Hi again, I tried the troubleshooting steps in the Arch wiki but no change in the problem:
- remove the kms hook and rebuild the initramfs
- add boot kernel param
acpi_os_name="Microsoft Windows NT"
Other steps weren’t applicable, hardware watchdog timer is already disabled, video driver is already AMDGPU and not using NVIDIA GPU.
So I went on to try debugging steps (the problem I’m seeing is mentioned in section 4.7.2, https://01.org/blogs/rzhang/2015/best-practice-debug-linux-suspend/hibernate-issues)
In section 2 it gives some easy boot options to output put info to the log. I set that up, and then tried the suspend/resume cycling using rtcwake (section 2.11). I set it to repeat 100 times, but it only got as far as 8 before failing to resume again.
btw. I also tried echo 0 > /sys/power/pm_async mentioned, but it didn’t help either.
This is the output from a successful cycle (sorry there’s a ton):
Nov 12 12:45:45 kernel: PM: suspend entry (deep)
Nov 12 12:45:45 kernel: Filesystems sync: 0.063 seconds
Nov 12 12:45:45 wpa_supplicant[1078]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Nov 12 12:46:17 kernel: Freezing user space processes
Nov 12 12:46:17 kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Nov 12 12:46:17 kernel: OOM killer disabled.
Nov 12 12:46:17 kernel: Freezing remaining freezable tasks
Nov 12 12:46:17 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Nov 12 12:46:17 kernel: rfkill rfkill2: PM: calling rfkill_suspend+0x0/0x20 [rfkill] @ 4926, parent: hci0
Nov 12 12:46:17 kernel: rfkill rfkill2: PM: rfkill_suspend+0x0/0x20 [rfkill] returned 0 after 1 usecs
Nov 12 12:46:17 kernel: rfkill rfkill0: PM: calling rfkill_suspend+0x0/0x20 [rfkill] @ 4926, parent: phy0
Nov 12 12:46:17 kernel: usb 5-3: PM: calling usb_dev_suspend+0x0/0x20 @ 4840, parent: usb5
Nov 12 12:46:17 kernel: rfkill rfkill0: PM: rfkill_suspend+0x0/0x20 [rfkill] returned 0 after 0 usecs
Nov 12 12:46:17 kernel: usb 5-3: PM: usb_dev_suspend+0x0/0x20 returned 0 after 66 usecs
Nov 12 12:46:17 kernel: leds phy0-led: PM: calling led_suspend+0x0/0x50 @ 4926, parent: 0000:03:00.0
Nov 12 12:46:17 kernel: ieee80211 phy0: PM: calling wiphy_suspend+0x0/0x2c0 [cfg80211] @ 4858, parent: 0000:03:00.0
Nov 12 12:46:17 kernel: leds phy0-led: PM: led_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: intel_rapl_msr intel_rapl_msr.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: intel_rapl_msr intel_rapl_msr.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input16: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: card1
Nov 12 12:46:17 kernel: input input16: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input15: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: card1
Nov 12 12:46:17 kernel: input input15: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: sound pcmC1D0c: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4926, parent: card1
Nov 12 12:46:17 kernel: sound pcmC1D0c: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 1 usecs
Nov 12 12:46:17 kernel: sound pcmC1D0p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4926, parent: card1
Nov 12 12:46:17 kernel: sound pcmC1D0p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:46:17 kernel: snd-soc-dummy snd-soc-dummy: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: snd-soc-dummy snd-soc-dummy: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input14: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input14: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input13: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input13: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input12: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input12: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input11: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input11: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: sound pcmC0D9p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4926, parent: card0
Nov 12 12:46:17 kernel: sound pcmC0D9p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:46:17 kernel: sound pcmC0D8p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4926, parent: card0
Nov 12 12:46:17 kernel: sound pcmC0D8p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 1 usecs
Nov 12 12:46:17 kernel: sound pcmC0D7p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4926, parent: card0
Nov 12 12:46:17 kernel: sound pcmC0D7p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:46:17 kernel: sound pcmC0D3p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4926, parent: card0
Nov 12 12:46:17 kernel: sound pcmC0D3p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:46:17 kernel: Generic FE-GE Realtek PHY r8169-0-200:00: PM: calling mdio_bus_phy_suspend+0x0/0x120 [libphy] @ 4926, parent: r8169-0-200
Nov 12 12:46:17 kernel: snd_hda_codec_realtek hdaudioC1D0: PM: calling hda_codec_pm_suspend+0x0/0x20 [snd_hda_codec] @ 4827, parent: 0000:04:00.6
Nov 12 12:46:17 kernel: Generic FE-GE Realtek PHY r8169-0-200:00: PM: mdio_bus_phy_suspend+0x0/0x120 [libphy] returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input10: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: eeepc-wmi
Nov 12 12:46:17 kernel: input input10: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: eeepc-wmi eeepc-wmi: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: eeepc-wmi eeepc-wmi: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: hid_sensor_prox HID-SENSOR-200011.7.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 0020:1022:0001.0008
Nov 12 12:46:17 kernel: hid_sensor_prox HID-SENSOR-200011.7.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ieee80211 phy0: PM: wiphy_suspend+0x0/0x2c0 [cfg80211] returned 0 after 37014 usecs
Nov 12 12:46:17 kernel: hid_sensor_als HID-SENSOR-200041.6.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 0020:1022:0001.0007
Nov 12 12:46:17 kernel: hid_sensor_als HID-SENSOR-200041.6.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: hid_sensor_magn_3d HID-SENSOR-200083.5.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 0020:1022:0001.0006
Nov 12 12:46:17 kernel: hid_sensor_magn_3d HID-SENSOR-200083.5.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: hid_sensor_gyro_3d HID-SENSOR-200076.4.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 0020:1022:0001.0005
Nov 12 12:46:17 kernel: hid_sensor_gyro_3d HID-SENSOR-200076.4.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: hid_sensor_accel_3d HID-SENSOR-200073.3.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 0020:1022:0001.0004
Nov 12 12:46:17 kernel: hid_sensor_accel_3d HID-SENSOR-200073.3.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform regulatory.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform regulatory.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: sp5100-tco sp5100-tco: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: sp5100-tco sp5100-tco: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input9: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: pcspkr
Nov 12 12:46:17 kernel: input input9: PM: input_dev_suspend+0x0/0x70 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: snd_hda_codec_realtek hdaudioC1D0: PM: hda_codec_pm_suspend+0x0/0x20 [snd_hda_codec] returned 0 after 20994 usecs
Nov 12 12:46:17 kernel: input input8: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: rc0
Nov 12 12:46:17 kernel: input input8: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: vboxdrv vboxdrv.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: vboxdrv vboxdrv.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: input input7: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: 0003:413C:2010.0003
Nov 12 12:46:17 kernel: input input7: PM: input_dev_suspend+0x0/0x70 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: input input6: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: 0003:413C:2010.0003
Nov 12 12:46:17 kernel: input input6: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::kana: PM: calling led_suspend+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::kana: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::compose: PM: calling led_suspend+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::compose: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::scrolllock: PM: calling led_suspend+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::scrolllock: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::capslock: PM: calling led_suspend+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::capslock: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::numlock: PM: calling led_suspend+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::numlock: PM: led_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: leds mmc0::: PM: calling led_suspend+0x0/0x50 @ 4926, parent: rtsx_usb_sdmmc.1.auto
Nov 12 12:46:17 kernel: leds mmc0::: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input5: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: 0003:413C:2010.0002
Nov 12 12:46:17 kernel: input input5: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input4: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: 0003:046D:C077.0001
Nov 12 12:46:17 kernel: input input4: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: rtsx_usb_ms rtsx_usb_ms.2.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 3-4:1.0
Nov 12 12:46:17 kernel: rtsx_usb_ms rtsx_usb_ms.2.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 62 usecs
Nov 12 12:46:17 kernel: rtsx_usb_sdmmc rtsx_usb_sdmmc.1.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 3-4:1.0
Nov 12 12:46:17 kernel: rtsx_usb_sdmmc rtsx_usb_sdmmc.1.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input3: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: LNXVIDEO:00
Nov 12 12:46:17 kernel: usb 3-2.1: PM: calling usb_dev_suspend+0x0/0x20 @ 4858, parent: 3-2
Nov 12 12:46:17 kernel: usb 3-4: PM: calling usb_dev_suspend+0x0/0x20 @ 4840, parent: usb3
Nov 12 12:46:17 kernel: usb 3-4: PM: usb_dev_suspend+0x0/0x20 returned 0 after 5 usecs
Nov 12 12:46:17 kernel: usb 3-1: PM: calling usb_dev_suspend+0x0/0x20 @ 4827, parent: usb3
Nov 12 12:46:17 kernel: usb 3-1: PM: usb_dev_suspend+0x0/0x20 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: usb 5-2: PM: calling usb_dev_suspend+0x0/0x20 @ 4866, parent: usb5
Nov 12 12:46:17 kernel: usb usb6: PM: calling usb_dev_suspend+0x0/0x20 @ 4827, parent: 0000:04:00.4
Nov 12 12:46:17 kernel: usb usb4: PM: calling usb_dev_suspend+0x0/0x20 @ 2460, parent: 0000:04:00.3
Nov 12 12:46:17 kernel: usb usb2: PM: calling usb_dev_suspend+0x0/0x20 @ 4880, parent: 0000:01:00.0
Nov 12 12:46:17 kernel: usb usb1: PM: calling usb_dev_suspend+0x0/0x20 @ 4862, parent: 0000:01:00.0
Nov 12 12:46:17 kernel: usb usb1: PM: usb_dev_suspend+0x0/0x20 returned 0 after 82 usecs
Nov 12 12:46:17 kernel: input input3: PM: input_dev_suspend+0x0/0x70 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: usb 5-2: PM: usb_dev_suspend+0x0/0x20 returned 0 after 738 usecs
Nov 12 12:46:17 kernel: usb usb5: PM: calling usb_dev_suspend+0x0/0x20 @ 4844, parent: 0000:04:00.4
Nov 12 12:46:17 kernel: usb usb5: PM: usb_dev_suspend+0x0/0x20 returned 0 after 12624 usecs
Nov 12 12:46:17 kernel: platform microcode: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: sd 2:0:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4866, parent: target2:0:0
Nov 12 12:46:17 kernel: sd 1:0:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4859, parent: target1:0:0
Nov 12 12:46:17 kernel: platform microcode: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: bootsplash bootsplash.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: bootsplash bootsplash.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: alarmtimer alarmtimer.0.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: rtc0
Nov 12 12:46:17 kernel: alarmtimer alarmtimer.0.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: rtc rtc0: PM: calling rtc_suspend+0x0/0x1f0 @ 4926, parent: 00:01
Nov 12 12:46:17 kernel: rtc rtc0: PM: rtc_suspend+0x0/0x1f0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: serial8250 serial8250: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: usb 3-2.1: PM: usb_dev_suspend+0x0/0x20 returned 0 after 23073 usecs
Nov 12 12:46:17 kernel: usb usb6: PM: usb_dev_suspend+0x0/0x20 returned 0 after 25360 usecs
Nov 12 12:46:17 kernel: scsi host0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4827, parent: ata1
Nov 12 12:46:17 kernel: scsi host0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ata1: PM: calling ata_port_pm_suspend+0x0/0x60 @ 4827, parent: 0000:05:00.0
Nov 12 12:46:17 kernel: usb usb2: PM: usb_dev_suspend+0x0/0x20 returned 0 after 25337 usecs
Nov 12 12:46:17 kernel: ata1: PM: ata_port_pm_suspend+0x0/0x60 returned 0 after 57 usecs
Nov 12 12:46:17 kernel: serial8250 serial8250: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: usb 3-2: PM: calling usb_dev_suspend+0x0/0x20 @ 4840, parent: usb3
Nov 12 12:46:17 kernel: input input2: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: LNXPWRBN:00
Nov 12 12:46:17 kernel: usb usb4: PM: usb_dev_suspend+0x0/0x20 returned 0 after 28548 usecs
Nov 12 12:46:17 kernel: input input2: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input1: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: PNP0C0E:00
Nov 12 12:46:17 kernel: input input1: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input0: PM: calling input_dev_suspend+0x0/0x70 @ 4926, parent: PNP0C0C:00
Nov 12 12:46:17 kernel: sd 1:0:0:0: [sda] Synchronizing SCSI cache
Nov 12 12:46:17 kernel: input input0: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: sd 2:0:0:0: [sdb] Synchronizing SCSI cache
Nov 12 12:46:17 kernel: sd 1:0:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 27420 usecs
Nov 12 12:46:17 kernel: pcspkr pcspkr: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: pcspkr pcspkr: PM: platform_pm_suspend+0x0/0x50 returned 0 after 9 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_suspend+0x0/0x170 @ 2460, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: system 00:03: PM: calling pnp_bus_suspend+0x0/0x20 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: system 00:03: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: ite-cir 00:02: PM: calling pnp_bus_suspend+0x0/0x20 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: ite-cir 00:02: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 31 usecs
Nov 12 12:46:17 kernel: rtc_cmos 00:01: PM: calling pnp_bus_suspend+0x0/0x20 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 82 usecs
Nov 12 12:46:17 kernel: rtc_cmos 00:01: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 34 usecs
Nov 12 12:46:17 kernel: system 00:00: PM: calling pnp_bus_suspend+0x0/0x20 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: system 00:00: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform efivars.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform efivars.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform rtc-efi.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform rtc-efi.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: button LNXPWRBN:00: PM: calling acpi_button_suspend+0x0/0x20 @ 4926, parent: LNXSYSTM:00
