System stopped during reboot after update
Hello, I am new to the forum hope this is where I should be posting and how. Believe it or not I have never posted to a forum before. Installed ver. 25 everything went fine. Conducted several updates via command line all went fine. About to do the first complete backup, added 1 more update at the end of Dec. 25 (70 files approx.) system stopped during reboot. I can attach an image showing where the failure occurred. Where should I upload this image?
Hello @THH and welcome to the Manjaro Community! :vulcan_salute:
A better way would be to use OCR (optical character recognition) on the image and post the text here (using the </> button at the top of the Reply window to enclose it in code formatting). That’s something those AI things are surprisingly good at — although please proof-read just in case.
I don’t use image hosting sites myself, so I’ll leave any suggestions regarding those to others.
Hello!
As BG405 said. Images have the problem of disappearing eventually, leaving your post lacking context. If the text is in the actual post, as pre-formatted block, it’ll stay as long as the post exists. This is meaningful in the sense of forming an archive for people to search through when they have issues.
And trust me: I know how it’s like, when you have to get something out of the start-up when the system doesn’t start all the way.
Is it possible to do a rollback ? (btrfs / timeshift)
Your post is lacking information like
inxi -zv8
This can be done from an usb/iso even when the system does not start.
:footprints:
Not just that; such images aren’t searchable in the way plain text is; this essentially requires us to use some form of OCR to do this. :wink:
And, they take up more space in the database than plain text.
Thank everyone for your help. Here is the result from inxi -zv8
sudo su
[manjaro manjaro]# manjaro-chroot-a
bash: manjaro-chroot-a: command not found
[manjaro manjaro]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme1n1p3]
→ mount: [/mnt]
→ mount: [/mnt/boot/efi]
→ mount: [/mnt/home]
[manjaro /]# inxi -zv8
tty: ttyname error: No such device
Kernel 6.12.48-1-MANJARO arch x86_64 bits 64 compiler gcc v 15.2.1 clocksource tsc avail acpi_pm
parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_25010 quiet systemd.show_status=1 splash driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop KDE Plasma v ERR-101 tk Qt v N/A wm kwin_x11 dm N/A Distro Manjaro base Arch Linux
Type Server System Supermicro product Super Server v 03456789 serial Chassis type 17
v 03456789 serial
Mobo Supermicro model X11SSH-GTF-1585 v 1.01 serial
uuid 00000000-0000-0000-0000-ac1f6b2c3ecc Firmware UEFI vendor American Megatrends v 1.2
date 08/29/2018
Message No system battery data found. Is one present?
System RAM total 64 GiB available 62.62 GiB used 4.2 GiB (6.7%)
Array-1 capacity 64 GiB slots 4 modules 4 EC Single-bit ECC max-module-size 16 GiB note est.
Device-1 DIMMA1 type DDR4 detail synchronous size 16 GiB speed spec 2667 MT/s actual 2133 MT/s
volts curr 1.2 min 1.2 max 1.2 width (bits) data 64 total 72 manufacturer Micron
part-no 18ASF2G72HZ-2G6E1 serial
Device-2 DIMMA2 type DDR4 detail synchronous size 16 GiB speed spec 2667 MT/s actual 2133 MT/s
Device-3 DIMMB1 type DDR4 detail synchronous size 16 GiB speed spec 2667 MT/s actual 2133 MT/s
Device-4 DIMMB2 type DDR4 detail synchronous size 16 GiB speed spec 2667 MT/s actual 2133 MT/s
Slot 6 type PCIe gen 3 status in use length long volts 3.3 bus-ID 02:00.0
Slot 5 type PCIe gen 3 status in use length short volts 3.3 bus-ID 01:00.0
Slot 4 type PCIe gen 3 status in use length short volts 3.3 bus-ID 03:00.0
Info model Intel Xeon E3-1585 v5 bits 64 type MT MCP arch Skylake-S level v3 note check
built 2015 process Intel 14nm family 6 model-id 0x5E (94) stepping 3 microcode 0xF0
Topology cpus 1x dies 1 clusters 4 cores 4 threads 8 tpc 2 smt enabled cache L1 256 KiB
desc d-4x32 KiB; i-4x32 KiB L2 1024 KiB desc 4x256 KiB L3 8 MiB desc 1x8 MiB
Speed (MHz) avg 800 min/max 800/3900 base/boost 3500/3900 scaling driver intel_pstate
governor powersave volts 1.3 V ext-clock 100 MHz cores 1 800 2 800 3 800 4 800 5 800 6 800 7 800
8 800 bogomips 56019
Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep
sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Vulnerabilities
Type gather_data_sampling status Vulnerable: No microcode
Type indirect_target_selection status Not affected
Type itlb_multihit status KVM: Split huge pages
Type l1tf mitigation PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type mds mitigation Clear CPU buffers; SMT vulnerable
Type meltdown mitigation PTI
Type mmio_stale_data mitigation Clear CPU buffers; SMT vulnerable
Type reg_file_data_sampling status Not affected
Type retbleed mitigation IBRS
Type spec_rstack_overflow status Not affected
Type spec_store_bypass mitigation Speculative Store Bypass disabled via prctl
Type spectre_v1 mitigation usercopy/swapgs barriers and __user pointer sanitization
Type spectre_v2 mitigation IBRS; IBPB: conditional; STIBP: conditional; RSB filling;
Type srbds mitigation Microcode
Type tsa status Not affected
Type tsx_async_abort mitigation TSX disabled
Type vmscape mitigation IBPB before exit to userspace
Device-1 NVIDIA GP106GL [Quadro P2200] driver nvidia v 580.82.09 non-free 550-580.xx+
status current (as of 2025-11; EOL~2026--xx) arch Pascal code GP10x process TSMC 16nm
built 2016-2021 pcie gen 2 speed 5 GT/s lanes 8 link-max gen 3 speed 8 GT/s lanes 16 ports
active none off DP-2 empty DP-1,DP-3,DP-4 bus-ID 02:00.0 chip-ID 10de:1c31 class-ID 0300
Device-2 ASPEED Graphics Family vendor Super Micro driver ast v kernel ports active VGA-1
empty none bus-ID 08:00.0 chip-ID 1a03:2000 class-ID 0300
Device-3 Logitech Webcam C930e driver snd-usb-audio,uvcvideo type USB rev 2.0 speed 480 Mb/s
lanes 1 mode 2.0 bus-ID 1-11.3:7 chip-ID 046d:0843 class-ID 0102 serial
Display server X.org v 1.21.1.21 with Xwayland v 24.1.9 compositor kwin_x11 driver X
loaded nvidia gpu ast,nvidia,nvidia-nvswitch display-ID :0
Monitor-1 DP-2 model BenQ SW271 serial built 2019 res 3840x2160 dpi 163 gamma 1.2
chroma red x 0.675 y 0.318 green x 0.208 y 0.714 blue x 0.149 y 0.055 white x 0.314 y 0.329
size 597x336mm (23.5x13.23") diag 685mm (27") ratio 16:9 modes 3840x2160, 2560x1440,
1920x1080, 1680x1050, 1600x900, 80x1024, 80x800, 80x720, 1024x768, 1440x480, 800x600,
720x576, 720x480, 640x480
EDID-Warnings 1 parse_edid: unhandled CEA mode 97 2 parse_edid: unhandled CEA mode 96
3 parse_edid: unhandled CEA mode 93 4 parse_edid: unhandled CEA mode 94 5 parse_edid: unhandled
CEA mode 95
Monitor-2 VGA-1 size-res N/A modes 1024x768, 1920x00, 1920x1080, 1600x00, 1680x1050,
1600x900, 80x1024, 1440x900, 1360x768, 80x800, 800x600, 640x480
API EGL Message No EGL data available.
API OpenGL Message GL data unavailable for root.
API Vulkan Message No Vulkan data available.
Info Tools api clinfo, eglinfo, glxinfo, vulkaninfo de kscreen-console,kscreen-doctor
gpu nvidia-settings,nvidia-smi wl wayland-info x11 xdpyinfo,xprop
Device-1 NVIDIA GP106 High Definition Audio driver snd_hda_intel v kernel pcie gen 2 speed 5 GT/s
lanes 8 link-max gen 3 speed 8 GT/s lanes 16 bus-ID 02:00.1 chip-ID 10de:10f1 class-ID 0403
Device-2 C-Media CMI8788 [Oxygen HD Audio] vendor ASUSTeK Virtuoso 100 driver snd_virtuoso
v kernel bus-ID 04:04.0 chip-ID 13f6:8788 class-ID 0401
API ALSA v k6..48-1-MANJARO status kernel-api with aoss type oss-emulator
tools alsactl,alsamixer,amixer
Server-1 JACK v 1.9.22 status off tools N/A
Server-2 PipeWire v 1.4.9 status n/a (root, process) with 1 pipewire-pulse status active
2 wireplumber status active 3 pipewire-alsa type plugin tools pactl,pw-cat,pw-cli,wpctl
Device-1 Intel Ethernet X550 vendor Super Micro driver ixgbe v kernel pcie gen 2 speed 5 GT/s
lanes 4 link-max lanes 8 port N/A bus-ID 05:00.0 chip-ID 8086:1563 class-ID 0200
IF eno1 state down mac
Device-2 Intel Ethernet X550 vendor Super Micro driver ixgbe v kernel pcie gen 2 speed 5 GT/s
lanes 4 link-max lanes 8 port N/A bus-ID 05:00.1 chip-ID 8086:1563 class-ID 0200
IF eno2 state up speed 1000 Mbps duplex full mac
IP v4 type dynamic noprefixroute scope global broadcast
IP v6 type noprefixroute scope link
Info services NetworkManager,systemd-timesyncd
WAN IP
Message No bluetooth data found.
Message No logical block device data found.
Message No RAID data found.
Local Storage total 5.53 TiB used 95.98 GiB (1.7%)
SMART Message Required tool smartctl not installed. Check --recommends
ID-1 /dev/nvme0n1 maj-min 259:5 vendor Samsung model SSD 970 PRO 1TB size 953.87 GiB block-size
physical 5 B logical 5 B speed 31.6 Gb/s lanes 4 tech SSD serial fw-rev 1B2QEXP7
temp 30.9 C
ID-2 /dev/nvme1n1 maj-min 259:0 vendor Samsung model SSD 9100 PRO with Heatsink 4TB
size 3.64 TiB block-size physical 5 B logical 5 B speed 6 Gb/s lanes 4 tech SSD
serial fw-rev 0B2QNXH7 temp 31.9 C
ID-3 /dev/sda maj-min 8:0 vendor A-Data model SX 8200PNP R090 size 953.87 GiB block-size
physical 4096 B logical 5 B type USB rev 3.2 spd 5 Gb/s lanes 1 mode 3.2 gen-1x1 tech N/A
serial fw-rev 0204
ID-4 /dev/sdc maj-min 8:32 vendor Kingston model Multi-Reader -1 size 29.72 GiB block-size
physical 5 B logical 5 B type USB rev 3.0 spd 5 Gb/s lanes 1 mode 3.2 gen-1x1 tech N/A
serial fw-rev 1.00
Optical-1 /dev/sr0 vendor HL-DT-ST model BD-RE BE16NU50 rev 1.04 dev-links cdrom
Features speed 48 multisession yes audio yes dvd yes rw cd-r,cd-rw,dvd-r,dvd-ram state running
ID-1 / raw-size 50.78 GiB size 49.68 GiB (97.84%) used 16.91 GiB (34.0%) fs ext4
block-size 4096 B dev /dev/nvme1n1p3 maj-min 259:2 label N/A
uuid b528d2-27b1-49bb-9f2f-31bab84a27eb
ID-2 /boot/efi raw-size 700 MiB size 698.6 MiB (99.80%) used 332 KiB (0.0%) fs vfat
block-size 5 B dev /dev/nvme1n1p2 maj-min 259:1 label N/A uuid 6021-8CAB
ID-3 /home raw-size 3.05 TiB size 3 TiB (98.40%) used 79.07 GiB (2.6%) fs ext4
block-size 4096 B dev /dev/nvme1n1p5 maj-min 259:4 label N/A
uuid 819eadd1-e408-42c7-8bae-842abfc9d7f5
Alert No swap data was found.
