.5.113.0
	libefisec.so.1 -> libefisec.so.1.38
	libicalss.so.3 -> libicalss.so.3.0.17
	libpoppler-cpp.so.0 -> libpoppler-cpp.so.0.11.0
	libmalcontent-0.so.0 -> libmalcontent-0.so.0.11.1
	libmpfr.so.6 -> libmpfr.so.6.2.1
	libical.so.3 -> libical.so.3.0.17
	libKF5Archive.so.5 -> libKF5Archive.so.5.113.0
	libabsl_kernel_timeout_internal.so.2308.0.0 -> libabsl_kernel_timeout_internal.so.2308.0.0
	libKF5ConfigCore.so.5 -> libKF5ConfigCore.so.5.113.0
	libabsl_random_internal_platform.so.2308.0.0 -> libabsl_random_internal_platform.so.2308.0.0
	libabsl_malloc_internal.so.2308.0.0 -> libabsl_malloc_internal.so.2308.0.0
	libKF5JSApi.so.5 -> libKF5JSApi.so.5.113.0
	libgimpui-2.0.so.0 -> libgimpui-2.0.so.0.1000.36
	libini_config.so.5 -> libini_config.so.5.2.1
	libgnomekbd.so.8 -> libgnomekbd.so.8.0.0
	libcaca.so.0 -> libcaca.so.0.99.20
	libGraphicsMagickWand.so.2 -> libGraphicsMagickWand.so.2.9.8
	libflatpak.so.0 -> libflatpak.so.0.11506.0
	libabsl_status.so.2308.0.0 -> libabsl_status.so.2308.0.0
	libmca_common_sm.so.40 -> libmca_common_sm.so.40.30.0
	libproxy.so.1 -> libproxy.so.1
	libfluidsynth.so.3 -> libfluidsynth.so.3.2.2
	libaudtag.so.3 -> libaudtag.so.3.0.0
	libcdio_cdda.so.2 -> libcdio_cdda.so.2.0.0
	libjxl.so.0.8 -> libjxl.so.0.8.2
	libgdbm_compat.so.4 -> libgdbm_compat.so.4.0.0
	libcdt.so.5 -> libcdt.so.5.0.0
	libgdbm.so.6 -> libgdbm.so.6.0.0
	libtumbler-1.so.0 -> libtumbler-1.so.0.0.0
	libabsl_city.so.2308.0.0 -> libabsl_city.so.2308.0.0
	libQt6Xml.so.6 -> libQt6Xml.so.6.6.1
	libgtop-2.0.so.11 -> libgtop-2.0.so.11.1.0
	libjxl_jni.so -> libjxl_jni.so
	libOpenEXRCore-3_2.so.31 -> libOpenEXRCore.so
	libgegl-sc-0.4.so -> libgegl-sc-0.4.so
	libsignon-plugins.so.1 -> libsignon-plugins.so.1.0.0
	libabsl_base.so.2308.0.0 -> libabsl_base.so.2308.0.0
	libabsl_crc_internal.so.2308.0.0 -> libabsl_crc_internal.so.2308.0.0
	libprotobuf-c.so.1 -> libprotobuf-c.so.1.0.0
	libsubid.so.4 -> libsubid.so.4.0.0
	libbcg729.so.0 -> libbcg729.so.0
	libappstream-glib.so.8 -> libappstream-glib.so.8.0.10
	libsamdb.so.0 -> libsamdb.so.0.0.1
	libnetsnmphelpers.so.40 -> libnetsnmphelpers.so.40.1.0
	libraw.so.23 -> libraw.so.23.0.0
	libfftw3f_threads.so.3 -> libfftw3f_threads.so.3.6.10
	libndr-standard.so.0 -> libndr-standard.so.0.0.1
	libx265.so.199 -> libx265.so.199
	libsoup-3.0.so.0 -> libsoup-3.0.so.0.7.1
	libsecret-1.so.0 -> libsecret-1.so.0.0.0
	libKF5ItemViews.so.5 -> libKF5ItemViews.so.5.113.0
	libgstriff-1.0.so.0 -> libgstriff-1.0.so.0.2208.0
	libsamba-util.so.0 -> libsamba-util.so.0.0.1
	libsignon-plugins-common.so.1 -> libsignon-plugins-common.so.1.0.0
	libboost_regex.so.1.83.0 -> libboost_regex.so.1.83.0
	libmono-profiler-coverage.so.0 -> libmono-profiler-coverage.so.0.0.0
	libabsl_periodic_sampler.so.2308.0.0 -> libabsl_periodic_sampler.so.2308.0.0
	libbasicobjects.so.0 -> libbasicobjects.so.0.1.0
	libavc1394.so.0 -> libavc1394.so.0.3.0
	libndp.so.0 -> libndp.so.0.2.0
	libopusurl.so.0 -> libopusurl.so.0.4.5
	libQt5Qml.so.5 -> libQt5Qml.so.5.15.11
	liblua5.3.so.5.3 -> liblua5.3.so.5.3.6
	libQt6LabsSharedImage.so.6 -> libQt6LabsSharedImage.so.6.6.1
	libcholmod.so.5 -> libcholmod.so.5.0.1
	libKF5Codecs.so.5 -> libKF5Codecs.so.5.113.0
	libspqr.so.4 -> libspqr.so.4.2.2
	libmpg123.so.0 -> libmpg123.so.0.48.1
	libRmath.so -> libRmath.so
	libpskc.so.0 -> libpskc.so.0.0.1
	libboost_nowide.so.1.83.0 -> libboost_nowide.so.1.83.0
	libtrampoline.so.1 -> libtrampoline.so.1.0.3
	libMonoSupportW.so -> libMonoSupportW.so
	libINIReader.so.0 -> libINIReader.so.0
	libtag_c.so.0 -> libtag_c.so.0.0.0
	libboost_math_tr1f.so.1.83.0 -> libboost_math_tr1f.so.1.83.0
	libgphoto2_port.so.12 -> libgphoto2_port.so.12.2.0
	libreadline.so.8 -> libreadline.so.8.2
	libts.so.0 -> libts.so.0.10.4
	libevdev.so.2 -> libevdev.so.2.3.0
	libmvec.so.1 -> libmvec.so.1
	libsnmp.so.40 -> libsnmp.so.40.1.0
	libabsl_flags_reflection.so.2308.0.0 -> libabsl_flags_reflection.so.2308.0.0
	libhwy_contrib.so.1 -> libhwy_contrib.so.1.0.7
	libKF5Parts.so.5 -> libKF5Parts.so.5.113.0
	libabsl_civil_time.so.2308.0.0 -> libabsl_civil_time.so.2308.0.0
	libnss_mdns_minimal.so.2 -> libnss_mdns_minimal.so.2
	libvte-2.91.so.0 -> libvte-2.91.so.0.7400.2
	libgiomm-2.4.so.1 -> libgiomm-2.4.so.1.3.0
	libQt6Widgets.so.6 -> libQt6Widgets.so.6.6.1
	libavutil.so.56 -> libavutil.so.56.70.100
	libpangomm-1.4.so.1 -> libpangomm-1.4.so.1.0.30
	libpolkit-gobject-1.so.0 -> libpolkit-gobject-1.so.0.0.0
	libutempter.so.0 -> libutempter.so.1.2.1
	libevent_extra-2.1.so.7 -> libevent_extra.so
	libpyldb-util.cpython-311-x86-64-linux-gnu.so.2 -> libpyldb-util.cpython-311-x86-64-linux-gnu.so.2.8.0
	libfarstream-0.2.so.5 -> libfarstream-0.2.so.5.1.1
	libref_array.so.1 -> libref_array.so.1.2.1
	libQt6MultimediaWidgets.so.6 -> libQt6MultimediaWidgets.so.6.6.1
	libboost_python311.so.1.83.0 -> libboost_python311.so.1.83.0
	libpcap.so.1 -> libpcap.so.1.10.4
	libaio.so.1 -> libaio.so.1.0.2
	libzvbi-chains.so.0 -> libzvbi-chains.so.0.0.0
	libpcre32.so.0 -> libpcre32.so.0.0.13
	liburing-ffi.so.2 -> liburing-ffi.so.2.5
	libabsl_graphcycles_internal.so.2308.0.0 -> libabsl_graphcycles_internal.so.2308.0.0
	libteam.so.5 -> libteam.so.5.6.2
	libgme.so.0 -> libgme.so.0.6.3
	libglslang.so.13 -> libglslang.so.13.1.1
	libjansson.so.4 -> libjansson.so.4.14.0
	libtss2-tctildr.so.0 -> libtss2-tctildr.so.0.0.0
	libsoup-2.4.so.1 -> libsoup-2.4.so.1.11.2
	libabsl_cord.so.2308.0.0 -> libabsl_cord.so.2308.0.0
	libthunarx-3.so.0 -> libthunarx-3.so.0.0.0
	libdb_stl-6.2.so -> libdb_stl.so
	libdaxctl.so.1 -> libdaxctl.so.1.2.5
	libKF5WidgetsAddons.so.5 -> libKF5WidgetsAddons.so.5.113.0
	libppd.so.2 -> libppd.so.2.0.0
	liblzo2.so.2 -> liblzo2.so.2.0.0
	libgirepository-1.0.so.1 -> libgirepository-1.0.so.1.0.0
	libboost_json.so.1.83.0 -> libboost_json.so.1.83.0
