System resumes immediately after suspend
Hi All,
I follow up on this thread because I have the same issue. System resume immediately after suspend.
This is dmesg:
dmesg
[    0.000000] Linux version 6.6.65-1-MANJARO (builduser@fv-az1423-505) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Wed Dec 11 22:24:04 UTC 2024
[    0.000000] Command line: root=UUID=dcd2885d-ae78-4f92-b3e7-c8507caef8a3 rw quiet splash udev.log_priority=3 initrd=\boot\initramfs-6.6-x86_64.img
[    0.000000] reserving inaccessible SNB gfx pages
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000008e000-0x000000000008ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000090000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000bffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000020200000-0x000000003fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000401fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040200000-0x000000008ed33fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008ed34000-0x000000008ed5efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008ed5f000-0x000000008ed6dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000008ed6e000-0x000000008ed8efff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008ed8f000-0x000000008ee5afff] usable
[    0.000000] BIOS-e820: [mem 0x000000008ee5b000-0x000000008ee8efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008ee8f000-0x000000008eed6fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008eed7000-0x000000008eefefff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008eeff000-0x000000008efa2fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008efa3000-0x000000008f8fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e00f8000-0x00000000e00f8fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffed8000-0x00000000ffefffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000036fefffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] e820: update [mem 0x89985018-0x899a0a57] usable ==> usable
[    0.000000] e820: update [mem 0x89962018-0x89973212] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000008dfff] usable
[    0.000000] reserve setup_data: [mem 0x000000000008e000-0x000000000008ffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000090000-0x000000000009ffff] usable
[    0.000000] reserve setup_data: [mem 0x00000000000a0000-0x00000000000bffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000020200000-0x000000003fffffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000040000000-0x00000000401fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000040200000-0x0000000089962017] usable
[    0.000000] reserve setup_data: [mem 0x0000000089962018-0x0000000089973212] usable
[    0.000000] reserve setup_data: [mem 0x0000000089973213-0x0000000089985017] usable
[    0.000000] reserve setup_data: [mem 0x0000000089985018-0x00000000899a0a57] usable
[    0.000000] reserve setup_data: [mem 0x00000000899a0a58-0x000000008ed33fff] usable
[    0.000000] reserve setup_data: [mem 0x000000008ed34000-0x000000008ed5efff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x000000008ed5f000-0x000000008ed6dfff] usable
[    0.000000] reserve setup_data: [mem 0x000000008ed6e000-0x000000008ed8efff] ACPI data
[    0.000000] reserve setup_data: [mem 0x000000008ed8f000-0x000000008ee5afff] usable
[    0.000000] reserve setup_data: [mem 0x000000008ee5b000-0x000000008ee8efff] reserved
[    0.000000] reserve setup_data: [mem 0x000000008ee8f000-0x000000008eed6fff] usable
[    0.000000] reserve setup_data: [mem 0x000000008eed7000-0x000000008eefefff] reserved
[    0.000000] reserve setup_data: [mem 0x000000008eeff000-0x000000008efa2fff] usable
[    0.000000] reserve setup_data: [mem 0x000000008efa3000-0x000000008f8fffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000e00f8000-0x00000000e00f8fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ffed8000-0x00000000ffefffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000036fefffff] usable
[    0.000000] efi: EFI v1.1 by Apple
[    0.000000] efi: ACPI=0x8ed8e000 ACPI 2.0=0x8ed8e014 SMBIOS=0x8ed3b000 INITRD=0x89a02b98
[    0.000000] efi: Not removing mem238: MMIO range=[0xe00f8000-0xe00f8fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem239: MMIO range=[0xfed1c000-0xfed1ffff] (16KB) from e820 map
[    0.000000] efi: Not removing mem240: MMIO range=[0xffed8000-0xffefffff] (160KB) from e820 map
[    0.000000] SMBIOS 2.4 present.
[    0.000000] DMI: Apple Inc. iMac12,1/Mac-942B5BF58194151B, BIOS 87.0.0.0.0 06/14/2019
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2500.044 MHz processor
[    0.000099] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000103] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000115] last_pfn = 0x36ff00 max_arch_pfn = 0x400000000
[    0.000121] MTRR map: 5 entries (4 fixed + 1 variable; max 24), built from 10 variable MTRRs
[    0.000123] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001005] last_pfn = 0x8efa3 max_arch_pfn = 0x400000000
[    0.021556] Secure boot disabled
[    0.021557] RAMDISK: [mem 0x7d30c000-0x7fffffff]
[    0.021598] ACPI: Early table checksum verification disabled
[    0.021601] ACPI: RSDP 0x000000008ED8E014 000024 (v02 APPLE )
[    0.021607] ACPI: XSDT 0x000000008ED8E1C0 0000A4 (v01 APPLE  Apple00  0000F000      01000013)
[    0.021614] ACPI: FACP 0x000000008ED8C000 0000F4 (v04 APPLE  Apple00  0000F000 Loki 0000005F)
[    0.021621] ACPI: DSDT 0x000000008ED81000 0053FB (v01 APPLE  iMac     00210001 INTL 20061109)
[    0.021626] ACPI: FACS 0x000000008ED3E000 000040
[    0.021629] ACPI: FACS 0x000000008ED3E000 000040
[    0.021633] ACPI: HPET 0x000000008ED8B000 000038 (v01 APPLE  Apple00  00000001 Loki 0000005F)
[    0.021637] ACPI: APIC 0x000000008ED8A000 0000BC (v02 APPLE  Apple00  00000001 Loki 0000005F)
[    0.021641] ACPI: SBST 0x000000008ED88000 000030 (v01 APPLE  Apple00  00000001 Loki 0000005F)
[    0.021645] ACPI: ECDT 0x000000008ED87000 000053 (v01 APPLE  Apple00  00000001 Loki 0000005F)
[    0.021648] ACPI: SSDT 0x000000008ED7E000 00020D (v01 APPLE  SataAhci 00001000 INTL 20061109)
[    0.021653] ACPI: SSDT 0x000000008ED7C000 0000B1 (v01 APPLE  SmcDppt  00001000 INTL 20061109)
[    0.021656] ACPI: SSDT 0x000000008ED7A000 000646 (v01 APPLE  UsbNoRmh 00001000 INTL 20061109)
[    0.021660] ACPI: SSDT 0x000000008ED78000 00013D (v01 APPLE  SataPrt1 00001000 INTL 20061109)
[    0.021664] ACPI: SSDT 0x000000008ED77000 0000A0 (v02 APPLE  IGHda    00001000 INTL 20061109)
[    0.021668] ACPI: SSDT 0x000000008ED75000 000032 (v01 APPLE  SsdtS3   00001000 INTL 20061109)
[    0.021672] ACPI: SSDT 0x000000008ED74000 0004C4 (v01 PmRef  Cpu0Ist  00003000 INTL 20061109)
[    0.021676] ACPI: SSDT 0x000000008ED73000 0009B1 (v01 PmRef  CpuPm    00003000 INTL 20061109)
[    0.021680] ACPI: SSDT 0x000000008ED72000 000315 (v01 PmRef  Cpu0Tst  00003000 INTL 20061109)
[    0.021684] ACPI: SSDT 0x000000008ED71000 00037A (v01 PmRef  ApTst    00003000 INTL 20061109)
[    0.021688] ACPI: MCFG 0x000000008ED89000 00003C (v01 APPLE  Apple00  00000001 Loki 0000005F)
[    0.021691] ACPI: Reserving FACP table memory at [mem 0x8ed8c000-0x8ed8c0f3]
[    0.021693] ACPI: Reserving DSDT table memory at [mem 0x8ed81000-0x8ed863fa]
[    0.021694] ACPI: Reserving FACS table memory at [mem 0x8ed3e000-0x8ed3e03f]
[    0.021695] ACPI: Reserving FACS table memory at [mem 0x8ed3e000-0x8ed3e03f]
[    0.021696] ACPI: Reserving HPET table memory at [mem 0x8ed8b000-0x8ed8b037]
[    0.021697] ACPI: Reserving APIC table memory at [mem 0x8ed8a000-0x8ed8a0bb]
[    0.021698] ACPI: Reserving SBST table memory at [mem 0x8ed88000-0x8ed8802f]
[    0.021699] ACPI: Reserving ECDT table memory at [mem 0x8ed87000-0x8ed87052]
[    0.021700] ACPI: Reserving SSDT table memory at [mem 0x8ed7e000-0x8ed7e20c]
[    0.021701] ACPI: Reserving SSDT table memory at [mem 0x8ed7c000-0x8ed7c0b0]
[    0.021702] ACPI: Reserving SSDT table memory at [mem 0x8ed7a000-0x8ed7a645]
[    0.021703] ACPI: Reserving SSDT table memory at [mem 0x8ed78000-0x8ed7813c]
[    0.021704] ACPI: Reserving SSDT table memory at [mem 0x8ed77000-0x8ed7709f]
[    0.021705] ACPI: Reserving SSDT table memory at [mem 0x8ed75000-0x8ed75031]
[    0.021707] ACPI: Reserving SSDT table memory at [mem 0x8ed74000-0x8ed744c3]
[    0.021708] ACPI: Reserving SSDT table memory at [mem 0x8ed73000-0x8ed739b0]
[    0.021709] ACPI: Reserving SSDT table memory at [mem 0x8ed72000-0x8ed72314]
[    0.021710] ACPI: Reserving SSDT table memory at [mem 0x8ed71000-0x8ed71379]
[    0.021711] ACPI: Reserving MCFG table memory at [mem 0x8ed89000-0x8ed8903b]
[    0.021719] ACPI: DMI detected to setup _OSI("Darwin"): Apple hardware
[    0.021767] No NUMA configuration found
[    0.021768] Faking a node at [mem 0x0000000000000000-0x000000036fefffff]
[    0.021772] NODE_DATA(0) allocated [mem 0x36fefb000-0x36fefffff]
[    0.021807] Zone ranges:
[    0.021808]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.021810]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.021812]   Normal   [mem 0x0000000100000000-0x000000036fefffff]
[    0.021814]   Device   empty
[    0.021815] Movable zone start for each node
[    0.021816] Early memory node ranges
[    0.021817]   node   0: [mem 0x0000000000001000-0x000000000008dfff]
[    0.021818]   node   0: [mem 0x0000000000090000-0x000000000009ffff]
[    0.021819]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
[    0.021821]   node   0: [mem 0x0000000020200000-0x000000003fffffff]
[    0.021822]   node   0: [mem 0x0000000040200000-0x000000008ed33fff]
[    0.021823]   node   0: [mem 0x000000008ed5f000-0x000000008ed6dfff]
[    0.021824]   node   0: [mem 0x000000008ed8f000-0x000000008ee5afff]
[    0.021825]   node   0: [mem 0x000000008ee8f000-0x000000008eed6fff]
[    0.021826]   node   0: [mem 0x000000008eeff000-0x000000008efa2fff]
[    0.021827]   node   0: [mem 0x0000000100000000-0x000000036fefffff]
[    0.021830] Initmem setup node 0 [mem 0x0000000000001000-0x000000036fefffff]
[    0.021835] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.021837] On node 0, zone DMA: 2 pages in unavailable ranges
[    0.021860] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.023589] On node 0, zone DMA32: 512 pages in unavailable ranges
[    0.025860] On node 0, zone DMA32: 512 pages in unavailable ranges
[    0.025865] On node 0, zone DMA32: 43 pages in unavailable ranges
[    0.025868] On node 0, zone DMA32: 33 pages in unavailable ranges
[    0.025870] On node 0, zone DMA32: 52 pages in unavailable ranges
[    0.025872] On node 0, zone DMA32: 40 pages in unavailable ranges
[    0.043839] On node 0, zone Normal: 4189 pages in unavailable ranges
[    0.043846] On node 0, zone Normal: 256 pages in unavailable ranges
[    0.044027] ACPI: PM-Timer IO Port: 0x408
[    0.044036] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.044038] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.044039] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.044040] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.044041] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.044042] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.044043] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.044044] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.044055] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.044058] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.044061] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.044066] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.044067] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.044073] TSC deadline timer available
[    0.044074] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.044098] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.044101] PM: hibernation: Registered nosave memory: [mem 0x0008e000-0x0008ffff]
[    0.044103] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000bffff]
[    0.044104] PM: hibernation: Registered nosave memory: [mem 0x000c0000-0x000fffff]
[    0.044106] PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
[    0.044109] PM: hibernation: Registered nosave memory: [mem 0x40000000-0x401fffff]
[    0.044111] PM: hibernation: Registered nosave memory: [mem 0x89962000-0x89962fff]
[    0.044113] PM: hibernation: Registered nosave memory: [mem 0x89973000-0x89973fff]
[    0.044115] PM: hibernation: Registered nosave memory: [mem 0x89985000-0x89985fff]
[    0.044117] PM: hibernation: Registered nosave memory: [mem 0x899a0000-0x899a0fff]
[    0.044119] PM: hibernation: Registered nosave memory: [mem 0x8ed34000-0x8ed5efff]
[    0.044122] PM: hibernation: Registered nosave memory: [mem 0x8ed6e000-0x8ed8efff]
[    0.044124] PM: hibernation: Registered nosave memory: [mem 0x8ee5b000-0x8ee8efff]
[    0.044126] PM: hibernation: Registered nosave memory: [mem 0x8eed7000-0x8eefefff]
[    0.044128] PM: hibernation: Registered nosave memory: [mem 0x8efa3000-0x8f8fffff]
[    0.044129] PM: hibernation: Registered nosave memory: [mem 0x8f900000-0xe00f7fff]
[    0.044130] PM: hibernation: Registered nosave memory: [mem 0xe00f8000-0xe00f8fff]
[    0.044131] PM: hibernation: Registered nosave memory: [mem 0xe00f9000-0xfed1bfff]
[    0.044132] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.044133] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xffed7fff]
[    0.044134] PM: hibernation: Registered nosave memory: [mem 0xffed8000-0xffefffff]
[    0.044135] PM: hibernation: Registered nosave memory: [mem 0xfff00000-0xffffffff]
[    0.044137] [mem 0x8f900000-0xe00f7fff] available for PCI devices
[    0.044140] Booting paravirtualized kernel on bare hardware
[    0.044142] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.051854] setup_percpu: NR_CPUS:320 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[    0.052193] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
[    0.052202] pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
[    0.052205] pcpu-alloc: [0] 0 1 2 3
[    0.052227] Kernel command line: root=UUID=dcd2885d-ae78-4f92-b3e7-c8507caef8a3 rw quiet splash udev.log_priority=3 initrd=\boot\initramfs-6.6-x86_64.img
[    0.052321] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.054090] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.055020] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.055090] Fallback order for Node 0: 0
[    0.055094] Built 1 zonelists, mobility grouping on.  Total pages: 3090771
[    0.055096] Policy zone: Normal
[    0.055371] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.055377] software IO TLB: area num 4.