Nov 12 12:46:17 kernel: button LNXPWRBN:00: PM: acpi_button_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform USBC000:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform USBC000:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_suspend+0x0/0x60 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_suspend+0x0/0x60 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform PNP0103:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform PNP0103:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform INT3515:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: AMDI0010:01
Nov 12 12:46:17 kernel: platform INT3515:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_suspend+0x0/0x60 @ 4926, parent: platform
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0f: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_suspend+0x0/0x60 @ 2460, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:0f: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0e: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:0e: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0d: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:0d: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0c: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 24 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0c: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0b: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:0b: PM: platform_pm_suspend+0x0/0x50 returned 0 after 14 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0a: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:0a: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:09: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:09: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:08: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:08: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform PNP0C0E:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform PNP0C0E:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform PNP0C0C:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform PNP0C0C:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform PNP0C09:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 0000:00:14.3
Nov 12 12:46:17 kernel: platform PNP0C09:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform PNP0800:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: 0000:00:14.3
Nov 12 12:46:17 kernel: platform PNP0800:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: button PNP0C0E:00: PM: calling acpi_button_suspend+0x0/0x20 @ 4926, parent: LNXSYBUS:00
Nov 12 12:46:17 kernel: button PNP0C0E:00: PM: acpi_button_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: button PNP0C0C:00: PM: calling acpi_button_suspend+0x0/0x20 @ 4926, parent: LNXSYBUS:00
Nov 12 12:46:17 kernel: button PNP0C0C:00: PM: acpi_button_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: calling acpi_ec_suspend+0x0/0x70 @ 4926, parent: device:3a
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: acpi_ec_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_suspend+0x0/0x170 @ 4827, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_suspend+0x0/0x170 returned 0 after 3 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_suspend+0x0/0x170 @ 4827, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: calling pci_pm_suspend+0x0/0x170 @ 4880, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: regulator regulator.0: PM: calling regulator_suspend+0x0/0x120 @ 4926, parent: reg-dummy
Nov 12 12:46:17 kernel: regulator regulator.0: PM: regulator_suspend+0x0/0x120 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_suspend+0x0/0x170 @ 4880, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: reg-dummy reg-dummy: PM: calling platform_pm_suspend+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: reg-dummy reg-dummy: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4841, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4841, parent: 0000:00:02.2
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4855, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: calling pci_pm_suspend+0x0/0x170 @ 4875, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4841, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4875, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4872, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4841, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4875, parent: 0000:00:01.2
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_suspend+0x0/0x170 returned 0 after 128 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: calling pci_pm_suspend+0x0/0x170 @ 4872, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: calling pci_pm_suspend+0x0/0x170 @ 4880, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: calling pci_pm_suspend+0x0/0x170 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: calling pci_pm_suspend+0x0/0x170 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4880, parent: pci0000:00
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4872, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4880, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4872, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4833, parent: pci0000:00
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 66 usecs
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4842, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4872, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4875, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4833, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 4 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4842, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4883, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4872, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 4 usecs
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: sd 2:0:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 28880 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1151 usecs
Nov 12 12:46:17 kernel: scsi target1:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 2449, parent: host1
Nov 12 12:46:17 kernel: scsi target2:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4862, parent: host2
Nov 12 12:46:17 kernel: scsi target1:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: scsi target2:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: scsi host1: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4865, parent: ata2
Nov 12 12:46:17 kernel: scsi host2: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4844, parent: ata3
Nov 12 12:46:17 kernel: scsi host1: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 9660 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4873, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 6 usecs
Nov 12 12:46:17 kernel: scsi host2: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ata2: PM: calling ata_port_pm_suspend+0x0/0x60 @ 4846, parent: 0000:05:00.0
Nov 12 12:46:17 kernel: ata3: PM: calling ata_port_pm_suspend+0x0/0x60 @ 4864, parent: 0000:05:00.1
Nov 12 12:46:17 kernel: ata2.00: Entering standby power mode
Nov 12 12:46:17 kernel: ata3.00: Entering standby power mode
Nov 12 12:46:17 kernel: usb 3-2: PM: usb_dev_suspend+0x0/0x20 returned 0 after 35881 usecs
Nov 12 12:46:17 kernel: ata3: PM: ata_port_pm_suspend+0x0/0x60 returned 0 after 23424 usecs
Nov 12 12:46:17 kernel: usb usb3: PM: calling usb_dev_suspend+0x0/0x20 @ 4863, parent: 0000:04:00.3
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: calling pci_pm_suspend+0x0/0x170 @ 2460, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: usb usb3: PM: usb_dev_suspend+0x0/0x20 returned 0 after 10258 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 5 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 122 usecs
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: free PSP TMR buffer
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 363944 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4880, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 7 usecs
Nov 12 12:46:17 kernel: ata2: PM: ata_port_pm_suspend+0x0/0x60 returned 0 after 571330 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4858, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 5 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 7 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 21 usecs
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4875, parent: platform
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 12 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4875, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4875, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4855, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4875, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4858, parent: 0000:00:02.2
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4855, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4875, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4855, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4875, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4858, parent: pci0000:00
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4846, parent: 0000:00:01.2
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: pci0000:00
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4858, parent: pci0000:00
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4875, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4855, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4880, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4836, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4858, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4875, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4855, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4880, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 2460, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_suspend_noirq+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_suspend_noirq+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_suspend_noirq+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_suspend_noirq+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_suspend_noirq+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_suspend_noirq+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_suspend_noirq+0x0/0x50 @ 4880, parent: platform
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_suspend_noirq+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: calling acpi_ec_suspend_noirq+0x0/0x90 @ 4926, parent: device:3a
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4846, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4880, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: ACPI: EC: interrupt blocked
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: acpi_ec_suspend_noirq+0x0/0x90 returned 0 after 8 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4858, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4837, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4855, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4875, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4863, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4844, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4865, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4873, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 157 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4841, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4837, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4862, parent: 0000:00:01.2
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 2449, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 322 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4844, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 338 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4865, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 162 usecs
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4859, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 157 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 2449, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 115 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 98 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4844, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4865, parent: pci0000:00
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4840, parent: 0000:00:02.2
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 348 usecs
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4859, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 378 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 442 usecs
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4872, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4860, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4842, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 944 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4844, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 959 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4865, parent: pci0000:00
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 636 usecs
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 362 usecs
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 330 usecs
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 105 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 93 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 72 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 11930 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 11969 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12226 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12427 usecs
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4864, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 11929 usecs
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12251 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4833, parent: pci0000:00
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12650 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4883, parent: pci0000:00
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 13207 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 13317 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 13315 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 2449, parent: pci0000:00
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 13787 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 21966 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 24381 usecs
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12133 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: calling pci_pm_suspend_noirq+0x0/0x2a0 @ 4827, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12714 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12280 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12000 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 10828 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: pci_pm_suspend_noirq+0x0/0x2a0 returned 0 after 12100 usecs
Nov 12 12:46:17 kernel: ACPI: PM: Preparing to enter system sleep state S3
Nov 12 12:46:17 kernel: ACPI: EC: event blocked
Nov 12 12:46:17 kernel: ACPI: EC: EC stopped
Nov 12 12:46:17 kernel: ACPI: PM: Saving platform NVS memory
Nov 12 12:46:17 kernel: Disabling non-boot CPUs ...
