System sometimes freezes when I log in
My system sometimes freezes when I log in. It stays on the picture (with the text Manjaro on a blue background), that is right before the switch to normal desktop. I have to turn the PC off with the power button.
I will try your suggested work-around with kernel parameters amdgu.dc=0
Fortunately the freezing happens rarely. I have not seen freezing during use, so once the desktop appears the system runs smoothly.
Errors in journal:
$ journalctl --boot --priority=err --output=with-unit --no-pager
Wed 2025-06-04 09:21:32 CEST statPC kernel: amdgpu 0000:08:00.0: [drm] *ERROR* [CRTC:60:crtc-0] flip_done timed out
Wed 2025-06-04 09:21:44 CEST statPC kernel: amdgpu 0000:08:00.0: [drm] *ERROR* flip_done timed out
Wed 2025-06-04 09:21:44 CEST statPC kernel: amdgpu 0000:08:00.0: [drm] *ERROR* [CRTC:60:crtc-0] commit wait timed out
My system:
KDE Plasma Version: 6.3.5
KDE Frameworks Version: 6.14.0
Qt Version: 6.9.0
Kernel Version: 6.14.6-2-MANJARO (64-bit)
Graphics Platform: X11
Processors: 12 × AMD Ryzen 5 3600 6-Core Processor
Memory: 15,5 GiB of RAM
Graphics Processor: AMD Radeon RX 590 Series
inxi -zv8 run by root
  Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
    root=UUID=15de0dd7-8a22-45e5-9004-6a1a9ba201e8 rw rootflags=subvol=@
    nowatchdog mitigations=off security=none udev.log_priority=3 noresume
    nohibernate
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
    serial: <filter> part-nu: SKU uuid: 1d39562d-d533-dfbc-9ce9-40b076a412f6
    BIOS: American Megatrends v: 4631 date: 01/14/2025
  System RAM: total: 16 GiB available: 15.53 GiB used: 3.31 GiB (21.3%)
  Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3000 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-3000C16-16GISB serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: no module installed
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
    children: 1: 08:00.0 class-ID: 0300 type: display 2: 08:00.1 class-ID: 0403
    type: audio
  Slot: 1 type: PCIe status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 2 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 3 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 4 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
    gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 1723 min/max: 550/4208 boost: enabled
    base/boost: 3600/4200 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 1723 2: 1723 3: 1723 4: 1723
    5: 1723 6: 1723 7: 1723 8: 1723 9: 1723 10: 1723 11: 1723 12: 1723
    bogomips: 86401
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: retbleed status: Vulnerable
  Type: spec_rstack_overflow status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Gigabyte driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-3,HDMI-A-1 empty: DP-1,DP-2,DVI-D-1 bus-ID: 08:00.0
    chip-ID: 1002:67df class-ID: 0300 temp: 48.0 C
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1013x570mm (39.88x22.44")
    s-diag: 1162mm (45.76") monitors: <missing: xrandr>
  Monitor-1: DP-3 model: Denon DENON-AVR serial: <filter> built: 2014
    res: 1920x1080 dpi: 61 gamma: 1.2 chroma: red: x: 0.627 y: 0.341 green:
    x: 0.278 y: 0.596 blue: x: 0.153 y: 0.071 white: x: 0.282 y: 0.298
    size: 708x398mm (27.87x15.67") diag: 918mm (36.1") ratio: 16:9
    modes: 1920x1080, 2880x576, 2880x480, 1280x720, 1440x576, 1440x480,
    720x576, 720x480, 640x480
  Monitor-2: HDMI-A-1 model: Philips FTV serial: <filter> built: 2017
    res: 1920x1080 dpi: 34 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green:
    x: 0.325 y: 0.588 blue: x: 0.145 y: 0.051 white: x: 0.278 y: 0.290
    size: 1440x810mm (56.69x31.89") diag: 1652mm (65") ratio: 16:9
    modes: 1920x1080, 3840x2160, 1600x1200, 1680x1050, 1400x1050, 1280x1024,
    1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 590 Series (radeonsi
    polaris10 ACO DRM 3.61 6.14.6-2-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.4.313 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 590 Series (RADV POLARIS10) driver: mesa radv v: 25.0.5-arch1.1
    device-ID: 1002:67df surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.14.6-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Local Storage: total: 2.52 TiB used: 23.09 GiB (0.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-00L5B1
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: N/A serial: <filter> fw-rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EADS-00L5B1 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
    scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Micron model: MTFDDAK256MAY-1AH12ABHA
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: M5T4 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU800NS38
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 8B scheme: MBR
  ID-1: / raw-size: 476.94 GiB size: 476.94 GiB (100.00%) used: 21 GiB (4.4%)
    fs: btrfs block-size: 4096 B dev: /dev/sdd1 maj-min: 8:49 label: statroot
    uuid: 15de0dd7-8a22-45e5-9004-6a1a9ba201e8
  ID-2: /data/ssd200 raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
    used: 1.7 GiB (0.7%) fs: btrfs block-size: 4096 B dev: /dev/sdc1
    maj-min: 8:33 label: ssd200 uuid: 2d8a5520-e05a-4a38-badb-5f0cbf44cae3
  ID-3: /home raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
    used: 21 GiB (4.4%) fs: btrfs block-size: 4096 B dev: /dev/sdd1
    maj-min: 8:49 label: statroot uuid: 15de0dd7-8a22-45e5-9004-6a1a9ba201e8
  ID-4: /home/<filter>/cryptomount.fredox.vol raw-size: 600 MiB
    size: 573.7 MiB (95.62%) used: 406.7 MiB (70.9%) fs: ext4 block-size: 4096 B
    dev: /dev/dm-1 maj-min: 253:1 mapped: loop0 label: N/A uuid: N/A
  ID-5: /var/cache raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
  ID-6: /var/log raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-0 maj-min: 253:0 mapped: swap label: swap
    uuid: 011aa570-e7b9-4112-9f89-bd193037a6a1
  ID-1: /dev/sda1 maj-min: 8:1 size: 923.5 GiB fs: ext4 label: swdisk
    uuid: ed96f3d3-edea-43bc-8418-2223e4ec312d
  ID-2: /dev/sda2 maj-min: 8:2 size: 8.01 GiB fs: ext2 label: cryptswap
    uuid: ec4a49ac-3057-4c0b-a02d-12dc093f7355
  ID-3: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ext4 label: hd1Tb
    uuid: a0f67169-c4c3-48e9-bafe-a73dc0983560
  Device-1: 1-7:2 info: MosArt Wireless Keyboard/Mouse type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4101 class-ID: 0301
  Device-2: 1-9:3 info: NZXT Smart Device V2 type: HID
    driver: nzxt-smart2,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2006 class-ID: 0300
    serial: <filter>
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-1:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0617
  System Temperatures: cpu: 49.5 C mobo: N/A gpu: amdgpu temp: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 768
  Packages: pm: pacman pkgs: 1189 libs: 282 tools: pamac
    1: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 381
  1: cpu: 1.0% command: firefox pid: 2729 mem: 489.3 MiB (3.0%)
  2: cpu: 0.9% command: qbittorrent pid: 2674 mem: 879.2 MiB (5.5%)
  3: cpu: 0.8% command: firefox pid: 3120 mem: 433.1 MiB (2.7%)
  4: cpu: 0.5% command: firefox pid: 1884 mem: 532.1 MiB (3.3%)
  5: cpu: 0.5% command: konsole pid: 4902 mem: 242.4 MiB (1.5%)
  Memory top: 5 of 381
  1: mem: 879.2 MiB (5.5%) command: qbittorrent pid: 2674 cpu: 0.9%
  2: mem: 532.1 MiB (3.3%) command: firefox pid: 1884 cpu: 0.5%
  3: mem: 489.3 MiB (3.0%) command: firefox pid: 2729 cpu: 1.0%
  4: mem: 433.1 MiB (2.7%) command: firefox pid: 3120 cpu: 0.8%
  5: mem: 388.1 MiB (2.4%) command: plasmashell pid: 1017 cpu: 0.2%
  Processes: 381 Power: uptime: 49m states: freeze,mem suspend: deep
    avail: s2idle wakeups: 0 hibernate: disabled image: 6.16 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Bash (su) v: 5.2.37 running-in: konsole
    inxi: 3.3.38
Xorg.0.log after freeze and hard poweroff
[     8.108] (--) Log file renamed from "/var/log/Xorg.pid-707.log" to "/var/log/Xorg.0.log"
[     8.109]
X.Org X Server 1.21.1.16
[     8.109] Current Operating System: Linux statPC 6.14.6-2-MANJARO #1 SMP PREEMPT_DYNAMIC Wed, 14 May 2025 14:56:34 +0000 x86_64
[     8.109] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64 root=UUID=15de0dd7-8a22-45e5-9004-6a1a9ba201e8 rw rootflags=subvol=@ nowatchdog mitigations=off security=none udev.log_priority=3 noresume nohibernate
[     8.109]
[     8.109] Current version of pixman: 0.46.0
[     8.109] 	Before reporting problems, check http://wiki.x.org
[     8.109] Markers: (--) probed, (**) from config file, (==) default setting,
[     8.109] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun  4 09:21:15 2025
[     8.109] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     8.109] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.109] (==) No Layout section.  Using the first Screen section.
