In short, I tried installing zoom application from AUR, and when it started downloading I got kicked out of GNOME and the system rebooted. The GRUB is working, and when I tried to boot manjaro it just stuck on asus logo, with only single working key, f1, which sends me to blank tty where no command works and I can only type stuff. I’m sorry the description is rushed but it’s the first time this happened and I’m kinda panicking..
Also, I booted SystemRescue and my files seems intact.. I chrooted into the manjaro partition as well
update: the system booted after I used fsck with the partition. I really dunno what happened
Since you haven’t provided any information about your system (inxi -czv8), we can only guess. But your description suggests a few things.
It sounds like you ran out of RAM (perhaps because you didn’t enable swap).
Such a reboot will certainly not have properly completed the file system beforehand. Can you imagine what would happen then?
We can’t know, but we can guess ![]()
If the missing swap was the cause (but it could also be something completely different, which we might see with inxi), then it will happen again at some point. The consequences (the damage) can be considerably greater.
So you shouldn’t just forget about it now without looking for the cause.
This time it was just a black eye. Next time it could be a total loss.
Running out of disk space can also be an issue, particularly when compiling/building packages.
It’s worth keeping an eye on the size of your pacman cache as well, as this can really build up:
du -h /var/cache/pacman/
… and clear it out periodically.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a
at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Re-opened in case the OP wants to further investigate what may be causing the issue.
Hello. Sorry for the messy topic: my OP was rather rushed. My bad for not providing system information, here it is:
inxi -zv8
Kernel: 6.12.44-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=2b46e692-5b16-4ea1-8147-89c990b86bc2 rw quiet splash
mem_sleep_default=deep apparmor=1 security=apparmor udev.log_priority=3
nvidia-drm.modeset=1
Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell with: ulauncher
tools: gsd-screensaver-proxy avail: hypridle, hyprlock, xfce4-screensaver
dm: 1: GDM v: 48.0 2: LightDM v: 1.32.0 note: stopped Distro: Manjaro
base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX507ZM_FX507ZM
v: 1.0 serial:
Mobo: ASUSTeK model: FX507ZM v: 1.0 serial:
uuid: UEFI: American Megatrends LLC. v: FX507ZM.315
date: 06/17/2022
ID-1: BAT1 charge: 68.4 Wh (100%) condition: 68.4/90 Wh (76%) volts: 16.47
min: 15.86 model: ASUS A32-K55 type: Li-ion serial: N/A charging:
status: full control: start: N/A end: 100% cycles: N/A
ID-2: hidpp_battery_0 charge: 48% condition: N/A volts: 3.81 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: charging: status: discharging cycles: N/A
System RAM: total: 64 GiB available: 62.42 GiB used: 12.89 GiB (20.6%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 32 GiB speed: spec: 5600 MT/s actual: 4800 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: CT32G56C46S5.M16D1
serial:
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
serial:
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x437
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 473 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 473 2: 473 3: 473 4: 473
5: 473 6: 473 7: 473 8: 473 9: 473 10: 473 11: 473 12: 473 13: 473 14: 473
15: 473 16: 473 17: 473 18: 473 19: 473 20: 473 bogomips: 107560
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
Type: spectre_v1 mitigation: usercopy/swapgs barriers and \__user pointer
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT2 \[Iris Xe Graphics\] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2021-22+ ports: active: none off: eDP-1 empty: DP-1,DP-2
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M \[GeForce RTX 3060 Mobile / Max-Q\] vendor: ASUSTeK
driver: nvidia v: 575.64.05 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-08; EOL\~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 ports:
active: none off: HDMI-A-1 empty: DP-3,eDP-2 bus-ID: 0000:01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3:7
chip-ID: 041e:40a1 class-ID: 0102 serial:
Device-4: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:6 chip-ID: 322e:202c
class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris
gpu: i915,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE serial:
built: 2019 res: 2560x1080 dpi: 97 gamma: 1.2 chroma: red: x: 0.651 y: 0.333
green: x: 0.306 y: 0.631 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 673x284mm (26.5x11.18") diag: 730mm (28.8") modes: 2560x1080,
1920x1080, 1680x1050, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480
Monitor-2: eDP-1 model: Najing CEC Panda 0x004d built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.596 y: 0.361 green: x: 0.345 y: 0.557
blue: x: 0.157 y: 0.106 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop
GPU/PCIe/SSE2 memory: 5.86 GiB display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: nvidia v: 575.64.05
device-ID: 10de:2520 surfaces: N/A device: 1 type: integrated-gpu
name: Intel Iris Xe Graphics (ADL GT2) driver: mesa intel
v: 25.2.1-arch1.4 device-ID: 8086:46a6 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
de: kscreen-doctor,xfce4-display-settings gpu: nvidia-settings,nvidia-smi
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-4: Audient EVO4 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 2708:0006
class-ID: fe01
Device-5: ASUSTek C-Media Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:8
chip-ID: 0b05:6203 class-ID: 0300
API: ALSA v: k6.12.44-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF: wlo1 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
Device-2: Intel Ethernet I219-LM vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 0000:00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
IF: eno2 state: down mac:
IF-ID-1: tun2 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IP v4: scope: global
WAN IP:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:9 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 648.05 GiB (45.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: fw-rev: 002C temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: MSI model: M390 1TB
lanes: 4 tech: SSD serial: fw-rev: EHFM32.0 temp: 51.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Generic model: Flash Disk
size: 3.75 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: fw-rev: 8.07
scheme: MBR
ID-1: / raw-size: 733.9 GiB size: 721.79 GiB (98.35%)
used: 648.02 GiB (89.8%) fs: ext4 dev: /dev/nvme1n1p6 maj-min: 259:12
label: N/A uuid: 2b46e692-5b16-4ea1-8147-89c990b86bc2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 31.8 MiB (12.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 3CD1-B482
ID-1: swap-1 type: file size: 24 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs:
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 453.07 GiB fs: bitlocker
label: ASUS-F15 OS 15.02.2024 uuid: 3e016b54-18ba-4f2d-8bd6-bde57c89ec8e
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 786 MiB fs: ntfs label: N/A
uuid: 9A8EB8E38EB8B959
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 22 GiB fs: ntfs label: RESTORE
uuid: 4CB4A1B2B4A19F48
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 200 MiB fs: vfat label: MYASUS
uuid: FAA2-05DD
ID-6: /dev/nvme1n1p1 maj-min: 259:8 size: 16 MiB fs:
ID-7: /dev/nvme1n1p2 maj-min: 259:9 size: 195.6 GiB fs: ntfs label: Files
uuid: 01DBB069510CCE50
ID-8: /dev/nvme1n1p4 maj-min: 259:10 size: 1024 MiB fs: vfat label: N/A
uuid: 7BCB-96C0
ID-9: /dev/nvme1n1p5 maj-min: 259:11 size: 1024 MiB fs: ext4 label: N/A
uuid: 905fe33e-45b4-4698-962d-3db926d5817b
ID-10: /dev/sda1 maj-min: 8:1 size: 3.63 GiB fs: iso9660
ID-11: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 9D59-BEAA
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 3-1.2:5 info: Alcor Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 058f:6387 class-ID: 0806
serial:
Device-2: 3-1.3:7 info: Creative Live! Cam Sync 1080p V2 type: video,audio
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 256mA
Device-3: 3-2:3 info: Logitech Lightspeed Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Device-4: 3-5:4 info: Audient EVO4 type: audio driver: snd-usb-audio
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 2708:0006 class-ID: fe01
Device-5: 3-7:6 info: Sonix USB2.0 HD UVC WebCam type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 322e:202c class-ID: 0e02
Device-6: 3-9:8 info: ASUSTek C-Media Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Device-7: 3-10:9 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 4-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
System Temperatures: cpu: 54.5 C mobo: N/A
Fan Speeds (rpm): cpu: 3600
Packages: 2156 pm: pacman pkgs: 2104 libs: 552
tools: gnome-software,pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 44
pm: snap pkgs: 8
1: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
2: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
3: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
4: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 532
1: cpu: 36.4% command: firefox pid: 6483 mem: 515.6 MiB (0.8%)
2: cpu: 18.2% command: firefox pid: 3480 mem: 970.2 MiB (1.5%)
3: cpu: 15.2% command: steamwebhelper pid: 12545 mem: 506.4 MiB (0.7%)
4: cpu: 9.8% command: gnome-shell pid: 2508 mem: 676.5 MiB (1.0%)
5: cpu: 9.2% command: Telegram pid: 7190 mem: 990.4 MiB (1.5%)
Memory top: 5 of 532
1: mem: 1833.5 MiB (2.8%) command: baobab pid: 16309 cpu: 6.8%
2: mem: 990.4 MiB (1.5%) command: Telegram pid: 7190 cpu: 9.2%
3: mem: 970.2 MiB (1.5%) command: firefox pid: 3480 cpu: 18.2%
4: mem: 676.5 MiB (1.0%) command: gnome-shell pid: 2508 cpu: 9.8%
5: mem: 615.0 MiB (0.9%) command: WebKitWebProcess pid: 7437 cpu: 0.9%
Processes: 532 Power: uptime: 1h 48m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.94 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kitty
inxi: 3.3.39
also, I was recommended to view the journalctl log. here’s the last few seconds before everything happened: (sorry for russian time locale)
journalctl -b -3 -k
окт 05 14:10:10 asusTUF15 gnome-shell\[28310\]: (EE) could not connect to wayland server
окт 05 14:10:10 asusTUF15 kernel: nautilus\[28733\]: segfault at 8 ip 000055b928b1c9c5 sp 00007ffd0e25c790 error 4 in nautilus\[339c5,55b928b0b000+be000\] likely on CPU 13 (core 25, socket 0)
окт 05 14:10:10 asusTUF15 kernel: Code: 48 8d 0d 3e 71 0b 00 ba 0f 00 00 00 ff 15 0b 59 14 00 4d 85 ed 74 09 4c 89 ef ff 15 55 85 14 00 48 8b 85 f8 fe ff ff 45 31 f6 <48> 8b 48 08 48 8d 15 40 71 0b 00 be 20 00 00 00 31 c0 48 8d 3d fa
окт 05 14:10:10 asusTUF15 systemd-coredump\[28794\]: Process 28733 (nautilus) of user 1000 terminated abnormally with signal 11/SEGV, processing…
окт 05 14:10:10 asusTUF15 systemd-coredump\[28794\]: Failed to send coredump datagram: Broken pipe
окт 05 14:10:10 asusTUF15 qjackctl\[27839\]: qt.qpa.xcb: could not connect to display :0
окт 05 14:10:10 asusTUF15 qjackctl\[27839\]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
окт 05 14:10:10 asusTUF15 qjackctl\[27839\]: qt.qpa.plugin: Could not load the Qt platform plugin “xcb” in “” even though it was found.
окт 05 14:10:10 asusTUF15 picom.desktop\[27819\]: \[ 05.10.2025 14:10:10.197 main FATAL ERROR \] Can’t open display.
окт 05 14:10:10 asusTUF15 unknown\[27826\]: cannot open display: :0
окт 05 14:10:10 asusTUF15 unknown\[27815\]: cannot open display: :0
окт 05 14:10:10 asusTUF15 kernel: usb 3-1.2: reset high-speed USB device number 5 using xhci_hcd
окт 05 14:10:10 asusTUF15 unknown\[27890\]: cannot open display: :0
окт 05 14:10:10 asusTUF15 unknown\[27604\]: Failed to open display
окт 05 14:10:10 asusTUF15 systemd\[2060\]: dbus-:1.2-org.freedesktop.FileManager1@0.service: Main process exited, code=dumped, status=11/SEGV
окт 05 14:10:10 asusTUF15 systemd\[2060\]: dbus-:1.2-org.freedesktop.FileManager1@0.service: Failed with result ‘core-dump’.