	libabsl_log_internal_globals.so.2308.0.0 -> libabsl_log_internal_globals.so.2308.0.0
	libtar.so.0 -> libtar.so.0.0.0
	libwebpmux.so.3 -> libwebpmux.so.3.0.13
	libabsl_log_internal_proto.so.2308.0.0 -> libabsl_log_internal_proto.so.2308.0.0
	libqmi-glib.so.5 -> libqmi-glib.so.5.10.0
	libopusfile.so.0 -> libopusfile.so.0.4.5
	libteamdctl.so.0 -> libteamdctl.so.0.1.6
	libfftw3l_mpi.so.3 -> libfftw3l_mpi.so.3.6.10
	libdhash.so.1 -> libdhash.so.1.1.0
	libbd_fs.so.3 -> libbd_fs.so.3.0.0
	libgstsctp-1.0.so.0 -> libgstsctp-1.0.so.0.2208.0
	libassuan.so.0 -> libassuan.so.0.8.6
	libgck-2.so.2 -> libgck-2.so.2.1.0
	libomxil-bellagio.so.0 -> libomxil-bellagio.so.0.0.0
	libb2.so.1 -> libb2.so.1.0.4
	libduktaped.so.207 -> libduktaped.so.207.20700
	libv4l2.so.0 -> libv4l2.so.0.0.0
	libv4l2tracer.so -> libv4l2tracer.so
	libmd4c-html.so.0 -> libmd4c-html.so.0.4.8
	libpamac-appstream.so.11 -> libpamac-appstream.so.11.6
	libdb-6.2.so -> libdb.so
	libgailutil.so.18 -> libgailutil.so.18.0.1
	libabsl_hashtablez_sampler.so.2308.0.0 -> libabsl_hashtablez_sampler.so.2308.0.0
	libQt5Test.so.5 -> libQt5Test.so.5.15.11
	libip4tc.so.2 -> libip4tc.so.2.0.0
	libprofiler.so.0 -> libprofiler.so.0.5.9
	libKF5Activities.so.5 -> libKF5Activities.so.5.113.0
	libKF5QuickAddons.so.5 -> libKF5QuickAddons.so.5.113.0
	libabsl_flags_parse.so.2308.0.0 -> libabsl_flags_parse.so.2308.0.0
	libpoppler-qt5.so.1 -> libpoppler-qt5.so.1.33.0
	libgcr-4.so.4 -> libgcr-4.so.4.1.0
	libnss_winbind.so.2 -> libnss_winbind.so.2
	libgsf-1.so.114 -> libgsf-1.so.114.0.51
	libmnl.so.0 -> libmnl.so.0.2.0
	libkaccounts.so.2 -> libkaccounts.so.23.08.4
	libabsl_random_internal_randen.so.2308.0.0 -> libabsl_random_internal_randen.so.2308.0.0
	libgettextsrc-0.22.4.so -> libgettextsrc.so
	libcpupower.so.1 -> libcpupower.so.0.0.1
	libgnome-desktop-3.so.20 -> libgnome-desktop-3.so.20.0.0
	libsamba-policy.cpython-311-x86-64-linux-gnu.so.0 -> libsamba-policy.cpython-311-x86-64-linux-gnu.so.0.0.1
	libbsd.so.0 -> libbsd.so.0.11.7
	libbtf.so.2 -> libbtf.so.2.2.1
	libgphoto2.so.6 -> libgphoto2.so.6.3.0
	libmagic.so.1 -> libmagic.so.1.0.0
	libappstream.so.5 -> libappstream.so.1.0.1
	libdcerpc-server-core.so.0 -> libdcerpc-server-core.so.0.0.1
	libdevmapper-event.so.1.02 -> libdevmapper-event.so.1.02
	libQt6LabsFolderListModel.so.6 -> libQt6LabsFolderListModel.so.6.6.1
	libtevent-util.so.0 -> libtevent-util.so.0.0.1
	libgtk-layer-shell.so.0 -> libgtk-layer-shell.so.0.8.1
	libgstapp-1.0.so.0 -> libgstapp-1.0.so.0.2208.0
	libcollection.so.4 -> libcollection.so.4.1.1
	libkmod.so.2 -> libkmod.so.2.4.1
	libuv.so.1 -> libuv.so.1.0.0
	libabsl_cordz_sample_token.so.2308.0.0 -> libabsl_cordz_sample_token.so.2308.0.0
	libenchant-2.so.2 -> libenchant-2.so.2.6.4
	libnss_mdns6.so.2 -> libnss_mdns6.so.2
	libgtkspell.so.0 -> libgtkspell.so.0.0.0
	libpathplan.so.4 -> libpathplan.so.4.0.0
	libsnapd-glib-2.so.1 -> libsnapd-glib-2.so.1.0.0
	libbytesize.so.1 -> libbytesize.so.1.0.0
	libabsl_log_globals.so.2308.0.0 -> libabsl_log_globals.so.2308.0.0
	libsnapd-qt-2.so.1 -> libsnapd-qt-2.so.1.0.0
	libabsl_flags.so.2308.0.0 -> libabsl_flags.so.2308.0.0
	libdca.so.0 -> libdca.so.0.0.0
	libKF5GlobalAccelPrivate.so.5 -> libKF5GlobalAccelPrivate.so.5.113.0
	libQt5DesignerComponents.so.5 -> libQt5DesignerComponents.so.5.15.11
	libltc.so.11 -> libltc.so.11.2.0
	libQt5WaylandClient.so.5 -> libQt5WaylandClient.so.5.15.11
	libmatroska.so.7 -> libmatroska.so.7.0.0
	libxtables.so.12 -> libxtables.so.12.7.0
	libverto-libevent.so.1 -> libverto-libevent.so.1.0.0
	libisofs.so.6 -> libisofs.so.6.92.0
	libpamac-aur.so.11 -> libpamac-aur.so.11.6
	libKF5JS.so.5 -> libKF5JS.so.5.113.0
	libabsl_flags_config.so.2308.0.0 -> libabsl_flags_config.so.2308.0.0
	libstartup-notification-1.so.0 -> libstartup-notification-1.so.0.0.0
	liba52.so.0 -> liba52.so.0.0.0
	libabsl_log_severity.so.2308.0.0 -> libabsl_log_severity.so.2308.0.0
	libaoss.so.0 -> libaoss.so.0.0.0
	libKF5KExiv2.so.15.0.0 -> libKF5KExiv2.so.5.0.0
	libjson-glib-1.0.so.0 -> libjson-glib-1.0.so.0.800.0
	libabsl_scoped_mock_log.so.2308.0.0 -> libabsl_scoped_mock_log.so.2308.0.0
	libbabl-0.1.so.0 -> libbabl-0.1.so.0.205.1
	libevent_openssl-2.1.so.7 -> libevent_openssl.so
	libQt6Svg.so.6 -> libQt6Svg.so.6.6.1
	libinput.so.10 -> libinput.so.10.13.0
	liblirc_client.so.0 -> liblirc_client.so.0.6.0
	libbotan-2.so.19 -> libbotan-2.so.19.19.3
	libgstnet-1.0.so.0 -> libgstnet-1.0.so.0.2208.0
	libfaad.so.2 -> libfaad.so.2.11.1
	libalpm.so.13 -> libalpm.so.13.0.2
	libboost_iostreams.so.1.83.0 -> libboost_iostreams.so.1.83.0
	libldl.so.3 -> libldl.so.3.2.1
	libabsl_random_distributions.so.2308.0.0 -> libabsl_random_distributions.so.2308.0.0
	libgcr-base-3.so.1 -> libgcr-base-3.so.1.0.0
	libpmix.so.2 -> libpmix.so.2.9.2
	libnet.so.9 -> libnet.so.9.0.0
	libavif.so.16 -> libavif.so.16.0.3
	libXpm.so.4 -> libXpm.so.4.11.0
	libgupnp-igd-1.6.so.0 -> libgupnp-igd-1.6.so.0.0.0
	libjavascriptcoregtk-4.1.so.0 -> libjavascriptcoregtk-4.1.so.0.4.13
	libQt6QuickControls2.so.6 -> libQt6QuickControls2.so.6.6.1
	libtss2-mu.so.0 -> libtss2-mu.so.0.0.1
	libnss_mdns4_minimal.so.2 -> libnss_mdns4_minimal.so.2
	libboost_random.so.1.83.0 -> libboost_random.so.1.83.0
	libgutenprint.so.9 -> libgutenprint.so.9.5.0
	libjack.so.0 -> libjack.so.0.1.0
	libKF5I18nLocaleData.so.5 -> libKF5I18nLocaleData.so.5.113.0
	libQt6QuickDialogs2.so.6 -> libQt6QuickDialogs2.so.6.6.1
	libcap-ng.so.0 -> libcap-ng.so.0.0.0
	libsamba-hostconfig.so.0 -> libsamba-hostconfig.so.0.0.1
	libKF5TextWidgets.so.5 -> libKF5TextWidgets.so.5.113.0
	libfftw3_threads.so.3 -> libfftw3_threads.so.3.6.10
	libfftw3q_threads.so.3 -> libfftw3q_threads.so.3.6.10
	libsbc.so.1 -> libsbc.so.1.3.1
	libportaudiocpp.so.0 -> libportaudiocpp.so.0.0.12
