I’ve been having this issue on the 6.1 lts kernel and later versions but not on the 5.15 lts kernel. Where when I come out of sleep mode I’ll have a blank black screen or solid underscore cursor for at least 2-3 minutes before the system will resume out of sleep mode. Journalctl is saying I have some disk errors on one of my drives, GSmartControl says the drive is fine and in spec. I recently aligned the partition on it and still get unaligned write command errors on it. Again these errors don’t appear in the 5.15 lts kernel logs at all. Unsure if this is a regression issue or something.
Jul 20 04:12:50 rageworks systemd-logind[869]: The system will suspend now!
Jul 20 04:12:50 rageworks ModemManager[902]: <info> [sleep-monitor-systemd] system is about to suspend
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.4923] manager: sleep: sleep requested (sleeping: no enabled: yes)
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.4924] manager: NetworkManager state is now ASLEEP
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.4926] device (enp9s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Jul 20 04:12:50 rageworks dbus-daemon[866]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=894 comm="/usr/bin/NetworkManager --no-daemon")
Jul 20 04:12:50 rageworks systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 20 04:12:50 rageworks dbus-daemon[866]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 20 04:12:50 rageworks systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.6544] device (enp9s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Jul 20 04:12:50 rageworks avahi-daemon[864]: Withdrawing address record for fe80::881:c55d:1583:20f5 on enp9s0.
Jul 20 04:12:50 rageworks avahi-daemon[864]: Leaving mDNS multicast group on interface enp9s0.IPv6 with address fe80::881:c55d:1583:20f5.
Jul 20 04:12:50 rageworks avahi-daemon[864]: Interface enp9s0.IPv6 no longer relevant for mDNS.
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.6726] dhcp4 (enp9s0): canceled DHCP transaction
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.6726] dhcp4 (enp9s0): activation: beginning transaction (timeout in 45 seconds)
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.6727] dhcp4 (enp9s0): state changed no lease
Jul 20 04:12:50 rageworks avahi-daemon[864]: Withdrawing address record for 192.168.1.3 on enp9s0.
Jul 20 04:12:50 rageworks avahi-daemon[864]: Leaving mDNS multicast group on interface enp9s0.IPv4 with address 192.168.1.3.
Jul 20 04:12:50 rageworks avahi-daemon[864]: Interface enp9s0.IPv4 no longer relevant for mDNS.
Jul 20 04:12:50 rageworks NetworkManager[894]: <info> [1689847970.7576] device (enp9s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jul 20 04:12:50 rageworks kernel: r8169 0000:09:00.0 enp9s0: Link is Down
Jul 20 04:12:50 rageworks systemd[1]: Reached target Sleep.
Jul 20 04:12:50 rageworks systemd[1]: Starting NVIDIA system suspend actions...
Jul 20 04:12:50 rageworks suspend[2051]: nvidia-suspend.service
Jul 20 04:12:50 rageworks logger[2051]: <13>Jul 20 04:12:50 suspend: nvidia-suspend.service
Jul 20 04:12:51 rageworks systemd[1]: nvidia-suspend.service: Deactivated successfully.
Jul 20 04:12:51 rageworks systemd[1]: Finished NVIDIA system suspend actions.
Jul 20 04:12:51 rageworks systemd[1]: Starting System Suspend...
Jul 20 04:12:51 rageworks systemd-sleep[2059]: Entering sleep state 'suspend'...
Jul 20 04:12:51 rageworks kernel: PM: suspend entry (deep)
Jul 20 04:13:41 rageworks kernel: Filesystems sync: 0.284 seconds
Jul 20 04:13:41 rageworks kernel: Freezing user space processes
Jul 20 04:13:41 rageworks kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Jul 20 04:13:41 rageworks kernel: OOM killer disabled.
Jul 20 04:13:41 rageworks kernel: Freezing remaining freezable tasks
Jul 20 04:13:41 rageworks kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Jul 20 04:13:41 rageworks kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jul 20 04:13:41 rageworks kernel: serial 00:05: disabled
Jul 20 04:13:41 rageworks kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Jul 20 04:13:41 rageworks kernel: sd 1:0:0:0: [sdb] Synchronizing SCSI cache
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: [sdc] Synchronizing SCSI cache
Jul 20 04:13:41 rageworks kernel: sd 1:0:0:0: [sdb] Stopping disk
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: [sdc] Stopping disk
Jul 20 04:13:41 rageworks kernel: sd 0:0:0:0: [sda] Stopping disk
Jul 20 04:13:41 rageworks kernel: ACPI: PM: Preparing to enter system sleep state S3
Jul 20 04:13:41 rageworks kernel: ACPI: PM: Saving platform NVS memory
Jul 20 04:13:41 rageworks kernel: Disabling non-boot CPUs ...