окт 05 14:10:10 asusTUF15 unknown\[27783\]: Failed to open display
окт 05 14:10:10 asusTUF15 msm_notifier\[27879\]: qt.qpa.xcb: could not connect to display :0
окт 05 14:10:10 asusTUF15 msm_notifier\[27879\]: qt.qpa.plugin: Could not load the Qt platform plugin “xcb” in “” even though it was found.
then there’s a boot after that, where the system was just numb and unresponsive, locked in tty.
journalctl -b -2 -k
окт 05 14:19:02 asusTUF15 kernel: Linux version 6.12.44-2-MANJARO (linux612@manjaro) (gcc (GCC) 15.2.1 20250813, GNU ld (GNU Binutils) 2.45.0) #1 SMP PREEMPT_DYNAMIC Sat, 30 Aug 2025 05:34:59 +0000
окт 05 14:19:02 asusTUF15 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=2b46e692-5b16-4ea1-8147-89c990b86bc2 rw quiet splash mem_sleep_default=deep apparmor=1 security=apparmor udev.log_pri>
окт 05 14:19:02 asusTUF15 kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
окт 05 14:19:02 asusTUF15 kernel: BIOS-provided physical RAM map:
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000000000000-0x000000000009dfff\] usable
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x000000000009e000-0x000000000009efff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x000000000009f000-0x000000000009ffff\] usable
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000000a0000-0x00000000000fffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000000100000-0x0000000037d56fff\] usable
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000037d57000-0x0000000040b73fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000040b74000-0x0000000040c5afff\] ACPI data
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000040c5b000-0x0000000040dc8fff\] ACPI NVS
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000040dc9000-0x00000000417fefff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000417ff000-0x00000000417fffff\] usable
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000041800000-0x0000000047ffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000048c00000-0x000000004f7fffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000c0000000-0x00000000cfffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000fe000000-0x00000000fe010fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000fec00000-0x00000000fec00fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000fed00000-0x00000000fed00fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000fed20000-0x00000000fed7ffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000fee00000-0x00000000fee00fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x00000000ff000000-0x00000000ffffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: BIOS-e820: \[mem 0x0000000100000000-0x00000010b07fffff\] usable
окт 05 14:19:02 asusTUF15 kernel: The simpledrm driver will not be probed
окт 05 14:19:02 asusTUF15 kernel: NX (Execute Disable) protection: active
окт 05 14:19:02 asusTUF15 kernel: APIC: Static calls initialized
окт 05 14:19:02 asusTUF15 kernel: e820: update \[mem 0x305a9018-0x305cd657\] usable ==> usable
окт 05 14:19:02 asusTUF15 kernel: extended physical RAM map:
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000000000000-0x000000000009dfff\] usable
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x000000000009e000-0x000000000009efff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x000000000009f000-0x000000000009ffff\] usable
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000000a0000-0x00000000000fffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000000100000-0x00000000305a9017\] usable
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000305a9018-0x00000000305cd657\] usable
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000305cd658-0x0000000037d56fff\] usable
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000037d57000-0x0000000040b73fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000040b74000-0x0000000040c5afff\] ACPI data
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000040c5b000-0x0000000040dc8fff\] ACPI NVS
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000040dc9000-0x00000000417fefff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000417ff000-0x00000000417fffff\] usable
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000041800000-0x0000000047ffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000048c00000-0x000000004f7fffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000c0000000-0x00000000cfffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000fe000000-0x00000000fe010fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000fec00000-0x00000000fec00fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000fed00000-0x00000000fed00fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000fed20000-0x00000000fed7ffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000fee00000-0x00000000fee00fff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x00000000ff000000-0x00000000ffffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: reserve setup_data: \[mem 0x0000000100000000-0x00000010b07fffff\] usable
окт 05 14:19:02 asusTUF15 kernel: efi: EFI v2.8 by American Megatrends
окт 05 14:19:02 asusTUF15 kernel: efi: ACPI=0x40c5a000 ACPI 2.0=0x40c5a014 TPMFinalLog=0x40cf4000 SMBIOS=0x41587000 SMBIOS 3.0=0x41586000 MEMATTR=0x335cc018 ESRT=0x335dab98 INITRD=0x333cc918 RNG=0x40ba1018 TPMEve>
окт 05 14:19:02 asusTUF15 kernel: random: crng init done
окт 05 14:19:02 asusTUF15 kernel: efi: Remove mem84: MMIO range=\[0xc0000000-0xcfffffff\] (256MB) from e820 map
окт 05 14:19:02 asusTUF15 kernel: e820: remove \[mem 0xc0000000-0xcfffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: efi: Not removing mem85: MMIO range=\[0xfe000000-0xfe010fff\] (68KB) from e820 map
окт 05 14:19:02 asusTUF15 kernel: efi: Not removing mem86: MMIO range=\[0xfec00000-0xfec00fff\] (4KB) from e820 map
окт 05 14:19:02 asusTUF15 kernel: efi: Not removing mem87: MMIO range=\[0xfed00000-0xfed00fff\] (4KB) from e820 map
окт 05 14:19:02 asusTUF15 kernel: efi: Not removing mem89: MMIO range=\[0xfee00000-0xfee00fff\] (4KB) from e820 map
окт 05 14:19:02 asusTUF15 kernel: efi: Remove mem90: MMIO range=\[0xff000000-0xffffffff\] (16MB) from e820 map
окт 05 14:19:02 asusTUF15 kernel: e820: remove \[mem 0xff000000-0xffffffff\] reserved
окт 05 14:19:02 asusTUF15 kernel: SMBIOS 3.4.0 present.
окт 05 14:19:02 asusTUF15 kernel: DMI: ASUSTeK COMPUTER INC. ASUS TUF Gaming F15 FX507ZM_FX507ZM/FX507ZM, BIOS FX507ZM.315 06/17/2022
окт 05 14:19:02 asusTUF15 kernel: DMI: Memory slots populated: 2/2
окт 05 14:19:02 asusTUF15 kernel: tsc: Detected 2700.000 MHz processor
окт 05 14:19:02 asusTUF15 kernel: tsc: Detected 2688.000 MHz TSC
окт 05 14:19:02 asusTUF15 kernel: e820: update \[mem 0x00000000-0x00000fff\] usable ==> reserved
окт 05 14:19:02 asusTUF15 kernel: e820: remove \[mem 0x000a0000-0x000fffff\] usable
окт 05 14:19:02 asusTUF15 kernel: last_pfn = 0x10b0800 max_arch_pfn = 0x400000000
окт 05 14:19:02 asusTUF15 kernel: MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
окт 05 14:19:02 asusTUF15 kernel: x86/PAT: Configuration \[0-7\]: WB WC UC- UC WB WP UC- WT
окт 05 14:19:02 asusTUF15 kernel: last_pfn = 0x41800 max_arch_pfn = 0x400000000
окт 05 14:19:02 asusTUF15 kernel: esrt: Reserving ESRT space from 0x00000000335dab98 to 0x00000000335dac98.
окт 05 14:19:02 asusTUF15 kernel: e820: update \[mem 0x335da000-0x335dafff\] usable ==> reserved
окт 05 14:19:02 asusTUF15 kernel: Using GB pages for direct mapping
окт 05 14:19:02 asusTUF15 kernel: Secure boot disabled
окт 05 14:19:02 asusTUF15 kernel: RAMDISK: \[mem 0x276f8000-0x2c0adfff\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Early table checksum verification disabled
окт 05 14:19:02 asusTUF15 kernel: ACPI: RSDP 0x0000000040C5A014 000024 (v02 *ASUS*)
окт 05 14:19:02 asusTUF15 kernel: ACPI: XSDT 0x0000000040C59728 000134 (v01 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: FACP 0x0000000040C55000 000114 (v06 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: DSDT 0x0000000040BE7000 06DFB9 (v02 *ASUS* Notebook 01072009 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: FACS 0x0000000040DC7000 000040
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040C56000 002877 (v02 DptfTb DptfTabl 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: FIDT 0x0000000040BE6000 00009C (v01 *ASUS* Notebook 01072009 AMI 00010013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: MSDM 0x0000000040BE5000 000055 (v03 *ASUS* Notebook 01072009 ASUS 00000001)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BE4000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BDE000 005D0B (v02 CpuRef CpuSsdt 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BDB000 002AA1 (v02 SaSsdt SaSsdt 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BD7000 0033D3 (v02 INTEL IgfxSsdt 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BC9000 00D39F (v02 INTEL TcssSsdt 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: HPET 0x0000000040BC8000 000038 (v01 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: APIC 0x0000000040BC7000 0001DC (v05 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: MCFG 0x0000000040BC6000 00003C (v01 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BC1000 004BA7 (v02 *ASUS* AdlP_Rvp 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: NHLT 0x0000000040BC0000 0002F1 (v00 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: LPIT 0x0000000040BBF000 0000CC (v01 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: WSMT 0x0000000040BBE000 000028 (v01 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BBB000 002A83 (v02 *ASUS* PtidDevc 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BB8000 002357 (v02 *ASUS* TbtTypeC 00000000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: DBGP 0x0000000040BB7000 000034 (v01 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: DBG2 0x0000000040BB6000 000054 (v00 *ASUS* Notebook 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BB5000 000ECF (v02 *ASUS* UsbCTabl 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: DMAR 0x0000000040BB4000 000088 (v02 INTEL EDK2 00000002 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BB3000 0008E7 (v02 INTEL xh_adlLP 00000000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BAF000 003AEA (v02 SocGpe SocGpe 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BAB000 0035A2 (v02 SocCmn SocCmn 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BAA000 000457 (v02 HgRef HgRpSsdt 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BA9000 000144 (v02 Intel ADebTabl 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: BGRT 0x0000000040BA8000 000038 (v01 *ASUS* Notebook 01072009 AMI 00010013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: UEFI 0x0000000040CD6000 00063A (v01 INTEL RstVmdE 00000000 INTL 00000000)
окт 05 14:19:02 asusTUF15 kernel: ACPI: UEFI 0x0000000040CD5000 00005C (v01 INTEL RstVmdV 00000000 INTL 00000000)
окт 05 14:19:02 asusTUF15 kernel: ACPI: TPM2 0x0000000040BA7000 00004C (v04 *ASUS* Notebook 00000001 AMI 00000000)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0x0000000040BA4000 002DCA (v01 OptRf2 Opt2Tabl 00001000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: PHAT 0x0000000040BA3000 00062D (v01 *ASUS* Notebook 00000005 MSFT 0100000D)
окт 05 14:19:02 asusTUF15 kernel: ACPI: FPDT 0x0000000040BA2000 000044 (v01 *ASUS* A M I 01072009 AMI 01000013)
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving FACP table memory at \[mem 0x40c55000-0x40c55113\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving DSDT table memory at \[mem 0x40be7000-0x40c54fb8\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving FACS table memory at \[mem 0x40dc7000-0x40dc703f\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40c56000-0x40c58876\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving FIDT table memory at \[mem 0x40be6000-0x40be609b\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving MSDM table memory at \[mem 0x40be5000-0x40be5054\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40be4000-0x40be438b\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bde000-0x40be3d0a\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bdb000-0x40bddaa0\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bd7000-0x40bda3d2\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bc9000-0x40bd639e\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving HPET table memory at \[mem 0x40bc8000-0x40bc8037\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving APIC table memory at \[mem 0x40bc7000-0x40bc71db\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving MCFG table memory at \[mem 0x40bc6000-0x40bc603b\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bc1000-0x40bc5ba6\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving NHLT table memory at \[mem 0x40bc0000-0x40bc02f0\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving LPIT table memory at \[mem 0x40bbf000-0x40bbf0cb\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving WSMT table memory at \[mem 0x40bbe000-0x40bbe027\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bbb000-0x40bbda82\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bb8000-0x40bba356\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving DBGP table memory at \[mem 0x40bb7000-0x40bb7033\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving DBG2 table memory at \[mem 0x40bb6000-0x40bb6053\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bb5000-0x40bb5ece\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving DMAR table memory at \[mem 0x40bb4000-0x40bb4087\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bb3000-0x40bb38e6\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40baf000-0x40bb2ae9\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40bab000-0x40bae5a1\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40baa000-0x40baa456\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40ba9000-0x40ba9143\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving BGRT table memory at \[mem 0x40ba8000-0x40ba8037\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving UEFI table memory at \[mem 0x40cd6000-0x40cd6639\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving UEFI table memory at \[mem 0x40cd5000-0x40cd505b\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving TPM2 table memory at \[mem 0x40ba7000-0x40ba704b\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving SSDT table memory at \[mem 0x40ba4000-0x40ba6dc9\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving PHAT table memory at \[mem 0x40ba3000-0x40ba362c\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: Reserving FPDT table memory at \[mem 0x40ba2000-0x40ba2043\]