	libiec61883.so.0 -> libiec61883.so.0.1.1
	libabsl_flags_marshalling.so.2308.0.0 -> libabsl_flags_marshalling.so.2308.0.0
	libkwalletbackend5.so.5 -> libkwalletbackend5.so.5.113.0
	libecryptfs.so.1 -> libecryptfs.so.1.0.0
	libabsl_demangle_internal.so.2308.0.0 -> libabsl_demangle_internal.so.2308.0.0
	libQt6QuickLayouts.so.6 -> libQt6QuickLayouts.so.6.6.1
	libfl.so.2 -> libfl.so.2.0.0
	libKF5Notifications.so.5 -> libKF5Notifications.so.5.113.0
	libyelp.so.0 -> libyelp.so.0.0.0
	libnpth.so.0 -> libnpth.so.0.1.2
	libpyside6qml.abi3.so.6.6 -> libpyside6qml.abi3.so.6.6.1
	libarchive.so.13 -> libarchive.so.13.7.2
	libboost_type_erasure.so.1.83.0 -> libboost_type_erasure.so.1.83.0
	libgraphene-1.0.so.0 -> libgraphene-1.0.so.0.1000.8
	libQt6QuickEffects.so.6 -> libQt6QuickEffects.so.6.6.1
	libabsl_flags_commandlineflag.so.2308.0.0 -> libabsl_flags_commandlineflag.so.2308.0.0
	libnftnl.so.11 -> libnftnl.so.11.6.0
	libmbedcrypto.so.14 -> libmbedcrypto.so.3.4.1
	libQt6QmlWorkerScript.so.6 -> libQt6QmlWorkerScript.so.6.6.1
	libdjvulibre.so.21 -> libdjvulibre.so.21.7.0
	libphonon4qt5.so.4 -> libphonon4qt5.so.4.12.0
	libnm.so.0 -> libnm.so.0.1.0
	libxmlsec1.so.1 -> libxmlsec1.so.1.2.37
	libusb-1.0.so.0 -> libusb-1.0.so.0.3.0
	libfuse.so.2 -> libfuse.so.2.9.9
	libpurple.so.0 -> libpurple.so.0.14.12
	libabsl_throw_delegate.so.2308.0.0 -> libabsl_throw_delegate.so.2308.0.0
	libyuv.so -> libyuv.so
	libkeybinder-3.0.so.0 -> libkeybinder-3.0.so.0.0.0
	libIlmThread-3_2.so.31 -> libIlmThread.so
	libQt5EglFSDeviceIntegration.so.5 -> libQt5EglFSDeviceIntegration.so.5.15.11
	libdconf.so.1 -> libdconf.so.1.0.0
	libboost_wave.so.1.83.0 -> libboost_wave.so.1.83.0
	libgimpwidgets-2.0.so.0 -> libgimpwidgets-2.0.so.0.1000.36
	libgit2.so.1.7 -> libgit2.so.1.7.1
	libswresample.so.4 -> libswresample.so.4.12.100
	libgnome-desktop-4.so.2 -> libgnome-desktop-4.so.2.1.0
	libQt6XcbQpa.so.6 -> libQt6XcbQpa.so.6.6.1
	libadwaita-1.so.0 -> libadwaita-1.so.0
	libQt6QmlCore.so.6 -> libQt6QmlCore.so.6.6.1
	libgctba.so.1 -> libgctba.so.1.5.0
	libXv.so.1 -> libXv.so.1.0.0
	libSPIRV-Tools-reduce.so -> libSPIRV-Tools-reduce.so
	libmpd.so.1 -> libmpd.so.1.3.0
	libgadu.so.3 -> libgadu.so.3.13.0
	libtcmalloc_and_profiler.so.4 -> libtcmalloc_and_profiler.so.4.6.9
	libWPEBackend-fdo-1.0.so.1 -> libWPEBackend-fdo-1.0.so.1.9.4
	libdc1394.so.26 -> libdc1394.so.26.0.1
	libboost_log.so.1.83.0 -> libboost_log.so.1.83.0
	libaom.so.3 -> libaom.so.3.8.0
	libgimpmodule-2.0.so.0 -> libgimpmodule-2.0.so.0.1000.36
	libQt6QmlXmlListModel.so.6 -> libQt6QmlXmlListModel.so.6.6.1
	libnl-cli-3.so.200 -> libnl-cli-3.so.200.26.0
	libSPIRV.so.13 -> libSPIRV.so.13.1.1
	libOpenEXRUtil-3_2.so.31 -> libOpenEXRUtil.so
	libnice.so.10 -> libnice.so.10.13.1
	libshout.so.3 -> libshout.so.3.2.0
	libQt5QuickControls2.so.5 -> libQt5QuickControls2.so.5.15.11
	libKF5KIONTLM.so.5 -> libKF5KIONTLM.so.5.113.0
	libwmflite-0.2.so.7 -> libwmflite.so
	libavcall.so.1 -> libavcall.so.1.1.0
	libheif.so.1 -> libheif.so.1.17.6
	libguile-3.0.so.1 -> libguile-3.0.so.1.6.0
	libsamplerate.so.0 -> libsamplerate.so.0.2.2
	libabsl_debugging_internal.so.2308.0.0 -> libabsl_debugging_internal.so.2308.0.0
	libKF5AuthCore.so.5 -> libKF5AuthCore.so.5.113.0
	libQt5Xml.so.5 -> libQt5Xml.so.5.15.11
	libspex.so.2 -> libspex.so.2.2.1
	libluajit-5.1.so.2 -> libluajit-5.1.so.2.1.1702233742
	libmpeg2.so.0 -> libmpeg2.so.0.1.0
	libQt5Location.so.5 -> libQt5Location.so.5.15.11
	libabsl_leak_check.so.2308.0.0 -> libabsl_leak_check.so.2308.0.0
	libtevent.so.0 -> libtevent.so.0.15.0
	libdevmapper-event-lvm2.so.2.03 -> libdevmapper-event-lvm2.so.2.03
	libxcb-ewmh.so.2 -> libxcb-ewmh.so.2.0.0
	libmarkdown.so.3 -> libmarkdown.so.3.0.0
	libwpd-0.10.so.10 -> libwpd-0.10.so.10.0.3
	libwpe-1.0.so.1 -> libwpe-1.0.so.1.8.1
	libzbar.so.0 -> libzbar.so.0.3.0
	libspeex.so.1 -> libspeex.so.1.5.2
	libgraphite2.so.3 -> libgraphite2.so.3.2.1
	libgc.so.1 -> libgc.so.1.5.2
	libxmlsec1-nss.so.1 -> libxmlsec1-nss.so.1.2.37
	libKF5KCMUtilsCore.so.5 -> libKF5KCMUtilsCore.so.5.113.0
	libboost_graph.so.1.83.0 -> libboost_graph.so.1.83.0
	libpamac-snap.so.11 -> libpamac-snap.so.11.6
	libfftw3.so.3 -> libfftw3.so.3.6.10
	libupnp.so.17 -> libupnp.so.17.1.9
	libndr-krb5pac.so.0 -> libndr-krb5pac.so.0.0.1
	libwebrtc_audio_processing.so.1 -> libwebrtc_audio_processing.so.1.0.0
	libsratom-0.so.0 -> libsratom-0.so.0.6.16
	libabsl_crc_cord_state.so.2308.0.0 -> libabsl_crc_cord_state.so.2308.0.0
	libboost_contract.so.1.83.0 -> libboost_contract.so.1.83.0
	libgtksourceview-3.0.so.1 -> libgtksourceview-3.0.so.1.8.0
	libgstfft-1.0.so.0 -> libgstfft-1.0.so.0.2208.0
	libmhwd.so -> libmhwd.so
	libzmq.so.5 -> libzmq.so.5.2.5
	libxfce4ui-2.so.0 -> libxfce4ui-2.so.0.0.0
	libhidapi-libusb.so.0 -> libhidapi-libusb.so.0.14.0
	liblua.so.5.4 -> liblua5.4.so
	libpipeline.so.1 -> libpipeline.so.1.5.7
	liboath.so.0 -> liboath.so.0.1.3
	libQt5WebChannel.so.5 -> libQt5WebChannel.so.5.15.11
	libobs-opengl.so.1 -> libobs-opengl.so.30
	libglibmm-2.4.so.1 -> libglibmm-2.4.so.1.3.0
	libfftw3_omp.so.3 -> libfftw3_omp.so.3.6.10
	libxdot.so.4 -> libxdot.so.4.0.0
	libabsl_crc32c.so.2308.0.0 -> libabsl_crc32c.so.2308.0.0
	liblirc_driver.so.0 -> liblirc_driver.so.0.3.0
	libostree-1.so.1 -> libostree-1.so.1.0.0
	libpcrecpp.so.0 -> libpcrecpp.so.0.0.2
	libQt5Multimedia.so.5 -> libQt5Multimedia.so.5.15.11
	libcolamd.so.3 -> libcolamd.so.3.2.1
	libbpf.so.1 -> libbpf.so.1.3.0
	libboost_coroutine.so.1.83.0 -> libboost_coroutine.so.1.83.0
	libieee1284.so.3 -> libieee1284.so.3.2.2
	libjacknet.so.0 -> libjacknet.so.0.1.0
	libgnome-menu-3.so.0 -> libgnome-menu-3.so.0.0.1
	libtcmalloc_minimal_debug.so.4 -> libtcmalloc_minimal_debug.so.4.5.14
	libtcmalloc_debug.so.4 -> libtcmalloc_debug.so.4.5.14