Nov 12 12:46:17 kernel: smpboot: CPU 1 is now offline
Nov 12 12:46:17 kernel: smpboot: CPU 2 is now offline
Nov 12 12:46:17 kernel: smpboot: CPU 3 is now offline
Nov 12 12:46:17 kernel: smpboot: CPU 4 is now offline
Nov 12 12:46:17 kernel: smpboot: CPU 5 is now offline
Nov 12 12:46:17 kernel: smpboot: CPU 6 is now offline
Nov 12 12:46:17 kernel: smpboot: CPU 7 is now offline
Nov 12 12:46:17 kernel: ACPI: PM: Low-level resume complete
Nov 12 12:46:17 kernel: ACPI: EC: EC started
Nov 12 12:46:17 kernel: ACPI: PM: Restoring platform NVS memory
Nov 12 12:46:17 kernel: AMD-Vi: Virtual APIC enabled
Nov 12 12:46:17 kernel: LVT offset 0 assigned for vector 0x400
Nov 12 12:46:17 kernel: Enabling non-boot CPUs ...
Nov 12 12:46:17 kernel: x86: Booting SMP configuration:
Nov 12 12:46:17 kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Nov 12 12:46:17 kernel: microcode: CPU1: patch_level=0x08600106
Nov 12 12:46:17 kernel: ACPI: \_SB_.PLTF.P001: Found 3 idle states
Nov 12 12:46:17 kernel: ACPI: FW issue: working around C-state latencies out of order
Nov 12 12:46:17 kernel: CPU1 is up
Nov 12 12:46:17 kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
Nov 12 12:46:17 kernel: microcode: CPU2: patch_level=0x08600106
Nov 12 12:46:17 kernel: ACPI: \_SB_.PLTF.P002: Found 3 idle states
Nov 12 12:46:17 kernel: CPU2 is up
Nov 12 12:46:17 kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Nov 12 12:46:17 kernel: microcode: CPU3: patch_level=0x08600106
Nov 12 12:46:17 kernel: ACPI: \_SB_.PLTF.P003: Found 3 idle states
Nov 12 12:46:17 kernel: CPU3 is up
Nov 12 12:46:17 kernel: smpboot: Booting Node 0 Processor 4 APIC 0x4
Nov 12 12:46:17 kernel: microcode: CPU4: patch_level=0x08600106
Nov 12 12:46:17 kernel: ACPI: \_SB_.PLTF.P004: Found 3 idle states
Nov 12 12:46:17 kernel: CPU4 is up
Nov 12 12:46:17 kernel: smpboot: Booting Node 0 Processor 5 APIC 0x5
Nov 12 12:46:17 kernel: microcode: CPU5: patch_level=0x08600106
Nov 12 12:46:17 kernel: ACPI: \_SB_.PLTF.P005: Found 3 idle states
Nov 12 12:46:17 kernel: CPU5 is up
Nov 12 12:46:17 kernel: smpboot: Booting Node 0 Processor 6 APIC 0x6
Nov 12 12:46:17 kernel: microcode: CPU6: patch_level=0x08600106
Nov 12 12:46:17 kernel: ACPI: \_SB_.PLTF.P006: Found 3 idle states
Nov 12 12:46:17 kernel: CPU6 is up
Nov 12 12:46:17 kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Nov 12 12:46:17 kernel: microcode: CPU7: patch_level=0x08600106
Nov 12 12:46:17 kernel: ACPI: \_SB_.PLTF.P007: Found 3 idle states
Nov 12 12:46:17 kernel: CPU7 is up
Nov 12 12:46:17 kernel: ACPI: PM: Waking up from system sleep state S3
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: calling acpi_ec_resume_noirq+0x0/0x90 @ 4926, parent: device:3a
Nov 12 12:46:17 kernel: ACPI: EC: interrupt unblocked
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: acpi_ec_resume_noirq+0x0/0x90 returned 0 after 4 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 31 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 39 usecs
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 28 usecs
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 15 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 66 usecs
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 39 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 105 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 99 usecs
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 56 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 59 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 62 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 109 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: pci0000:00
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_resume_noirq+0x0/0x30 @ 4926, parent: platform
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 8 usecs
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_resume_noirq+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 7 usecs
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 8 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 7 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 7 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 6 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 9 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: 0000:00:01.2
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 7 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 197 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 212 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 271 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 173 usecs
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: 0000:00:02.2
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 1089 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 1113 usecs
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 122 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 218 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 1290 usecs
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 84 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 90 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4834, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 50 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4827, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4866, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 2449, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_resume_noirq+0x0/0x30 @ 4883, parent: platform
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_resume_noirq+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_resume_noirq+0x0/0x130 @ 4883, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_resume_noirq+0x0/0x30 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_resume_noirq+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_resume_noirq+0x0/0x30 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_resume_noirq+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 201 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 225 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 804 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 824 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_resume_noirq+0x0/0x130 returned 0 after 2169 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: calling pci_pm_resume_early+0x0/0x30 @ 2460, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4863, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: calling pci_pm_resume_early+0x0/0x30 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: calling pci_pm_resume_early+0x0/0x30 @ 2460, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: calling pci_pm_resume_early+0x0/0x30 @ 4863, parent: pci0000:00
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: calling pci_pm_resume_early+0x0/0x30 @ 4836, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: calling pci_pm_resume_early+0x0/0x30 @ 4837, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: calling pci_pm_resume_early+0x0/0x30 @ 4840, parent: pci0000:00
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: calling pci_pm_resume_early+0x0/0x30 @ 2460, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: calling pci_pm_resume_early+0x0/0x30 @ 4880, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: 0000:00:01.2
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: calling pci_pm_resume_early+0x0/0x30 @ 4836, parent: pci0000:00
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_resume_early+0x0/0x80 @ 4926, parent: platform
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4840, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: calling pci_pm_resume_early+0x0/0x30 @ 4846, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: calling pci_pm_resume_early+0x0/0x30 @ 4880, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: calling pci_pm_resume_early+0x0/0x30 @ 4836, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: calling pci_pm_resume_early+0x0/0x30 @ 2460, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_resume_early+0x0/0x80 returned 0 after 9 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: 0000:00:02.2
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: calling pci_pm_resume_early+0x0/0x30 @ 4837, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_resume_early+0x0/0x30 @ 4833, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: calling pci_pm_resume_early+0x0/0x30 @ 4880, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_resume_early+0x0/0x30 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: calling pci_pm_resume_early+0x0/0x30 @ 4846, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_resume_early+0x0/0x30 @ 2460, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: calling pci_pm_resume_early+0x0/0x30 @ 4834, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_resume_early+0x0/0x30 @ 4833, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_resume_early+0x0/0x80 @ 4840, parent: platform
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: calling pci_pm_resume_early+0x0/0x30 @ 4863, parent: pci0000:00
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_resume_early+0x0/0x80 returned 0 after 12 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: pci_pm_resume_early+0x0/0x30 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_resume_early+0x0/0x80 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_resume_early+0x0/0x80 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_resume_early+0x0/0x80 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_resume_early+0x0/0x80 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4840, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4858, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: calling pci_pm_resume+0x0/0xf0 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: calling pci_pm_resume+0x0/0xf0 @ 4875, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4883, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:01.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:00.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:02.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: calling pci_pm_resume+0x0/0xf0 @ 4858, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: calling pci_pm_resume+0x0/0xf0 @ 2449, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:01.2: PM: pci_pm_resume+0x0/0xf0 returned 0 after 18 usecs
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4833, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: calling pci_pm_resume+0x0/0xf0 @ 4840, parent: pci0000:00
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: calling pci_pm_resume+0x0/0xf0 @ 4883, parent: pci0000:00
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:08.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: reg-dummy reg-dummy: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: piix4_smbus 0000:00:14.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: calling pci_pm_resume+0x0/0xf0 @ 4833, parent: pci0000:00