[     8.109] (==) No screen section available. Using defaults.
[     8.109] (**) |-->Screen "Default Screen Section" (0)
[     8.109] (**) |   |-->Monitor "<default monitor>"
[     8.109] (==) No monitor specified for screen "Default Screen Section".
[     8.109] (**) Allowing byte-swapped clients
[     8.109] (==) Automatically adding devices
[     8.109] (==) Automatically enabling devices
[     8.109] (==) Automatically adding GPU devices
[     8.109] (==) Automatically binding GPU devices
[     8.109] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.110] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     8.110] 	Entry deleted from font path.
[     8.110] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     8.110] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     8.110] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     8.110] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     8.110] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.110] (II) The server relies on udev to provide the list of input devices.
[     8.110] (II) Module ABI versions:
[     8.110] 	X.Org ANSI C Emulation: 0.4
[     8.110] 	X.Org Video Driver: 25.2
[     8.110] 	X.Org XInput driver : 24.4
[     8.110] 	X.Org Server Extension : 10.0
[     8.111] (++) using VT number 2
[     8.111] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     8.111] (II) xfree86: Adding drm device (/dev/dri/card1)
[     8.111] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:08:00.0/drm/card1
[     8.118] (--) PCI:*(8@0:0:0) 1002:67df:1458:2311 rev 225, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfcf00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     8.118] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.118] (II) LoadModule: "glx"
[     8.119] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.128] (II) Module glx: vendor="X.Org Foundation"
[     8.128] 	compiled for 1.21.1.16, module version = 1.0.0
[     8.128] 	ABI class: X.Org Server Extension, version 10.0
[     8.128] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[     8.128] 	loading driver: amdgpu
[     8.128] (==) Matched amdgpu as autoconfigured driver 0
[     8.128] (==) Matched ati as autoconfigured driver 1
[     8.128] (==) Matched modesetting as autoconfigured driver 2
[     8.128] (==) Matched fbdev as autoconfigured driver 3
[     8.128] (==) Matched vesa as autoconfigured driver 4
[     8.128] (==) Assigned the driver to the xf86ConfigLayout
[     8.128] (II) LoadModule: "amdgpu"
[     8.128] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     8.130] (II) Module amdgpu: vendor="X.Org Foundation"
[     8.130] 	compiled for 1.21.1.11, module version = 23.0.0
[     8.130] 	Module class: X.Org Video Driver
[     8.130] 	ABI class: X.Org Video Driver, version 25.2
[     8.130] (II) LoadModule: "ati"
[     8.130] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     8.130] (II) Module ati: vendor="X.Org Foundation"
[     8.130] 	compiled for 1.21.1.11, module version = 22.0.0
[     8.149] (II) LoadModule: "modesetting"
[     8.149] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     8.149] (II) Module modesetting: vendor="X.Org Foundation"
[     8.149] 	compiled for 1.21.1.16, module version = 1.21.1
[     8.149] 	Module class: X.Org Video Driver
[     8.149] 	ABI class: X.Org Video Driver, version 25.2
[     8.149] (II) LoadModule: "fbdev"
[     8.149] (WW) Warning, couldn't open module fbdev
[     8.149] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     8.149] (II) LoadModule: "vesa"
[     8.149] (WW) Warning, couldn't open module vesa
[     8.149] (EE) Failed to load module "vesa" (module does not exist, 0)
[     8.149] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[     8.149] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     8.169] (WW) Falling back to old probe method for modesetting
[     8.169] (EE) open /dev/dri/card0: No such file or directory
[     8.169] (II) AMDGPU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     8.169] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     8.169] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     8.169] (==) AMDGPU(0): Default visual is TrueColor
[     8.169] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card1
[     8.169] (==) AMDGPU(0): RGB weight 888
[     8.169] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     8.169] (--) AMDGPU(0): Chipset: "AMD Radeon RX 590 Series" (ChipID = 0x67df)
[     8.169] (II) Loading sub module "fb"
[     8.169] (II) LoadModule: "fb"
[     8.169] (II) Module "fb" already built-in
[     8.169] (II) Loading sub module "dri2"
[     8.169] (II) LoadModule: "dri2"
[     8.169] (II) Module "dri2" already built-in
[     8.478] (II) Loading sub module "glamoregl"
[     8.478] (II) LoadModule: "glamoregl"
[     8.478] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     8.483] (II) Module glamoregl: vendor="X.Org Foundation"
[     8.483] 	compiled for 1.21.1.16, module version = 1.0.1
[     8.483] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.493] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon RX 590 Series (radeonsi, polaris10, ACO, DRM 3.61, 6.14.6-2-MANJARO)
[     8.493] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     8.493] (==) AMDGPU(0): TearFree property default: auto
[     8.493] (==) AMDGPU(0): VariableRefresh: disabled
[     8.493] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[     8.493] (II) AMDGPU(0): KMS Pageflipping: enabled
[     8.493] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[     8.493] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[     8.498] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[     8.506] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[     8.506] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[     8.506] (II) AMDGPU(0): EDID for output DisplayPort-0
[     8.506] (II) AMDGPU(0): EDID for output DisplayPort-1
[     8.512] (II) AMDGPU(0): EDID for output DisplayPort-2
[     8.512] (II) AMDGPU(0): Manufacturer: DON  Model: 3d  Serial#: 16843009
[     8.512] (II) AMDGPU(0): Year: 2014  Week: 0
[     8.512] (II) AMDGPU(0): EDID Version: 1.3
[     8.512] (II) AMDGPU(0): Digital Display Input
[     8.512] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 80  vert.: 45
[     8.512] (II) AMDGPU(0): Gamma: 2.20
[     8.512] (II) AMDGPU(0): No DPMS capabilities specified
[     8.512] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     8.512] (II) AMDGPU(0): First detailed timing is preferred mode
[     8.512] (II) AMDGPU(0): redX: 0.625 redY: 0.340   greenX: 0.280 greenY: 0.595
[     8.512] (II) AMDGPU(0): blueX: 0.155 blueY: 0.070   whiteX: 0.283 whiteY: 0.298
[     8.512] (II) AMDGPU(0): Supported established timings:
[     8.512] (II) AMDGPU(0): 640x480@60Hz
[     8.512] (II) AMDGPU(0): Manufacturer's mask: 0
[     8.512] (II) AMDGPU(0): Supported detailed timing:
[     8.512] (II) AMDGPU(0): clock: 74.2 MHz   Image Size:  708 x 398 mm
[     8.512] (II) AMDGPU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     8.512] (II) AMDGPU(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[     8.512] (II) AMDGPU(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[     8.512] (II) AMDGPU(0): Monitor name: DENON-AVR
[     8.512] (II) AMDGPU(0): Ranges: V min: 49 V max: 61 Hz, H min: 15 H max: 68 kHz, PixClock max 155 MHz
[     8.512] (II) AMDGPU(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[     8.512] (II) AMDGPU(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[     8.512] (II) AMDGPU(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[     8.512] (II) AMDGPU(0): clock: 27.0 MHz   Image Size:  708 x 398 mm
[     8.512] (II) AMDGPU(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[     8.512] (II) AMDGPU(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[     8.512] (II) AMDGPU(0): Number of EDID sections to follow: 1
[     8.512] (II) AMDGPU(0): EDID (in hex):
[     8.512] (II) AMDGPU(0): 	00ffffffffffff0011ee3d0001010101
[     8.512] (II) AMDGPU(0): 	0018010380502d780a0dc9a057479827