Jul 20 04:13:41 rageworks kernel: smpboot: CPU 1 is now offline
Jul 20 04:13:41 rageworks kernel: smpboot: CPU 2 is now offline
Jul 20 04:13:41 rageworks kernel: smpboot: CPU 3 is now offline
Jul 20 04:13:41 rageworks kernel: ACPI: PM: Low-level resume complete
Jul 20 04:13:41 rageworks kernel: ACPI: PM: Restoring platform NVS memory
Jul 20 04:13:41 rageworks kernel: Enabling non-boot CPUs ...
Jul 20 04:13:41 rageworks kernel: x86: Booting SMP configuration:
Jul 20 04:13:41 rageworks kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Jul 20 04:13:41 rageworks kernel: microcode: CPU1: patch_level=0x08101016
Jul 20 04:13:41 rageworks kernel: CPU1 is up
Jul 20 04:13:41 rageworks kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
Jul 20 04:13:41 rageworks kernel: microcode: CPU2: patch_level=0x08101016
Jul 20 04:13:41 rageworks kernel: CPU2 is up
Jul 20 04:13:41 rageworks kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Jul 20 04:13:41 rageworks kernel: microcode: CPU3: patch_level=0x08101016
Jul 20 04:13:41 rageworks kernel: CPU3 is up
Jul 20 04:13:41 rageworks kernel: ACPI: PM: Waking up from system sleep state S3
Jul 20 04:13:41 rageworks kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
Jul 20 04:13:41 rageworks kernel: usb usb1: root hub lost power or was reset
Jul 20 04:13:41 rageworks kernel: usb usb2: root hub lost power or was reset
Jul 20 04:13:41 rageworks kernel: serial 00:05: activated
Jul 20 04:13:41 rageworks kernel: sd 0:0:0:0: [sda] Starting disk
Jul 20 04:13:41 rageworks kernel: sd 1:0:0:0: [sdb] Starting disk
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: [sdc] Starting disk
Jul 20 04:13:41 rageworks kernel: ata5: SATA link down (SStatus 0 SControl 330)
Jul 20 04:13:41 rageworks kernel: ata9: SATA link down (SStatus 0 SControl 300)
Jul 20 04:13:41 rageworks kernel: ata6: SATA link down (SStatus 0 SControl 330)
Jul 20 04:13:41 rageworks kernel: usb 1-7: reset full-speed USB device number 2 using xhci_hcd
Jul 20 04:13:41 rageworks kernel: usb 1-10: reset full-speed USB device number 4 using xhci_hcd
Jul 20 04:13:41 rageworks kernel: usb 1-8: reset full-speed USB device number 3 using xhci_hcd
Jul 20 04:13:41 rageworks kernel: ata2: found unknown device (class 0)
Jul 20 04:13:41 rageworks kernel: ata1: found unknown device (class 0)
Jul 20 04:13:41 rageworks kernel: ata10: found unknown device (class 0)
Jul 20 04:13:41 rageworks kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jul 20 04:13:41 rageworks kernel: ata2.00: configured for UDMA/133
Jul 20 04:13:41 rageworks kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jul 20 04:13:41 rageworks kernel: ata1.00: configured for UDMA/133
Jul 20 04:13:41 rageworks kernel: ata10: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jul 20 04:13:41 rageworks kernel: ata10.00: configured for UDMA/133
Jul 20 04:13:41 rageworks kernel: ata10.00: device reported invalid CHS sector 0
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: [sdc] Start/Stop Unit failed: Result: hostbyte=DID_OK driverbyte=DRIVER_OK
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: [sdc] Sense Key : Illegal Request [current]
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: [sdc] Add. Sense: Unaligned write command
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: PM: dpm_run_callback(): scsi_bus_resume+0x0/0x90 returns -5
Jul 20 04:13:41 rageworks kernel: sd 9:0:0:0: PM: failed to resume async: error -5
Jul 20 04:13:41 rageworks kernel: OOM killer enabled.
Jul 20 04:13:41 rageworks kernel: Restarting tasks ... done.
