I am on my 4th nuke and pave with this install and I cannot narrow down what is causing this issue. After I reinstall from the live image I start setting up firefox downloading and installing applications etc. Then after some time ( this is where I haven’t been able to pin down what may be the cause, not certain if it is one of the apps being installed or updated or what) I can no longer open system settings, and once that happens the only option on the “leave” panel that works is suspend, hibernate and lock screen. clicking on System settings will bounce a few times, pop the icon on the panel and then crash out. the only change I have made within system settings is turn num lock on at plasma start. Once all this happens if I reboot
or do a hard reboot I get a blank screen with a blinking cursor and can only access tty2.
inxi -Fazy | sed -e "s/$HOSTNAME/HOST/gI" -e "s/$USER/USER/gI"
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=e9365ae1-8586-49d1-a086-979096c16379 rw quiet apparmor=1
security=apparmor resume=UUID=1aa4113f-d0ea-41c0-b49e-92e68e9aa30c
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: B450 AORUS M serial: <filter>
UEFI: American Megatrends v: F60c date: 10/29/2020
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 4096 KiB
bogomips: 115024
Speed: 3592 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3592 2: 2053 3: 2048 4: 2149 5: 2196 6: 2195 7: 2196 8: 2196 9: 2048
10: 2050 11: 2195 12: 2196 13: 2196 14: 2195 15: 3592 16: 2047
conditional, RSB filling
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 09:00.0
chip ID: 1002:7340
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 82
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 0b:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.9.11-3-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus ID: 04:00.0
chip ID: 10ec:8168
Local Storage: total: 12.73 TiB used: 99.98 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 211070WD scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1B6Q scheme: GPT
ID-3: /dev/sdb type: USB vendor: Western Digital model: WD Elements 25A3
size: 10.91 TiB block size: physical: 4096 B logical: 512 B serial: <filter>
rev: 1030 scheme: GPT
ID-1: / raw size: 896.71 GiB size: 881.64 GiB (98.32%)
used: 21.68 GiB (2.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 34.51 GiB used: 1.03 GiB (3.0%)
priority: -2 dev: /dev/nvme0n1p3
System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 0.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 358 Uptime: 21h 42m Memory: 31.37 GiB used: 6.66 GiB (21.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1296
pacman: 1292 lib: 362 flatpak: 4 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
