I am not sure what info is needed to help with this.
I am on unstable .
This seemed to start when I was building a live usb but I don’t think it has anything to do with it.
Not sure if this helps but also my keyboard is responsive so I can do a alt-fn-prtsc
I was able to shutdown once without a crash.
Here is a partial screen capture
https://i.imgur.com/Rgej4Fm.jpg
Here is my system info
[demo@manjaro ~]$ inxi -Fxxxr
Host: manjaro Kernel: 5.16.10-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.2.0 Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.26 date: 07/09/2021
ID-1: BAT0 charge: 51.4 Wh (76.5%) condition: 67.2/67.2 Wh (100.0%)
volts: 12.2 min: 11.6 model: HP Primary type: Li-ion serial: SerialNumber
status: N/A cycles: 170
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP
smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB
L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 3396 high: 3434 min/max: 400/4900 cores: 1: 3434
2: 3428 3: 3403 4: 3400 5: 3401 6: 3400 7: 3305 8: 3397 bogomips: 36812
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 510.54 bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: 200901010001
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.6
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
class-ID: 0401
Sound Server-1: ALSA v: k5.16.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.46 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: 0c:dd:24:ab:82:13
Local Storage: total: 931.51 GiB used: 170.81 GiB (18.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: S59ANS0N809758J rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-1: / size: 235 GiB used: 48.56 GiB (20.7%) fs: ext4 dev: /dev/nvme0n1p11
ID-2: /boot/efi size: 96 MiB used: 66.7 MiB (69.5%) fs: vfat
dev: /dev/nvme0n1p2
ID-3: /home size: 319.4 GiB used: 122.18 GiB (38.3%) fs: ext4
dev: /dev/nvme0n1p7
System Temperatures: cpu: 68.0 C pch: 53.0 C mobo: N/A
Packages: 1411 pacman: 1404 snap: 7
1: https://mirrors.gigenet.com/manjaro/unstable/$repo/$arch
2: https://mirror.clarkson.edu/manjaro/unstable/$repo/$arch
3: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
4: https://mirrors.sonic.net/manjaro/unstable/$repo/$arch
5: https://mirrors.ocf.berkeley.edu/manjaro/unstable/$repo/$arch
6: https://mirror.math.princeton.edu/pub/manjaro/unstable/$repo/$arch
Processes: 308 Uptime: 4m wakeups: 651 Memory: 15.26 GiB
used: 3.5 GiB (22.9%) Init: systemd v: 250 Compilers: gcc: 11.2.0
clang: 13.0.1 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