[     8.512] (II) AMDGPU(0): 	12484c20000001010101010101010101
[     8.512] (II) AMDGPU(0): 	010101010101011d8018711c1620582c
[     8.512] (II) AMDGPU(0): 	2500c48e2100009e011d80d0721c1620
[     8.512] (II) AMDGPU(0): 	102c2580c48e2100009e000000fc0044
[     8.512] (II) AMDGPU(0): 	454e4f4e2d4156520a202020000000fd
[     8.512] (II) AMDGPU(0): 	00313d0f440f000a20202020202001a3
[     8.512] (II) AMDGPU(0): 	02033c71588514041302031112101f20
[     8.512] (II) AMDGPU(0): 	06071516010e230f241d251e26320f7f
[     8.512] (II) AMDGPU(0): 	071507503d1ec05706005f7e01677e00
[     8.512] (II) AMDGPU(0): 	835f000067030c005000b82d011d0072
[     8.512] (II) AMDGPU(0): 	51d01e206e285500c48e2100001e011d
[     8.512] (II) AMDGPU(0): 	00bc52d01e20b8285540c48e2100001e
[     8.512] (II) AMDGPU(0): 	8c0ad08a20e02d10103e9600c48e2100
[     8.512] (II) AMDGPU(0): 	0018000000000000000000000000006a
[     8.512] (--) AMDGPU(0): HDMI max TMDS frequency 225000KHz
[     8.512] (II) AMDGPU(0): Printing probed modes for output DisplayPort-2
[     8.512] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "2880x576"x50.0  108.00  2880 2928 3184 3456  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "2880x480"x60.0  108.11  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "2880x480"x59.9  108.00  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1440x576"x50.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1440x480"x60.0   54.05  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "1440x480"x59.9   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.512] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.519] (II) AMDGPU(0): EDID for output HDMI-A-0
[     8.519] (II) AMDGPU(0): Manufacturer: PHL  Model: 1ea  Serial#: 16843009
[     8.519] (II) AMDGPU(0): Year: 2017  Week: 15
[     8.519] (II) AMDGPU(0): EDID Version: 1.3
[     8.519] (II) AMDGPU(0): Digital Display Input
[     8.519] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 144  vert.: 81
[     8.519] (II) AMDGPU(0): Gamma: 2.20
[     8.519] (II) AMDGPU(0): No DPMS capabilities specified
[     8.519] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     8.519] (II) AMDGPU(0): First detailed timing is preferred mode
[     8.519] (II) AMDGPU(0): redX: 0.649 redY: 0.334   greenX: 0.324 greenY: 0.589
[     8.519] (II) AMDGPU(0): blueX: 0.145 blueY: 0.051   whiteX: 0.280 whiteY: 0.290
[     8.519] (II) AMDGPU(0): Supported established timings:
[     8.519] (II) AMDGPU(0): 640x480@60Hz
[     8.519] (II) AMDGPU(0): 800x600@60Hz
[     8.519] (II) AMDGPU(0): 1024x768@60Hz
[     8.519] (II) AMDGPU(0): Manufacturer's mask: 0
[     8.519] (II) AMDGPU(0): Supported standard timings:
[     8.519] (II) AMDGPU(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     8.519] (II) AMDGPU(0): #1: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     8.519] (II) AMDGPU(0): #2: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[     8.519] (II) AMDGPU(0): #3: hsize: 1400  vsize 1050  refresh: 60  vid: 16528
[     8.519] (II) AMDGPU(0): #4: hsize: 1280  vsize 800  refresh: 60  vid: 129
[     8.519] (II) AMDGPU(0): #5: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     8.519] (II) AMDGPU(0): #6: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[     8.519] (II) AMDGPU(0): Supported detailed timing:
[     8.519] (II) AMDGPU(0): clock: 148.5 MHz   Image Size:  1440 x 810 mm
[     8.519] (II) AMDGPU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     8.519] (II) AMDGPU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     8.519] (II) AMDGPU(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[     8.519] (II) AMDGPU(0): Monitor name: Philips FTV
[     8.519] (II) AMDGPU(0): Ranges: V min: 48 V max: 62 Hz, H min: 15 H max: 70 kHz, PixClock max 605 MHz
[     8.520] (II) AMDGPU(0): Supported detailed timing:
[     8.520] (II) AMDGPU(0): clock: 594.0 MHz   Image Size:  1440 x 810 mm
[     8.520] (II) AMDGPU(0): h_active: 3840  h_sync: 4016  h_sync_end 4104 h_blank_end 4400 h_border: 0
[     8.520] (II) AMDGPU(0): v_active: 2160  v_sync: 2168  v_sync_end 2178 v_blanking: 2250 v_border: 0
[     8.520] (II) AMDGPU(0): clock: 74.2 MHz   Image Size:  1440 x 810 mm
[     8.520] (II) AMDGPU(0): h_active: 1920  h_sync: 2558  h_sync_end 2602 h_blank_end 2750 h_border: 0
[     8.520] (II) AMDGPU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     8.520] (II) AMDGPU(0): Number of EDID sections to follow: 1
[     8.520] (II) AMDGPU(0): EDID (in hex):
[     8.520] (II) AMDGPU(0): 	00ffffffffffff00410cea0101010101
[     8.520] (II) AMDGPU(0): 	0f1b0103809051780a630da655539625
[     8.520] (II) AMDGPU(0): 	0d474a210800b3009500a94090408100
[     8.520] (II) AMDGPU(0): 	818081400101023a801871382d40582c
[     8.520] (II) AMDGPU(0): 	4500a02a5300001e023a80d072382d40
[     8.520] (II) AMDGPU(0): 	102c4580a02a5300001e000000fc0050
[     8.520] (II) AMDGPU(0): 	68696c697073204654560a20000000fd
[     8.520] (II) AMDGPU(0): 	00303e0f463c000a2020202020200190
[     8.520] (II) AMDGPU(0): 	020355f15761605f5e5d101f20222105
[     8.520] (II) AMDGPU(0): 	1404131203110216071506012c091f07
[     8.520] (II) AMDGPU(0): 	1507503d07c0570600830100006f030c
[     8.520] (II) AMDGPU(0): 	002000383ca02929086001020367d85d
[     8.520] (II) AMDGPU(0): 	c401788000e20049e40f030000e305c0
[     8.520] (II) AMDGPU(0): 	00e306050108e80030f2705a80b0588a
[     8.520] (II) AMDGPU(0): 	00a02a5300001e011d803e73382d407e
[     8.520] (II) AMDGPU(0): 	2c4580a02a5300001e0000000000006a
[     8.520] (--) AMDGPU(0): HDMI max TMDS frequency 300000KHz
[     8.520] (II) AMDGPU(0): Printing probed modes for output HDMI-A-0
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x60.0  594.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x50.0  594.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x59.9  593.41  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (134.9 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x25.0  297.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x24.0  297.00  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x30.0  296.70  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "3840x2160"x24.0  296.70  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x30.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x25.0   74.25  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1400x1050"x59.9  101.00  1400 1448 1480 1560  1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.520] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.520] (II) AMDGPU(0): EDID for output DVI-D-0
[     8.520] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[     8.520] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[     8.520] (II) AMDGPU(0): Output DisplayPort-2 connected
[     8.520] (II) AMDGPU(0): Output HDMI-A-0 connected
[     8.520] (II) AMDGPU(0): Output DVI-D-0 disconnected
[     8.520] (II) AMDGPU(0): Using exact sizes for initial modes
[     8.520] (II) AMDGPU(0): Output DisplayPort-2 using initial mode 1920x1080 +0+0
[     8.520] (II) AMDGPU(0): Output HDMI-A-0 using initial mode 1920x1080 +0+0
[     8.520] (II) AMDGPU(0): mem size init: gart size :1f02f1000 vram size: s:1feae7000 visible:f413000
[     8.520] (==) AMDGPU(0): DPI set to (96, 96)
[     8.520] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.520] (II) Loading sub module "ramdac"
[     8.520] (II) LoadModule: "ramdac"
[     8.520] (II) Module "ramdac" already built-in
[     8.520] (II) UnloadModule: "modesetting"
[     8.520] (II) Unloading modesetting
[     8.520] (II) AMDGPU(0): [DRI2] Setup complete
[     8.520] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     8.520] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     8.520] (II) AMDGPU(0): Front buffer pitch: 8192 bytes
[     8.520] (II) AMDGPU(0): SYNC extension fences enabled
[     8.520] (II) AMDGPU(0): Present extension enabled
[     8.520] (==) AMDGPU(0): DRI3 enabled
[     8.520] (==) AMDGPU(0): Backing store enabled
[     8.520] (II) AMDGPU(0): Direct rendering enabled
[     8.531] (II) AMDGPU(0): Use GLAMOR acceleration.
