System update failed - how to resolve?
Conflicts reported, cannot update. Ran terminal commands:
[steve@steve ~]$ sudo pacman -Syu
[sudo] password for steve:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Replace lib32-libva-mesa-driver with multilib/lib32-mesa? [Y/n] y
:: Replace lib32-mesa-vdpau with multilib/lib32-mesa? [Y/n] y
:: Replace libva-mesa-driver with extra/mesa? [Y/n] y
:: Replace linux610 with core/linux-meta? [Y/n] y
:: Replace linux610-virtualbox-host-modules with extra/linux-virtualbox-host-modules-meta? [Y/n] y
:: Replace mesa-vdpau with extra/mesa? [Y/n] y
:: Replace qcoro-qt6 with extra/qcoro? [Y/n] y
:: Replace tracker3 with extra/tinysparql? [Y/n] y
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: tlp-1.7.0-1 and power-profiles-daemon-0.23-2 are in conflict
[steve@steve ~]$ ^C
[steve@steve ~]$ sudo pacman-mirrors -f 5
sudo pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.349 Canada         : https://mirror.xenyth.net/manjaro/
::INFO Writing mirror list
::Canada          : https://mirror.xenyth.net/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core                  138.9 KiB   671 KiB/s 00:00 [######################] 100%
 extra                   8.1 MiB  7.03 MiB/s 00:01 [######################] 100%
 community              29.0   B  1260   B/s 00:00 [######################] 100%
 multilib              141.4 KiB  5.31 MiB/s 00:00 [######################] 100%
[steve@steve ~]$
What is not clear? Remove one of the conflicting packages. If you are on kde that would probably be tlp.
Would you please offer a detailed instruction? I am not a programmer. I do not know what is using the conflicting programs, which ones to delete.
Same as here Failing to update packages due to some cryptic package conflict - #5 by mehran
btw there are other 2 topics about the same issue in this same category just before yours
to resolve the conflict
remove tlp
You can search for what these two are for - the important thing here though is:
you need to remove one or the other to resolve the conflict - and tlp definitely is not essential
I wasn’t sure how to remove tlp (not a programmer). So I used the pamac, searched for tlp, found one and removed it. The system is now updating. But some failed to retrieve.
… whatever that might mean …
probably a good idea to refresh your list of mirrors before you try to run the update again to fetch the rest
It seems to have updated now. Thanks to all.
Just for the future, note that you are using a custom mirror file which appears to contain only a single mirror. -f/--fasttrack 5 is trying to find the top 5 from your list of 1. You will probably have better luck adding a few more North American mirrors.
I have a new problem, likely related. After an overnight cold boot, my system is usable but something is going on in the background. I tried to print, but my printer is no longer functioning. The HP app does not boot. I tried to re-install it but was told that another update is installing so I have to wait for it to finish. No disk activity now. The HP app apparently reinstalled but still is not working. I am not sure how to proceed.
I have several packages treated as ignored by Pamac. How do I un-ignore them?
→ preferences → advanced → ignored updates
you used the + sign to add to the list
you use the - sign beside each package that you added to remove it from that list
Thank you. I was hoping that was the answer!
… and you did not try and test whether it was?
Too new at this. Trying to solve problems noted above and now my HP Device Manager program will not recognise my printer. It worked this morning. Everything happens at once!
Just a reminder:
packages in the ignore list are a recipe for desaster (or at least for more problems down the line)
usually not a good idea to have any there
Hitting the minus sign seems to just put them back in the ignore lists. I would like to empty the ignore list. There are too many there to do one at a time!
That is not how the app behaves for me - can’t replicate.
Is there a quick way to empty the list?
yes - the list of packages to be ignored is added to: /etc/pacman.conf
on the line starting with:
IgnorePkg =
simply edit that file - comment out that line - put a # in front of that line
the default state (empty list) looks like this:
#IgnorePkg =
