I have done the stupid thing to use pip with sudo, now i see/read that it wasn’t a good idea.
now i get this:
error: failed to commit transaction (conflicting files)
slither: /usr/lib/python3.9/site-packages/tests/__init__.py exists in filesystem (owned by python-crccheck)
slither: /usr/lib/python3.9/site-packages/tests/__pycache__/__init__.cpython-39.opt-1.pyc exists in filesystem (owned by python-crccheck)
slither: /usr/lib/python3.9/site-packages/tests/__pycache__/__init__.cpython-39.pyc exists in filesystem (owned by python-crccheck)
Yes, i been looking online to fix the problem, i even found things here about it.
nothing works! rewriting the files, trying to remove them, etc.
did these steps also https://forum.manjaro.org/t/update-or-package-installation-returns-failed-to-commit-transaction-conflicting-files-filename-exists-in-filesystem/3598
Also when i try to remove them i get this
error: target not found: /usr/lib/python3.9/site-packages/tests/__init__.py
bash: /usr/lib/python3.9/site-packages/tests/__pycache__/__init__.cpython-39.opt-1.pyc: Permission denied
bash: usr/lib/python3.9/site-packages/tests/__pycache__/__init__.cpython-39.pyc: No such file or directory
i am getting pretty frustrated atm, any help would be awesome!
ps. isn’t there a way to skipp these files when updating??
you saved the day!!