ID-1 /dev/nvme0n1p1 maj-min 259:6 size 748.5 MiB fs ntfs label N/A uuid 18E6FA61E6FA3E96
ID-2 /dev/nvme0n1p2 maj-min 259:7 size 100 MiB fs fat (32 bit) label N/A uuid 3E9B-9F4B
ID-3 /dev/nvme0n1p3 maj-min 259:8 size 16 MiB fs N/A label N/A uuid N/A
ID-4 /dev/nvme0n1p4 maj-min 259:9 size 476.5 GiB fs ntfs label Win10 64 uuid E6EA9C97EA9C6599
ID-5 /dev/nvme0n1p5 maj-min 259:10 size 476.52 GiB fs ntfs label Pro10 uuid 01DC5061C61BC230
ID-6 /dev/nvme1n1p4 maj-min 259:3 size 20.31 GiB fs swap label N/A
uuid 784a4f-ffc0-4f3c-9f25-5be5eb937888
ID-7 /dev/sda1 maj-min 8:1 size 953.87 GiB fs N/A label Data 1 uuid 6F5E-E8B3
ID-8 /dev/sdc1 maj-min 8:33 size 5.1 GiB fs N/A label N/A uuid N/A
ID-9 /dev/sdc2 maj-min 8:34 size 4 MiB fs N/A label MISO_EFI uuid CA66-EF73
Hub-1 1-0:1 info hi-speed hub with single TT ports 16 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1
mode 2.0 chip-ID 1d6b:0002 class-ID 0900
Device-1 1-1:2 info Cooler Master MK770 Hybrid Mechanical Keyboard type keyboard
driver hid-generic,usbhid interfaces 4 rev 1.1 speed  Mb/s (1.4 MiB/s) lanes 1 mode 1.1
power 100mA chip-ID 2516:01d5 class-ID 0301 serial
Device-2 1-10:3 info Logitech Logi Bolt Receiver type keyboard,mouse,HID
driver hid-generic,usbhid interfaces 3 rev 2.0 speed  Mb/s (1.4 MiB/s) lanes 1 mode 1.1
power 98mA chip-ID 046d:c548 class-ID 0300
Hub-2 1-11:4 info Realtek RTS5411 Hub ports 4 rev 2.1 speed 480 Mb/s (57.2 MiB/s) lanes 1
mode 2.0 chip-ID 0bda:5411 class-ID 0900
Hub-3 1-11.1:6 info Genesys Logic Hub ports 2 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1
mode 2.0 power 100mA chip-ID 05e3:0610 class-ID 0900
Device-1 1-11.1.2:9 info Future Devices USB ↔ Serial Cable type driver N/A
interfaces 1 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 power 100mA chip-ID 0403:7a58
class-ID 0000
Device-2 1-11.3:7 info Logitech Webcam C930e type video,audio driver snd-usb-audio,uvcvideo
interfaces 4 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 power 500mA chip-ID 046d:0843
Hub-4 1-13:5 info ATEN Hub ports 4 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0
power 100mA chip-ID 0557:7000 class-ID 0900
Device-1 1-13.1:8 info ATEN Virtual mouse/keyboard device type keyboard,mouse
driver hid-generic,usbhid interfaces 2 rev 1.1 speed 1.5 Mb/s (183 KiB/s) lanes 1 mode 1.0
power 160mA chip-ID 0557:2419 class-ID 0301
Hub-5 2-0:1 info super-speed hub ports 10 rev 3.0 speed 5 Gb/s (596.0 MiB/s) lanes 1
mode 3.2 gen-1x1 chip-ID 1d6b:0003 class-ID 0900
Device-1 2-1:2 info Logitec JMS583 Gen 2 - PCIe Gen3x2 Bridge type mass storage driver uas
interfaces 1 rev 3.2 speed 5 Gb/s (596.0 MiB/s) lanes 1 mode 3.2 gen-1x1 power 896mA
chip-ID 0789:0578 class-ID 0806 serial
Device-2 2-2:3 info LG (HLDS) GP08NU6W DVD-RW type mass storage driver usb-storage interfaces 1
rev 3.0 speed 5 Gb/s (596.0 MiB/s) lanes 1 mode 3.2 gen-1x1 power 96mA chip-ID 152e:2571
Hub-6 2-5:4 info Realtek Hub ports 4 rev 3.1 speed 5 Gb/s (596.0 MiB/s) lanes 1
mode 3.2 gen-1x1 chip-ID 0bda:0411 class-ID 0900
Device-1 2-5.2:5 info ATECH FLASH Multi-Reader type mass storage driver usb-storage
interfaces 1 rev 3.0 speed 5 Gb/s (596.0 MiB/s) lanes 1 mode 3.2 gen-1x1 power 800mA
chip-ID 11b0:6368 class-ID 0806 serial
Device-2 2-5.4:6 info Genesys Logic SD Card Reader and Writer type mass storage
driver usb-storage interfaces 1 rev 3.0 speed 5 Gb/s (596.0 MiB/s) lanes 1 mode 3.2 gen-1x1
power 896mA chip-ID 05e3:0749 class-ID 0806 serial
System Temperatures cpu 31.7 C pch 34.5 C mobo N/A
Fan Speeds (rpm) N/A
Packages 1434 pm pacman pkgs 1427 libs 378 tools pamac pm flatpak pkgs 7
Active pacman repo servers in /etc/pacman.d/mirrorlist
1 https: //opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
2 https: //mirror.fcix.net/manjaro/stable/$repo/$arch
3 https: //mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
4 https: //mirrors.sonic.net/manjaro/stable/$repo/$arch
5 https: //mirrors.gigenet.com/manjaro/stable/$repo/$arch
6 https: //coresite.mm.fcix.net/manjaro/stable/$repo/$arch
7 https: //forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
8 https: //nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top 5 of 278
1 cpu 100% command ps pid 19757 mem 3.94 MiB (0.0%)
2 cpu 4.8% command plasmashell pid 18096 mem 479.8 MiB (0.7%)
3 cpu 4.4% command Xorg pid 17968 mem 149.5 MiB (0.2%)
4 cpu 3.4% command kwin_x11 pid 18057 mem 248.6 MiB (0.3%)
5 cpu 2.0% command konsole pid 18482 mem 130.7 MiB (0.2%)
Memory top 5 of 278
1 mem 479.8 MiB (0.7%) command plasmashell pid 18096 cpu 4.8%
2 mem 248.6 MiB (0.3%) command kwin_x11 pid 18057 cpu 3.4%
3 mem 149.5 MiB (0.2%) command Xorg pid 17968 cpu 4.4%
4 mem 130.7 MiB (0.2%) command konsole pid 18482 cpu 2.0%
5 mem 4.7 MiB (0.1%) command yakuake pid 18298 cpu 0.6%
Processes 278 Power uptime 3m states freeze,mem,disk suspend s2idle wakeups 0 hibernate platform
avail shutdown, reboot, suspend, test_resume image 25 GiB services org_kde_powerdevil,
power-profiles-daemon, upowerd Init systemd v 258 default graphical tool systemctl
Compilers clang 21.1.6 gcc 15.2.1 Client systemd inxi 3.3.40
[manjaro /]#
Mod edit: Added code formatting and removed those 12s. There might be some valid 12s missing as a result.
Tip for future reference: When running inxi in chroot, those 12s can be avoided using inxi -zv8x0 … we should have mentioned this, I guess. :speak_no_evil_monkey:
Here is the boot screen before the update stall
Good GRUB before update.
Manjaro Linux
Advanced options for Manjaro Linux
Windows Boot Manager (on /dev/nvme0n1p2)
UEFI Firmware Settings
Memory Tester (memtest86+)
Unable to resume from device ‘/deu/disk/by-uuid/784a4f12-ffc0-4f3c-9f25-5be5eb93     “Not sure if this is an issue.”
7888’ (259:3) offset 0, continuing boot process.
/dev/nume1n1p3: clean, 506993/3334144 files, 4508504/13312000 blocks
Here is the screen info after the update when it stalled
Stopped Virtual Console Setup.
StoppedgVVrtáad lC6ogeddeS8tápp .. .
Stopping Virtual Console Setup …
Ftartbng Virtual Console Setup …
Finished Otetta1SgohsulEiSesupud Directories.
Statsheg Beeatd System BddesShuddDunectoUTUB …
Finithad Record System Boot/Shutdown in UTMP …
Started Monthly clean packages cache.
Started Generate mirrorlist weekly.
Started Daily verification of password and group files.
Started Daily Cleanup of Temporary Directories.
Reached target Path Units.
Reached target Timer Units.
Listening on CUPS Scheduler.
Listening on D-Bus System Message Bus Socket.
Listening on GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg
Listening on GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Listening on GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Listening on GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Listening on GnuPG public key management service for /etc/pacman.d/gnupg.
Listening on Authorization Manager Agent Helper.
Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Listening on Hostname Service Socket.
Listening on User Login Management Varlink Socket.
Listening on Virtual Machine and Container Registration Service Socket.
Reached target Socket Units.
Starting D-Bus System Message Bus …
Started D-Bus System Message Bus.
Reached target Basic System.
Starting Network Manager.
Starting Save/Restore Sound Card State …
Starting Authorization Manager ..
Starting User Login Management …
Finished Save/Restore Sound Card State.
Reached target Sound Card.
Starting Hostname Service ..
Started User Login Management.
Started Authorization Manager.
Starting Modem Manager …
Started Hostname Service.
Listening on Load/Save RF Kill Switch Status /deu/rfkill Watch.
Started Modem Manager.
Starting Network Manager Script Dispatcher Service …
Started Network Manager.
Reached target Network.
Starting CUPS Scheduler ..
Starting Permit User Sessions ..
Started Network Manager Script Dispatcher Service.
Finished Permit User Sessions.
Started Command Scheduler.
Starting Hold until boot process finishes up …
Starting Terminate Plymouth Boot Screen …
Started CUPS Scheduler.
OK for all of the above
Stalled at the last line.
Some text might not have OCR’d correctly most did
Mod edit: Added code formatting. :wink:
Before I joined the forum, I wanted to understand as much as I could about linux. I used manjaro-charoot -a and and ran some commands and did my best not to damage the current install.
Lmanjaro manjaro \]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device. map.
== > Mounting (ManjaroLinux) \[/dev/nvme1n1p3\]
– > mount: \[/mnt\]
– > mount: \[/mnt/boot/efi\]
– > mount: \[/mnt/home\]
\[manjaro /\]# grub-install – target=x86_64-efi – efi-directory=/boot/efi – bootloader-id=manjaro – recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
\[manjaro /\]# grub-mkconfig -o /boot/grub.cfg
Generating grub configuration file
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode. img /boot/initramfs-6.12-x86_64. img
ERROR: mkdir /var/lock/dmraid
Adding boot menu entry for UEFI Firmware Settings
Root filesystem isn’t btrfs
If you think an error has occurred, please file a bug report at “https://github. com/Antynea/grub-btrfs”
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
manjaro
\[manjaro /\]# fdisk -l
Disk /dev/nvme0n1: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: Samsung SSD 9100 PRO with Heatsink 4TB
Units: sectors of 1 \* 512 = 512 bytes
Disklabel type: gpt
Disk identifier: EE0846BE-C4F8-11F0-91A9-AC1F6B2C3ECD
Device             Start        End    Sectors  Size Type
/dev/nvme0n1p2      2048    1435647    1433600  700M EFI System
/dev/nvme0n1p3   1435648  107931647  106496000 50.8G Linux filesystem
/dev/nvme0n1p4 107931648  150530047   42598400 20.3G Linux swap
/dev/nvme0n1p5 150530048 6704130047 6553600000  3.1T Linux filesystem
Disk /dev/nvme1n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: Samsung SSD 970 PRO 1TB
Disklabel type: gpt
Disk identifier: 71F5ADED-BB34-9366-ADE9-48E31EBDA19D
/dev/nvme1n1p1       2048    1534975   1532928 748.5M Windows recovery environment
/dev/nvme1n1p2    1534976    1739775    204800   100M EFI System
/dev/nvme1n1p3    1739776    1772543     32768    16M Microsoft reserved
/dev/nvme1n1p4    1772544 1001065471 999292928 476.5G Microsoft basic data
/dev/nvme1n1p5 1001065472 2000409229 999343758 476.5G Microsoft basic data
Disk /dev/sda: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: 8200PNP     R090
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 19E845EC-BF04-11F0-9194-AC1F6B2C3ECD
/dev/sda1   2048 2000408575 2000406528 953.9G Microsoft basic data
Disk /dev/sdc: 29.72 GiB, 31914983424 bytes, 62333952 sectors
Disk model: Multi-Reader  -1
Disklabel type: dos
Disk identifier: 0xed436cbf
Device     Boot    Start      End  Sectors  Size Id Type
/dev/sdc1  \*          64 10694619 10694556  5.1G  0 Empty
/dev/sdc2       10694620 10702811     8192    4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 39.75 MiB, 41684992 bytes, 81416 sectors
Disk /dev/loop1: 2.16 GiB, 2318643200 bytes, 4528600 sectors
Disk /dev/loop2: 1.85 GiB, 1986961408 bytes, 3880784 sectors
Disk /dev/loop3: 928.31 MiB, 973406208 bytes, 1901184 sectors
\[manjaro /\]#
````Preformatted text`
I ran the journalctl -b -x -p3, Kernal Ring Buffer, and Timshift. They returned some info. not much. I can post the information if you feel it would be useful.