[    0.104035] Memory: 12109328K/12559968K available (18432K kernel code, 2150K rwdata, 13116K rodata, 3448K init, 3616K bss, 450384K reserved, 0K cma-reserved)
[    0.113549] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.113681] Kernel/User page tables isolation: enabled
[    0.113768] ftrace: allocating 49251 entries in 193 pages
[    0.122813] ftrace: allocated 193 pages with 3 groups
[    0.122962] Dynamic Preempt: full
[    0.123134] rcu: Preemptible hierarchical RCU implementation.
[    0.123135] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.123137] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.123138] 	Trampoline variant of Tasks RCU enabled.
[    0.123139] 	Rude variant of Tasks RCU enabled.
[    0.123139] 	Tracing variant of Tasks RCU enabled.
[    0.123140] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.123141] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.126976] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[    0.127186] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.127320] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.127407] Console: colour dummy device 80x25
[    0.127410] printk: console [tty0] enabled
[    0.127890] ACPI: Core revision 20230628
[    0.128170] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.128184] APIC: Switch to symmetric I/O mode setup
[    0.128254] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.128684] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.144851] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2409637a2ca, max_idle_ns: 440795265956 ns
[    0.144856] Calibrating delay loop (skipped), value calculated using timer frequency.. 5002.42 BogoMIPS (lpj=8333480)
[    0.144883] CPU0: Thermal monitoring enabled (TM1)
[    0.144904] process: using mwait in idle threads
[    0.144908] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.144909] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.144913] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.144915] Spectre V2 : Mitigation: Retpolines
[    0.144916] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.144917] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.144918] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.144920] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.144922] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.144924] MDS: Mitigation: Clear CPU buffers
[    0.144925] MMIO Stale Data: Unknown: No mitigations
[    0.144929] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.144930] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.144931] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.144933] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.144935] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.167050] Freeing SMP alternatives memory: 40K
[    0.167056] pid_max: default: 32768 minimum: 301
[    0.172308] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
[    0.173318] landlock: Up and running.
[    0.173320] Yama: becoming mindful.
[    0.173326] LSM support for eBPF active
[    0.173633] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.173656] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.174582] smpboot: CPU0: Intel(R) Core(TM) i5-2400S CPU @ 2.50GHz (family: 0x6, model: 0x2a, stepping: 0x7)
[    0.174838] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.174854] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.174854] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.174854] Performance Events: PEBS fmt1+, SandyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.174854] ... version:                3
[    0.174854] ... bit width:              48
[    0.174854] ... generic registers:      8
[    0.174854] ... value mask:             0000ffffffffffff
[    0.174854] ... max period:             00007fffffffffff
[    0.174854] ... fixed-purpose events:   3
[    0.174854] ... event mask:             00000007000000ff
[    0.174854] signal: max sigframe size: 1776
[    0.174854] Estimated ratio of average max frequency by base frequency (times 1024): 1064
[    0.174854] rcu: Hierarchical SRCU implementation.
[    0.174854] rcu: 	Max phase no-delay instances is 1000.
[    0.174854] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.174854] smp: Bringing up secondary CPUs ...
[    0.174854] smpboot: x86: Booting SMP configuration:
[    0.174854] .... node  #0, CPUs:      #1 #2 #3
[    0.178259] smp: Brought up 1 node, 4 CPUs
[    0.178259] smpboot: Max logical packages: 1
[    0.178259] smpboot: Total of 4 processors activated (20008.70 BogoMIPS)
[    0.181782] devtmpfs: initialized
[    0.181782] x86/mm: Memory block size: 128MB
[    0.182966] ACPI: PM: Registering ACPI NVS region [mem 0x8ed34000-0x8ed5efff] (176128 bytes)
[    0.183021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.183031] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.183272] pinctrl core: initialized pinctrl subsystem
[    0.183414] PM: RTC time: 16:03:52, date: 2024-12-18
[    0.184205] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.184512] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.185036] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.185203] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.185570] audit: initializing netlink subsys (disabled)
[    0.185592] audit: type=2000 audit(1734537832.056:1): state=initialized audit_enabled=0 res=1
[    0.185592] thermal_sys: Registered thermal governor 'fair_share'
[    0.185592] thermal_sys: Registered thermal governor 'bang_bang'
[    0.185592] thermal_sys: Registered thermal governor 'step_wise'
[    0.185592] thermal_sys: Registered thermal governor 'user_space'
[    0.185592] thermal_sys: Registered thermal governor 'power_allocator'
[    0.185592] cpuidle: using governor ladder
[    0.185592] cpuidle: using governor menu
[    0.185592] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.185592] PCI: MMCONFIG for domain 0000 [bus 00-9b] at [mem 0xe0000000-0xe9bfffff] (base 0xe0000000)
[    0.185592] PCI: Using configuration type 1 for base access
[    0.185592] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.185764] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.185773] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.185773] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.185773] ACPI: Disabled all _OSI OS vendors
[    0.185773] ACPI: Added _OSI(Module Device)
[    0.185773] ACPI: Added _OSI(Processor Device)
[    0.185773] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.185773] ACPI: Added _OSI(Processor Aggregator Device)
[    0.185773] ACPI: Added _OSI(Darwin)
[    0.192853] ACPI: 11 ACPI AML tables successfully acquired and loaded
[    0.193307] ACPI: EC: EC started
[    0.193309] ACPI: EC: interrupt blocked
[    0.193504] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.193506] ACPI: EC: Boot ECDT EC used to handle transactions
[    0.193723] ACPI: BIOS _OSI(Darwin) query honored via DMI
[    0.193985] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.198588] ACPI: Dynamic OEM Table Load:
[    0.198597] ACPI: SSDT 0xFFFF888100944000 000781 (v01 PmRef  Cpu0Cst  00003001 INTL 20061109)
[    0.201664] ACPI: Dynamic OEM Table Load:
[    0.201671] ACPI: SSDT 0xFFFF888100F66000 0003A4 (v01 PmRef  ApIst    00003000 INTL 20061109)
[    0.202203] ACPI: Dynamic OEM Table Load:
[    0.202209] ACPI: SSDT 0xFFFF888100254800 000119 (v01 PmRef  ApCst    00003000 INTL 20061109)
[    0.203113] ACPI: _OSC evaluated successfully for all CPUs
[    0.203115] ACPI: Interpreter enabled
[    0.203133] ACPI: PM: (supports S0 S3 S4 S5)
[    0.203134] ACPI: Using IOAPIC for interrupt routing
[    0.203571] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.203573] PCI: Using E820 reservations for host bridge windows
[    0.203736] ACPI: Enabled 6 GPEs in block 00 to 3F
[    0.209943] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.209951] acpi PNP0A08:00: _OSC: OS assumes control of [PCIeHotplug SHPCHotplug AER PCIeCapability LTR DPC]
[    0.209963] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-9b] only partially covers this bridge
[    0.210362] PCI host bridge to bus 0000:00
[    0.210365] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.210368] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.210371] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
[    0.210373] pci_bus 0000:00: root bus resource [mem 0x8f900000-0xfeafffff window]
[    0.210375] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
[    0.210377] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.210393] pci 0000:00:00.0: [8086:0100] type 00 class 0x060000
[    0.210499] pci 0000:00:01.0: [8086:0101] type 01 class 0x060400
[    0.210539] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.210640] pci 0000:00:02.0: [8086:0102] type 00 class 0x038000
[    0.210648] pci 0000:00:02.0: reg 0x10: [mem 0xa8000000-0xa83fffff 64bit]
[    0.210655] pci 0000:00:02.0: reg 0x18: [mem 0xa0000000-0xa7ffffff 64bit pref]
[    0.210659] pci 0000:00:02.0: reg 0x20: [io  0x3000-0x303f]
[    0.210769] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[    0.210790] pci 0000:00:16.0: reg 0x10: [mem 0xa8907100-0xa890710f 64bit]
