System lag, extremely slow on external monitor
I just got a new Dell G15 laptop and installed Manajro. All is fine except if I attach an external monitor, and close the laptop’s lid than the whole system is laggin, everything is extremely slow.
If I use both monitors (the laptop’s and the external) everything is normal.
I found this thread: Stuttering and Laggy monitor on "External Only" mode but I am not sure if it solves my problem, and I do not know how to " replace gdm with this patched version : gdm-prime".
 inxi --admin --verbosity=7 --filter --no-host --width                                            ✔  21s 
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=6b97925a-c2a0-4906-9a82-eaeb4a9a4d71 rw quiet nvme_load=YES splash
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: Dell product: Dell G15 5510 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0983D5 v: A00 serial: <filter> UEFI: Dell v: 1.3.1
  date: 03/29/2021
  ID-1: BAT0 charge: 54.9 Wh (100.0%) condition: 54.9/54.9 Wh (100.0%)
  volts: 12.9 min: 11.4 model: BYD DELL DVG8M14 type: Li-poly serial: <filter>
  status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  RAM: total: 7.55 GiB used: 3.59 GiB (47.5%)
  Info: Quad Core model: Intel Core i5-10200H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
  cache: L2: 8 MiB bogomips: 38408
  Speed: 1072 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 1072 2: 1088
  3: 1036 4: 1000 5: 1000 6: 1000 7: 964 8: 1053
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:9ba4 class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f9d class-ID: 0300
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 0bda:565c class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT1) v: 4.6 Mesa 21.2.2
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell
  driver: sof-audio-pci-intel-cnl
  alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  chip-ID: 8086:06c8 class-ID: 0401
  Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 10de:10fa class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.37 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 5000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
  vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 476.94 GiB used: 109.6 GiB (23.0%)
  model: PC SN530 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
  rev: 21112012 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 476.65 GiB size: 468.09 GiB (98.21%)
  used: 109.6 GiB (23.4%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: 6b97925a-c2a0-4906-9a82-eaeb4a9a4d71
  used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  label: NO_LABEL uuid: F635-7260
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
  driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 98mA chip-ID: 046d:c534 class-ID: 0301
  Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
  Device-3: 1-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 50.0 C mobo: N/A
  Processes: 295 Uptime: 1h 14m wakeups: 2302 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1273 lib: 326
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
  • Kernel 5.13 is EOL so please install both 5.4 and 5.10 LTS (Long Term Support) and see which one of the two troubles you least.
I’m on KDE, not Gnome, so I can’t tell you what to do exactly, but closing the laptop lid is like pressing a physical button, so ensure that “Close laptop lid” in your Gnome settings is set to “do nothing”. Even when you set it to do nothing; the screen will still turn off to save battery, but the computer will continue working at normal speed, whereas it now sounds it’s going into toem form of sleep mode.
Thanks, I will do them.
:+1:
If that works, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
I installed the 5.4, 5.10 and 5.14 kernel, and upgraded all drivers and software.
Since than my external monitor does not even detected with any of the kernels.
I don’t understand… Now none of you monitors are recognized?
mhwd --listinstalled
Please?
  Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  date: 03/29/2021
  volts: 12.7 min: 11.4 model: BYD DELL DVG8M14 type: Li-poly serial: <filter>
  status: Full
  RAM: total: 7.55 GiB used: 4.27 GiB (56.6%)
  Speed: 4000 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4000 2: 4000
  3: 4000 4: 4000 5: 4000 6: 4000 7: 4000 8: 4000
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: modesetting display-ID: 0 resolution: <missing: xdpyinfo>
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT1) v: 4.6 Mesa 21.2.3
  direct render: Yes
  Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  Local Storage: total: 1.38 TiB used: 767.12 GiB (54.5%)
  rev: 21112012 temp: 52.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: JMicron Tech model: Generic
  size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
  serial: <filter> rev: 0204 scheme: GPT
  used: 125.06 GiB (26.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /run/media/rrd/4CF8-2C65 raw-size: 62 MiB size: 61.9 MiB (99.78%)
  used: 10.5 MiB (17.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 4CF8-2C65
  ID-4: /run/media/rrd/D6F3-8643 raw-size: 19.44 GiB size: 19.43 GiB (99.95%)
  used: 16.72 GiB (86.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: D6F3-8643
  ID-5: /run/media/rrd/backup raw-size: 781.25 GiB size: 767.99 GiB (98.30%)
  used: 625.33 GiB (81.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: backup
  uuid: 9d743a6f-ea72-40f5-a05e-c1b4e18cef95
  ID-1: /dev/sda2 maj-min: 8:2 size: 1024 KiB fs: <superuser required>
  label: N/A uuid: N/A
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
  class-ID: e001
  Device-1: 2-1:2 info: JMicron / JMicron USA JMS578 SATA 6Gb/s
  type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
  power: 896mA chip-ID: 152d:0578 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 55.0 C mobo: N/A
  Processes: 355 Uptime: 1h 10m wakeups: 7040 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1302 lib: 328
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.07
mhwd --listinstalled         ✔
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2021.07.28               false            PCI
The laptop monitor is working fine, the external HDMI monitor is not detected.