Thanks for having a go with the OCR; even though it isn’t perfect, it’s quite likely better than some of us could read the actual image. :wink:
I’ve added code formatting to a couple of your previous posts; this makes it much more Forum-Friendly™. The easiest way I find is to add three backticks ``` on their own lines above and below the pasted output. Could I ask you to do the same on the last one? Don’t worry if you get stuck; we can fix that. :smiley:
As for those 12s, this is an issue with inxi when used in a chroot environment, at present at least, so I also left a little tip at the bottom of your post for how to avoid this (inxi -zv8c0) which will hopefully help if you need to post updated results.
Thank you for the information and updating my input. Hopefully I added the ``` in the correct places. Is there any other information I can provide and do you feel I can recover this installation? I am a bit outdated, some fortarn 4/punch card, IBM os2, lastly windows (sadly) generation person.
The formatting is spot on, thanks. :ok_hand:
I can’t really see anything wrong (so far) in those outputs (the GRUB error messages referring to sdc can obviously be ignored, since that’s your flash drive).
What I might suggest if it’s accessible is to remove the Windows disk (as I see this appears to be a dual-boot system) and then re-run the grub update within manjaro-chroot again; see if this makes any difference?
Removed the windows drive.
Loaded manjaro-chroot -a from live boot disk
Updated the GRUB ([manjaro /]# grub-install – target=x86_64-efi – efi-directory=/boot/efi – bootloader-id=manjaro – recheck)
No errors, exited and booted the system, it stalled at the same point.
Loaded live manjaro again, entered chroot, ran the following. ([ -f /var/lib/pacman/db.lck ] && rm -f /var/lib/pacman/db.lck
pacman-mirrors -f && pacman -Syyu
update-grub
exit) no errors. exited and boot the system, it stalled with to new lines.
18.9020381] intel_ish_ipc 0000:00:13.0: [ishtp-ish]: Timed out wating for FW-initiated rest
18.9029641] intel_ish_ipc 0000:00:13.0 ISH: hw start failed.
Back into the live disk, added a new kernel using ([ -f /var/lib/pacman/db.lck ] && rm -f /var/lib/pacman/db.lck
pacman -Syu
mhwd-kernel -i linux618
update-grub)
Reboot the system, stalls a the same point, no difference.
[manjaro /]# [ -f /var/lib/pacman/db.lck ] && rm -f /var/lib/pacman/db.lck
pacman -Syu
update-grub
 core is up to date
 extra is up to date
 multilib is up to date
 there is nothing to do
 core is up to date
 extra is up to date
resolving dependencies...
Packages (2) linux618-6.18.4-1  linux618-nvidia-590.48.01-5
Total Download Size:   228.32 MiB
Total Installed Size:  234.48 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 linux618-nvidia-590.4...    83.7 MiB  17.9 MiB/s 00:05 [##############################] 100%
 linux618-6.18.4-1-x86_64   144.6 MiB  22.9 MiB/s 00:06 [##############################] 100%
 Total (2/2)                228.3 MiB  36.1 MiB/s 00:06 [##############################] 100%
(2/2) checking keys in keyring                          [##############################] 100%
(2/2) checking package integrity                        [##############################] 100%
(2/2) loading package files                             [##############################] 100%
(2/2) checking for file conflicts                       [##############################] 100%
(2/2) checking available disk space                     [##############################] 100%
(1/2) installing linux618                               [##############################] 100%
Optional dependencies for linux618
    linux-firmware: firmware images needed for some devices [installed]
    scx-scheds: to use sched-ext schedulers
    wireless-regdb: to set the correct wireless channels of your country [installed]
(2/2) installing linux618-nvidia                        [##############################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux618.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.18-x86_64 -g /boot/initramfs-6.18-x86_64.img
==> Starting build: '6.18.4-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'ast'
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [resume]
  -> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.18-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Running post hooks
  -> Running post hook: [sbctl]
Secureboot key directory doesn't exist, not signing!
==> Post processing done
(4/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.18-x86_64.img
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
(5/5) Signing EFI binaries...
Generating EFI bundles....
done
Back into live disk and chroot, ran log command.
-- Boot 12b40ade367542868e15b1f4686fa491 --
Dec 18 21:27:34 Manjaro kernel: Linux version 6.12.62-1-MANJARO (linux612@manjaro) (gcc (GCC>
Dec 18 21:27:34 Manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID>
Dec 18 21:27:34 Manjaro kernel: BIOS-provided physical RAM map:
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000003efff] usable
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x000000000003f000-0x000000000003ffff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x0000000000040000-0x000000000009dfff] usable
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000066b88fff] usable
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x0000000066b89000-0x0000000066b89fff] ACPI >
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x0000000066b8a000-0x0000000066bd3fff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x0000000066bd4000-0x000000006cff5fff] usable
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x000000006cff6000-0x000000006d385fff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x000000006d386000-0x000000006d3b5fff] ACPI >
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x000000006d3b6000-0x000000006dd07fff] ACPI >
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x000000006dd08000-0x000000006fffefff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x000000006ffff000-0x000000006fffffff] usable
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reser>
Dec 18 21:27:34 Manjaro kernel: BIOS-e820: [mem 0x0000000100000000-0x0000001087bfffff] usable
Dec 18 21:27:34 Manjaro kernel: NX (Execute Disable) protection: active
Dec 18 21:27:34 Manjaro kernel: APIC: Static calls initialized
Dec 18 21:27:34 Manjaro kernel: e820: update [mem 0x60acb018-0x60aeac57] usable ==> usable
Dec 18 21:27:34 Manjaro kernel: e820: update [mem 0x60a96018-0x60acac57] usable ==> usable
Dec 18 21:27:34 Manjaro kernel: e820: update [mem 0x60a61018-0x60a95c57] usable ==> usable
Dec 18 21:27:34 Manjaro kernel: e820: update [mem 0x60a58018-0x60a60057] usable ==> usable
Dec 18 21:27:34 Manjaro kernel: extended physical RAM map:
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000003ef>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x000000000003f000-0x000000000003ff>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000000040000-0x000000000009df>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x000000000009e000-0x000000000009ff>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000000100000-0x0000000060a580>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060a58018-0x0000000060a600>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060a60058-0x0000000060a610>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060a61018-0x0000000060a95c>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060a95c58-0x0000000060a960>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060a96018-0x0000000060acac>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060acac58-0x0000000060acb0>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060acb018-0x0000000060aeac>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000060aeac58-0x0000000066b88f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000066b89000-0x0000000066b89f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000066b8a000-0x0000000066bd3f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000066bd4000-0x000000006cff5f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x000000006cff6000-0x000000006d385f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x000000006d386000-0x000000006d3b5f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x000000006d3b6000-0x000000006dd07f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x000000006dd08000-0x000000006fffef>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x000000006ffff000-0x000000006fffff>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x00000000e0000000-0x00000000efffff>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00f>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffff>
Dec 18 21:27:34 Manjaro kernel: reserve setup_data: [mem 0x0000000100000000-0x0000001087bfff>
Dec 18 21:27:34 Manjaro kernel: efi: EFI v2.4 by American Megatrends
Dec 18 21:27:34 Manjaro kernel: efi: TPMFinalLog=0x6dcf0000 ESRT=0x6fc2d918 ACPI=0x6dc83000 >
Dec 18 21:27:34 Manjaro kernel: efi: Remove mem32: MMIO range=[0xe0000000-0xefffffff] (256MB>
Dec 18 21:27:34 Manjaro kernel: e820: remove [mem 0xe0000000-0xefffffff] reserved
Dec 18 21:27:34 Manjaro kernel: efi: Not removing mem33: MMIO range=[0xfe000000-0xfe010fff] >
Dec 18 21:27:34 Manjaro kernel: efi: Not removing mem34: MMIO range=[0xfec00000-0xfec00fff] >
Dec 18 21:27:34 Manjaro kernel: efi: Not removing mem35: MMIO range=[0xfee00000-0xfee00fff] >
Dec 18 21:27:34 Manjaro kernel: efi: Remove mem36: MMIO range=[0xff000000-0xffffffff] (16MB)>
Dec 18 21:27:34 Manjaro kernel: e820: remove [mem 0xff000000-0xffffffff] reserved
Dec 18 21:27:34 Manjaro kernel: SMBIOS 3.0.0 present.
