Uhm… I’m experiencing some weird behavior after the latest update. My system refuses to reboot or shutdown sometimes. Using shutdown or sysemctl poweroff or reboot (both with and without -force) just results in a timeout. I can’t pin down the reason. It just happens sometimes. Using TTY doesn’t help either, I just get a blinkling cursor and no login.
Host: jonas Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 Desktop: GNOME 40.3
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO v: x.x
serial: <superuser required> BIOS: American Megatrends v: F10
date: 09/18/2020
Info: 8-Core model: AMD Ryzen 7 3800XT bits: 64 type: MT MCP cache:
L2: 4 MiB
Speed: 2179 MHz min/max: 2200/3900 MHz Core speeds (MHz): 1: 2179 2: 2080
3: 2100 4: 2101 5: 2061 6: 2176 7: 2053 8: 3593 9: 2100 10: 2067 11: 2053
12: 2053 13: 2053 14: 3593 15: 2867 16: 2212
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] driver: nvidia v: 470.57.02
Device-2: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
Display: x11 server: X.org 1.20.11 driver: loaded: nvidia
OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Sound Server-3: PipeWire v: 0.3.32 running: yes
Device-1: Realtek RTL8125 2.5GbE driver: r8169
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 18:c0:4d:3d:86:9a
IF-ID-1: br-51f354fd0888 state: up speed: 10000 Mbps duplex: unknown
mac: 02:42:dc:6a:3f:a1
IF-ID-2: br-e621a92c68ee state: up speed: 10000 Mbps duplex: unknown
mac: 02:42:30:61:9d:94
IF-ID-3: docker0 state: down mac: 02:42:6c:f3:f5:04
IF-ID-4: veth096aef6 state: up speed: 10000 Mbps duplex: full
mac: ce:23:de:37:c2:0d
IF-ID-5: veth30bb934 state: up speed: 10000 Mbps duplex: full
mac: 8a:69:73:a9:41:0a
IF-ID-6: veth900d55a state: up speed: 10000 Mbps duplex: full
mac: 62:6d:c0:4b:56:8a
IF-ID-7: vethb2c8f15 state: up speed: 10000 Mbps duplex: full
mac: 1a:29:c6:49:27:f3
IF-ID-8: vethb3088cf state: up speed: 10000 Mbps duplex: full
mac: be:ef:e8:e8:2d:72
IF-ID-9: vethf1119d5 state: up speed: 10000 Mbps duplex: full
mac: 46:74:09:dd:5a:53
IF-ID-10: vethfefa666 state: up speed: 10000 Mbps duplex: full
mac: f6:14:ec:1c:b4:7e
Local Storage: total: 5.46 TiB used: 1.16 TiB (21.2%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P5SSD8 size: 931.51 GiB
ID-2: /dev/sda vendor: Western Digital model: WD40EZRZ-00GXCB0
ID-3: /dev/sdb vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB
ID-1: / size: 915.81 GiB used: 374.67 GiB (40.9%) fs: ext4
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 53.5 C mobo: 36.0 C gpu: nvidia temp: 53 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 543 gpu: nvidia fan: 0%
Processes: 407 Uptime: 21m Memory: 31.3 GiB used: 4.85 GiB (15.5%)
Shell: Zsh inxi: 3.3.06