[     8.531] (II) AMDGPU(0): Acceleration enabled
[     8.531] (==) AMDGPU(0): DPMS enabled
[     8.531] (==) AMDGPU(0): Silken mouse enabled
[     8.531] (II) AMDGPU(0): Set up textured video (glamor)
[     8.566] (WW) AMDGPU(0): Option "HotplugDriver" is not used
[     8.566] (II) Initializing extension Generic Event Extension
[     8.566] (II) Initializing extension SHAPE
[     8.566] (II) Initializing extension MIT-SHM
[     8.566] (II) Initializing extension XInputExtension
[     8.566] (II) Initializing extension XTEST
[     8.566] (II) Initializing extension BIG-REQUESTS
[     8.566] (II) Initializing extension SYNC
[     8.566] (II) Initializing extension XKEYBOARD
[     8.566] (II) Initializing extension XC-MISC
[     8.566] (II) Initializing extension SECURITY
[     8.566] (II) Initializing extension XFIXES
[     8.566] (II) Initializing extension RENDER
[     8.566] (II) Initializing extension RANDR
[     8.566] (II) Initializing extension COMPOSITE
[     8.566] (II) Initializing extension DAMAGE
[     8.566] (II) Initializing extension MIT-SCREEN-SAVER
[     8.566] (II) Initializing extension DOUBLE-BUFFER
[     8.566] (II) Initializing extension RECORD
[     8.566] (II) Initializing extension DPMS
[     8.567] (II) Initializing extension Present
[     8.567] (II) Initializing extension DRI3
[     8.567] (II) Initializing extension X-Resource
[     8.567] (II) Initializing extension XVideo
[     8.567] (II) Initializing extension XVideo-MotionCompensation
[     8.567] (II) Initializing extension GLX
[     8.573] (II) AIGLX: Loaded and initialized radeonsi
[     8.573] (II) GLX: Initialized DRI2 GL provider for screen 0
[     8.573] (II) Initializing extension XFree86-VidModeExtension
[     8.573] (II) Initializing extension XFree86-DGA
[     8.573] (II) Initializing extension XFree86-DRI
[     8.573] (II) Initializing extension DRI2
[     8.573] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[     8.713] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.713] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.713] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.713] (**) Power Button: Applying InputClass "system-keyboard"
[     8.713] (II) LoadModule: "libinput"
[     8.713] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.717] (II) Module libinput: vendor="X.Org Foundation"
[     8.717] 	compiled for 1.21.1.13, module version = 1.5.0
[     8.717] 	Module class: X.Org XInput Driver
[     8.717] 	ABI class: X.Org XInput driver, version 24.4
[     8.717] (II) Using input driver 'libinput' for 'Power Button'
[     8.717] (**) Power Button: always reports core events
[     8.717] (**) Option "Device" "/dev/input/event1"
[     8.720] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.720] (II) event1  - Power Button: device is a keyboard
[     8.720] (II) event1  - Power Button: device removed
[     8.728] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     8.728] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.728] (**) Option "xkb_layout" "dk"
[     8.728] (**) Option "xkb_variant" "winkeys"
[     8.739] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.739] (II) event1  - Power Button: device is a keyboard
[     8.739] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     8.739] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.739] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.739] (**) Power Button: Applying InputClass "system-keyboard"
[     8.739] (II) Using input driver 'libinput' for 'Power Button'
[     8.739] (**) Power Button: always reports core events
[     8.739] (**) Option "Device" "/dev/input/event0"
[     8.740] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.740] (II) event0  - Power Button: device is a keyboard
[     8.740] (II) event0  - Power Button: device removed
[     8.756] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     8.756] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     8.756] (**) Option "xkb_layout" "dk"
[     8.756] (**) Option "xkb_variant" "winkeys"
[     8.756] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.756] (II) event0  - Power Button: device is a keyboard
[     8.756] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event2)
[     8.756] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[     8.756] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "libinput keyboard catchall"
[     8.756] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "system-keyboard"
[     8.756] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse'
[     8.756] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[     8.756] (**) Option "Device" "/dev/input/event2"
[     8.757] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     8.757] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     8.757] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: device removed
[     8.773] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.0/0003:062A:4101.0001/input/input2/event2"
[     8.773] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 8)
[     8.773] (**) Option "xkb_layout" "dk"
[     8.773] (**) Option "xkb_variant" "winkeys"
[     8.773] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     8.773] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     8.774] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event3)
[     8.774] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[     8.774] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[     8.774] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse'
[     8.774] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[     8.774] (**) Option "Device" "/dev/input/event3"
[     8.775] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Mouse
[     8.775] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: device is a pointer
[     8.775] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: device removed
[     8.801] (II) libinput: MOSART Semi. 2.4G Keyboard Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[     8.801] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input3/event3"
[     8.801] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: MOUSE, id 9)
[     8.801] (**) Option "AccelerationScheme" "none"
[     8.801] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) selected scheme none/0
[     8.801] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration factor: 2.000
[     8.801] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration threshold: 4
[     8.801] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Mouse
[     8.801] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: device is a pointer
[     8.802] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/mouse0)
[     8.802] (II) No input driver specified, ignoring this device.
[     8.802] (II) This device may have been added with another device file.
[     8.802] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse Consumer Control (/dev/input/event4)
[     8.802] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     8.802] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     8.802] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "system-keyboard"
[     8.802] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse Consumer Control'
[     8.802] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: always reports core events
[     8.802] (**) Option "Device" "/dev/input/event4"
[     8.803] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: is tagged by udev as: Keyboard
[     8.803] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device is a keyboard
[     8.803] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device removed
[     8.819] (II) libinput: MOSART Semi. 2.4G Keyboard Mouse Consumer Control: needs a virtual subdevice
[     8.819] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input4/event4"
[     8.819] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse Consumer Control" (type: MOUSE, id 10)
[     8.819] (**) Option "AccelerationScheme" "none"
[     8.819] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: (accel) selected scheme none/0
[     8.819] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: (accel) acceleration factor: 2.000
[     8.819] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: (accel) acceleration threshold: 4
[     8.819] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: is tagged by udev as: Keyboard
[     8.819] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device is a keyboard
[     8.820] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse System Control (/dev/input/event5)
[     8.820] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: Applying InputClass "evdev keyboard catchall"
[     8.820] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: Applying InputClass "libinput keyboard catchall"
[     8.820] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: Applying InputClass "system-keyboard"
[     8.820] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse System Control'
[     8.820] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: always reports core events
[     8.820] (**) Option "Device" "/dev/input/event5"
[     8.821] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: is tagged by udev as: Keyboard
[     8.821] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: device is a keyboard
[     8.821] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: device removed
[     8.837] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input5/event5"
[     8.837] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse System Control" (type: KEYBOARD, id 11)
[     8.837] (**) Option "xkb_layout" "dk"
[     8.837] (**) Option "xkb_variant" "winkeys"
[     8.837] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: is tagged by udev as: Keyboard
[     8.837] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: device is a keyboard
[     8.838] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event6)
[     8.838] (II) No input driver specified, ignoring this device.
[     8.838] (II) This device may have been added with another device file.
[     8.838] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event10)
[     8.838] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event11)
[     8.839] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event12)
[     8.839] (II) No input driver specified, ignoring this device.
[     8.839] (II) This device may have been added with another device file.
[     8.839] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event13)
[     8.839] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event14)
[     8.839] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[     8.839] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event15)
[     8.839] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event16)
[     8.840] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event17)
[     8.840] (II) No input driver specified, ignoring this device.
[     8.840] (II) This device may have been added with another device file.