Dec 18 21:27:34 Manjaro kernel: DMI: Supermicro Super Server/X11SSH-GTF-1585, BIOS 1.2 08/29>
Dec 18 21:27:34 Manjaro kernel: DMI: Memory slots populated: 4/4
Dec 18 21:27:34 Manjaro kernel: tsc: Detected 3500.000 MHz processor
Dec 18 21:27:34 Manjaro kernel: tsc: Detected 3499.912 MHz TSC
Dec 18 21:27:34 Manjaro kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 18 21:27:34 Manjaro kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 18 21:27:34 Manjaro kernel: last_pfn = 0x1087c00 max_arch_pfn = 0x400000000
Dec 18 21:27:34 Manjaro kernel: MTRR map: 4 entries (3 fixed + 1 variable; max 23), built fr>
Dec 18 21:27:34 Manjaro kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT>
Dec 18 21:27:34 Manjaro kernel: last_pfn = 0x70000 max_arch_pfn = 0x400000000
Dec 18 21:27:34 Manjaro kernel: esrt: Reserving ESRT space from 0x000000006fc2d918 to 0x0000>
Dec 18 21:27:34 Manjaro kernel: Using GB pages for direct mapping
Dec 18 21:27:34 Manjaro kernel: Secure boot disabled
Dec 18 21:27:34 Manjaro kernel: RAMDISK: [mem 0x60aeb000-0x64cdbfff]
Dec 18 21:27:34 Manjaro kernel: ACPI: Early table checksum verification disabled
Dec 18 21:27:34 Manjaro kernel: ACPI: RSDP 0x000000006DC83000 000024 (v02 SUPERM)
Dec 18 21:27:34 Manjaro kernel: ACPI: XSDT 0x000000006DC830B0 0000E4 (v01 SUPERM SUPERM   01>
Dec 18 21:27:34 Manjaro kernel: ACPI: FACP 0x000000006DCA59B0 00010C (v05                 01>
Dec 18 21:27:34 Manjaro kernel: ACPI: DSDT 0x000000006DC83230 02277F (v02 SUPERM SMCI--MB 01>
Dec 18 21:27:34 Manjaro kernel: ACPI: FACS 0x000000006DCEEF80 000040
Dec 18 21:27:34 Manjaro kernel: ACPI: APIC 0x000000006DCA5AC0 0000BC (v03                 01>
Dec 18 21:27:34 Manjaro kernel: ACPI: FPDT 0x000000006DCA5B80 000044 (v01                 01>
Dec 18 21:27:34 Manjaro kernel: ACPI: FIDT 0x000000006DCA5BC8 00009C (v01                 01>
Dec 18 21:27:34 Manjaro kernel: ACPI: SPMI 0x000000006DCA5C68 000041 (v05 SUPERM SMCI--MB 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: MCFG 0x000000006DCA5CB0 00003C (v01 SUPERM SMCI--MB 01>
Dec 18 21:27:34 Manjaro kernel: ACPI: HPET 0x000000006DCA5CF0 000038 (v01 SUPERM SMCI--MB 01>
Dec 18 21:27:34 Manjaro kernel: ACPI: LPIT 0x000000006DCA5D28 000094 (v01 INTEL  GNLR     00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0x000000006DCA5DC0 000248 (v02 INTEL  sensrhub 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0x000000006DCA6008 002BAE (v02 INTEL  PtidDevc 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0x000000006DCA8BB8 000BE3 (v02 INTEL  Ther_Rvp 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: DBGP 0x000000006DCA97A0 000034 (v01 INTEL           00>
Dec 18 21:27:34 Manjaro kernel: ACPI: DBG2 0x000000006DCA97D8 000054 (v00 INTEL           00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0x000000006DCA9830 000617 (v02 INTEL  xh_Zumba 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: PRAD 0x000000006DCA9E48 0000CA (v02 PRADID PRADTID  00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0x000000006DCA9F18 00547E (v02 SaSsdt SaSsdt   00>
Dec 18 21:27:34 Manjaro kernel: ACPI: UEFI 0x000000006DCAF398 000042 (v01                 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0x000000006DCAF3E0 000E73 (v02 CpuRef CpuSsdt  00>
Dec 18 21:27:34 Manjaro kernel: ACPI: DMAR 0x000000006DCB0258 000070 (v01 INTEL  SKL      00>
Dec 18 21:27:34 Manjaro kernel: ACPI: TPM2 0x000000006DCB02C8 000034 (v03        Tpm2Tabl 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: EINJ 0x000000006DCB0300 000130 (v01 AMI    AMI.EINJ 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: ERST 0x000000006DCB0430 000230 (v01 AMIER  AMI.ERST 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: BERT 0x000000006DCB0660 000030 (v01 AMI    AMI.BERT 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: HEST 0x000000006DCB0690 00027C (v01 AMI    AMI.HEST 00>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving FACP table memory at [mem 0x6dca59b0-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving DSDT table memory at [mem 0x6dc83230-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving FACS table memory at [mem 0x6dceef80-0x6dcee>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving APIC table memory at [mem 0x6dca5ac0-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving FPDT table memory at [mem 0x6dca5b80-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving FIDT table memory at [mem 0x6dca5bc8-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving SPMI table memory at [mem 0x6dca5c68-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving MCFG table memory at [mem 0x6dca5cb0-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving HPET table memory at [mem 0x6dca5cf0-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving LPIT table memory at [mem 0x6dca5d28-0x6dca5>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0x6dca5dc0-0x6dca6>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0x6dca6008-0x6dca8>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0x6dca8bb8-0x6dca9>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving DBGP table memory at [mem 0x6dca97a0-0x6dca9>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving DBG2 table memory at [mem 0x6dca97d8-0x6dca9>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0x6dca9830-0x6dca9>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving PRAD table memory at [mem 0x6dca9e48-0x6dca9>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0x6dca9f18-0x6dcaf>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving UEFI table memory at [mem 0x6dcaf398-0x6dcaf>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0x6dcaf3e0-0x6dcb0>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving DMAR table memory at [mem 0x6dcb0258-0x6dcb0>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving TPM2 table memory at [mem 0x6dcb02c8-0x6dcb0>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving EINJ table memory at [mem 0x6dcb0300-0x6dcb0>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving ERST table memory at [mem 0x6dcb0430-0x6dcb0>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving BERT table memory at [mem 0x6dcb0660-0x6dcb0>
Dec 18 21:27:34 Manjaro kernel: ACPI: Reserving HEST table memory at [mem 0x6dcb0690-0x6dcb0>
Dec 18 21:27:34 Manjaro kernel: No NUMA configuration found
Dec 18 21:27:34 Manjaro kernel: Faking a node at [mem 0x0000000000000000-0x0000001087bfffff]
Dec 18 21:27:34 Manjaro kernel: NODE_DATA(0) allocated [mem 0x1087bd52c0-0x1087bfffff]
Dec 18 21:27:34 Manjaro kernel: Zone ranges:
Dec 18 21:27:34 Manjaro kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Dec 18 21:27:34 Manjaro kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Dec 18 21:27:34 Manjaro kernel:   Normal   [mem 0x0000000100000000-0x0000001087bfffff]
Dec 18 21:27:34 Manjaro kernel:   Device   empty
Dec 18 21:27:34 Manjaro kernel: Movable zone start for each node
Dec 18 21:27:34 Manjaro kernel: Early memory node ranges
Dec 18 21:27:34 Manjaro kernel:   node   0: [mem 0x0000000000001000-0x000000000003efff]
Dec 18 21:27:34 Manjaro kernel:   node   0: [mem 0x0000000000040000-0x000000000009dfff]
Dec 18 21:27:34 Manjaro kernel:   node   0: [mem 0x0000000000100000-0x0000000066b88fff]
Dec 18 21:27:34 Manjaro kernel:   node   0: [mem 0x0000000066bd4000-0x000000006cff5fff]
Dec 18 21:27:34 Manjaro kernel:   node   0: [mem 0x000000006ffff000-0x000000006fffffff]
Dec 18 21:27:34 Manjaro kernel:   node   0: [mem 0x0000000100000000-0x0000001087bfffff]
Dec 18 21:27:34 Manjaro kernel: Initmem setup node 0 [mem 0x0000000000001000-0x0000001087bff>
Dec 18 21:27:34 Manjaro kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Dec 18 21:27:34 Manjaro kernel: On node 0, zone DMA: 98 pages in unavailable ranges
Dec 18 21:27:34 Manjaro kernel: On node 0, zone DMA32: 75 pages in unavailable ranges
Dec 18 21:27:34 Manjaro kernel: On node 0, zone DMA32: 12297 pages in unavailable ranges
Dec 18 21:27:34 Manjaro kernel: On node 0, zone Normal: 1024 pages in unavailable ranges
Dec 18 21:27:34 Manjaro kernel: ACPI: PM-Timer IO Port: 0x1808
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Dec 18 21:27:34 Manjaro kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0->
Dec 18 21:27:34 Manjaro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Dec 18 21:27:34 Manjaro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Dec 18 21:27:34 Manjaro kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Dec 18 21:27:34 Manjaro kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
Dec 18 21:27:34 Manjaro kernel: TSC deadline timer available
Dec 18 21:27:34 Manjaro kernel: CPU topo: Max. logical packages:   1
Dec 18 21:27:34 Manjaro kernel: CPU topo: Max. logical dies:       1
Dec 18 21:27:34 Manjaro kernel: CPU topo: Max. dies per package:   1
Dec 18 21:27:34 Manjaro kernel: CPU topo: Max. threads per core:   2
Dec 18 21:27:34 Manjaro kernel: CPU topo: Num. cores per package:     4
Dec 18 21:27:34 Manjaro kernel: CPU topo: Num. threads per package:   8
Dec 18 21:27:34 Manjaro kernel: CPU topo: Allowing 8 present CPUs plus 0 hotplug CPUs
Dec 18 21:27:34 Manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0>
Dec 18 21:27:34 Manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x0003f000-0>
Dec 18 21:27:34 Manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0>
Dec 18 21:27:34 Manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x66b89000-0>
Dec 18 21:27:34 Manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x6cff6000-0>
Dec 18 21:27:34 Manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x70000000-0>
Dec 18 21:27:34 Manjaro kernel: [mem 0x70000000-0xfdffffff] available for PCI devices
Dec 18 21:27:34 Manjaro kernel: Booting paravirtualized kernel on bare hardware
Dec 18 21:27:34 Manjaro kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0>
Dec 18 21:27:34 Manjaro kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr>
Dec 18 21:27:34 Manjaro kernel: percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
Dec 18 21:27:34 Manjaro kernel: pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
Dec 18 21:27:34 Manjaro kernel: pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
Dec 18 21:27:34 Manjaro kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 ro>
Dec 18 21:27:34 Manjaro kernel: Unknown kernel command line parameters "splash", will be pas>
Dec 18 21:27:34 Manjaro kernel: random: crng init done
Dec 18 21:27:34 Manjaro kernel: Dentry cache hash table entries: 8388608 (order: 14, 6710886>
Dec 18 21:27:34 Manjaro kernel: Inode-cache hash table entries: 4194304 (order: 13, 33554432>
Dec 18 21:27:34 Manjaro kernel: Fallback order for Node 0: 0
Dec 18 21:27:34 Manjaro kernel: Built 1 zonelists, mobility grouping on.  Total pages: 16730>
Dec 18 21:27:34 Manjaro kernel: Policy zone: Normal
Dec 18 21:27:34 Manjaro kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Dec 18 21:27:34 Manjaro kernel: software IO TLB: area num 8.
Dec 18 21:27:34 Manjaro kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Dec 18 21:27:34 Manjaro kernel: Kernel/User page tables isolation: enabled
Dec 18 21:27:34 Manjaro kernel: ftrace: allocating 51488 entries in 202 pages
Dec 18 21:27:34 Manjaro kernel: ftrace: allocated 202 pages with 4 groups
Dec 18 21:27:34 Manjaro kernel: Dynamic Preempt: full
Dec 18 21:27:34 Manjaro kernel: rcu: Preemptible hierarchical RCU implementation.
Dec 18 21:27:34 Manjaro kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cp>
Dec 18 21:27:34 Manjaro kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Dec 18 21:27:34 Manjaro kernel:         Trampoline variant of Tasks RCU enabled.
Dec 18 21:27:34 Manjaro kernel:         Rude variant of Tasks RCU enabled.
Dec 18 21:27:34 Manjaro kernel:         Tracing variant of Tasks RCU enabled.
Dec 18 21:27:34 Manjaro kernel: rcu: RCU calculated value of scheduler-enlistment delay is 3>
Dec 18 21:27:34 Manjaro kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
Dec 18 21:27:34 Manjaro kernel: RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjus>
Dec 18 21:27:34 Manjaro kernel: RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_>
Dec 18 21:27:34 Manjaro kernel: RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb>
Dec 18 21:27:34 Manjaro kernel: NR_IRQS: 524544, nr_irqs: 488, preallocated irqs: 16
Dec 18 21:27:34 Manjaro kernel: rcu: srcu_init: Setting srcu_struct sizes based on contentio>
Dec 18 21:27:34 Manjaro kernel: kfence: initialized - using 2097152 bytes for 255 objects at>
Dec 18 21:27:34 Manjaro kernel: spurious 8259A interrupt: IRQ7.
Dec 18 21:27:34 Manjaro kernel: Console: colour dummy device 80x25
Dec 18 21:27:34 Manjaro kernel: printk: legacy console [tty0] enabled
Dec 18 21:27:34 Manjaro kernel: ACPI: Core revision 20240827
Dec 18 21:27:34 Manjaro kernel: hpet: HPET dysfunctional in PC10. Force disabled.