окт 05 14:19:02 asusTUF15 kernel: No NUMA configuration found
окт 05 14:19:02 asusTUF15 kernel: Faking a node at \[mem 0x0000000000000000-0x00000010b07fffff\]
окт 05 14:19:02 asusTUF15 kernel: NODE_DATA(0) allocated \[mem 0x10b07d52c0-0x10b07fffff\]
окт 05 14:19:02 asusTUF15 kernel: Zone ranges:
окт 05 14:19:02 asusTUF15 kernel: DMA \[mem 0x0000000000001000-0x0000000000ffffff\]
окт 05 14:19:02 asusTUF15 kernel: DMA32 \[mem 0x0000000001000000-0x00000000ffffffff\]
окт 05 14:19:02 asusTUF15 kernel: Normal \[mem 0x0000000100000000-0x00000010b07fffff\]
окт 05 14:19:02 asusTUF15 kernel: Device empty
окт 05 14:19:02 asusTUF15 kernel: Movable zone start for each node
окт 05 14:19:02 asusTUF15 kernel: Early memory node ranges
окт 05 14:19:02 asusTUF15 kernel: node 0: \[mem 0x0000000000001000-0x000000000009dfff\]
окт 05 14:19:02 asusTUF15 kernel: node 0: \[mem 0x000000000009f000-0x000000000009ffff\]
окт 05 14:19:02 asusTUF15 kernel: node 0: \[mem 0x0000000000100000-0x0000000037d56fff\]
окт 05 14:19:02 asusTUF15 kernel: node 0: \[mem 0x00000000417ff000-0x00000000417fffff\]
окт 05 14:19:02 asusTUF15 kernel: node 0: \[mem 0x0000000100000000-0x00000010b07fffff\]
окт 05 14:19:02 asusTUF15 kernel: Initmem setup node 0 \[mem 0x0000000000001000-0x00000010b07fffff\]
окт 05 14:19:02 asusTUF15 kernel: On node 0, zone DMA: 1 pages in unavailable ranges
окт 05 14:19:02 asusTUF15 kernel: On node 0, zone DMA: 96 pages in unavailable ranges
окт 05 14:19:02 asusTUF15 kernel: On node 0, zone DMA32: 6824 pages in unavailable ranges
окт 05 14:19:02 asusTUF15 kernel: On node 0, zone Normal: 26624 pages in unavailable ranges
окт 05 14:19:02 asusTUF15 kernel: On node 0, zone Normal: 30720 pages in unavailable ranges
окт 05 14:19:02 asusTUF15 kernel: Reserving Intel graphics memory at \[mem 0x4b800000-0x4f7fffff\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: PM-Timer IO Port: 0x1808
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x01\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x02\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x03\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x04\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x05\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x06\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x07\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x08\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x09\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x0a\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x0b\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x0c\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x0d\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x0e\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x0f\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x10\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x11\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x12\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x13\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x14\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x15\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x16\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x17\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: ACPI: LAPIC_NMI (acpi_id\[0x00\] high edge lint\[0x1\])
окт 05 14:19:02 asusTUF15 kernel: IOAPIC\[0\]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
окт 05 14:19:02 asusTUF15 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
окт 05 14:19:02 asusTUF15 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
окт 05 14:19:02 asusTUF15 kernel: ACPI: Using ACPI (MADT) for SMP configuration information
окт 05 14:19:02 asusTUF15 kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
окт 05 14:19:02 asusTUF15 kernel: e820: update \[mem 0x3367e000-0x336acfff\] usable ==> reserved
окт 05 14:19:02 asusTUF15 kernel: TSC deadline timer available
окт 05 14:19:02 asusTUF15 kernel: CPU topo: Max. logical packages: 1
окт 05 14:19:02 asusTUF15 kernel: CPU topo: Max. logical dies: 1
окт 05 14:19:02 asusTUF15 kernel: CPU topo: Max. dies per package: 1
окт 05 14:19:02 asusTUF15 kernel: CPU topo: Max. threads per core: 2
окт 05 14:19:02 asusTUF15 kernel: CPU topo: Num. cores per package: 14
окт 05 14:19:02 asusTUF15 kernel: CPU topo: Num. threads per package: 20
окт 05 14:19:02 asusTUF15 kernel: CPU topo: Allowing 20 present CPUs plus 0 hotplug CPUs
окт 05 14:19:02 asusTUF15 kernel: PM: hibernation: Registered nosave memory: \[mem 0x00000000-0x00000fff\]
окт 05 14:19:02 asusTUF15 kernel: PM: hibernation: Registered nosave memory: \[mem 0x0009e000-0x0009efff\]
окт 05 14:19:02 asusTUF15 kernel: PM: hibernation: Registered nosave memory: \[mem 0x000a0000-0x000fffff\]
окт 05 14:19:02 asusTUF15 kernel: PM: hibernation: Registered nosave memory: \[mem 0x335da000-0x335dafff\]
окт 05 14:19:02 asusTUF15 kernel: PM: hibernation: Registered nosave memory: \[mem 0x3367e000-0x336acfff\]
окт 05 14:19:02 asusTUF15 kernel: PM: hibernation: Registered nosave memory: \[mem 0x37d57000-0x417fefff\]
окт 05 14:19:02 asusTUF15 kernel: PM: hibernation: Registered nosave memory: \[mem 0x41800000-0xffffffff\]
окт 05 14:19:02 asusTUF15 kernel: \[mem 0x4f800000-0xfdffffff\] available for PCI devices
окт 05 14:19:02 asusTUF15 kernel: Booting paravirtualized kernel on bare hardware
окт 05 14:19:02 asusTUF15 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
окт 05 14:19:02 asusTUF15 kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:20 nr_cpu_ids:20 nr_node_ids:1
окт 05 14:19:02 asusTUF15 kernel: percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
окт 05 14:19:02 asusTUF15 kernel: pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1\*2097152
окт 05 14:19:02 asusTUF15 kernel: pcpu-alloc: \[0\] 00 01 02 03 \[0\] 04 05 06 07
окт 05 14:19:02 asusTUF15 kernel: pcpu-alloc: \[0\] 08 09 10 11 \[0\] 12 13 14 15
окт 05 14:19:02 asusTUF15 kernel: pcpu-alloc: \[0\] 16 17 18 19
окт 05 14:19:02 asusTUF15 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=2b46e692-5b16-4ea1-8147-89c990b86bc2 rw quiet splash mem_sleep_default=deep apparmor=1 security=apparmor udev.>
окт 05 14:19:02 asusTUF15 kernel: Booted with the nomodeset parameter. Only the system framebuffer will be available
окт 05 14:19:02 asusTUF15 kernel: Unknown kernel command line parameters “splash BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64”, will be passed to user space.
окт 05 14:19:02 asusTUF15 kernel: printk: log_buf_len individual max cpu contribution: 4096 bytes
окт 05 14:19:02 asusTUF15 kernel: printk: log_buf_len total cpu_extra contributions: 77824 bytes
окт 05 14:19:02 asusTUF15 kernel: printk: log_buf_len min size: 131072 bytes
окт 05 14:19:02 asusTUF15 kernel: printk: log_buf_len: 262144 bytes
окт 05 14:19:02 asusTUF15 kernel: printk: early log buf free: 113384(86%)
окт 05 14:19:02 asusTUF15 kernel: Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: Fallback order for Node 0: 0
окт 05 14:19:02 asusTUF15 kernel: Built 1 zonelists, mobility grouping on. Total pages: 16680182
окт 05 14:19:02 asusTUF15 kernel: Policy zone: Normal
окт 05 14:19:02 asusTUF15 kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
окт 05 14:19:02 asusTUF15 kernel: software IO TLB: area num 32.
окт 05 14:19:02 asusTUF15 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=20, Nodes=1
окт 05 14:19:02 asusTUF15 kernel: ftrace: allocating 51450 entries in 201 pages
окт 05 14:19:02 asusTUF15 kernel: ftrace: allocated 201 pages with 4 groups
окт 05 14:19:02 asusTUF15 kernel: Dynamic Preempt: full
окт 05 14:19:02 asusTUF15 kernel: rcu: Preemptible hierarchical RCU implementation.
окт 05 14:19:02 asusTUF15 kernel: rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=20.
окт 05 14:19:02 asusTUF15 kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
окт 05 14:19:02 asusTUF15 kernel: Trampoline variant of Tasks RCU enabled.
окт 05 14:19:02 asusTUF15 kernel: Rude variant of Tasks RCU enabled.
окт 05 14:19:02 asusTUF15 kernel: Tracing variant of Tasks RCU enabled.
окт 05 14:19:02 asusTUF15 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
окт 05 14:19:02 asusTUF15 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=20
окт 05 14:19:02 asusTUF15 kernel: RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=20.
окт 05 14:19:02 asusTUF15 kernel: RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=20.
окт 05 14:19:02 asusTUF15 kernel: RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=20.
окт 05 14:19:02 asusTUF15 kernel: NR_IRQS: 524544, nr_irqs: 2216, preallocated irqs: 16
окт 05 14:19:02 asusTUF15 kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
окт 05 14:19:02 asusTUF15 kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(**ptrval**)-0x(**ptrval**)
окт 05 14:19:02 asusTUF15 kernel: Console: colour dummy device 80x25
окт 05 14:19:02 asusTUF15 kernel: printk: legacy console \[tty0\] enabled
окт 05 14:19:02 asusTUF15 kernel: ACPI: Core revision 20240827
окт 05 14:19:02 asusTUF15 kernel: hpet: HPET dysfunctional in PC10. Force disabled.
окт 05 14:19:02 asusTUF15 kernel: APIC: Switch to symmetric I/O mode setup
окт 05 14:19:02 asusTUF15 kernel: DMAR: Host address width 39
окт 05 14:19:02 asusTUF15 kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
окт 05 14:19:02 asusTUF15 kernel: DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
окт 05 14:19:02 asusTUF15 kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
окт 05 14:19:02 asusTUF15 kernel: DMAR: dmar1: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
окт 05 14:19:02 asusTUF15 kernel: DMAR: RMRR base: 0x0000004b000000 end: 0x0000004f7fffff
окт 05 14:19:02 asusTUF15 kernel: DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
окт 05 14:19:02 asusTUF15 kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
окт 05 14:19:02 asusTUF15 kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
окт 05 14:19:02 asusTUF15 kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
окт 05 14:19:02 asusTUF15 kernel: x2apic enabled
окт 05 14:19:02 asusTUF15 kernel: APIC: Switched APIC routing to: cluster x2apic
окт 05 14:19:02 asusTUF15 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26bef67878b, max_idle_ns: 440795293631 ns
окт 05 14:19:02 asusTUF15 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5378.00 BogoMIPS (lpj=8960000)
окт 05 14:19:02 asusTUF15 kernel: CPU0: Thermal monitoring enabled (TM1)
окт 05 14:19:02 asusTUF15 kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
окт 05 14:19:02 asusTUF15 kernel: CET detected: Indirect Branch Tracking enabled
окт 05 14:19:02 asusTUF15 kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
окт 05 14:19:02 asusTUF15 kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
окт 05 14:19:02 asusTUF15 kernel: process: using mwait in idle threads
окт 05 14:19:02 asusTUF15 kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and *user pointer sanitization
окт 05 14:19:02 asusTUF15 kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
окт 05 14:19:02 asusTUF15 kernel: Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
окт 05 14:19:02 asusTUF15 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
окт 05 14:19:02 asusTUF15 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
окт 05 14:19:02 asusTUF15 kernel: Register File Data Sampling: Mitigation: Clear Register File
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: Supporting XSAVE feature 0x800: ‘Control-flow User registers’
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: xstate_offset\[2\]: 576, xstate_sizes\[2\]: 256
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: xstate_offset\[9\]: 832, xstate_sizes\[9\]: 8
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: xstate_offset\[11\]: 840, xstate_sizes\[11\]: 16
окт 05 14:19:02 asusTUF15 kernel: x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using ‘compacted’ format.
окт 05 14:19:02 asusTUF15 kernel: Freeing SMP alternatives memory: 44K
окт 05 14:19:02 asusTUF15 kernel: pid_max: default: 32768 minimum: 301
окт 05 14:19:02 asusTUF15 kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
окт 05 14:19:02 asusTUF15 kernel: landlock: Up and running.
окт 05 14:19:02 asusTUF15 kernel: Yama: becoming mindful.
окт 05 14:19:02 asusTUF15 kernel: LSM support for eBPF active
окт 05 14:19:02 asusTUF15 kernel: AppArmor: AppArmor initialized
окт 05 14:19:02 asusTUF15 kernel: Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: smpboot: CPU0: 12th Gen Intel(R) Core™ i7-12700H (family: 0x6, model: 0x9a, stepping: 0x3)
окт 05 14:19:02 asusTUF15 kernel: Performance Events: XSAVE Architectural LBR, PEBS fmt4±baseline, AnyThread deprecated, Alderlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
окт 05 14:19:02 asusTUF15 kernel: core: cpu_core PMU driver:
окт 05 14:19:02 asusTUF15 kernel: … version: 5
окт 05 14:19:02 asusTUF15 kernel: … bit width: 48
окт 05 14:19:02 asusTUF15 kernel: … generic registers: 8
окт 05 14:19:02 asusTUF15 kernel: … value mask: 0000ffffffffffff
окт 05 14:19:02 asusTUF15 kernel: … max period: 00007fffffffffff
окт 05 14:19:02 asusTUF15 kernel: … fixed-purpose events: 4
окт 05 14:19:02 asusTUF15 kernel: … event mask: 0001000f000000ff
окт 05 14:19:02 asusTUF15 kernel: signal: max sigframe size: 3632
окт 05 14:19:02 asusTUF15 kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1668
окт 05 14:19:02 asusTUF15 kernel: rcu: Hierarchical SRCU implementation.
окт 05 14:19:02 asusTUF15 kernel: rcu: Max phase no-delay instances is 1000.