Nov 12 12:46:17 kernel: reg-dummy reg-dummy: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:14.3: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4865, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: calling pci_pm_resume+0x0/0xf0 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: calling pci_pm_resume+0x0/0xf0 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: calling pci_pm_resume+0x0/0xf0 @ 4833, parent: pci0000:00
Nov 12 12:46:17 kernel: regulator regulator.0: PM: calling regulator_resume+0x0/0x190 @ 4926, parent: reg-dummy
Nov 12 12:46:17 kernel: pci 0000:00:18.2: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: k10temp 0000:00:18.3: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: calling pci_pm_resume+0x0/0xf0 @ 4864, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.1: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: calling pci_pm_resume+0x0/0xf0 @ 4846, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: calling pci_pm_resume+0x0/0xf0 @ 4866, parent: pci0000:00
Nov 12 12:46:17 kernel: regulator regulator.0: PM: regulator_resume+0x0/0x190 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: calling pci_pm_resume+0x0/0xf0 @ 4833, parent: pci0000:00
Nov 12 12:46:17 kernel: pci 0000:00:18.4: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.5: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4855, parent: 0000:00:01.2
Nov 12 12:46:17 kernel: pci 0000:00:18.7: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:00:18.6: PM: pci_pm_resume+0x0/0xf0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: calling acpi_ec_resume+0x0/0x20 @ 4926, parent: device:3a
Nov 12 12:46:17 kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Nov 12 12:46:17 kernel: ACPI: EC: event unblocked
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PCI INT A: no GSI
Nov 12 12:46:17 kernel: ec PNP0C09:00: PM: acpi_ec_resume+0x0/0x20 returned 0 after 15 usecs
Nov 12 12:46:17 kernel: button PNP0C0C:00: PM: calling acpi_button_resume+0x0/0x110 @ 4926, parent: LNXSYBUS:00
Nov 12 12:46:17 kernel: pci 0000:00:00.2: PM: pci_pm_resume+0x0/0xf0 returned 0 after 132 usecs
Nov 12 12:46:17 kernel: button PNP0C0C:00: PM: acpi_button_resume+0x0/0x110 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: button PNP0C0E:00: PM: calling acpi_button_resume+0x0/0x110 @ 4926, parent: LNXSYBUS:00
Nov 12 12:46:17 kernel: pcieport 0000:00:02.2: PM: pci_pm_resume+0x0/0xf0 returned 0 after 146 usecs
Nov 12 12:46:17 kernel: button PNP0C0E:00: PM: acpi_button_resume+0x0/0x110 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_resume+0x0/0x80 @ 4862, parent: platform
Nov 12 12:46:17 kernel: pcieport 0000:00:08.2: PM: pci_pm_resume+0x0/0xf0 returned 0 after 164 usecs
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4841, parent: 0000:00:02.2
Nov 12 12:46:17 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_resume+0x0/0x80 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform PNP0800:00: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 0000:00:14.3
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: calling pci_pm_resume+0x0/0xf0 @ 4875, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4880, parent: 0000:00:08.2
Nov 12 12:46:17 kernel: platform PNP0800:00: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform PNP0C09:00: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 0000:00:14.3
Nov 12 12:46:17 kernel: ahci 0000:05:00.1: PM: pci_pm_resume+0x0/0xf0 returned 0 after 21 usecs
Nov 12 12:46:17 kernel: ahci 0000:05:00.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 23 usecs
Nov 12 12:46:17 kernel: platform PNP0C09:00: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pcieport 0000:00:02.1: PM: pci_pm_resume+0x0/0xf0 returned 0 after 410 usecs
Nov 12 12:46:17 kernel: platform PNP0C0C:00: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: ata3: PM: calling ata_port_pm_resume+0x0/0x60 @ 4859, parent: 0000:05:00.1
Nov 12 12:46:17 kernel: pcieport 0000:00:08.1: PM: pci_pm_resume+0x0/0xf0 returned 0 after 419 usecs
Nov 12 12:46:17 kernel: ata2: PM: calling ata_port_pm_resume+0x0/0x60 @ 4862, parent: 0000:05:00.0
Nov 12 12:46:17 kernel: platform PNP0C0C:00: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ata3: PM: ata_port_pm_resume+0x0/0x60 returned 0 after 6 usecs
Nov 12 12:46:17 kernel: ata1: PM: calling ata_port_pm_resume+0x0/0x60 @ 4860, parent: 0000:05:00.0
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4865, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: ata2: PM: ata_port_pm_resume+0x0/0x60 returned 0 after 9 usecs
Nov 12 12:46:17 kernel: platform PNP0C0E:00: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: scsi host2: PM: calling scsi_bus_resume+0x0/0x90 @ 4831, parent: ata3
Nov 12 12:46:17 kernel: ata1: PM: ata_port_pm_resume+0x0/0x60 returned 0 after 6 usecs
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: calling pci_pm_resume+0x0/0xf0 @ 4873, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: platform PNP0C0E:00: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_resume+0x0/0xf0 @ 2460, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: scsi host2: PM: scsi_bus_resume+0x0/0x90 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:04:00.5: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:08: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: calling pci_pm_resume+0x0/0xf0 @ 4834, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: platform ACPI0007:08: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: scsi host0: PM: calling scsi_bus_resume+0x0/0x90 @ 4842, parent: ata1
Nov 12 12:46:17 kernel: platform ACPI0007:09: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: ccp 0000:04:00.2: PM: pci_pm_resume+0x0/0xf0 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: scsi host0: PM: scsi_bus_resume+0x0/0x90 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:09: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_resume+0x0/0xf0 @ 4827, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: platform ACPI0007:0a: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: scsi target2:0:0: PM: calling scsi_bus_resume+0x0/0x90 @ 4875, parent: host2
Nov 12 12:46:17 kernel: platform ACPI0007:0a: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 393 usecs
Nov 12 12:46:17 kernel: scsi target2:0:0: PM: scsi_bus_resume+0x0/0x90 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0b: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: sd 2:0:0:0: PM: calling scsi_bus_resume+0x0/0x90 @ 4839, parent: target2:0:0
Nov 12 12:46:17 kernel: sd 2:0:0:0: PM: scsi_bus_resume+0x0/0x90 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: scsi host1: PM: calling scsi_bus_resume+0x0/0x90 @ 4872, parent: ata2
Nov 12 12:46:17 kernel: scsi host1: PM: scsi_bus_resume+0x0/0x90 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0b: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0c: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: calling pci_pm_resume+0x0/0xf0 @ 4864, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: calling pci_pm_resume+0x0/0xf0 @ 4846, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_resume+0x0/0xf0 @ 4837, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_resume+0x0/0xf0 @ 4863, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: platform ACPI0007:0c: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: serial 0000:02:00.2: PM: pci_pm_resume+0x0/0xf0 returned 0 after 9 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0d: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: serial 0000:02:00.1: PM: pci_pm_resume+0x0/0xf0 returned 0 after 8 usecs
Nov 12 12:46:17 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_resume+0x0/0xf0 returned 0 after 3 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: calling pci_pm_resume+0x0/0xf0 @ 4833, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: platform ACPI0007:0d: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: calling pci_pm_resume+0x0/0xf0 @ 4866, parent: 0000:00:02.1
Nov 12 12:46:17 kernel: pci 0000:02:00.3: PM: pci_pm_resume+0x0/0xf0 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0e: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_resume+0x0/0xf0 @ 4836, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: pci 0000:02:00.4: PM: pci_pm_resume+0x0/0xf0 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0e: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform ACPI0007:0f: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform ACPI0007:0f: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_resume+0x0/0x80 @ 4926, parent: platform
Nov 12 12:46:17 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_resume+0x0/0x80 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: platform INT3515:00: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: AMDI0010:01
Nov 12 12:46:17 kernel: platform INT3515:00: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform PNP0103:00: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform PNP0103:00: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_resume+0x0/0x80 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_resume+0x0/0x80 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_resume+0x0/0x80 @ 4926, parent: platform
Nov 12 12:46:17 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_resume+0x0/0x80 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: platform USBC000:00: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform USBC000:00: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: button LNXPWRBN:00: PM: calling acpi_button_resume+0x0/0x110 @ 4926, parent: LNXSYSTM:00
Nov 12 12:46:17 kernel: ieee80211 phy0: PM: calling wiphy_resume+0x0/0x1b0 [cfg80211] @ 4885, parent: 0000:03:00.0
Nov 12 12:46:17 kernel: button LNXPWRBN:00: PM: acpi_button_resume+0x0/0x110 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform rtc-efi.0: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform rtc-efi.0: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform efivars.0: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform efivars.0: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: system 00:00: PM: calling pnp_bus_resume+0x0/0xa0 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: system 00:00: PM: pnp_bus_resume+0x0/0xa0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: rtc_cmos 00:01: PM: calling pnp_bus_resume+0x0/0xa0 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: rtc_cmos 00:01: PM: pnp_bus_resume+0x0/0xa0 returned 0 after 6 usecs
Nov 12 12:46:17 kernel: ite-cir 00:02: PM: calling pnp_bus_resume+0x0/0xa0 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: [drm] PCIE GART of 1024M enabled.
Nov 12 12:46:17 kernel: [drm] PTB located at 0x000000F41FC00000
Nov 12 12:46:17 kernel: [drm] PSP is resuming...