Jul 20 04:13:41 rageworks kernel: random: crng reseeded on system resumption
Jul 20 04:13:41 rageworks kernel: PM: suspend exit
Jul 20 04:13:41 rageworks rtkit-daemon[1349]: The canary thread is apparently starving. Taking action.
Jul 20 04:13:41 rageworks systemd-sleep[2059]: System returned from sleep state.
Jul 20 04:13:41 rageworks rtkit-daemon[1349]: Demoting known real-time threads.
Jul 20 04:13:41 rageworks systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jul 20 04:13:41 rageworks rtkit-daemon[1349]: Successfully demoted thread 1597 of process 1342.
Jul 20 04:13:41 rageworks rtkit-daemon[1349]: Successfully demoted thread 1342 of process 1342.
Jul 20 04:13:41 rageworks rtkit-daemon[1349]: Demoted 2 threads.
Jul 20 04:13:42 rageworks systemd[1]: systemd-suspend.service: Deactivated successfully.
Jul 20 04:13:42 rageworks systemd[1]: Finished System Suspend.
Jul 20 04:13:42 rageworks systemd[1]: Stopped target Sleep.
Jul 20 04:13:42 rageworks systemd[1]: Reached target Suspend.
Jul 20 04:13:42 rageworks systemd[1]: Stopped target Suspend.
Jul 20 04:13:42 rageworks systemd-logind[869]: Operation 'sleep' finished.
Inxi info
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=d964fe19-43ec-4f0f-8307-a365f21cf14b rw quiet apparmor=1
security=apparmor resume=UUID=359477c8-3654-43b2-b057-f4534ecae4a5
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
UEFI: American Megatrends v: P5.60 date: 10/20/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 2.27 GiB (7.3%)
Device-1: DIMM 0 type: no module installed
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2A2666C16 serial: N/A
Device-3: DIMM 0 type: no module installed
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics socket: AM4 bits: 64
type: MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1775 high: 2300 min/max: 1600/3500 boost: enabled
base/boost: 3500/3700 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.4 V ext-clock: 100 MHz cores: 1: 1600 2: 1600 3: 2300 4: 1600
bogomips: 28013
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: xfwm v: 4.18.0 driver: X: loaded: nvidia gpu: nvidia
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX 1050
Ti/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.74 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.55 TiB used: 1.76 TiB (38.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM006-2DM164
family: BarraCuda 3.5 (CMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: CC26 temp: 41 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 141d 12h cycles: 2208
read: 278.35 TiB written: 24.27 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
family: Barracuda 7200.12 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: JC4B temp: 40 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 109d 17h cycles: 4769
read: 1.84 TiB written: 1015.63 GiB Pre-Fail: attribute: Spin_Retry_Count
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
serial: <filter> fw-rev: 0001 temp: 39 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4502h+24m+35.083s cycles: 774
read: 4.51 TiB written: 5.2 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 828.3 GiB (45.4%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: d964fe19-43ec-4f0f-8307-a365f21cf14b
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: CC36-8466
ID-3: /mnt/backup raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 346.78 GiB (37.9%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: backup uuid: d10a04e0-75c3-4d35-9c0d-c5dae0164ecb
ID-4: /mnt/secondary raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 624.74 GiB (34.1%) fs: ext4 block-size: 4096 B dev: /dev/sdc1
maj-min: 8:33 label: secondary uuid: 2111b3ea-8e42-48ec-9d73-55ac5f16851e
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 359477c8-3654-43b2-b057-f4534ecae4a5
Device-1: 1-7:2 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Device-2: 1-8:3 info: Areson Corp Akko 2.4G wireless Keyboard
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 25a7:fa19 class-ID: 0301
Device-3: 1-10:4 info: Primax AKKO Multi-modes Keyboard-B
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 0461:4002 class-ID: 0300
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 34.6 C mobo: N/A
Processes: 210 Uptime: 16m wakeups: 5 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1351 libs: 464 tools: pamac,yay Shell: Sudo (sudo) v: 1.9.14p1
default: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.28
Thanks,
Xorg
EDIT: Nevermind, there seems to be an issue with the drive in question and other Seagate drives across several different distros after the 6.x kernel after looking at this Linux Hardware page. here
EDIT 2: Incase anyone else has this issue, I had the same error across multiple different distros when coming out of suspend so contacted the kernel regression mailing list and got a patch through them that will hopefully be in an update soon.