[    0.210864] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.210929] pci 0000:00:1a.0: [8086:1c2c] type 00 class 0x0c0300
[    0.210970] pci 0000:00:1a.0: reg 0x20: [io  0x3140-0x315f]
[    0.211095] pci 0000:00:1a.7: [8086:1c2d] type 00 class 0x0c0320
[    0.211112] pci 0000:00:1a.7: reg 0x10: [mem 0xa8906c00-0xa8906fff]
[    0.211197] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[    0.211625] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[    0.211642] pci 0000:00:1b.0: reg 0x10: [mem 0xa8900000-0xa8903fff 64bit]
[    0.211712] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.211829] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[    0.211922] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.212048] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[    0.212140] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.212255] pci 0000:00:1c.2: [8086:1c14] type 01 class 0x060400
[    0.212347] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.212462] pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
[    0.212555] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.212675] pci 0000:00:1d.0: [8086:1c27] type 00 class 0x0c0300
[    0.212717] pci 0000:00:1d.0: reg 0x20: [io  0x30e0-0x30ff]
[    0.212839] pci 0000:00:1d.7: [8086:1c26] type 00 class 0x0c0320
[    0.212855] pci 0000:00:1d.7: reg 0x10: [mem 0xa8906800-0xa8906bff]
[    0.212940] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.213345] pci 0000:00:1f.0: [8086:1c44] type 00 class 0x060100
[    0.213540] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
[    0.213553] pci 0000:00:1f.2: reg 0x10: [io  0x3168-0x316f]
[    0.213560] pci 0000:00:1f.2: reg 0x14: [io  0x317c-0x317f]
[    0.213568] pci 0000:00:1f.2: reg 0x18: [io  0x3160-0x3167]
[    0.213575] pci 0000:00:1f.2: reg 0x1c: [io  0x3178-0x317b]
[    0.213582] pci 0000:00:1f.2: reg 0x20: [io  0x3060-0x307f]
[    0.213589] pci 0000:00:1f.2: reg 0x24: [mem 0xa8906000-0xa89067ff]
[    0.213630] pci 0000:00:1f.2: PME# supported from D3hot
[    0.213709] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[    0.213725] pci 0000:00:1f.3: reg 0x10: [mem 0xa8907000-0xa89070ff 64bit]
[    0.213740] pci 0000:00:1f.3: reg 0x20: [io  0xefa0-0xefbf]
[    0.213870] pci 0000:01:00.0: [1002:6741] type 00 class 0x030000
[    0.213887] pci 0000:01:00.0: reg 0x10: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.213897] pci 0000:01:00.0: reg 0x18: [mem 0xa8800000-0xa881ffff 64bit]
[    0.213905] pci 0000:01:00.0: reg 0x20: [io  0x2000-0x20ff]
[    0.213918] pci 0000:01:00.0: reg 0x30: [mem 0xa8820000-0xa883ffff pref]
[    0.213924] pci 0000:01:00.0: enabling Extended Tags
[    0.213938] pci 0000:01:00.0: BAR 0: assigned to efifb
[    0.213971] pci 0000:01:00.0: supports D1 D2
[    0.214168] pci 0000:01:00.1: [1002:aa90] type 00 class 0x040300
[    0.214183] pci 0000:01:00.1: reg 0x10: [mem 0xa8840000-0xa8843fff 64bit]
[    0.214211] pci 0000:01:00.1: enabling Extended Tags
[    0.214253] pci 0000:01:00.1: supports D1 D2
[    0.214444] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.214447] pci 0000:00:01.0:   bridge window [io  0x2000-0x2fff]
[    0.214450] pci 0000:00:01.0:   bridge window [mem 0xa8800000-0xa88fffff]
[    0.214453] pci 0000:00:01.0:   bridge window [mem 0x90000000-0x9fffffff 64bit pref]
[    0.214544] pci 0000:02:00.0: [14e4:16b4] type 00 class 0x020000
[    0.214578] pci 0000:02:00.0: reg 0x10: [mem 0xa8400000-0xa840ffff 64bit pref]
[    0.214601] pci 0000:02:00.0: reg 0x18: [mem 0xa8410000-0xa841ffff 64bit pref]
[    0.214767] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.215009] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.215016] pci 0000:00:1c.0:   bridge window [mem 0xa8700000-0xa87fffff]
[    0.215021] pci 0000:00:1c.0:   bridge window [mem 0xa8400000-0xa84fffff 64bit pref]
[    0.215105] pci 0000:03:00.0: [168c:0030] type 00 class 0x028000
[    0.215137] pci 0000:03:00.0: reg 0x10: [mem 0xa8600000-0xa861ffff 64bit]
[    0.215200] pci 0000:03:00.0: reg 0x30: [mem 0xffff0000-0xffffffff pref]
[    0.215299] pci 0000:03:00.0: supports D1 D2
[    0.215300] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.215495] pci 0000:00:1c.1: PCI bridge to [bus 03]
[    0.215501] pci 0000:00:1c.1:   bridge window [mem 0xa8600000-0xa86fffff]
[    0.215589] pci 0000:04:00.0: [11c1:5901] type 00 class 0x0c0010
[    0.215624] pci 0000:04:00.0: reg 0x10: [mem 0xa8500000-0xa8500fff 64bit]
[    0.215795] pci 0000:04:00.0: supports D1 D2
[    0.215797] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.216283] pci 0000:00:1c.2: PCI bridge to [bus 04]
[    0.216290] pci 0000:00:1c.2:   bridge window [mem 0xa8500000-0xa85fffff]
[    0.216379] pci 0000:05:00.0: [8086:1513] type 01 class 0x060400
[    0.216448] pci 0000:05:00.0: enabling Extended Tags
[    0.216551] pci 0000:05:00.0: supports D1 D2
[    0.216552] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.216857] pci 0000:00:1c.4: PCI bridge to [bus 05-9b]
[    0.216862] pci 0000:00:1c.4:   bridge window [io  0x4000-0x4fff]
[    0.216865] pci 0000:00:1c.4:   bridge window [mem 0xa8a00000-0xacefffff]
[    0.216871] pci 0000:00:1c.4:   bridge window [mem 0xacf00000-0xb0efffff 64bit pref]
[    0.217001] acpiphp: Slot [3] registered
[    0.217036] acpiphp: Slot [4] registered
[    0.217087] pci 0000:06:00.0: [8086:1513] type 01 class 0x060400
[    0.217161] pci 0000:06:00.0: enabling Extended Tags
[    0.217270] pci 0000:06:00.0: supports D1 D2
[    0.217271] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.217515] pci 0000:06:03.0: [8086:1513] type 01 class 0x060400
[    0.217579] pci 0000:06:03.0: enabling Extended Tags
[    0.217692] pci 0000:06:03.0: supports D1 D2
[    0.217694] pci 0000:06:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.217932] pci 0000:06:04.0: [8086:1513] type 01 class 0x060400
[    0.217996] pci 0000:06:04.0: enabling Extended Tags
[    0.218109] pci 0000:06:04.0: supports D1 D2
[    0.218110] pci 0000:06:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.218362] pci 0000:06:05.0: [8086:1513] type 01 class 0x060400
[    0.218426] pci 0000:06:05.0: enabling Extended Tags
[    0.218539] pci 0000:06:05.0: supports D1 D2
[    0.218541] pci 0000:06:05.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.218783] pci 0000:06:06.0: [8086:1513] type 01 class 0x060400
[    0.218847] pci 0000:06:06.0: enabling Extended Tags
[    0.218960] pci 0000:06:06.0: supports D1 D2
[    0.218961] pci 0000:06:06.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.219213] pci 0000:05:00.0: PCI bridge to [bus 06-6b]
[    0.219225] pci 0000:05:00.0:   bridge window [mem 0xa8a00000-0xa8efffff]
[    0.219301] acpiphp: Slot [1] registered
[    0.219346] pci 0000:07:00.0: [8086:1513] type 00 class 0x088000
[    0.219374] pci 0000:07:00.0: reg 0x10: [mem 0xa8c00000-0xa8c3ffff]
[    0.219390] pci 0000:07:00.0: reg 0x14: [mem 0xa8c40000-0xa8c40fff]
[    0.219473] pci 0000:07:00.0: enabling Extended Tags
[    0.219608] pci 0000:07:00.0: supports D1 D2
[    0.219609] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.219907] pci 0000:06:00.0: PCI bridge to [bus 07]
[    0.219919] pci 0000:06:00.0:   bridge window [mem 0xa8c00000-0xa8cfffff]
[    0.219980] pci 0000:06:03.0: PCI bridge to [bus 08]
[    0.219991] pci 0000:06:03.0:   bridge window [mem 0xa8b00000-0xa8bfffff]
[    0.220061] pci 0000:06:04.0: PCI bridge to [bus 09-39]
[    0.220073] pci 0000:06:04.0:   bridge window [mem 0xa8d00000-0xa8dfffff]
[    0.220141] pci 0000:06:05.0: PCI bridge to [bus 3a-6a]
[    0.220152] pci 0000:06:05.0:   bridge window [mem 0xa8e00000-0xa8efffff]
[    0.220214] pci 0000:06:06.0: PCI bridge to [bus 6b]
[    0.220225] pci 0000:06:06.0:   bridge window [mem 0xa8a00000-0xa8afffff]
[    0.222334] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.222337] ACPI: PCI: Interrupt link LNKA disabled
[    0.222406] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.222408] ACPI: PCI: Interrupt link LNKB disabled
[    0.222480] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.222482] ACPI: PCI: Interrupt link LNKC disabled
[    0.222547] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.222549] ACPI: PCI: Interrupt link LNKD disabled
[    0.222613] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.222615] ACPI: PCI: Interrupt link LNKE disabled
[    0.222679] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.222680] ACPI: PCI: Interrupt link LNKF disabled
[    0.222745] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.222746] ACPI: PCI: Interrupt link LNKG disabled
[    0.222810] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.222812] ACPI: PCI: Interrupt link LNKH disabled
[    0.223034] ACPI: EC: interrupt unblocked
[    0.223036] ACPI: EC: event unblocked
[    0.223038] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.223039] ACPI: EC: GPE=0x17
[    0.223041] ACPI: \_SB_.PCI0.LPCB.EC__: Boot ECDT EC initialization complete
[    0.223043] ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
[    0.223115] iommu: Default domain type: Translated
[    0.223115] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.223115] SCSI subsystem initialized
[    0.223115] libata version 3.00 loaded.