[     8.840] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event18)
[     8.840] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event19)
[     8.840] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event8)
[     8.840] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     8.840] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     8.840] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[     8.840] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[     8.840] (**) Eee PC WMI hotkeys: always reports core events
[     8.840] (**) Option "Device" "/dev/input/event8"
[     8.841] (II) event8  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     8.841] (II) event8  - Eee PC WMI hotkeys: device is a keyboard
[     8.841] (II) event8  - Eee PC WMI hotkeys: device removed
[     8.866] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input8/event8"
[     8.866] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 12)
[     8.866] (**) Option "xkb_layout" "dk"
[     8.866] (**) Option "xkb_variant" "winkeys"
[     8.866] (II) event8  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     8.866] (II) event8  - Eee PC WMI hotkeys: device is a keyboard
[     8.866] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     8.866] (II) No input driver specified, ignoring this device.
[     8.866] (II) This device may have been added with another device file.
[     8.869] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     8.869] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     8.869] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "system-keyboard"
[     8.869] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse Consumer Control'
[     8.869] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: always reports core events
[     8.869] (**) Option "Device" "/dev/input/event4"
[     8.869] (II) libinput: MOSART Semi. 2.4G Keyboard Mouse Consumer Control: is a virtual subdevice
[     8.869] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input4/event4"
[     8.869] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse Consumer Control" (type: KEYBOARD, id 13)
[     8.869] (**) Option "xkb_layout" "dk"
[     8.869] (**) Option "xkb_variant" "winkeys"
[    14.771] (II) AMDGPU(0): EDID vendor "DON", prod id 61
[    14.771] (II) AMDGPU(0): Using EDID range info for horizontal sync
[    14.771] (II) AMDGPU(0): Using EDID range info for vertical refresh
[    14.771] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    14.771] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz eP)
[    14.771] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    14.771] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    14.771] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    14.771] (II) AMDGPU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    14.771] (II) AMDGPU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    14.771] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    14.771] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    14.771] (II) AMDGPU(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    14.772] (II) AMDGPU(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[    14.772] (II) AMDGPU(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[    14.772] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    14.772] (II) AMDGPU(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    14.772] (II) AMDGPU(0): Modeline "2880x480"x0.0  108.00  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    14.772] (II) AMDGPU(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    14.772] (II) AMDGPU(0): Modeline "2880x576"x0.0  108.00  2880 2928 3184 3456  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    14.772] (--) AMDGPU(0): HDMI max TMDS frequency 225000KHz
[    14.779] (--) AMDGPU(0): HDMI max TMDS frequency 300000KHz
[    15.090] (II) AMDGPU(0): EDID vendor "DON", prod id 61
[    15.090] (II) AMDGPU(0): Using hsync ranges from config file
[    15.090] (II) AMDGPU(0): Using vrefresh ranges from config file
[    15.090] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    15.090] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz eP)
[    15.090] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "2880x480"x0.0  108.00  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    15.090] (II) AMDGPU(0): Modeline "2880x576"x0.0  108.00  2880 2928 3184 3456  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    15.090] (--) AMDGPU(0): HDMI max TMDS frequency 225000KHz
[    15.098] (--) AMDGPU(0): HDMI max TMDS frequency 300000KHz
[    15.106] (II) AMDGPU(0): Allocate new frame buffer 3840x2160
[    15.107] (II) AMDGPU(0):  => pitch 15360 bytes
[    53.009] (II) event1  - Power Button: device removed
[    53.025] (II) event0  - Power Button: device removed
[    53.035] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: device removed
[    53.047] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: device removed
[    53.067] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: device removed
[    53.078] (II) event8  - Eee PC WMI hotkeys: device removed
[    53.098] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device removed
[    53.108] (II) AIGLX: Suspending AIGLX clients for VT switch
Xorg.0.log normal after boot
[     8.270] (--) Log file renamed from "/var/log/Xorg.pid-700.log" to "/var/log/Xorg.0.log"
[     8.270]
[     8.270] Current Operating System: Linux statPC 6.14.6-2-MANJARO #1 SMP PREEMPT_DYNAMIC Wed, 14 May 2025 14:56:34 +0000 x86_64
[     8.270] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64 root=UUID=15de0dd7-8a22-45e5-9004-6a1a9ba201e8 rw rootflags=subvol=@ nowatchdog mitigations=off security=none udev.log_priority=3 noresume nohibernate
[     8.270]
[     8.270] Current version of pixman: 0.46.0
[     8.270] 	Before reporting problems, check http://wiki.x.org
[     8.270] Markers: (--) probed, (**) from config file, (==) default setting,
[     8.270] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun  4 09:24:09 2025
[     8.271] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     8.271] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.271] (==) No Layout section.  Using the first Screen section.
[     8.271] (==) No screen section available. Using defaults.
[     8.271] (**) |-->Screen "Default Screen Section" (0)
[     8.271] (**) |   |-->Monitor "<default monitor>"
[     8.271] (==) No monitor specified for screen "Default Screen Section".
[     8.271] (**) Allowing byte-swapped clients
[     8.271] (==) Automatically adding devices
[     8.271] (==) Automatically enabling devices
[     8.271] (==) Automatically adding GPU devices
[     8.271] (==) Automatically binding GPU devices
[     8.271] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.272] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     8.272] 	Entry deleted from font path.
[     8.272] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     8.272] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     8.272] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     8.272] (==) FontPath set to:
[     8.272] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.272] (II) The server relies on udev to provide the list of input devices.
[     8.272] (II) Module ABI versions:
[     8.272] 	X.Org ANSI C Emulation: 0.4
[     8.272] 	X.Org Video Driver: 25.2
[     8.272] 	X.Org XInput driver : 24.4
[     8.272] 	X.Org Server Extension : 10.0
[     8.272] (++) using VT number 2
[     8.272] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     8.273] (II) xfree86: Adding drm device (/dev/dri/card1)
[     8.273] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:08:00.0/drm/card1
[     8.279] (--) PCI:*(8@0:0:0) 1002:67df:1458:2311 rev 225, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfcf00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     8.279] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.279] (II) LoadModule: "glx"
[     8.280] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.289] (II) Module glx: vendor="X.Org Foundation"
[     8.289] 	compiled for 1.21.1.16, module version = 1.0.0
[     8.289] 	ABI class: X.Org Server Extension, version 10.0
[     8.289] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[     8.289] 	loading driver: amdgpu
[     8.289] (==) Matched amdgpu as autoconfigured driver 0
[     8.289] (==) Matched ati as autoconfigured driver 1
[     8.289] (==) Matched modesetting as autoconfigured driver 2
[     8.289] (==) Matched fbdev as autoconfigured driver 3
[     8.289] (==) Matched vesa as autoconfigured driver 4
[     8.289] (==) Assigned the driver to the xf86ConfigLayout
[     8.289] (II) LoadModule: "amdgpu"
[     8.289] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     8.292] (II) Module amdgpu: vendor="X.Org Foundation"
[     8.292] 	compiled for 1.21.1.11, module version = 23.0.0
[     8.292] 	Module class: X.Org Video Driver
[     8.292] 	ABI class: X.Org Video Driver, version 25.2
[     8.292] (II) LoadModule: "ati"
[     8.292] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     8.292] (II) Module ati: vendor="X.Org Foundation"
[     8.292] 	compiled for 1.21.1.11, module version = 22.0.0
[     8.310] (II) LoadModule: "modesetting"
[     8.310] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     8.311] (II) Module modesetting: vendor="X.Org Foundation"
[     8.311] 	compiled for 1.21.1.16, module version = 1.21.1
[     8.311] 	Module class: X.Org Video Driver
[     8.311] 	ABI class: X.Org Video Driver, version 25.2
[     8.311] (II) LoadModule: "fbdev"
[     8.311] (WW) Warning, couldn't open module fbdev
