After last update, and I run
sudo pacman -R $(pacman -Qdtq)
to remove useless packages, the system tray icons now:
Hi there.
That’s a bit weird. Have you tried going “Panel”, “Panel Preferences”, “Items”, removing each one & then going back in & selecting each one again? That might be worth a try. You’ve obviously rebooted. I’m sure there is also a way to look at recently removed files etc, but I’m not sure how to do that.
All the best with this one.
Ruziel
I’d wager that some of the removed packages where not useless after all.
You possibly removed some icon theme …
See what got removed:
tac /var/log/pacman.log | less
(this lists the contents of the log in reverse order, newest first - scroll with up/down arrow)
Ok, I will try them, reply result tomorrow, thanks
try switching to “light-mode” icons. default on manjaro xfce is `Papirus-Dark-Maia". use “Papirus-Maia” from appearance settings.
Its fine here on xfce with Adapta-Maia Theme and Papirus-Maia icons
It`s OK now, switing theme to Adapta and icon to Papirus, thanks all!