	libbluray.so.2 -> libbluray.so.2.4.3
	libavfilter.so.9 -> libavfilter.so.9.12.100
	libcppdap.so -> libcppdap.so
	libmbim-glib.so.4 -> libmbim-glib.so.4.8.0
	libxcb-keysyms.so.1 -> libxcb-keysyms.so.1.0.0
	libbtrfsutil.so.1 -> libbtrfsutil.so.1.2.0
	libHLSL.so.13 -> libHLSL.so.13.1.1
	liburcu-qsbr.so.8 -> liburcu-qsbr.so.8.1.0
	libzbargtk.so.0 -> libzbargtk.so.0.0.2
	libprotobuf-lite.so.25 -> libprotobuf-lite.so.25.1.0
	libabsl_failure_signal_handler.so.2308.0.0 -> libabsl_failure_signal_handler.so.2308.0.0
	libaribb24.so.0 -> libaribb24.so.0.0.0
	libSDL2-2.0.so.0 -> libSDL2.so
	libmtp.so.9 -> libmtp.so.9.4.0
	libXpresent.so.1 -> libXpresent.so.1.0.0
	libsframe.so.1 -> libsframe.so.1.0.0
	libKF5Declarative.so.5 -> libKF5Declarative.so.5.113.0
	libQt6LabsAnimation.so.6 -> libQt6LabsAnimation.so.6.6.1
	libplist++-2.0.so.4 -> libplist++-2.0.so.4.3.0
	libnetsnmp.so.40 -> libnetsnmp.so.40.1.0
	libpolkit-qt5-gui-1.so.1 -> libpolkit-qt5-gui-1.so.1.175.0
	libPhabricatorHelpers.so.5 -> libPhabricatorHelpers.so.5.113.0
	libqrencode.so.4 -> libqrencode.so.4.1.1
	libbd_nvdimm.so.3 -> libbd_nvdimm.so.3.0.0
	libcallback.so.1 -> libcallback.so.1.0.4
	libsoxr.so.0 -> libsoxr.so.0.1.2
	libbs2b.so.0 -> libbs2b.so.0.0.0
	libstilview.so.0 -> libstilview.so.0.0.4
	libtss2-esys.so.0 -> libtss2-esys.so.0.0.1
	libhunspell-1.7.so.0 -> libhunspell.so
	libverto.so.1 -> libverto.so.1.0.0
	libopencore-amrwb.so.0 -> libopencore-amrwb.so.0.0.5
	libopenal.so.1 -> libopenal.so.1.23.1
	libKF5XmlGui.so.5 -> libKF5XmlGui.so.5.113.0
	libgstplay-1.0.so.0 -> libgstplay-1.0.so.0.2208.0
	libijs-0.35.so -> libijs.so
	libexo-2.so.0 -> libexo-2.so.0.1.0
	libsnappy.so.1 -> libsnappy.so.1.1.10
	libboost_chrono.so.1.83.0 -> libboost_chrono.so.1.83.0
	libphonon4qt5experimental.so.4 -> libphonon4qt5experimental.so.4.12.0
	libabsl_flags_private_handle_accessor.so.2308.0.0 -> libabsl_flags_private_handle_accessor.so.2308.0.0
	libumfpack.so.6 -> libumfpack.so.6.2.2
	libxfce4panel-2.0.so.4 -> libxfce4panel-2.0.so.4.0.0
	libgspell-1.so.2 -> libgspell-1.so.2.3.2
	libfftw3l_omp.so.3 -> libfftw3l_omp.so.3.6.10
	libKF5Crash.so.5 -> libKF5Crash.so.5.113.0
	libQt6QuickParticles.so.6 -> libQt6QuickParticles.so.6.6.1
	libreiserfscore.so.0 -> libreiserfscore.so.0.0.0
	libqt5ct-common.so.1.8 -> libqt5ct-common.so.1.8
	libsmbconf.so.0 -> libsmbconf.so.0.0.1
	libswscale.so.7 -> libswscale.so.7.5.100
	libhpipp.so.0 -> libhpipp.so.0.0.1
	libabsl_strerror.so.2308.0.0 -> libabsl_strerror.so.2308.0.0
	libxcb-util.so.1 -> libxcb-util.so.1.0.0
	libavdevice.so.58 -> libavdevice.so.58.13.100
	libavahi-ui-gtk3.so.0 -> libavahi-ui-gtk3.so.0.1.4
	libabsl_random_internal_randen_slow.so.2308.0.0 -> libabsl_random_internal_randen_slow.so.2308.0.0
	libQt6MultimediaQuick.so.6 -> libQt6MultimediaQuick.so.6.6.1
	libindicator3.so.7 -> libindicator3.so.7.0.0
	libtag.so.1 -> libtag.so.1.19.1
	libMagickCore-7.Q16HDRI.so.10 -> libMagickCore-7.Q16HDRI.so.10.0.1
	libabsl_bad_any_cast_impl.so.2308.0.0 -> libabsl_bad_any_cast_impl.so.2308.0.0
	librav1e.so.0.6 -> librav1e.so.0.6.6
	libnetpbm.so.11 -> libnetpbm.so.11.86
	libIntelXvMC.so.1 -> libIntelXvMC.so.1.0.0
	libspandsp.so.2 -> libspandsp.so.2.0.0
	libzvbi.so.0 -> libzvbi.so.0.13.2
	libclang.so.16 -> libclang.so.16.0.6
	libqpdf.so.29 -> libqpdf.so.29.6.4
	libQt6QuickTest.so.6 -> libQt6QuickTest.so.6.6.1
	libabsl_random_internal_randen_hwaes_impl.so.2308.0.0 -> libabsl_random_internal_randen_hwaes_impl.so.2308.0.0
	libharfbuzz-icu.so.0 -> libharfbuzz-icu.so.0.60830.0
	libgstva-1.0.so.0 -> libgstva-1.0.so.0.2208.0
	libical-glib.so.3 -> libical-glib.so.3.0.17
	libfftw3f_mpi.so.3 -> libfftw3f_mpi.so.3.6.10
	libImath-3_1.so.29 -> libImath.so
	libboost_filesystem.so.1.83.0 -> libboost_filesystem.so.1.83.0
	libKF5CalendarEvents.so.5 -> libKF5CalendarEvents.so.5.113.0
	libavahi-qt5.so.1 -> libavahi-qt5.so.1.0.2
	libKF5GlobalAccel.so.5 -> libKF5GlobalAccel.so.5.113.0
	libnfsidmap.so.1 -> libnfsidmap.so.1.0.0
	libglibmm_generate_extra_defs-2.4.so.1 -> libglibmm_generate_extra_defs-2.4.so.1.3.0
	libtexluajit.so.2 -> libtexluajit.so.2.1.0
	libplacebo.so.264 -> libplacebo.so.264
	libgstwebrtc-1.0.so.0 -> libgstwebrtc-1.0.so.0.2208.0
	libwacom.so.9 -> libwacom.so.9.0.0
	libgstvideo-1.0.so.0 -> libgstvideo-1.0.so.0.2208.0
	libkpathsea.so.6 -> libkpathsea.so.6.3.5
	libbd_mdraid.so.3 -> libbd_mdraid.so.3.0.0
	libabsl_log_internal_log_sink_set.so.2308.0.0 -> libabsl_log_internal_log_sink_set.so.2308.0.0
	libQt6Quick3DSpatialAudio.so.6 -> libQt6Quick3DSpatialAudio.so.6.6.1
	libKF5DBusAddons.so.5 -> libKF5DBusAddons.so.5.113.0
	libgstcuda-1.0.so.0 -> libgstcuda-1.0.so.0.2208.0
	libsidplayfp.so.6 -> libsidplayfp.so.6.3.27
	libXvMC.so.1 -> libXvMC.so.1.0.0
	libavcodec.so.58 -> libavcodec.so.58.134.100
	libpython3.so -> libpython3.so
	libhpip.so.0 -> libhpip.so.0.0.1
	libcdr-0.1.so.1 -> libcdr-0.1.so.1.0.7
	libgtk-x11-2.0.so.0 -> libgtk-x11-2.0.so.0.2400.33
	libQt6QmlCompiler.so.6 -> libQt6QmlCompiler.so.6.6.1
	libmad.so.0 -> libmad.so.0.2.1
	liblz4.so.1 -> liblz4.so.1.9.4
	libnl-route-3.so.200 -> libnl-route-3.so.200.26.0
	libfftw3l_threads.so.3 -> libfftw3l_threads.so.3.6.10
	libpyside6.abi3.so.6.6 -> libpyside6.abi3.so.6.6.1
	libgsturidownloader-1.0.so.0 -> libgsturidownloader-1.0.so.0.2208.0
	libdav1d.so.7 -> libdav1d.so.7.0.0
	libraptor2.so.0 -> libraptor2.so.0.0.0
	libiso9660++.so.0 -> libiso9660++.so.0.0.0
	liblavjpeg-2.2.so.0 -> liblavjpeg.so
	libKF5ConfigWidgets.so.5 -> libKF5ConfigWidgets.so.5.113.0
	libabsl_time.so.2308.0.0 -> libabsl_time.so.2308.0.0
	libgsl.so.27 -> libgsl.so.27.0.0
	libgstallocators-1.0.so.0 -> libgstallocators-1.0.so.0.2208.0
	libldacBT_enc.so.2 -> libldacBT_enc.so.2.0.2.3
	libvisio-0.1.so.1 -> libvisio-0.1.so.1.0.7