[     8.311] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     8.311] (II) LoadModule: "vesa"
[     8.311] (WW) Warning, couldn't open module vesa
[     8.311] (EE) Failed to load module "vesa" (module does not exist, 0)
[     8.311] (II) AMDGPU: Driver for AMD Radeon:
[     8.311] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     8.330] (WW) Falling back to old probe method for modesetting
[     8.330] (EE) open /dev/dri/card0: No such file or directory
[     8.330] (II) AMDGPU(0): Creating default Display subsection in Screen section
[     8.330] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     8.330] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     8.330] (==) AMDGPU(0): Default visual is TrueColor
[     8.330] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card1
[     8.330] (==) AMDGPU(0): RGB weight 888
[     8.330] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     8.330] (--) AMDGPU(0): Chipset: "AMD Radeon RX 590 Series" (ChipID = 0x67df)
[     8.330] (II) Loading sub module "fb"
[     8.330] (II) LoadModule: "fb"
[     8.330] (II) Module "fb" already built-in
[     8.330] (II) Loading sub module "dri2"
[     8.330] (II) LoadModule: "dri2"
[     8.330] (II) Module "dri2" already built-in
[     8.638] (II) Loading sub module "glamoregl"
[     8.638] (II) LoadModule: "glamoregl"
[     8.638] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     8.643] (II) Module glamoregl: vendor="X.Org Foundation"
[     8.643] 	compiled for 1.21.1.16, module version = 1.0.1
[     8.643] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.653] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon RX 590 Series (radeonsi, polaris10, ACO, DRM 3.61, 6.14.6-2-MANJARO)
[     8.653] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     8.653] (==) AMDGPU(0): TearFree property default: auto
[     8.653] (==) AMDGPU(0): VariableRefresh: disabled
[     8.653] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[     8.653] (II) AMDGPU(0): KMS Pageflipping: enabled
[     8.653] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[     8.653] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[     8.659] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[     8.666] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[     8.666] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[     8.666] (II) AMDGPU(0): EDID for output DisplayPort-0
[     8.666] (II) AMDGPU(0): EDID for output DisplayPort-1
[     8.672] (II) AMDGPU(0): EDID for output DisplayPort-2
[     8.672] (II) AMDGPU(0): Manufacturer: DON  Model: 3d  Serial#: 16843009
[     8.672] (II) AMDGPU(0): Year: 2014  Week: 0
[     8.672] (II) AMDGPU(0): EDID Version: 1.3
[     8.672] (II) AMDGPU(0): Digital Display Input
[     8.672] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 80  vert.: 45
[     8.672] (II) AMDGPU(0): Gamma: 2.20
[     8.672] (II) AMDGPU(0): No DPMS capabilities specified
[     8.672] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     8.672] (II) AMDGPU(0): First detailed timing is preferred mode
[     8.672] (II) AMDGPU(0): redX: 0.625 redY: 0.340   greenX: 0.280 greenY: 0.595
[     8.672] (II) AMDGPU(0): blueX: 0.155 blueY: 0.070   whiteX: 0.283 whiteY: 0.298
[     8.672] (II) AMDGPU(0): Supported established timings:
[     8.672] (II) AMDGPU(0): 640x480@60Hz
[     8.672] (II) AMDGPU(0): Manufacturer's mask: 0
[     8.672] (II) AMDGPU(0): Supported detailed timing:
[     8.672] (II) AMDGPU(0): clock: 74.2 MHz   Image Size:  708 x 398 mm
[     8.672] (II) AMDGPU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     8.672] (II) AMDGPU(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[     8.672] (II) AMDGPU(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[     8.672] (II) AMDGPU(0): Monitor name: DENON-AVR
[     8.672] (II) AMDGPU(0): Ranges: V min: 49 V max: 61 Hz, H min: 15 H max: 68 kHz, PixClock max 155 MHz
[     8.672] (II) AMDGPU(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[     8.672] (II) AMDGPU(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[     8.672] (II) AMDGPU(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[     8.672] (II) AMDGPU(0): clock: 27.0 MHz   Image Size:  708 x 398 mm
[     8.672] (II) AMDGPU(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[     8.672] (II) AMDGPU(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[     8.672] (II) AMDGPU(0): Number of EDID sections to follow: 1
[     8.672] (II) AMDGPU(0): EDID (in hex):
[     8.672] (II) AMDGPU(0): 	00ffffffffffff0011ee3d0001010101
[     8.672] (II) AMDGPU(0): 	0018010380502d780a0dc9a057479827
[     8.672] (II) AMDGPU(0): 	12484c20000001010101010101010101
[     8.672] (II) AMDGPU(0): 	010101010101011d8018711c1620582c
[     8.672] (II) AMDGPU(0): 	2500c48e2100009e011d80d0721c1620
[     8.672] (II) AMDGPU(0): 	102c2580c48e2100009e000000fc0044
[     8.672] (II) AMDGPU(0): 	454e4f4e2d4156520a202020000000fd
[     8.672] (II) AMDGPU(0): 	00313d0f440f000a20202020202001a3
[     8.672] (II) AMDGPU(0): 	02033c71588514041302031112101f20
[     8.672] (II) AMDGPU(0): 	06071516010e230f241d251e26320f7f
[     8.672] (II) AMDGPU(0): 	071507503d1ec05706005f7e01677e00
[     8.672] (II) AMDGPU(0): 	835f000067030c005000b82d011d0072
[     8.672] (II) AMDGPU(0): 	51d01e206e285500c48e2100001e011d
[     8.672] (II) AMDGPU(0): 	00bc52d01e20b8285540c48e2100001e
[     8.672] (II) AMDGPU(0): 	8c0ad08a20e02d10103e9600c48e2100
[     8.672] (II) AMDGPU(0): 	0018000000000000000000000000006a
[     8.672] (--) AMDGPU(0): HDMI max TMDS frequency 225000KHz
[     8.672] (II) AMDGPU(0): Printing probed modes for output DisplayPort-2
[     8.672] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "2880x576"x50.0  108.00  2880 2928 3184 3456  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "2880x480"x60.0  108.11  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "2880x480"x59.9  108.00  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1440x576"x50.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1440x480"x60.0   54.05  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "1440x480"x59.9   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.672] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.680] (II) AMDGPU(0): EDID for output HDMI-A-0
[     8.680] (II) AMDGPU(0): Manufacturer: PHL  Model: 1ea  Serial#: 16843009
[     8.680] (II) AMDGPU(0): Year: 2017  Week: 15
[     8.680] (II) AMDGPU(0): EDID Version: 1.3
[     8.680] (II) AMDGPU(0): Digital Display Input
[     8.680] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 144  vert.: 81
[     8.680] (II) AMDGPU(0): Gamma: 2.20
[     8.680] (II) AMDGPU(0): No DPMS capabilities specified
[     8.680] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     8.680] (II) AMDGPU(0): First detailed timing is preferred mode
[     8.680] (II) AMDGPU(0): redX: 0.649 redY: 0.334   greenX: 0.324 greenY: 0.589
[     8.680] (II) AMDGPU(0): blueX: 0.145 blueY: 0.051   whiteX: 0.280 whiteY: 0.290
[     8.680] (II) AMDGPU(0): Supported established timings:
[     8.680] (II) AMDGPU(0): 640x480@60Hz
[     8.680] (II) AMDGPU(0): 800x600@60Hz
[     8.680] (II) AMDGPU(0): 1024x768@60Hz
[     8.680] (II) AMDGPU(0): Manufacturer's mask: 0
[     8.680] (II) AMDGPU(0): Supported standard timings:
[     8.680] (II) AMDGPU(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     8.680] (II) AMDGPU(0): #1: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     8.680] (II) AMDGPU(0): #2: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[     8.680] (II) AMDGPU(0): #3: hsize: 1400  vsize 1050  refresh: 60  vid: 16528
[     8.680] (II) AMDGPU(0): #4: hsize: 1280  vsize 800  refresh: 60  vid: 129
[     8.680] (II) AMDGPU(0): #5: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     8.680] (II) AMDGPU(0): #6: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[     8.680] (II) AMDGPU(0): Supported detailed timing:
[     8.680] (II) AMDGPU(0): clock: 148.5 MHz   Image Size:  1440 x 810 mm
[     8.680] (II) AMDGPU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     8.680] (II) AMDGPU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     8.680] (II) AMDGPU(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[     8.680] (II) AMDGPU(0): Monitor name: Philips FTV
[     8.680] (II) AMDGPU(0): Ranges: V min: 48 V max: 62 Hz, H min: 15 H max: 70 kHz, PixClock max 605 MHz
[     8.680] (II) AMDGPU(0): clock: 594.0 MHz   Image Size:  1440 x 810 mm
[     8.680] (II) AMDGPU(0): h_active: 3840  h_sync: 4016  h_sync_end 4104 h_blank_end 4400 h_border: 0
[     8.680] (II) AMDGPU(0): v_active: 2160  v_sync: 2168  v_sync_end 2178 v_blanking: 2250 v_border: 0
[     8.680] (II) AMDGPU(0): clock: 74.2 MHz   Image Size:  1440 x 810 mm
[     8.680] (II) AMDGPU(0): h_active: 1920  h_sync: 2558  h_sync_end 2602 h_blank_end 2750 h_border: 0
[     8.680] (II) AMDGPU(0): Number of EDID sections to follow: 1
[     8.680] (II) AMDGPU(0): EDID (in hex):
[     8.680] (II) AMDGPU(0): 	00ffffffffffff00410cea0101010101
[     8.680] (II) AMDGPU(0): 	0f1b0103809051780a630da655539625
[     8.680] (II) AMDGPU(0): 	0d474a210800b3009500a94090408100
[     8.680] (II) AMDGPU(0): 	818081400101023a801871382d40582c
[     8.680] (II) AMDGPU(0): 	4500a02a5300001e023a80d072382d40
[     8.680] (II) AMDGPU(0): 	102c4580a02a5300001e000000fc0050
[     8.680] (II) AMDGPU(0): 	68696c697073204654560a20000000fd
[     8.680] (II) AMDGPU(0): 	00303e0f463c000a2020202020200190
[     8.680] (II) AMDGPU(0): 	020355f15761605f5e5d101f20222105
[     8.680] (II) AMDGPU(0): 	1404131203110216071506012c091f07
[     8.680] (II) AMDGPU(0): 	1507503d07c0570600830100006f030c