Dec 18 21:27:34 Manjaro kernel: APIC: Switch to symmetric I/O mode setup
Dec 18 21:27:34 Manjaro kernel: DMAR: Host address width 39
Dec 18 21:27:34 Manjaro kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x1
Dec 18 21:27:34 Manjaro kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap d2008c406604>
Dec 18 21:27:34 Manjaro kernel: DMAR: RMRR base: 0x0000006d0dd000 end: 0x0000006d0fcfff
Dec 18 21:27:34 Manjaro kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed90000 IOMMU 0
Dec 18 21:27:34 Manjaro kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed90000
Dec 18 21:27:34 Manjaro kernel: DMAR-IR: Queued invalidation will be enabled to support x2ap>
Dec 18 21:27:34 Manjaro kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Dec 18 21:27:34 Manjaro kernel: x2apic enabled
Dec 18 21:27:34 Manjaro kernel: APIC: Switched APIC routing to: cluster x2apic
Dec 18 21:27:34 Manjaro kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles:>
Dec 18 21:27:34 Manjaro kernel: Calibrating delay loop (skipped), value calculated using tim>
Dec 18 21:27:34 Manjaro kernel: CPU0: Thermal monitoring enabled (TM1)
Dec 18 21:27:34 Manjaro kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
Dec 18 21:27:34 Manjaro kernel: Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
Dec 18 21:27:34 Manjaro kernel: process: using mwait in idle threads
Dec 18 21:27:34 Manjaro kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user>
Dec 18 21:27:34 Manjaro kernel: Spectre V2 : Mitigation: IBRS
Dec 18 21:27:34 Manjaro kernel: Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context>
Dec 18 21:27:34 Manjaro kernel: RETBleed: Mitigation: IBRS
Dec 18 21:27:34 Manjaro kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branc>
Dec 18 21:27:34 Manjaro kernel: Spectre V2 : User space: Mitigation: STIBP via prctl
Dec 18 21:27:34 Manjaro kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypa>
Dec 18 21:27:34 Manjaro kernel: MDS: Mitigation: Clear CPU buffers
Dec 18 21:27:34 Manjaro kernel: TAA: Mitigation: TSX disabled
Dec 18 21:27:34 Manjaro kernel: MMIO Stale Data: Mitigation: Clear CPU buffers
Dec 18 21:27:34 Manjaro kernel: SRBDS: Mitigation: Microcode
Dec 18 21:27:34 Manjaro kernel: GDS: Vulnerable: No microcode
Dec 18 21:27:34 Manjaro kernel: VMSCAPE: Mitigation: IBPB before exit to userspace
Dec 18 21:27:34 Manjaro kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point>
Dec 18 21:27:34 Manjaro kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Dec 18 21:27:34 Manjaro kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Dec 18 21:27:34 Manjaro kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registe>
Dec 18 21:27:34 Manjaro kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Dec 18 21:27:34 Manjaro kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Dec 18 21:27:34 Manjaro kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
Dec 18 21:27:34 Manjaro kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
Dec 18 21:27:34 Manjaro kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 b>
Dec 18 21:27:34 Manjaro kernel: Freeing SMP alternatives memory: 44K
Dec 18 21:27:34 Manjaro kernel: pid_max: default: 32768 minimum: 301
Dec 18 21:27:34 Manjaro kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
Dec 18 21:27:34 Manjaro kernel: landlock: Up and running.
Dec 18 21:27:34 Manjaro kernel: Yama: becoming mindful.
Dec 18 21:27:34 Manjaro kernel: LSM support for eBPF active
Dec 18 21:27:34 Manjaro kernel: Mount-cache hash table entries: 131072 (order: 8, 1048576 by>
Dec 18 21:27:34 Manjaro kernel: Mountpoint-cache hash table entries: 131072 (order: 8, 10485>
Dec 18 21:27:34 Manjaro kernel: smpboot: CPU0: Intel(R) Xeon(R) CPU E3-1585 v5 @ 3.50GHz (fa>
Dec 18 21:27:34 Manjaro kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR,>
Dec 18 21:27:34 Manjaro kernel: ... version:                4
Dec 18 21:27:34 Manjaro kernel: ... bit width:              48
Dec 18 21:27:34 Manjaro kernel: ... generic registers:      4
Dec 18 21:27:34 Manjaro kernel: ... value mask:             0000ffffffffffff
Dec 18 21:27:34 Manjaro kernel: ... max period:             00007fffffffffff
Dec 18 21:27:34 Manjaro kernel: ... fixed-purpose events:   3
Dec 18 21:27:34 Manjaro kernel: ... event mask:             000000070000000f
Dec 18 21:27:34 Manjaro kernel: signal: max sigframe size: 2032
Dec 18 21:27:34 Manjaro kernel: Estimated ratio of average max frequency by base frequency (>
Dec 18 21:27:34 Manjaro kernel: rcu: Hierarchical SRCU implementation.
Dec 18 21:27:34 Manjaro kernel: rcu:         Max phase no-delay instances is 1000.
Dec 18 21:27:34 Manjaro kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1>
Dec 18 21:27:34 Manjaro kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU count>
Dec 18 21:27:34 Manjaro kernel: smp: Bringing up secondary CPUs ...
Dec 18 21:27:34 Manjaro kernel: smpboot: x86: Booting SMP configuration:
Dec 18 21:27:34 Manjaro kernel: .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
Dec 18 21:27:34 Manjaro kernel: MDS CPU bug present and SMT on, data leak possible. See http>
Dec 18 21:27:34 Manjaro kernel: MMIO Stale Data CPU bug present and SMT on, data leak possib>
Dec 18 21:27:34 Manjaro kernel: VMSCAPE: SMT on, STIBP is required for full protection. See >
Dec 18 21:27:34 Manjaro kernel: smp: Brought up 1 node, 8 CPUs
Dec 18 21:27:34 Manjaro kernel: smpboot: Total of 8 processors activated (56020.86 BogoMIPS)
Dec 18 21:27:34 Manjaro kernel: Memory: 65571424K/66923808K available (18432K kernel code, 2>
Dec 18 21:27:34 Manjaro kernel: devtmpfs: initialized
Dec 18 21:27:34 Manjaro kernel: x86/mm: Memory block size: 2048MB
Dec 18 21:27:34 Manjaro kernel: ACPI: PM: Registering ACPI NVS region [mem 0x66b89000-0x66b8>
Dec 18 21:27:34 Manjaro kernel: ACPI: PM: Registering ACPI NVS region [mem 0x6d3b6000-0x6dd0>
Dec 18 21:27:34 Manjaro kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xfffffff>
Dec 18 21:27:34 Manjaro kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, line>
Dec 18 21:27:34 Manjaro kernel: pinctrl core: initialized pinctrl subsystem
Dec 18 21:27:34 Manjaro kernel: PM: RTC time: 05:27:26, date: 2025-12-19
Dec 18 21:27:34 Manjaro kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Dec 18 21:27:34 Manjaro kernel: DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic alloca>
Dec 18 21:27:34 Manjaro kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomi>
Dec 18 21:27:34 Manjaro kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for ato>
Dec 18 21:27:34 Manjaro kernel: audit: initializing netlink subsys (disabled)
Dec 18 21:27:34 Manjaro kernel: audit: type=2000 audit(1766122046.009:1): state=initialized >
Dec 18 21:27:34 Manjaro kernel: thermal_sys: Registered thermal governor 'fair_share'
Dec 18 21:27:34 Manjaro kernel: thermal_sys: Registered thermal governor 'bang_bang'
Dec 18 21:27:34 Manjaro kernel: thermal_sys: Registered thermal governor 'step_wise'
Dec 18 21:27:34 Manjaro kernel: thermal_sys: Registered thermal governor 'user_space'
Dec 18 21:27:34 Manjaro kernel: thermal_sys: Registered thermal governor 'power_allocator'
Dec 18 21:27:34 Manjaro kernel: cpuidle: using governor ladder
Dec 18 21:27:34 Manjaro kernel: cpuidle: using governor menu
Dec 18 21:27:34 Manjaro kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 18 21:27:34 Manjaro kernel: PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for >
Dec 18 21:27:34 Manjaro kernel: PCI: Using configuration type 1 for base access
Dec 18 21:27:34 Manjaro kernel: kprobes: kprobe jump-optimization is enabled. All kprobes ar>
Dec 18 21:27:34 Manjaro kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Dec 18 21:27:34 Manjaro kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Dec 18 21:27:34 Manjaro kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Dec 18 21:27:34 Manjaro kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Dec 18 21:27:34 Manjaro kernel: ACPI: Added _OSI(Module Device)
Dec 18 21:27:34 Manjaro kernel: ACPI: Added _OSI(Processor Device)
Dec 18 21:27:34 Manjaro kernel: ACPI: Added _OSI(Processor Aggregator Device)
Dec 18 21:27:34 Manjaro kernel: ACPI: 7 ACPI AML tables successfully acquired and loaded
Dec 18 21:27:34 Manjaro kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Dec 18 21:27:34 Manjaro kernel: ACPI: Dynamic OEM Table Load:
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0xFFFF8D0A80F37400 00037F (v02 PmRef  Cpu0Cst  00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0xFFFF8D0A80F40800 0006ED (v02 PmRef  Cpu0Ist  00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0xFFFF8D0A80F41800 0005AA (v02 PmRef  ApIst    00>
Dec 18 21:27:34 Manjaro kernel: ACPI: SSDT 0xFFFF8D0A81A44200 000119 (v02 PmRef  ApCst    00>
Dec 18 21:27:34 Manjaro kernel: ACPI: Interpreter enabled
Dec 18 21:27:34 Manjaro kernel: ACPI: PM: (supports S0 S4 S5)
Dec 18 21:27:34 Manjaro kernel: ACPI: Using IOAPIC for interrupt routing
Dec 18 21:27:34 Manjaro kernel: HEST: Enabling Firmware First mode for corrected errors.
Dec 18 21:27:34 Manjaro kernel: mce: [Firmware Bug]: Ignoring request to disable invalid MCA>
Dec 18 21:27:34 Manjaro kernel: HEST: Table parsing has been initialized.
