When I crawl out of bed in the morning, after my PC has been idle for 8 hours or so, I normally just power on my monitor and get to work. But since the December 30 upgrade, my LG monitor says: ‘No Signal’. I can’t even switch VTs and Magick Syrq doesn’t work either. I need to do a cold boot.
I figure this might be related to the nvidia driver issue other people are experiencing as described in official Manjaro forum support thread but I am not 100% sure. Is there any other information I could provide to confirm this either way?
The recent main support thread (that I linked to above) explains how to compile old nvidia drivers but these instructions are not relevant in my case because I’ve got a Maxwell chip so I do not require legacy drivers (<= v390 for Fermi and below) and the current v455.x is compatible with my GeForce 950 hardware, is this correct?
My system otherwise boots, is stable, and runs well I guess.
Maybe it’s not a driver issue. Is there any other potential power-related feature for me to check? I’ve double checked my Xfce power settings and have ensured that everything is turned off, including the screen saver and the hibernate feature. But is there any other power switch I could try changing?
Here is: $ inxi -Fazy:
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=6403b740-9546-4f5d-95fc-646e358e098d rw quiet apparmor=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel, latte-dock
wm: Compiz 0.8.18 dm: GDM 3.38.2.1, LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
serial: <filter>
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F2 date: 03/14/2018
Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D L2 cache: 4 MiB
bogomips: 102430
Speed: 2663 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 2663 2: 2896 3: 2467 4: 1814 5: 2624 6: 1701 7: 2972 8: 2429 9: 1530
10: 1632 11: 2616 12: 1943 13: 3261 14: 2670 15: 2912 16: 2650
disabled, RSB filling
Device-1: NVIDIA GM206 [GeForce GTX 950] vendor: eVga.com. driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 0a:00.0
chip ID: 10de:1402
Display: x11 server: X.Org 1.20.10 compositor: compiz v: 0.8.18
driver: nvidia display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1600 s-dpi: 96 s-size: 1016x423mm (40.0x16.7")
s-diag: 1101mm (43.3")
Monitor-1: HDMI-0 res: 3840x1600 hz: 60 dpi: 111
size: 879x366mm (34.6x14.4") diag: 952mm (37.5")
OpenGL: renderer: GeForce GTX 950/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus ID: 0a:00.1 chip ID: 10de:0fba
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 0c:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus ID: 07:00.0 chip ID: 8086:1539
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.28 TiB used: 821.9 GiB (35.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 2B2QEXE7 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: M4-CT256M4SSD2
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 000F
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EFRX-68AX9N0
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0A80
ID-1: / raw size: 83.01 GiB size: 81.2 GiB (97.83%) used: 32.66 GiB (40.2%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw size: 1000 MiB size: 998 MiB (99.80%)
used: 272 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw size: 960.25 GiB size: 944.18 GiB (98.33%)
used: 789.24 GiB (83.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 59.2 C mobo: N/A gpu: nvidia temp: 50 C
Processes: 489 Uptime: 2h 04m wakeups: 0 Memory: 62.82 GiB
used: 15.73 GiB (25.0%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1847 lib: 468 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.01