[    0.223115] ACPI: bus type USB registered
[    0.223115] usbcore: registered new interface driver usbfs
[    0.223115] usbcore: registered new interface driver hub
[    0.223115] usbcore: registered new device driver usb
[    0.223115] pps_core: LinuxPPS API ver. 1 registered
[    0.223115] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.223115] PTP clock support registered
[    0.223115] EDAC MC: Ver: 3.0.0
[    0.223115] efivars: Registered efivars operations
[    0.223115] NetLabel: Initializing
[    0.223115] NetLabel:  domain hash size = 128
[    0.223115] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.223115] NetLabel:  unlabeled traffic allowed by default
[    0.223115] mctp: management component transport protocol core
[    0.223115] NET: Registered PF_MCTP protocol family
[    0.223115] PCI: Using ACPI for IRQ routing
[    0.231386] PCI: pci_cache_line_size set to 64 bytes
[    0.231463] e820: reserve RAM buffer [mem 0x0008e000-0x0008ffff]
[    0.231466] e820: reserve RAM buffer [mem 0x89962018-0x8bffffff]
[    0.231468] e820: reserve RAM buffer [mem 0x89985018-0x8bffffff]
[    0.231469] e820: reserve RAM buffer [mem 0x8ed34000-0x8fffffff]
[    0.231471] e820: reserve RAM buffer [mem 0x8ed6e000-0x8fffffff]
[    0.231472] e820: reserve RAM buffer [mem 0x8ee5b000-0x8fffffff]
[    0.231473] e820: reserve RAM buffer [mem 0x8eed7000-0x8fffffff]
[    0.231475] e820: reserve RAM buffer [mem 0x8efa3000-0x8fffffff]
[    0.231476] e820: reserve RAM buffer [mem 0x36ff00000-0x36fffffff]
[    0.231533] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.231535] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.231536] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.231540] vgaarb: loaded
[    0.231608] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.231617] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.233679] clocksource: Switched to clocksource tsc-early
[    0.234292] VFS: Disk quotas dquot_6.6.0
[    0.234329] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.234434] pnp: PnP ACPI init
[    0.234628] system 00:00: [mem 0xfed00000-0xfed003ff] has been reserved
[    0.234690] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.234693] system 00:01: [io  0x1000-0x100f] has been reserved
[    0.234695] system 00:01: [io  0xffff] has been reserved
[    0.234697] system 00:01: [io  0xffff] has been reserved
[    0.234699] system 00:01: [io  0x0400-0x047f] has been reserved
[    0.234701] system 00:01: [io  0x0500-0x057f] has been reserved
[    0.234702] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.234777] system 00:03: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.234777] system 00:03: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.234777] system 00:03: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.234777] system 00:03: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.234777] system 00:03: [mem 0xe0000000-0xefffffff] could not be reserved
[    0.234777] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.234777] system 00:03: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.234777] system 00:03: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.234777] system 00:03: [mem 0xff000000-0xffffffff] could not be reserved
[    0.234777] system 00:03: [mem 0xfee00000-0xfeefffff] has been reserved
[    0.234777] pnp: PnP ACPI: found 4 devices
[    0.234777] pci 0000:01:00.0: assigning 67 device properties
[    0.234777] pci 0000:04:00.0: assigning 2 device properties
[    0.234777] pci 0000:07:00.0: assigning 3 device properties
[    0.234777] pci 0000:00:1b.0: assigning 4 device properties
[    0.239234] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.239434] NET: Registered PF_INET protocol family
[    0.239627] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.244153] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.244192] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.244277] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.244586] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.244941] TCP: Hash tables configured (established 131072 bind 65536)
[    0.245105] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.245184] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.245242] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.245394] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.245402] NET: Registered PF_XDP protocol family
[    0.245407] pci 0000:03:00.0: can't claim BAR 6 [mem 0xffff0000-0xffffffff pref]: no compatible bridge window
[    0.245416] pci 0000:06:03.0: bridge window [io  0x1000-0x0fff] to [bus 08] add_size 1000
[    0.245420] pci 0000:06:03.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 08] add_size 200000 add_align 100000
[    0.245423] pci 0000:06:04.0: bridge window [io  0x1000-0x0fff] to [bus 09-39] add_size 1000
[    0.245425] pci 0000:06:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 09-39] add_size 200000 add_align 100000
[    0.245428] pci 0000:06:05.0: bridge window [io  0x1000-0x0fff] to [bus 3a-6a] add_size 1000
[    0.245430] pci 0000:06:05.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3a-6a] add_size 200000 add_align 100000
[    0.245433] pci 0000:06:06.0: bridge window [io  0x1000-0x0fff] to [bus 6b] add_size 1000
[    0.245434] pci 0000:06:06.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 6b] add_size 200000 add_align 100000
[    0.245438] pci 0000:05:00.0: bridge window [io  0x1000-0x0fff] to [bus 06-6b] add_size 4000
[    0.245441] pci 0000:05:00.0: bridge window [mem 0x00100000-0x004fffff 64bit pref] to [bus 06-6b] add_size 800000 add_align 100000
[    0.245449] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.245452] pci 0000:00:01.0:   bridge window [io  0x2000-0x2fff]
[    0.245456] pci 0000:00:01.0:   bridge window [mem 0xa8800000-0xa88fffff]
[    0.245458] pci 0000:00:01.0:   bridge window [mem 0x90000000-0x9fffffff 64bit pref]
[    0.245462] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.245466] pci 0000:00:1c.0:   bridge window [mem 0xa8700000-0xa87fffff]
[    0.245470] pci 0000:00:1c.0:   bridge window [mem 0xa8400000-0xa84fffff 64bit pref]
[    0.245478] pci 0000:03:00.0: BAR 6: assigned [mem 0xa8620000-0xa862ffff pref]
[    0.245481] pci 0000:00:1c.1: PCI bridge to [bus 03]
[    0.245485] pci 0000:00:1c.1:   bridge window [mem 0xa8600000-0xa86fffff]
[    0.245493] pci 0000:00:1c.2: PCI bridge to [bus 04]
[    0.245497] pci 0000:00:1c.2:   bridge window [mem 0xa8500000-0xa85fffff]
[    0.245506] pci 0000:05:00.0: BAR 15: assigned [mem 0xacf00000-0xadafffff 64bit pref]
[    0.245508] pci 0000:05:00.0: BAR 13: no space for [io  size 0x4000]
[    0.245510] pci 0000:05:00.0: BAR 13: failed to assign [io  size 0x4000]
[    0.245512] pci 0000:05:00.0: BAR 13: no space for [io  size 0x4000]
[    0.245514] pci 0000:05:00.0: BAR 13: failed to assign [io  size 0x4000]
[    0.245518] pci 0000:06:03.0: BAR 15: assigned [mem 0xacf00000-0xad0fffff 64bit pref]
[    0.245521] pci 0000:06:04.0: BAR 15: assigned [mem 0xad100000-0xad2fffff 64bit pref]
[    0.245523] pci 0000:06:05.0: BAR 15: assigned [mem 0xad300000-0xad4fffff 64bit pref]
[    0.245525] pci 0000:06:06.0: BAR 15: assigned [mem 0xad500000-0xad6fffff 64bit pref]
[    0.245527] pci 0000:06:03.0: BAR 13: no space for [io  size 0x1000]
[    0.245528] pci 0000:06:03.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245530] pci 0000:06:04.0: BAR 13: no space for [io  size 0x1000]
[    0.245531] pci 0000:06:04.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245533] pci 0000:06:05.0: BAR 13: no space for [io  size 0x1000]
[    0.245534] pci 0000:06:05.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245536] pci 0000:06:06.0: BAR 13: no space for [io  size 0x1000]
[    0.245537] pci 0000:06:06.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245540] pci 0000:06:06.0: BAR 13: no space for [io  size 0x1000]
[    0.245541] pci 0000:06:06.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245543] pci 0000:06:05.0: BAR 13: no space for [io  size 0x1000]
[    0.245544] pci 0000:06:05.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245546] pci 0000:06:04.0: BAR 13: no space for [io  size 0x1000]
[    0.245547] pci 0000:06:04.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245549] pci 0000:06:03.0: BAR 13: no space for [io  size 0x1000]
[    0.245550] pci 0000:06:03.0: BAR 13: failed to assign [io  size 0x1000]
[    0.245552] pci 0000:06:00.0: PCI bridge to [bus 07]
[    0.245559] pci 0000:06:00.0:   bridge window [mem 0xa8c00000-0xa8cfffff]
[    0.245570] pci 0000:06:03.0: PCI bridge to [bus 08]
[    0.245576] pci 0000:06:03.0:   bridge window [mem 0xa8b00000-0xa8bfffff]
[    0.245581] pci 0000:06:03.0:   bridge window [mem 0xacf00000-0xad0fffff 64bit pref]
[    0.245590] pci 0000:06:04.0: PCI bridge to [bus 09-39]
[    0.245596] pci 0000:06:04.0:   bridge window [mem 0xa8d00000-0xa8dfffff]
[    0.245601] pci 0000:06:04.0:   bridge window [mem 0xad100000-0xad2fffff 64bit pref]
[    0.245609] pci 0000:06:05.0: PCI bridge to [bus 3a-6a]
[    0.245615] pci 0000:06:05.0:   bridge window [mem 0xa8e00000-0xa8efffff]
[    0.245620] pci 0000:06:05.0:   bridge window [mem 0xad300000-0xad4fffff 64bit pref]
[    0.245628] pci 0000:06:06.0: PCI bridge to [bus 6b]
[    0.245635] pci 0000:06:06.0:   bridge window [mem 0xa8a00000-0xa8afffff]
[    0.245639] pci 0000:06:06.0:   bridge window [mem 0xad500000-0xad6fffff 64bit pref]
[    0.245648] pci 0000:05:00.0: PCI bridge to [bus 06-6b]
[    0.245654] pci 0000:05:00.0:   bridge window [mem 0xa8a00000-0xa8efffff]
[    0.245658] pci 0000:05:00.0:   bridge window [mem 0xacf00000-0xadafffff 64bit pref]
[    0.245666] pci 0000:00:1c.4: PCI bridge to [bus 05-9b]
[    0.245669] pci 0000:00:1c.4:   bridge window [io  0x4000-0x4fff]
[    0.245673] pci 0000:00:1c.4:   bridge window [mem 0xa8a00000-0xacefffff]
[    0.245676] pci 0000:00:1c.4:   bridge window [mem 0xacf00000-0xb0efffff 64bit pref]
[    0.245683] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.245685] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.245687] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
[    0.245689] pci_bus 0000:00: resource 7 [mem 0x8f900000-0xfeafffff window]
[    0.245690] pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed44fff window]
[    0.245692] pci_bus 0000:01: resource 0 [io  0x2000-0x2fff]
[    0.245693] pci_bus 0000:01: resource 1 [mem 0xa8800000-0xa88fffff]
[    0.245695] pci_bus 0000:01: resource 2 [mem 0x90000000-0x9fffffff 64bit pref]
[    0.245697] pci_bus 0000:02: resource 1 [mem 0xa8700000-0xa87fffff]
[    0.245698] pci_bus 0000:02: resource 2 [mem 0xa8400000-0xa84fffff 64bit pref]
[    0.245700] pci_bus 0000:03: resource 1 [mem 0xa8600000-0xa86fffff]
[    0.245702] pci_bus 0000:04: resource 1 [mem 0xa8500000-0xa85fffff]
[    0.245703] pci_bus 0000:05: resource 0 [io  0x4000-0x4fff]
[    0.245705] pci_bus 0000:05: resource 1 [mem 0xa8a00000-0xacefffff]
[    0.245706] pci_bus 0000:05: resource 2 [mem 0xacf00000-0xb0efffff 64bit pref]
[    0.245708] pci_bus 0000:06: resource 1 [mem 0xa8a00000-0xa8efffff]
[    0.245709] pci_bus 0000:06: resource 2 [mem 0xacf00000-0xadafffff 64bit pref]
[    0.245711] pci_bus 0000:07: resource 1 [mem 0xa8c00000-0xa8cfffff]
[    0.245713] pci_bus 0000:08: resource 1 [mem 0xa8b00000-0xa8bfffff]
[    0.245714] pci_bus 0000:08: resource 2 [mem 0xacf00000-0xad0fffff 64bit pref]
[    0.245716] pci_bus 0000:09: resource 1 [mem 0xa8d00000-0xa8dfffff]
[    0.245717] pci_bus 0000:09: resource 2 [mem 0xad100000-0xad2fffff 64bit pref]
[    0.245719] pci_bus 0000:3a: resource 1 [mem 0xa8e00000-0xa8efffff]
[    0.245721] pci_bus 0000:3a: resource 2 [mem 0xad300000-0xad4fffff 64bit pref]
[    0.245722] pci_bus 0000:6b: resource 1 [mem 0xa8a00000-0xa8afffff]
[    0.245724] pci_bus 0000:6b: resource 2 [mem 0xad500000-0xad6fffff 64bit pref]
[    0.246458] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.246535] PCI: CLS 256 bytes, default 64
[    0.246552] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.246553] software IO TLB: mapped [mem 0x0000000085962000-0x0000000089962000] (64MB)
[    0.246618] Trying to unpack rootfs image as initramfs...