	libQt6QuickDialogs2QuickImpl.so.6 -> libQt6QuickDialogs2QuickImpl.so.6.6.1
	libxapp.so.1 -> libxapp.so.2.8.1
	libQt6Concurrent.so.6 -> libQt6Concurrent.so.6.6.1
	liblsof.so.0 -> liblsof.so.0.0.0
	libopen-rte.so.40 -> libopen-rte.so.40.30.3
	libmtdev.so.1 -> libmtdev.so.1.0.0
	liburcu-mb.so.8 -> liburcu-mb.so.8.1.0
	libSPIRV-Tools-shared.so -> libSPIRV-Tools-shared.so
	libKF5ConfigQml.so.5 -> libKF5ConfigQml.so.5.113.0
	libgsttag-1.0.so.0 -> libgsttag-1.0.so.0.2208.0
	libspeexdsp.so.1 -> libspeexdsp.so.1.5.2
	libKF5Pty.so.5 -> libKF5Pty.so.5.113.0
	libmm-glib.so.0 -> libmm-glib.so.0.10.0
	libcxl.so.1 -> libcxl.so.1.1.3
	libgstcontroller-1.0.so.0 -> libgstcontroller-1.0.so.0.2208.0
	libfftw3_mpi.so.3 -> libfftw3_mpi.so.3.6.10
	libnfs.so.14 -> libnfs.so.14.0.0
	libcloudproviders.so.0 -> libcloudproviders.so.0.3.5
	libcddb.so.2 -> libcddb.so.2.2.3
	libQt5X11Extras.so.5 -> libQt5X11Extras.so.5.15.11
	libQt6PrintSupport.so.6 -> libQt6PrintSupport.so.6.6.1
	libKF5Package.so.5 -> libKF5Package.so.5.113.0
	libQt6EglFSDeviceIntegration.so.6 -> libQt6EglFSDeviceIntegration.so.6.6.1
	libQt6Network.so.6 -> libQt6Network.so.6.6.1
	libmono-profiler-aot.so.0 -> libmono-profiler-aot.so.0.0.0
	libqrtr-glib.so.0 -> libqrtr-glib.so.0.0.0
	libavfilter.so.7 -> libavfilter.so.7.110.100
	libserd-0.so.0 -> libserd-0.so.0.32.0
	libappstream-compose.so.0 -> libappstream-compose.so.1.0.1
	libmono-profiler-log.so.0 -> libmono-profiler-log.so.0.0.0
	libgstaudio-1.0.so.0 -> libgstaudio-1.0.so.0.2208.0
	liblua5.2.so.5.2 -> liblua5.2.so.5.2.4
	libgstsdp-1.0.so.0 -> libgstsdp-1.0.so.0.2208.0
	libImlib2.so.1 -> libImlib2.so.1.12.1
	libgdk-x11-2.0.so.0 -> libgdk-x11-2.0.so.0.2400.33
	libevent_core-2.1.so.7 -> libevent_core.so
	libQt5WaylandCompositor.so.5 -> libQt5WaylandCompositor.so.5.15.11
	libcolordprivate.so.2 -> libcolordprivate.so.2.0.5
	libpytalloc-util.cpython-311-x86-64-linux-gnu.so.2 -> libpytalloc-util.cpython-311-x86-64-linux-gnu.so.2.4.1
	libMagickWand-7.Q16HDRI.so.10 -> libMagickWand-7.Q16HDRI.so.10.0.1
	libavformat.so.58 -> libavformat.so.58.76.100
	libdb-5.3.so -> libdb-5.3.so
	libpgm-5.3.so.0 -> libpgm.so
	librbio.so.4 -> librbio.so.4.2.1
	libgstinsertbin-1.0.so.0 -> libgstinsertbin-1.0.so.0.2208.0
	libopenjp2.so.7 -> libopenjp2.so.2.5.0
	libQt6Qml.so.6 -> libQt6Qml.so.6.6.1
	libabsl_random_internal_pool_urbg.so.2308.0.0 -> libabsl_random_internal_pool_urbg.so.2308.0.0
	libabsl_string_view.so.2308.0.0 -> libabsl_string_view.so.2308.0.0
	libgegl-0.4.so.0 -> libgegl-0.4.so.0.445.1
	libccolamd.so.3 -> libccolamd.so.3.2.1
	libgstreamer-1.0.so.0 -> libgstreamer-1.0.so.0.2208.0
	libQt5Pdf.so.5 -> libQt5Pdf.so.5.15.15
	libQt6EglFsKmsSupport.so.6 -> libQt6EglFsKmsSupport.so.6.6.1
	libfreeaptx.so.0 -> libfreeaptx.so.0.1.1
	libfuse3.so.3 -> libfuse3.so.3.16.2
	libgccpp.so.1 -> libgccpp.so.1.5.0
	libgstbasecamerabinsrc-1.0.so.0 -> libgstbasecamerabinsrc-1.0.so.0.2208.0
	libboost_stacktrace_basic.so.1.83.0 -> libboost_stacktrace_basic.so.1.83.0
	libdv.so.4 -> libdv.so.4.0.3
	librom1394.so.0 -> librom1394.so.0.3.0
	libmfx.so.1 -> libmfx.so.1.35
	libprotoc.so.25 -> libprotoc.so.25.1.0
	libcamera.so.0.1 -> libcamera.so.0.1.0
	libcc1.so.0 -> libcc1.so.0.0.0
	libefivar.so.1 -> libefivar.so.1.38
	libnl-nf-3.so.200 -> libnl-nf-3.so.200.26.0
	libsyn123.so.0 -> libsyn123.so.0.2.2
	libOkular5Core.so.11 -> libOkular5Core.so.11.0.0
	libKF5JobWidgets.so.5 -> libKF5JobWidgets.so.5.113.0
	libgssdp-1.6.so.0 -> libgssdp-1.6.so.0.106.3
	libgirara-gtk3.so.3 -> libgirara-gtk3.so.3.1
	libcue.so.2 -> libcue.so.2.3.0
	libQt5Quick.so.5 -> libQt5Quick.so.5.15.11
	libgstmpegts-1.0.so.0 -> libgstmpegts-1.0.so.0.2208.0
	libnvme-mi.so.1 -> libnvme-mi.so.1.6.0
	libKF5Service.so.5 -> libKF5Service.so.5.113.0
	libQt5WebEngineCore.so.5 -> libQt5WebEngineCore.so.5.15.15
	libportaudio.so.2 -> libportaudio.so.2.0.0
	libtracker-sparql-3.0.so.0 -> libtracker-sparql-3.0.so.0.600.0
	libtss2-tcti-swtpm.so.0 -> libtss2-tcti-swtpm.so.0.0.0
	libgstphotography-1.0.so.0 -> libgstphotography-1.0.so.0.2208.0
	libgimpconfig-2.0.so.0 -> libgimpconfig-2.0.so.0.1000.36
	libv4lconvert.so.0 -> libv4lconvert.so.0.0.0
	libmypaint.so.0 -> libmypaint.so.0.0.0
	libchromaprint.so.1 -> libchromaprint.so.1.5.1
	libshaderc_shared.so.1 -> libshaderc_shared.so.1
	libgstbadaudio-1.0.so.0 -> libgstbadaudio-1.0.so.0.2208.0
	libgstplayer-1.0.so.0 -> libgstplayer-1.0.so.0.2208.0
	libsamba-credentials.so.1 -> libsamba-credentials.so.1.0.0
	libgck-1.so.0 -> libgck-1.so.0.0.0
	libminizip.so.1 -> libminizip.so.1.0.0
	libzzipfseeko-0.so.13 -> libzzipfseeko.so
	libxcvt.so.0 -> libxcvt.so.0.1.2
	libargon2.so.1 -> libargon2.so.1
	libopencore-amrnb.so.0 -> libopencore-amrnb.so.0.0.5
	libstemmer.so.0 -> libstemmer.so.0.0.0
	libgarcon-gtk3-1.so.0 -> libgarcon-gtk3-1.so.0.0.0
	libsharpyuv.so.0 -> libsharpyuv.so.0.0.1
	libhpdiscovery.so.0 -> libhpdiscovery.so.0.0.1
	libt1x.so.5 -> libt1x.so.5.1.2
	libabsl_random_seed_sequences.so.2308.0.0 -> libabsl_random_seed_sequences.so.2308.0.0
	libQt5OpenGL.so.5 -> libQt5OpenGL.so.5.15.11
	libbluetooth.so.3 -> libbluetooth.so.3.19.11
	libvmaf.so.3 -> libvmaf.so.3.0.0
	libQt6QuickControls2Impl.so.6 -> libQt6QuickControls2Impl.so.6.6.1
	libKF5PurposeWidgets.so.5 -> libKF5PurposeWidgets.so.5.113.0
	libmca_common_monitoring.so.50 -> libmca_common_monitoring.so.50.20.0
	liblab_gamut.so.1 -> liblab_gamut.so.1.0.0
	liblilv-0.so.0 -> liblilv-0.so.0.24.22
	libmpi_mpifh.so.40 -> libmpi_mpifh.so.40.30.0
	libgcab-1.0.so.0 -> libgcab-1.0.so.0.3.0
	libalsatoss.so.0 -> libalsatoss.so.0.0.0
	libdaemon.so.0 -> libdaemon.so.0.5.0
	libfaad_drm.so.2 -> libfaad_drm.so.2.11.1
	libisl.so.23 -> libisl.so.23.3.0
	libsane.so.1 -> libsane.so.1.2.1
	libQt5QuickShapes.so.5 -> libQt5QuickShapes.so.5.15.11