окт 05 14:19:02 asusTUF15 kernel: Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
окт 05 14:19:02 asusTUF15 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
окт 05 14:19:02 asusTUF15 kernel: smp: Bringing up secondary CPUs …
окт 05 14:19:02 asusTUF15 kernel: smpboot: x86: Booting SMP configuration:
окт 05 14:19:02 asusTUF15 kernel: … node* #0\*, CPUs:\* #2 #4 #6 #8 #10 #12 #13 #14 #15 #16 #17 #18 #19\*
окт 05 14:19:02 asusTUF15 kernel: core: cpu_atom PMU driver:
окт 05 14:19:02 asusTUF15 kernel: … generic registers: 6
окт 05 14:19:02 asusTUF15 kernel: … fixed-purpose events: 3
окт 05 14:19:02 asusTUF15 kernel: … event mask: 000000070000003f
окт 05 14:19:02 asusTUF15 kernel:\* #1 #3 #5 #7 #9 #11\*
окт 05 14:19:02 asusTUF15 kernel: smp: Brought up 1 node, 20 CPUs
окт 05 14:19:02 asusTUF15 kernel: smpboot: Total of 20 processors activated (107563.00 BogoMIPS)
окт 05 14:19:02 asusTUF15 kernel: Memory: 65340104K/66720728K available (18432K kernel code, 2670K rwdata, 14348K rodata, 4284K init, 4276K bss, 1348104K reserved, 0K cma-reserved)
окт 05 14:19:02 asusTUF15 kernel: devtmpfs: initialized
окт 05 14:19:02 asusTUF15 kernel: x86/mm: Memory block size: 2048MB
окт 05 14:19:02 asusTUF15 kernel: ACPI: PM: Registering ACPI NVS region \[mem 0x40c5b000-0x40dc8fff\] (1499136 bytes)
окт 05 14:19:02 asusTUF15 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
окт 05 14:19:02 asusTUF15 kernel: futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: pinctrl core: initialized pinctrl subsystem
окт 05 14:19:02 asusTUF15 kernel: PM: RTC time: 11:18:55, date: 2025-10-05
окт 05 14:19:02 asusTUF15 kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
окт 05 14:19:02 asusTUF15 kernel: DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
окт 05 14:19:02 asusTUF15 kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
окт 05 14:19:02 asusTUF15 kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
окт 05 14:19:02 asusTUF15 kernel: audit: initializing netlink subsys (disabled)
окт 05 14:19:02 asusTUF15 kernel: audit: type=2000 audit(1759663135.023:1): state=initialized audit_enabled=0 res=1
окт 05 14:19:02 asusTUF15 kernel: thermal_sys: Registered thermal governor ‘fair_share’
окт 05 14:19:02 asusTUF15 kernel: thermal_sys: Registered thermal governor ‘bang_bang’
окт 05 14:19:02 asusTUF15 kernel: thermal_sys: Registered thermal governor ‘step_wise’
окт 05 14:19:02 asusTUF15 kernel: thermal_sys: Registered thermal governor ‘user_space’
окт 05 14:19:02 asusTUF15 kernel: thermal_sys: Registered thermal governor ‘power_allocator’
окт 05 14:19:02 asusTUF15 kernel: cpuidle: using governor ladder
окт 05 14:19:02 asusTUF15 kernel: cpuidle: using governor menu
окт 05 14:19:02 asusTUF15 kernel: ACPI FADT declares the system doesn’t support PCIe ASPM, so disable it
окт 05 14:19:02 asusTUF15 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
окт 05 14:19:02 asusTUF15 kernel: PCI: ECAM \[mem 0xc0000000-0xce0fffff\] (base 0xc0000000) for domain 0000 \[bus 00-e0\]
окт 05 14:19:02 asusTUF15 kernel: PCI: Using configuration type 1 for base access
окт 05 14:19:02 asusTUF15 kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
окт 05 14:19:02 asusTUF15 kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
окт 05 14:19:02 asusTUF15 kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
окт 05 14:19:02 asusTUF15 kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
окт 05 14:19:02 asusTUF15 kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
окт 05 14:19:02 asusTUF15 kernel: ACPI: Added OSI(Module Device)
окт 05 14:19:02 asusTUF15 kernel: ACPI: Added OSI(Processor Device)
окт 05 14:19:02 asusTUF15 kernel: ACPI: Added OSI(Processor Aggregator Device)
окт 05 14:19:02 asusTUF15 kernel: ACPI: 17 ACPI AML tables successfully acquired and loaded
окт 05 14:19:02 asusTUF15 kernel: ACPI: USB4 OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
окт 05 14:19:02 asusTUF15 kernel: ACPI: USB4 OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
окт 05 14:19:02 asusTUF15 kernel: ACPI: Dynamic OEM Table Load:
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C1DCE800 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C1DDF800 000626 (v02 PmRef Cpu0Ist 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C2C3E000 0001AB (v02 PmRef Cpu0Psd 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C1DD8800 0004BA (v02 PmRef Cpu0Hwp 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C1DC4000 001BAF (v02 PmRef ApIst 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C2D3A000 001038 (v02 PmRef ApHwp 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C2D3E000 001349 (v02 PmRef ApPsd 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: SSDT 0xFFFF8E23C1DD7000 000FBB (v02 PmRef ApCst 00003000 INTL 20200717)
окт 05 14:19:02 asusTUF15 kernel: ACPI: EC: EC started
окт 05 14:19:02 asusTUF15 kernel: ACPI: EC: interrupt blocked
окт 05 14:19:02 asusTUF15 kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\*.PC00.LPCB.EC0: Boot DSDT EC used to handle transactions
окт 05 14:19:02 asusTUF15 kernel: ACPI: Interpreter enabled
окт 05 14:19:02 asusTUF15 kernel: ACPI: PM: (supports S0 S3 S4 S5)
окт 05 14:19:02 asusTUF15 kernel: ACPI: Using IOAPIC for interrupt routing
окт 05 14:19:02 asusTUF15 kernel: PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
окт 05 14:19:02 asusTUF15 kernel: PCI: Using E820 reservations for host bridge windows
окт 05 14:19:02 asusTUF15 kernel: ACPI: Enabled 10 GPEs in block 00 to 7F
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB.PC00.PEG1.PXP: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB.PC00.RP08.PXP: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB.DBTP: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.XHCI.RHUB.HS10.BTRT: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.PAUD: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.I2C0.PXTC: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.CNVW.WRST: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.VMD0.VOL0.V0PR: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.VMD0.VOL1.V1PR: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.VMD0.VOL2.V2PR: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.VMD0.VOL3.V3PR: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.TBT0: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.TBT1: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB\_.PC00.D3C\_: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: \\PIN\_: New power resource
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI Root Bridge \[PC00\] (domain 0000 \[bus 00-e0\])
окт 05 14:19:02 asusTUF15 kernel: acpi PNP0A08:00: *OSC: OS supports \[ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3\]
окт 05 14:19:02 asusTUF15 kernel: acpi PNP0A08:00: OSC: platform does not support \[AER\]
окт 05 14:19:02 asusTUF15 kernel: acpi PNP0A08:00: OSC: OS now controls \[PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC\]
окт 05 14:19:02 asusTUF15 kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
окт 05 14:19:02 asusTUF15 kernel: PCI host bridge to bus 0000:00
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: root bus resource \[io 0x0000-0x0cf7 window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: root bus resource \[io 0x0d00-0xffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: root bus resource \[mem 0x000a0000-0x000bffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: root bus resource \[mem 0x000e0000-0x000fffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: root bus resource \[mem 0x4f800000-0xbfffffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: root bus resource \[mem 0x4000000000-0x7fffffffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: root bus resource \[bus 00-e0\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:00.0: \[8086:4641\] type 00 class 0x060000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: \[8086:460d\] type 01 class 0x060400 PCIe Root Port
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: PCI bridge to \[bus 01\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: bridge window \[io 0x3000-0x3fff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: bridge window \[mem 0x5f000000-0x600fffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: bridge window \[mem 0x6000000000-0x6201ffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: PTM enabled (root), 4ns granularity
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: \[8086:46a6\] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: BAR 0 \[mem 0x622e000000-0x622effffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: BAR 2 \[mem 0x4000000000-0x400fffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: BAR 4 \[io 0x4000-0x403f\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: Video device with shadowed ROM at \[mem 0x000c0000-0x000dffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: VF BAR 0 \[mem 0x00000000-0x00ffffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: VF BAR 0 \[mem 0x00000000-0x06ffffff 64bit\]: contains BAR 0 for 7 VFs
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: VF BAR 2 \[mem 0x00000000-0x1fffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: VF BAR 2 \[mem 0x00000000-0xdfffffff 64bit pref\]: contains BAR 2 for 7 VFs
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:04.0: \[8086:461d\] type 00 class 0x118000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:04.0: BAR 0 \[mem 0x622f240000-0x622f25ffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:06.0: \[8086:09ab\] type 00 class 0x088000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: \[8086:466e\] type 01 class 0x060400 PCIe Root Port
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: PCI bridge to \[bus 02-2b\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: bridge window \[mem 0x52000000-0x5e1fffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: bridge window \[mem 0x6210000000-0x622bffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: Overriding RP PIO Log Size to 4
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: PTM enabled (root), 4ns granularity
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:08.0: \[8086:464f\] type 00 class 0x088000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:08.0: BAR 0 \[mem 0x622f29a000-0x622f29afff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0a.0: \[8086:467d\] type 00 class 0x118000 PCIe Root Complex Integrated Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0a.0: BAR 0 \[mem 0x622f280000-0x622f287fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0a.0: enabling Extended Tags
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.0: \[8086:461e\] type 00 class 0x0c0330 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.0: BAR 0 \[mem 0x622f270000-0x622f27ffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.0: PME# supported from D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.2: \[8086:463e\] type 00 class 0x0c0340 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.2: BAR 0 \[mem 0x622f200000-0x622f23ffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.2: BAR 2 \[mem 0x622f299000-0x622f299fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.2: supports D1 D2
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0e.0: \[8086:467f\] type 00 class 0x010400 PCIe Root Complex Integrated Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0e.0: BAR 0 \[mem 0x622c000000-0x622dffffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0e.0: BAR 2 \[mem 0x50000000-0x51ffffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0e.0: BAR 4 \[mem 0x622f100000-0x622f1fffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.0: \[8086:51ed\] type 00 class 0x0c0330 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.0: BAR 0 \[mem 0x622f260000-0x622f26ffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.2: \[8086:51ef\] type 00 class 0x050000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.2: BAR 0 \[mem 0x622f290000-0x622f293fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.2: BAR 2 \[mem 0x622f298000-0x622f298fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.3: \[8086:51f0\] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.3: BAR 0 \[mem 0x622f28c000-0x622f28ffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.0: \[8086:51e8\] type 00 class 0x0c8000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.0: BAR 0 \[mem 0x00000000-0x00000fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.2: \[8086:51ea\] type 00 class 0x0c8000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.2: BAR 0 \[mem 0x00000000-0x00000fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:16.0: \[8086:51e0\] type 00 class 0x078000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:16.0: BAR 0 \[mem 0x622f295000-0x622f295fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:16.0: PME# supported from D3hot
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.0: \[8086:5182\] type 00 class 0x060100 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.3: \[8086:51c8\] type 00 class 0x040300 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.3: BAR 0 \[mem 0x622f288000-0x622f28bfff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.3: BAR 4 \[mem 0x622f000000-0x622f0fffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.4: \[8086:51a3\] type 00 class 0x0c0500 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.4: BAR 0 \[mem 0x622f294000-0x622f2940ff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.4: BAR 4 \[io 0xefa0-0xefbf\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.5: \[8086:51a4\] type 00 class 0x0c8000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.5: BAR 0 \[mem 0xfe010000-0xfe010fff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.6: \[8086:1a1e\] type 00 class 0x020000 conventional PCI endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.6: BAR 0 \[mem 0x60100000-0x6011ffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: acpiphp: Slot \[1\] registered
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: \[10de:2520\] type 00 class 0x030000 PCIe Legacy Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: BAR 0 \[mem 0x5f000000-0x5fffffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: BAR 1 \[mem 0x6000000000-0x61ffffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: BAR 3 \[mem 0x6200000000-0x6201ffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: BAR 5 \[io 0x3000-0x307f\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: ROM \[mem 0x60000000-0x6007ffff pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: PME# supported from D0 D3hot
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.1: \[10de:228e\] type 00 class 0x040300 PCIe Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.1: BAR 0 \[mem 0x60080000-0x60083fff\]
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 1
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
окт 05 14:19:02 asusTUF15 kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
окт 05 14:19:02 asusTUF15 kernel: ACPI: EC: interrupt unblocked
окт 05 14:19:02 asusTUF15 kernel: ACPI: EC: event unblocked
окт 05 14:19:02 asusTUF15 kernel: ACPI: EC: GPE=0x6e
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB*.PC00.LPCB.EC0: Boot DSDT EC initialization complete
окт 05 14:19:02 asusTUF15 kernel: ACPI: \_SB.PC00.LPCB.EC0\_: EC: Used to handle transactions and events
окт 05 14:19:02 asusTUF15 kernel: iommu: Default domain type: Translated
окт 05 14:19:02 asusTUF15 kernel: iommu: DMA domain TLB invalidation policy: lazy mode
окт 05 14:19:02 asusTUF15 kernel: SCSI subsystem initialized
окт 05 14:19:02 asusTUF15 kernel: libata version 3.00 loaded.