[    0.252198] Initialise system trusted keyrings
[    0.252216] Key type blacklist registered
[    0.252294] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.252310] zbud: loaded
[    0.252747] integrity: Platform Keyring initialized
[    0.252751] integrity: Machine keyring initialized
[    0.263992] Key type asymmetric registered
[    0.263997] Asymmetric key parser 'x509' registered
[    0.264026] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.264094] io scheduler mq-deadline registered
[    0.264096] io scheduler kyber registered
[    0.264141] io scheduler bfq registered
[    0.265373] pcieport 0000:06:03.0: enabling device (0000 -> 0002)
[    0.265463] pcieport 0000:06:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
[    0.265660] pcieport 0000:06:04.0: enabling device (0000 -> 0002)
[    0.265742] pcieport 0000:06:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
[    0.265930] pcieport 0000:06:05.0: enabling device (0000 -> 0002)
[    0.266011] pcieport 0000:06:05.0: pciehp: Slot #5 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
[    0.266181] pcieport 0000:06:06.0: enabling device (0000 -> 0002)
[    0.266261] pcieport 0000:06:06.0: pciehp: Slot #6 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
[    0.266468] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.266838] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.266872] ACPI: button: Power Button [PWRB]
[    0.266905] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[    0.266930] ACPI: button: Sleep Button [SLPB]
[    0.266960] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.268247] ACPI: button: Power Button [PWRF]
[    0.270632] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.273300] Non-volatile memory driver v1.3
[    0.273304] Linux agpgart interface v0.103
[    0.273337] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    0.273394] ACPI: bus type drm_connector registered
[    0.273878] ahci 0000:00:1f.2: version 3.0
[    0.284916] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x7 impl SATA mode
[    0.284925] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[    0.305590] scsi host0: ahci
[    0.305967] scsi host1: ahci
[    0.306283] scsi host2: ahci
[    0.306492] scsi host3: ahci
[    0.306671] scsi host4: ahci
[    0.306796] scsi host5: ahci
[    0.306840] ata1: SATA max UDMA/133 abar m2048@0xa8906000 port 0xa8906100 irq 26
[    0.306843] ata2: SATA max UDMA/133 abar m2048@0xa8906000 port 0xa8906180 irq 26
[    0.306845] ata3: SATA max UDMA/133 abar m2048@0xa8906000 port 0xa8906200 irq 26
[    0.306846] ata4: DUMMY
[    0.306847] ata5: DUMMY
[    0.306848] ata6: DUMMY
[    0.307106] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    0.307113] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.307120] uhci_hcd 0000:00:1a.0: detected 2 ports
[    0.307164] uhci_hcd 0000:00:1a.0: irq 21, io port 0x00003140
[    0.307236] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[    0.307240] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.307241] usb usb1: Product: UHCI Host Controller
[    0.307243] usb usb1: Manufacturer: Linux 6.6.65-1-MANJARO uhci_hcd
[    0.307244] usb usb1: SerialNumber: 0000:00:1a.0
[    0.307383] hub 1-0:1.0: USB hub found
[    0.307398] hub 1-0:1.0: 2 ports detected
[    0.307517] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    0.307524] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    0.307536] ehci-pci 0000:00:1d.7: debug port 2
[    0.311458] ehci-pci 0000:00:1d.7: irq 22, io mem 0xa8906800
[    0.321540] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    0.321611] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    0.321614] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.321616] usb usb2: Product: EHCI Host Controller
[    0.321618] usb usb2: Manufacturer: Linux 6.6.65-1-MANJARO ehci_hcd
[    0.321619] usb usb2: SerialNumber: 0000:00:1d.7
[    0.321840] hub 2-0:1.0: USB hub found
[    0.321851] hub 2-0:1.0: 8 ports detected
[    0.322171] ehci-pci 0000:00:1a.7: EHCI Host Controller
[    0.322180] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 3
[    0.322193] ehci-pci 0000:00:1a.7: debug port 2
[    0.326114] ehci-pci 0000:00:1a.7: irq 23, io mem 0xa8906c00
[    0.338219] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    0.338543] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    0.338548] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.338551] usb usb3: Product: EHCI Host Controller
[    0.338552] usb usb3: Manufacturer: Linux 6.6.65-1-MANJARO ehci_hcd
[    0.338554] usb usb3: SerialNumber: 0000:00:1a.7
[    0.338813] hub 3-0:1.0: USB hub found
[    0.338860] hub 3-0:1.0: 6 ports detected
[    0.364953] hub 1-0:1.0: USB hub found
[    0.365001] hub 1-0:1.0: 2 ports detected
[    0.365153] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.365164] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[    0.365172] uhci_hcd 0000:00:1d.0: detected 2 ports
[    0.365214] uhci_hcd 0000:00:1d.0: irq 19, io port 0x000030e0
[    0.365485] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[    0.365490] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.365492] usb usb4: Product: UHCI Host Controller
[    0.365494] usb usb4: Manufacturer: Linux 6.6.65-1-MANJARO uhci_hcd
[    0.365495] usb usb4: SerialNumber: 0000:00:1d.0
[    0.365631] hub 4-0:1.0: USB hub found
[    0.365644] hub 4-0:1.0: 2 ports detected
[    0.365809] usbcore: registered new interface driver usbserial_generic
[    0.365818] usbserial: USB Serial support registered for generic
[    0.365923] rtc_cmos 00:02: RTC can wake from S4
[    0.366176] rtc_cmos 00:02: registered as rtc0
[    0.366209] rtc_cmos 00:02: setting system clock to 2024-12-18T16:03:52 UTC (1734537832)
[    0.366236] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram
[    0.366347] intel_pstate: Intel P-state driver initializing
[    0.366532] ledtrig-cpu: registered to indicate activity on CPUs
[    0.366837] Relocating firmware framebuffer to offset 0x0000000000010000[d] within [mem 0x90000000-0x9fffffff flags 0x14220c]
[    0.367055] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.368129] fbcon: Deferring console take-over
[    0.368134] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.368205] hid: raw HID events driver (C) Jiri Kosina
[    0.368348] drop_monitor: Initializing network drop monitor service
[    0.381438] Initializing XFRM netlink socket
[    0.381677] NET: Registered PF_INET6 protocol family
[    0.501366] Freeing initrd memory: 46032K
[    0.507948] Segment Routing with IPv6
[    0.507951] RPL Segment Routing with IPv6
[    0.507971] In-situ OAM (IOAM) with IPv6
[    0.508010] NET: Registered PF_PACKET protocol family
[    0.508393] microcode: Microcode Update Driver: v2.2.
[    0.508398] IPI shorthand broadcast: enabled
[    0.510473] sched_clock: Marking stable (507420724, 969717)->(515592763, -7202322)
[    0.510709] registered taskstats version 1
[    0.510975] Loading compiled-in X.509 certificates
[    0.514600] Loaded X.509 cert 'Build time autogenerated kernel key: 12f1b0111d6bf51aacdbd0eb6c0ff9d41a7664f2'
[    0.516601] zswap: loaded using pool zstd/zsmalloc
[    0.518816] Key type .fscrypt registered
[    0.518819] Key type fscrypt-provisioning registered
[    0.524152] PM:   Magic number: 4:600:85
[    0.527665] RAS: Correctable Errors collector initialized.
[    0.527747] clk: Disabling unused clocks
[    0.574917] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    0.588243] usb 3-1: new high-speed USB device number 2 using ehci-pci
[    0.624914] ata2: SATA link down (SStatus 0 SControl 300)
[    0.624939] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    0.624969] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    0.626488] ata1.00: ACPI cmd ef/90:03:00:00:00:a0(SET FEATURES) rejected by device (Stat=0x51 Err=0x04)
[    0.626738] ata1.00: ATA-8: ST3500418AS, AP2A, max UDMA/133
[    0.626746] ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 32)
[    0.627537] ata3.00: ACPI cmd ef/10:03:00:00:00:a0(SET FEATURES) filtered out
[    0.627542] ata3.00: ATAPI: HL-DT-STDVDRW  GA32N, KE06, max UDMA/100
[    0.628573] ata1.00: ACPI cmd ef/90:03:00:00:00:a0(SET FEATURES) rejected by device (Stat=0x51 Err=0x04)
[    0.628822] ata1.00: configured for UDMA/133
[    0.630553] ata3.00: ACPI cmd ef/10:03:00:00:00:a0(SET FEATURES) filtered out
[    0.630560] ata3.00: configured for UDMA/100
[    0.631785] scsi 0:0:0:0: Direct-Access     ATA      ST3500418AS      AP2A PQ: 0 ANSI: 5
[    0.632516] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    0.632545] sd 0:0:0:0: [sda] Write Protect is off
[    0.632549] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.632597] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.632659] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[    0.634590] scsi 2:0:0:0: CD-ROM            HL-DT-ST DVDRW  GA32N     KE06 PQ: 0 ANSI: 5
[    0.669230]  sda: sda1 sda2 sda3 sda4 sda5 sda8
[    0.669816] sd 0:0:0:0: [sda] Attached SCSI disk
[    0.672246] Freeing unused decrypted memory: 2028K
[    0.672651] Freeing unused kernel image (initmem) memory: 3448K
[    0.672695] Write protecting the kernel read-only data: 32768k
[    0.673218] Freeing unused kernel image (rodata/data gap) memory: 1220K
[    0.715933] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.715938] rodata_test: all tests were successful
[    0.715939] x86/mm: Checking user space page tables
[    0.735266] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= 0.03
[    0.735270] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    0.735541] hub 2-1:1.0: USB hub found
[    0.735639] hub 2-1:1.0: 4 ports detected
[    0.745240] usb 3-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= 0.03
[    0.745242] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    0.745384] hub 3-1:1.0: USB hub found
[    0.745489] hub 3-1:1.0: 3 ports detected
[    0.756360] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.756365] Run /init as init process
[    0.756366]   with arguments:
[    0.756367]     /init
[    0.756368]     splash
[    0.756369]   with environment:
[    0.756370]     HOME=/
[    0.756370]     TERM=linux
[    0.868218] usb 3-2: new high-speed USB device number 3 using ehci-pci
[    1.005500] ACPI: video: [Firmware Bug]: ACPI(GFX0) defines _DOD but not _DOS
[    1.005578] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    1.005731] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input3
[    1.014869] usb 2-1.1: new high-speed USB device number 3 using ehci-pci
[    1.034738] usb 3-2: New USB device found, idVendor=05ac, idProduct=850b, bcdDevice= 7.55
[    1.034744] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.034746] usb 3-2: Product: FaceTime HD Camera (Built-in)
[    1.034748] usb 3-2: Manufacturer: Apple Inc.
[    1.034749] usb 3-2: SerialNumber: CCGB3K038DDDJPFX
[    1.084936] firewire_ohci 0000:04:00.0: added OHCI v1.10 device as card 0, 8 IR + 8 IT contexts, quirks 0x0, physUB
[    1.084972] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[    1.084977] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.098208] usb 3-1.1: new full-speed USB device number 4 using ehci-pci
[    1.123016] usb 2-1.1: New USB device found, idVendor=05ac, idProduct=8403, bcdDevice=98.33
[    1.123022] usb 2-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[    1.123023] usb 2-1.1: Product: Card Reader
[    1.123024] usb 2-1.1: Manufacturer: Apple
[    1.123026] usb 2-1.1: SerialNumber: 000000009833
[    1.146638] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    1.168351] [drm] radeon kernel modesetting enabled.
[    1.196329] usb-storage 2-1.1:1.0: USB Mass Storage device detected
[    1.196510] scsi host6: usb-storage 2-1.1:1.0
[    1.196590] usbcore: registered new interface driver usb-storage
[    1.202984] usb 3-1.1: New USB device found, idVendor=0a5c, idProduct=4500, bcdDevice= 1.00
[    1.202991] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.202993] usb 3-1.1: Product: BRCM2046 Hub
[    1.202994] usb 3-1.1: Manufacturer: Apple Inc.