	libwebp.so.7 -> libwebp.so.7.1.8
	libctf.so.0 -> libctf.so.0.0.0
	libgexiv2.so.2 -> libgexiv2.so.2.14.2
	libcamd.so.3 -> libcamd.so.3.2.1
	libxcb-render-util.so.0 -> libxcb-render-util.so.0.0.0
	libxmlsec1-openssl.so.1 -> libxmlsec1-openssl.so.1.2.37
	libnetsnmpagent.so.40 -> libnetsnmpagent.so.40.1.0
	libsysfs.so.2 -> libsysfs.so.2.0.1
	liblua++.so.5.4 -> liblua++5.4.so
	libdbusmenu-gtk3.so.4 -> libdbusmenu-gtk3.so.4.0.12
	libctf-nobfd.so.0 -> libctf-nobfd.so.0.0.0
	libmonosgen-2.0.so.1 -> libmonosgen-2.0.so.1.0.0
	libvlc.so.5 -> libvlc.so.5.6.1
	libboost_mpi_python311.so.1.83.0 -> libboost_mpi_python311.so.1.83.0
	liburcu-signal.so.8 -> liburcu-signal.so.8.1.0
	libbd_lvm.so.3 -> libbd_lvm.so.3.0.0
	libnss_mdns.so.2 -> libnss_mdns.so.2
	libevview3.so.3 -> libevview3.so.3.0.0
	libQt5Gui.so.5 -> libQt5Gui.so.5.15.11
	libboost_math_tr1l.so.1.83.0 -> libboost_math_tr1l.so.1.83.0
	libQt5Network.so.5 -> libQt5Network.so.5.15.11
	libauparse.so.0 -> libauparse.so.0.0.0
	libXaw.so.6 -> libXaw6.so.6.0.1
	libQt5Help.so.5 -> libQt5Help.so.5.15.11
	libxmlsec1-gcrypt.so.1 -> libxmlsec1-gcrypt.so.1.2.37
	libpoppler.so.133 -> libpoppler.so.133.0.0
	libldns.so.3 -> libldns.so.3.5.0
	libpcscspy.so.0 -> libpcscspy.so.0.0.0
	libsuitesparseconfig.so.7 -> libsuitesparseconfig.so.7.3.1
	libblockdev.so.3 -> libblockdev.so.3.0.0
	libpcsclite.so.1 -> libpcsclite.so.1.0.0
	libQt5PdfWidgets.so.5 -> libQt5PdfWidgets.so.5.15.15
	libboost_timer.so.1.83.0 -> libboost_timer.so.1.83.0
	libQt6DBus.so.6 -> libQt6DBus.so.6.6.1
	libraqm.so.0 -> libraqm.so.0.10.1
	libmaxminddb.so.0 -> libmaxminddb.so.0.0.7
	libabsl_spinlock_wait.so.2308.0.0 -> libabsl_spinlock_wait.so.2308.0.0
	libwebpdemux.so.2 -> libwebpdemux.so.2.0.14
	libtss2-sys.so.1 -> libtss2-sys.so.1.0.1
	libcolorhug.so.2 -> libcolorhug.so.2.0.5
	libspectre.so.1 -> libspectre.so.1.1.12
	libgpm.so.2 -> libgpm.so.2.1.0
	libtheoradec.so.1 -> libtheoradec.so.1.1.4
	libQt5QuickTest.so.5 -> libQt5QuickTest.so.5.15.11
	libmpi_usempif08.so.40 -> libmpi_usempif08.so.40.30.0
	libfftw3q.so.3 -> libfftw3q.so.3.6.10
	libwireshark.so.17 -> libwireshark.so.17.0.0
	libusb-0.1.so.4 -> libusb.so
	libsmbclient.so.0 -> libsmbclient.so.0.7.0
	libacl.so.1 -> libacl.so.1.1.2301
	libcgraph.so.6 -> libcgraph.so.6.0.0
	libtss2-policy.so.0 -> libtss2-policy.so.0.0.0
	libxxhash.so.0 -> libxxhash.so.0.8.2
	libQt6QuickTemplates2.so.6 -> libQt6QuickTemplates2.so.6.6.1
	libjavascriptcoregtk-4.0.so.18 -> libjavascriptcoregtk-4.0.so.18.23.13
	libpcreposix.so.0 -> libpcreposix.so.0.0.7
	libmpeg2encpp-2.2.so.0 -> libmpeg2encpp.so
	libabsl_cordz_functions.so.2308.0.0 -> libabsl_cordz_functions.so.2308.0.0
	libQt5QuickWidgets.so.5 -> libQt5QuickWidgets.so.5.15.11
	libQt5Widgets.so.5 -> libQt5Widgets.so.5.15.11
	libinstpatch-1.0.so.2 -> libinstpatch-1.0.so.2.2.0
	libgettextpo.so.0 -> libgettextpo.so.0.5.10
	libjson-c.so.5 -> libjson-c.so.5.3.0
	libevdocument3.so.4 -> libevdocument3.so.4.0.0
	libsignon-extension.so.1 -> libsignon-extension.so.1.0.0
	libxcb-cursor.so.0 -> libxcb-cursor.so.0.0.0
	libavahi-core.so.7 -> libavahi-core.so.7.1.0
	libndctl.so.6 -> libndctl.so.6.1.21
	libseccomp.so.2 -> libseccomp.so.2.5.4
	libKF5Completion.so.5 -> libKF5Completion.so.5.113.0
	libmd.so.0 -> libmd.so.0.1.0
	libQt6LabsQmlModels.so.6 -> libQt6LabsQmlModels.so.6.6.1
	libical_cxx.so.3 -> libical_cxx.so.3.0.17
	libunwind-x86_64.so.8 -> libunwind-x86_64.so.8.0.1
	libpurple-client.so.0 -> libpurple-client.so.0.14.12
	libdmraid.so.1 -> libdmraid.so.1.0.0
	libpolkit-qt5-agent-1.so.1 -> libpolkit-qt5-agent-1.so.1.175.0
	libnl-xfrm-3.so.200 -> libnl-xfrm-3.so.200.26.0
	libboost_math_tr1.so.1.83.0 -> libboost_math_tr1.so.1.83.0
	libcdio.so.19 -> libcdio.so.19.0.0
	libpoppler-glib.so.8 -> libpoppler-glib.so.8.26.0
	libobs.so.0 -> libobs.so.30
	libgusb.so.2 -> libgusb.so.2.0.10
	libabsl_statusor.so.2308.0.0 -> libabsl_statusor.so.2308.0.0
	libavahi-glib.so.1 -> libavahi-glib.so.1.0.2
	libavahi-libevent.so.1 -> libavahi-libevent.so.1.0.0
	libtss2-rc.so.0 -> libtss2-rc.so.0.0.0
	libgstadaptivedemux-1.0.so.0 -> libgstadaptivedemux-1.0.so.0.2208.0
	libbtrfs.so.0 -> libbtrfs.so.0.1
	libdcerpc-server.so.0 -> libdcerpc-server.so.0.0.1
	liborc-test-0.4.so.0 -> liborc-test-0.4.so.0.34.0
	libjbig85.so.2.1 -> libjbig85.so.2.1
	libmicrodns.so.1 -> libmicrodns.so.1.0.0
	libmbedtls.so.19 -> libmbedtls.so.3.4.1
	libopenraw.so.9 -> libopenraw.so.9.0.7
	libzix-0.so.0 -> libzix-0.so.0.4.2
	libgstcodecs-1.0.so.0 -> libgstcodecs-1.0.so.0.2208.0
	libhistory.so.8 -> libhistory.so.8.2
	libmng.so.2 -> libmng.so.2.0.2
	libgstgl-1.0.so.0 -> libgstgl-1.0.so.0.2208.0
	libatasmart.so.4 -> libatasmart.so.4.0.5
	libaudcore.so.5 -> libaudcore.so.5.4.0
	libulockmgr.so.1 -> libulockmgr.so.1.0.1
	libQt6QmlModels.so.6 -> libQt6QmlModels.so.6.6.1
	libhd.so.23 -> libhd.so.23.2
	libx86emu.so.3 -> libx86emu.so.3.5
	libtraceevent.so.1 -> libtraceevent.so.1.7.3
	libid3tag.so.0 -> libid3tag.so.0.3.0
	libabsl_strings.so.2308.0.0 -> libabsl_strings.so.2308.0.0
	libfontenc.so.1 -> libfontenc.so.1.0.0
	libgd.so.3 -> libgd.so.3.0.11
	libQt5QmlWorkerScript.so.5 -> libQt5QmlWorkerScript.so.5.15.11
	libaccounts-qt5.so.1 -> libaccounts-qt5.so.1.4.0
	librevenge-stream-0.0.so.0 -> librevenge-stream-0.0.so.0.0.5
	libmpc.so.3 -> libmpc.so.3.3.1
	libtwolame.so.0 -> libtwolame.so.0.0.0
	libavahi-gobject.so.0 -> libavahi-gobject.so.0.0.5
	libboost_numpy311.so.1.83.0 -> libboost_numpy311.so.1.83.0
	liborc-0.4.so.0 -> liborc-0.4.so.0.34.0
	libtss2-tcti-device.so.0 -> libtss2-tcti-device.so.0.0.0
	libQt5PrintSupport.so.5 -> libQt5PrintSupport.so.5.15.11
	libevent-2.1.so.7 -> libevent.so
	libnetapi.so.1 -> libnetapi.so.1.0.0
	libQt6QmlLocalStorage.so.6 -> libQt6QmlLocalStorage.so.6.6.1