Looks like you did many actions at once: besides kernel versions, you upgraded drivers and software.
Now it is harder to recognize which one exactly cuts the external monitor.
  1. If to switch to 5.13 kernel back, then does the external monitor works again (with notebook’s lid opened)?
  2. Also I can’t find the monitor model (it is just for general info, I do not know what it can brings).
  3. Try to change HDMI cable to quality one (or expected as non-broken), also test on lower length of HDMI cable (having 2 meters max). May be it could clarify something.
  4. Does the external monitor still works with other device? For example smartphones having USB-C port usually can send screen picture via USB-C - HDMI cable. May be you have some other HDMI sources to check with the monitor.
  5. Re-check power supply of monitor and input port selected. Try suggestions from monitor’s user manual.
  6. do you have any other HDMI display? TV, other one external monitor, etc. (may be to try a monitor of neighbors living close to you)? Do any other external display works with any current kernel (5.4, 5.10, 5.14)?
May be others have more valuable ideas, but meanwhile already posted ideas could be tried.
Unfortunatelly not. It does not detected with any of the kernels.
IT is an LG 23MP
It is a brand new cable, I am sure it is OK. I usd it only 3 days before the updates.
Yes, it is OK.
HDMI is selected
I will try it.
So it is not kernel-dependent issue, cause previously worked 5.13 now can’t detect it?
I had the 23MP55D from 2014 to 2021 (it brokes: 3 column of matrix became to be shown of solid color blue or red), it is off-topic, but in PM I can suggest you better and also cheap model.
I could changes the deal a bit: my model has no HDMI port, I used HDMI (PC) to DVI-D (Display) cable. But I used 1920*1080@60fps 5 meters fabric cable (solid, w/o adapters) which worked well.
So: cable OK, display show picture from other devices, so its HDMI still works, no port selection issues.
Probably it is not the case: it will not have the picture as it has no picture on definitely working monitor. So currently the issue mutate to sort of
“Unable to use HDMI port of notebook”
Does the port is dusty enough? may be to clean it and in further to use silicone anti-dust caps?
yep, the laptop port is clean. It is a new laptop, I use it for 3 weeks…
As laptop is new, and if the issue is software-based only consider to check newest kernel also 5.15-rcX
May be your new hardware is not completely supported by current complex used: drivers you installed + kernel + UEFI.
Also check your notebook manufacturer for notebooks’ firmware updates (UEFI) may be it changes something (example of that sort of another (irrelevant) hardware case: HDMI Firmware Update Tool for NUC8i3BE, NUC8i5BE, NUC8i7BE just as example, do not install it on your different configuration)
If that will not work, than need to review all HDMI port modes/settings.
Also you have journalctl logger helper on your PC. Already used all tips from it?
journalctl -b -p3
journalctl -b | grep -iE "hdmi|display|video"
or review all kernel messages
journalctl -b -k
and general
journalctl -b
logs.
Also consider to try live version. Execute:
journalctl -f
and connect and disconnect display to/from HDMI port. You will see log messages under the OS GUI hood. May be some of them could be used as tips.