окт 05 14:19:02 asusTUF15 kernel: ACPI: bus type USB registered
окт 05 14:19:02 asusTUF15 kernel: usbcore: registered new interface driver usbfs
окт 05 14:19:02 asusTUF15 kernel: usbcore: registered new interface driver hub
окт 05 14:19:02 asusTUF15 kernel: usbcore: registered new device driver usb
окт 05 14:19:02 asusTUF15 kernel: EDAC MC: Ver: 3.0.0
окт 05 14:19:02 asusTUF15 kernel: efivars: Registered efivars operations
окт 05 14:19:02 asusTUF15 kernel: NetLabel: Initializing
окт 05 14:19:02 asusTUF15 kernel: NetLabel: domain hash size = 128
окт 05 14:19:02 asusTUF15 kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
окт 05 14:19:02 asusTUF15 kernel: NetLabel: unlabeled traffic allowed by default
окт 05 14:19:02 asusTUF15 kernel: mctp: management component transport protocol core
окт 05 14:19:02 asusTUF15 kernel: NET: Registered PF_MCTP protocol family
окт 05 14:19:02 asusTUF15 kernel: PCI: Using ACPI for IRQ routing
окт 05 14:19:02 asusTUF15 kernel: PCI: pci_cache_line_size set to 64 bytes
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.5: BAR 0 \[mem 0xfe010000-0xfe010fff\]: can’t claim; no compatible bridge window
окт 05 14:19:02 asusTUF15 kernel: e820: reserve RAM buffer \[mem 0x0009e000-0x0009ffff\]
окт 05 14:19:02 asusTUF15 kernel: e820: reserve RAM buffer \[mem 0x305a9018-0x33ffffff\]
окт 05 14:19:02 asusTUF15 kernel: e820: reserve RAM buffer \[mem 0x335da000-0x33ffffff\]
окт 05 14:19:02 asusTUF15 kernel: e820: reserve RAM buffer \[mem 0x3367e000-0x33ffffff\]
окт 05 14:19:02 asusTUF15 kernel: e820: reserve RAM buffer \[mem 0x37d57000-0x37ffffff\]
окт 05 14:19:02 asusTUF15 kernel: e820: reserve RAM buffer \[mem 0x41800000-0x43ffffff\]
окт 05 14:19:02 asusTUF15 kernel: e820: reserve RAM buffer \[mem 0x10b0800000-0x10b3ffffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: vgaarb: bridge control possible
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: vgaarb: bridge control possible
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
окт 05 14:19:02 asusTUF15 kernel: vgaarb: loaded
окт 05 14:19:02 asusTUF15 kernel: clocksource: Switched to clocksource tsc-early
окт 05 14:19:02 asusTUF15 kernel: VFS: Disk quotas dquot_6.6.0
окт 05 14:19:02 asusTUF15 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
окт 05 14:19:02 asusTUF15 kernel: AppArmor: AppArmor Filesystem Enabled
окт 05 14:19:02 asusTUF15 kernel: pnp: PnP ACPI init
окт 05 14:19:02 asusTUF15 kernel: system 00:00: \[io 0x0680-0x069f\] has been reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:00: \[io 0x164e-0x164f\] has been reserved
окт 05 14:19:02 asusTUF15 kernel: pnp 00:03: disabling \[mem 0xc0000000-0xcfffffff\] because it overlaps 0000:00:02.0 BAR 9 \[mem 0x00000000-0xdfffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: system 00:03: \[mem 0xfedc0000-0xfedc7fff\] has been reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:03: \[mem 0xfeda0000-0xfeda0fff\] has been reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:03: \[mem 0xfeda1000-0xfeda1fff\] has been reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:03: \[mem 0xfed20000-0xfed7ffff\] could not be reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:03: \[mem 0xfed90000-0xfed93fff\] could not be reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:03: \[mem 0xfed45000-0xfed8ffff\] could not be reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:03: \[mem 0xfee00000-0xfeefffff\] could not be reserved
окт 05 14:19:02 asusTUF15 kernel: system 00:04: \[io 0x2000-0x20fe\] has been reserved
окт 05 14:19:02 asusTUF15 kernel: pnp: PnP ACPI: found 6 devices
окт 05 14:19:02 asusTUF15 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
окт 05 14:19:02 asusTUF15 kernel: NET: Registered PF_INET protocol family
окт 05 14:19:02 asusTUF15 kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: TCP: Hash tables configured (established 524288 bind 65536)
окт 05 14:19:02 asusTUF15 kernel: MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
окт 05 14:19:02 asusTUF15 kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
окт 05 14:19:02 asusTUF15 kernel: NET: Registered PF_XDP protocol family
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: bridge window \[io 0x1000-0x0fff\] to \[bus 02-2b\] add_size 1000
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: VF BAR 2 \[mem 0x4020000000-0x40ffffffff 64bit pref\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: VF BAR 0 \[mem 0x4010000000-0x4016ffffff 64bit\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: bridge window \[io 0x5000-0x5fff\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.0: BAR 0 \[mem 0x4017000000-0x4017000fff 64bit\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.2: BAR 0 \[mem 0x4017001000-0x4017001fff 64bit\]: assigned
окт 05 14:19:02 asusTUF15 kernel: resource: avoiding allocation from e820 entry \[mem 0x000a0000-0x000fffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.5: BAR 0 \[mem 0x4f800000-0x4f800fff\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: resource 4 \[io 0x0000-0x0cf7 window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: resource 5 \[io 0x0d00-0xffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: resource 6 \[mem 0x000a0000-0x000bffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: resource 7 \[mem 0x000e0000-0x000fffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: resource 8 \[mem 0x4f800000-0xbfffffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:00: resource 9 \[mem 0x4000000000-0x7fffffffff window\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:01: resource 0 \[io 0x3000-0x3fff\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:01: resource 1 \[mem 0x5f000000-0x600fffff\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:01: resource 2 \[mem 0x6000000000-0x6201ffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:02: resource 0 \[io 0x5000-0x5fff\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:02: resource 1 \[mem 0x52000000-0x5e1fffff\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 0000:02: resource 2 \[mem 0x6210000000-0x622bffffff 64bit pref\]
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
окт 05 14:19:02 asusTUF15 kernel: PCI: CLS 64 bytes, default 64
окт 05 14:19:02 asusTUF15 kernel: DMAR: Intel-IOMMU force enabled due to platform opt in
окт 05 14:19:02 asusTUF15 kernel: DMAR: No ATSR found
окт 05 14:19:02 asusTUF15 kernel: DMAR: No SATC found
окт 05 14:19:02 asusTUF15 kernel: DMAR: IOMMU feature fl1gp_support inconsistent
окт 05 14:19:02 asusTUF15 kernel: DMAR: IOMMU feature pgsel_inv inconsistent
окт 05 14:19:02 asusTUF15 kernel: DMAR: IOMMU feature nwfs inconsistent
окт 05 14:19:02 asusTUF15 kernel: DMAR: IOMMU feature dit inconsistent
окт 05 14:19:02 asusTUF15 kernel: DMAR: IOMMU feature sc_support inconsistent
окт 05 14:19:02 asusTUF15 kernel: DMAR: IOMMU feature dev_iotlb_support inconsistent
окт 05 14:19:02 asusTUF15 kernel: DMAR: dmar0: Using Queued invalidation
окт 05 14:19:02 asusTUF15 kernel: DMAR: dmar1: Using Queued invalidation
окт 05 14:19:02 asusTUF15 kernel: Trying to unpack rootfs image as initramfs…
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:02.0: Adding to iommu group 0
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:00.0: Adding to iommu group 1
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:01.0: Adding to iommu group 2
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:04.0: Adding to iommu group 3
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:06.0: Adding to iommu group 4
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:07.0: Adding to iommu group 5
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:08.0: Adding to iommu group 6
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0a.0: Adding to iommu group 7
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.0: Adding to iommu group 8
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0d.2: Adding to iommu group 8
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:0e.0: Adding to iommu group 9
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.0: Adding to iommu group 10
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.2: Adding to iommu group 10
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:14.3: Adding to iommu group 11
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.0: Adding to iommu group 12
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:15.2: Adding to iommu group 12
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:16.0: Adding to iommu group 13
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.0: Adding to iommu group 14
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.3: Adding to iommu group 14
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.4: Adding to iommu group 14
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.5: Adding to iommu group 14
окт 05 14:19:02 asusTUF15 kernel: pci 0000:00:1f.6: Adding to iommu group 14
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.0: Adding to iommu group 15
окт 05 14:19:02 asusTUF15 kernel: pci 0000:01:00.1: Adding to iommu group 15
окт 05 14:19:02 asusTUF15 kernel: DMAR: Intel(R) Virtualization Technology for Directed I/O
окт 05 14:19:02 asusTUF15 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
окт 05 14:19:02 asusTUF15 kernel: software IO TLB: mapped \[mem 0x00000000228d4000-0x00000000268d4000\] (64MB)
окт 05 14:19:02 asusTUF15 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26bef67878b, max_idle_ns: 440795293631 ns
окт 05 14:19:02 asusTUF15 kernel: Initialise system trusted keyrings
окт 05 14:19:02 asusTUF15 kernel: Key type blacklist registered
окт 05 14:19:02 asusTUF15 kernel: workingset: timestamp_bits=36 max_order=24 bucket_order=0
окт 05 14:19:02 asusTUF15 kernel: fuse: init (API version 7.41)
окт 05 14:19:02 asusTUF15 kernel: integrity: Platform Keyring initialized
окт 05 14:19:02 asusTUF15 kernel: integrity: Machine keyring initialized
окт 05 14:19:02 asusTUF15 kernel: Key type asymmetric registered
окт 05 14:19:02 asusTUF15 kernel: Asymmetric key parser ‘x509’ registered
окт 05 14:19:02 asusTUF15 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
окт 05 14:19:02 asusTUF15 kernel: io scheduler mq-deadline registered
окт 05 14:19:02 asusTUF15 kernel: io scheduler kyber registered
окт 05 14:19:02 asusTUF15 kernel: io scheduler bfq registered
окт 05 14:19:02 asusTUF15 kernel: ledtrig-cpu: registered to indicate activity on CPUs
окт 05 14:19:02 asusTUF15 kernel: pcieport 0000:00:01.0: PME: Signaling with IRQ 122
окт 05 14:19:02 asusTUF15 kernel: pcieport 0000:00:07.0: PME: Signaling with IRQ 123
окт 05 14:19:02 asusTUF15 kernel: pcieport 0000:00:07.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
окт 05 14:19:02 asusTUF15 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
окт 05 14:19:02 asusTUF15 kernel: ACPI: AC: AC Adapter \[ACAD\] (on-line)
окт 05 14:19:02 asusTUF15 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
окт 05 14:19:02 asusTUF15 kernel: ACPI: button: Sleep Button \[SLPB\]
окт 05 14:19:02 asusTUF15 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
окт 05 14:19:02 asusTUF15 kernel: ACPI: button: Power Button \[PWRB\]
окт 05 14:19:02 asusTUF15 kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
окт 05 14:19:02 asusTUF15 kernel: ACPI: button: Lid Switch \[LID0\]
окт 05 14:19:02 asusTUF15 kernel: thermal LNXTHERM:00: registered as thermal_zone0
окт 05 14:19:02 asusTUF15 kernel: ACPI: thermal: Thermal Zone \[THRM\] (71 C)
окт 05 14:19:02 asusTUF15 kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
окт 05 14:19:02 asusTUF15 kernel: ACPI: battery: Slot \[BAT1\] (battery present)
окт 05 14:19:02 asusTUF15 kernel: hpet_acpi_add: no address or irqs in \_CRS
окт 05 14:19:02 asusTUF15 kernel: Non-volatile memory driver v1.3
окт 05 14:19:02 asusTUF15 kernel: Linux agpgart interface v0.103
окт 05 14:19:02 asusTUF15 kernel: ACPI: bus type drm_connector registered
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:0d.0: xHCI Host Controller
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
окт 05 14:19:02 asusTUF15 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
окт 05 14:19:02 asusTUF15 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
окт 05 14:19:02 asusTUF15 kernel: usb usb1: Product: xHCI Host Controller
окт 05 14:19:02 asusTUF15 kernel: usb usb1: Manufacturer: Linux 6.12.44-2-MANJARO xhci-hcd
окт 05 14:19:02 asusTUF15 kernel: usb usb1: SerialNumber: 0000:00:0d.0
окт 05 14:19:02 asusTUF15 kernel: hub 1-0:1.0: USB hub found
окт 05 14:19:02 asusTUF15 kernel: hub 1-0:1.0: 1 port detected
окт 05 14:19:02 asusTUF15 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
окт 05 14:19:02 asusTUF15 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
окт 05 14:19:02 asusTUF15 kernel: usb usb2: Product: xHCI Host Controller
окт 05 14:19:02 asusTUF15 kernel: usb usb2: Manufacturer: Linux 6.12.44-2-MANJARO xhci-hcd
окт 05 14:19:02 asusTUF15 kernel: usb usb2: SerialNumber: 0000:00:0d.0
окт 05 14:19:02 asusTUF15 kernel: hub 2-0:1.0: USB hub found
