Hi there,
I am running ManjaroLinux 23.1.0 Vulcan with kernel 6.5.13-1-MANJARO.
Whenever I try to turn off wifi , the system behaves strangely:
Sudo commands stop working , Some applications do not open
**Unable to power-off / reboot the system **
Occasionally the hard reboot is stuck with a message:
Dec 13 09:32:22 rishabh-latitude7480 kernel: iwlwifi 0000:02:00.0: Queue 5 is active on fifo 3 and stuck for 10000 ms. SW [5, 6] HW [6, 6] FH TRB=0x080305005
This may be due to a recent regression in kernels 6.1 and 6.6 which affected WiFi. Search the forum for more information.
The point; this has since been corrected. Updating to the latest 6.6 or 6.1 iterations will likely also resolve your issue. Report back if it doesn’t.
Dec 14 14:23:33 rishabh-latitude7480 kernel: iwlwifi 0000:02:00.0: fail to flush all tx fifo queues Q 5
Dec 14 14:23:33 rishabh-latitude7480 kernel: iwlwifi 0000:02:00.0: Queue 5 is active on fifo 3 and stuck for 10000 ms. SW [2, 3] HW [3, 3] FH TRB=0x080305002