[    1.204436] radeon 0000:01:00.0: vgaarb: deactivate vga console
[    1.204556] hub 3-1.1:1.0: USB hub found
[    1.204734] hub 3-1.1:1.0: 3 ports detected
[    1.204890] [drm] initializing kernel modesetting (TURKS 0x1002:0x6741 0x106B:0x6741 0x00).
[    1.220982] usb 2-1.2: new low-speed USB device number 4 using ehci-pci
[    1.250987] tsc: Refined TSC clocksource calibration: 2500.017 MHz
[    1.250994] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x240949cbdf1, max_idle_ns: 440795269944 ns
[    1.254321] clocksource: Switched to clocksource tsc
[    1.284313] usb 3-1.2: new full-speed USB device number 5 using ehci-pci
[    1.336888] usb 2-1.2: New USB device found, idVendor=05ac, idProduct=8242, bcdDevice= 0.16
[    1.336893] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.336895] usb 2-1.2: Product: IR Receiver
[    1.336896] usb 2-1.2: Manufacturer: Apple Computer, Inc.
[    1.398140] usb 3-1.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[    1.398147] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.398149] usb 3-1.2: Product: USB Receiver
[    1.398150] usb 3-1.2: Manufacturer: Logitech
[    1.417648] usb 2-1.4: new full-speed USB device number 5 using ehci-pci
[    1.497674] usb 3-1.1.1: new full-speed USB device number 6 using ehci-pci
[    1.510133] ATOM BIOS: Apple
[    1.510275] radeon 0000:01:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[    1.510279] radeon 0000:01:00.0: GTT: 1024M 0x0000000020000000 - 0x000000005FFFFFFF
[    1.510286] [drm] Detected VRAM RAM=512M, BAR=256M
[    1.510287] [drm] RAM width 128bits DDR
[    1.510425] [drm] radeon: 512M of VRAM memory ready
[    1.510430] [drm] radeon: 1024M of GTT memory ready.
[    1.510438] [drm] Loading TURKS Microcode
[    1.511088] [drm] External GPIO thermal controller with fan control
[    1.516013] [drm] radeon: dpm initialized
[    1.517595] [drm] GART: num cpu pages 262144, num gpu pages 262144
[    1.518205] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[    1.530611] usb 2-1.4: New USB device found, idVendor=046d, idProduct=c548, bcdDevice= 5.03
[    1.530617] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.530619] usb 2-1.4: Product: USB Receiver
[    1.530620] usb 2-1.4: Manufacturer: Logitech
[    1.539014] [drm] PCIE GART of 1024M enabled (table at 0x0000000000162000).
[    1.539120] radeon 0000:01:00.0: WB enabled
[    1.539123] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000020000c00
[    1.539125] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c
[    1.539871] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000072118
[    1.540092] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[    1.540144] radeon 0000:01:00.0: radeon: using MSI.
[    1.540181] [drm] radeon: irq initialized.
[    1.556656] [drm] ring test on 0 succeeded in 2 usecs
[    1.556667] [drm] ring test on 3 succeeded in 6 usecs
[    1.601170] firewire_core 0000:04:00.0: created device fw0: GUID c82a14fffe8acd24, S800
[    1.601190] firewire_core 0000:04:00.0: phy config: new root=ffc0, gap_count=63
[    1.601235] usbcore: registered new interface driver uas
[    1.603390] i915 0000:00:02.0: enabling device (0006 -> 0007)
[    1.604163] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.0/0003:046D:C52B.0002/input/input4
[    1.606984] usb 3-1.1.1: New USB device found, idVendor=05ac, idProduct=8215, bcdDevice= 2.08
[    1.606989] usb 3-1.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.606991] usb 3-1.1.1: Product: Bluetooth USB Host Controller
[    1.606993] usb 3-1.1.1: Manufacturer: Apple Inc.
[    1.606995] usb 3-1.1.1: SerialNumber: 442A60D7E3B5
[    1.656399] i915 0000:00:02.0: BAR 6: can't assign [??? 0x00000000 flags 0x20000000] (bogus alignment)
[    1.656406] i915 0000:00:02.0: [drm] Failed to find VBIOS tables (VBT)
[    1.656678] radeon 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=none
[    1.733801] [drm] ring test on 5 succeeded in 2 usecs
[    1.733811] [drm] UVD initialized successfully.
[    1.734007] [drm] ib test on ring 0 succeeded in 0 usecs
[    1.734098] [drm] ib test on ring 3 succeeded in 0 usecs
[    1.784613] hid-generic 0003:046D:C52B.0002: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.7-1.2/input0
[    1.787088] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.1/0003:046D:C52B.0003/input/input5
[    1.787257] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.1/0003:046D:C52B.0003/input/input6
[    1.841162] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.1/0003:046D:C52B.0003/input/input7
[    1.841521] hid-generic 0003:046D:C52B.0003: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.7-1.2/input1
[    1.843385] hid-generic 0003:046D:C52B.0004: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.7-1.2/input2
[    1.844643] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.0/0003:046D:C548.0005/input/input9
[    1.971331] hid-generic 0003:046D:C548.0005: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1d.7-1.4/input0
[    1.973871] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:046D:C548.0006/input/input10
[    1.974125] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:046D:C548.0006/input/input11
[    2.027876] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:046D:C548.0006/input/input12
[    2.028085] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:046D:C548.0006/input/input13
[    2.028554] hid-generic 0003:046D:C548.0006: input,hiddev98,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.7-1.4/input1
[    2.030119] hid-generic 0003:046D:C548.0007: hiddev99,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.7-1.4/input2
[    2.032570] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.3/0003:046D:C548.0008/input/input14
[    2.032896] hid-generic 0003:046D:C548.0008: input,hidraw6: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.7-1.4/input3
[    2.032952] usbcore: registered new interface driver usbhid
[    2.032955] usbhid: USB HID core driver
[    2.039998] input: Apple Computer, Inc. IR Receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.2/2-1.2:1.0/0003:05AC:8242.0001/input/input15
[    2.094862] appleir 0003:05AC:8242.0001: input,hiddev100,hidraw7: USB HID v1.11 Device [Apple Computer, Inc. IR Receiver] on usb-0000:00:1d.7-1.2/input0
[    2.095738] logitech-djreceiver 0003:046D:C52B.0004: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.7-1.2/input2
[    2.210224] input: Logitech Wireless Device PID:4055 Mouse as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.2/0003:046D:C52B.0004/0003:046D:4055.0009/input/input16
[    2.212981] scsi 6:0:0:0: Direct-Access     APPLE    SD Card Reader   1.00 PQ: 0 ANSI: 0
[    2.213990] sd 6:0:0:0: [sdb] Media removed, stopped polling
[    2.214328] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[    2.251333] hid-generic 0003:046D:4055.0009: input,hidraw0: USB HID v1.11 Mouse [Logitech Wireless Device PID:4055] on usb-0000:00:1a.7-1.2/input2:1
[    2.252979] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.3/0003:046D:C548.0008/input/input20
[    2.258040] input: Logitech K520 as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.2/0003:046D:C52B.0004/0003:046D:2011.000A/input/input21
[    2.321491] hid-multitouch 0003:046D:C548.0008: input,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.7-1.4/input3
[    2.327879] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.2/0003:046D:C52B.0004/0003:046D:4055.0009/input/input22
[    2.397834] [drm] ib test on ring 5 succeeded
[    2.431319] logitech-hidpp-device 0003:046D:2011.000A: input,hidraw6: USB HID v1.11 Keyboard [Logitech K520] on usb-0000:00:1a.7-1.2/input2:2
[    2.438075] input: Logitech MX Anywhere 2S as /devices/pci0000:00/0000:00:1a.7/usb3/3-1/3-1.2/3-1.2:1.2/0003:046D:C52B.0004/0003:046D:406A.000B/input/input23
[    2.461020] [drm] radeon atom DIG backlight initialized
[    2.461027] [drm] Radeon Display Connectors
[    2.461028] [drm] Connector 0:
[    2.461031] [drm]   eDP-1
[    2.461032] [drm]   HPD3
[    2.461033] [drm]   DDC: 0x6450 0x6450 0x6454 0x6454 0x6458 0x6458 0x645c 0x645c
[    2.461037] [drm]   Encoders:
[    2.461038] [drm]     LCD1: INTERNAL_UNIPHY2
[    2.461040] [drm] Connector 1:
[    2.461041] [drm]   DP-1
[    2.461042] [drm]   HPD1
[    2.461043] [drm]   DDC: 0x6430 0x6430 0x6434 0x6434 0x6438 0x6438 0x643c 0x643c
[    2.461046] [drm]   Encoders:
[    2.461055] [drm]     DFP1: INTERNAL_UNIPHY1
[    2.461056] [drm] Connector 2:
[    2.461057] [drm]   DP-2
[    2.461057] [drm]   HPD2
[    2.461058] [drm]   DDC: 0x6440 0x6440 0x6444 0x6444 0x6448 0x6448 0x644c 0x644c
[    2.461060] [drm]   Encoders:
[    2.461061] [drm]     DFP2: INTERNAL_UNIPHY1
[    2.461062] [drm] Connector 3:
[    2.461063] [drm]   DP-3
[    2.461063] [drm]   HPD5
[    2.461064] [drm]   DDC: 0x6460 0x6460 0x6464 0x6464 0x6468 0x6468 0x646c 0x646c
[    2.461066] [drm]   Encoders:
[    2.461067] [drm]     DFP3: INTERNAL_UNIPHY2
[    2.461068] [drm] Connector 4:
[    2.461069] [drm]   VGA-2
[    2.461070] [drm]   DDC: 0x64d8 0x64d8 0x64dc 0x64dc 0x64e0 0x64e0 0x64e4 0x64e4
[    2.461072] [drm]   Encoders:
[    2.461072] [drm]     CRT1: INTERNAL_KLDSCP_DAC1
[    2.462856] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
[    2.463352] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
[    2.468050] logitech-hidpp-device 0003:046D:4055.0009: input,hidraw8: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:1a.7-1.2/input2:1
[    2.567800] logitech-hidpp-device 0003:046D:406A.000B: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Anywhere 2S] on usb-0000:00:1a.7-1.2/input2:3
[    2.574356] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    2.677692] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    3.612754] [drm] fb mappable at 0x90363000
[    3.612759] [drm] vram apper at 0x90000000
[    3.612760] [drm] size 8294400
[    3.612762] [drm] fb depth is 24
[    3.612763] [drm]    pitch is 7680
[    3.612934] fbcon: radeondrmfb (fb0) is primary device
[    3.612938] fbcon: Deferring console take-over
[    3.612943] radeon 0000:01:00.0: [drm] fb0: radeondrmfb frame buffer device
[    6.090098] [drm] amdgpu kernel modesetting enabled.
[    6.090339] amdgpu: Virtual CRAT table created for CPU
[    6.090353] amdgpu: Topology: Add CPU node
[    8.336682] EXT4-fs (sda4): mounted filesystem dcd2885d-ae78-4f92-b3e7-c8507caef8a3 r/w with ordered data mode. Quota mode: none.
[    9.762410] systemd[1]: systemd 256.9-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    9.762423] systemd[1]: Detected architecture x86-64.
[    9.781668] systemd[1]: Hostname set to <manjaro-imac>.
[    9.915531] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   10.447783] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[   11.074681] random: crng init done
[   13.633618] systemd[1]: Queued start job for default target Graphical Interface.
[   13.736968] systemd[1]: Created slice Slice /system/dirmngr.
[   13.737786] systemd[1]: Created slice Slice /system/getty.
[   13.738466] systemd[1]: Created slice Slice /system/gpg-agent.
