My system is taking too long to shutdown (>90 seconds). The issue is that something is causing a network drive to not disconnect and so I have to wait for it to timeout fully before it continues the shutdown. I’m guessing something is trying to write to it, but I have no idea what. Any suggestions to troubleshoot this?
inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.3 tk: Gtk 3.24.23
info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Micro-Star product: GF65 Thin 9SD v: REV:1.0 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <filter> UEFI: American Megatrends v: E16W1IMS.108
date: 12/04/2019
Battery: ID-1: BAT1 charge: 36.4 Wh condition: 49.7/51.3 Wh (97%) volts: 12.0/11.4 model: MSI Corp. MS-16W1 type: Li-ion
serial: N/A status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360 serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: Discharging
Memory: RAM: total: 31.21 GiB used: 4.43 GiB (14.2%)
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 12.0 MiB
bogomips: 62431
Speed: 900 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
9: 900 10: 900 11: 900 12: 901
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel UHD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Micro-Star MSI driver: nvidia v: 450.80.02
bus ID: 01:00.0 chip ID: 10de:2191
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus ID: 1-11:3 chip ID: 5986:211b
Display: x11 server: X.Org 1.20.10 driver: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
resolution: 1: 1920x1080~120Hz 2: 1920x1080~75Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.3 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 6000 bus ID: 00:14.3
chip ID: 8086:a370
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: 3000 bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter>
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Drives: Local Storage: total: 953.88 GiB used: 333.95 GiB (35.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLV512HCJH-000L2 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 5L0QBXV7 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Western Digital model: PC SN530 SDBPNPZ-512G-1032 size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 21101000 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 125.30 GiB used: 77.67 GiB (62.0%) fs: ext4 dev: /dev/nvme1n1p4 label: N/A
uuid: 9ce0d192-74cb-480c-a301-5218e56ae9d2
ID-2: /boot/efi size: 500.0 MiB used: 360 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 label: N/A uuid: 9146-CB96
ID-3: /home size: 310.67 GiB used: 187.13 GiB (60.2%) fs: ext4 dev: /dev/nvme1n1p3 label: N/A
uuid: 301dc4d2-0455-4799-ae01-db9895f819f7
ID-4: /home/<filter>/d_drive size: 176.24 GiB used: 69.15 GiB (39.2%) fs: ntfs dev: /dev/nvme0n1p5 label: d_drive
uuid: 43FBFFD71AD3FC68
ID-5: /home/<filter>/network_drives size: 931.28 GiB used: 560.67 GiB (60.2%) fs: cifs
remote: //192.168.1.1/17e7-062b label: N/A uuid: N/A
ID-6: /run/timeshift/backup raw size: 127.80 GiB size: <superuser/root required> used: <superuser/root required>
fs: ext4 dev: /dev/nvme1n1p4 label: N/A uuid: 9ce0d192-74cb-480c-a301-5218e56ae9d2
Swap: ID-1: swap-1 type: partition size: 32.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme1n1p2 label: N/A
uuid: 5b9fd5b9-6a63-41d5-977e-336d40f2ebaf
Unmounted: ID-1: /dev/nvme0n1p2 size: 300.00 GiB fs: ntfs label: c_drive uuid: C6AE0EAEAE0E9759
ID-2: /dev/nvme0n1p3 size: 100.0 MiB fs: vfat label: BOOT uuid: 429D-B2A7
ID-3: /dev/nvme0n1p4 size: 561.0 MiB fs: ntfs label: diagnostic uuid: A04478FB4478D60E
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0605
Device-1: 1-3.1:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b
Device-2: 1-3.2:6 info: Microsoft Nano Transceiver 1.1 type: Keyboard,HID,Mouse driver: hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 045e:07fd
Device-3: 1-11:3 info: Acer HD Webcam type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 5986:211b
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 68.0 C mobo: N/A
Info: Processes: 332 Uptime: 20m Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1862 pacman: 1839
flatpak: 15 snap: 8 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
This is useless till I get it fixed:
journalctl --boot=-1
An error was encountered while opening journal file or directory /var/log/journal, ignoring file: Not a directory
Specifying boot ID or boot offset has no effect, no persistent journal was found.