	libparted-fs-resize.so.0 -> libparted-fs-resize.so.0.0.5
	libsord-0.so.0 -> libsord-0.so.0.16.16
	liblvm2cmd.so.2.03 -> liblvm2cmd.so.2.03
	libgpgmepp.so.6 -> libgpgmepp.so.6.20.1
	libXaw.so.7 -> libXaw7.so.7.0.0
	librhash.so.1 -> librhash.so.1.4.4
	libneon.so.27 -> libneon.so.27.5.5
	libsrtp2.so.1 -> libsrtp2.so.1
	libIex-3_2.so.31 -> libIex.so
	libxfconf-0.so.3 -> libxfconf-0.so.3.0.0
	libpkcs11-helper.so.1 -> libpkcs11-helper.so.1.0.0
	libReviewboardHelpers.so.5 -> libReviewboardHelpers.so.5.113.0
	libsignon-qt5.so.1 -> libsignon-qt5.so.1.0.0
	libavformat.so.60 -> libavformat.so.60.16.100
	libaccountsservice.so.0 -> libaccountsservice.so.0.0.0
	libgudev-1.0.so.0 -> libgudev-1.0.so.0.3.0
	libMagick++-7.Q16HDRI.so.5 -> libMagick++-7.Q16HDRI.so.5.0.0
	libabsl_int128.so.2308.0.0 -> libabsl_int128.so.2308.0.0
	libXRes.so.1 -> libXRes.so.1.0.0
	libftdi1.so.2 -> libftdi1.so.2.5.0
	liburcu-memb.so.8 -> liburcu-memb.so.8.1.0
	libGraphicsMagick++.so.12 -> libGraphicsMagick++.so.12.7.0
	libQt5TextToSpeech.so.5 -> libQt5TextToSpeech.so.5.15.11
	libcblas.so.3 -> libgslcblas.so
	libbd_dm.so.3 -> libbd_dm.so.3.0.0
	libmypaint-gegl.so.0 -> libmypaint-gegl.so.0.0.0
	libwavpack.so.1 -> libwavpack.so.1.2.5
	libavdevice.so.60 -> libavdevice.so.60.3.100
	liblsan.so.0 -> liblsan.so.0.0.0
	libtcmalloc.so.4 -> libtcmalloc.so.4.5.14
	libopenmpt.so.0 -> libopenmpt.so.0.4.4
	libcdda_paranoia.so.0 -> libcdda_paranoia.so.0.10.2
	libabsl_log_internal_format.so.2308.0.0 -> libabsl_log_internal_format.so.2308.0.0
	libcdio_paranoia.so.2 -> libcdio_paranoia.so.2.0.0
	libQt5DBus.so.5 -> libQt5DBus.so.5.15.11
	libsmbldap.so.2 -> libsmbldap.so.2.1.0
	libgstbase-1.0.so.0 -> libgstbase-1.0.so.0.2208.0
	libspiro.so.1 -> libspiro.so.1.0.3
	libmca_common_ompio.so.41 -> libmca_common_ompio.so.41.29.4
	libopen-pal.so.40 -> libopen-pal.so.40.30.3
	libSDL-1.2.so.0 -> libSDL.so
	libgnutls-openssl.so.27 -> libgnutls-openssl.so.27.0.2
	libattr.so.1 -> libattr.so.1.1.2501
	libmono-btls-shared.so -> libmono-btls-shared.so
	libmca_common_cuda.so.40 -> libmca_common_cuda.so.40.30.0
	libQt5QuickParticles.so.5 -> libQt5QuickParticles.so.5.15.11
	libKF5CoreAddons.so.5 -> libKF5CoreAddons.so.5.113.0
	liblightdm-gobject-1.so.0 -> liblightdm-gobject-1.so.0.0.0
	liblapack.so.3 -> liblapack.so.3.12.0
	libcupsfilters.so.2 -> libcupsfilters.so.2.0.0
	libgimp-2.0.so.0 -> libgimp-2.0.so.0.1000.36
	libstoken.so.1 -> libstoken.so.1.3.0
	libQt6Test.so.6 -> libQt6Test.so.6.6.1
	libQt5Sql.so.5 -> libQt5Sql.so.5.15.11
	libxcb-image.so.0 -> libxcb-image.so.0.0.0
	libhttp_parser.so.2.9 -> libhttp_parser.so.2.9.4
	libgimpcolor-2.0.so.0 -> libgimpcolor-2.0.so.0.1000.36
	libwebkit2gtk-4.1.so.0 -> libwebkit2gtk-4.1.so.0.12.7
	libQt5WebEngineWidgets.so.5 -> libQt5WebEngineWidgets.so.5.15.15
	libKF5Kirigami2.so.5 -> libKF5Kirigami2.so.5.113.0
	libQt5Core.so.5 -> libQt5Core.so.5.15.11
	libgstwebrtcnice-1.0.so.0 -> libgstwebrtcnice-1.0.so.0.2208.0
	ld-linux-x86-64.so.2 -> ld-linux-x86-64.so.2
	libKF5KCMUtils.so.5 -> libKF5KCMUtils.so.5.113.0
	libQt5Designer.so.5 -> libQt5Designer.so.5.15.11
	libwmf-0.2.so.7 -> libwmf.so
	libpostproc.so.55 -> libpostproc.so.55.9.100
	libmonoboehm-2.0.so.1 -> libmonoboehm-2.0.so.1.0.0
	liblavfile-2.2.so.0 -> liblavfile.so
	libQt5MultimediaGstTools.so.5 -> libQt5MultimediaGstTools.so.5.15.11
	libgstrtp-1.0.so.0 -> libgstrtp-1.0.so.0.2208.0
	libgpuqrengine.so.3 -> libgpuqrengine.so.3.2.2
	libQt6OpenGLWidgets.so.6 -> libQt6OpenGLWidgets.so.6.6.1
	libnetfilter_conntrack.so.3 -> libnetfilter_conntrack.so.3.8.0
	libudisks2.so.0 -> libudisks2.so.0.0.0
	libnss_mdns6_minimal.so.2 -> libnss_mdns6_minimal.so.2
	libffmpegthumbnailer.so.4 -> libffmpegthumbnailer.so.4.15.1
	libtheora.so.0 -> libtheora.so.0.3.10
	libavahi-common.so.3 -> libavahi-common.so.3.5.4
	libvisual-0.4.so.0 -> libvisual-0.4.so.0.0.0
	libatkmm-1.6.so.1 -> libatkmm-1.6.so.1.1.0
	libhandle.so.1 -> libhandle.so.1.0.3
	libipq.so.0 -> libipq.so.0.0.0
	libmpcdec.so.6 -> libmpcdec.so.6.1.0
	libwpg-0.3.so.3 -> libwpg-0.3.so.3.0.4
	libt1.so.5 -> libt1.so.5.1.2
	libmono-native.so.0 -> libmono-native.so.0.0.0
	libQt6QuickDialogs2Utils.so.6 -> libQt6QuickDialogs2Utils.so.6.6.1
	libQt6SvgWidgets.so.6 -> libQt6SvgWidgets.so.6.6.1
	libboost_url.so.1.83.0 -> libboost_url.so.1.83.0
	librnnoise.so.0 -> librnnoise.so.0.4.1
	libzzipwrap-0.so.13 -> libzzipwrap.so
	libsoup-gnome-2.4.so.1 -> libsoup-gnome-2.4.so.1.11.2
	libavcodec.so.60 -> libavcodec.so.60.31.102
	libvlccore.so.9 -> libvlccore.so.9.0.1
	libglslang-default-resource-limits.so.13 -> libglslang-default-resource-limits.so.13.1.1
	libdcerpc-binding.so.0 -> libdcerpc-binding.so.0.0.1
	libtss2-tcti-cmd.so.0 -> libtss2-tcti-cmd.so.0.0.0
	libhpmud.so.0 -> libhpmud.so.0.0.6
	libirrecord.so.0 -> libirrecord.so.0.0.0
	libpolkit-agent-1.so.0 -> libpolkit-agent-1.so.0.0.0
	libixml.so.11 -> libixml.so.11.1.2
	libjbig2dec.so.0 -> libjbig2dec.so.0.0.0
	libfaac.so.0 -> libfaac.so.0.0.0
	libSvtAv1Dec.so.0 -> libSvtAv1Dec.so.0.8.7
	libsynctex.so.2 -> libsynctex.so.2.0.0
	libevent_pthreads-2.1.so.7 -> libevent_pthreads.so
	libparted.so.2 -> libparted.so.2.0.5
	libKF5IconThemes.so.5 -> libKF5IconThemes.so.5.113.0
	libftdipp1.so.3 -> libftdipp1.so.2.5.0
	libdbus-glib-1.so.2 -> libdbus-glib-1.so.2.3.5
	libfftw3l.so.3 -> libfftw3l.so.3.6.10
	libgstisoff-1.0.so.0 -> libgstisoff-1.0.so.0.2208.0
	libabsl_log_flags.so.2308.0.0 -> libabsl_log_flags.so.2308.0.0
	libboost_log_setup.so.1.83.0 -> libboost_log_setup.so.1.83.0
	libabsl_log_internal_conditions.so.2308.0.0 -> libabsl_log_internal_conditions.so.2308.0.0
	libOpenCL.so.1 -> libOpenCL.so.1.0.0
	libQt5WebEngine.so.5 -> libQt5WebEngine.so.5.15.15
	libXvMCW.so.1 -> libXvMCW.so.1.0.0
	libgtksourceview-4.so.0 -> libgtksourceview-4.so.0.0.0