Nov 12 12:46:17 kernel: scsi target1:0:0: PM: calling scsi_bus_resume+0x0/0x90 @ 4835, parent: host1
Nov 12 12:46:17 kernel: scsi target1:0:0: PM: scsi_bus_resume+0x0/0x90 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: sd 1:0:0:0: PM: calling scsi_bus_resume+0x0/0x90 @ 4880, parent: target1:0:0
Nov 12 12:46:17 kernel: ite-cir 00:02: PM: pnp_bus_resume+0x0/0xa0 returned 0 after 89 usecs
Nov 12 12:46:17 kernel: sd 1:0:0:0: PM: scsi_bus_resume+0x0/0x90 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: system 00:03: PM: calling pnp_bus_resume+0x0/0xa0 @ 4926, parent: pnp0
Nov 12 12:46:17 kernel: system 00:03: PM: pnp_bus_resume+0x0/0xa0 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: pcspkr pcspkr: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: pcspkr pcspkr: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input0: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: PNP0C0C:00
Nov 12 12:46:17 kernel: input input0: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input1: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: PNP0C0E:00
Nov 12 12:46:17 kernel: input input1: PM: input_dev_resume+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: input input2: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: LNXPWRBN:00
Nov 12 12:46:17 kernel: input input2: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: serial8250 serial8250: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: serial8250 serial8250: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: rtc rtc0: PM: calling rtc_resume+0x0/0x240 @ 4926, parent: 00:01
Nov 12 12:46:17 kernel: rtc rtc0: PM: rtc_resume+0x0/0x240 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: alarmtimer alarmtimer.0.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: rtc0
Nov 12 12:46:17 kernel: alarmtimer alarmtimer.0.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: bootsplash bootsplash.0: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: bootsplash bootsplash.0: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform microcode: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform microcode: PM: platform_pm_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: input input3: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: LNXVIDEO:00
Nov 12 12:46:17 kernel: input input3: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_resume+0x0/0xf0 returned 0 after 4417 usecs
Nov 12 12:46:17 kernel: snd_hda_codec_realtek hdaudioC1D0: PM: calling hda_codec_pm_resume+0x0/0x20 [snd_hda_codec] @ 4887, parent: 0000:04:00.6
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: xHC error in resume, USBSTS 0x401, Reinit
Nov 12 12:46:17 kernel: usb usb1: root hub lost power or was reset
Nov 12 12:46:17 kernel: usb usb2: root hub lost power or was reset
Nov 12 12:46:17 kernel: [drm] reserve 0x400000 from 0xf41f800000 for PSP TMR
Nov 12 12:46:17 kernel: snd_hda_codec_realtek hdaudioC1D0: PM: hda_codec_pm_resume+0x0/0x20 [snd_hda_codec] returned 0 after 42123 usecs
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: dpm has been disabled
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
Nov 12 12:46:17 kernel: [drm] DMUB hardware initialized: version=0x01010027
Nov 12 12:46:17 kernel: r8169 0000:02:00.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 118512 usecs
Nov 12 12:46:17 kernel: r8169 0000:02:00.0 enp2s0f0: Link is Down
Nov 12 12:46:17 kernel: [drm] DP Alt mode state on HPD: 1
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_resume+0x0/0xf0 returned 0 after 125004 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_resume+0x0/0xf0 returned 0 after 125153 usecs
Nov 12 12:46:17 kernel: usb usb5: PM: calling usb_dev_resume+0x0/0x20 @ 4872, parent: 0000:04:00.4
Nov 12 12:46:17 kernel: usb usb4: PM: calling usb_dev_resume+0x0/0x20 @ 4841, parent: 0000:04:00.3
Nov 12 12:46:17 kernel: usb usb6: PM: calling usb_dev_resume+0x0/0x20 @ 4850, parent: 0000:04:00.4
Nov 12 12:46:17 kernel: usb usb3: PM: calling usb_dev_resume+0x0/0x20 @ 4867, parent: 0000:04:00.3
Nov 12 12:46:17 kernel: usb usb4: PM: usb_dev_resume+0x0/0x20 returned 0 after 26624 usecs
Nov 12 12:46:17 kernel: usb usb6: PM: usb_dev_resume+0x0/0x20 returned 0 after 26598 usecs
Nov 12 12:46:17 kernel: usb usb3: PM: usb_dev_resume+0x0/0x20 returned 0 after 58000 usecs
Nov 12 12:46:17 kernel: usb 3-4: PM: calling usb_dev_resume+0x0/0x20 @ 4871, parent: usb3
Nov 12 12:46:17 kernel: usb usb5: PM: usb_dev_resume+0x0/0x20 returned 0 after 58082 usecs
Nov 12 12:46:17 kernel: usb 3-1: PM: calling usb_dev_resume+0x0/0x20 @ 4833, parent: usb3
Nov 12 12:46:17 kernel: usb 5-3: PM: calling usb_dev_resume+0x0/0x20 @ 4888, parent: usb5
Nov 12 12:46:17 kernel: usb 3-2: PM: calling usb_dev_resume+0x0/0x20 @ 4866, parent: usb3
Nov 12 12:46:17 kernel: usb 5-2: PM: calling usb_dev_resume+0x0/0x20 @ 2478, parent: usb5
Nov 12 12:46:17 kernel: usb 3-4: PM: usb_dev_resume+0x0/0x20 returned 0 after 15444 usecs
Nov 12 12:46:17 kernel: rtsx_usb_sdmmc rtsx_usb_sdmmc.1.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 3-4:1.0
Nov 12 12:46:17 kernel: rtsx_usb_sdmmc rtsx_usb_sdmmc.1.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: rtsx_usb_ms rtsx_usb_ms.2.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 3-4:1.0
Nov 12 12:46:17 kernel: rtsx_usb_ms rtsx_usb_ms.2.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: usb 5-2: PM: usb_dev_resume+0x0/0x20 returned 0 after 16059 usecs
Nov 12 12:46:17 kernel: input input4: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: 0003:046D:C077.0001
Nov 12 12:46:17 kernel: input input4: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: usb 3-1: PM: usb_dev_resume+0x0/0x20 returned 0 after 16942 usecs
Nov 12 12:46:17 kernel: usb 5-3: PM: usb_dev_resume+0x0/0x20 returned 0 after 18091 usecs
Nov 12 12:46:17 kernel: xhci_hcd 0000:01:00.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 205353 usecs
Nov 12 12:46:17 kernel: usb usb2: PM: calling usb_dev_resume+0x0/0x20 @ 4883, parent: 0000:01:00.0
Nov 12 12:46:17 kernel: usb usb1: PM: calling usb_dev_resume+0x0/0x20 @ 4869, parent: 0000:01:00.0
Nov 12 12:46:17 kernel: usb usb1: PM: usb_dev_resume+0x0/0x20 returned 0 after 26559 usecs
Nov 12 12:46:17 kernel: ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
Nov 12 12:46:17 kernel: ieee80211 phy0: PM: wiphy_resume+0x0/0x1b0 [cfg80211] returned 0 after 278812 usecs
Nov 12 12:46:17 kernel: usb 3-2: PM: usb_dev_resume+0x0/0x20 returned 0 after 118945 usecs
Nov 12 12:46:17 kernel: usb 3-2.1: PM: calling usb_dev_resume+0x0/0x20 @ 4856, parent: 3-2
Nov 12 12:46:17 kernel: usb usb2: PM: usb_dev_resume+0x0/0x20 returned 0 after 106877 usecs
Nov 12 12:46:17 kernel: usb 3-2.1: PM: usb_dev_resume+0x0/0x20 returned 0 after 69967 usecs
Nov 12 12:46:17 kernel: input input5: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: 0003:413C:2010.0002
Nov 12 12:46:17 kernel: input input5: PM: input_dev_resume+0x0/0x40 returned 0 after 35 usecs
Nov 12 12:46:17 kernel: leds mmc0::: PM: calling led_resume+0x0/0x50 @ 4926, parent: rtsx_usb_sdmmc.1.auto
Nov 12 12:46:17 kernel: leds mmc0::: PM: led_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::numlock: PM: calling led_resume+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::numlock: PM: led_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: leds input5::capslock: PM: calling led_resume+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::capslock: PM: led_resume+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:46:17 kernel: leds input5::scrolllock: PM: calling led_resume+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::scrolllock: PM: led_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::compose: PM: calling led_resume+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::compose: PM: led_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds input5::kana: PM: calling led_resume+0x0/0x50 @ 4926, parent: input5
Nov 12 12:46:17 kernel: leds input5::kana: PM: led_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input6: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: 0003:413C:2010.0003
Nov 12 12:46:17 kernel: input input6: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input7: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: 0003:413C:2010.0003
Nov 12 12:46:17 kernel: input input7: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: vboxdrv vboxdrv.0: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: vboxdrv vboxdrv.0: PM: platform_pm_resume+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: input input8: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: rc0
Nov 12 12:46:17 kernel: input input8: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input9: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: pcspkr
Nov 12 12:46:17 kernel: input input9: PM: input_dev_resume+0x0/0x40 returned 0 after 18 usecs
Nov 12 12:46:17 kernel: sp5100-tco sp5100-tco: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: sp5100-tco sp5100-tco: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: platform regulatory.0: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: platform regulatory.0: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: hid_sensor_accel_3d HID-SENSOR-200073.3.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 0020:1022:0001.0004
Nov 12 12:46:17 kernel: hid_sensor_accel_3d HID-SENSOR-200073.3.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: hid_sensor_gyro_3d HID-SENSOR-200076.4.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 0020:1022:0001.0005
Nov 12 12:46:17 kernel: hid_sensor_gyro_3d HID-SENSOR-200076.4.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: hid_sensor_magn_3d HID-SENSOR-200083.5.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 0020:1022:0001.0006
Nov 12 12:46:17 kernel: hid_sensor_magn_3d HID-SENSOR-200083.5.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: hid_sensor_als HID-SENSOR-200041.6.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 0020:1022:0001.0007
Nov 12 12:46:17 kernel: hid_sensor_als HID-SENSOR-200041.6.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: hid_sensor_prox HID-SENSOR-200011.7.auto: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: 0020:1022:0001.0008
Nov 12 12:46:17 kernel: hid_sensor_prox HID-SENSOR-200011.7.auto: PM: platform_pm_resume+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:46:17 kernel: eeepc-wmi eeepc-wmi: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: eeepc-wmi eeepc-wmi: PM: platform_pm_resume+0x0/0x50 returned 0 after 214 usecs
Nov 12 12:46:17 kernel: input input10: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: eeepc-wmi
Nov 12 12:46:17 kernel: input input10: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: Generic FE-GE Realtek PHY r8169-0-200:00: PM: calling mdio_bus_phy_resume+0x0/0x130 [libphy] @ 4926, parent: r8169-0-200
Nov 12 12:46:17 kernel: Generic FE-GE Realtek PHY r8169-0-200:00: PM: mdio_bus_phy_resume+0x0/0x130 [libphy] returned 0 after 1 usecs
Nov 12 12:46:17 kernel: [drm] kiq ring mec 2 pipe 1 q 0
Nov 12 12:46:17 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Nov 12 12:46:17 kernel: [drm] JPEG decode initialized successfully.
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Nov 12 12:46:17 kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 12 12:46:17 kernel: ata2.00: Entering active power mode
Nov 12 12:46:17 kernel: ata2.00: supports DRM functions and may not be fully accessible
Nov 12 12:46:17 kernel: ata2.00: configured for UDMA/133
Nov 12 12:46:17 kernel: amdgpu 0000:04:00.0: PM: pci_pm_resume+0x0/0xf0 returned 0 after 486935 usecs
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_resume+0x0/0xf0 @ 4844, parent: 0000:00:08.1
Nov 12 12:46:17 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_resume+0x0/0xf0 returned 0 after 2311 usecs
Nov 12 12:46:17 kernel: input input11: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input11: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: ata2.00: Enabling discard_zeroes_data
Nov 12 12:46:17 kernel: input input12: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input12: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input13: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input13: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input14: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: card0
Nov 12 12:46:17 kernel: input input14: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: snd-soc-dummy snd-soc-dummy: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: snd-soc-dummy snd-soc-dummy: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input15: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: card1
Nov 12 12:46:17 kernel: input input15: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: input input16: PM: calling input_dev_resume+0x0/0x40 @ 4926, parent: card1
Nov 12 12:46:17 kernel: input input16: PM: input_dev_resume+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: intel_rapl_msr intel_rapl_msr.0: PM: calling platform_pm_resume+0x0/0x50 @ 4926, parent: platform
Nov 12 12:46:17 kernel: intel_rapl_msr intel_rapl_msr.0: PM: platform_pm_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: leds phy0-led: PM: calling led_resume+0x0/0x50 @ 4926, parent: 0000:03:00.0
Nov 12 12:46:17 kernel: leds phy0-led: PM: led_resume+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:46:17 kernel: rfkill rfkill0: PM: calling rfkill_resume+0x0/0x80 [rfkill] @ 4926, parent: phy0
Nov 12 12:46:17 kernel: rfkill rfkill0: PM: rfkill_resume+0x0/0x80 [rfkill] returned 0 after 6 usecs
Nov 12 12:46:17 kernel: rfkill rfkill2: PM: calling rfkill_resume+0x0/0x80 [rfkill] @ 4926, parent: hci0
Nov 12 12:46:17 kernel: rfkill rfkill2: PM: rfkill_resume+0x0/0x80 [rfkill] returned 0 after 4 usecs
Nov 12 12:46:17 kernel: OOM killer enabled.