Dec 18 21:27:34 Manjaro kernel: GHES: APEI firmware first mode is enabled by APEI bit and WH>
Dec 18 21:27:34 Manjaro kernel: PCI: Using host bridge windows from ACPI; if necessary, use >
Dec 18 21:27:34 Manjaro kernel: PCI: Using E820 reservations for host bridge windows
Dec 18 21:27:34 Manjaro kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.PEG0.PG00: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.PEG1.PG01: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.PEG2.PG02: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP09.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP10.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP11.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP12.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP13.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP01.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP02.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP03.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP04.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP05.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP06.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP07.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP08.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP17.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP18.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP19.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP20.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP14.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP15.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_SB_.PCI0.RP16.PXSX.WRST: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_TZ_.FN00: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_TZ_.FN01: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_TZ_.FN02: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_TZ_.FN03: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: \_TZ_.FN04: New power resource
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
Dec 18 21:27:34 Manjaro kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM Cloc>
Dec 18 21:27:34 Manjaro kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplu>
Dec 18 21:27:34 Manjaro kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME PCIe>
Dec 18 21:27:34 Manjaro kernel: PCI host bridge to bus 0000:00
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000ffff>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: root bus resource [mem 0x78400000-0xdffffff>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7ffff>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: root bus resource [bus 00-fe]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:00.0: [8086:1918] type 00 class 0x060000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.0: [8086:1901] type 01 class 0x060400 PCIe Ro>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.0:   bridge window [mem 0xdf400000-0xdf4fffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.1: [8086:1905] type 01 class 0x060400 PCIe Ro>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.1: PCI bridge to [bus 02]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.1:   bridge window [io  0xe000-0xefff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.1:   bridge window [mem 0xde000000-0xdf0fffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.1:   bridge window [mem 0xc0000000-0xd1ffffff>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:13.0: [8086:a135] type 00 class 0x000000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:13.0: BAR 0 [mem 0xdd118000-0xdd118fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:14.0: BAR 0 [mem 0xdd100000-0xdd10ffff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:14.2: [8086:a131] type 00 class 0x118000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:14.2: BAR 0 [mem 0xdd117000-0xdd117fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:16.0: BAR 0 [mem 0xdd116000-0xdd116fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:16.0: PME# supported from D3hot
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:16.1: [8086:a13b] type 00 class 0x078000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:16.1: BAR 0 [mem 0xdd115000-0xdd115fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:16.1: PME# supported from D3hot
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.0: [8086:a110] type 01 class 0x060400 PCIe Ro>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.0: PCI bridge to [bus 03-04]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.0:   bridge window [io  0xd000-0xdfff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.4: [8086:a114] type 01 class 0x060400 PCIe Ro>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.4: PCI bridge to [bus 05]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.4:   bridge window [mem 0xdf300000-0xdf3fffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.4:   bridge window [mem 0xd2200000-0xd26fffff>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.0: [8086:a118] type 01 class 0x060400 PCIe Ro>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.0: PCI bridge to [bus 06]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.0:   bridge window [mem 0xdf200000-0xdf2fffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.4: [8086:a11c] type 01 class 0x060400 PCIe Ro>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.4: PCI bridge to [bus 07-08]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.4:   bridge window [io  0xc000-0xcfff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.4:   bridge window [mem 0xdc000000-0xdd0fffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1d.4: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.0: [8086:a149] type 00 class 0x060100 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.2: BAR 0 [mem 0xdd110000-0xdd113fff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.4: BAR 0 [mem 0xdd114000-0xdd1140ff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.4: BAR 4 [io  0xf000-0xf01f]
Dec 18 21:27:34 Manjaro kernel: pci 0000:01:00.0: [144d:a808] type 00 class 0x010802 PCIe En>
Dec 18 21:27:34 Manjaro kernel: pci 0000:01:00.0: BAR 0 [mem 0xdf400000-0xdf403fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: [10de:1c31] type 00 class 0x030000 PCIe Le>
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: BAR 0 [mem 0xde000000-0xdeffffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pre>
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pre>
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: BAR 5 [io  0xe000-0xe07f]
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: ROM [mem 0xdf000000-0xdf07ffff pref]
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: 16.000 Gb/s available PCIe bandwidth, limi>
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.1: [10de:10f1] type 00 class 0x040300 PCIe En>
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.1: BAR 0 [mem 0xdf080000-0xdf083fff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:03:00.0: [1b21:1080] type 01 class 0x060400 PCIe to>
Dec 18 21:27:34 Manjaro kernel: pci 0000:03:00.0: PCI bridge to [bus 04]
Dec 18 21:27:34 Manjaro kernel: pci 0000:03:00.0:   bridge window [io  0xd000-0xdfff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:03:00.0: supports D1 D2
Dec 18 21:27:34 Manjaro kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:04: extended config space not accessible
Dec 18 21:27:34 Manjaro kernel: pci 0000:04:04.0: [13f6:8788] type 00 class 0x040100 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:04:04.0: BAR 0 [io  0xd000-0xd0ff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:04:04.0: supports D1 D2
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: [8086:1563] type 00 class 0x020000 PCIe En>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: BAR 0 [mem 0xd2400000-0xd25fffff 64bit pre>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: BAR 4 [mem 0xd2604000-0xd2607fff 64bit pre>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: ROM [mem 0xdf380000-0xdf3fffff pref]
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 0 [mem 0x00000000-0x00003fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 0 [mem 0x00000000-0x000fffff 64bit]>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 3 [mem 0x00000000-0x00003fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 3 [mem 0x00000000-0x000fffff 64bit]>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: 16.000 Gb/s available PCIe bandwidth, limi>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: [8086:1563] type 00 class 0x020000 PCIe En>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: BAR 0 [mem 0xd2200000-0xd23fffff 64bit pre>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: BAR 4 [mem 0xd2600000-0xd2603fff 64bit pre>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: ROM [mem 0xdf300000-0xdf37ffff pref]
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: PME# supported from D0 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 0 [mem 0x00000000-0x00003fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 0 [mem 0x00000000-0x000fffff 64bit]>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 3 [mem 0x00000000-0x00003fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 3 [mem 0x00000000-0x000fffff 64bit]>
Dec 18 21:27:34 Manjaro kernel: pci 0000:06:00.0: [144d:a810] type 00 class 0x010802 PCIe En>
Dec 18 21:27:34 Manjaro kernel: pci 0000:06:00.0: BAR 0 [mem 0xdf200000-0xdf203fff 64bit]
Dec 18 21:27:34 Manjaro kernel: pci 0000:06:00.0: enabling Extended Tags
Dec 18 21:27:34 Manjaro kernel: pci 0000:06:00.0: 31.504 Gb/s available PCIe bandwidth, limi>
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0: [1a03:1150] type 01 class 0x060400 PCIe to>
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0: PCI bridge to [bus 08]
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0:   bridge window [io  0xc000-0xcfff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0:   bridge window [mem 0xdc000000-0xdd0fffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0: enabling Extended Tags
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0: supports D1 D2
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: pci 0000:07:00.0: disabling ASPM on pre-1.1 PCIe device.  Yo>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:08: extended config space not accessible
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: [1a03:2000] type 00 class 0x030000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: BAR 0 [mem 0xdc000000-0xdcffffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: BAR 1 [mem 0xdd000000-0xdd01ffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: BAR 2 [io  0xc000-0xc07f]
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: Video device with shadowed ROM at [mem 0x0>
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: supports D1 D2
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 11
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 10
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 11
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 11
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 11
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 11
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 11
Dec 18 21:27:34 Manjaro kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 11
Dec 18 21:27:34 Manjaro kernel: iommu: Default domain type: Translated
Dec 18 21:27:34 Manjaro kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Dec 18 21:27:34 Manjaro kernel: SCSI subsystem initialized
Dec 18 21:27:34 Manjaro kernel: libata version 3.00 loaded.
Dec 18 21:27:34 Manjaro kernel: ACPI: bus type USB registered
Dec 18 21:27:34 Manjaro kernel: usbcore: registered new interface driver usbfs
Dec 18 21:27:34 Manjaro kernel: usbcore: registered new interface driver hub
Dec 18 21:27:34 Manjaro kernel: usbcore: registered new device driver usb
Dec 18 21:27:34 Manjaro kernel: EDAC MC: Ver: 3.0.0
Dec 18 21:27:34 Manjaro kernel: efivars: Registered efivars operations
Dec 18 21:27:34 Manjaro kernel: NetLabel: Initializing
Dec 18 21:27:34 Manjaro kernel: NetLabel:  domain hash size = 128
Dec 18 21:27:34 Manjaro kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec 18 21:27:34 Manjaro kernel: NetLabel:  unlabeled traffic allowed by default
Dec 18 21:27:34 Manjaro kernel: mctp: management component transport protocol core
Dec 18 21:27:34 Manjaro kernel: NET: Registered PF_MCTP protocol family
Dec 18 21:27:34 Manjaro kernel: PCI: Using ACPI for IRQ routing
Dec 18 21:27:34 Manjaro kernel: PCI: pci_cache_line_size set to 64 bytes
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x0003f000-0x0003ffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x60a58018-0x63ffffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x60a61018-0x63ffffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x60a96018-0x63ffffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x60acb018-0x63ffffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x66b89000-0x67ffffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x6cff6000-0x6fffffff]
Dec 18 21:27:34 Manjaro kernel: e820: reserve RAM buffer [mem 0x1087c00000-0x1087ffffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: vgaarb: setting as boot VGA device
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: vgaarb: bridge control possible
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.0: vgaarb: VGA device added: decodes=io+mem,o>
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: vgaarb: bridge control possible
Dec 18 21:27:34 Manjaro kernel: pci 0000:08:00.0: vgaarb: VGA device added: decodes=io+mem,o>
Dec 18 21:27:34 Manjaro kernel: vgaarb: loaded
Dec 18 21:27:34 Manjaro kernel: clocksource: Switched to clocksource tsc-early
Dec 18 21:27:34 Manjaro kernel: VFS: Disk quotas dquot_6.6.0
Dec 18 21:27:34 Manjaro kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 byte>
Dec 18 21:27:34 Manjaro kernel: pnp: PnP ACPI init
Dec 18 21:27:34 Manjaro kernel: system 00:00: [io  0x0a00-0x0a0f] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:00: [io  0x0a10-0x0a1f] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:00: [io  0x0a20-0x0a2f] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:00: [io  0x0a30-0x0a3f] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:00: [io  0x0a40-0x0a4f] has been reserved
Dec 18 21:27:34 Manjaro kernel: pnp 00:01: [dma 0 disabled]
Dec 18 21:27:34 Manjaro kernel: pnp 00:02: [dma 0 disabled]
Dec 18 21:27:34 Manjaro kernel: system 00:03: [io  0x0680-0x069f] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:03: [io  0xffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:03: [io  0x1800-0x18fe] could not be reserved
Dec 18 21:27:34 Manjaro kernel: system 00:03: [io  0x164e-0x164f] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:04: [io  0x0800-0x087f] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xfed90000-0xfed93fff] could not be reser>
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xff000000-0xffffffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xfee00000-0xfeefffff] could not be reser>
Dec 18 21:27:34 Manjaro kernel: system 00:06: [mem 0xdffe0000-0xdfffffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:07: [mem 0xfd000000-0xfdabffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:07: [mem 0xfdad0000-0xfdadffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:07: [mem 0xfdb00000-0xfdffffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:07: [mem 0xfe000000-0xfe01ffff] could not be reser>
Dec 18 21:27:34 Manjaro kernel: system 00:07: [mem 0xfe036000-0xfe03bfff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:07: [mem 0xfe03d000-0xfe3fffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:07: [mem 0xfe410000-0xfe7fffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:08: [io  0xff00-0xfffe] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:09: [mem 0xfdaf0000-0xfdafffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:09: [mem 0xfdae0000-0xfdaeffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: system 00:09: [mem 0xfdac0000-0xfdacffff] has been reserved
Dec 18 21:27:34 Manjaro kernel: pnp: PnP ACPI: found 10 devices
Dec 18 21:27:34 Manjaro kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, m>
Dec 18 21:27:34 Manjaro kernel: NET: Registered PF_INET protocol family
Dec 18 21:27:34 Manjaro kernel: IP idents hash table entries: 262144 (order: 9, 2097152 byte>
Dec 18 21:27:34 Manjaro kernel: tcp_listen_portaddr_hash hash table entries: 32768 (order: 7>
Dec 18 21:27:34 Manjaro kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 by>
Dec 18 21:27:34 Manjaro kernel: TCP established hash table entries: 524288 (order: 10, 41943>
Dec 18 21:27:34 Manjaro kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes,>
Dec 18 21:27:34 Manjaro kernel: TCP: Hash tables configured (established 524288 bind 65536)
Dec 18 21:27:34 Manjaro kernel: MPTCP token hash table entries: 65536 (order: 9, 1572864 byt>
Dec 18 21:27:34 Manjaro kernel: UDP hash table entries: 32768 (order: 8, 1048576 bytes, line>
Dec 18 21:27:34 Manjaro kernel: UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes,>
Dec 18 21:27:34 Manjaro kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Dec 18 21:27:34 Manjaro kernel: NET: Registered PF_XDP protocol family
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 0 [mem size 0x00100000 64bit]: can'>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 0 [mem size 0x00100000 64bit]: fail>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 3 [mem size 0x00100000 64bit]: can'>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.0: VF BAR 3 [mem size 0x00100000 64bit]: fail>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 0 [mem size 0x00100000 64bit]: can'>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 0 [mem size 0x00100000 64bit]: fail>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 3 [mem size 0x00100000 64bit]: can'>
Dec 18 21:27:34 Manjaro kernel: pci 0000:05:00.1: VF BAR 3 [mem size 0x00100000 64bit]: fail>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: Some PCI device resources are unassigned, t>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff windo>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: resource 7 [mem 0x78400000-0xdfffffff windo>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff windo>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:01: resource 1 [mem 0xdf400000-0xdf4fffff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:02: resource 1 [mem 0xde000000-0xdf0fffff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:02: resource 2 [mem 0xc0000000-0xd1ffffff 64bit>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:04: resource 0 [io  0xd000-0xdfff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:05: resource 1 [mem 0xdf300000-0xdf3fffff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:05: resource 2 [mem 0xd2200000-0xd26fffff 64bit>
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:06: resource 1 [mem 0xdf200000-0xdf2fffff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:07: resource 0 [io  0xc000-0xcfff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:07: resource 1 [mem 0xdc000000-0xdd0fffff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:08: resource 0 [io  0xc000-0xcfff]
Dec 18 21:27:34 Manjaro kernel: pci_bus 0000:08: resource 1 [mem 0xdc000000-0xdd0fffff]
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.1: extending delay after power-on from D3hot >
Dec 18 21:27:34 Manjaro kernel: pci 0000:02:00.1: D0 power state depends on 0000:02:00.0
Dec 18 21:27:34 Manjaro kernel: pci 0000:03:00.0: Disabling ASPM L0s/L1
Dec 18 21:27:34 Manjaro kernel: PCI: CLS 0 bytes, default 64
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.1: [8086:a120] type 00 class 0x058000 convent>
Dec 18 21:27:34 Manjaro kernel: pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
Dec 18 21:27:34 Manjaro kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Dec 18 21:27:34 Manjaro kernel: software IO TLB: mapped [mem 0x000000005ca58000-0x0000000060>
Dec 18 21:27:34 Manjaro kernel: Trying to unpack rootfs image as initramfs...
