It kinda has…
“Get new …” where you can filter updateable and update.
inxi -v7azy
Kernel: 6.8.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
root=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 rw
resume=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 resume_offset=30074880
apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1
nvidia_drm.modeset=1 nvidia_drm.fbdev=1 modprobe.blacklist=nouveau
systemd.setenv=GPUMOD=nvidia nowatchdog intel_iommu=on iommu=pt
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: MSI model: P55-GD55 (MS-7589) v: 1.0
serial: <superuser required> uuid: <superuser required>
BIOS: American Megatrends v: 1.9 date: 03/02/2011
System RAM: total: 8 GiB available: 7.75 GiB used: 6.48 GiB (83.6%)
Array-1: capacity: 8 GiB slots: 4 modules: 4 EC: None
max-module-size: 2 GiB note: est.
Device-1: DIMM1 type: SDRAM detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: N/A part-no: N/A serial: N/A
Device-2: DIMM2 type: SDRAM detail: synchronous size: 2 GiB
Device-3: DIMM3 type: SDRAM detail: synchronous size: 2 GiB
Device-4: DIMM4 type: SDRAM detail: synchronous size: 2 GiB
Info: model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1E (30) stepping: 5 microcode: 0xA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1575 high: 1739 min/max: 1200/2801 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1674 2: 1690
3: 1739 4: 1608 5: 1633 6: 1405 7: 1439 8: 1417 bogomips: 44934
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none off: DVI-I-1 empty: DP-1,DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 102 s-size: 478x269mm (18.82x10.59")
s-diag: 548mm (21.59")
Monitor-1: DVI-I-1 note: disabled model: Samsung SyncMaster
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 970 driver: nvidia v: 550.67 device-ID: 10de:13c2
surfaces: xcb,xlib
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Micro-Star MSI 5 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: JMTek LLC. Lioncast_LX60_USB_Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-1.1:3 chip-ID: 0c76:1617 class-ID: 0300
serial: <filter>
API: ALSA v: k6.8.1-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d800 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 3.18 TiB used: 257.72 GiB (7.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103SJ size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 00E4 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS5C3020ALA632
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5940 serial: <filter> fw-rev: A580 scheme: MBR
ID-1: / raw-size: 371.09 GiB size: 364.2 GiB (98.14%) used: 66.6 GiB (18.3%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: SSDRoot
uuid: 9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6
ID-2: /home raw-size: 489.27 GiB size: 480.51 GiB (98.21%)
used: 191.12 GiB (39.8%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: home
uuid: c5fcc6d4-1db5-4ec5-8ede-0f76cd6ee4ab
Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 11 GiB used: 1.29 GiB (11.8%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System-reserviert
uuid: 583E97273E96FD66
ID-2: /dev/sda2 maj-min: 8:2 size: 199.39 GiB fs: ntfs label: System
uuid: 0A12C25D12C24CFF
ID-3: /dev/sda3 maj-min: 8:3 size: 527 MiB fs: ntfs label: N/A
uuid: 34862028861FE95E
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sda5 maj-min: 8:5 size: 242.25 GiB fs: ntfs label: Daten
uuid: 7024BEAB24BE73A6
ID-6: /dev/sdb2 maj-min: 8:18 size: 94.66 GiB fs: ext4 label: SSDDaten
uuid: b9358f37-9f4f-4c92-a7e7-034e046fa0f8
ID-7: /dev/sdc1 maj-min: 8:33 size: 1.15 TiB fs: ntfs label: Daten3
uuid: 86E470A6E47099DF
ID-8: /dev/sdc2 maj-min: 8:34 size: 100.18 GiB fs: ext4 label: Backup
uuid: ff56fbe9-6e09-4569-8fa8-8b97d1c923f1
ID-9: /dev/sdc3 maj-min: 8:35 size: 439.45 GiB fs: ext4 label: N/A
uuid: e1875968-aed1-42d3-b90c-be51960c7910
ID-10: /dev/sdc4 maj-min: 8:36 size: 146.48 GiB fs: ext4 label: Testsys
uuid: afafb774-fda7-444d-b5f3-8ded4befe91c
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0020
Device-1: 1-1.5:3 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 2516:0042 class-ID: 0301
Device-2: 1-1.6:4 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: JMTek LLC. Lioncast_LX60_USB_Headset
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 0c76:1617 class-ID: 0300 serial: <filter>