Nov 12 12:46:17 kernel: Restarting tasks ... done.
Nov 12 12:46:17 kernel: random: crng reseeded on system resumption
Nov 12 12:46:17 kernel: PM: suspend exit
Nov 12 12:46:17 kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 12 12:46:17 kernel: ata3.00: Entering active power mode
Nov 12 12:46:17 kernel: ata3.00: supports DRM functions and may not be fully accessible
Nov 12 12:46:17 kernel: ata3.00: configured for UDMA/133
Nov 12 12:46:17 kernel: ata3.00: Enabling discard_zeroes_data
Nov 12 12:46:17 kernel: PM: suspend entry (deep)
This is the output from an unsuccessful cycle:
Nov 12 12:46:49 kernel: PM: suspend entry (deep)
Nov 12 12:46:49 kernel: Filesystems sync: 0.079 seconds
Nov 12 12:46:49 wpa_supplicant[1078]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Nov 12 12:46:49 NetworkManager[1048]: <warn> [1699822009.5873] device (wlp3s0): link timed out.
Nov 12 12:46:49 dunst[1580]: WARNING: No icon found in path: 'nm-no-connection'
Nov 12 12:46:49 dunst[1580]: CRITICAL: Source ID 32 was not found when attempting to remove it
Nov 12 12:46:49 avahi-daemon[1019]: Interface wlp3s0.IPv6 no longer relevant for mDNS.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.5874] device (wlp3s0): state change: activated -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Nov 12 12:46:49 avahi-daemon[1019]: Leaving mDNS multicast group on interface wlp3s0.IPv6 with address 2604:3d08:467e:0:1bc3:b026:439d:636a.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.5879] manager: NetworkManager state is now DISCONNECTED
Nov 12 12:46:49 avahi-daemon[1019]: Interface wlp3s0.IPv4 no longer relevant for mDNS.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6423] device (wlp3s0): set-hw-addr: set MAC address to 9E:22:81:77:D2:79 (scanning)
Nov 12 12:46:49 avahi-daemon[1019]: Leaving mDNS multicast group on interface wlp3s0.IPv4 with address 10.0.0.198.
Nov 12 12:46:49 NetworkManager[1048]: <warn> [1699822009.6470] device (wlp3s0): Activation: failed for connection 'SHAW-EFD1'
Nov 12 12:46:49 avahi-daemon[1019]: Withdrawing address record for 2604:3d08:467e::7c43 on wlp3s0.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6487] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 12 12:46:49 avahi-daemon[1019]: Withdrawing address record for 2604:3d08:467e:0:1bc3:b026:439d:636a on wlp3s0.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6490] dhcp4 (wlp3s0): canceled DHCP transaction
Nov 12 12:46:49 avahi-daemon[1019]: Withdrawing address record for 10.0.0.198 on wlp3s0.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6491] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Nov 12 12:46:49 avahi-daemon[1019]: Joining mDNS multicast group on interface wlp3s0.IPv4 with address 10.0.0.198.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6491] dhcp4 (wlp3s0): state changed no lease
Nov 12 12:46:49 avahi-daemon[1019]: New relevant interface wlp3s0.IPv4 for mDNS.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6492] dhcp6 (wlp3s0): canceled DHCP transaction
Nov 12 12:46:49 avahi-daemon[1019]: Registering new address record for 10.0.0.198 on wlp3s0.IPv4.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6492] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Nov 12 12:46:49 avahi-daemon[1019]: Joining mDNS multicast group on interface wlp3s0.IPv6 with address fe80::bde9:11d1:3d10:b100.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.6493] dhcp6 (wlp3s0): state changed no lease
Nov 12 12:46:49 avahi-daemon[1019]: New relevant interface wlp3s0.IPv6 for mDNS.
Nov 12 12:46:49 systemd[1]: Starting Network Manager Script Dispatcher Service...
Nov 12 12:46:49 avahi-daemon[1019]: Registering new address record for fe80::bde9:11d1:3d10:b100 on wlp3s0.*.
Nov 12 12:46:49 systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 12 12:46:49 avahi-daemon[1019]: Leaving mDNS multicast group on interface wlp3s0.IPv6 with address fe80::bde9:11d1:3d10:b100.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.7277] device (wlp3s0): supplicant interface state: scanning -> disconnected
Nov 12 12:46:49 avahi-daemon[1019]: Joining mDNS multicast group on interface wlp3s0.IPv6 with address 2604:3d08:467e:0:1bc3:b026:439d:636a.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.7277] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> disconnected
Nov 12 12:46:49 avahi-daemon[1019]: Registering new address record for 2604:3d08:467e:0:1bc3:b026:439d:636a on wlp3s0.*.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.7278] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 12 12:46:49 avahi-daemon[1019]: Withdrawing address record for fe80::bde9:11d1:3d10:b100 on wlp3s0.
Nov 12 12:46:49 NetworkManager[1048]: <info> [1699822009.7279] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> inactive
Nov 12 12:46:49 avahi-daemon[1019]: Registering new address record for 2604:3d08:467e::7c43 on wlp3s0.*.
Nov 12 12:46:49 dbus-daemon[1020]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=1048 comm="/usr/bin/NetworkManager --no-daemon")
Nov 12 12:46:49 dbus-daemon[1020]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 12 12:47:21 kernel: Freezing user space processes
Nov 12 12:47:21 kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Nov 12 12:47:21 kernel: OOM killer disabled.
Nov 12 12:47:21 kernel: Freezing remaining freezable tasks
Nov 12 12:47:21 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Nov 12 12:47:21 kernel: rfkill rfkill2: PM: calling rfkill_suspend+0x0/0x20 [rfkill] @ 4973, parent: hci0
Nov 12 12:47:21 kernel: rfkill rfkill2: PM: rfkill_suspend+0x0/0x20 [rfkill] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: rfkill rfkill0: PM: calling rfkill_suspend+0x0/0x20 [rfkill] @ 4973, parent: phy0
Nov 12 12:47:21 kernel: usb 5-3: PM: calling usb_dev_suspend+0x0/0x20 @ 4839, parent: usb5
Nov 12 12:47:21 kernel: rfkill rfkill0: PM: rfkill_suspend+0x0/0x20 [rfkill] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: usb 5-3: PM: usb_dev_suspend+0x0/0x20 returned 0 after 51 usecs
Nov 12 12:47:21 kernel: leds phy0-led: PM: calling led_suspend+0x0/0x50 @ 4973, parent: 0000:03:00.0
Nov 12 12:47:21 kernel: ieee80211 phy0: PM: calling wiphy_suspend+0x0/0x2c0 [cfg80211] @ 2449, parent: 0000:03:00.0
Nov 12 12:47:21 kernel: leds phy0-led: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: intel_rapl_msr intel_rapl_msr.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: queueing ieee80211 work while going to suspend
Nov 12 12:47:21 kernel: intel_rapl_msr intel_rapl_msr.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input16: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: card1
Nov 12 12:47:21 kernel: input input16: PM: input_dev_suspend+0x0/0x70 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: input input15: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: card1
Nov 12 12:47:21 kernel: input input15: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: sound pcmC1D0c: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4973, parent: card1
Nov 12 12:47:21 kernel: sound pcmC1D0c: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: sound pcmC1D0p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4973, parent: card1
Nov 12 12:47:21 kernel: sound pcmC1D0p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: snd-soc-dummy snd-soc-dummy: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: snd-soc-dummy snd-soc-dummy: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: input input14: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: card0
Nov 12 12:47:21 kernel: input input14: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input13: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: card0
Nov 12 12:47:21 kernel: input input13: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input12: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: card0
Nov 12 12:47:21 kernel: input input12: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input11: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: card0
Nov 12 12:47:21 kernel: input input11: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: sound pcmC0D9p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4973, parent: card0
Nov 12 12:47:21 kernel: sound pcmC0D9p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: sound pcmC0D8p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4973, parent: card0
Nov 12 12:47:21 kernel: sound pcmC0D8p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: sound pcmC0D7p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4973, parent: card0
Nov 12 12:47:21 kernel: sound pcmC0D7p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: sound pcmC0D3p: PM: calling do_pcm_suspend+0x0/0x30 [snd_pcm] @ 4973, parent: card0
Nov 12 12:47:21 kernel: sound pcmC0D3p: PM: do_pcm_suspend+0x0/0x30 [snd_pcm] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: Generic FE-GE Realtek PHY r8169-0-200:00: PM: calling mdio_bus_phy_suspend+0x0/0x120 [libphy] @ 4973, parent: r8169-0-200
Nov 12 12:47:21 kernel: snd_hda_codec_realtek hdaudioC1D0: PM: calling hda_codec_pm_suspend+0x0/0x20 [snd_hda_codec] @ 4881, parent: 0000:04:00.6
Nov 12 12:47:21 kernel: Generic FE-GE Realtek PHY r8169-0-200:00: PM: mdio_bus_phy_suspend+0x0/0x120 [libphy] returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input10: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: eeepc-wmi
Nov 12 12:47:21 kernel: input input10: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: eeepc-wmi eeepc-wmi: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: eeepc-wmi eeepc-wmi: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: hid_sensor_prox HID-SENSOR-200011.7.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 0020:1022:0001.0008
Nov 12 12:47:21 kernel: ieee80211 phy0: PM: wiphy_suspend+0x0/0x2c0 [cfg80211] returned 0 after 36080 usecs
Nov 12 12:47:21 kernel: hid_sensor_prox HID-SENSOR-200011.7.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: hid_sensor_als HID-SENSOR-200041.6.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 0020:1022:0001.0007
Nov 12 12:47:21 kernel: hid_sensor_als HID-SENSOR-200041.6.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: hid_sensor_magn_3d HID-SENSOR-200083.5.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 0020:1022:0001.0006
Nov 12 12:47:21 kernel: hid_sensor_magn_3d HID-SENSOR-200083.5.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: hid_sensor_gyro_3d HID-SENSOR-200076.4.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 0020:1022:0001.0005
Nov 12 12:47:21 kernel: hid_sensor_gyro_3d HID-SENSOR-200076.4.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: hid_sensor_accel_3d HID-SENSOR-200073.3.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 0020:1022:0001.0004
Nov 12 12:47:21 kernel: hid_sensor_accel_3d HID-SENSOR-200073.3.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform regulatory.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform regulatory.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: snd_hda_codec_realtek hdaudioC1D0: PM: hda_codec_pm_suspend+0x0/0x20 [snd_hda_codec] returned 0 after 16611 usecs
Nov 12 12:47:21 kernel: sp5100-tco sp5100-tco: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: sp5100-tco sp5100-tco: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input9: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: pcspkr
Nov 12 12:47:21 kernel: input input9: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input8: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: rc0