окт 05 14:19:02 asusTUF15 kernel: hub 2-0:1.0: 1 port detected
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000100200009810
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
окт 05 14:19:02 asusTUF15 kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
окт 05 14:19:02 asusTUF15 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
окт 05 14:19:02 asusTUF15 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
окт 05 14:19:02 asusTUF15 kernel: usb usb3: Product: xHCI Host Controller
окт 05 14:19:02 asusTUF15 kernel: usb usb3: Manufacturer: Linux 6.12.44-2-MANJARO xhci-hcd
окт 05 14:19:02 asusTUF15 kernel: usb usb3: SerialNumber: 0000:00:14.0
окт 05 14:19:02 asusTUF15 kernel: hub 3-0:1.0: USB hub found
окт 05 14:19:02 asusTUF15 kernel: hub 3-0:1.0: 12 ports detected
окт 05 14:19:02 asusTUF15 kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
окт 05 14:19:02 asusTUF15 kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
окт 05 14:19:02 asusTUF15 kernel: usb usb4: Product: xHCI Host Controller
окт 05 14:19:02 asusTUF15 kernel: usb usb4: Manufacturer: Linux 6.12.44-2-MANJARO xhci-hcd
окт 05 14:19:02 asusTUF15 kernel: usb usb4: SerialNumber: 0000:00:14.0
окт 05 14:19:02 asusTUF15 kernel: hub 4-0:1.0: USB hub found
окт 05 14:19:02 asusTUF15 kernel: hub 4-0:1.0: 4 ports detected
окт 05 14:19:02 asusTUF15 kernel: usbcore: registered new interface driver usbserial_generic
окт 05 14:19:02 asusTUF15 kernel: usbserial: USB Serial support registered for generic
окт 05 14:19:02 asusTUF15 kernel: rtc_cmos 00:01: RTC can wake from S4
окт 05 14:19:02 asusTUF15 kernel: rtc_cmos 00:01: registered as rtc0
окт 05 14:19:02 asusTUF15 kernel: rtc_cmos 00:01: setting system clock to 2025-10-05T11:18:56 UTC (1759663136)
окт 05 14:19:02 asusTUF15 kernel: rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
окт 05 14:19:02 asusTUF15 kernel: intel_pstate: Intel P-state driver initializing
окт 05 14:19:02 asusTUF15 kernel: Freeing initrd memory: 75480K
окт 05 14:19:02 asusTUF15 kernel: intel_pstate: HWP enabled
окт 05 14:19:02 asusTUF15 kernel: efifb: probing for efifb
окт 05 14:19:02 asusTUF15 kernel: efifb: showing boot graphics
окт 05 14:19:02 asusTUF15 kernel: efifb: framebuffer at 0x4000000000, using 8100k, total 8100k
окт 05 14:19:02 asusTUF15 kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
окт 05 14:19:02 asusTUF15 kernel: efifb: scrolling: redraw
окт 05 14:19:02 asusTUF15 kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
окт 05 14:19:02 asusTUF15 kernel: fbcon: Deferring console take-over
окт 05 14:19:02 asusTUF15 kernel: fb0: EFI VGA frame buffer device
окт 05 14:19:02 asusTUF15 kernel: hid: raw HID events driver (C) Jiri Kosina
окт 05 14:19:02 asusTUF15 kernel: drop_monitor: Initializing network drop monitor service
окт 05 14:19:02 asusTUF15 kernel: NET: Registered PF_INET6 protocol family
окт 05 14:19:02 asusTUF15 kernel: Segment Routing with IPv6
окт 05 14:19:02 asusTUF15 kernel: RPL Segment Routing with IPv6
окт 05 14:19:02 asusTUF15 kernel: In-situ OAM (IOAM) with IPv6
окт 05 14:19:02 asusTUF15 kernel: NET: Registered PF_PACKET protocol family
окт 05 14:19:02 asusTUF15 kernel: ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
окт 05 14:19:02 asusTUF15 kernel: microcode: Current revision: 0x00000437
окт 05 14:19:02 asusTUF15 kernel: microcode: Updated early from: 0x0000041c
окт 05 14:19:02 asusTUF15 kernel: IPI shorthand broadcast: enabled
окт 05 14:19:02 asusTUF15 kernel: sched_clock: Marking stable (1147597908, 16001371)->(1212360606, -48761327)
окт 05 14:19:02 asusTUF15 kernel: registered taskstats version 1
окт 05 14:19:02 asusTUF15 kernel: Loading compiled-in X.509 certificates
окт 05 14:19:02 asusTUF15 kernel: Loaded X.509 cert ‘Build time autogenerated kernel key: a69a864d6865fa0071e89d0a1d1a478b2171d6bf’
окт 05 14:19:02 asusTUF15 kernel: Demotion targets for Node 0: null
окт 05 14:19:02 asusTUF15 kernel: Key type .fscrypt registered
окт 05 14:19:02 asusTUF15 kernel: Key type fscrypt-provisioning registered
окт 05 14:19:02 asusTUF15 kernel: AppArmor: AppArmor sha256 policy hashing enabled
окт 05 14:19:02 asusTUF15 kernel: integrity: Loading X.509 certificate: UEFI:db
окт 05 14:19:02 asusTUF15 kernel: integrity: Loaded X.509 cert ‘ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071’
окт 05 14:19:02 asusTUF15 kernel: integrity: Loaded X.509 cert ‘ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2’
окт 05 14:19:02 asusTUF15 kernel: integrity: Loaded X.509 cert ‘Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4’
окт 05 14:19:02 asusTUF15 kernel: integrity: Loaded X.509 cert ‘Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53’
окт 05 14:19:02 asusTUF15 kernel: integrity: Loaded X.509 cert ‘Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63’
окт 05 14:19:02 asusTUF15 kernel: PM: Magic number: 13:835:326
окт 05 14:19:02 asusTUF15 kernel: RAS: Correctable Errors collector initialized.
окт 05 14:19:02 asusTUF15 kernel: clk: Disabling unused clocks
окт 05 14:19:02 asusTUF15 kernel: PM: genpd: Disabling unused power domains
окт 05 14:19:02 asusTUF15 kernel: Freeing unused decrypted memory: 2028K
окт 05 14:19:02 asusTUF15 kernel: Freeing unused kernel image (initmem) memory: 4284K
окт 05 14:19:02 asusTUF15 kernel: Write protecting the kernel read-only data: 34816k
окт 05 14:19:02 asusTUF15 kernel: Freeing unused kernel image (rodata/data gap) memory: 2036K
окт 05 14:19:02 asusTUF15 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
окт 05 14:19:02 asusTUF15 kernel: rodata_test: all tests were successful
окт 05 14:19:02 asusTUF15 kernel: Run /init as init process
окт 05 14:19:02 asusTUF15 kernel: with arguments:
окт 05 14:19:02 asusTUF15 kernel: /init
окт 05 14:19:02 asusTUF15 kernel: splash
окт 05 14:19:02 asusTUF15 kernel: with environment:
окт 05 14:19:02 asusTUF15 kernel: HOME=/
окт 05 14:19:02 asusTUF15 kernel: TERM=linux
окт 05 14:19:02 asusTUF15 kernel: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
окт 05 14:19:02 asusTUF15 kernel: i8042: PNP: PS/2 Controller \[PNP0303:PS2K\] at 0x60,0x64 irq 1
окт 05 14:19:02 asusTUF15 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
окт 05 14:19:02 asusTUF15 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
окт 05 14:19:02 asusTUF15 kernel: vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
окт 05 14:19:02 asusTUF15 kernel: pci_bus 10000:e0: root bus resource \[bus e0-ff\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 10000:e0: root bus resource \[mem 0x50000000-0x51ffffff\]
окт 05 14:19:02 asusTUF15 kernel: pci_bus 10000:e0: root bus resource \[mem 0x622f102000-0x622f1fffff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: \[8086:464d\] type 01 class 0x060400 PCIe Root Port
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: PCI bridge to \[bus e1\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: bridge window \[io 0x0000-0x0fff\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: bridge window \[mem 0x50000000-0x500fffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: PME# supported from D0 D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: PTM enabled (root), 4ns granularity
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: Adding to iommu group 9
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: \[8086:463d\] type 01 class 0x060400 PCIe Root Port
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: PCI bridge to \[bus e2\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: bridge window \[io 0x0000-0x0fff\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: bridge window \[mem 0x50100000-0x501fffff\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: PME# supported from D0 D3hot D3cold
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: PTM enabled (root), 4ns granularity
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: Adding to iommu group 9
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: Primary bus is hard wired to 0
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: \[8086:f1aa\] type 00 class 0x010802 PCIe Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: BAR 0 \[mem 0x50000000-0x50003fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: VF BAR 0 \[mem 0x00000000-0x00003fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: VF BAR 0 \[mem 0x00000000-0x0001ffff 64bit\]: contains BAR 0 for 8 VFs
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: Adding to iommu group 9
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: Primary bus is hard wired to 0
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e2:00.0: \[1987:5015\] type 00 class 0x010802 PCIe Endpoint
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e2:00.0: BAR 0 \[mem 0x50100000-0x50103fff 64bit\]
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e2:00.0: Adding to iommu group 9
окт 05 14:19:02 asusTUF15 kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
окт 05 14:19:02 asusTUF15 kernel: usb 3-2: new full-speed USB device number 2 using xhci_hcd
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: bridge window \[mem 0x50000000-0x500fffff\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: bridge window \[mem 0x50100000-0x501fffff\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: bridge window \[io size 0x1000\]: can’t assign; no space
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.0: bridge window \[io size 0x1000\]: failed to assign
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: bridge window \[io size 0x1000\]: can’t assign; no space
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e0:06.2: bridge window \[io size 0x1000\]: failed to assign
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: BAR 0 \[mem 0x50000000-0x50003fff 64bit\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: VF BAR 0 \[mem 0x50004000-0x50023fff 64bit\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e2:00.0: BAR 0 \[mem 0x50100000-0x50103fff 64bit\]: assigned
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: VMD: Default LTR value set by driver
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e1:00.0: can’t override BIOS ASPM; OS doesn’t have ASPM control
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e2:00.0: VMD: Default LTR value set by driver
окт 05 14:19:02 asusTUF15 kernel: pci 10000:e2:00.0: can’t override BIOS ASPM; OS doesn’t have ASPM control
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.0: can’t derive routing for PCI INT D
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.0: PCI INT D: no GSI
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.0: PME: Signaling with IRQ 159
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.2: can’t derive routing for PCI INT B
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.2: PCI INT B: no GSI
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.2: PME: Signaling with IRQ 160
окт 05 14:19:02 asusTUF15 kernel: vmd 0000:00:0e.0: Bound to PCI domain 10000
окт 05 14:19:02 asusTUF15 kernel: usb 3-2: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06
окт 05 14:19:02 asusTUF15 kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
окт 05 14:19:02 asusTUF15 kernel: usb 3-2: Product: USB Receiver
окт 05 14:19:02 asusTUF15 kernel: usb 3-2: Manufacturer: Logitech
окт 05 14:19:02 asusTUF15 kernel: nvme nvme1: pci function 10000:e1:00.0
окт 05 14:19:02 asusTUF15 kernel: nvme nvme0: pci function 10000:e2:00.0
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.0: can’t derive routing for PCI INT A
окт 05 14:19:02 asusTUF15 kernel: nvme 10000:e1:00.0: PCI INT A: not connected
окт 05 14:19:02 asusTUF15 kernel: pcieport 10000:e0:06.2: can’t derive routing for PCI INT A
окт 05 14:19:02 asusTUF15 kernel: nvme 10000:e2:00.0: PCI INT A: no GSI
окт 05 14:19:02 asusTUF15 kernel: nvme nvme1: 8/0/0 default/read/poll queues
окт 05 14:19:02 asusTUF15 kernel: nvme1n1: p1 p2 p3 p4 p5 p6
окт 05 14:19:02 asusTUF15 kernel: nvme nvme0: allocated 64 MiB host memory buffer.
окт 05 14:19:02 asusTUF15 kernel: usb 3-7: new high-speed USB device number 3 using xhci_hcd
окт 05 14:19:02 asusTUF15 kernel: nvme nvme0: 8/0/0 default/read/poll queues
окт 05 14:19:02 asusTUF15 kernel: nvme0n1: p1 p2 p4 p5 p6
окт 05 14:19:02 asusTUF15 kernel: usb 3-7: New USB device found, idVendor=322e, idProduct=202c, bcdDevice= 1.03
окт 05 14:19:02 asusTUF15 kernel: usb 3-7: New USB device strings: Mfr=2, Product=1, SerialNumber=0
окт 05 14:19:02 asusTUF15 kernel: usb 3-7: Product: USB2.0 HD UVC WebCam
окт 05 14:19:02 asusTUF15 kernel: usb 3-7: Manufacturer: Sonix Technology Co., Ltd.
окт 05 14:19:02 asusTUF15 kernel: usb 3-9: new full-speed USB device number 4 using xhci_hcd
окт 05 14:19:02 asusTUF15 kernel: usb 3-9: New USB device found, idVendor=0b05, idProduct=6203, bcdDevice= 1.06
окт 05 14:19:02 asusTUF15 kernel: usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
окт 05 14:19:02 asusTUF15 kernel: usb 3-9: Product: C-Media(R) Audio
окт 05 14:19:02 asusTUF15 kernel: usb 3-9: Manufacturer: ASUSTeK COMPUTER INC.