Device-2: 2-1.2:4 info: Logitech F510 Gamepad [DirectInput Mode] type: HID
driver: logitech,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 500mA chip-ID: 046d:c218 class-ID: 0300
Device-3: 2-1.3:5 info: Genesys Logic USB 2.0 Card Reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 05e3:070e class-ID: 0806 serial: <filter>
System Temperatures: cpu: 45.0 C mobo: 36.0 C gpu: nvidia temp: 54 C
Fan Speeds (rpm): cpu: 1075 fan-1: 799 fan-3: 880 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.26
Processes: 301 Power: uptime: 2h 57m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1921 libs: 515 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: menu.sh default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Here’s the corresponding journal (opening systems-setting, going to Icons, get new, select updateable and click button update)
Mär 30 20:59:35 alexander-ms7589 systemsettings[9546]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "qrc:/qt/qml/org/kde/desktop/private/TextFieldContextMenu.qml" and "qrc:/qt/qml/org/kde/desktop/MenuItem.qml"
Mär 30 20:59:36 alexander-ms7589 systemsettings[9546]: qt.svg: <input>:78:10: Could not resolve property: #linearGradient981
Mär 30 20:59:36 alexander-ms7589 systemsettings[9546]: qt.svg: <input>:86:10: Could not resolve property: #linearGradient981
Mär 30 20:59:43 alexander-ms7589 systemsettings[9546]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "qrc:/qt/qml/org/kde/desktop/private/TextFieldContextMenu.qml" and "qrc:/qt/qml/org/kde/desktop/MenuItem.qml"
Mär 30 20:59:43 alexander-ms7589 systemsettings[9546]: qrc:/kcm/kcm_lookandfeel/main.qml:142:9: QML StackView: Binding loop detected for property "implicitHeight"
Mär 30 20:59:43 alexander-ms7589 systemsettings[9546]: qrc:/kcm/kcm_lookandfeel/main.qml:138:5: QML OverlaySheet: Binding loop detected for property "implicitHeight"
Mär 30 20:59:43 alexander-ms7589 systemsettings[9546]: qml: Pushed pages do not conform to the rules. Please check the documentation.
Mär 30 20:59:45 alexander-ms7589 systemsettings[9546]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "qrc:/qt/qml/org/kde/desktop/private/TextFieldContextMenu.qml" and "qrc:/qt/qml/org/kde/desktop/MenuItem.qml"
Mär 30 20:59:46 alexander-ms7589 systemsettings[9546]: qml: Pushed pages do not conform to the rules. Please check the documentation.
Mär 30 20:59:49 alexander-ms7589 systemsettings[9546]: qrc:/qt/qml/org/kde/newstuff/Page.qml:454:5: QML DownloadItemsSheet: Binding loop detected for property "implicitHeight"
Mär 30 20:59:49 alexander-ms7589 systemsettings[9546]: qrc:/qt/qml/org/kde/newstuff/Action.qml:130:68: QML Connections: Detected function "onInitialized" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Mär 30 21:00:08 alexander-ms7589 systemsettings[9546]: "Could not convert argument 0 at"
Mär 30 21:00:08 alexander-ms7589 systemsettings[9546]: "expression for onTriggered@qrc:/qt/qml/org/kde/newstuff/private/entrygriddelegates/BigPreviewDelegate.qml:54"
Mär 30 21:00:08 alexander-ms7589 systemsettings[9546]: "expression for onClicked@qrc:/qt/qml/org/kde/newstuff/private/GridTileDelegate.qml:160"
Mär 30 21:00:08 alexander-ms7589 systemsettings[9546]: qrc:/qt/qml/org/kde/newstuff/private/entrygriddelegates/BigPreviewDelegate.qml:54: TypeError: Passing incompatible arguments to C++ functions from JavaScript is not allowed.
Mär 30 21:00:13 alexander-ms7589 systemsettings[9546]: "Could not convert argument 0 at"
Mär 30 21:00:13 alexander-ms7589 systemsettings[9546]: "expression for onTriggered@qrc:/qt/qml/org/kde/newstuff/private/entrygriddelegates/BigPreviewDelegate.qml:54"
Mär 30 21:00:13 alexander-ms7589 systemsettings[9546]: "expression for onClicked@qrc:/qt/qml/org/kde/newstuff/private/GridTileDelegate.qml:160"
Mär 30 21:00:13 alexander-ms7589 systemsettings[9546]: qrc:/qt/qml/org/kde/newstuff/private/entrygriddelegates/BigPreviewDelegate.qml:54: TypeError: Passing incompatible arguments to C++ functions from JavaScript is not allowed.
it seams to have indeed some problems.
I think i will test it with another theme. Since i did not find an update for system-settings in the last couple of day, maybe it’s data-driven…
isn’t discover
rather a replacement for pamac