[     8.680] (II) AMDGPU(0): 	002000383ca02929086001020367d85d
[     8.680] (II) AMDGPU(0): 	c401788000e20049e40f030000e305c0
[     8.680] (II) AMDGPU(0): 	00e306050108e80030f2705a80b0588a
[     8.680] (II) AMDGPU(0): 	00a02a5300001e011d803e73382d407e
[     8.680] (II) AMDGPU(0): 	2c4580a02a5300001e0000000000006a
[     8.680] (--) AMDGPU(0): HDMI max TMDS frequency 300000KHz
[     8.680] (II) AMDGPU(0): Printing probed modes for output HDMI-A-0
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x60.0  594.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x50.0  594.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x59.9  593.41  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (134.9 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x25.0  297.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x24.0  297.00  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x30.0  296.70  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "3840x2160"x24.0  296.70  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x30.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x25.0   74.25  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1400x1050"x59.9  101.00  1400 1448 1480 1560  1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.680] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.680] (II) AMDGPU(0): EDID for output DVI-D-0
[     8.680] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[     8.680] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[     8.680] (II) AMDGPU(0): Output DisplayPort-2 connected
[     8.680] (II) AMDGPU(0): Output HDMI-A-0 connected
[     8.680] (II) AMDGPU(0): Output DVI-D-0 disconnected
[     8.680] (II) AMDGPU(0): Using exact sizes for initial modes
[     8.680] (II) AMDGPU(0): Output DisplayPort-2 using initial mode 1920x1080 +0+0
[     8.680] (II) AMDGPU(0): Output HDMI-A-0 using initial mode 1920x1080 +0+0
[     8.680] (II) AMDGPU(0): mem size init: gart size :1f02f0000 vram size: s:1feae7000 visible:f413000
[     8.680] (==) AMDGPU(0): DPI set to (96, 96)
[     8.680] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.680] (II) Loading sub module "ramdac"
[     8.680] (II) LoadModule: "ramdac"
[     8.680] (II) Module "ramdac" already built-in
[     8.680] (II) UnloadModule: "modesetting"
[     8.680] (II) Unloading modesetting
[     8.680] (II) AMDGPU(0): [DRI2] Setup complete
[     8.680] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     8.680] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     8.680] (II) AMDGPU(0): Front buffer pitch: 8192 bytes
[     8.680] (II) AMDGPU(0): SYNC extension fences enabled
[     8.680] (II) AMDGPU(0): Present extension enabled
[     8.680] (==) AMDGPU(0): DRI3 enabled
[     8.680] (==) AMDGPU(0): Backing store enabled
[     8.680] (II) AMDGPU(0): Direct rendering enabled
[     8.691] (II) AMDGPU(0): Use GLAMOR acceleration.
[     8.691] (II) AMDGPU(0): Acceleration enabled
[     8.691] (==) AMDGPU(0): DPMS enabled
[     8.691] (==) AMDGPU(0): Silken mouse enabled
[     8.691] (II) AMDGPU(0): Set up textured video (glamor)
[     8.710] (WW) AMDGPU(0): Option "HotplugDriver" is not used
[     8.710] (II) Initializing extension Generic Event Extension
[     8.710] (II) Initializing extension SHAPE
[     8.710] (II) Initializing extension MIT-SHM
[     8.710] (II) Initializing extension XInputExtension
[     8.710] (II) Initializing extension XTEST
[     8.710] (II) Initializing extension BIG-REQUESTS
[     8.710] (II) Initializing extension SYNC
[     8.710] (II) Initializing extension XKEYBOARD
[     8.710] (II) Initializing extension XC-MISC
[     8.711] (II) Initializing extension SECURITY
[     8.711] (II) Initializing extension XFIXES
[     8.711] (II) Initializing extension RENDER
[     8.711] (II) Initializing extension RANDR
[     8.711] (II) Initializing extension COMPOSITE
[     8.711] (II) Initializing extension DAMAGE
[     8.711] (II) Initializing extension MIT-SCREEN-SAVER
[     8.711] (II) Initializing extension DOUBLE-BUFFER
[     8.711] (II) Initializing extension RECORD
[     8.711] (II) Initializing extension DPMS
[     8.711] (II) Initializing extension Present
[     8.711] (II) Initializing extension DRI3
[     8.711] (II) Initializing extension X-Resource
[     8.711] (II) Initializing extension XVideo
[     8.711] (II) Initializing extension XVideo-MotionCompensation
[     8.711] (II) Initializing extension GLX
[     8.717] (II) AIGLX: Loaded and initialized radeonsi
[     8.717] (II) GLX: Initialized DRI2 GL provider for screen 0
[     8.717] (II) Initializing extension XFree86-VidModeExtension
[     8.717] (II) Initializing extension XFree86-DGA
[     8.718] (II) Initializing extension XFree86-DRI
[     8.718] (II) Initializing extension DRI2
[     8.718] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[     8.858] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.858] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.858] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.858] (**) Power Button: Applying InputClass "system-keyboard"
[     8.858] (II) LoadModule: "libinput"
[     8.858] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.862] (II) Module libinput: vendor="X.Org Foundation"
[     8.862] 	compiled for 1.21.1.13, module version = 1.5.0
[     8.862] 	Module class: X.Org XInput Driver
[     8.862] 	ABI class: X.Org XInput driver, version 24.4
[     8.862] (II) Using input driver 'libinput' for 'Power Button'
[     8.862] (**) Power Button: always reports core events
[     8.862] (**) Option "Device" "/dev/input/event1"
[     8.865] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.865] (II) event1  - Power Button: device is a keyboard
[     8.865] (II) event1  - Power Button: device removed
[     8.881] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     8.881] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.881] (**) Option "xkb_layout" "dk"
[     8.881] (**) Option "xkb_variant" "winkeys"
[     8.892] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.892] (II) event1  - Power Button: device is a keyboard
[     8.892] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     8.892] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.892] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.892] (**) Power Button: Applying InputClass "system-keyboard"
[     8.892] (II) Using input driver 'libinput' for 'Power Button'
[     8.892] (**) Power Button: always reports core events
[     8.892] (**) Option "Device" "/dev/input/event0"
[     8.892] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.892] (II) event0  - Power Button: device is a keyboard
[     8.892] (II) event0  - Power Button: device removed
[     8.900] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     8.900] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     8.900] (**) Option "xkb_layout" "dk"
[     8.900] (**) Option "xkb_variant" "winkeys"
[     8.900] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.900] (II) event0  - Power Button: device is a keyboard
[     8.901] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event2)
[     8.901] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[     8.901] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "libinput keyboard catchall"
[     8.901] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "system-keyboard"
[     8.901] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse'
[     8.901] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[     8.901] (**) Option "Device" "/dev/input/event2"
[     8.901] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     8.901] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     8.901] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: device removed
[     8.914] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.0/0003:062A:4101.0001/input/input2/event2"
[     8.914] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 8)
[     8.914] (**) Option "xkb_layout" "dk"
[     8.914] (**) Option "xkb_variant" "winkeys"
[     8.914] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     8.914] (II) event2  - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     8.915] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event3)
[     8.915] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[     8.915] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[     8.915] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse'
[     8.915] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[     8.915] (**) Option "Device" "/dev/input/event3"
[     8.916] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Mouse
[     8.916] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: device is a pointer
[     8.916] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: device removed
[     8.942] (II) libinput: MOSART Semi. 2.4G Keyboard Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[     8.942] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input3/event3"
[     8.942] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: MOUSE, id 9)
[     8.942] (**) Option "AccelerationScheme" "none"
[     8.942] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) selected scheme none/0
[     8.942] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration factor: 2.000
[     8.942] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration threshold: 4
[     8.942] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Mouse
[     8.942] (II) event3  - MOSART Semi. 2.4G Keyboard Mouse: device is a pointer
[     8.943] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/mouse0)
[     8.943] (II) No input driver specified, ignoring this device.
