System stuck on reboot & shutdown - SDDM crash
KDE Plasma Version: 5.27.10
Kernel Version: 6.7.0-0-MANJARO (64-bit)
After the previous upgrade my system gets stuck during reboot and shutdown.
I see many warnings & errors but I have no idea how to solve this problem …
However, this error message seems interesting → SDDM crash
Jan 18 07:40:47 mysystem sddm[650]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Jan 18 07:40:47 mysystem sddm[650]: Auth: sddm-helper (--socket /tmp/sddm-auth-53d91201-8dff-4148-9acd-7296c38edaee --id 1 --start /usr/bin/startplasma-x11 --user myusername) crashed (exit code 1)
$ journalctl -b-1 -p4 --no-pager
Jan 18 07:26:34 mysystem kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jan 18 07:26:34 mysystem kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Jan 18 07:26:34 mysystem kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jan 18 07:26:34 mysystem kernel: usb: port power management may be unreliable
Jan 18 07:26:34 mysystem systemd-fstab-generator[234]: x-systemd.device-timeout ignored for print-pc:/mnt/nfs_share
Jan 18 07:26:34 mysystem kernel: vboxdrv: loading out-of-tree module taints kernel.
Jan 18 07:26:34 mysystem kernel: VBoxNetAdp: Successfully started.
Jan 18 07:26:34 mysystem kernel: VBoxNetFlt: Successfully started.
Jan 18 07:26:35 mysystem kernel: wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
Jan 18 07:26:36 mysystem NetworkManager[565]: <warn>  [1705559196.8250] device (wireguard1): connectivity: "/proc/sys/net/ipv4/conf/wireguard1/rp_filter" is set to "1". This might break connectivity checking for IPv4 on this device
Jan 18 07:26:36 mysystem NetworkManager[565]: <warn>  [1705559196.8302] device (wireguard1): No agents were available for this request.
Jan 18 07:26:36 mysystem NetworkManager[565]: <warn>  [1705559196.8306] device (wireguard1): Activation: failed for connection 'wireguard1'
Jan 18 07:26:36 mysystem dbus-broker-launch[563]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Jan 18 07:26:38 mysystem dbus-broker-launch[563]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jan 18 07:26:39 mysystem dbus-broker-launch[683]: Service file '/usr/share//dbus-1/services/org.jackaudio.service' is not named after the D-Bus name 'org.jackaudio.service'.
Jan 18 07:26:39 mysystem dbus-broker-launch[683]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jan 18 07:26:39 mysystem dbus-broker-launch[683]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jan 18 07:26:39 mysystem dbus-broker-launch[683]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jan 18 07:26:39 mysystem dbus-broker-launch[563]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jan 18 07:36:42 mysystem dbus-broker-launch[776]: Service file '/usr/share//dbus-1/services/org.jackaudio.service' is not named after the D-Bus name 'org.jackaudio.service'.
Jan 18 07:36:42 mysystem dbus-broker-launch[776]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jan 18 07:36:42 mysystem dbus-broker-launch[776]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jan 18 07:36:42 mysystem dbus-broker-launch[776]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jan 18 07:36:44 mysystem xdg-desktop-por[798]: Failed connect to PipeWire: Couldn't connect to PipeWire
Jan 18 07:36:44 mysystem backlighthelper[986]: org.kde.powerdevil: no kernel backlight interface found
Jan 18 07:36:48 mysystem systemd[750]: app-pulseaudio@autostart.service: Failed with result 'exit-code'.
Jan 18 07:36:48 mysystem cairo-dock[1155]: Theme parsing error: <data>:7:1467: The :insensitive pseudo-class is deprecated. Use :disabled instead.
Jan 18 07:36:48 mysystem cairo-dock[1155]: Theme parsing error: <data>:7:3649: The :inconsistent pseudo-class is deprecated. Use :indeterminate instead.
Jan 18 07:36:50 mysystem pulseaudio[1361]: JACK error >Cannot use real-time scheduling (RR/90) (1: Die Operation ist nicht erlaubt)<
Jan 18 07:36:50 mysystem pulseaudio[1361]: JACK error >JackClient::AcquireSelfRealTime error<
Jan 18 07:36:50 mysystem pulseaudio[1361]: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your configuration.
Jan 18 07:36:58 mysystem pamac-manager[2139]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
Jan 18 07:37:43 mysystem systemd[750]: dbus-:1.2-org.kde.KSplash@0.service: Failed with result 'exit-code'.
Jan 18 07:37:47 mysystem systemd-fstab-generator[4526]: x-systemd.device-timeout ignored for print-pc:/mnt/nfs_share
Jan 18 07:40:44 mysystem systemd[750]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Jan 18 07:40:45 mysystem systemd[750]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Jan 18 07:40:46 mysystem xdg-desktop-por[27453]: Failed connect to PipeWire: Couldn't connect to PipeWire
Jan 18 07:40:47 mysystem sddm-helper[747]: Signal received: SIGTERM
Jan 18 07:40:47 mysystem sddm[650]: Auth: sddm-helper exited with 1
Jan 18 07:40:47 mysystem sddm[650]: Signal received: SIGTERM
Jan 18 07:40:47 mysystem systemd[750]: plasma-kscreen.service: Failed with result 'exit-code'.
