I am currently trying to connect a Steam Deck to my laptop via a Narvitech NJ300. From what I can tell it is a plug-and-play UVC device.
I tried two distinct setups: one connects the Steam Deck to a powered USB-C hub, which has an HDMI to HDMI output feeding into the NJ300, and a USB-C to USB-C connector between the output of the NJ300 to my computer. The other directly connects the Deck to the NJ300 with a USB-C to HDMI connector, and connects to my computer in the same manner.
When I connect it to my laptop, however, neither VLC nor OBS can properly read the output. The output does show up, in OBS and v4l2-ctl. The game does properly display upon switching to the output, and I confirmed with some animated loading scenes and key inputs that the output is not frozen, but will only do so for roughly one second. After that, the output will go dark. The only way to get the output again is by switching the device to a built-in webcam on the laptop and back on OBS, or by restarting VLC.
I have tried it powered (with a hub connected to the Deck’s port), unpowered, with different cables, directly connected to the port, plugged into different ports on my laptop, as YU12, YV12, MJPEG, etc., and the results are the same. The only thing I haven’t tried swapping out is the capture card itself; considering its price, I would like to know if I am overlooking something first. Notably, I saw instructions for the input to be configured as YUY2, but I don’t see this option in OBS, only the three aforementioned formats.
inxi
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9f1e15e1-145d-4d25-94c0-790195da9733 rw quiet apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1 ibt=off
iommu=soft snd_hda_intel.power_save=0 intel_iommu=igfx_off
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: XPS 17 9710 v: N/A
Mobo: Dell model: 0TXN0W v: A00 serial: <superuser required> part-nu: 0A5D
uuid: <superuser required> UEFI: Dell v: 1.22.0 date: 08/11/2023
ID-1: BAT0 charge: 92.2 Wh (100.0%) condition: 92.2/95.1 Wh (97.0%)
volts: 12.7 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly serial: <filter>
status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x4E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1131 high: 2668 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2434 3: 872 4: 800
5: 800 6: 800 7: 2668 8: 800 9: 800 10: 1662 11: 800 12: 800 13: 1673
14: 800 15: 789 16: 807 bogomips: 73744
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-11:5 chip-ID: 0bda:5510
Display: x11 server: X.Org v: 21.1.12 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 266 s-size: 366x229mm (14.41x9.02")
s-diag: 432mm (17")
Monitor-1: eDP-1 model: Sharp 0x14d6 built: 2020 res: 3840x2400 hz: 60
dpi: 266 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
ratio: 16:10 modes: 3840x2400
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a60 memory: 61.07 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.67 device-ID: 10de:2520
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD Graphics
(TGL GT1) driver: mesa intel v: 24.0.2-manjaro1.1 device-ID: 8086:9a60
surfaces: xcb,xlib
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Conexant Systems (Rockwell) Hi-Res Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:43 chip-ID: 0572:1b08 class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:6 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.86 TiB used: 725.68 GiB (38.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KXG60PNV2T04 NVMe
2048GB size: 1.86 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 10704103
temp: 31.9 C scheme: GPT
ID-1: / raw-size: 64 GiB size: 61.94 GiB (96.79%) used: 44.25 GiB (71.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 284 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.73 TiB size: 1.7 TiB (98.37%)
used: 681.43 GiB (39.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-1: swap-1 type: partition size: 68.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 49.0 C mobo: 39.0 C
Fan Speeds (rpm): cpu: 1354
Memory: total: 64 GiB note: est. available: 62.53 GiB used: 9.74 GiB (15.6%)
Processes: 390 Power: uptime: 1d 3h 31m states: freeze,mem,disk
suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 24.96 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1750 pm: pacman pkgs: 1741 libs: 476 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 9 Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12
Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.34```
VLC output
VLC media player 3.0.20 Vetinari (revision 3.0.20-0-g6f0d0ab126b)
[00005591008ee5e0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[mjpeg @ 0x7f9a3c01d740] No JPEG data found in image
[mjpeg @ 0x7f9a3c01d740] No JPEG data found in image```
OBS output when resetting input source to get the image to show up briefly. No errors were reported.
info: v4l2-input: /dev/video3 seems to not support video capture
info: v4l2-input: /dev/video1 seems to not support video capture
info: v4l2-input: /dev/video8 seems to not support video capture
info: v4l2-input: Found device 'Integrated_Webcam_HD: Integrate' at /dev/video2
info: v4l2-input: Found device 'Integrated_Webcam_HD: Integrate' at /dev/video0
info: v4l2-input: Stepwise and Continuous framerates are currently hardcoded
info: v4l2-input: Pixelformat: Motion-JPEG (available)
info: v4l2-input: Pixelformat: RGB3 (Emulated) (unavailable)
info: v4l2-input: Pixelformat: BGR3 (Emulated) (available)
info: v4l2-input: Pixelformat: YU12 (Emulated) (available)
info: v4l2-input: Pixelformat: YV12 (Emulated) (available)
info: v4l2-input: Found input 'Camera 1' (Index 0)
info: v4l2-input: Start capture from /dev/video7
info: v4l2-input: Input: 0
info: v4l2-input: Resolution: 1920x1080
info: v4l2-input: Linesize: 1920 Bytes
info: v4l2-input: Framerate: 60.00 fps
info: v4l2-input: /dev/video7: select timeout set to 83333 (5x frame periods)```
v4l2-ctl --list-devices
Integrated_Webcam_HD: Integrate (usb-0000:00:14.0-11):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/media0
/dev/media1
NarviCapture U3 HD60 4K Device: (usb-0000:00:14.0-3):
/dev/video7
/dev/video8
/dev/media2```