[     8.943] (II) This device may have been added with another device file.
[     8.943] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse Consumer Control (/dev/input/event4)
[     8.943] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     8.943] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     8.943] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "system-keyboard"
[     8.943] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse Consumer Control'
[     8.943] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: always reports core events
[     8.943] (**) Option "Device" "/dev/input/event4"
[     8.944] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: is tagged by udev as: Keyboard
[     8.944] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device is a keyboard
[     8.944] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device removed
[     8.960] (II) libinput: MOSART Semi. 2.4G Keyboard Mouse Consumer Control: needs a virtual subdevice
[     8.960] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input4/event4"
[     8.960] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse Consumer Control" (type: MOUSE, id 10)
[     8.960] (**) Option "AccelerationScheme" "none"
[     8.960] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: (accel) selected scheme none/0
[     8.960] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: (accel) acceleration factor: 2.000
[     8.960] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: (accel) acceleration threshold: 4
[     8.960] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: is tagged by udev as: Keyboard
[     8.960] (II) event4  - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device is a keyboard
[     8.961] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse System Control (/dev/input/event5)
[     8.961] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: Applying InputClass "evdev keyboard catchall"
[     8.961] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: Applying InputClass "libinput keyboard catchall"
[     8.961] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: Applying InputClass "system-keyboard"
[     8.961] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse System Control'
[     8.961] (**) MOSART Semi. 2.4G Keyboard Mouse System Control: always reports core events
[     8.961] (**) Option "Device" "/dev/input/event5"
[     8.962] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: is tagged by udev as: Keyboard
[     8.962] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: device is a keyboard
[     8.962] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: device removed
[     8.978] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input5/event5"
[     8.978] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse System Control" (type: KEYBOARD, id 11)
[     8.978] (**) Option "xkb_layout" "dk"
[     8.978] (**) Option "xkb_variant" "winkeys"
[     8.978] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: is tagged by udev as: Keyboard
[     8.978] (II) event5  - MOSART Semi. 2.4G Keyboard Mouse System Control: device is a keyboard
[     8.979] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event6)
[     8.979] (II) No input driver specified, ignoring this device.
[     8.979] (II) This device may have been added with another device file.
[     8.979] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event10)
[     8.979] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event11)
[     8.980] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event12)
[     8.980] (II) No input driver specified, ignoring this device.
[     8.980] (II) This device may have been added with another device file.
[     8.980] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event13)
[     8.980] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event14)
[     8.980] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[     8.980] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event15)
[     8.980] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event16)
[     8.981] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event17)
[     8.981] (II) No input driver specified, ignoring this device.
[     8.981] (II) This device may have been added with another device file.
[     8.981] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event18)
[     8.981] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event19)
[     8.981] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event8)
[     8.981] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     8.981] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     8.981] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[     8.981] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[     8.981] (**) Eee PC WMI hotkeys: always reports core events
[     8.981] (**) Option "Device" "/dev/input/event8"
[     8.981] (II) event8  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     8.981] (II) event8  - Eee PC WMI hotkeys: device is a keyboard
[     8.982] (II) event8  - Eee PC WMI hotkeys: device removed
[     9.014] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input8/event8"
[     9.014] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 12)
[     9.014] (**) Option "xkb_layout" "dk"
[     9.014] (**) Option "xkb_variant" "winkeys"
[     9.014] (II) event8  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     9.014] (II) event8  - Eee PC WMI hotkeys: device is a keyboard
[     9.014] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     9.014] (II) No input driver specified, ignoring this device.
[     9.014] (II) This device may have been added with another device file.
[     9.017] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     9.017] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     9.017] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: Applying InputClass "system-keyboard"
[     9.017] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse Consumer Control'
[     9.017] (**) MOSART Semi. 2.4G Keyboard Mouse Consumer Control: always reports core events
[     9.017] (**) Option "Device" "/dev/input/event4"
[     9.017] (II) libinput: MOSART Semi. 2.4G Keyboard Mouse Consumer Control: is a virtual subdevice
[     9.017] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:062A:4101.0002/input/input4/event4"
[     9.017] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse Consumer Control" (type: KEYBOARD, id 13)
[     9.017] (**) Option "xkb_layout" "dk"
[     9.017] (**) Option "xkb_variant" "winkeys"
[    21.021] (II) AMDGPU(0): EDID vendor "DON", prod id 61
[    21.021] (II) AMDGPU(0): Using EDID range info for horizontal sync
[    21.021] (II) AMDGPU(0): Using EDID range info for vertical refresh
[    21.021] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    21.021] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz eP)
[    21.021] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "2880x480"x0.0  108.00  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    21.021] (II) AMDGPU(0): Modeline "2880x576"x0.0  108.00  2880 2928 3184 3456  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    21.021] (--) AMDGPU(0): HDMI max TMDS frequency 225000KHz
[    21.029] (--) AMDGPU(0): HDMI max TMDS frequency 300000KHz
[    21.524] (II) AMDGPU(0): EDID vendor "DON", prod id 61
[    21.524] (II) AMDGPU(0): Using hsync ranges from config file
[    21.524] (II) AMDGPU(0): Using vrefresh ranges from config file
[    21.524] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    21.524] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz eP)
[    21.524] (II) AMDGPU(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "2880x480"x0.0  108.00  2880 2944 3192 3432  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    21.524] (II) AMDGPU(0): Modeline "2880x576"x0.0  108.00  2880 2928 3184 3456  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    21.524] (--) AMDGPU(0): HDMI max TMDS frequency 225000KHz
[    21.532] (--) AMDGPU(0): HDMI max TMDS frequency 300000KHz
[    21.541] (II) AMDGPU(0): Allocate new frame buffer 3840x2160
[    21.541] (II) AMDGPU(0):  => pitch 15360 bytes
Hi @fredvej
I’ve moved your post to a separate support topic.
I notice that you are still running Plasma on X11:
Does the issue also occur when running Plasma on Wayland?
You can switch to a Wayland session either at the login screen or, if you use autologin to skip the login screen, by opening System Settings → Colors & Themes → Login Screen (SDDM) → Behavior.
Hi @fredvej,
Have you tried with a different, kernel? Perhaps 6.12, the latest SLTS?
I cannot reproduce the freezing when I want, and it happens rarely, so I have not tried Wayland or other kernels.
With my original post I just wanted to contribute with my data, I do not expect any action from the Manjaro team on this.
There have been reports about random freezes up to kernel 6.15-rc1 in the discussion I linked. I myself am using 6.12 atm and I still have the occasional freeze at least once a day. It seems the random nature of the error makes it difficult to fix.
That intention might be better served in a Feedback category rather than Support; though now it’s clearly moved beyond that intention.
Your first post presents all the hallmarks of someone asking for Support.
In future, please specify your intention in no uncertain terms, so that a topic may be moved elsewhere if needed. Or, better still, choose a more appropriate category yourself.
This would save much unnecessary response from those who might wish to help, in what seemed a genuine call for assistance.
Nonetheless, doing so is a valid way to isolate a cause; to rule out possible contributors.
I can only suggest - do try Wayland and/or other kernels, and report back if there is noticeable difference.
If, as you say, the freezing is infrequent, then this topic might best be closed in lieu of you providing updated information; results from trying things suggested.
Anecdotal:-
I personally use Manjaro KDE and remain free of any such crashes (on an Intel system with AMD graphics).