Nov 12 12:47:21 kernel: input input8: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: vboxdrv vboxdrv.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: vboxdrv vboxdrv.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: input input7: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: 0003:413C:2010.0003
Nov 12 12:47:21 kernel: input input7: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input6: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: 0003:413C:2010.0003
Nov 12 12:47:21 kernel: input input6: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: leds input5::kana: PM: calling led_suspend+0x0/0x50 @ 4973, parent: input5
Nov 12 12:47:21 kernel: leds input5::kana: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: leds input5::compose: PM: calling led_suspend+0x0/0x50 @ 4973, parent: input5
Nov 12 12:47:21 kernel: leds input5::compose: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: leds input5::scrolllock: PM: calling led_suspend+0x0/0x50 @ 4973, parent: input5
Nov 12 12:47:21 kernel: leds input5::scrolllock: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: leds input5::capslock: PM: calling led_suspend+0x0/0x50 @ 4973, parent: input5
Nov 12 12:47:21 kernel: leds input5::capslock: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: leds input5::numlock: PM: calling led_suspend+0x0/0x50 @ 4973, parent: input5
Nov 12 12:47:21 kernel: leds input5::numlock: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: leds mmc0::: PM: calling led_suspend+0x0/0x50 @ 4973, parent: rtsx_usb_sdmmc.1.auto
Nov 12 12:47:21 kernel: leds mmc0::: PM: led_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input5: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: 0003:413C:2010.0002
Nov 12 12:47:21 kernel: input input5: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input4: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: 0003:046D:C077.0001
Nov 12 12:47:21 kernel: input input4: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: rtsx_usb_ms rtsx_usb_ms.2.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 3-4:1.0
Nov 12 12:47:21 kernel: rtsx_usb_ms rtsx_usb_ms.2.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 87 usecs
Nov 12 12:47:21 kernel: rtsx_usb_sdmmc rtsx_usb_sdmmc.1.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 3-4:1.0
Nov 12 12:47:21 kernel: rtsx_usb_sdmmc rtsx_usb_sdmmc.1.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input3: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: LNXVIDEO:00
Nov 12 12:47:21 kernel: usb 3-2.1: PM: calling usb_dev_suspend+0x0/0x20 @ 2449, parent: 3-2
Nov 12 12:47:21 kernel: usb 3-4: PM: calling usb_dev_suspend+0x0/0x20 @ 4881, parent: usb3
Nov 12 12:47:21 kernel: usb 3-4: PM: usb_dev_suspend+0x0/0x20 returned 0 after 4 usecs
Nov 12 12:47:21 kernel: usb 3-1: PM: calling usb_dev_suspend+0x0/0x20 @ 4881, parent: usb3
Nov 12 12:47:21 kernel: usb 3-1: PM: usb_dev_suspend+0x0/0x20 returned 0 after 2 usecs
Nov 12 12:47:21 kernel: usb usb6: PM: calling usb_dev_suspend+0x0/0x20 @ 4881, parent: 0000:04:00.4
Nov 12 12:47:21 kernel: usb 5-2: PM: calling usb_dev_suspend+0x0/0x20 @ 4886, parent: usb5
Nov 12 12:47:21 kernel: usb usb4: PM: calling usb_dev_suspend+0x0/0x20 @ 4865, parent: 0000:04:00.3
Nov 12 12:47:21 kernel: usb usb2: PM: calling usb_dev_suspend+0x0/0x20 @ 4884, parent: 0000:01:00.0
Nov 12 12:47:21 kernel: usb usb1: PM: calling usb_dev_suspend+0x0/0x20 @ 4838, parent: 0000:01:00.0
Nov 12 12:47:21 kernel: usb 5-2: PM: usb_dev_suspend+0x0/0x20 returned 0 after 137 usecs
Nov 12 12:47:21 kernel: usb usb5: PM: calling usb_dev_suspend+0x0/0x20 @ 4844, parent: 0000:04:00.4
Nov 12 12:47:21 kernel: usb usb1: PM: usb_dev_suspend+0x0/0x20 returned 0 after 131 usecs
Nov 12 12:47:21 kernel: input input3: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: usb usb5: PM: usb_dev_suspend+0x0/0x20 returned 0 after 10149 usecs
Nov 12 12:47:21 kernel: platform microcode: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: sd 2:0:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4838, parent: target2:0:0
Nov 12 12:47:21 kernel: sd 1:0:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4832, parent: target1:0:0
Nov 12 12:47:21 kernel: platform microcode: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: bootsplash bootsplash.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: bootsplash bootsplash.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 2 usecs
Nov 12 12:47:21 kernel: usb 3-2.1: PM: usb_dev_suspend+0x0/0x20 returned 0 after 18962 usecs
Nov 12 12:47:21 kernel: alarmtimer alarmtimer.0.auto: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: rtc0
Nov 12 12:47:21 kernel: usb 3-2: PM: calling usb_dev_suspend+0x0/0x20 @ 4839, parent: usb3
Nov 12 12:47:21 kernel: alarmtimer alarmtimer.0.auto: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: usb usb6: PM: usb_dev_suspend+0x0/0x20 returned 0 after 24387 usecs
Nov 12 12:47:21 kernel: usb usb2: PM: usb_dev_suspend+0x0/0x20 returned 0 after 24345 usecs
Nov 12 12:47:21 kernel: usb usb4: PM: usb_dev_suspend+0x0/0x20 returned 0 after 25202 usecs
Nov 12 12:47:21 kernel: rtc rtc0: PM: calling rtc_suspend+0x0/0x1f0 @ 4973, parent: 00:01
Nov 12 12:47:21 kernel: rtc rtc0: PM: rtc_suspend+0x0/0x1f0 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: serial8250 serial8250: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: scsi host0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 2449, parent: ata1
Nov 12 12:47:21 kernel: serial8250 serial8250: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: scsi host0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input2: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: LNXPWRBN:00
Nov 12 12:47:21 kernel: ata1: PM: calling ata_port_pm_suspend+0x0/0x60 @ 4846, parent: 0000:05:00.0
Nov 12 12:47:21 kernel: input input2: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: ata1: PM: ata_port_pm_suspend+0x0/0x60 returned 0 after 253 usecs
Nov 12 12:47:21 kernel: input input1: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: PNP0C0E:00
Nov 12 12:47:21 kernel: input input1: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: input input0: PM: calling input_dev_suspend+0x0/0x70 @ 4973, parent: PNP0C0C:00
Nov 12 12:47:21 kernel: input input0: PM: input_dev_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pcspkr pcspkr: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: pcspkr pcspkr: PM: platform_pm_suspend+0x0/0x50 returned 0 after 9 usecs
Nov 12 12:47:21 kernel: system 00:03: PM: calling pnp_bus_suspend+0x0/0x20 @ 4973, parent: pnp0
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_suspend+0x0/0x170 @ 2449, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: system 00:03: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 72 usecs
Nov 12 12:47:21 kernel: ite-cir 00:02: PM: calling pnp_bus_suspend+0x0/0x20 @ 4973, parent: pnp0
Nov 12 12:47:21 kernel: ite-cir 00:02: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 31 usecs
Nov 12 12:47:21 kernel: rtc_cmos 00:01: PM: calling pnp_bus_suspend+0x0/0x20 @ 4973, parent: pnp0
Nov 12 12:47:21 kernel: rtc_cmos 00:01: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 33 usecs
Nov 12 12:47:21 kernel: system 00:00: PM: calling pnp_bus_suspend+0x0/0x20 @ 4973, parent: pnp0
Nov 12 12:47:21 kernel: system 00:00: PM: pnp_bus_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform efivars.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform efivars.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform rtc-efi.0: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform rtc-efi.0: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: button LNXPWRBN:00: PM: calling acpi_button_suspend+0x0/0x20 @ 4973, parent: LNXSYSTM:00
Nov 12 12:47:21 kernel: button LNXPWRBN:00: PM: acpi_button_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform USBC000:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform USBC000:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_suspend+0x0/0x60 @ 4973, parent: platform
Nov 12 12:47:21 kernel: usb 3-2: PM: usb_dev_suspend+0x0/0x20 returned 0 after 35970 usecs
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: usb usb3: PM: calling usb_dev_suspend+0x0/0x20 @ 4863, parent: 0000:04:00.3
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_suspend+0x0/0x60 @ 4973, parent: platform
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform PNP0103:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform PNP0103:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform INT3515:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: AMDI0010:01
Nov 12 12:47:21 kernel: platform INT3515:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_suspend+0x0/0x60 @ 4973, parent: platform
Nov 12 12:47:21 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_suspend+0x0/0x60 @ 4839, parent: platform
Nov 12 12:47:21 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_suspend+0x0/0x60 returned 0 after 28 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:0f: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: usb usb3: PM: usb_dev_suspend+0x0/0x20 returned 0 after 10194 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:0f: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:0e: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform ACPI0007:0e: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:0d: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform ACPI0007:0d: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:0c: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform ACPI0007:0c: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:0b: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform ACPI0007:0b: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:0a: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform ACPI0007:0a: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:09: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform ACPI0007:09: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform ACPI0007:08: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform ACPI0007:08: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform PNP0C0E:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform PNP0C0E:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform PNP0C0C:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: platform PNP0C0C:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform PNP0C09:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 0000:00:14.3
Nov 12 12:47:21 kernel: platform PNP0C09:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: platform PNP0800:00: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: 0000:00:14.3
Nov 12 12:47:21 kernel: platform PNP0800:00: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: button PNP0C0E:00: PM: calling acpi_button_suspend+0x0/0x20 @ 4973, parent: LNXSYBUS:00
Nov 12 12:47:21 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_suspend+0x0/0x170 @ 2449, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_suspend+0x0/0x170 @ 4846, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: pci 0000:04:00.5: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: pci 0000:04:00.5: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4834, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: ccp 0000:04:00.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4831, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: ccp 0000:04:00.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 3 usecs
Nov 12 12:47:21 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4831, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: 0000:00:02.2
