Hi All -
I got a new system this week and it has an NVIDIA GeForce RTX 4060 GPU. Nvidia X Server Settings detects the card but lspci doesn’t. Furthermore, based on “About This System” - the intel mesa driver is being used and not nvidia driver (which is installed).
Here’s about my system:
KDE Plasma Version: 5.27.10
KDE Frameworks Version: 5.112.0
Qt Version: 5.15.11
Kernel Version: 6.6.7-4-MANJARO (64-bit)
Graphics Platform: X11
Processors: 20 × 13th Gen Intel® Core™ i9-13900H
Memory: 31.0 GiB of RAM
Graphics Processor: Mesa Intel® Graphics
Manufacturer: Dell Inc.
Product Name: XPS 15 9530
Here’s my output from the following command "lspci -k | grep -A 2 -i “VGA” "
lspci -k | grep -A 2 -i "VGA" 127 ✘
00:02.0 VGA compatible controller: Intel Corporation Raptor Lake-P [Iris Xe Graphics] (rev 04)
Subsystem: Dell Raptor Lake-P [Iris Xe Graphics]
Kernel driver in use: i915
And here is what I get from Nvidia Settings app that is installed:
NVIDIA GeForce RTX 4060 Laptop GPU
Thanks in advance.
cscs
22 December 2023 23:17
2
So these will give us decent information about the system:
inxi -Fazy
mhwd -li -l
For a guide on how to find info and format things, etc:
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
PS.
My guess is this is a hybrid/optimus/dual-gpu system and you just dont realize that and/or how to manage it. The output of the above will help confirm it and influence the following suggestions.
Thanks for quick reply. Hopefully I got formatting right:
Kernel: 6.6.7-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=29221945-aeb0-4217-8b21-a05dc798e023 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: Dell product: XPS 15 9530 v: N/A
Mobo: Dell model: 0GY0F9 v: A00 serial: <superuser required> UEFI: Dell
v: 1.9.0 date: 11/13/2023
ID-1: BAT0 charge: 84.3 Wh (100.0%) condition: 84.3/84.3 Wh (100.0%)
volts: 12.9 min: 11.4 model: BYD DELL M59JH39 type: Li-poly serial: <filter>
status: not charging cycles: 2
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x411C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 470 high: 902 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 902 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 810 11: 895 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 119840
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:a7a0 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Dell
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:28a0
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0c45:6748
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3456x2160 s-dpi: 96 s-size: 914x571mm (35.98x22.48")
s-diag: 1078mm (42.43") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: Samsung 0x414d built: 2020 res: 3456x2160 dpi: 261
gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6") ratio: 16:10
modes: 3456x2160
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 30.3 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:28a0 surfaces: xcb,xlib
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51ca class-ID: 0401
API: ALSA v: k6.6.7-4-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 953.87 GiB used: 386.9 GiB (40.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC801 NVMe 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 51003141 temp: 36.9 C
scheme: GPT
ID-1: / raw-size: 29.3 GiB size: 28.67 GiB (97.86%) used: 14.21 GiB (49.6%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
used: 2.17 GiB (7.6%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
ID-1: swap-1 type: partition size: 7.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p11 maj-min: 259:11
System Temperatures: cpu: 48.0 C mobo: 36.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 1694
Processes: 373 Uptime: 3h 0m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.02 GiB used: 7.72 GiB (24.9%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1229 libs: 346 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
mhwd -li -l ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
> 0000:01:00.0 (0302:10de:28a0) Display controller nVidia Corporation:
video-nvidia 2023.03.23 false PCI
> 0000:00:02.0 (0300:8086:a7a0) Display controller Intel Corporation:
video-vesa 2017.03.12 true PCI
cscs
22 December 2023 23:32
4
So you do have a hybrid system.
And it looks like you have correctly selected the current prime profile.
This should mean you use the intel iGPU by default, and can use the nvidia dGPU with prime-run.
Lets test it out;
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
Seems to have worked as far as output showing NVIDIA. How do I set that as the primary GPU. Is there a reason it defaults to the intel GPU when I think it’s hard to imagine why I’d want to use the intel one over the NVIDIA one…lots of questions and thank you as always.
pobrn
23 December 2023 00:47
6
Energy efficiency. Why use the nvidia one when it’s not really needed?
Think all my questions on this front are answered. Assuming that if I push the graphics to need NVIDIA it’ll switch over automatically…? Or do I have to remember always to switch using the prime-rum command? (Guess not all questions answered). Started with 3 issues on this new computer, down to 1…appreciate it!
cscs
23 December 2023 01:04
8
No, there is no automatic switching based on load.
You simply use prime-run when you want.
This is usually just 3D-rendering, like Blender, or games.
A note on that for steam;
Do not launch steam itself with prime-run, instead edit the game launch options to use prime-rin, ex (assuming no other options);
prime-run %command%
(%command% is a special steam variable that in this context means ‘this game’)
For more information on prime see the arch wiki:
https://wiki.archlinux.org/title/PRIME
bedna
23 December 2023 10:48
9
Not only that, using nvidia to render the desktop is sometimes way worse than the internal gpu.
For me on KDE, if I use nvidia, there is stuttering, lagging etc. That is completely gone when using my amd igpu. I know you have intel, but I would not be one bit surprised if your igpu runs better.
This is the case for x11, wayland actually runs descent with nvidia now.
As for steam, proton selects the nvidia autoamtically, no need to add anything.
Proton (or it might be snipr, I’m not sure, steam selects the nvidia is the point) sets __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia witch is the same thing that prime-run does.
But outside of steam, just run prime-run application_name and the nvidia will be used for that application.
So this is how you WANT your setup and you should probably be glad you did not face what I had to.
It took me a while to figure out how to even use my amd instead of nvidia at all. xD
Merry xmas!
