System Keeps Locking Up
I am experiencing an issue where when I am using my computer, usually with a browser open, the system all the sudden freezes. Videos will freeze, the mouse wont move, no keyboard input works. I cant even switch over to a separate terminal environment. The only thing that I can do to remedy the issue is to hard shut down the computer. This has been happening ever since I upgraded my hardware to a new CPU, RAM, and motherboard. After I had upgraded, I did a fresh install of Manjaro. The weird thing is that when this happens, if a video is playing, even though the screen is frozen, the audio keeps playing and if I am in a video call, the other person can still hear and see me even though the system is completely locked up. Not sure how to fix this. I tried updating the BIOS but no luck, the issue still occurs.
Edit: Weirdly enough, I have never had my system lock up when I am playing a game, its only when I am using my web browser. It seems to happen when using any browser as I have tried multiple. It is never consistent in when it happens however, there might be days when this issue does not occur.
As a relatively new forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) is often useful (and this or similar will usually be asked for in Support threads):
inxi -zv8
This gives some (privacy-filtered) information about your system.
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=1e8b7e61-fed3-491a-ae45-9ea12c77c6f0 rw quiet splash
    resume=UUID=1b0cc630-50cd-4356-83c9-92a84ada2995 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Desktop Mobo: ASRock model: X870E Taichi Lite
    serial: <superuser required> uuid: <superuser required> BIOS: American
    Megatrends LLC. v: 3.16 date: 12/18/2024
  System RAM: total: 64 GiB available: 60.41 GiB used: 5.86 GiB (9.7%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 4800 MT/s actual: 3600 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Patriot part-no: 6000 Series serial: <filter>
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
  Device-3: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: N/A level: v4
    note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
    microcode: 0xB404023
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 3663 min/max: 600/5269 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3663 2: 3663 3: 3663
    4: 3663 5: 3663 6: 3663 7: 3663 8: 3663 9: 3663 10: 3663 11: 3663 12: 3663
    13: 3663 14: 3663 15: 3663 16: 3663 bogomips: 150471
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip
    vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
    vendor: ASRock driver: N/A alternate: amdgpu pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 7d:00.0 chip-ID: 1002:13c0 class-ID: 0300
  Device-3: Insta360 Link driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-1.3:5 chip-ID: 2e1a:4c01
    class-ID: 0102
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR+ serial: <filter>
    built: 2023 res: mode: 3440x1440 hz: 240 scale: 114% (1.15) to: 2991x1252
    dpi: 83 gamma: 1.2 chroma: red: x: 0.678 y: 0.322 green: x: 0.255 y: 0.686
    blue: x: 0.145 y: 0.055 white: x: 0.290 y: 0.302
    size: 1048x441mm (41.26x17.36") diag: 1137mm (44.8") modes: 3440x1440,
    1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
    navi31 LLVM 19.1.7 DRM 3.61 6.12.19-1-MANJARO) device-ID: 1002:744c
    memory: 19.53 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XT (RADV NAVI31) driver: N/A device-ID: 1002:744c
    surfaces: xcb,xlib,wayland
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 7d:00.1 chip-ID: 1002:1640 class-ID: 0403
    driver: N/A alternate: snd_hda_intel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 7d:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3
    chip-ID: 26ce:0a0b class-ID: 0300
  Device-5: Focusrite-Novation Scarlett Solo (3rd Gen.)
    driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 9-1.2:4 chip-ID: 1235:8211 class-ID: 0102 serial: <filter>
  Device-6: Insta360 Link driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    class-ID: 0102
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8126 5GbE vendor: ASRock driver: r8169 v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 0b:00.0 chip-ID: 10ec:8126
    class-ID: 0200
  IF: enp11s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK driver: mt7925e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 port: N/A bus-ID: 0c:00.0 chip-ID: 14c3:0717 class-ID: 0280
  IF: wlp12s0 state: down mac: <filter>
  Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-1.1:3
    chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 0e8d:0717
  Local Storage: total: 2.73 TiB used: 697.91 GiB (25.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 33.9 C
    scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 42.9 C
    scheme: GPT
  ID-1: / raw-size: 865.06 GiB size: 850.41 GiB (98.31%)
    used: 36.59 GiB (4.3%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 1e8b7e61-fed3-491a-ae45-9ea12c77c6f0
  ID-2: /run/media/athena/17cfbfe0-c5d3-4868-92c6-725ef83cbab5
    raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 661.32 GiB (36.1%) fs: ext4
    dev: /dev/nvme1n1p1 maj-min: 259:4 label: N/A
    uuid: 17cfbfe0-c5d3-4868-92c6-725ef83cbab5
  ID-1: swap-1 type: partition size: 66.45 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
    uuid: 1b0cc630-50cd-4356-83c9-92a84ada2995
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Compx 2.4G Wireless Receiver type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 260d:1074 class-ID: 0301
  Device-2: 1-6:3 info: Areson Corp Akko 2.4G wireless Keyboard
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 25a7:fa19 class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0717 class-ID: e001 serial: <filter>
  Device-2: 3-8:3 info: Generic USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
  Hub-4: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 9-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
  Device-1: 9-1.1:3 info: Microsoft Xbox Wireless Adapter for Windows
    type: WiFi driver: xone-dongle interfaces: 1 rev: 2.0
  Device-2: 9-1.2:4 info: Focusrite-Novation Scarlett Solo (3rd Gen.)