[   13.739153] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[   13.739841] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[   13.740524] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[   13.741250] systemd[1]: Created slice Slice /system/keyboxd.
[   13.741943] systemd[1]: Created slice Slice /system/modprobe.
[   13.742614] systemd[1]: Created slice Encrypted Volume Units Service Slice.
[   13.743306] systemd[1]: Created slice Slice /system/systemd-fsck.
[   13.743784] systemd[1]: Created slice User and Session Slice.
[   13.743931] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   13.744274] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   13.744333] systemd[1]: Expecting device /dev/disk/by-uuid/2860-11F4...
[   13.744353] systemd[1]: Expecting device /dev/disk/by-uuid/de042e37-84bd-4412-bdd0-c472808f1c25...
[   13.744366] systemd[1]: Expecting device /dev/mapper/luks_home...
[   13.744406] systemd[1]: Reached target Login Prompts.
[   13.744441] systemd[1]: Reached target Local Integrity Protected Volumes.
[   13.744483] systemd[1]: Reached target Remote File Systems.
[   13.744505] systemd[1]: Reached target Slice Units.
[   13.744544] systemd[1]: Reached target Swaps.
[   13.744593] systemd[1]: Reached target Local Verity Protected Volumes.
[   13.744772] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   13.744959] systemd[1]: Listening on LVM2 poll daemon socket.
[   13.773924] systemd[1]: Listening on Process Core Dump Socket.
[   13.774859] systemd[1]: Listening on Credential Encryption/Decryption.
[   13.774966] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.775062] systemd[1]: Listening on Journal Sockets.
[   13.775099] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.775116] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.775199] systemd[1]: Listening on udev Control Socket.
[   13.775267] systemd[1]: Listening on udev Kernel Socket.
[   13.781430] systemd[1]: Mounting Huge Pages File System...
[   13.782205] systemd[1]: Mounting POSIX Message Queue File System...
[   13.783090] systemd[1]: Mounting Kernel Debug File System...
[   13.784387] systemd[1]: Mounting Kernel Trace File System...
[   13.796758] systemd[1]: Mounting Temporary Directory /tmp...
[   13.797705] systemd[1]: Starting Create List of Static Device Nodes...
[   13.798621] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   13.801410] systemd[1]: Starting Load Kernel Module configfs...
[   13.803045] systemd[1]: Starting Load Kernel Module dm_mod...
[   13.804086] systemd[1]: Starting Load Kernel Module drm...
[   13.806202] systemd[1]: Starting Load Kernel Module fuse...
[   13.807779] systemd[1]: Starting Load Kernel Module loop...
[   13.807890] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   13.807946] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[   13.943440] device-mapper: uevent: version 1.0.3
[   13.943641] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[   13.945998] loop: module loaded
[   13.959277] systemd[1]: Starting Load Kernel Modules...
[   13.959299] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.960109] systemd[1]: Starting Remount Root and Kernel File Systems...
[   13.960165] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.961015] systemd[1]: Starting Load udev Rules from Credentials...
[   13.963577] systemd[1]: Starting Coldplug All udev Devices...
[   13.979215] systemd[1]: Starting Virtual Console Setup...
[   13.979405] fuse: init (API version 7.39)
[   13.981908] systemd[1]: Mounted Huge Pages File System.
[   13.982082] systemd[1]: Mounted POSIX Message Queue File System.
[   13.982230] systemd[1]: Mounted Kernel Debug File System.
[   13.982352] systemd[1]: Mounted Kernel Trace File System.
[   13.982482] systemd[1]: Mounted Temporary Directory /tmp.
[   14.001339] systemd[1]: Finished Create List of Static Device Nodes.
[   14.001752] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   14.017984] EXT4-fs (sda4): re-mounted dcd2885d-ae78-4f92-b3e7-c8507caef8a3 r/w. Quota mode: none.
[   14.018040] systemd[1]: Finished Load Kernel Module configfs.
[   14.019050] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   14.037928] systemd[1]: Finished Load Kernel Module dm_mod.
[   14.038757] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   14.061254] systemd[1]: Finished Load Kernel Module drm.
[   14.061607] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   14.081262] systemd[1]: Finished Load Kernel Module fuse.
[   14.081623] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   14.114576] systemd[1]: Finished Load Kernel Module loop.
[   14.164591] systemd[1]: Finished Remount Root and Kernel File Systems.
[   14.191682] i2c_dev: i2c /dev entries driver
[   14.217931] systemd[1]: Finished Virtual Console Setup.
[   14.219189] systemd[1]: Mounting FUSE Control File System...
[   14.220018] systemd[1]: Mounting Kernel Configuration File System...
[   14.265923] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   14.266847] systemd[1]: Starting Load/Save OS Random Seed...
[   14.266903] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[   14.267725] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[   14.267745] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   14.287881] systemd[1]: Finished Load Kernel Modules.
[   14.307908] systemd[1]: Finished Load udev Rules from Credentials.
[   14.308156] systemd[1]: Mounted FUSE Control File System.
[   14.308276] systemd[1]: Mounted Kernel Configuration File System.
[   14.309415] systemd[1]: Starting Apply Kernel Variables...
[   14.427855] systemd[1]: Finished Coldplug All udev Devices.
[   14.481362] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   14.531203] systemd[1]: Finished Load/Save OS Random Seed.
[   14.561193] systemd[1]: Finished Apply Kernel Variables.
[   14.871202] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[   14.871530] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[   14.873096] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.964550] systemd[1]: Finished Create Static Device Nodes in /dev.
[   14.964779] systemd[1]: Reached target Preparation for Local File Systems.
[   14.964846] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[   14.967512] systemd[1]: Starting Journal Service...
[   14.968597] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   14.981470] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[   15.024640] systemd-journald[323]: Collecting audit messages is disabled.
[   15.093149] systemd[1]: Started Journal Service.
[   15.169419] systemd-journald[323]: Received client request to flush runtime journal.
[   16.910573] input: PC Speaker as /devices/platform/pcspkr/input/input24
[   17.040850] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20230628/utaddress-204)
[   17.040859] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.040862] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   17.040866] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.040867] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   17.040870] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.040871] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   17.040874] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.040875] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   17.287719] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[   17.287725] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[   17.287726] RAPL PMU: hw unit of domain package 2^-16 Joules
[   17.287727] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[   17.303793] ACPI: bus type thunderbolt registered
[   17.303809] i801_smbus 0000:00:1f.3: enabling device (0000 -> 0003)
[   17.304006] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[   17.304213] i2c i2c-18: 4/4 memory slots populated (from DMI)
[   17.304545] i2c i2c-18: Successfully instantiated SPD at 0x50
[   17.304853] i2c i2c-18: Successfully instantiated SPD at 0x51
[   17.305153] i2c i2c-18: Successfully instantiated SPD at 0x52
[   17.305466] i2c i2c-18: Successfully instantiated SPD at 0x53
[   17.323768] cryptd: max_cpu_qlen set to 1000
[   17.343095] tg3 0000:02:00.0 eth0: Tigon3 [partno(BCM957765) rev 57785100] (PCI Express) MAC address c8:2a:14:20:6e:9d
[   17.343102] tg3 0000:02:00.0 eth0: attached PHY is 57765 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[   17.343105] tg3 0000:02:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[   17.343107] tg3 0000:02:00.0 eth0: dma_rwctrl[00000001] dma_mask[64-bit]
[   17.441269] AVX version of gcm_enc/dec engaged.
[   17.441307] AES CTR mode by8 optimization enabled
[   17.540338] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   17.540666] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   17.540916] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   17.559034] iTCO_vendor_support: vendor-support=0
[   17.718723] at24 18-0050: supply vcc not found, using dummy regulator
[   17.719874] iTCO_wdt iTCO_wdt.1.auto: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[   17.720330] at24 18-0050: 256 byte spd EEPROM, read-only
[   17.720403] at24 18-0051: supply vcc not found, using dummy regulator
[   17.722065] at24 18-0051: 256 byte spd EEPROM, read-only
[   17.722095] at24 18-0052: supply vcc not found, using dummy regulator
[   17.723676] at24 18-0052: 256 byte spd EEPROM, read-only
[   17.723700] at24 18-0053: supply vcc not found, using dummy regulator
[   17.725272] at24 18-0053: 256 byte spd EEPROM, read-only
[   17.783572] usbcore: registered new device driver apple-mfi-fastcharge
[   17.807262] applesmc: key=332 fan=3 temp=50 index=49 acc=0 lux=2 kbd=0
[   17.807388] applesmc applesmc.768: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[   17.995760] mousedev: PS/2 mouse device common for all mice
[   17.996217] Bluetooth: Core ver 2.22
[   17.996239] NET: Registered PF_BLUETOOTH protocol family
[   17.996241] Bluetooth: HCI device and connection manager initialized
[   17.996245] Bluetooth: HCI socket layer initialized
[   17.996247] Bluetooth: L2CAP socket layer initialized
[   17.996253] Bluetooth: SCO socket layer initialized
[   17.996617] mc: Linux media interface: v0.10
[   17.996961] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[   17.997141] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[   17.997392] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   18.012839] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops radeon_audio_component_bind_ops [radeon])
[   18.013407] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input25
[   18.069756] snd_hda_codec_cirrus hdaudioC0D0: autoconfig for CS4206: line_outs=2 (0x9/0xb/0x0/0x0/0x0) type:speaker
[   18.069764] snd_hda_codec_cirrus hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   18.069766] snd_hda_codec_cirrus hdaudioC0D0:    hp_outs=1 (0xa/0x0/0x0/0x0/0x0)
[   18.069768] snd_hda_codec_cirrus hdaudioC0D0:    mono: mono_out=0x0
[   18.069770] snd_hda_codec_cirrus hdaudioC0D0:    dig-out=0x10/0x0
[   18.069771] snd_hda_codec_cirrus hdaudioC0D0:    inputs:
[   18.069773] snd_hda_codec_cirrus hdaudioC0D0:      Mic=0xd
[   18.069774] snd_hda_codec_cirrus hdaudioC0D0:      Line=0xc
[   18.069775] snd_hda_codec_cirrus hdaudioC0D0:    dig-in=0xf
[   18.090213] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input26
[   18.090270] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input27
[   18.090320] input: HDA Intel PCH SPDIF In as /devices/pci0000:00/0000:00:1b.0/sound/card0/input28
[   18.124892] videodev: Linux video capture interface: v2.00
[   18.166879] tg3 0000:02:00.0 enp2s0: renamed from eth0
[   18.194199] ath: EEPROM regdomain: 0x37
[   18.194203] ath: EEPROM indicates we should expect a direct regpair map
[   18.194204] ath: Country alpha2 being used: AL
[   18.194205] ath: Regpair used: 0x37
[   18.208995] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   18.231118] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0x00000000725e665d, irq=17
[   18.233536] usbcore: registered new interface driver btusb
[   18.348652] Bluetooth: hci0: BCM: chip id 254 build 0518
[   18.348812] ath9k 0000:03:00.0 wlp3s0: renamed from wlan0
[   18.349712] Bluetooth: hci0: BCM: product 05ac:8215
[   18.351668] Bluetooth: hci0: BCM: features 0x00
[   18.368705] Bluetooth: hci0: manjaro-imac
[   18.455315] usb 3-2: Found UVC 1.00 device FaceTime HD Camera (Built-in) (05ac:850b)
[   18.479521] usbcore: registered new interface driver uvcvideo
[   18.562982] intel_rapl_common: Found RAPL domain package
[   18.562986] intel_rapl_common: Found RAPL domain core
[   18.562987] intel_rapl_common: Found RAPL domain uncore
[   39.992904] Key type encrypted registered
[   40.602435] EXT4-fs (dm-0): mounted filesystem 1b988319-9c2d-4b19-b779-9441f61b40c9 r/w with ordered data mode. Quota mode: none.