I booted into an Ubuntu live USB and it detects the external HDMI monitor. Mirroring was working; however, on attach second screen mode I saw only (!) the mouse cursor, nothing else…
I updated my bios from version 1.3.1 to 1.5.0 but the monitor was still not detected.
journalctl -b -p3
-- Journal begins at Fri 2021-09-24 14:10:45 CEST, ends at Sat 2021-10-16 11:57:20 CEST. --
okt 16 11:55:36 rrd-dell kernel: x86/cpu: SGX disabled by BIOS.
okt 16 11:55:36 rrd-dell kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.RP09.PXSX], AE_ALREADY_EXISTS (20210604/dswload2-326)
okt 16 11:55:36 rrd-dell kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210604/psobject-220)
okt 16 11:55:36 rrd-dell kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.RP21.PXSX], AE_ALREADY_EXISTS (20210604/dswload2-326)
okt 16 11:55:36 rrd-dell systemd-udevd[296]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
okt 16 11:55:36 rrd-dell systemd-udevd[292]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
okt 16 11:55:37 rrd-dell systemd-udevd[292]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
okt 16 11:55:37 rrd-dell systemd-udevd[291]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetct>
okt 16 11:55:37 rrd-dell systemd-udevd[307]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
okt 16 11:55:37 rrd-dell systemd-udevd[299]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
okt 16 11:55:38 rrd-dell wpa_supplicant[750]: nl80211: kernel reports: Attribute failed policy validation
okt 16 11:55:38 rrd-dell wpa_supplicant[750]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
okt 16 11:55:38 rrd-dell wpa_supplicant[750]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
okt 16 11:55:39 rrd-dell kernel:
okt 16 11:55:49 rrd-dell gdm-password][1215]: gkr-pam: unable to locate daemon control file
okt 16 11:55:51 rrd-dell systemd[1227]: Failed to start Application launched by gnome-session-binary.
okt 16 11:55:52 rrd-dell gdm-launch-environment][766]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
journalctl -b | grep -iE "hdmi|display|video"         ✔
okt 16 11:55:36 rrd-dell kernel: ACPI: Added _OSI(Linux-Dell-Video)
okt 16 11:55:36 rrd-dell kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
okt 16 11:55:36 rrd-dell kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
okt 16 11:55:36 rrd-dell kernel: ACPI: video: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
okt 16 11:55:36 rrd-dell kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input2
okt 16 11:55:36 rrd-dell kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
okt 16 11:55:36 rrd-dell kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input3
okt 16 11:55:37 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input19
okt 16 11:55:37 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input20
okt 16 11:55:37 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input21
okt 16 11:55:37 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input22
okt 16 11:55:38 rrd-dell systemd[1]: Starting GNOME Display Manager...
okt 16 11:55:38 rrd-dell systemd[1]: Started GNOME Display Manager.
okt 16 11:55:38 rrd-dell kernel: videodev: Linux video capture interface: v2.00
okt 16 11:55:38 rrd-dell kernel: usbcore: registered new interface driver uvcvideo
okt 16 11:55:39 rrd-dell kernel: input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input39
okt 16 11:55:39 rrd-dell kernel: input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input40
okt 16 11:55:39 rrd-dell kernel: input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input41
okt 16 11:55:42 rrd-dell gnome-shell[796]: Using public X11 display :1024, (using :1025 for managed services)
okt 16 11:55:42 rrd-dell gnome-shell[796]: Using Wayland display name 'wayland-0'
okt 16 11:55:43 rrd-dell org.gnome.Shell.desktop[1032]: > Warning:          Could not resolve keysym XF86DisplayOff
okt 16 11:55:43 rrd-dell org.gnome.Shell.desktop[1032]: > Warning:          Could not resolve keysym XF86VideoPhone
okt 16 11:55:43 rrd-dell org.gnome.Shell.desktop[1032]: > Warning:          Could not resolve keysym XF86DisplayToggle
okt 16 11:55:43 rrd-dell org.gnome.Shell.desktop[1080]: > Warning:          Could not resolve keysym XF86DisplayOff
okt 16 11:55:43 rrd-dell org.gnome.Shell.desktop[1080]: > Warning:          Could not resolve keysym XF86VideoPhone
okt 16 11:55:43 rrd-dell org.gnome.Shell.desktop[1080]: > Warning:          Could not resolve keysym XF86DisplayToggle
okt 16 11:55:50 rrd-dell gnome-shell[1289]: Using public X11 display :0, (using :1 for managed services)
okt 16 11:55:50 rrd-dell gnome-shell[1289]: Using Wayland display name 'wayland-0'
okt 16 11:55:51 rrd-dell gnome-shell[1289]: Some code accessed the property 'SecondaryMonitorDisplay' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
okt 16 11:55:52 rrd-dell gnome-shell[1686]: > Warning:          Could not resolve keysym XF86DisplayOff
