Hi, recently Skype stopped detecting microphone (“no device found” in audio settings), and it seems like it’s not visible in other apps too (tried OBS and Zoom). It’s not in the system tray either. It used to work fine, so some update must have broken it. And I’m on kernel 5.4 but it’s the same with the 5.11.
Here’s inxi Fazy:
Kernel: 5.4.101-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=adebe5df-56a6-44e4-9f48-03451392bc85 ro quiet udev.log_priority=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP ENVY Laptop 15-ep0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 878D v: 18.32 serial: <filter> UEFI: AMI v: F.05
date: 12/29/2020
ID-1: BAT0 charge: 15.6 Wh condition: 79.3/79.3 Wh (100%) volts: 10.8/11.6
model: HP Primary type: Li-ion serial: <filter> status: Discharging
cycles: 33
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
L2 cache: 12 MiB
bogomips: 62431
Speed: 900 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 901 7: 900 8: 901 9: 900 10: 901 11: 902 12: 900
Device-1: Intel UHD Graphics vendor: Hewlett-Packard driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9bc4 class ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:2191 class ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-6:2 chip ID: 0408:5429 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:06c8 class ID: 0401
Sound Server: ALSA v: k5.4.101-1-MANJARO
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus ID: 00:14.3 chip ID: 8086:06f0 class ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus ID: 1-14:4
chip ID: 8087:0026 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus ID: 00:17.0 chip ID: 8086.282a rev: N/A
Local Storage: total: 476.94 GiB used: 194.35 GiB (40.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000H1
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: HPS0NEXF scheme: GPT
ID-1: / raw size: 183.96 GiB size: 180.08 GiB (97.89%)
used: 84.16 GiB (46.7%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%)
used: 139.4 MiB (54.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 3.73 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:5
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 396 Uptime: 23m wakeups: 1235 Memory: 15.41 GiB
used: 4.12 GiB (26.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1443 pacman: 1422 lib: 461 flatpak: 9 snap: 12 Shell: Bash
v: 5.1.0 running in: yakuake inxi: 3.3.01
here’s ALSA info:
http://alsa-project.org/db/?f=046b74f5be3f4498765ff313bf3e0e9ce135470e
Any help appreciated, I use teleconferencing for my everyday work and have to resort to windows for now…
EDIT: I double checked with a different kernel - in 5.4 mic is completely gone, in 5.11 the mic is fine but Skype doesn’t see the speakers now (they are otherwise ok elsewhere).