Jan 18 07:40:47 mysystem systemd[750]: dbus-:1.53-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Jan 18 07:40:47 mysystem kglobalaccel5[27478]: The X11 connection broke: I/O error (code 1)
Jan 18 07:40:47 mysystem systemd[750]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
Jan 18 07:40:47 mysystem systemd[750]: dbus-:1.2-org.freedesktop.Notifications@0.service: Failed with result 'exit-code'.
Jan 18 07:40:47 mysystem systemd[750]: dbus-:1.2-org.kde.kcookiejar5@0.service: Failed with result 'exit-code'.
Jan 18 07:42:17 mysystem systemd[750]: dbus-:1.2-org.jackaudio.service@1.service: State 'stop-sigterm' timed out. Killing.
Jan 18 07:42:17 mysystem systemd[750]: dbus-:1.2-org.jackaudio.service@1.service: Main process exited, code=killed, status=9/KILL
Jan 18 07:42:17 mysystem systemd[750]: dbus-:1.2-org.jackaudio.service@1.service: Failed with result 'timeout'.
Jan 18 07:42:18 mysystem dbus-broker-launch[563]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jan 18 07:42:18 mysystem kernel: watchdog: watchdog0: watchdog did not stop!
inxi -Fxxxz
  Kernel: 6.7.0-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12
    info: cairo-dock wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 0HD5W2 v: A00 serial: <superuser required>
    UEFI-[Legacy]: Dell v: 1.11.1 date: 10/10/2018
  Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP smt: enabled
    arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
  Speed (MHz): avg: 1774 high: 3400 min/max: 800/3400 cores: 1: 800 2: 800
    3: 800 4: 800 5: 3400 6: 3399 7: 800 8: 3400 bogomips: 54417
  Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
    arch: Gen-9 ports: active: DP-2,HDMI-A-1,HDMI-A-2 empty: DP-1,DP-3,HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1848 s-dpi: 96 s-size: 1016x488mm (40.00x19.21")
    s-diag: 1127mm (44.37")
  Monitor-1: DP-2 mapped: DP2 pos: top-center model: Samsung SyncMaster
    serial: <filter> res: 1360x768 hz: 60 dpi: 84 size: 410x230mm (16.14x9.06")
    diag: 470mm (18.5") modes: max: 1360x768 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI1 pos: bottom-r model: Acer K242HL
    serial: <filter> res: 1920x1080 hz: 60 dpi: 92
    size: 530x300mm (20.87x11.81") diag: 609mm (24") modes: max: 1920x1080
    min: 720x400
  Monitor-3: HDMI-A-2 mapped: HDMI2 pos: primary,bottom-l model: Acer K242HL
    min: 720x400
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
    device-ID: 8086:1912
  API: Vulkan v: 1.3.274 layers: N/A surfaces: xcb,xlib device: 0
    type: integrated-gpu driver: mesa intel device-ID: 8086:1912
  Device-1: Focusrite-Novation Focusrite Scarlett 2i2 driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 1235:8016
    class-ID: fe01
  Device-2: USB MIDI Interface driver: snd-usb-audio type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 bus-ID: 1-7:5 chip-ID: fc02:0101 class-ID: 0103
  API: ALSA v: k6.7.0-0-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: active with: 1: a2jmidid status: active
    2: nsmd status: off
  Server-3: PipeWire v: 1.0.0 status: off with: wireplumber status: off
  Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wireguard1 state: unknown speed: N/A duplex: N/A mac: N/A
  Local Storage: total: 1.39 TiB used: 246.6 GiB (17.4%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
  ID-2: /dev/sdb vendor: Silicon Power model: SPCC Solid State Disk
    size: 953.87 GiB speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 916a
    scheme: GPT
  ID-1: / size: 57.37 GiB used: 21.34 GiB (37.2%) fs: ext4 dev: /dev/sda2
  ID-2: /boot size: 511 MiB used: 240.7 MiB (47.1%) fs: vfat dev: /dev/sda1
  ID-3: /home size: 152.74 GiB used: 61.68 GiB (40.4%) fs: ext4
    dev: /dev/sda3
  System Temperatures: cpu: 29.0 C pch: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 272 Uptime: 19m wakeups: 0 Memory: total: 32 GiB
  available: 31.11 GiB used: 4.23 GiB (13.6%) Init: systemd v: 255
  default: graphical Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1536 Shell: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Plasma - including SDDM - often crashes on custom themes - especially after updates.
It is wellknown that Plasma is extremely sensitive when using custom theming.
I suggest you revert your system - completely - to the default theme - preferably Breeze.