Dec 18 21:27:34 Manjaro kernel: sgx: EPC section 0x70200000-0x75f7ffff
Dec 18 21:27:34 Manjaro kernel: sgx: SGX disabled: SGX launch control CPU feature is not ava>
Dec 18 21:27:34 Manjaro kernel: Initialise system trusted keyrings
Dec 18 21:27:34 Manjaro kernel: Key type blacklist registered
Dec 18 21:27:34 Manjaro kernel: workingset: timestamp_bits=36 max_order=24 bucket_order=0
Dec 18 21:27:34 Manjaro kernel: fuse: init (API version 7.41)
Dec 18 21:27:34 Manjaro kernel: integrity: Platform Keyring initialized
Dec 18 21:27:34 Manjaro kernel: integrity: Machine keyring initialized
Dec 18 21:27:34 Manjaro kernel: Key type asymmetric registered
Dec 18 21:27:34 Manjaro kernel: Asymmetric key parser 'x509' registered
Dec 18 21:27:34 Manjaro kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (ma>
Dec 18 21:27:34 Manjaro kernel: io scheduler mq-deadline registered
Dec 18 21:27:34 Manjaro kernel: io scheduler kyber registered
Dec 18 21:27:34 Manjaro kernel: io scheduler bfq registered
Dec 18 21:27:34 Manjaro kernel: ledtrig-cpu: registered to indicate activity on CPUs
Dec 18 21:27:34 Manjaro kernel: pcieport 0000:00:01.0: PME: Signaling with IRQ 24
Dec 18 21:27:34 Manjaro kernel: pcieport 0000:00:01.1: PME: Signaling with IRQ 25
Dec 18 21:27:34 Manjaro kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 26
Dec 18 21:27:34 Manjaro kernel: pcieport 0000:00:1c.4: PME: Signaling with IRQ 27
Dec 18 21:27:34 Manjaro kernel: pcieport 0000:00:1d.0: PME: Signaling with IRQ 28
Dec 18 21:27:34 Manjaro kernel: pcieport 0000:00:1d.4: PME: Signaling with IRQ 29
Dec 18 21:27:34 Manjaro kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Dec 18 21:27:34 Manjaro kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0>
Dec 18 21:27:34 Manjaro kernel: ACPI: button: Sleep Button [SLPB]
Dec 18 21:27:34 Manjaro kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0>
Dec 18 21:27:34 Manjaro kernel: ACPI: button: Power Button [PWRB]
Dec 18 21:27:34 Manjaro kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/inpu>
Dec 18 21:27:34 Manjaro kernel: ACPI: button: Power Button [PWRF]
Dec 18 21:27:34 Manjaro kernel: thermal LNXTHERM:00: registered as thermal_zone0
Dec 18 21:27:34 Manjaro kernel: ACPI: thermal: Thermal Zone [TZ00] (28 C)
Dec 18 21:27:34 Manjaro kernel: thermal LNXTHERM:01: registered as thermal_zone1
Dec 18 21:27:34 Manjaro kernel: ACPI: thermal: Thermal Zone [TZ01] (30 C)
Dec 18 21:27:34 Manjaro kernel: ERST: Error Record Serialization Table (ERST) support is ini>
Dec 18 21:27:34 Manjaro kernel: pstore: Using crash dump compression: deflate
Dec 18 21:27:34 Manjaro kernel: pstore: Registered erst as persistent store backend
Dec 18 21:27:34 Manjaro kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Dec 18 21:27:34 Manjaro kernel: 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a>
Dec 18 21:27:34 Manjaro kernel: 00:02: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a>
Dec 18 21:27:34 Manjaro kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 18 21:27:34 Manjaro kernel: Non-volatile memory driver v1.3
Dec 18 21:27:34 Manjaro kernel: Linux agpgart interface v0.103
Dec 18 21:27:34 Manjaro kernel: tpm_tis MSFT0101:00: 2.0 TPM (device-id 0x1A, rev-id 16)
Dec 18 21:27:34 Manjaro kernel: Freeing initrd memory: 67524K
Dec 18 21:27:34 Manjaro kernel: ACPI: bus type drm_connector registered
Dec 18 21:27:34 Manjaro kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Dec 18 21:27:34 Manjaro kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus >
Dec 18 21:27:34 Manjaro kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x1>
Dec 18 21:27:34 Manjaro kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
Dec 18 21:27:34 Manjaro kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=000>
Dec 18 21:27:34 Manjaro kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNu>
Dec 18 21:27:34 Manjaro kernel: usb usb1: Product: xHCI Host Controller
Dec 18 21:27:34 Manjaro kernel: usb usb1: Manufacturer: Linux 6.12.62-1-MANJARO xhci-hcd
Dec 18 21:27:34 Manjaro kernel: usb usb1: SerialNumber: 0000:00:14.0
Dec 18 21:27:34 Manjaro kernel: hub 1-0:1.0: USB hub found
Dec 18 21:27:34 Manjaro kernel: hub 1-0:1.0: 16 ports detected
Dec 18 21:27:34 Manjaro kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=000>
Dec 18 21:27:34 Manjaro kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNu>
Dec 18 21:27:34 Manjaro kernel: usb usb2: Product: xHCI Host Controller
Dec 18 21:27:34 Manjaro kernel: usb usb2: Manufacturer: Linux 6.12.62-1-MANJARO xhci-hcd
Dec 18 21:27:34 Manjaro kernel: usb usb2: SerialNumber: 0000:00:14.0
Dec 18 21:27:34 Manjaro kernel: hub 2-0:1.0: USB hub found
Dec 18 21:27:34 Manjaro kernel: hub 2-0:1.0: 10 ports detected
Dec 18 21:27:34 Manjaro kernel: usbcore: registered new interface driver usbserial_generic
Dec 18 21:27:34 Manjaro kernel: usbserial: USB Serial support registered for generic
Dec 18 21:27:34 Manjaro kernel: rtc_cmos 00:05: RTC can wake from S4
Dec 18 21:27:34 Manjaro kernel: rtc_cmos 00:05: registered as rtc0
Dec 18 21:27:34 Manjaro kernel: rtc_cmos 00:05: setting system clock to 2025-12-19T05:27:27 >
Dec 18 21:27:34 Manjaro kernel: rtc_cmos 00:05: alarms up to one month, y3k, 242 bytes nvram
Dec 18 21:27:34 Manjaro kernel: intel_pstate: Intel P-state driver initializing
Dec 18 21:27:34 Manjaro kernel: intel_pstate: HWP enabled
Dec 18 21:27:34 Manjaro kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 >
Dec 18 21:27:34 Manjaro kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 o>
Dec 18 21:27:34 Manjaro kernel: fbcon: Deferring console take-over
Dec 18 21:27:34 Manjaro kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledr>
Dec 18 21:27:34 Manjaro kernel: hid: raw HID events driver (C) Jiri Kosina
Dec 18 21:27:34 Manjaro kernel: drop_monitor: Initializing network drop monitor service
Dec 18 21:27:34 Manjaro kernel: NET: Registered PF_INET6 protocol family
Dec 18 21:27:34 Manjaro kernel: Segment Routing with IPv6
Dec 18 21:27:34 Manjaro kernel: RPL Segment Routing with IPv6
Dec 18 21:27:34 Manjaro kernel: In-situ OAM (IOAM) with IPv6
Dec 18 21:27:34 Manjaro kernel: NET: Registered PF_PACKET protocol family
Dec 18 21:27:34 Manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 18 21:27:34 Manjaro kernel: microcode: Current revision: 0x000000f0
Dec 18 21:27:34 Manjaro kernel: microcode: Updated early from: 0x000000c6
Dec 18 21:27:34 Manjaro kernel: IPI shorthand broadcast: enabled
Dec 18 21:27:34 Manjaro kernel: sched_clock: Marking stable (820178259, 1780183)->(911171911>
Dec 18 21:27:34 Manjaro kernel: registered taskstats version 1
Dec 18 21:27:34 Manjaro kernel: Loading compiled-in X.509 certificates
Dec 18 21:27:34 Manjaro kernel: Loaded X.509 cert 'Build time autogenerated kernel key: a612>
Dec 18 21:27:34 Manjaro kernel: Demotion targets for Node 0: null
Dec 18 21:27:34 Manjaro kernel: Key type .fscrypt registered
Dec 18 21:27:34 Manjaro kernel: Key type fscrypt-provisioning registered
Dec 18 21:27:34 Manjaro kernel: integrity: Loading X.509 certificate: UEFI:db
Dec 18 21:27:34 Manjaro kernel: integrity: Loaded X.509 cert 'Intel Corporation: Intel(R) DC>
Dec 18 21:27:34 Manjaro kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA >
Dec 18 21:27:34 Manjaro kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production P>
Dec 18 21:27:34 Manjaro kernel: integrity: Loaded X.509 cert 'Microsoft UEFI CA 2023: 81aa6b>
Dec 18 21:27:34 Manjaro kernel: integrity: Loaded X.509 cert 'Microsoft Option ROM UEFI CA 2>
Dec 18 21:27:34 Manjaro kernel: PM:   Magic number: 5:918:466
Dec 18 21:27:34 Manjaro kernel: RAS: Correctable Errors collector initialized.