окт 05 14:19:02 asusTUF15 kernel: usb 3-10: new full-speed USB device number 5 using xhci_hcd
окт 05 14:19:02 asusTUF15 kernel: usb 3-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
окт 05 14:19:02 asusTUF15 kernel: usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
окт 05 14:19:02 asusTUF15 kernel: usbcore: registered new interface driver usbhid
окт 05 14:19:02 asusTUF15 kernel: usbhid: USB HID core driver
окт 05 14:19:02 asusTUF15 kernel: input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/0003:046D:C539.0001/input/input4
окт 05 14:19:02 asusTUF15 kernel: hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard \[Logitech USB Receiver\] on usb-0000:00:14.0-2/input0
окт 05 14:19:02 asusTUF15 kernel: input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:046D:C539.0002/input/input5
окт 05 14:19:02 asusTUF15 kernel: input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:046D:C539.0002/input/input6
окт 05 14:19:02 asusTUF15 kernel: input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:046D:C539.0002/input/input7
окт 05 14:19:02 asusTUF15 kernel: hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse \[Logitech USB Receiver\] on usb-0000:00:14.0-2/input1
окт 05 14:19:02 asusTUF15 kernel: hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device \[Logitech USB Receiver\] on usb-0000:00:14.0-2/input2
окт 05 14:19:02 asusTUF15 kernel: input: ASUSTeK COMPUTER INC. C-Media(R) Audio as /devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.3/0003:0B05:6203.0004/input/input9
окт 05 14:19:02 asusTUF15 kernel: hid-generic 0003:0B05:6203.0004: input,hidraw3: USB HID v1.11 Device \[ASUSTeK COMPUTER INC. C-Media(R) Audio\] on usb-0000:00:14.0-9/input3
окт 05 14:19:02 asusTUF15 kernel: logitech-djreceiver 0003:046D:C539.0001: hidraw0: USB HID v1.11 Keyboard \[Logitech USB Receiver\] on usb-0000:00:14.0-2/input0
окт 05 14:19:02 asusTUF15 kernel: logitech-djreceiver 0003:046D:C539.0002: hiddev96,hidraw1: USB HID v1.11 Mouse \[Logitech USB Receiver\] on usb-0000:00:14.0-2/input1
окт 05 14:19:02 asusTUF15 kernel: logitech-djreceiver 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device \[Logitech USB Receiver\] on usb-0000:00:14.0-2/input2
окт 05 14:19:02 asusTUF15 kernel: logitech-djreceiver 0003:046D:C539.0003: device of type eQUAD Lightspeed 1 (0x0c) connected on slot 1
окт 05 14:19:02 asusTUF15 kernel: input: Logitech Wireless Mouse PID:407f Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2/0003:046D:C539.0003/0003:046D:407F.0005/input/input10
окт 05 14:19:02 asusTUF15 kernel: input: Logitech Wireless Mouse PID:407f Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2/0003:046D:C539.0003/0003:046D:407F.0005/input/input11
окт 05 14:19:02 asusTUF15 kernel: hid-generic 0003:046D:407F.0005: input,hidraw4: USB HID v1.11 Keyboard \[Logitech Wireless Mouse PID:407f\] on usb-0000:00:14.0-2/input2:1
окт 05 14:19:02 asusTUF15 kernel: input: Logitech G502 as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2/0003:046D:C539.0003/0003:046D:407F.0005/input/input15
окт 05 14:19:02 asusTUF15 kernel: logitech-hidpp-device 0003:046D:407F.0005: input,hidraw4: USB HID v1.11 Keyboard \[Logitech G502\] on usb-0000:00:14.0-2/input2:1
окт 05 14:19:02 asusTUF15 kernel: logitech-hidpp-device 0003:046D:407F.0005: HID++ 4.2 device connected.
окт 05 14:19:02 asusTUF15 kernel: EXT4-fs (nvme0n1p6): mounted filesystem 2b46e692-5b16-4ea1-8147-89c990b86bc2 r/w with ordered data mode. Quota mode: none.
окт 05 14:19:02 asusTUF15 systemd\[1\]: systemd 257.8-4-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -ID>
окт 05 14:19:02 asusTUF15 systemd\[1\]: Detected architecture x86-64.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Hostname set to .
окт 05 14:19:02 asusTUF15 systemd\[1\]: bpf-restrict-fs: LSM BPF program attached
окт 05 14:19:02 asusTUF15 systemd\[1\]: /etc/systemd/system/disable-wakeups.service:7: Unbalanced quoting, ignoring: “/bin/sh -c '”
окт 05 14:19:02 asusTUF15 systemd\[1\]: disable-wakeups.service: Unit configuration has fatal error, unit will not be started.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Configuration file /etc/systemd/system/AmneziaVPN.service is marked executable. Please remove executable permission bits. Proceeding anyway.
окт 05 14:19:02 asusTUF15 systemd\[1\]: disable-wakeups.service: Cannot add dependency job, ignoring: Unit disable-wakeups.service has a bad unit file setting.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Queued start job for default target Graphical Interface.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Virtual Machine and Container Slice.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice CUPS Slice.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/dirmngr.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/getty.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/gpg-agent.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/gpg-agent-browser.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/gpg-agent-extra.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/gpg-agent-ssh.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/keyboxd.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/modprobe.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice Slice /system/systemd-fsck.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Created slice User and Session Slice.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Started Forward Password Requests to Wall Directory Watch.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Set up automount Arbitrary Executable File Formats File System Automount Point.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Expecting device /dev/disk/by-uuid/3CD1-B482…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Reached target Login Prompts.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Reached target Local Integrity Protected Volumes.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Reached target Remote File Systems.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Reached target Slice Units.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Reached target Mounting snaps.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Reached target Local Verity Protected Volumes.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on Device-mapper event daemon FIFOs.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on LVM2 poll daemon socket.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on Process Core Dump Socket.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on Credential Encryption/Decryption.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on Journal Socket (/dev/log).
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on Journal Sockets.
окт 05 14:19:02 asusTUF15 systemd\[1\]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
окт 05 14:19:02 asusTUF15 systemd\[1\]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on udev Control Socket.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on udev Kernel Socket.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Listening on User Database Manager Socket.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounting Huge Pages File System…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounting POSIX Message Queue File System…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounting Kernel Debug File System…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounting Kernel Trace File System…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load AppArmor profiles…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Create List of Static Device Nodes…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load Kernel Module configfs…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load Kernel Module dm_mod…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load Kernel Module drm…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load Kernel Module fuse…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load Kernel Module loop…
окт 05 14:19:02 asusTUF15 systemd\[1\]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
окт 05 14:19:02 asusTUF15 systemd\[1\]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d>
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Journal Service…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load Kernel Modules…
окт 05 14:19:02 asusTUF15 systemd\[1\]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Remount Root and Kernel File Systems…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Load udev Rules from Credentials…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Coldplug All udev Devices…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Virtual Console Setup…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounted Huge Pages File System.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounted POSIX Message Queue File System.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounted Kernel Debug File System.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounted Kernel Trace File System.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Create List of Static Device Nodes.
окт 05 14:19:02 asusTUF15 systemd\[1\]: modprobe@configfs.service: Deactivated successfully.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Load Kernel Module configfs.
окт 05 14:19:02 asusTUF15 systemd\[1\]: modprobe@drm.service: Deactivated successfully.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Load Kernel Module drm.
окт 05 14:19:02 asusTUF15 systemd\[1\]: modprobe@fuse.service: Deactivated successfully.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Load Kernel Module fuse.
окт 05 14:19:02 asusTUF15 kernel: loop: module loaded
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounting FUSE Control File System…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounting Kernel Configuration File System…
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting Create Static Device Nodes in /dev gracefully…
окт 05 14:19:02 asusTUF15 systemd\[1\]: modprobe@loop.service: Deactivated successfully.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Load Kernel Module loop.
окт 05 14:19:02 asusTUF15 kernel: device-mapper: uevent: version 1.0.3
окт 05 14:19:02 asusTUF15 kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Load udev Rules from Credentials.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Virtual Console Setup.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounted FUSE Control File System.
окт 05 14:19:02 asusTUF15 systemd\[1\]: modprobe@dm_mod.service: Deactivated successfully.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Finished Load Kernel Module dm_mod.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Mounted Kernel Configuration File System.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Repartition Root Disk was skipped because no trigger condition checks were met.
окт 05 14:19:02 asusTUF15 kernel: i2c_dev: i2c /dev entries driver
окт 05 14:19:02 asusTUF15 systemd-journald\[464\]: Collecting audit messages is disabled.
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“Discord” pid=485 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“epiphany” pid=503 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“element-desktop” pid=502 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“cam” pid=494 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“chromium” pid=498 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“vscode” pid=499 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“balena-etcher” pid=489 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“ch-run” pid=496 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“crun” pid=500 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: audit: type=1400 audit(1759663142.660:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“1password” pid=484 comm=“apparmor_parser”
окт 05 14:19:02 asusTUF15 kernel: vboxdrv: loading out-of-tree module taints kernel.
окт 05 14:19:02 asusTUF15 kernel: vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
окт 05 14:19:02 asusTUF15 systemd\[1\]: Starting User Database Manager…
окт 05 14:19:02 asusTUF15 kernel: vboxdrv: Found 20 processor cores/threads
окт 05 14:19:02 asusTUF15 kernel: EXT4-fs (nvme0n1p6): re-mounted 2b46e692-5b16-4ea1-8147-89c990b86bc2.
окт 05 14:19:02 asusTUF15 systemd\[1\]: Started Journal Service.
окт 05 14:19:02 asusTUF15 kernel: vboxdrv: TSC mode is Invariant, tentative frequency 2687999970 Hz
окт 05 14:19:02 asusTUF15 kernel: vboxdrv: Successfully loaded version 7.2.0 r170228 (interface 0x00340001)
окт 05 14:19:02 asusTUF15 systemd-journald\[464\]: Received client request to flush runtime journal.
окт 05 14:19:02 asusTUF15 kernel: VBoxNetAdp: Successfully started.
окт 05 14:19:02 asusTUF15 systemd-journald\[464\]: File /var/log/journal/0c91d0e6c18841b48c694b76a5224157/system.journal corrupted or uncleanly shut down, renaming and replacing.
окт 05 14:19:02 asusTUF15 kernel: VBoxNetFlt: Successfully started.
окт 05 14:19:02 asusTUF15 kernel: Adding 25165820k swap on /swapfile. Priority:-2 extents:542 across:385368060k SS
окт 05 14:19:02 asusTUF15 kernel: resource: resource sanity check: requesting \[mem 0x00000000fedc0000-0x00000000fedcffff\], which spans more than pnp 00:03 \[mem 0xfedc0000-0xfedc7fff\]
окт 05 14:19:02 asusTUF15 kernel: Consider using thermal netlink events interface
окт 05 14:19:02 asusTUF15 kernel: caller igen6_probe+0x158/0x7b0 \[igen6_edac\] mapping multiple BARs
окт 05 14:19:02 asusTUF15 kernel: input: Intel HID events as /devices/platform/INTC1070:00/input/input16
окт 05 14:19:02 asusTUF15 kernel: intel-hid INTC1070:00: platform supports 5 button array
окт 05 14:19:02 asusTUF15 kernel: input: Intel HID 5 button array as /devices/platform/INTC1070:00/input/input17
окт 05 14:19:02 asusTUF15 kernel: EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
окт 05 14:19:02 asusTUF15 kernel: EDAC MC1: Giving out device to module igen6_edac controller Intel_client_SoC MC#1: DEV 0000:00:00.0 (INTERRUPT)
окт 05 14:19:02 asusTUF15 kernel: EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
окт 05 14:19:02 asusTUF15 kernel: EDAC igen6 MC0: ADDR 0x7fffffffe0
окт 05 14:19:02 asusTUF15 kernel: EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
окт 05 14:19:02 asusTUF15 kernel: EDAC igen6 MC1: ADDR 0x7fffffffe0
окт 05 14:19:02 asusTUF15 kernel: EDAC igen6: v2.5.1
окт 05 14:19:02 asusTUF15 kernel: intel_pmc_core INT33A1:00: initialized
окт 05 14:19:02 asusTUF15 kernel: pps_core: LinuxPPS API ver. 1 registered
окт 05 14:19:02 asusTUF15 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
окт 05 14:19:02 asusTUF15 kernel: i801_smbus 0000:00:1f.4: enabling device (0001 → 0003)
окт 05 14:19:02 asusTUF15 kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
окт 05 14:19:02 asusTUF15 kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
окт 05 14:19:02 asusTUF15 kernel: ACPI: bus type thunderbolt registered
окт 05 14:19:02 asusTUF15 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input18
окт 05 14:19:03 asusTUF15 kernel: i2c i2c-0: Successfully instantiated SPD at 0x50
окт 05 14:19:03 asusTUF15 kernel: intel-lpss 0000:00:15.0: enabling device (0004 → 0006)
окт 05 14:19:03 asusTUF15 kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
окт 05 14:19:03 asusTUF15 kernel: PTP clock support registered
окт 05 14:19:03 asusTUF15 kernel: intel-lpss 0000:00:15.2: enabling device (0004 → 0006)
окт 05 14:19:03 asusTUF15 kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
окт 05 14:19:03 asusTUF15 kernel: typec port0: bound usb3-port4 (ops connector_ops)
окт 05 14:19:03 asusTUF15 kernel: typec port0: bound usb2-port1 (ops connector_ops)
окт 05 14:19:03 asusTUF15 kernel: input: ASUF1204:00 2808:0104 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ASUF1204:00/0018:2808:0104.0006/input/input19
окт 05 14:19:03 asusTUF15 kernel: input: ASUF1204:00 2808:0104 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ASUF1204:00/0018:2808:0104.0006/input/input20
окт 05 14:19:03 asusTUF15 kernel: hid-generic 0018:2808:0104.0006: input,hidraw5: I2C HID v1.00 Mouse \[ASUF1204:00 2808:0104\] on i2c-ASUF1204:00
окт 05 14:19:03 asusTUF15 kernel: typec port1: bound usb3-port5 (ops connector_ops)
окт 05 14:19:03 asusTUF15 kernel: typec port1: bound usb4-port4 (ops connector_ops)
окт 05 14:19:03 asusTUF15 kernel: input: ITE5570:00 048D:8051 as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-2/i2c-ITE5570:00/0018:048D:8051.0007/input/input23
окт 05 14:19:03 asusTUF15 kernel: hid-generic 0018:048D:8051.0007: input,hidraw6: I2C HID v1.00 Device \[ITE5570:00 048D:8051\] on i2c-ITE5570:00
окт 05 14:19:03 asusTUF15 kernel: mc: Linux media interface: v0.10
окт 05 14:19:03 asusTUF15 kernel: mousedev: PS/2 mouse device common for all mice
окт 05 14:19:03 asusTUF15 kernel: iTCO_vendor_support: vendor-support=0
окт 05 14:19:03 asusTUF15 kernel: intel_rapl_msr: PL4 support detected.