okt 16 11:55:52 rrd-dell gnome-shell[1686]: > Warning:          Could not resolve keysym XF86VideoPhone
okt 16 11:55:52 rrd-dell gnome-shell[1686]: > Warning:          Could not resolve keysym XF86DisplayToggle
okt 16 11:55:52 rrd-dell gnome-shell[1691]: > Warning:          Could not resolve keysym XF86DisplayOff
okt 16 11:55:52 rrd-dell gnome-shell[1691]: > Warning:          Could not resolve keysym XF86VideoPhone
okt 16 11:55:52 rrd-dell gnome-shell[1691]: > Warning:          Could not resolve keysym XF86DisplayToggle
journalctl -b -k         ✔
-- Journal begins at Fri 2021-09-24 14:10:45 CEST, ends at Sat 2021-10-16 11:58:29 CEST. --
okt 16 11:55:36 rrd-dell kernel: Linux version 5.14.10-1-MANJARO (builduser@fv-az72-723) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Thu Oct 7>
okt 16 11:55:36 rrd-dell kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=6b97925a-c2a0-4906-9a82-eaeb4a9a4d71 rw quiet nvme_load=YES splash a>
okt 16 11:55:36 rrd-dell kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
okt 16 11:55:36 rrd-dell kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
okt 16 11:55:36 rrd-dell kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
okt 16 11:55:36 rrd-dell kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
okt 16 11:55:36 rrd-dell kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
okt 16 11:55:36 rrd-dell kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
okt 16 11:55:36 rrd-dell kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
okt 16 11:55:36 rrd-dell kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
okt 16 11:55:36 rrd-dell kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
okt 16 11:55:36 rrd-dell kernel: x86/fpu: xstate_offset[9]:  960, xstate_sizes[9]:    8
okt 16 11:55:36 rrd-dell kernel: x86/fpu: Enabled xstate features 0x21f, context size is 968 bytes, using 'compacted' format.
okt 16 11:55:36 rrd-dell kernel: signal: max sigframe size: 3632
okt 16 11:55:36 rrd-dell kernel: BIOS-provided physical RAM map:
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000061378fff] usable
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000061379000-0x0000000061379fff] ACPI NVS
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x000000006137a000-0x000000006137afff] reserved
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x000000006137b000-0x0000000062824fff] usable
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062825000-0x0000000062a46fff] reserved
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a47000-0x0000000062a47fff] type 20
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a48000-0x0000000062a4bfff] reserved
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a4c000-0x0000000062a4cfff] type 20
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a4d000-0x0000000062a50fff] reserved
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a51000-0x0000000062a55fff] type 20
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a56000-0x0000000062a5afff] reserved
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a5b000-0x0000000062a5bfff] type 20
okt 16 11:55:36 rrd-dell kernel: BIOS-e820: [mem 0x0000000062a5c000-0x0000000062a60fff] reserved
journalctl -f
okt 16 11:56:21 rrd-dell systemd[1]: systemd-localed.service: Deactivated successfully.
okt 16 11:56:21 rrd-dell audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:21 rrd-dell kernel: audit: type=1131 audit(1634378181.881:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:21 rrd-dell systemd[1]: systemd-hostnamed.service: Deactivated successfully.
okt 16 11:56:21 rrd-dell audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:21 rrd-dell kernel: audit: type=1131 audit(1634378181.888:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:21 rrd-dell audit: BPF prog-id=18 op=UNLOAD
okt 16 11:56:21 rrd-dell audit: BPF prog-id=17 op=UNLOAD
okt 16 11:56:21 rrd-dell audit: BPF prog-id=16 op=UNLOAD
okt 16 11:56:21 rrd-dell kernel: audit: type=1334 audit(1634378181.958:115): prog-id=18 op=UNLOAD
okt 16 11:56:21 rrd-dell kernel: audit: type=1334 audit(1634378181.958:116): prog-id=17 op=UNLOAD
okt 16 11:56:21 rrd-dell kernel: audit: type=1334 audit(1634378181.958:117): prog-id=16 op=UNLOAD
okt 16 11:56:22 rrd-dell gnome-shell[1289]: updates_checker.vala:71: check updates
okt 16 11:56:22 rrd-dell audit: BPF prog-id=14 op=UNLOAD
okt 16 11:56:22 rrd-dell audit: BPF prog-id=13 op=UNLOAD
okt 16 11:56:22 rrd-dell audit: BPF prog-id=12 op=UNLOAD
okt 16 11:56:22 rrd-dell kernel: audit: type=1334 audit(1634378182.058:118): prog-id=14 op=UNLOAD
okt 16 11:56:22 rrd-dell kernel: audit: type=1334 audit(1634378182.058:119): prog-id=13 op=UNLOAD
okt 16 11:56:22 rrd-dell kernel: audit: type=1334 audit(1634378182.058:120): prog-id=12 op=UNLOAD
okt 16 11:56:28 rrd-dell systemd[1]: systemd-timedated.service: Deactivated successfully.
