For 2 weeks I don’t get any updates anymore.
The mirror list is empty. Is this supposed to be normal?
Any ideas how to fix this? Thanks in advance.
First of all, you’ve been around on this forum long enough to know that gratuitous screenshots of terminal output are frowned upon here. They unnecessarily take up space in the database, they cannot be searched for context, and they cannot be copied and pasted from.
Secondly, I don’t know what the purpose is supposed to be of your second screenshot, but have you tried refreshing your mirror list? ![]()
sudo pacman-mirrors -f && sudo pacman -Syu
Thirdly… ![]()
You know, it is difficult for people to read German when they don’t know German. Especially when there are pictures. Next time use the Deutsch category. Or reset language to plain English with LANG=C in the terminal.
You are not new at all and should know that.
Pictures of text are useless. For us and for the future. Please avoid them when there is text which you can copy&paste. There is an extra button for preformatted text here.
sudo pacman-mirrors --country Germany
sudo pacman-mirrors --fasttrack
OR
This is it. Thx. I’ve had a look into the settings but after a 14h workday and the translation of the button I didn’t notice it.
No I didn’t know that. I’m always asked to use lots of pictures to describe things shorter and better.
This was the problem. The list is not supposed to be empty. I wonder how this could be happen.
In my opinion it’s suitable for beginners. Installation can’t be easier. I’m not missing anything and most of the time it’s working without any problems.