    type: audio driver: snd-usb-audio interfaces: 4 rev: 2.0
  Device-3: 9-1.3:5 info: Insta360 Link type: video,audio
    chip-ID: 2e1a:4c01 class-ID: 0102
  Device-4: 9-1.4:6 info: Beeprt Printer type: printer driver: usblp
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 09c6:0426 class-ID: 0701 serial: <filter>
  Hub-11: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-12: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 11-1:2 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-13: 12-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 40.0 C mobo: 36.5 C gpu: amdgpu temp: 50.0 C
    mem: 67.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 141
  Packages: 1291 pm: pacman pkgs: 1286 libs: 378 tools: pamac pm: flatpak
    pkgs: 5
    1: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    6: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    7: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    8: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 374
  1: cpu: 7.6% command: [kworker/0:3-pm] pid: 5871 mem: 0.00 MiB (0.0%)
  2: cpu: 7.1% command: firefox pid: 1611 mem: 770.5 MiB (1.2%)
  3: cpu: 5.5% command: Discord pid: 5417 mem: 339.5 MiB (0.5%)
  4: cpu: 4.2% command: konsole pid: 5764 mem: 241.6 MiB (0.3%)
  5: cpu: 2.5% command: firefox pid: 3195 mem: 292.6 MiB (0.4%)
  Memory top: 5 of 374
  1: mem: 770.5 MiB (1.2%) command: firefox pid: 1611 cpu: 7.1%
  2: mem: 617.9 MiB (0.9%) command: firefox pid: 2118 cpu: 1.7%
  3: mem: 539.0 MiB (0.8%) command: plasmashell pid: 1207 cpu: 0.0%
  4: mem: 462.7 MiB (0.7%) command: firefox pid: 2831 cpu: 0.6%
  5: mem: 434.8 MiB (0.7%) command: kwin_wayland pid: 962 cpu: 2.0%
  Processes: 374 Power: uptime: 49m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.14 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Could you create a new User account (for diagnostic purposes) and let us know if these crashes also occur in that account. This may help to rule out local configuration as the culprit.
Will do! It might be some time for me to determine if things are working properly.
Logs can be an indicator of problems that might be contributing. When you next experience the crash, run the following command immediately after you login again; and post the output:
journalctl --boot=-1 --priority=3 --catalog --no-pager
i had this problem and largely fixed it with going to wayland.
The OP is using Wayland.
I agree that Wayland is generally more performant; and I’ve personally never had an issue with it (used for going on two years).
But… many using (particularly older) Nvidia graphics are still experiencing issues from time to time. :man_shrugging:
I have been using my alt test account for a while now and do not seem to be experiencing this issue any longer. Should I just migrate to this account and remove the other one? Still unsure as to what caused this issue in the first place. If I ever do experience this lockup again, I will certainly use that command you posted.
I am using an AMD Radeon RX 7900 XT graphics card. My CPU and chipset are also newer AMD architecture.
Likely a good combination with Wayland. I’m using RX 580 myself, with none of the issues often experienced by Nvidia users.
That there is no problem in a fresh account does infer that the problem is limited to your existing account.
While migrating to a fresh account may be convenient for you, it doesn’t actually solve the issue, and makes this topic useless as a reference for others who might have a similar problem.
In that case, the topic will be closed without a solution.
Whatever you decide (we are not judging), the choice is ultimately yours as the administrator of your system, and the sun will still rise tomorrow morning. :slight_smile:
Let us know, either way.
