Hi there. So I’ve been using XFCE for months with zero issues and this morning I decided to wipe all clear with the latest version. Sometimes the system hangs when booting, I don’t see any pattern:
Here’s some logs, unfortunately I don’t have more info right now.
➜ ~ sudo cat /var/log/boot.log
------------ Fri Dec 01 12:34:11 MST 2023 ------------
/dev/nvme0n1p2: clean, 364134/15613952 files, 4356871/62435619 blocks
[ OK ] Finished Tell Plymouth To Write Out Runtime Data.
[ OK ] Finished Load Kernel Module dm_mod.
[ OK ] Finished Load Kernel Module loop.
[ OK ] Finished Create Volatile Files and Directories.
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Reached target System Initialization.
[ OK ] Started CUPS Scheduler.
[ OK ] Started Refresh existing PGP keys of archlinux-keyring regularly.
[ OK ] Started Discard unused filesystem blocks once a week.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily man-db regeneration.
[ OK ] Started Refresh pacman files databases weekly.
[ OK ] Started Monthly clean packages cache.
[ OK ] Started Generate mirrorlist weekly.
[ OK ] Started Daily verification of password and group files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Daily locate database update.
[ OK ] Reached target Path Units.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on CUPS Scheduler.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Socket activation for snappy daemon...
[ OK ] Listening on Socket activation for snappy daemon.
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
Starting Save/Restore Sound Card State...
Starting Avahi mDNS/DNS-SD Stack...
Starting D-Bus System Message Bus...
Starting Authorization Manager...
Starting Snap Daemon...
Starting User Login Management...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Finished Save/Restore Sound Card State.
Starting Network Manager...
[ OK ] Reached target Sound Card.
[ OK ] Started User Login Management.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Hostname Service...
[ OK ] Started Authorization Manager.
Starting Modem Manager...
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service...
[ OK ] Started Modem Manager.
Starting Bluetooth service...
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Snap Daemon.
Starting Time & Date Service...
[ OK ] Started Bluetooth service.
[ OK ] Reached target Bluetooth Support.
[ OK ] Started Time & Date Service.
Starting WPA supplicant...
[ OK ] Started Network Manager.
[ OK ] Started WPA supplicant.
[ OK ] Reached target Network.
Starting CUPS Scheduler...
Starting Permit User Sessions...
[ OK ] Finished Permit User Sessions.
[ OK ] Started Command Scheduler.
Starting Hold until boot process finishes up...
Starting Terminate Plymouth Boot Screen...
------------ Fri Dec 01 12:36:30 MST 2023 ------------
/dev/nvme1n1p2: clean, 364136/15613952 files, 4357876/62435619 blocks
PS. This is a lenovo ThinkPad E15 and it’s just a few months old so I don’t think it’s a hardware problem. Thanks in advance!
