System update failed
I recently reinstalled Manjaro on a new drive. No issues until I tried to run the recent update. Here is relevant fragment of pacman.log:
[2023-10-05T18:19:37+0000] [PAMAC] synchronizing package lists
[2023-10-05T18:22:58+0000] [PACMAN] Running 'pacman -Syu'
[2023-10-05T18:22:58+0000] [PACMAN] synchronizing package lists
[2023-10-05T18:23:30+0000] [ALPM] transaction started
[2023-10-05T18:23:30+0000] [ALPM] upgraded archlinux-keyring (20230821-2 -> 20230918-1)
[2023-10-05T18:23:30+0000] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2023-10-05T18:23:32+0000] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2023-10-05T18:23:32+0000] [ALPM-SCRIPTLET]   -> Disabled 2 keys.
[2023-10-05T18:23:32+0000] [ALPM-SCRIPTLET] ==> Updating trust database...
[2023-10-05T18:23:33+0000] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: pgp
[2023-10-05T18:23:33+0000] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  21  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2023-10-05T18:23:33+0000] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  21  signed:  96  trust: 0-, 0q, 0n, 21m, 0f, 0u
[2023-10-05T18:23:33+0000] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  72  signed:  27  trust: 72-, 0q, 0n, 0m, 0f, 0u
[2023-10-05T18:23:33+0000] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2023-10-27
[2023-10-05T18:23:33+0000] [ALPM] transaction completed
[2023-10-05T18:23:33+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-10-05T18:23:34+0000] [ALPM] running '30-systemd-update.hook'...
[2023-10-05T18:23:34+0000] [ALPM] running '90-packagekit-refresh.hook'...
[2023-10-05T18:23:34+0000] [PACMAN] starting full system upgrade
[2023-10-05T18:24:50+0000] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-10-05T18:24:50+0000] [ALPM] running '71-dkms-remove.hook'...
[2023-10-05T18:24:50+0000] [ALPM] transaction started
[2023-10-05T18:24:50+0000] [ALPM] error: problem occurred while upgrading filesystem
[2023-10-05T18:24:50+0000] [ALPM] upgraded filesystem (2023.09.03-1 -> 2023.09.22-1)
[2023-10-05T18:24:50+0000] [ALPM] transaction failed
Output from inxi:
CPU: 12-core AMD Ryzen 9 5900X (-MT MCP-) speed/min/max: 2673/2200/4950 MHz
Kernel: 6.5.3-1-MANJARO x86_64 Up: 6d 18h 1m Mem: 10.9/62.68 GiB (17.4%)
Storage: 12.74 TiB (50.3% used) Procs: 496 Shell: Zsh inxi: 3.3.30
The log does not tell where to look for the cause of failure, or the second last line is misleading. Although filesystem seems to be updated:
[asok log]#  pacman -Q filesystem
filesystem 2023.09.22-1
I need help.
Hopefully relevant output from journalctl:
Oct 05 18:38:26 asok archlinux-keyring-wkd-sync[813906]: Refreshing key 5E6D49448958B384301F1F22498EF247>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[814255]: gpg: error retrieving 'fabiscafe@archlinux.org'>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[814255]: gpg: error reading key: End of file
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key 02FD1C7A934E614545849F19A6>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key 169704C6FB490C6892C7F23C37>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key 42DFAFB7C03B2E4E7BBDBA6993>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key 8E1992167465DB5FB045557CB0>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key 954A3772D62EF90E4B31FBC6C9>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key 9D74DF6F91B7BDABD5815CA84A>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key ADC8A1FCC15E01D45310419E94>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key B4B759625D4633430B74877059>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key B81B051F2D7FC867AAFF35A58D>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key BE2DBCF2B1E3E588AC325AEAA0>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key C521846436D75A3294795B27B4>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key CB33B736591A9CA06098A9A5FC>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key D89FAAEB4CECAFD199A2F5E612>
Oct 05 18:38:28 asok archlinux-keyring-wkd-sync[813906]: Error refreshing key 5E6D49448958B384301F1F2249>
Oct 05 18:38:28 asok systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, s>
Oct 05 18:38:28 asok systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Oct 05 18:38:28 asok systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 1.521s CPU time.
Oct 05 18:38:28 asok pamac-tray-plas[1231]: updates_checker.vala:71: check updates
Oct 05 18:38:30 asok pamac-tray-plas[1231]: updates_checker.vala:101: 95 updates found
Oct 05 18:38:42 asok systemd[1]: Started Process Core Dump (PID 814333/UID 0).
Oct 05 18:38:42 asok systemd-coredump[814334]: [🡕] Process 814332 (eglinfo) of user 501 dumped core.
@yt87 Do you have enough space on your root partition?
df -h
Yes:
[asok log]# df -h
Filesystem      Size  Used Avail Use% Mounted on
dev              32G     0   32G   0% /dev
run              32G  4.4M   32G   1% /run
efivarfs        128K   36K   88K  29% /sys/firmware/efi/efivars
/dev/nvme1n1p3  269G   15G  241G   6% /
tmpfs            32G   53M   32G   1% /dev/shm
/dev/sdb1       916G  141G  729G  17% /mnt/sdb1
/dev/nvme0n1p1  916G  480G  390G  56% /mnt/nvme0
/dev/sdc1       3.6T  1.6T  1.9T  45% /mnt/sdc1
/dev/sdd1       2.8T  2.1T  717G  75% /mnt/sdd1
tmpfs            32G  4.3G   28G  14% /tmp
/dev/nvme1n1p1  300M  288K  300M   1% /boot/efi
tmpfs           6.3G  112K  6.3G   1% /run/user/501
/dev/sda2       432G   37G  389G   9% /mnt/sda2
/dev/sde1       3.6T  2.2T  1.3T  65% /run/media/george/snapshots
sudo pacman-mirrors --geoip
sudo pacman-mirrors --fasttrack
sudo pacman -Syyuu --overwrite "*"
Thanks, that worked! I am a bit concerned about this:
Found linux image: /boot/vmlinuz-6.5-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.5-x86_64.img
Found initrd fallback image: /boot/initramfs-6.5-x86_64-fallback.img
Found Manjaro Linux on /dev/sda2
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(17/22) Reloading system bus configuration...
The sda drive is my old Manjaro system disk, which is btrfs while nvme1n1p1 is ext4. The final test will be reboot.
Why concerned?
This is the output of update-grub.
Normal.
Since you said you have an extra install on sda … this is also normal.
You said your root should be ext4 … and you are still using grub-btrfs … so normal as well.
At least for me, on an nvme with an ESP formatted fat32 (used by windoze as well) this message is also displayed every update-grub. It also gets a rating of normal.
Warning: Generally avoid using the --overwrite switch. See System maintenance#Avoid certain pacman commands.
pacman - ArchWiki
Alright. Next time…
it should only be used when explicitly recommended by the Arch developers.
:face_with_peeking_eye:
I see that the package grub-btrfs is installed, even if I did not want a btrfs filesystem. I am not sure it is worthwhile to uninstall it. It is likely another layer that falls back to ext4 in absence of btrfs.
Yeah thats how the install goes.
I noticed a handful of packages that were unneeded or incorrect given the choices … cronie, timeshift things, and this being among the examples.
Though - since the installs are not dynamic … it makes sense it is like this.
Anyhoo, yes, if you dont use btrfs you can uninstall grub-btrfs - just make sure to have regular grub installed.
