Hi guys!
I have a problem regarding my laptop.
Upon boot the pc works somewhat fine, but animations and performance in general are a little sluggish, I can’t watch 1080p youtube videos without it lagging and certain programs are just slower than normal. For example, I use GIMP with a graphic tablet for notes when I study and pen input will lag a lot.
The fun thing is, If i suspend the pc and wake it up, even immediatly, all lags and general sluggishness just desappears, youtube videos work fine and so does GIMP and the system feels generally snappier and faster. So I thought that it has something to do with RAM, maybe when I wake up my laptop from sleep a lot of wath it put into RAM remains there, but looking at system monitor before and after suspend doesn’t show more or less ram usage… can’t wrap my head around it!
It’s nothing too serious, it takes like 10 seconds to close and open the laptop lid again, but still it would be even nicer if I didn’t have to do it XD
What do you think about it?
inxi -Fazy
Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=5f7a7ef9-ca3d-413a-8734-f763cb82c6ef rw pci=noaer quiet apparmor=1
security=apparmor resume=UUID=bc81d4a7-d397-440e-9225-c2eae38cb1df
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X541UAK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X541UAK v: 1.0 serial: <filter>
UEFI: American Megatrends v: X541UAK.311 date: 03/14/2018
ID-1: BAT0 charge: 23.2 Wh condition: 29.6/34.6 Wh (86%) volts: 10.8/10.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 354
Topology: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: D6
L2 cache: 3072 KiB
bogomips: 16006
Speed: 2000 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 2000 2: 2000
3: 2000 4: 2001
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1916
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 13d3:5a01 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d70
Sound Server: ALSA v: k5.7.19-2-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: e000 bus ID: 02:00.2 chip ID: 10ec:8136
IF: enp2s0f2 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:b723
Local Storage: total: 577.55 GiB used: 109.64 GiB (19.0%)
ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 023 scheme: GPT
ID-2: /dev/sdb vendor: Crucial model: CT120BX500SSD1 size: 111.79 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: R013 scheme: GPT
ID-1: / raw size: 161.13 GiB size: 157.60 GiB (97.81%)
used: 33.80 GiB (21.4%) fs: ext4 dev: /dev/sda5
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7
System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2000
Processes: 183 Uptime: 33m Memory: 7.66 GiB used: 1.15 GiB (15.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1332 lib: 376
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