okt 16 11:56:28 rrd-dell audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:28 rrd-dell kernel: audit: type=1131 audit(1634378188.664:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:28 rrd-dell audit: BPF prog-id=25 op=UNLOAD
okt 16 11:56:28 rrd-dell audit: BPF prog-id=24 op=UNLOAD
okt 16 11:56:28 rrd-dell audit: BPF prog-id=23 op=UNLOAD
okt 16 11:56:28 rrd-dell kernel: audit: type=1334 audit(1634378188.684:122): prog-id=25 op=UNLOAD
okt 16 11:56:28 rrd-dell kernel: audit: type=1334 audit(1634378188.684:123): prog-id=24 op=UNLOAD
okt 16 11:56:28 rrd-dell kernel: audit: type=1334 audit(1634378188.684:124): prog-id=23 op=UNLOAD
okt 16 11:56:31 rrd-dell gnome-shell[1289]: updates_checker.vala:101: 1 updates found
okt 16 11:56:43 rrd-dell geoclue[890]: Service not used for 60 seconds. Shutting down..
okt 16 11:56:43 rrd-dell systemd[1]: geoclue.service: Deactivated successfully.
okt 16 11:56:43 rrd-dell audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:43 rrd-dell kernel: audit: type=1131 audit(1634378203.078:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 16 11:56:52 rrd-dell dbus-daemon[1245]: [session uid=1000 pid=1245] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.15' (uid=1000 pid=1289 comm="/usr/bin/gnome-shell ")
okt 16 11:56:52 rrd-dell systemd[1227]: Starting Virtual filesystem metadata service...
okt 16 11:56:52 rrd-dell dbus-daemon[1245]: [session uid=1000 pid=1245] Successfully activated service 'org.gtk.vfs.Metadata'
okt 16 11:56:52 rrd-dell systemd[1227]: Started Virtual filesystem metadata service.
okt 16 11:57:01 rrd-dell chromium.desktop[2160]: [2160:2160:1016/115701.471126:ERROR:object_proxy.cc(642)] Failed to call method: org.freedesktop.ScreenSaver.GetActive: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NotSupported: This method is not implemented
okt 16 11:57:01 rrd-dell chromium.desktop[2160]: [2160:2160:1016/115701.472455:ERROR:object_proxy.cc(642)] Failed to call method: org.gnome.ScreenSaver.GetActive: object_path= /: org.freedesktop.DBus.Error.UnknownMethod: Az objektum nem létezik a(z) „/” útvonalon
okt 16 11:57:07 rrd-dell systemd[1227]: Started Application launched by gnome-shell.
I switched to Xorg from Wayland just in case, but the external HDMI monitor is not detected with any of the kernels.
As you connected the monitor to other devices and the monitor works, it seems to be the notebook’s HDMI port problem.
Since you mentioned on earlier OS state (5.13 kernel, older drivers, other software before update)
and tried
it seems it is not the notebook’s hardware problem and also you already
It looks like the OS software problem: some HDMI modes/settings . I do not know there they are and how much of them are available.
I ran out of ideas, but as I remember we have The knowledge base with easy access from almost any point of any modern town: if I were you, I would try to search through the Internet a phrases sort of:
linux notebook hdmi external display not detected
arch linux hdmi port modes settings
linux which modes/settings are available for hdmi port notebook
linux after update external display not detected/recognized
linux diagnose hdmi port work notebook
etc.
As all my other attemptm failed I reinstalled my whole system.
Now I am back to the original problem.
External hdmi monitor is detected, mirroring and using both monitors working well, but if I close the laptop lid the whole system is unusably slow.
I don’t know if you are still looking for a solution, but this thread may help, it seems that the problem is the hybrid graphics mode and the only solution, yet, is installing optimus-manager and using only the NVIDIA card Stuttering and Laggy monitor on "External Only" mode - #6 by Fabby