Unfortunately that doesn’t change anything, I can still log in with SDDM - so there are no issues w/ SDDM when starting or login, it’s just a matter of the hangs during shutdown or reboot and I dont know if it’s caused by SDDM …
There were no problems with this before, it started right after the latest upgrade.
hmm - I don’t know - try searching dbus-broker using the search :mag: in upper right corner.
I believe there was an upstream change recently relating to this.
https://archlinux.org/news/making-dbus-broker-our-default-d-bus-daemon/
Also check if dbus-broker and units has been synced to your system
 $ pamac search dbus-broker --no-aur
dbus-broker-units  35-2 [Installed]        core
    Linux D-Bus Message Broker - Service units
dbus-broker  35-2 [Installed]        core
yes, it shows the same output and status just a few warnings
# pamac search dbus-broker --no-aur
# systemctl status dbus-broker.service
● dbus-broker.service - D-Bus System Message Bus
     Loaded: loaded (/usr/lib/systemd/system/dbus-broker.service; static)
     Active: active (running) since Thu 2024-01-18 07:42:48 CET; 3h 51min ago
TriggeredBy: ● dbus.socket
       Docs: man:dbus-broker-launch(1)
   Main PID: 543 (dbus-broker-lau)
      Tasks: 2 (limit: 38194)
     Memory: 5.1M (peak: 5.9M)
        CPU: 293ms
     CGroup: /system.slice/dbus-broker.service
             ├─543 /usr/bin/dbus-broker-launch --scope system --audit
             └─544 dbus-broker --log 4 --controller 9 --machine-id 192e731811b543ccb35273344dbf43c2 --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
systemd[1]: Starting D-Bus System Message Bus...
systemd[1]: Started D-Bus System Message Bus.
dbus-broker-launch[543]: Ready
dbus-broker-launch[543]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
dbus-broker-launch[543]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
dbus-broker-launch[543]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
create a new test user in system settings, reboot, and log in with it and see if it has the same issues…
It seems to be related to this
hmm, or could this be caused by new stuff like (systemd, mkinitcpio…) when a nfs_share is in use?
# cat /etc/fstab
print-pc:/mnt/nfs_share /mnt/share      nfs     auto,x-systemd.automount,x-systemd.device-timeout=10,timeo=14,x-systemd.idle-timeout=1min       0       0
$ inxi -Fazy
    parameters: BOOT_IMAGE=/vmlinuz-6.7-x86_64
    root=UUID=6fbe564e-f0ac-43bb-ae2c-0f8514fb0985 rw quiet i915.enable_psr=0
    i915.enable_fbc=1 udev.log_priority=3 threadirqs
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: cairo-dock
    wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2100 high: 3400 min/max: 800/3400 scaling:
    driver: intel_pstate governor: performance cores: 1: 3400 2: 3400 3: 800
    4: 800 5: 800 6: 3400 7: 800 8: 3400 bogomips: 54417
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
    arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: DP-2,HDMI-A-1,HDMI-A-2 empty: DP-1,DP-3,HDMI-A-3 bus-ID: 00:02.0
    serial: <filter> built: 2009 res: 1360x768 hz: 60 dpi: 84 gamma: 1.2
    size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
    serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    size: 530x300mm (20.87x11.81") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
    device-ID: 8086:1912 memory: 30.38 GiB unified: yes
  API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 530 (SKL GT2) driver: mesa intel v: 23.3.3-manjaro1.1
    device-ID: 8086:1912 surfaces: xcb,xlib
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3
    chip-ID: 1235:8016 class-ID: fe01
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: fc02:0101
    class-ID: 0103
    2: nsmd status: off tools: cadence,jack_control
    tools: pw-cli,wpctl
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Local Storage: total: 1.39 TiB used: 247.78 GiB (17.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 500G
  ID-2: /dev/sdb maj-min: 8:16 vendor: Silicon Power
    model: SPCC Solid State Disk size: 953.87 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 916a
    scheme: GPT
  ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 21.34 GiB (37.2%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 241.9 MiB (47.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 156.25 GiB size: 152.74 GiB (97.75%)
    used: 62.11 GiB (40.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 31.0 C pch: 47.5 C mobo: N/A
  Processes: 279 Uptime: 9h 24m wakeups: 0 Memory: total: 32 GiB
  available: 31.11 GiB used: 4.97 GiB (16.0%) Init: systemd v: 255
  Packages: pm: pacman pkgs: 1535 libs: 470 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
I have found the cause of the problem, jack2 and cadence are installed (including realtime privileges) …
https://bbs.archlinux.org/viewtopic.php?pid=2145907#p2145907
Same problem here, is there a better solution than storing scripts (temporary workarounds) under /usr/lib/systemd?
it seems KillSignal=SIGKILL is needed for jack2 …
This is caused by jackdbus or missing jackdbus support in dbus-broker …
For now I use a KDE shutdown scipt (user in group audio)
/usr/bin/killall -q -w -s KILL jackdbus
inxi data shows jack_control installed, so it might be possible to stop JACK server:
jack_control stop
or exit jack dbus service:
jack_control exit
