System takes too long to boot
hi,
My system seems to take a long period before accessing login screen.
I send you the results of systemd-analyze.
Blockquote
Startup finished in 24.338s (firmware) + 6.093s (loader) + 34.576s (kernel) + 5.536s (userspace) = 1min 10.544s
graphical.target reached after 5.536s in userspace.
Also I cannot reach grub to select the appropriate kernel.
Any tips will be very appreciated.
Probably a hardware issue. The firmware is really slow, but the kernel is struggling with something. Just for comparison, mine loads in 0.6 sec.
And there is no such thing as cannot enter grub - you will have to pump esc or shift keys really quickly for 24 seconds obviously, or enable the menu in /etc/default/grub
Please read how to provide more information (inxi and journal errors would be appropriate) and how to post logs (</> button).
got it;
It is probably related to my pci-express usb card.
I will remove this card and see what behavior I will get.
I had this error during the last boot with this card attached ;
oct. 09 11:35:46 kevlar-ms7924 kernel: usb 3-2: can’t set config #1, error -110
oct. 09 11:35:46 kevlar-ms7924 kernel: xhci_hcd 0000:03:00.0: can’t setup: -110
oct. 09 11:35:46 kevlar-ms7924 kernel: xhci_hcd 0000:03:00.0: init 0000:03:00.0 fail, -110
oct. 09 11:35:46 kevlar-ms7924 kernel: xhci_hcd 0000:03:00.0: probe with driver xhci_hcd failed with error -110
oct. 09 11:35:47 kevlar-ms7924 systemd-udevd[401]: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Unknown group ‘uaccess’, ignoring.
oct. 09 11:35:47 kevlar-ms7924 kernel: usb 3-6: 3:1: cannot get freq at ep 0x84
oct. 09 11:36:06 kevlar-ms7924 kernel: usb 3-6: 3:1: cannot get freq at ep 0x84
oct. 09 11:36:16 kevlar-ms7924 (udev-worker)[1240]: hiddev0: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k>
oct. 09 11:36:16 kevlar-ms7924 (udev-worker)[1242]: hiddev1: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k>
oct. 09 11:40:01 kevlar-ms7924 kwin_wayland[691]: kwin_scene_opengl: Invalid framebuffer status: “GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT”
oct. 09 11:43:27 kevlar-ms7924 systemd-udevd[401]: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Unknown group ‘uaccess’, ignoring.
oct. 09 11:47:49 kevlar-ms7924 kwin_wayland[691]: kwin_scene_opengl: Invalid framebuffer status: “GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT”
oct. 09 12:11:55 kevlar-ms7924 dbus-broker-launch[523]: Activation request for ‘org.freedesktop.nm_dispatcher’ failed.
It is a renesas card which seems problematic.
I provide to you the inxi results :slight_smile:
  Kernel: 6.11.0-6-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=ab47d8fc-c1c7-45cf-99aa-ce416f76e0c4 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Desktop Mobo: MSI model: H97M-G43(MS-7924) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: 2.11 date: 02/16/2016
  Info: model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell gen: core 4
    level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 800/3400 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 25608
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen-7.5
    process: Intel 22nm built: 2013 ports: active: HDMI-A-1 empty: DP-1,
    HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412
    class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 res: 1920x1080 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
    drv: crocus x11: drv: crocus
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) device-ID: 8086:0412 memory: 1.46 GiB unified: yes display-ID: :1.0
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
    class-ID: 0403
  Device-3: VIA Audio-gd driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 040d:3410
    class-ID: 0300
  API: ALSA v: k6.11.0-6-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.13 TiB used: 33.29 GiB (2.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0A-00JH30
    size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0000 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB10C
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-1: / raw-size: 223.28 GiB size: 218.72 GiB (97.96%)
    used: 33.29 GiB (15.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 32.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB available: 15.49 GiB used: 4 GiB (25.8%)
  Processes: 212 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1521 libs: 454 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.32
    running-in: konsole inxi: 3.3.36
