I’ve been working fine with Manjaro KDE from long time ago, I work with dual boot (Windows 10 / Manjaro KDE) and two (NTFS) drives mounted from booting. After several months without using Manjaro, I full-updated system and changed kernel to 5.4.x LTS, and proprietary graphic drivers to video-nvidia-440xx. Shortly after I started having problems with random freezes ans reboots. Recently I’ve done a fresh installation (EFI(fat32,100MB), / (root, ext4, 190GB), swap (4GB)), the same problem arose some time later. I tried Ubuntu Budgie without any problems. With Windows 10 no problem.
The output for inxi -Fza
is:
System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=8c5e9e33-d0ff-4332-869d-9438cea2160a rw quiet
resume=UUID=1f1b1cc2-dbdc-47c1-924c-290b3b99e43e udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: CROSSHAIR VI HERO v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 1701 date: 09/22/2017
CPU: Topology: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
microcode: 8001129 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 95844
Speed: 1831 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz): 1: 2678 2: 2278 3: 1373 4: 1373 5: 1374
6: 1371 7: 1375 8: 1374 9: 1319 10: 1318 11: 1318 12: 1318 13: 1317 14: 1315 15: 1375 16: 1374
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nouveau v: kernel alternate: nvidia_drm,nvidia
bus ID: 29:00.0 chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting alternate: fbdev,nouveau,nv,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
OpenGL: renderer: NV134 v: 4.3 Mesa 20.1.6 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 29:00.1
chip ID: 10de:10f0
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 2b:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.8.3-2-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k port: e000 bus ID: 23:00.0
chip ID: 8086:1539
IF: enp35s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.73 TiB used: 1.35 TiB (49.5%)
ID-1: /dev/sda vendor: Western Digital model: WD10EARS-00Y5B1 size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 0A80 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-75WN4A0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-3: /dev/sdc vendor: Western Digital model: WD10EZRX-00L4HB0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
Partition: ID-1: / raw size: 196.00 GiB size: 191.92 GiB (97.92%) used: 17.54 GiB (9.1%) fs: ext4 dev: /dev/sdb7
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb8
Sensors: System Temperatures: cpu: 36.8 C mobo: N/A gpu: nouveau temp: 35 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Info: Processes: 337 Uptime: 2m Memory: 15.63 GiB used: 1.37 GiB (8.8%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1129 lib: 293 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Any solution? Thanks in advance.