окт 05 14:19:03 asusTUF15 kernel: e1000e: Intel(R) PRO/1000 Network Driver
окт 05 14:19:03 asusTUF15 kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
окт 05 14:19:03 asusTUF15 kernel: e1000e 0000:00:1f.6: enabling device (0000 → 0002)
окт 05 14:19:03 asusTUF15 kernel: mei_me 0000:00:16.0: enabling device (0000 → 0002)
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: Core ver 2.22
окт 05 14:19:03 asusTUF15 kernel: NET: Registered PF_BLUETOOTH protocol family
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: HCI device and connection manager initialized
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: HCI socket layer initialized
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: L2CAP socket layer initialized
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: SCO socket layer initialized
окт 05 14:19:03 asusTUF15 kernel: intel_rapl_common: Found RAPL domain package
окт 05 14:19:03 asusTUF15 kernel: intel_rapl_common: Found RAPL domain core
окт 05 14:19:03 asusTUF15 kernel: e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
окт 05 14:19:03 asusTUF15 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
окт 05 14:19:03 asusTUF15 kernel: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
окт 05 14:19:03 asusTUF15 kernel: Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
окт 05 14:19:03 asusTUF15 kernel: spd5118 0-0050: DDR5 temperature sensor: vendor 0x06:0x32 revision 1.6
окт 05 14:19:03 asusTUF15 kernel: proc_thermal_pci 0000:00:04.0: enabling device (0000 → 0002)
окт 05 14:19:03 asusTUF15 kernel: asus_wmi: ASUS WMI generic driver loaded
окт 05 14:19:03 asusTUF15 kernel: Creating 1 MTD partitions on “0000:00:1f.5”:
окт 05 14:19:03 asusTUF15 kernel: 0x000000000000-0x000002000000 : “BIOS”
окт 05 14:19:03 asusTUF15 kernel: videodev: Linux video capture interface: v2.00
окт 05 14:19:03 asusTUF15 kernel: spd5118 0-0052: DDR5 temperature sensor: vendor 0x06:0x32 revision 1.6
окт 05 14:19:03 asusTUF15 kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
окт 05 14:19:03 asusTUF15 kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
окт 05 14:19:03 asusTUF15 kernel: RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 655360 ms ovfl timer
окт 05 14:19:03 asusTUF15 kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
окт 05 14:19:03 asusTUF15 kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
окт 05 14:19:03 asusTUF15 kernel: cryptd: max_cpu_qlen set to 1000
окт 05 14:19:03 asusTUF15 kernel: Intel(R) Wireless WiFi driver for Linux
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: enabling device (0000 → 0002)
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: Detected crf-id 0x1300504, cnv-id 0x80400 wfpm id 0x80000030
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: PCI dev 51f0/0074, rev=0x370, rfid=0x10a100
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz
окт 05 14:19:03 asusTUF15 kernel: Missing max value on FX507ZM for tunable: nv_temp_target
окт 05 14:19:03 asusTUF15 kernel: AES CTR mode by8 optimization enabled
окт 05 14:19:03 asusTUF15 kernel: asus_wmi: Initialization: 0x1
окт 05 14:19:03 asusTUF15 kernel: asus_wmi: SFUN value: 0x21
окт 05 14:19:03 asusTUF15 kernel: asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
окт 05 14:19:03 asusTUF15 kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 → 0002)
окт 05 14:19:03 asusTUF15 kernel: asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile support
окт 05 14:19:03 asusTUF15 kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 → 0002)
окт 05 14:19:03 asusTUF15 kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
окт 05 14:19:03 asusTUF15 kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
окт 05 14:19:03 asusTUF15 kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
окт 05 14:19:03 asusTUF15 kernel: usb 3-7: Found UVC 1.00 device USB2.0 HD UVC WebCam (322e:202c)
окт 05 14:19:03 asusTUF15 kernel: input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input24
окт 05 14:19:03 asusTUF15 kernel: usbcore: registered new interface driver uvcvideo
окт 05 14:19:03 asusTUF15 kernel: asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
окт 05 14:19:03 asusTUF15 kernel: asus_wmi: using asus-wmi for asus::kbd_backlight
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: loaded firmware version 89.af655058.0 so-a0-hr-b0-89.ucode op_mode iwlmvm
окт 05 14:19:03 asusTUF15 kernel: usbcore: registered new interface driver snd-usb-audio
окт 05 14:19:03 asusTUF15 kernel: input: ASUF1204:00 2808:0104 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ASUF1204:00/0018:2808:0104.0006/input/input25
окт 05 14:19:03 asusTUF15 kernel: input: ASUF1204:00 2808:0104 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ASUF1204:00/0018:2808:0104.0006/input/input26
окт 05 14:19:03 asusTUF15 kernel: hid-multitouch 0018:2808:0104.0006: input,hidraw5: I2C HID v1.00 Mouse \[ASUF1204:00 2808:0104\] on i2c-ASUF1204:00
окт 05 14:19:03 asusTUF15 kernel: ACPI: battery: new extension: ASUS Battery Extension
окт 05 14:19:03 asusTUF15 kernel: e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
окт 05 14:19:03 asusTUF15 kernel: usbcore: registered new interface driver btusb
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Device revision is 2
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Secure boot is enabled
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: OTP lock is enabled
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: API lock is enabled
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Debug lock is disabled
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: DSM reset method type: 0x00
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0040-4150.sfi
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Boot Address: 0x100800
окт 05 14:19:03 asusTUF15 kernel: Bluetooth: hci0: Firmware Version: 133-20.25
окт 05 14:19:03 asusTUF15 kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input29
окт 05 14:19:03 asusTUF15 kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input30
окт 05 14:19:03 asusTUF15 kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input31
окт 05 14:19:03 asusTUF15 kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input32
окт 05 14:19:03 asusTUF15 kernel: e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 50:eb:f6:91:d7:86
окт 05 14:19:03 asusTUF15 kernel: e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
окт 05 14:19:03 asusTUF15 kernel: e1000e 0000:00:1f.6 eth0: MAC: 15, PHY: 12, PBA No: FFFFFF-0FF
окт 05 14:19:03 asusTUF15 kernel: e1000e 0000:00:1f.6 eno2: renamed from eth0
окт 05 14:19:03 asusTUF15 kernel: intel_tcc_cooling: TCC Offset locked
окт 05 14:19:03 asusTUF15 kernel: loop0: detected capacity change from 0 to 8
окт 05 14:19:03 asusTUF15 kernel: loop1: detected capacity change from 0 to 136816
окт 05 14:19:03 asusTUF15 kernel: loop2: detected capacity change from 0 to 136808
окт 05 14:19:03 asusTUF15 kernel: loop3: detected capacity change from 0 to 1207552
окт 05 14:19:03 asusTUF15 kernel: loop4: detected capacity change from 0 to 1266192
окт 05 14:19:03 asusTUF15 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
окт 05 14:19:03 asusTUF15 kernel: loop5: detected capacity change from 0 to 187776
окт 05 14:19:03 asusTUF15 kernel: loop6: detected capacity change from 0 to 342968
окт 05 14:19:03 asusTUF15 kernel: loop7: detected capacity change from 0 to 342992
окт 05 14:19:03 asusTUF15 kernel: loop8: detected capacity change from 0 to 595504
окт 05 14:19:03 asusTUF15 kernel: loop9: detected capacity change from 0 to 595512
окт 05 14:19:03 asusTUF15 kernel: loop10: detected capacity change from 0 to 100952
окт 05 14:19:03 asusTUF15 kernel: loop11: detected capacity change from 0 to 103976
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3: base HW address: a0:e7:0b:56:a5:f9
окт 05 14:19:03 asusTUF15 kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
окт 05 14:19:04 asusTUF15 kernel: input: keyd virtual keyboard as /devices/virtual/input/input33
окт 05 14:19:04 asusTUF15 kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
окт 05 14:19:04 asusTUF15 kernel: Bluetooth: BNEP filters: protocol multicast
окт 05 14:19:04 asusTUF15 kernel: Bluetooth: BNEP socket layer initialized
окт 05 14:19:04 asusTUF15 kernel: NET: Registered PF_QIPCRTR protocol family
окт 05 14:19:04 asusTUF15 kernel: loop12: detected capacity change from 0 to 8
окт 05 14:19:04 asusTUF15 kernel: input: keyd virtual pointer as /devices/virtual/input/input34
окт 05 14:19:04 asusTUF15 kernel: Bluetooth: hci0: Waiting for firmware download to complete
окт 05 14:19:04 asusTUF15 kernel: Bluetooth: hci0: Firmware loaded in 1405411 usecs
окт 05 14:19:04 asusTUF15 kernel: Bluetooth: hci0: Waiting for device to boot
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Device booted in 14837 usecs
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-4150.ddc
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Firmware timestamp 2025.20 buildtype 1 build 82053
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Firmware SHA1: 0x937bca4a
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Fseq status: Success (0x00)
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Fseq executed: 00.00.02.41
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Fseq BT Top: 00.00.02.41
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: MGMT ver 1.23
окт 05 14:19:05 asusTUF15 kernel: NET: Registered PF_ALG protocol family
окт 05 14:19:05 asusTUF15 kernel: pcieport 10000:e0:06.0: Primary bus is hard wired to 0
окт 05 14:19:05 asusTUF15 kernel: pcieport 10000:e0:06.2: Primary bus is hard wired to 0
окт 05 14:19:05 asusTUF15 kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
окт 05 14:19:05 asusTUF15 kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
окт 05 14:19:05 asusTUF15 kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
окт 05 14:19:05 asusTUF15 kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
окт 05 14:19:05 asusTUF15 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
окт 05 14:19:05 asusTUF15 kernel: iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
окт 05 14:19:05 asusTUF15 kernel: Bluetooth: hci0: Bad flag given (0x1) vs supported (0x0)
окт 05 14:19:05 asusTUF15 kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 510
окт 05 14:19:05 asusTUF15 kernel: nvidia 0000:01:00.0: enabling device (0000 → 0003)
окт 05 14:19:05 asusTUF15 kernel: nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
окт 05 14:19:05 asusTUF15 kernel: NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 575.64.05 Release Build (root@)
окт 05 14:19:05 asusTUF15 kernel: nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 575.64.05 Release Build (root@)
окт 05 14:19:05 asusTUF15 kernel: \[drm\] \[nvidia-drm\] \[GPU ID 0x00000100\] Loading driver
окт 05 14:19:05 asusTUF15 kernel: NVRM: testIfDsmSubFunctionEnabled: GPS ACPI DSM called before \_acpiDsmSupportedFuncCacheInit subfunction = 11.
окт 05 14:19:07 asusTUF15 kernel: NVRM: testIfDsmSubFunctionEnabled: GPS ACPI DSM called before \_acpiDsmSupportedFuncCacheInit subfunction = 11.
окт 05 14:19:07 asusTUF15 kernel: \[drm\] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
окт 05 14:19:07 asusTUF15 kernel: nvidia 0000:01:00.0: \[drm\] Cannot find any crtc or sizes
окт 05 14:19:09 asusTUF15 kernel: wlo1: authenticate with 28:ee:52:9d:f6:0f (local address=a0:e7:0b:56:a5:f9)
окт 05 14:19:09 asusTUF15 kernel: wlo1: send auth to 28:ee:52:9d:f6:0f (try 1/3)
окт 05 14:19:09 asusTUF15 kernel: wlo1: authenticated
окт 05 14:19:09 asusTUF15 kernel: wlo1: associate with 28:ee:52:9d:f6:0f (try 1/3)
окт 05 14:19:09 asusTUF15 kernel: wlo1: associate with 28:ee:52:9d:f6:0f (try 2/3)
окт 05 14:19:09 asusTUF15 kernel: wlo1: RX AssocResp from 28:ee:52:9d:f6:0f (capab=0x1411 status=0 aid=2)
окт 05 14:19:09 asusTUF15 kernel: wlo1: associated
окт 05 14:19:20 asusTUF15 kernel: rfkill: input handler disabled
окт 05 14:19:20 asusTUF15 kernel: Bluetooth: RFCOMM TTY layer initialized
окт 05 14:19:20 asusTUF15 kernel: Bluetooth: RFCOMM socket layer initialized
окт 05 14:19:20 asusTUF15 kernel: Bluetooth: RFCOMM ver 1.11
If I missed something, please say: I will gladly provide any related info to dig into this.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Your Filesystem ist at 89.8% full that means you have 73 GiB free
You use a swapfile instead of a partition (max 24 GB)
It’s normal for the file system to reserve some of the free space.
A certain portion is reserved for root only (previously this has been 5% = 36GiB).
tune2fs -l /dev/nvme1n1p6 | grep -E 'Reserved block count' -
A certain portion is reserved for metadata.
I can’t say whether your swap file (24 GiB) is counted as free space or not.
So, a current lack of space is still a possible cause.
Abandoned topic (30+ days)