Nov 12 12:47:21 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: pci 0000:02:00.4: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: 0000:00:02.1
Nov 12 12:47:21 kernel: pci 0000:02:00.4: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:02:00.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: 0000:00:02.1
Nov 12 12:47:21 kernel: pci 0000:02:00.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: serial 0000:02:00.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: 0000:00:02.1
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_suspend+0x0/0x170 returned 0 after 153 usecs
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 137 usecs
Nov 12 12:47:21 kernel: serial 0000:02:00.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:47:21 kernel: serial 0000:02:00.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: 0000:00:02.1
Nov 12 12:47:21 kernel: r8169 0000:02:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4834, parent: 0000:00:02.1
Nov 12 12:47:21 kernel: xhci_hcd 0000:01:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: 0000:00:01.2
Nov 12 12:47:21 kernel: serial 0000:02:00.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:47:21 kernel: pci 0000:00:18.7: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:18.7: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:00:18.6: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:18.6: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: pci 0000:00:18.5: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:18.5: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:00:18.4: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:18.4: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:00:18.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: k10temp 0000:00:18.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4928, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:18.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: k10temp 0000:00:18.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:00:18.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:18.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4928, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:18.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:00:18.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: piix4_smbus 0000:00:14.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:14.3: PM: calling pci_pm_suspend+0x0/0x170 @ 4860, parent: pci0000:00
Nov 12 12:47:21 kernel: piix4_smbus 0000:00:14.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: xhci_hcd 0000:01:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 119 usecs
Nov 12 12:47:21 kernel: pci 0000:00:14.3: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:00:08.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: pci0000:00
Nov 12 12:47:21 kernel: pcieport 0000:00:02.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4860, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:08.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pcieport 0000:00:02.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 3 usecs
Nov 12 12:47:21 kernel: pci 0000:00:02.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:02.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pcieport 0000:00:01.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4860, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:01.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4861, parent: pci0000:00
Nov 12 12:47:21 kernel: pcieport 0000:00:01.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 2 usecs
Nov 12 12:47:21 kernel: pci 0000:00:01.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pci 0000:00:00.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4860, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:00.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: pci 0000:00:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4878, parent: pci0000:00
Nov 12 12:47:21 kernel: pci 0000:00:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: button PNP0C0E:00: PM: acpi_button_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_suspend+0x0/0x170 returned 0 after 1126 usecs
Nov 12 12:47:21 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_suspend+0x0/0x170 returned 0 after 5 usecs
Nov 12 12:47:21 kernel: button PNP0C0C:00: PM: calling acpi_button_suspend+0x0/0x20 @ 4973, parent: LNXSYBUS:00
Nov 12 12:47:21 kernel: button PNP0C0C:00: PM: acpi_button_suspend+0x0/0x20 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: r8169 0000:02:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 8952 usecs
Nov 12 12:47:21 kernel: ec PNP0C09:00: PM: calling acpi_ec_suspend+0x0/0x70 @ 4973, parent: device:3a
Nov 12 12:47:21 kernel: pcieport 0000:00:02.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4864, parent: pci0000:00
Nov 12 12:47:21 kernel: ec PNP0C09:00: PM: acpi_ec_suspend+0x0/0x70 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: pcieport 0000:00:02.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 6 usecs
Nov 12 12:47:21 kernel: regulator regulator.0: PM: calling regulator_suspend+0x0/0x120 @ 4973, parent: reg-dummy
Nov 12 12:47:21 kernel: regulator regulator.0: PM: regulator_suspend+0x0/0x120 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: reg-dummy reg-dummy: PM: calling platform_pm_suspend+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: reg-dummy reg-dummy: PM: platform_pm_suspend+0x0/0x50 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: sd 2:0:0:0: [sdb] Synchronizing SCSI cache
Nov 12 12:47:21 kernel: sd 1:0:0:0: [sda] Synchronizing SCSI cache
Nov 12 12:47:21 kernel: sd 2:0:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 150606 usecs
Nov 12 12:47:21 kernel: scsi target2:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4886, parent: host2
Nov 12 12:47:21 kernel: scsi target2:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: scsi host2: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4865, parent: ata3
Nov 12 12:47:21 kernel: scsi host2: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: sd 1:0:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 150700 usecs
Nov 12 12:47:21 kernel: ata3: PM: calling ata_port_pm_suspend+0x0/0x60 @ 4884, parent: 0000:05:00.1
Nov 12 12:47:21 kernel: scsi target1:0:0: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4849, parent: host1
Nov 12 12:47:21 kernel: scsi target1:0:0: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: ata3.00: Entering standby power mode
Nov 12 12:47:21 kernel: scsi host1: PM: calling scsi_bus_suspend+0x0/0xc0 @ 4881, parent: ata2
Nov 12 12:47:21 kernel: scsi host1: PM: scsi_bus_suspend+0x0/0xc0 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: ata2: PM: calling ata_port_pm_suspend+0x0/0x60 @ 4844, parent: 0000:05:00.0
Nov 12 12:47:21 kernel: ata2.00: Entering standby power mode
Nov 12 12:47:21 kernel: ata3: PM: ata_port_pm_suspend+0x0/0x60 returned 0 after 19938 usecs
Nov 12 12:47:21 kernel: ahci 0000:05:00.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4863, parent: 0000:00:08.2
Nov 12 12:47:21 kernel: ahci 0000:05:00.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 3 usecs
Nov 12 12:47:21 kernel: amdgpu 0000:04:00.0: amdgpu: free PSP TMR buffer
Nov 12 12:47:21 kernel: amdgpu 0000:04:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 242731 usecs
Nov 12 12:47:21 kernel: pcieport 0000:00:08.1: PM: calling pci_pm_suspend+0x0/0x170 @ 4835, parent: pci0000:00
Nov 12 12:47:21 kernel: pcieport 0000:00:08.1: PM: pci_pm_suspend+0x0/0x170 returned 0 after 7 usecs
Nov 12 12:47:21 kernel: ata2: PM: ata_port_pm_suspend+0x0/0x60 returned 0 after 442394 usecs
Nov 12 12:47:21 kernel: ahci 0000:05:00.0: PM: calling pci_pm_suspend+0x0/0x170 @ 4839, parent: 0000:00:08.2
Nov 12 12:47:21 kernel: ahci 0000:05:00.0: PM: pci_pm_suspend+0x0/0x170 returned 0 after 5 usecs
Nov 12 12:47:21 kernel: pcieport 0000:00:08.2: PM: calling pci_pm_suspend+0x0/0x170 @ 4928, parent: pci0000:00
Nov 12 12:47:21 kernel: pcieport 0000:00:08.2: PM: pci_pm_suspend+0x0/0x170 returned 0 after 7 usecs
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4844, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:01: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:01: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:00: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: acpi-wmi PNP0C14:00: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: amd_gpio AMDI0030:00: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4973, parent: platform
Nov 12 12:47:21 kernel: amd_gpio AMDI0030:00: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 18 usecs
Nov 12 12:47:21 kernel: i2c_designware AMDI0010:01: PM: calling acpi_subsys_suspend_late+0x0/0x50 @ 4839, parent: platform
Nov 12 12:47:21 kernel: ahci 0000:05:00.1: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4844, parent: 0000:00:08.2
Nov 12 12:47:21 kernel: i2c_designware AMDI0010:01: PM: acpi_subsys_suspend_late+0x0/0x50 returned 0 after 12 usecs
Nov 12 12:47:21 kernel: ahci 0000:05:00.1: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: ahci 0000:05:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4839, parent: 0000:00:08.2
Nov 12 12:47:21 kernel: pcie_mp2_amd 0000:04:00.7: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4844, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: ahci 0000:05:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.6: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4863, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: pcie_mp2_amd 0000:04:00.7: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: pci 0000:04:00.5: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4839, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: snd_hda_intel 0000:04:00.6: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.4: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4844, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.3: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4863, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: pci 0000:04:00.5: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.4: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: ccp 0000:04:00.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4831, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: xhci_hcd 0000:04:00.3: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: amdgpu 0000:04:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4839, parent: 0000:00:08.1
Nov 12 12:47:21 kernel: pci 0000:02:00.4: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4863, parent: 0000:00:02.1
Nov 12 12:47:21 kernel: iwlwifi 0000:03:00.0: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4844, parent: 0000:00:02.2
Nov 12 12:47:21 kernel: pci 0000:02:00.3: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4835, parent: 0000:00:02.1
Nov 12 12:47:21 kernel: amdgpu 0000:04:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 0 usecs
Nov 12 12:47:21 kernel: iwlwifi 0000:03:00.0: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: ccp 0000:04:00.2: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 2 usecs
Nov 12 12:47:21 kernel: pci 0000:02:00.4: PM: pci_pm_suspend_late+0x0/0x40 returned 0 after 1 usecs
Nov 12 12:47:21 kernel: serial 0000:02:00.2: PM: calling pci_pm_suspend_late+0x0/0x40 @ 4839, parent: 0000:00:02.1
The last line of the unsuccessful cycle is:
That line occurs in the good cycle at line 334, then that call returns a couple of lines afterwards, and there’s a lot more output after that.
Is this a clue for anyone, what is that serial, is it a driver? Is that where the problem is, or is that not clear enough?
Any suggestions welcome
Thanks!