Dec 18 21:27:34 Manjaro kernel: clk: Disabling unused clocks
Dec 18 21:27:34 Manjaro kernel: PM: genpd: Disabling unused power domains
Dec 18 21:27:34 Manjaro kernel: Freeing unused decrypted memory: 2028K
Dec 18 21:27:34 Manjaro kernel: Freeing unused kernel image (initmem) memory: 4296K
Dec 18 21:27:34 Manjaro kernel: Write protecting the kernel read-only data: 34816k
Dec 18 21:27:34 Manjaro kernel: Freeing unused kernel image (rodata/data gap) memory: 2036K
Dec 18 21:27:34 Manjaro kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 18 21:27:34 Manjaro kernel: rodata_test: all tests were successful
Dec 18 21:27:34 Manjaro kernel: x86/mm: Checking user space page tables
Dec 18 21:27:34 Manjaro kernel: Run /init as init process
Dec 18 21:27:34 Manjaro kernel:   with arguments:
Dec 18 21:27:34 Manjaro kernel:     /init
Dec 18 21:27:34 Manjaro kernel:     splash
Dec 18 21:27:34 Manjaro kernel:   with environment:
Dec 18 21:27:34 Manjaro kernel:     HOME=/
Dec 18 21:27:34 Manjaro kernel:     TERM=linux
Dec 18 21:27:34 Manjaro kernel: usb 1-1: new full-speed USB device number 2 using xhci_hcd
Dec 18 21:27:34 Manjaro kernel: usb 1-1: New USB device found, idVendor=2516, idProduct=01d5>
Dec 18 21:27:34 Manjaro kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNum>
Dec 18 21:27:34 Manjaro kernel: usb 1-1: Product: MK770 Hybrid Mechanical Keyboard
Dec 18 21:27:34 Manjaro kernel: usb 1-1: Manufacturer: COOLE MASTER
Dec 18 21:27:34 Manjaro kernel: usb 1-1: SerialNumber: MK770
Dec 18 21:27:34 Manjaro kernel: usbcore: registered new interface driver usbhid
Dec 18 21:27:34 Manjaro kernel: usbhid: USB HID core driver
Dec 18 21:27:34 Manjaro kernel: nvme nvme1: pci function 0000:06:00.0
Dec 18 21:27:34 Manjaro kernel: nvme nvme0: pci function 0000:01:00.0
Dec 18 21:27:34 Manjaro kernel: nvme nvme1: D3 entry latency set to 10 seconds
Dec 18 21:27:34 Manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Dec 18 21:27:34 Manjaro kernel: nvme nvme0: D3 entry latency set to 8 seconds
Dec 18 21:27:34 Manjaro kernel: nvme nvme1: 8/0/0 default/read/poll queues
Dec 18 21:27:34 Manjaro kernel:  nvme1n1: p2 p3 p4 p5
Dec 18 21:27:34 Manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Dec 18 21:27:34 Manjaro kernel:  nvme0n1: p1 p2 p3 p4 p5
Dec 18 21:27:34 Manjaro kernel: ast 0000:08:00.0: Using P2A bridge for configuration
Dec 18 21:27:34 Manjaro kernel: ast 0000:08:00.0: AST 2400 detected
Dec 18 21:27:34 Manjaro kernel: ast 0000:08:00.0: [drm] Using analog VGA
Dec 18 21:27:34 Manjaro kernel: ast 0000:08:00.0: [drm] dram MCLK=408 Mhz type=1 bus_width=16
Dec 18 21:27:34 Manjaro kernel: ast 0000:08:00.0: [drm] Registered 1 planes with drm panic
Dec 18 21:27:34 Manjaro kernel: [drm] Initialized ast 0.1.0 for 0000:08:00.0 on minor 1
Dec 18 21:27:34 Manjaro kernel: ast 0000:08:00.0: [drm] fb1: astdrmfb frame buffer device
Dec 18 21:27:34 Manjaro kernel: usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
Dec 18 21:27:34 Manjaro kernel: usb 2-1: New USB device found, idVendor=0789, idProduct=0578>
Dec 18 21:27:34 Manjaro kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNum>
Dec 18 21:27:34 Manjaro kernel: usb 2-1: Product: JMS583
Dec 18 21:27:34 Manjaro kernel: usb 2-1: Manufacturer: JMicron
Dec 18 21:27:34 Manjaro kernel: usb 2-1: SerialNumber: DD5641988391F
Dec 18 21:27:34 Manjaro kernel: usb 1-10: new full-speed USB device number 3 using xhci_hcd
Dec 18 21:27:34 Manjaro kernel: tsc: Refined TSC clocksource calibration: 3504.003 MHz
Dec 18 21:27:34 Manjaro kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x328>
Dec 18 21:27:34 Manjaro kernel: usb 1-10: New USB device found, idVendor=046d, idProduct=c54>
Dec 18 21:27:34 Manjaro kernel: usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNu>
Dec 18 21:27:34 Manjaro kernel: usb 1-10: Product: USB Receiver
Dec 18 21:27:34 Manjaro kernel: usb 1-10: Manufacturer: Logitech
Dec 18 21:27:34 Manjaro kernel: usb 2-2: new SuperSpeed USB device number 3 using xhci_hcd
Dec 18 21:27:34 Manjaro kernel: usb 2-2: New USB device found, idVendor=152e, idProduct=2571>
Dec 18 21:27:34 Manjaro kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNum>
Dec 18 21:27:34 Manjaro kernel: usb 2-2: Product: External Blu-ray Writer
Dec 18 21:27:34 Manjaro kernel: usb 2-2: Manufacturer: HLDS Inc
Dec 18 21:27:34 Manjaro kernel: usb 2-2: SerialNumber: HITACHLGDA00000002C
Dec 18 21:27:34 Manjaro kernel: usb 1-11: new high-speed USB device number 4 using xhci_hcd
Dec 18 21:27:34 Manjaro kernel: usb 1-11: New USB device found, idVendor=0bda, idProduct=541>
Dec 18 21:27:34 Manjaro kernel: usb 1-11: New USB device strings: Mfr=1, Product=2, SerialNu>
Dec 18 21:27:34 Manjaro kernel: usb 1-11: Product: 4-Port USB 2.0 Hub
Dec 18 21:27:34 Manjaro kernel: usb 1-11: Manufacturer: Generic
Dec 18 21:27:34 Manjaro kernel: hub 1-11:1.0: USB hub found
Dec 18 21:27:34 Manjaro kernel: hub 1-11:1.0: 4 ports detected
Dec 18 21:27:34 Manjaro kernel: usb 2-5: new SuperSpeed USB device number 4 using xhci_hcd
Dec 18 21:27:34 Manjaro kernel: usb 2-5: New USB device found, idVendor=0bda, idProduct=0411>
Dec 18 21:27:34 Manjaro kernel: usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNum>
Dec 18 21:27:34 Manjaro kernel: usb 2-5: Product: 4-Port USB 3.0 Hub
Dec 18 21:27:34 Manjaro kernel: usb 2-5: Manufacturer: Generic
Dec 18 21:27:34 Manjaro kernel: hub 2-5:1.0: USB hub found
Dec 18 21:27:34 Manjaro kernel: hub 2-5:1.0: 4 ports detected
Dec 18 21:27:34 Manjaro kernel: usb-storage 2-2:1.0: USB Mass Storage device detected
Dec 18 21:27:34 Manjaro kernel: scsi host0: usb-storage 2-2:1.0
Dec 18 21:27:34 Manjaro kernel: usbcore: registered new interface driver usb-storage
Dec 18 21:27:34 Manjaro kernel: scsi host1: uas
Dec 18 21:27:34 Manjaro kernel: usbcore: registered new interface driver uas
Dec 18 21:27:34 Manjaro kernel: scsi 1:0:0:0: Direct-Access     ADATA SX 8200PNP     R090 02>
Dec 18 21:27:34 Manjaro kernel: sd 1:0:0:0: [sda] 2000409264 512-byte logical blocks: (1.02 >
Dec 18 21:27:34 Manjaro kernel: sd 1:0:0:0: [sda] 4096-byte physical blocks
Dec 18 21:27:34 Manjaro kernel: sd 1:0:0:0: [sda] Write Protect is off
Dec 18 21:27:34 Manjaro kernel: sd 1:0:0:0: [sda] Mode Sense: 5f 00 00 08
Dec 18 21:27:34 Manjaro kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled,>
Dec 18 21:27:34 Manjaro kernel: sd 1:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
Dec 18 21:27:34 Manjaro kernel: sd 1:0:0:0: [sda] Optimal transfer size 33553920 bytes not a>
Dec 18 21:27:35 Manjaro kernel: usb 1-13: new high-speed USB device number 5 using xhci_hcd
Dec 18 21:27:35 Manjaro kernel:  sda: sda1
Dec 18 21:27:35 Manjaro kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Dec 18 21:27:35 Manjaro kernel: usb 1-13: New USB device found, idVendor=0557, idProduct=700>
Dec 18 21:27:35 Manjaro kernel: usb 1-13: New USB device strings: Mfr=0, Product=0, SerialNu>
Dec 18 21:27:35 Manjaro kernel: hub 1-13:1.0: USB hub found
Dec 18 21:27:35 Manjaro kernel: hub 1-13:1.0: 4 ports detected
Dec 18 21:27:35 Manjaro kernel: input: COOLE MASTER MK770 Hybrid Mechanical Keyboard as /dev>
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1: new high-speed USB device number 6 using xhci_hcd
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1: New USB device found, idVendor=05e3, idProduct=0>
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1: New USB device strings: Mfr=0, Product=1, Serial>
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1: Product: USB2.0 Hub
Dec 18 21:27:35 Manjaro kernel: hub 1-11.1:1.0: USB hub found
Dec 18 21:27:35 Manjaro kernel: hub 1-11.1:1.0: 2 ports detected
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:2516:01D5.0001: input,hidraw0: USB HID v1.1>
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:2516:01D5.0002: input,hidraw1: USB HID v1.1>
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:2516:01D5.0003: input,hiddev96,hidraw2: USB>
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:2516:01D5.0004: hiddev97,hidraw3: USB HID v>
Dec 18 21:27:35 Manjaro kernel: input: Logitech USB Receiver as /devices/pci0000:00/0000:00:>
Dec 18 21:27:35 Manjaro kernel: usb 2-5.2: new SuperSpeed USB device number 5 using xhci_hcd
Dec 18 21:27:35 Manjaro kernel: usb 2-5.2: New USB device found, idVendor=11b0, idProduct=63>
Dec 18 21:27:35 Manjaro kernel: usb 2-5.2: New USB device strings: Mfr=1, Product=2, SerialN>
Dec 18 21:27:35 Manjaro kernel: usb 2-5.2: Product: Multi-Reader
Dec 18 21:27:35 Manjaro kernel: usb 2-5.2: Manufacturer: Kingston
Dec 18 21:27:35 Manjaro kernel: usb 2-5.2: SerialNumber: 08738174205346
Dec 18 21:27:35 Manjaro kernel: usb-storage 2-5.2:1.0: USB Mass Storage device detected
Dec 18 21:27:35 Manjaro kernel: scsi host2: usb-storage 2-5.2:1.0
Dec 18 21:27:35 Manjaro kernel: usb 1-11.3: new high-speed USB device number 7 using xhci_hcd
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:046D:C548.0005: input,hidraw4: USB HID v1.1>
Dec 18 21:27:35 Manjaro kernel: input: Logitech USB Receiver Mouse as /devices/pci0000:00/00>
Dec 18 21:27:35 Manjaro kernel: input: Logitech USB Receiver Consumer Control as /devices/pc>
Dec 18 21:27:35 Manjaro kernel: input: Logitech USB Receiver System Control as /devices/pci0>
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:046D:C548.0006: input,hidraw5: USB HID v1.1>
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:046D:C548.0007: hiddev98,hidraw6: USB HID v>
Dec 18 21:27:35 Manjaro kernel: usb 1-13.1: new low-speed USB device number 8 using xhci_hcd
Dec 18 21:27:35 Manjaro kernel: usb 1-13.1: New USB device found, idVendor=0557, idProduct=2>
Dec 18 21:27:35 Manjaro kernel: usb 1-13.1: New USB device strings: Mfr=0, Product=0, Serial>
Dec 18 21:27:35 Manjaro kernel: input: HID 0557:2419 as /devices/pci0000:00/0000:00:14.0/usb>
Dec 18 21:27:35 Manjaro kernel: usb 2-5.4: new SuperSpeed USB device number 6 using xhci_hcd
Dec 18 21:27:35 Manjaro kernel: usb 2-5.4: New USB device found, idVendor=05e3, idProduct=07>
Dec 18 21:27:35 Manjaro kernel: usb 2-5.4: New USB device strings: Mfr=3, Product=4, SerialN>
Dec 18 21:27:35 Manjaro kernel: usb 2-5.4: Product: USB3.0 Card Reader
Dec 18 21:27:35 Manjaro kernel: usb 2-5.4: Manufacturer: Generic
Dec 18 21:27:35 Manjaro kernel: usb 2-5.4: SerialNumber: 000000001532
Dec 18 21:27:35 Manjaro kernel: usb-storage 2-5.4:1.0: USB Mass Storage device detected
Dec 18 21:27:35 Manjaro kernel: scsi host3: usb-storage 2-5.4:1.0
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1.2: new high-speed USB device number 9 using xhci_>
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:0557:2419.0008: input,hidraw7: USB HID v1.0>
Dec 18 21:27:35 Manjaro kernel: hid-generic 0003:0557:2419.0009: input,hidraw8: USB HID v1.0>
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1.2: New USB device found, idVendor=0403, idProduct>
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1.2: New USB device strings: Mfr=1, Product=2, Seri>
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1.2: Product: USB <-> Serial Cable
Dec 18 21:27:35 Manjaro kernel: usb 1-11.1.2: Manufacturer: FTDI
Dec 18 21:27:35 Manjaro kernel: scsi 2:0:0:0: Direct-Access              Multi-Reader  -0 1.>
Dec 18 21:27:35 Manjaro kernel: scsi 2:0:0:1: Direct-Access              Multi-Reader  -1 1.>
Dec 18 21:27:35 Manjaro kernel: scsi 2:0:0:2: Direct-Access              Multi-Reader  -2 1.>
Dec 18 21:27:35 Manjaro kernel: scsi 2:0:0:3: Direct-Access              Multi-Reader  -3 1.>
lines 99997-100035
It is looking like there is no fix. Any last thoughts?
Thank you.