[   42.605067] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   42.605072] Bluetooth: BNEP filters: protocol multicast
[   42.605076] Bluetooth: BNEP socket layer initialized
[   42.706362] Bluetooth: MGMT ver 1.22
[   42.833306] NET: Registered PF_ALG protocol family
[   46.656388] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[   46.656394] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[   50.315398] wlp3s0: authenticate with b0:be:76:bc:21:c8
[   50.325654] wlp3s0: send auth to b0:be:76:bc:21:c8 (try 1/3)
[   50.326709] wlp3s0: authenticated
[   50.327671] wlp3s0: associate with b0:be:76:bc:21:c8 (try 1/3)
[   50.329257] wlp3s0: RX AssocResp from b0:be:76:bc:21:c8 (capab=0x111 status=0 aid=1)
[   50.329391] wlp3s0: associated
[   90.563610] sched: RT throttling activated
[   91.844361] Bluetooth: RFCOMM TTY layer initialized
[   91.844378] Bluetooth: RFCOMM socket layer initialized
[   91.844382] Bluetooth: RFCOMM ver 1.11
[  147.764815] logitech-hidpp-device 0003:046D:406A.000B: HID++ 4.5 device connected.
[  152.871050] wlp3s0: deauthenticating from b0:be:76:bc:21:c8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  153.349728] PM: suspend entry (deep)
[  154.008980] Filesystems sync: 0.659 seconds
[  154.157281] Freezing user space processes
[  154.158573] Freezing user space processes completed (elapsed 0.001 seconds)
[  154.158578] OOM killer disabled.
[  154.158579] Freezing remaining freezable tasks
[  154.159702] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[  154.159727] printk: Suspending console(s) (use no_console_suspend to debug)
[  154.173402] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[  154.173746] ata1.00: Entering standby power mode
[  155.203915] ACPI: EC: interrupt blocked
[  155.263192] ACPI: PM: Preparing to enter system sleep state S3
[  155.270481] ACPI: EC: event blocked
[  155.270482] ACPI: EC: EC stopped
[  155.270483] ACPI: PM: Saving platform NVS memory
[  155.270509] Disabling non-boot CPUs ...
[  155.271894] smpboot: CPU 1 is now offline
[  155.273665] smpboot: CPU 2 is now offline
[  155.275297] smpboot: CPU 3 is now offline
[  155.276595] ACPI: PM: Low-level resume complete
[  155.276615] ACPI: EC: EC started
[  155.276616] ACPI: PM: Restoring platform NVS memory
[  155.276964] Enabling non-boot CPUs ...
[  155.277134] smpboot: Booting Node 0 Processor 1 APIC 0x2
[  155.400761] CPU1 is up
[  155.403147] smpboot: Booting Node 0 Processor 2 APIC 0x4
[  155.525998] CPU2 is up
[  155.527926] smpboot: Booting Node 0 Processor 3 APIC 0x6
[  155.667018] CPU3 is up
[  155.670989] ACPI: PM: Waking up from system sleep state S3
[  156.098193] ACPI: EC: interrupt unblocked
[  156.117751] ACPI: EC: event unblocked
[  156.117827] usb usb1: root hub lost power or was reset
[  156.117892] usb usb4: root hub lost power or was reset
[  156.127527] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[  156.133999] [drm] PCIE GART of 1024M enabled (table at 0x0000000000162000).
[  156.134095] radeon 0000:01:00.0: WB enabled
[  156.134098] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000020000c00
[  156.134100] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c
[  156.134854] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000072118
[  156.135098] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[  156.135101] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[  156.151247] [drm] ring test on 0 succeeded in 2 usecs
[  156.151258] [drm] ring test on 3 succeeded in 6 usecs
[  156.151259] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[  156.328388] [drm] ring test on 5 succeeded in 2 usecs
[  156.328396] [drm] UVD initialized successfully.
[  156.328552] [drm] ib test on ring 0 succeeded in 0 usecs
[  156.328695] [drm] ib test on ring 3 succeeded in 0 usecs
[  156.471201] ata2: SATA link down (SStatus 0 SControl 300)
[  156.471220] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[  156.473931] ata3.00: ACPI cmd ef/10:03:00:00:00:a0(SET FEATURES) filtered out
[  156.476908] ata3.00: ACPI cmd ef/10:03:00:00:00:a0(SET FEATURES) filtered out
[  156.476915] ata3.00: configured for UDMA/100
[  156.694843] firewire_core 0000:04:00.0: rediscovered device fw0
[  156.988230] [drm] ib test on ring 5 succeeded
[  159.385056] OOM killer enabled.
[  159.385059] Restarting tasks ... done.
[  159.386674] random: crng reseeded on system resumption
[  159.390605] PM: suspend exit
[  159.988165] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  159.988188] ata1.00: Entering active power mode
[  160.017068] ata1.00: ACPI cmd ef/90:03:00:00:00:a0(SET FEATURES) rejected by device (Stat=0x51 Err=0x04)
[  160.017279] sd 0:0:0:0: [sda] Starting disk
[  160.018775] ata1.00: ACPI cmd ef/90:03:00:00:00:a0(SET FEATURES) rejected by device (Stat=0x51 Err=0x04)
[  160.018974] ata1.00: configured for UDMA/133
[  160.018993] ata1.00: Entering active power mode
[  160.791391] clocksource: Long readout interval, skipping watchdog check: cs_nsec: 1029916832 wd_nsec: 1029916653
[  164.082481] wlp3s0: authenticate with b0:be:76:bc:21:c8
[  164.092513] wlp3s0: send auth to b0:be:76:bc:21:c8 (try 1/3)
[  164.093481] wlp3s0: authenticated
[  164.094949] wlp3s0: associate with b0:be:76:bc:21:c8 (try 1/3)
[  164.096514] wlp3s0: RX AssocResp from b0:be:76:bc:21:c8 (capab=0x111 status=0 aid=1)
[  164.096625] wlp3s0: associated
This is inxi:
inxi
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: root=UUID=dcd2885d-ae78-4f92-b3e7-c8507caef8a3 rw quiet splash
    udev.log_priority=3 initrd=\boot\initramfs-6.6-x86_64.img
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop System: Apple product: iMac12,1 v: 1.0 serial: <filter>
    Chassis: type: 13 v: Mac-942B5BF58194151B serial: <filter>
  Mobo: Apple model: Mac-942B5BF58194151B serial: <filter>
    uuid: dde55577-2af9-4356-b684-4d5b04ee5dbd UEFI: Apple v: 87.0.0.0.0
    date: 06/14/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX Anywhere
    2S serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: Intel Core i5-2400S socket: U2E1 bits: 64 type: MCP SMP
    arch: Sandy Bridge gen: core 2 level: v2 built: 2010-12 process: Intel 32nm
    family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L1: 4x 256 KiB (1024 KiB) desc: d-4x32 KiB; i-4x32 KiB
    L2: 4x 1024 KiB (4 MiB) desc: 4x256 KiB L3: 4x 6 MiB (24 MiB) desc: 1x6 MiB
  Speed (MHz): avg: 1600 min/max: 1600/3300 base/boost: 2533/2500 scaling:
    driver: intel_cpufreq governor: schedutil volts: 0.0 V cores: 1: 1600 2: 1600
    3: 1600 4: 1600 bogomips: 20009
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    driver: i915 v: kernel arch: Gen-6 code: Sandybridge process: Intel 32nm
    built: 2011 ports: active: none empty: VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0102 class-ID: 0380
  Device-2: Advanced Micro Devices [AMD/ATI] Whistler [Radeon HD
    6630M/6650M/6750M/7670M/7690M] vendor: Apple driver: radeon v: kernel
    alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
    built: 2009-15 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2
    speed: 5 GT/s ports: active: eDP-1 empty: DP-1, DP-2, DP-3, VGA-2
    bus-ID: 01:00.0 chip-ID: 1002:6741 class-ID: 0300
  Device-3: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 05ac:850b
  Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: modesetting,radeon
    alternate: fbdev,vesa dri: r600,crocus gpu: radeon display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: eDP-1 model: Apple iMac built: 2010 res: 1920x1080 hz: 60
    dpi: 103 gamma: 1.2 size: 475x267mm (18.7x10.51") diag: 545mm (21.5")
    ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel crocus drv: amd r600 platforms: device: 0
    drv: r600 device: 1 drv: crocus device: 2 drv: swrast gbm: drv: r600
    surfaceless: drv: r600 x11: drv: r600 inactive: wayland
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 24.2.8-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD TURKS (DRM 2.50.0 / 6.6.65-1-MANJARO LLVM
    18.1.8) device-ID: 1002:6741 memory: 500 MiB unified: no
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Turks HDMI Audio [Radeon HD
    6500/6600 / 6700M Series] vendor: Apple driver: snd_hda_intel v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s
    bus-ID: 01:00.1 chip-ID: 1002:aa90 class-ID: 0403
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
    vendor: Apple AirPort Extreme driver: ath9k v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
  IF-ID-1: de-dus-wg-001 state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: Apple Built-in Bluetooth 2.0+EDR HCI driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1.1:6
    chip-ID: 05ac:8215 class-ID: fe01 serial: <filter>
  Local Storage: total: 465.76 GiB used: 115.4 GiB (24.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
    family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: AP2A temp: 38 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 4y 148d 20h cycles: 25343
    Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
  ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 22.24 GiB (46.6%)
    fs: ext4 block-size: 4096 B dev: /dev/sda4 maj-min: 8:4
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.44%)
    used: 37.7 MiB (19.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 273.36 GiB size: 268.89 GiB (98.36%)
    used: 93.12 GiB (34.6%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks_home
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 1199
  Memory: total: 12 GiB available: 11.66 GiB used: 1.88 GiB (16.1%)
  Processes: 307 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 4.64 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1212 pm: pacman pkgs: 1205 libs: 329 tools: gnome-software,pamac
    pm: flatpak pkgs: 7 Compilers: gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
Suggestions?
Many thanks!
t
P.S. I see the OP marked gnome, but in my case I actually use KDE ( I tried both X11 and Wayland)
Switching kernel version to LTS worked for some.
Hi @rednose
I have moved your post to a new thread where it may command better attention. Please avoid adding your issue(s) to someone else’s thread.
Also note that this condition might already be addressed in the Known Issues and Solutions section of recent Update announcements – a little searching should bear fruit.
As an infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
HI there, I understand kernel is LTS? It is among the “recommended” in manjaro settings …
I also tried installing another “recommended”, but problem persists …
when did it started to happen?
try with the 5.15 kernel…
if it doesnt help, reboot so that we minimize the amount of logs, suspend and provide logs:
journalctl -b0 -p5 --no-pager
are you on raid?:
inxi -R
I’ve had this happen with certain USB devices, in my case a multimedia keyboard connected via a USB to PS2 adaptor. Pressing the sleep key would have the effect you describe, unless I immediately disconnected the keyboard from the adaptor (or pulled the adaptor itself out).
If you have USB devices plugged in, try removing each of those, in turn, immediately after clicking suspend. Just a suspicion on my part.
Following @BG405 suggestion I did the following as root: sleep 30; systemctl suspend. In those 30sec I removed the USB dongle that connects my keyboard and mouse. System went to sleep.
Instead if I try the same procedure, but only switching off mouse and keyboard, leaving the usb dongle connected, then the resume after suspend happens.
I also run on the same machine another linux distribution based on debian (hence all is older, kernel 5, kde 5, X11…), and there I have no issue.
Is there any usb power setting I should have a look to?
many thanks!
… problem looks solved if I run solaar …
