I noticed my system time is consistently some 6 minutes behind the official time (as seen on this website), which tends to make me late for appointments.
In the last session, I’ve manually synced my machine system time with the official one, using an appropriate sudo date command, but I’ve found on the next boot that the change is not persistent.
Here’s my system info (through $ inxi --admin --verbosity=7 --filter --no-host --width | xclip):
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=7d129f16-68a5-4166-af3c-be36b7ba6c40 rw quiet
cryptdevice=UUID=d4d370d7-082e-437f-b4ae-84c750147f53:luks-d4d370d7-082e-437f-b4ae-84c750147f53
root=/dev/mapper/luks-d4d370d7-082e-437f-b4ae-84c750147f53 apparmor=1
security=apparmor resume=UUID=85ffc8b9-36cc-4a1d-a122-a69aa6ef2518
udev.log_priority=3 pcie_aspm=off
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop Mobo: Gigabyte model: H310M H 2.0 v: x.x serial: <filter>
UEFI: American Megatrends v: F12 date: 08/13/2019
RAM: total: 15.58 GiB used: 2.36 GiB (15.2%)
Info: Quad Core model: Intel Core i3-9100F bits: 64 type: MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: B (11)
microcode: DE cache: L2: 6 MiB bogomips: 28808
Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GK208B [GeForce GT 710] driver: nvidia v: 460.73.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:128b
class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 55 size: 885x498mm (34.8x19.6")
diag: 1015mm (40")
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.26 running: no
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:818b class-ID: 0280
vendor: Gigabyte driver: r8169 v: kernel port: c000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-1: luks-bd4c91ef-b67b-4d8c-a73d-f8f8642b867b maj-min: 254:1
type: LUKS dm: dm-1 size: 931.51 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 931.51 GiB
Device-2: luks-d4d370d7-082e-437f-b4ae-84c750147f53 maj-min: 254:0
type: LUKS dm: dm-0 size: 155.57 GiB
Components:
p-1: sdb3 maj-min: 8:19 size: 155.57 GiB
Local Storage: total: 1.13 TiB used: 696.72 GiB (60.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0400
scheme: GPT
ID-1: / raw-size: 155.57 GiB size: 152.13 GiB (97.79%)
used: 42.51 GiB (27.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-d4d370d7-082e-437f-b4ae-84c750147f53 label: N/A
uuid: 7d129f16-68a5-4166-af3c-be36b7ba6c40
ID-2: /boot/efi raw-size: 4 GiB size: 3.99 GiB (99.80%) used: 424 KiB (0.0%)
fs: vfat dev: /dev/sdb2 maj-min: 8:18 label: N/A uuid: 50B3-509E
ID-3: /home raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 654.21 GiB (71.4%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-bd4c91ef-b67b-4d8c-a73d-f8f8642b867b label: N/A
uuid: 5e60496a-8abb-4130-b96e-7a2f3ef1bc44
ID-1: swap-1 type: partition size: 64 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 85ffc8b9-36cc-4a1d-a122-a69aa6ef2518
Device-1: 1-7:2 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 275d:0ba6 class-ID: 0301
Device-2: 1-8:3 info: Megawin Defender Gaming Keyboard type: Keyboard
power: 100mA chip-ID: 0e6a:02c0 class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 225 Uptime: 1h 11m wakeups: 0 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 alt: 8/9 clang: 11.1.0 Packages: 1900
pacman: 1896 lib: 461 flatpak: 0 snap: 4 Shell: Bash v: 5.1.0
running-in: screen inxi: 3.3.04
Looking for similar threads in the forum, I’ve only found this one, which methinks isn’t what I need; however the command below might be a helpful lead:
$ sudo timedatectl show-timesync
Failed to parse bus message: No such file or directory
What should I do to make sure my system time is synchronized (preferably with https://www.horariodebrasilia.org) every time?
