Hello.
I’ve noticed my laptop has slowed down significantly after a recent update in which my manjaro OS broke and I had to reinstall grub since the update didn’t finish. Everything from opening applications to booting and shutting down is several times slower than it used to be. And this is despite my system still running with significant room for more processing tasks and memory usage. Below is a snapshot of the system resource use, Ironically it took spectacle about a minute to successfully open after I called it.
And here is the full system information. Please feel free to request for more information if necessary.
user > inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=799acea8-83e9-4271-880a-119665f23be5 rw quiet apparmor=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Laptop 15-cs3xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 86E2 v: 95.32 serial: <superuser required> UEFI: Insyde
v: F.06 date: 04/08/2020
ID-1: BAT0 charge: 25.9 Wh (67.6%) condition: 38.3/38.3 Wh (100.0%)
volts: 11.5 min: 11.4 model: HP Primary type: Li-ion serial: N/A
status: Discharging
RAM: total: 15.42 GiB used: 5.04 GiB (32.7%)
RAM Report:
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA8
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 963 high: 1003 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 963 2: 985 3: 953 4: 941
5: 957 6: 959 7: 944 8: 1003 bogomips: 19048
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:8a56 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
driver: N/A alternate: nouveau pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 06:00.0 chip-ID: 10de:174d class-ID: 0302
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b627 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 built: 2018 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x194mm (13.5x7.6") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: Unknown
lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 10:00.0
IF-ID-1: anbox0 state: down mac: <filter>
IP v4: <filter> scope: global
IF-ID-2: docker0 state: down mac: <filter>
bus-ID: 1-10:3 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 7060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 238.28 GiB (25.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 7C scheme: GPT
ID-1: / raw-size: 292.97 GiB size: 287.31 GiB (98.07%)
used: 238.25 GiB (82.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 799acea8-83e9-4271-880a-119665f23be5
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 163E-ECA1
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 390.51 GiB fs: ntfs label: N/A
uuid: 8226551426550A95
ID-3: /dev/sda5 maj-min: 8:5 size: 247.43 GiB fs: ntfs label: N/A
uuid: C2D45BCED45BC379
ID-4: /dev/sda6 maj-min: 8:6 size: 499 MiB fs: ntfs label: N/A
uuid: E6C6C5B9C6C58A6F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:14 info: Lab126 KFONWI type: <vendor specific> driver: usbfs
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 1949:0588
class-ID: 0000 serial: <filter>
Device-2: 1-3:2 info: Chicony HP Wide Vision HD Camera type: Video
Device-3: 1-10:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 319 Uptime: 3h 59m wakeups: 1 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 2130
pacman: 2068 lib: 465 flatpak: 36 snap: 26 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.13
> glxinfo | grep OpenGL ✔ 3s
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics (ICL GT1)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 21.3.7
OpenGL core profile shading language version string: 4.60
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.3.7
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.3.7
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
>inxi -Fza ✔
ID-1: BAT0 charge: 23.0 Wh (60.1%) condition: 38.3/38.3 Wh (100.0%)
volts: 11.4 min: 11.4 model: HP Primary type: Li-ion serial: N/A
status: Discharging
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 893 high: 961 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 936 2: 944 3: 961 4: 952
5: 830 6: 838 7: 732 8: 956 bogomips: 19048
Type: spectre_v2
driver: N/A alternate: nouveau pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 06:00.0 chip-ID: 10de:174d class-ID: 0302
screens: 1
modes: 1920x1080
direct render: Yes
class-ID: 0104
Local Storage: total: 931.51 GiB used: 240.86 GiB (25.9%)
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 7C scheme: GPT
used: 240.84 GiB (83.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
Processes: 309 Uptime: 4h 11m wakeups: 1 Memory: 15.42 GiB
used: 4.63 GiB (30.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 2130 pacman: 2068 lib: 465 flatpak: 36
snap: 26 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
Looking at the task manager, I see that most of the top slots when sorted by memory usage are taken by Google Chrome as can be seen below.
Still there’s a lot of leeway for memory and CPU usage.
It’s honestly absurd how slow it has become. I would appreciate any advice.