	libdovi.so.3 -> libdovi.so.3.2.0
	libompitrace.so.40 -> libompitrace.so.40.30.1
	libKF5KIOCore.so.5 -> libKF5KIOCore.so.5.113.0
	libwebpdecoder.so.3 -> libwebpdecoder.so.3.1.8
	libQt5QmlModels.so.5 -> libQt5QmlModels.so.5.15.11
	librevenge-generators-0.0.so.0 -> librevenge-generators-0.0.so.0.0.5
	libKF5KIOWidgets.so.5 -> libKF5KIOWidgets.so.5.113.0
	libip6tc.so.2 -> libip6tc.so.2.0.0
	libfftw3q_omp.so.3 -> libfftw3q_omp.so.3.6.10
	libsamba-passdb.so.0 -> libsamba-passdb.so.0.28.0
	libKF5GuiAddons.so.5 -> libKF5GuiAddons.so.5.113.0
	libzzip-0.so.13 -> libzzip.so
	libhwy.so.1 -> libhwy.so.1.0.7
	libklu.so.2 -> libklu.so.2.2.2
	libgee-0.8.so.2 -> libgee-0.8.so.2.6.1
	libhyphen.so.0 -> libhyphen.so.0.3.0
	libzzipmmapped-0.so.13 -> libzzipmmapped.so
	liblsmash.so.2 -> liblsmash.so.2
	libvolume_key.so.1 -> libvolume_key.so.1.2.3
	libunibreak.so.5 -> libunibreak.so.5.0.1
	libhavege.so.2 -> libhavege.so.2.0.0
	libimagequant.so.0.0.4 -> libimagequant.so.0.0.4
	libQt5MultimediaQuick.so.5 -> libQt5MultimediaQuick.so.5.15.11
	libebml.so.5 -> libebml.so.5.0.0
	libksba.so.8 -> libksba.so.8.14.5
	libyaml-0.so.2 -> libyaml.so
	libpcre.so.1 -> libpcre.so.1.2.13
	libbd_utils.so.3 -> libbd_utils.so.3.0.0
	libsamba-errors.so.1 -> libsamba-errors.so.1.0.0
	libdb_stl-5.3.so -> libdb_stl-5.3.so
	libwbclient.so.0 -> libwbclient.so.0.16
	libefiboot.so.1 -> libefiboot.so.1.38
	libsigsegv.so.2 -> libsigsegv.so.2.0.7
	libQt5Svg.so.5 -> libQt5Svg.so.5.15.11
	libgimpthumb-2.0.so.0 -> libgimpthumb-2.0.so.0.1000.36
	libgstcodecparsers-1.0.so.0 -> libgstcodecparsers-1.0.so.0.2208.0
	libre2.so.11 -> libre2.so.11.0.0
	libKF5WindowSystem.so.5 -> libKF5WindowSystem.so.5.113.0
	libzimg.so.2 -> libzimg.so.2.0.0
	libQt5PositioningQuick.so.5 -> libQt5PositioningQuick.so.5.15.11
	libwnck-3.so.0 -> libwnck-3.so.0.3.0
	libnvme.so.1 -> libnvme.so.1.6.0
	libicalvcal.so.3 -> libicalvcal.so.3.0.17
	libQt6OpenGL.so.6 -> libQt6OpenGL.so.6.6.1
	libxfce4kbd-private-3.so.0 -> libxfce4kbd-private-3.so.0.0.0
	libnl-idiag-3.so.200 -> libnl-idiag-3.so.200.26.0
	libQt6SpatialAudio.so.6 -> libQt6SpatialAudio.so.6.6.1
	libhandy-1.so.0 -> libhandy-1.so.0
	libtheoraenc.so.1 -> libtheoraenc.so.1.1.2
	libQt6QuickShapes.so.6 -> libQt6QuickShapes.so.6.6.1
	libQt6Sql.so.6 -> libQt6Sql.so.6.6.1
	libabsl_log_internal_nullguard.so.2308.0.0 -> libabsl_log_internal_nullguard.so.2308.0.0
	libOpenEXR-3_2.so.31 -> libOpenEXR.so
	libxslt.so.1 -> libxslt.so.1.1.39
	libQt6Quick.so.6 -> libQt6Quick.so.6.6.1
	libnss_wins.so.2 -> libnss_wins.so.2
	libsodium.so.26 -> libsodium.so.26.1.0
	libpotrace.so.0 -> libpotrace.so.0.0.6
	liblmdb.so -> liblmdb.so
	libf2fs_format.so.9 -> libf2fs_format.so.9.0.0
	libdvdread.so.8 -> libdvdread.so.8.0.0
	libnotify.so.4 -> libnotify.so.4.0.0
	libQt5Concurrent.so.5 -> libQt5Concurrent.so.5.15.11
	libdbusmenu-glib.so.4 -> libdbusmenu-glib.so.4.0.12
	libnetsnmptrapd.so.40 -> libnetsnmptrapd.so.40.1.0
	libgimpmath-2.0.so.0 -> libgimpmath-2.0.so.0.1000.36
	libQt5MultimediaWidgets.so.5 -> libQt5MultimediaWidgets.so.5.15.11
	libexiv2.so.28 -> libexiv2.so.0.28.1
	libabsl_synchronization.so.2308.0.0 -> libabsl_synchronization.so.2308.0.0
	libgnome-rr-4.so.2 -> libgnome-rr-4.so.2.1.0
	libzbarqt.so.0 -> libzbarqt.so.0.1.2
	libgsm.so.1 -> libgsm.so.1.0.22
	libclang-cpp.so.16 -> libclang-cpp.so.16
	libsoxr-lsr.so.0 -> libsoxr-lsr.so.0.1.9
	libcamera-base.so.0.1 -> libcamera-base.so.0.1.0
	libpkgconf.so.4 -> libpkgconf.so.4.0.0
	libdcerpc.so.0 -> libdcerpc.so.0.0.1
	libQt5XcbQpa.so.5 -> libQt5XcbQpa.so.5.15.11
	libobs-frontend-api.so.0 -> libobs-frontend-api.so.30
	libgxps.so.2 -> libgxps.so.2.2.4
	libavtp.so.0 -> libavtp.so.0.2.0
	libtmglib.so.3 -> libtmglib.so.3.12.0
	libklu_cholmod.so.2 -> libklu_cholmod.so.2.2.2
	libgstvulkan-1.0.so.0 -> libgstvulkan-1.0.so.0.2208.0
	libmongoose.so.3 -> libmongoose.so.3.2.1
	libptexenc.so.1 -> libptexenc.so.1.4.3
	libf2fs.so.10 -> libf2fs.so.10.0.0
	libout123.so.0 -> libout123.so.0.5.0
	liburcu.so.8 -> liburcu.so.8.1.0
	libmplex2-2.2.so.0 -> libmplex2.so
	liblrdf.so.2 -> liblrdf.so.2.0.0
	libwiretap.so.14 -> libwiretap.so.14.0.0
	libbd_part.so.3 -> libbd_part.so.3.0.0
	libmp3lame.so.0 -> libmp3lame.so.0.0.0
	libxmlsec1-gnutls.so.1 -> libxmlsec1-gnutls.so.1.2.37
	libxvidcore.so.4 -> libxvidcore.so.4.3
	libmpi_usempi_ignore_tkr.so.40 -> libmpi_usempi_ignore_tkr.so.40.30.0
	libv4l1.so.0 -> libv4l1.so.0.0.0
	libdvbv5.so.0 -> libdvbv5.so.0.0.0
	libdvbpsi.so.10 -> libdvbpsi.so.10.0.0
	libmbedx509.so.5 -> libmbedx509.so.3.4.1
	libgdiplus.so.0 -> libgdiplus.so.0.0.0
	libKF5ConfigGui.so.5 -> libKF5ConfigGui.so.5.113.0
	libXfont2.so.2 -> libXfont2.so.2.0.0
	libimobiledevice-1.0.so.6 -> libimobiledevice-1.0.so.6.0.0
	libmms.so.0 -> libmms.so.0.0.2
	libraw_r.so.23 -> libraw_r.so.23.0.0
	libdrop_ambient.so.0 -> libdrop_ambient.so.0.0.0
	libtk8.6.so -> libtk8.6.so
	libabsl_random_internal_distribution_test_util.so.2308.0.0 -> libabsl_random_internal_distribution_test_util.so.2308.0.0
	libpipewire-0.3.so.0 -> libpipewire-0.3.so.0.1000.0
	libbd_swap.so.3 -> libbd_swap.so.3.0.0
	libKF5SonnetCore.so.5 -> libKF5SonnetCore.so.5.113.0
	libblas.so.3 -> libblas.so.3.12.0
	libKF5SonnetUi.so.5 -> libKF5SonnetUi.so.5.113.0
	libQt5QuickTemplates2.so.5 -> libQt5QuickTemplates2.so.5.15.11
output of mhwd-kernel -li:
Currently running: 6.1.1-1-MANJARO (linux61)
   * linux513
   * linux515
ldconfig should return nothing…
you have a dead kernel, so remove it:
pacman -R linux513
and reinstall the 5.15 and install also the 6.1:
pacman -S linux515 linux61
if there are exists in filesystem use overwrite:
pacman -S linux515 linux61 --overwrite '*'
exit chroot, reboot and see if it helped…
Additionally you can do sudo pacman -Qkk 1>/dev/null.
